  4. Syntax Error seit Stromausfall
    6.8k
28 Beiträge 9 Kommentatoren 4.0k Aufrufe 10 Beobachtet
    @markphilip
    Zeig bitte mal die Langfassung.
    markphilip
    @meister-mopper
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: IoBroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-23-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.11.1-0-g0551a4be2c-prebuilt.qemu-project.org
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     18:33:40 up  5:09,  3 users,  load average: 0.08, 0.09, 0.09
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-01-04 18:33:40 CET
               Universal time: Sat 2025-01-04 17:33:40 UTC
                     RTC time: Sat 2025-01-04 17:33:40
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    mark
    HOME=/home/mark
    GROUPS=mark cdrom floppy sudo audio dip video plugdev netdev iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.1G        346M        344M        704K        2.6G        2.8G
    Swap:           3.2G         21M        3.2G
    Total:          6.3G        367M        3.5G
    Active iob-Instances:   0
             2972 M total memory
              330 M used memory
              638 M active memory
             1496 M inactive memory
              328 M free memory
              163 M buffer memory
             2337 M swap cache
             3069 M total swap
               20 M used swap
             3049 M free swap
    top - 18:33:40 up  5:09,  3 users,  load average: 0.08, 0.09, 0.09
    Tasks:  95 total,   1 running,  94 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   2972.2 total,    328.1 free,    330.8 used,   2501.4 buff/cache
    MiB Swap:   3070.0 total,   3049.6 free,     20.4 used.   2641.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.5G     0  1.5G   0% /dev
    tmpfs          tmpfs     298M  556K  297M   1% /run
    /dev/sda1      ext4       29G   20G  7.9G  71% /
    tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     298M     0  298M   0% /run/user/1000
    [Sat Jan  4 13:23:55 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Jan  4 13:23:56 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    979M    /var/
    542M    /var/log
    516M    /var/log/journal/c4e4bfe1d7c94199919f017b537b1ac0
    235M    /var/cache
    Archived and active journals take up 38.8M in the file system.
    /opt/iobroker/backups:
    115M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.6G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian stable/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security stable-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
    import tar from 'tar';
    SyntaxError: The requested module 'tar' does not provide an export named 'default'
        at ModuleJob._instantiate (node:internal/modules/esm/module_job:146:21)
        at async ModuleJob.run (node:internal/modules/esm/module_job:229:5)
        at async ModuleLoader.import (node:internal/modules/esm/loader:473:24)
    Node.js v20.18.1
    Hosts:
    Node.js v20.18.1
    Core adapters versions
    Node.js v20.18.1
    js-controller:
    Node.js v20.18.1
    admin:
    Node.js v20.18.1
    javascript:
    nodejs modules from github:     1
    |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
    Adapter State
    ioBroker-Repositories
    Node.js v20.18.1
    Installed ioBroker-Instances
    Node.js v20.18.1
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://security.debian.org/debian-security stable-security InRelease
    Hit:2 http://deb.debian.org/debian stable InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15654      515/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12762      1/systemd
    tcp        0      0 0.0.0.0:9418            0.0.0.0:*               LISTEN      110        103270     23071/git-daemon
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          103234     22998/exim4
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        15827      476/redis-server 12
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15664      515/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          12768      1/systemd
    tcp6       0      0 :::80                   :::*                    LISTEN      0          102711     22610/apache2
    tcp6       0      0 :::9418                 :::*                    LISTEN      110        103271     23071/git-daemon
    tcp6       0      0 ::1:6379                :::*                    LISTEN      108        15828      476/redis-server 12
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          103235     22998/exim4
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        15554      465/avahi-daemon: r
    udp        0      0 0.0.0.0:36253           0.0.0.0:*                           107        15556      465/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14024      349/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12765      1/systemd
    udp6       0      0 :::56189                :::*                                107        15557      465/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                107        15555      465/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          12771      1/systemd
    2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) exit, all done
    2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) timer killed
    2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) Plugin sentry destroyed
    2025-01-04 12:46:02.255  - info: daswetter.0 (3742622) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-01-04 12:46:02.760  - info: daswetter.0 (3742622) cleaned everything up...
