  4. Syntax Error seit Stromausfall
    6.8k
28 Beiträge 9 Kommentatoren 4.0k Aufrufe 10 Beobachtet
  • M markphilip
    seit heute Mittag kurz der Strom weg war bekomme ich meinen Iobroker nicht mehr ans laufen.
    Zugriff per Console habe ich hier die Ausgabe von Iobroker diag
                            v.2024-10-19
     Static hostname: IoBroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-23-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.11.1-0-g0551a4be2c-prebuilt.qemu-project.org
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
    import tar from 'tar';
    SyntaxError: The requested module 'tar' does not provide an export named 'default'
        at ModuleJob._instantiate (node:internal/modules/esm/module_job:146:21)
        at async ModuleJob.run (node:internal/modules/esm/module_job:229:5)
        at async ModuleLoader.import (node:internal/modules/esm/loader:473:24)
    Node.js v20.18.1
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:            3.1G        371M        325M        712K        2.6G        2.7G
    Swap:           3.2G         21M        3.2G
    Total:          6.3G        392M        3.5G
    Active iob-Instances:   0
    Node.js v20.18.1
    Node.js v20.18.1
    ioBroker Core:          js-controller
    Node.js v20.18.1
                            admin
    Node.js v20.18.1
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    0       /opt/iobroker/iobroker-data/objects.json.broken
    8.0K    /opt/iobroker/iobroker-data/states.json.bak
    Operating System is the current Debian stable version codenamed 'bookworm'!
    === Mark text until here for copying ===
    @markphilip
    da das ne VM ist, wuerd ich einfach das letzte Backup der VM wieder einspielen.
    Da hats was in deinem System geschossen.. hoffentlich ist nicht die Platte im Eimer.. hast du noch mehr VM's laufen?
    • arteckA Offline
      arteckA Offline
      arteck
      @ALLE
      liest doch mal ALLE das diag richtig
      Objects:                0
      States:                 0
      da ist NIX an objekten und states.. was soll dann da laufen
      @markphilip
      hoffe du hast ein backup.. sonst schaumal in den iobroker-data ordner da sollte eine objects.bak und eine states.bak liegen.. und die sollten grösser sein als die entsprechenden jsonl's
      sonst hilft dir nur backup zurück
      • arteckA arteck
        @ALLE
        Objects:                0
        States:                 0
        @markphilip
        wendy2702W Online
        wendy2702W Online
        @arteck soll das jetzt die Erklärung für den Syntax Fehler sein oder was?
        • wendy2702W wendy2702
          @wendy2702
          Schlechte Laune? Geh mal an die Luft... :)
          Wenn du weiter liest, siehst du, was passiert ist und warum das so ist.
            @wendy2702
            wendy2702W Online
            wendy2702W Online
            @ilovegym keine schlechte Laune.
            Hätte es nur gerne vernünftig erklärt wenn man schon schreibt wir würden alle nicht richtig lesen.
            Vor allem warum es beim Versuch den Controller neu zu installieren immer noch zum Syntax Fehler kommt.
              @wendy2702
              Nehme an, dass es das Dateisystem zerrissen hat..
              das kann uns aber auch nur der TE erklären..
              Vielleicht war auch schon vorher was krumm und jetzt ist es endgültig durch…
                @wendy2702
                @ilovegym sagte in Syntax Error seit Stromausfall:
                ich auch
                Deswegen war meine Meinung
                @homoran sagte in Syntax Error seit Stromausfall:
                laut letztem debug-log ist da noch einiges mehr kaputt, und diese Meldung wohl nur eine Folge davon
                • wendy2702W Online
                  wendy2702W Online
                  Ja,
                  Dateisystem zerrissen ist gut möglich und wahrscheinlich. Mir erschließt sich nur gerade nicht wie man das an dem Status: "Objects & States" fest machen kann und was der Status "Objects & States" an der Stelle mit dem Syntax error zu tun hat.
                  Aber ist jetzt auch egal. Ich hoffe der TE hat ein Backup.
                  ? arteckA 2 Antworten Letzte Antwort
                    Ja,
                    @wendy2702
                    naja der erwartet anstatt das "tar" ein andere variable, evtl. eine Zahl, und daher kommt dann der Syntax error.
                    wenn in den Objekts und States nix drin steht, dann kann er auch nix auslesen.. das wird dann als syntax error interpretiert.. vielleichit verwirrend aber so erklaer ich es mir..
                    bei so einem Fehler soll man sich keine Gedanken machen und auch keine Zeit verschwenden, einfach Restore vom letzten Image und gut ist..
                      Ja,
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @wendy2702 sagte in Syntax Error seit Stromausfall:
                      wie soll ein system starten wen NIX aber auch NIX konfiguriert ist.. wenn ich dir sage dass die Datenbank des iobroker kaputt ist hilft dir das weiter ??
                      es müssen zumindest standart Einstellungen da stehen aber da ist NIX = 0 drin
                      da hilft auch nix wenn du den js-controller neu installierst..
