  4. Syntax Error seit Stromausfall
    6.8k
28 Beiträge 9 Kommentatoren 4.0k Aufrufe 10 Beobachtet
  • M markphilip
    seit heute Mittag kurz der Strom weg war bekomme ich meinen Iobroker nicht mehr ans laufen.
    Zugriff per Console habe ich hier die Ausgabe von Iobroker diag
                            v.2024-10-19
     Static hostname: IoBroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-23-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.11.1-0-g0551a4be2c-prebuilt.qemu-project.org
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
    import tar from 'tar';
    SyntaxError: The requested module 'tar' does not provide an export named 'default'
        at ModuleJob._instantiate (node:internal/modules/esm/module_job:146:21)
        at async ModuleJob.run (node:internal/modules/esm/module_job:229:5)
        at async ModuleLoader.import (node:internal/modules/esm/loader:473:24)
    Node.js v20.18.1
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:            3.1G        371M        325M        712K        2.6G        2.7G
    Swap:           3.2G         21M        3.2G
    Total:          6.3G        392M        3.5G
    Active iob-Instances:   0
    Node.js v20.18.1
    Node.js v20.18.1
    ioBroker Core:          js-controller
    Node.js v20.18.1
                            admin
    Node.js v20.18.1
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    0       /opt/iobroker/iobroker-data/objects.json.broken
    8.0K    /opt/iobroker/iobroker-data/states.json.bak
    Operating System is the current Debian stable version codenamed 'bookworm'!
    === Mark text until here for copying ===
    wendy2702W Online
    wendy2702W Online
    @markphilip erster Versuch wäre das:
    iobroker stop
    iobroker fix
    iobroker restart
    • M markphilip
                              v.2024-10-19
               Chassis: vm 🖴
        Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1000
      Node.js v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
      Swap:           3.2G         21M        3.2G
      Node.js v20.18.1
      Node.js v20.18.1
      Node.js v20.18.1
                              admin
      Node.js v20.18.1
      ioBroker Status:
      Objects:                0
      States:                 0
      Meister MopperM Online
      Meister Mopper
      @markphilip
      Zeig bitte mal die Langfassung.
      Proxmox und HA ...
        @markphilip
        markphilip
        @meister-mopper
        Script v.2024-10-19
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        OS is similar to:
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         18:33:40 up  5:09,  3 users,  load average: 0.08, 0.09, 0.09
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        *** TIME AND TIMEZONES ***
                       Local time: Sat 2025-01-04 18:33:40 CET
                   Universal time: Sat 2025-01-04 17:33:40 UTC
                         RTC time: Sat 2025-01-04 17:33:40
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        mark
        HOME=/home/mark
        GROUPS=mark cdrom floppy sudo audio dip video plugdev netdev iobroker
        js-controller is not running
        *** DISPLAY-SERVER SETUP ***
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.1G        346M        344M        704K        2.6G        2.8G
        Swap:           3.2G         21M        3.2G
        Total:          6.3G        367M        3.5G
                 2972 M total memory
                  330 M used memory
                  638 M active memory
                 1496 M inactive memory
                  328 M free memory
                  163 M buffer memory
                 2337 M swap cache
                 3069 M total swap
                   20 M used swap
                 3049 M free swap
        top - 18:33:40 up  5:09,  3 users,  load average: 0.08, 0.09, 0.09
        Tasks:  95 total,   1 running,  94 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   2972.2 total,    328.1 free,    330.8 used,   2501.4 buff/cache
        MiB Swap:   3070.0 total,   3049.6 free,     20.4 used.   2641.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.5G     0  1.5G   0% /dev
        tmpfs          tmpfs     298M  556K  297M   1% /run
        /dev/sda1      ext4       29G   20G  7.9G  71% /
        tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     298M     0  298M   0% /run/user/1000
        [Sat Jan  4 13:23:55 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Jan  4 13:23:56 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        979M    /var/
        542M    /var/log
        516M    /var/log/journal/c4e4bfe1d7c94199919f017b537b1ac0
        235M    /var/cache
        Archived and active journals take up 38.8M in the file system.