    2025-01-04 12:46:02.768  - info: host.IoBroker instance system.adapter.daswetter.0 having pid 3742622 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-04 12:48:46.617  - warn: javascript.0 (1458350) You are assigning a number to the state "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    2025-01-04 12:48:46.622  - warn: javascript.0 (1458350)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
    2025-01-04 12:48:46.625  - warn: javascript.0 (1458350)     at Object.<anonymous> (script.js.Meine_Geräte.Photovoltaik.Verfügbare_Leistung:3:3)
    2025-01-04 12:48:46.625  - warn: javascript.0 (1458350)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
    2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at processImmediate (node:internal/timers:483:21)
    2025-01-04 12:48:46.626  - warn: javascript.0 (1458350) You are assigning a number to the state "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
    2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.<anonymous> (script.js.Meine_Geräte.Photovoltaik.Verfügbare_Leistung:3:3)
    2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2025-01-04 12:48:46.641  - info: javascript.0 (1458350) State value to set for "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" has to be type "string" but received type "number"
    2025-01-04 12:48:46.642  - info: javascript.0 (1458350) State value to set for "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" has to be type "string" but received type "number"
    2025-01-04 12:49:02.295  - error: hm-rpc.1 (1458491) Cannot call listDevices: socket hang up
    2025-01-04 12:49:04.231  - info: sonoff.0 (1458585) Client [Absaugung] connection closed: closed
    • wendy2702W wendy2702
      @markphilip erster Versuch wäre das:
      iobroker stop
      iobroker fix
      iobroker restart
      markphilip
      @wendy2702
      iobroker fixer läuft durch ändert allerdings nichts. Der Fehler bleibt der gleiche.
      Der Syntax Fehler erscheint auch wenn ich Versuche JS Controller neu zu installieren.
      wendy2702W HomoranH 2 Antworten Letzte Antwort
      • M markphilip
        @wendy2702
        wendy2702W Online
        wendy2702W Online
        @markphilip Dann zeige uns deinen Versuch den JS Controller neu zu installieren mal als log komplett mit ein und Ausgabe der Konsole
          markphilip
          schrieb am zuletzt editiert von markphilip
          @wendy2702 Ich hoffe das ist so richtig
          mark@IoBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
          npm warn skipping integrity check for git dependency ssh://git@github.com/klein0r/ioBroker.comfoairq.git
          npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
          npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
          npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
          npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
          npm warn deprecated npmlog@6.0.2: This package is no longer supported.
          npm warn deprecated @humanwhocodes/config-array@0.13.0: Use @eslint/config-array instead
          npm warn deprecated har-validator@5.1.5: this library is no longer supported
          npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
          npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
          npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
          npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
          npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
          npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
          npm warn deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
          npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
          npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
          npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
          npm warn deprecated gauge@4.0.4: This package is no longer supported.
          npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
          npm warn deprecated sinon@15.2.0: 16.1.1
          npm warn deprecated eslint@8.57.1: This version is no longer supported. Please see https://eslint.org/version-support for other options.
          npm error code 1
          npm error path /opt/iobroker/node_modules/iobroker.js-controller
          npm error command failed
          npm error command sh -c node iobroker.js setup first
          npm error file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
          npm error import tar from 'tar';
          npm error        ^^^
          npm error SyntaxError: The requested module 'tar' does not provide an export named 'default'
          npm error     at ModuleJob._instantiate (node:internal/modules/esm/module_job:146:21)
          npm error     at async ModuleJob.run (node:internal/modules/esm/module_job:229:5)
          npm error     at async ModuleLoader.import (node:internal/modules/esm/loader:473:24)
          npm error
          npm error Node.js v20.18.1
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log
          mark@IoBroker:/opt/iobroker$ /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log
          -bash: /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log: Keine Berechtigung
          • wendy2702W Online
            wendy2702W Online
            Hm,
            Fällt mir auf die schnelle nichts zu ein.
            Vielleicht hat @Thomas-Braun eine Idee.
            • M markphilip
              @wendy2702
              @markphilip sagte in Syntax Error seit Stromausfall:
              welcher Syntaxfehler?
                markphilip
                @homoran hi oben im ersten Post im Code:
                • M markphilip
                  @markphilip
                  Achso, im iob diag.
                  Hatte ich mir gar nicht angesehen weil nur Summary.
                  laut letztem debug-log ist da noch einiges mehr kaputt, und diese Meldung wohl nur eine Folge davon
                    @markphilip
                    Achso, im iob diag.
                    markphilip
                    @homoran ok eine Idee was ich machen kann oder soll ich das System einmal neu aufsetzen?
                    • M markphilip
                      leider nein, das ist weit über meinen skills.
                      das würde ich jetzt machen, aber vielleicht hat @thomas-braun eine Idee, oder gar Lust das zu fixen, wenn möglich.
                      • M markphilip
                        seit heute Mittag kurz der Strom weg war bekomme ich meinen Iobroker nicht mehr ans laufen.
