  4. Syntax Error seit Stromausfall
    6.8k
28 Beiträge 9 Kommentatoren 4.0k Aufrufe 10 Beobachtet
  • M markphilip
    seit heute Mittag kurz der Strom weg war bekomme ich meinen Iobroker nicht mehr ans laufen.
    Zugriff per Console habe ich hier die Ausgabe von Iobroker diag
                            v.2024-10-19
     Static hostname: IoBroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-23-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.11.1-0-g0551a4be2c-prebuilt.qemu-project.org
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
    import tar from 'tar';
    SyntaxError: The requested module 'tar' does not provide an export named 'default'
        at ModuleJob._instantiate (node:internal/modules/esm/module_job:146:21)
        at async ModuleJob.run (node:internal/modules/esm/module_job:229:5)
        at async ModuleLoader.import (node:internal/modules/esm/loader:473:24)
    Node.js v20.18.1
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:            3.1G        371M        325M        712K        2.6G        2.7G
    Swap:           3.2G         21M        3.2G
    Total:          6.3G        392M        3.5G
    Active iob-Instances:   0
    Node.js v20.18.1
    Node.js v20.18.1
    ioBroker Core:          js-controller
    Node.js v20.18.1
                            admin
    Node.js v20.18.1
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    0       /opt/iobroker/iobroker-data/objects.json.broken
    8.0K    /opt/iobroker/iobroker-data/states.json.bak
    Operating System is the current Debian stable version codenamed 'bookworm'!
    === Mark text until here for copying ===
    Meister MopperM Online
    Meister Mopper
    @markphilip
    Zeig bitte mal die Langfassung.
    Proxmox und HA ...
      @markphilip
      markphilip
      @meister-mopper
      Script v.2024-10-19
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      OS is similar to:
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       18:33:40 up  5:09,  3 users,  load average: 0.08, 0.09, 0.09
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2025-01-04 18:33:40 CET
                 Universal time: Sat 2025-01-04 17:33:40 UTC
                       RTC time: Sat 2025-01-04 17:33:40
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      mark
      HOME=/home/mark
      GROUPS=mark cdrom floppy sudo audio dip video plugdev netdev iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.1G        346M        344M        704K        2.6G        2.8G
      Swap:           3.2G         21M        3.2G
      Total:          6.3G        367M        3.5G
               2972 M total memory
                330 M used memory
                638 M active memory
               1496 M inactive memory
                328 M free memory
                163 M buffer memory
               2337 M swap cache
               3069 M total swap
                 20 M used swap
               3049 M free swap
      top - 18:33:40 up  5:09,  3 users,  load average: 0.08, 0.09, 0.09
      Tasks:  95 total,   1 running,  94 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   2972.2 total,    328.1 free,    330.8 used,   2501.4 buff/cache
      MiB Swap:   3070.0 total,   3049.6 free,     20.4 used.   2641.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.5G     0  1.5G   0% /dev
      tmpfs          tmpfs     298M  556K  297M   1% /run
      /dev/sda1      ext4       29G   20G  7.9G  71% /
      tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     298M     0  298M   0% /run/user/1000
      [Sat Jan  4 13:23:55 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Jan  4 13:23:56 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      979M    /var/
      542M    /var/log
      516M    /var/log/journal/c4e4bfe1d7c94199919f017b537b1ac0
      235M    /var/cache
      Archived and active journals take up 38.8M in the file system.
      /opt/iobroker/backups:
      115M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.6G    /opt/iobroker/iobroker-data/
      1.4G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian stable/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security stable-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Node.js v20.18.1
      Hosts:
      Node.js v20.18.1
      Core adapters versions
      Node.js v20.18.1
      js-controller:
      Node.js v20.18.1
      admin:
      Node.js v20.18.1
      javascript:
      nodejs modules from github:     1
      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      Adapter State
      ioBroker-Repositories
      Node.js v20.18.1
      Installed ioBroker-Instances
      Node.js v20.18.1
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://security.debian.org/debian-security stable-security InRelease
      Hit:2 http://deb.debian.org/debian stable InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15654      515/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12762      1/systemd
      tcp        0      0 0.0.0.0:9418            0.0.0.0:*               LISTEN      110        103270     23071/git-daemon
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          103234     22998/exim4
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        15827      476/redis-server 12
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15664      515/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          12768      1/systemd
      tcp6       0      0 :::80                   :::*                    LISTEN      0          102711     22610/apache2
      tcp6       0      0 :::9418                 :::*                    LISTEN      110        103271     23071/git-daemon
      tcp6       0      0 ::1:6379                :::*                    LISTEN      108        15828      476/redis-server 12
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          103235     22998/exim4
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        15554      465/avahi-daemon: r
      udp        0      0 0.0.0.0:36253           0.0.0.0:*                           107        15556      465/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14024      349/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12765      1/systemd
      udp6       0      0 :::56189                :::*                                107        15557      465/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                107        15555      465/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          12771      1/systemd
      2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) exit, all done
      2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) timer killed
      2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) Plugin sentry destroyed
      2025-01-04 12:46:02.255  - info: daswetter.0 (3742622) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-01-04 12:46:02.760  - info: daswetter.0 (3742622) cleaned everything up...