        /opt/iobroker/backups:
        115M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.6G    /opt/iobroker/iobroker-data/
        1.4G    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
        24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian stable/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security stable-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Node.js v20.18.1
        Hosts:
        Node.js v20.18.1
        Core adapters versions
        Node.js v20.18.1
        js-controller:
        Node.js v20.18.1
        admin:
        Node.js v20.18.1
        javascript:
        nodejs modules from github:     1
        |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
        Adapter State
        ioBroker-Repositories
        Node.js v20.18.1
        Installed ioBroker-Instances
        Node.js v20.18.1
        Objects and States
        Objects:        0
        States:         0
        Hit:1 http://security.debian.org/debian-security stable-security InRelease
        Hit:2 http://deb.debian.org/debian stable InRelease
        Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15654      515/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12762      1/systemd
        tcp        0      0 0.0.0.0:9418            0.0.0.0:*               LISTEN      110        103270     23071/git-daemon
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          103234     22998/exim4
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        15827      476/redis-server 12
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15664      515/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          12768      1/systemd
        tcp6       0      0 :::80                   :::*                    LISTEN      0          102711     22610/apache2
        tcp6       0      0 :::9418                 :::*                    LISTEN      110        103271     23071/git-daemon
        tcp6       0      0 ::1:6379                :::*                    LISTEN      108        15828      476/redis-server 12
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          103235     22998/exim4
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        15554      465/avahi-daemon: r
        udp        0      0 0.0.0.0:36253           0.0.0.0:*                           107        15556      465/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14024      349/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12765      1/systemd
        udp6       0      0 :::56189                :::*                                107        15557      465/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                107        15555      465/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          12771      1/systemd
        2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) exit, all done
        2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) timer killed
        2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) Plugin sentry destroyed
        2025-01-04 12:46:02.255  - info: daswetter.0 (3742622) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2025-01-04 12:46:02.760  - info: daswetter.0 (3742622) cleaned everything up...
        2025-01-04 12:46:02.768  - info: host.IoBroker instance system.adapter.daswetter.0 having pid 3742622 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-01-04 12:48:46.617  - warn: javascript.0 (1458350) You are assigning a number to the state "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
        2025-01-04 12:48:46.622  - warn: javascript.0 (1458350)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
        2025-01-04 12:48:46.625  - warn: javascript.0 (1458350)     at Object.<anonymous> (script.js.Meine_Geräte.Photovoltaik.Verfügbare_Leistung:3:3)
        2025-01-04 12:48:46.625  - warn: javascript.0 (1458350)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
        2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at processImmediate (node:internal/timers:483:21)
        2025-01-04 12:48:46.626  - warn: javascript.0 (1458350) You are assigning a number to the state "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
        2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
        2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.<anonymous> (script.js.Meine_Geräte.Photovoltaik.Verfügbare_Leistung:3:3)
        2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2025-01-04 12:48:46.641  - info: javascript.0 (1458350) State value to set for "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" has to be type "string" but received type "number"
        2025-01-04 12:48:46.642  - info: javascript.0 (1458350) State value to set for "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" has to be type "string" but received type "number"
        2025-01-04 12:49:02.295  - error: hm-rpc.1 (1458491) Cannot call listDevices: socket hang up
        2025-01-04 12:49:04.231  - info: sonoff.0 (1458585) Client [Absaugung] connection closed: closed
        • wendy2702W wendy2702
          iobroker stop
          iobroker fix
          iobroker restart
          markphilip
          @wendy2702
          iobroker fixer läuft durch ändert allerdings nichts. Der Fehler bleibt der gleiche.
          Der Syntax Fehler erscheint auch wenn ich Versuche JS Controller neu zu installieren.
          wendy2702W HomoranH 2 Antworten Letzte Antwort
          • M markphilip
            @wendy2702
            wendy2702W Online
            wendy2702W Online
            @markphilip Dann zeige uns deinen Versuch den JS Controller neu zu installieren mal als log komplett mit ein und Ausgabe der Konsole
              markphilip
              schrieb am zuletzt editiert von markphilip
              @wendy2702 Ich hoffe das ist so richtig
              mark@IoBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
              npm warn skipping integrity check for git dependency ssh://git@github.com/klein0r/ioBroker.comfoairq.git
              npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
              npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
              npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
              npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
              npm warn deprecated npmlog@6.0.2: This package is no longer supported.
              npm warn deprecated @humanwhocodes/config-array@0.13.0: Use @eslint/config-array instead
              npm warn deprecated har-validator@5.1.5: this library is no longer supported
              npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
              npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
              npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
              npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
              npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
              npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
              npm warn deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
              npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
              npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
              npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
              npm warn deprecated gauge@4.0.4: This package is no longer supported.
              npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
              npm warn deprecated sinon@15.2.0: 16.1.1
              npm warn deprecated eslint@8.57.1: This version is no longer supported. Please see https://eslint.org/version-support for other options.
              npm error code 1
              npm error path /opt/iobroker/node_modules/iobroker.js-controller
              npm error command failed
              npm error command sh -c node iobroker.js setup first
              npm error file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
              npm error import tar from 'tar';
              npm error        ^^^
              npm error SyntaxError: The requested module 'tar' does not provide an export named 'default'
              npm error     at ModuleJob._instantiate (node:internal/modules/esm/module_job:146:21)
              npm error     at async ModuleJob.run (node:internal/modules/esm/module_job:229:5)
              npm error     at async ModuleLoader.import (node:internal/modules/esm/loader:473:24)
              npm error
              npm error Node.js v20.18.1
              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log
              mark@IoBroker:/opt/iobroker$ /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log
              -bash: /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log: Keine Berechtigung
              • wendy2702W Online
                wendy2702W Online
                Hm,
                Fällt mir auf die schnelle nichts zu ein.