                        Zugriff per Console habe ich hier die Ausgabe von Iobroker diag
                                                v.2024-10-19
                                 Chassis: vm 🖴
                          Virtualization: kvm
                        Installation:           kvm
                        Kernel:                 x86_64
                        Userland:               64 bit
                        Timezone:               Europe/Berlin (CET, +0100)
                        User-ID:                1000
                        Boot Target:            multi-user.target
                        Pending OS-Updates:     0
                        Node.js v20.18.1
                        Pending iob updates:    0
                        Nodejs-Installation:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        Recommended versions are nodejs  and npm
                        nodeJS installation is correct
                        MEMORY:
                        Mem:            3.1G        371M        325M        712K        2.6G        2.7G
                        Swap:           3.2G         21M        3.2G
                        Total:          6.3G        392M        3.5G
                        Node.js v20.18.1
                        Node.js v20.18.1
                        ioBroker Core:          js-controller
                        Node.js v20.18.1
                                                admin
                        Node.js v20.18.1
                        ioBroker Status:
                        Objects:                0
                        States:                 0
                        Size of iob-Database:
                        15M     /opt/iobroker/iobroker-data/objects.jsonl
                        11M     /opt/iobroker/iobroker-data/objects.json.migrated
                        11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                        0       /opt/iobroker/iobroker-data/objects.json.broken
                        8.0K    /opt/iobroker/iobroker-data/states.json.bak
                        === Mark text until here for copying ===
                        @markphilip
                        da das ne VM ist, wuerd ich einfach das letzte Backup der VM wieder einspielen.
                        Da hats was in deinem System geschossen.. hoffentlich ist nicht die Platte im Eimer.. hast du noch mehr VM's laufen?
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          @ALLE
                          liest doch mal ALLE das diag richtig
                          Objects:                0
                          States:                 0
                          da ist NIX an objekten und states.. was soll dann da laufen
                          @markphilip
                          hoffe du hast ein backup.. sonst schaumal in den iobroker-data ordner da sollte eine objects.bak und eine states.bak liegen.. und die sollten grösser sein als die entsprechenden jsonl's
                          sonst hilft dir nur backup zurück
                          • arteckA arteck
                            @ALLE
                            Objects:                0
                            States:                 0
                            @markphilip
                            wendy2702W Online
                            wendy2702W Online
                            @arteck soll das jetzt die Erklärung für den Syntax Fehler sein oder was?
                              @wendy2702
                              Schlechte Laune? Geh mal an die Luft... :)
                              Wenn du weiter liest, siehst du, was passiert ist und warum das so ist.
                                @wendy2702
                                wendy2702W Online
                                wendy2702W Online
                                @ilovegym keine schlechte Laune.
                                Hätte es nur gerne vernünftig erklärt wenn man schon schreibt wir würden alle nicht richtig lesen.
                                Vor allem warum es beim Versuch den Controller neu zu installieren immer noch zum Syntax Fehler kommt.
                                  @wendy2702
                                  Nehme an, dass es das Dateisystem zerrissen hat..
                                  das kann uns aber auch nur der TE erklären..
                                  Vielleicht war auch schon vorher was krumm und jetzt ist es endgültig durch…
                                    @wendy2702
                                    @ilovegym sagte in Syntax Error seit Stromausfall:
                                    ich auch
                                    Deswegen war meine Meinung
                                    @homoran sagte in Syntax Error seit Stromausfall:
                                    • wendy2702W Online
                                      wendy2702W Online
                                      Ja,
                                      Dateisystem zerrissen ist gut möglich und wahrscheinlich. Mir erschließt sich nur gerade nicht wie man das an dem Status: "Objects & States" fest machen kann und was der Status "Objects & States" an der Stelle mit dem Syntax error zu tun hat.
                                      Aber ist jetzt auch egal. Ich hoffe der TE hat ein Backup.
                                      ? arteckA 2 Antworten Letzte Antwort
                                        Ja,
                                        @wendy2702
                                        naja der erwartet anstatt das "tar" ein andere variable, evtl. eine Zahl, und daher kommt dann der Syntax error.
                                        wenn in den Objekts und States nix drin steht, dann kann er auch nix auslesen.. das wird dann als syntax error interpretiert.. vielleichit verwirrend aber so erklaer ich es mir..
                                        bei so einem Fehler soll man sich keine Gedanken machen und auch keine Zeit verschwenden, einfach Restore vom letzten Image und gut ist..
                                          Ja,
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @wendy2702 sagte in Syntax Error seit Stromausfall:
                                          wie soll ein system starten wen NIX aber auch NIX konfiguriert ist.. wenn ich dir sage dass die Datenbank des iobroker kaputt ist hilft dir das weiter ??
                                          es müssen zumindest standart Einstellungen da stehen aber da ist NIX = 0 drin
                                          da hilft auch nix wenn du den js-controller neu installierst..