      2025-01-04 12:46:02.768  - info: host.IoBroker instance system.adapter.daswetter.0 having pid 3742622 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-01-04 12:48:46.617  - warn: javascript.0 (1458350) You are assigning a number to the state "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
      2025-01-04 12:48:46.622  - warn: javascript.0 (1458350)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
      2025-01-04 12:48:46.625  - warn: javascript.0 (1458350)     at Object.<anonymous> (script.js.Meine_Geräte.Photovoltaik.Verfügbare_Leistung:3:3)
      2025-01-04 12:48:46.625  - warn: javascript.0 (1458350)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at processImmediate (node:internal/timers:483:21)
      2025-01-04 12:48:46.626  - warn: javascript.0 (1458350) You are assigning a number to the state "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
      2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
      2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.<anonymous> (script.js.Meine_Geräte.Photovoltaik.Verfügbare_Leistung:3:3)
      2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-01-04 12:48:46.641  - info: javascript.0 (1458350) State value to set for "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" has to be type "string" but received type "number"
      2025-01-04 12:48:46.642  - info: javascript.0 (1458350) State value to set for "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" has to be type "string" but received type "number"
      2025-01-04 12:49:02.295  - error: hm-rpc.1 (1458491) Cannot call listDevices: socket hang up
      2025-01-04 12:49:04.231  - info: sonoff.0 (1458585) Client [Absaugung] connection closed: closed
      • wendy2702W wendy2702
        @markphilip erster Versuch wäre das:
        iobroker stop
        iobroker fix
        iobroker restart
        markphilip
        @wendy2702
        iobroker fixer läuft durch ändert allerdings nichts. Der Fehler bleibt der gleiche.
        Der Syntax Fehler erscheint auch wenn ich Versuche JS Controller neu zu installieren.
        wendy2702W HomoranH 2 Antworten Letzte Antwort
        • M markphilip
          @wendy2702
          wendy2702W Online
          wendy2702W Online
          @markphilip Dann zeige uns deinen Versuch den JS Controller neu zu installieren mal als log komplett mit ein und Ausgabe der Konsole
            markphilip
            schrieb am zuletzt editiert von markphilip
            @wendy2702 Ich hoffe das ist so richtig
            mark@IoBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
            npm warn skipping integrity check for git dependency ssh://git@github.com/klein0r/ioBroker.comfoairq.git
            npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
            npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
            npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
            npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
            npm warn deprecated npmlog@6.0.2: This package is no longer supported.
            npm warn deprecated @humanwhocodes/config-array@0.13.0: Use @eslint/config-array instead
            npm warn deprecated har-validator@5.1.5: this library is no longer supported
            npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
            npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
            npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
            npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
            npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
            npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
            npm warn deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
            npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
            npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
            npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
            npm warn deprecated gauge@4.0.4: This package is no longer supported.
            npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
            npm warn deprecated sinon@15.2.0: 16.1.1
            npm warn deprecated eslint@8.57.1: This version is no longer supported. Please see https://eslint.org/version-support for other options.
            npm error code 1
            npm error path /opt/iobroker/node_modules/iobroker.js-controller
            npm error command failed
            npm error command sh -c node iobroker.js setup first
            npm error file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
            npm error import tar from 'tar';
            npm error        ^^^
            npm error SyntaxError: The requested module 'tar' does not provide an export named 'default'
            npm error     at ModuleJob._instantiate (node:internal/modules/esm/module_job:146:21)
            npm error     at async ModuleJob.run (node:internal/modules/esm/module_job:229:5)
            npm error     at async ModuleLoader.import (node:internal/modules/esm/loader:473:24)
            npm error
            npm error Node.js v20.18.1
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log
            mark@IoBroker:/opt/iobroker$ /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log
            -bash: /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log: Keine Berechtigung
            • wendy2702W Online
              wendy2702W Online
              Hm,
              Fällt mir auf die schnelle nichts zu ein.