                Vielleicht hat @Thomas-Braun eine Idee.
                • M markphilip
                  @wendy2702
                  @markphilip sagte in Syntax Error seit Stromausfall:
                  welcher Syntaxfehler?
                    markphilip
                    @homoran hi oben im ersten Post im Code:
                    • M markphilip
                      @markphilip
                      Achso, im iob diag.
                      Hatte ich mir gar nicht angesehen weil nur Summary.
                      laut letztem debug-log ist da noch einiges mehr kaputt, und diese Meldung wohl nur eine Folge davon
                        @markphilip
                        Achso, im iob diag.
                        markphilip
                        @homoran ok eine Idee was ich machen kann oder soll ich das System einmal neu aufsetzen?
                        • M markphilip
                          leider nein, das ist weit über meinen skills.
                          das würde ich jetzt machen, aber vielleicht hat @thomas-braun eine Idee, oder gar Lust das zu fixen, wenn möglich.
                          • M markphilip
                                                    v.2024-10-19
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            Installation:           kvm
                            Kernel:                 x86_64
                            Userland:               64 bit
                            User-ID:                1000
                            Node.js v20.18.1
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            MEMORY:
                            Swap:           3.2G         21M        3.2G
                            Node.js v20.18.1
                            Node.js v20.18.1
                            Node.js v20.18.1
                                                    admin
                            Node.js v20.18.1
                            ioBroker Status:
                            Objects:                0
                            States:                 0
                            @markphilip
                            da das ne VM ist, wuerd ich einfach das letzte Backup der VM wieder einspielen.
                            Da hats was in deinem System geschossen.. hoffentlich ist nicht die Platte im Eimer.. hast du noch mehr VM's laufen?
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              @ALLE
                              liest doch mal ALLE das diag richtig
                              Objects:                0
                              States:                 0
                              da ist NIX an objekten und states.. was soll dann da laufen
                              @markphilip
                              hoffe du hast ein backup.. sonst schaumal in den iobroker-data ordner da sollte eine objects.bak und eine states.bak liegen.. und die sollten grösser sein als die entsprechenden jsonl's
                              sonst hilft dir nur backup zurück
                              • arteckA arteck
                                @ALLE
                                Objects:                0
                                States:                 0
                                @markphilip
                                wendy2702W Online
                                wendy2702W Online
                                @arteck soll das jetzt die Erklärung für den Syntax Fehler sein oder was?
                                  @wendy2702
                                  Schlechte Laune? Geh mal an die Luft... :)
                                  Wenn du weiter liest, siehst du, was passiert ist und warum das so ist.
                                    @wendy2702
                                    wendy2702W Online
                                    wendy2702W Online
                                    @ilovegym keine schlechte Laune.
                                    Hätte es nur gerne vernünftig erklärt wenn man schon schreibt wir würden alle nicht richtig lesen.
                                    Vor allem warum es beim Versuch den Controller neu zu installieren immer noch zum Syntax Fehler kommt.
                                      @wendy2702
                                      Nehme an, dass es das Dateisystem zerrissen hat..
                                      das kann uns aber auch nur der TE erklären..
                                      Vielleicht war auch schon vorher was krumm und jetzt ist es endgültig durch…
                                        @wendy2702
                                        @ilovegym sagte in Syntax Error seit Stromausfall:
                                        ich auch
                                        Deswegen war meine Meinung
                                        @homoran sagte in Syntax Error seit Stromausfall:
                                        • wendy2702W Online
                                          wendy2702W Online
                                          Ja,
                                          Dateisystem zerrissen ist gut möglich und wahrscheinlich. Mir erschließt sich nur gerade nicht wie man das an dem Status: "Objects & States" fest machen kann und was der Status "Objects & States" an der Stelle mit dem Syntax error zu tun hat.
                                          Aber ist jetzt auch egal. Ich hoffe der TE hat ein Backup.
                                          ? arteckA 2 Antworten Letzte Antwort