                      • Z Offline
                        Z Offline
                        ZeroQool
                        Also ich habe genau das gleiche Problem. Der ioBroker fährt sogar gar nicht hoch. Ich muss die Import Referenz hier ändern: /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js dann fährt der ioBroker hoch, aber ich habe dennoch Probleme Adapter zu installieren. Denn dort kommt die gleiche TAR Fehlermeldung.
                        Verfügbar js-controller:7.0.6
                        Installiert js-controller:7.0.6
                        Node.js
                        v20.15.1 (Es gibt eine neuere Version: v20.19.2 - Empfohlene Version v18.20.8)
                        der iob diag spuckt auch seltsames aus:
                                                v.2025-02-23
                         Static hostname: iobroker
                               Icon name: computer-container
                                 Chassis: container ☐
                          Virtualization: lxc
                                  Kernel: Linux 6.5.13-3-pve
                        Installation:           lxc
                        Kernel:                 x86_64
                        Userland:               64 bit
                        User-ID:                1001
                        Pending OS-Updates:     152
                        /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                                throw e;
                        Error: Connection is closed.
                            at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                            at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                            at Object.onceWrapper (node:events:634:26)
                            at Socket.emit (node:events:519:28)
                            at TCP.<anonymous> (node:net:338:12)
                        Emitted 'error' event on ScanStream instance at:
                            at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                            at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                            at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                        Node.js v20.15.1
                        /usr/bin/nodejs         v20.15.1
                        /usr/bin/node           v20.15.1
                        /usr/bin/npm            10.7.0
                        /usr/bin/npx            10.7.0
                        /usr/bin/corepack       0.28.1
                        Recommended versions are nodejs 20.19.2 and npm 10.8.2
                        MEMORY:
                        Mem:             10G        3.5G        6.2G         86K        1.1G        7.2G
                        Swap:           8.6G        2.3G        6.3G
                        Total:           19G        5.8G         12G
                        Active iob-Instances:   53
                        Upgrade policy: none
                        ioBroker Core:          js-controller           7.0.6
                                                admin                   7.6.3
                        At least one iobroker host is running.
                        Objects type: redis
                        States  type: redis
                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.83 (SSL), run as: admin
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                        Objects:                99529
                        States:                 60846
                        find: Failed to change directory: /root: Permission denied
                        find: Failed to restore initial working directory: /root: Permission denied
                        • Z ZeroQool
                          Node.js
                                                  v.2025-02-23
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               64 bit
                          User-ID:                1001
                                  throw e;
                          Node.js v20.15.1
                          /usr/bin/npm            10.7.0
                          /usr/bin/npx            10.7.0
                          MEMORY:
                          Total:           19G        5.8G         12G
                                                  admin                   7.6.3
                          Objects type: redis
                          States  type: redis
                          Objects:                99529
                          States:                 60846
                          CodierknechtC Offline
                          Codierknecht
                          @zeroqool
                          Du solltest zunächst mal Dein System auf Stand bringen.
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                          • Z Offline
                            Z Offline
                            ZeroQool
                            @codierknecht Stimmt
                                                    v.2025-02-23
                              Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               64 bit
                            User-ID:                1001
                            /usr/bin/nodejs         v20.19.2
                            /usr/bin/node           v20.19.2
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.31.0
                            MEMORY:
                            Mem:             10G        4.6G        3.4G        167K        2.7G        6.1G
                            Swap:           8.6G         22M        8.6G
                            Total:           19G        4.7G         11G
                                                    admin                   7.6.3
                            Objects type: redis
                            States  type: redis
                            Objects:                99529
                            States:                 60899
                            CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
                            • Z ZeroQool
                                                      v.2025-02-23
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               64 bit
                              User-ID:                1001
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              MEMORY:
                              Swap:           8.6G         22M        8.6G
                              Total:           19G        4.7G         11G
                                                      admin                   7.6.3
                              Objects type: redis
                              States  type: redis
                              Objects:                99529
                              States:                 60899
                              Codierknecht
                              @zeroqool
                              Wenn Du jetzt noch die Langfassung statt Summary lieferst, könnte man sehen wie Du da unterwegs bist.
                              • Z ZeroQool
                                                        v.2025-02-23
                                  Virtualization: lxc
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               64 bit
                                User-ID:                1001
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                MEMORY:
                                Swap:           8.6G         22M        8.6G
                                Total:           19G        4.7G         11G
                                                        admin                   7.6.3
                                Objects type: redis
                                States  type: redis
                                Objects:                99529
                                States:                 60899
                                @zeroqool sagte in Syntax Error seit Stromausfall:
                                Im Verzeichnis /root hast du nix verloren. Und der ioBroker auch nicht. Da stimmt irgendwas nicht bei dir.