              Vielleicht hat @Thomas-Braun eine Idee.
              • M markphilip
                @wendy2702
                @markphilip sagte in Syntax Error seit Stromausfall:
                welcher Syntaxfehler?
                  markphilip
                  @homoran hi oben im ersten Post im Code:
                  • M markphilip
                    @markphilip
                    Achso, im iob diag.
                    Hatte ich mir gar nicht angesehen weil nur Summary.
                    laut letztem debug-log ist da noch einiges mehr kaputt, und diese Meldung wohl nur eine Folge davon
                      @markphilip
                      Achso, im iob diag.
                      markphilip
                      @homoran ok eine Idee was ich machen kann oder soll ich das System einmal neu aufsetzen?
                      • M markphilip
                        leider nein, das ist weit über meinen skills.
                        das würde ich jetzt machen, aber vielleicht hat @thomas-braun eine Idee, oder gar Lust das zu fixen, wenn möglich.
                        • M markphilip
                                                  v.2024-10-19
                                   Chassis: vm 🖴
                            Virtualization: kvm
                          Installation:           kvm
                          Kernel:                 x86_64
                          Userland:               64 bit
                          User-ID:                1000
                          Node.js v20.18.1
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          MEMORY:
                          Swap:           3.2G         21M        3.2G
                          Node.js v20.18.1
                          Node.js v20.18.1
                          Node.js v20.18.1
                                                  admin
                          Node.js v20.18.1
                          ioBroker Status:
                          Objects:                0
                          States:                 0
                          @markphilip
                          da das ne VM ist, wuerd ich einfach das letzte Backup der VM wieder einspielen.
                          Da hats was in deinem System geschossen.. hoffentlich ist nicht die Platte im Eimer.. hast du noch mehr VM's laufen?
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            @ALLE
                            liest doch mal ALLE das diag richtig
                            Objects:                0
                            States:                 0
                            da ist NIX an objekten und states.. was soll dann da laufen
                            @markphilip
                            hoffe du hast ein backup.. sonst schaumal in den iobroker-data ordner da sollte eine objects.bak und eine states.bak liegen.. und die sollten grösser sein als die entsprechenden jsonl's
                            sonst hilft dir nur backup zurück
                            • arteckA arteck
                              @ALLE
                              Objects:                0
                              States:                 0
                              @markphilip
                              wendy2702W Online
                              wendy2702W Online
                              @arteck soll das jetzt die Erklärung für den Syntax Fehler sein oder was?
                                @wendy2702
                                Schlechte Laune? Geh mal an die Luft... :)
                                Wenn du weiter liest, siehst du, was passiert ist und warum das so ist.
                                  @wendy2702
                                  wendy2702W Online
                                  wendy2702W Online
                                  @ilovegym keine schlechte Laune.
                                  Hätte es nur gerne vernünftig erklärt wenn man schon schreibt wir würden alle nicht richtig lesen.
                                  Vor allem warum es beim Versuch den Controller neu zu installieren immer noch zum Syntax Fehler kommt.
                                    @wendy2702
                                    Nehme an, dass es das Dateisystem zerrissen hat..
                                    das kann uns aber auch nur der TE erklären..
                                    Vielleicht war auch schon vorher was krumm und jetzt ist es endgültig durch…
                                      @wendy2702
                                      @ilovegym sagte in Syntax Error seit Stromausfall:
                                      ich auch
                                      Deswegen war meine Meinung
                                      @homoran sagte in Syntax Error seit Stromausfall:
                                      • wendy2702W Online
                                        wendy2702W Online
                                        Ja,
                                        Dateisystem zerrissen ist gut möglich und wahrscheinlich. Mir erschließt sich nur gerade nicht wie man das an dem Status: "Objects & States" fest machen kann und was der Status "Objects & States" an der Stelle mit dem Syntax error zu tun hat.
                                        Aber ist jetzt auch egal. Ich hoffe der TE hat ein Backup.
                                        ? arteckA 2 Antworten Letzte Antwort
                                          Ja,
                                          @wendy2702
                                          naja der erwartet anstatt das "tar" ein andere variable, evtl. eine Zahl, und daher kommt dann der Syntax error.
                                          wenn in den Objekts und States nix drin steht, dann kann er auch nix auslesen.. das wird dann als syntax error interpretiert.. vielleichit verwirrend aber so erklaer ich es mir..
                                          bei so einem Fehler soll man sich keine Gedanken machen und auch keine Zeit verschwenden, einfach Restore vom letzten Image und gut ist..
