Test Adapter Tagesschau 0.6.x
@ticaki Bitte schön:
2025-01-04 23:10:30.063 - info: host.iobroker-pmx "system.adapter.tagesschau.0" enabled 2025-01-04 23:10:30.870 - info: host.iobroker-pmx instance system.adapter.tagesschau.0 in version "0.1.3" (non-npm: ticaki/ioBroker.tagesschau#00fec256e4e5c0ae411a3572598658c3d8c5db45) started with pid 28668 2025-01-04 23:10:32.061 - debug: tagesschau.0 (28668) Redis Objects: Use Redis connection: 127.0.0.1:9001 2025-01-04 23:10:32.103 - debug: tagesschau.0 (28668) Objects client ready ... initialize now 2025-01-04 23:10:32.104 - debug: tagesschau.0 (28668) Objects create System PubSub Client 2025-01-04 23:10:32.105 - debug: tagesschau.0 (28668) Objects create User PubSub Client 2025-01-04 23:10:32.195 - debug: tagesschau.0 (28668) Objects client initialize lua scripts 2025-01-04 23:10:32.200 - debug: tagesschau.0 (28668) Objects connected to redis: 127.0.0.1:9001 2025-01-04 23:10:32.241 - debug: tagesschau.0 (28668) Redis States: Use Redis connection: 127.0.0.1:9000 2025-01-04 23:10:32.305 - debug: tagesschau.0 (28668) States create System PubSub Client 2025-01-04 23:10:32.308 - debug: tagesschau.0 (28668) States create User PubSub Client 2025-01-04 23:10:32.373 - debug: tagesschau.0 (28668) States connected to redis: 127.0.0.1:9000 2025-01-04 23:10:32.545 - info: tagesschau.0 (28668) starting. Version 0.1.3 (non-npm: ticaki/ioBroker.tagesschau#00fec256e4e5c0ae411a3572598658c3d8c5db45) in /opt/iobroker/node_modules/iobroker.tagesschau, node: v20.18.1, js-controller: 7.0.6 2025-01-04 23:10:32.800 - info: tagesschau.0 (28668) Set news interval to 30 minutes 2025-01-04 23:10:32.803 - debug: tagesschau.0 (28668) selectedTags: [] 2025-01-04 23:10:32.823 - debug: tagesschau.0 (28668) URL: https://www.tagesschau.de/api2u/news/?regions=310,&ressort=inland 2025-01-04 23:10:33.022 - error: tagesschau.0 (28668) Error: AxiosError: Request failed with status code 400 2025-01-04 23:10:33.029 - debug: tagesschau.0 (28668) URL: https://www.tagesschau.de/api2u/news/?regions=310,&ressort=wirtschaft 2025-01-04 23:10:33.083 - error: tagesschau.0 (28668) Error: AxiosError: Request failed with status code 400 2025-01-04 23:10:33.091 - debug: tagesschau.0 (28668) URL: https://www.tagesschau.de/api2u/news/?regions=310,&ressort=wissen 2025-01-04 23:10:33.116 - error: tagesschau.0 (28668) Error: AxiosError: Request failed with status code 400reicht das?
@rene55
Komma sitzt falsch.Mein Tester hat die Region 1 da geht 12-16 ohne Fehler, ist behoben auf Github, npmjs dauert etwas.
v0.2.1
- schöne Namen für alle States
- Admin (Konfigurationstext) feingetunt
- date auch als number
- der Interval für die Aktualisierung war noch fest eingeben. (5 minuten)
Ein bekannter Fehler in 0.2.1 die Namen von States sind zwar schick, aber die bleiben für die Ordner auch stehen, wenn die Nachricht gelöscht ist - könnte auffallen, wenn mal wenige Nachrichten da sind. :) (Kann auch sein das ich mich irre )
Habe mal das Projekt mit der View abgelegt:
4401757c-cecc-430e-89b0-609a95323cda-2025-01-04-Tagesschau.zip
Sind unter Skripte noch ein paar Funktionen drin:
Außerdem wird noch ein Datenpunkt unter 0_userdata benötigt, in den die URL für das abzuspielende Video aus den Buttons kopiert wird.
0_userdata.0.news.vis.Video@armilar
Wäre es möglich, dass du nur die View einstellst.
Möchte nicht unbedingt ein neues Projekt erzeugen.Und das css Script bitte in code-tag.
Danke. -
v0.2.3
- Fehler behoben: Der Adapter löscht alle seine eigenen States nach einiger Zeit.
Jetzt löscht er in keinem Fall mehr States.
@ticaki Eben noch in der 0.2.3 gefunden:
admin.0 2025-01-05 10:22:53.230 warn tagesschau has an invalid jsonConfig: [{"instancePath":"/items/interval","schemaPath":"#/definitions/numberProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"unit"},"message":"must NOT have additional properties"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"else"},"message":"must match \"else\" schema"}]Eventuell nicht so wichtig.
Eine Frage weil ich ne Vis Niete bin.
Wenn in einem Datenpunkt in einem "Link auf ein Bild" Datenpunkt ein Link auf ein externes Bild steht und ich ändere den gelegentlich auf ein internes Bild - funktioniert das in Vis?
interner Link:
/adapter/tagesschau/img/16x9-1280.png
externer Link:https://images.tagesschau.de/image/e56d58c9-8d7d-438f-828c-fc9cc0b2e35e/AAABlDVa2Yo/AAABkZLhkrw/16x9-1280.jpgEDIT habs selbst raus bekommen. :)
@rene55
Bekannt ist ein schema fehler :)"params":{"additionalProperty":"unit"},unit steht nur in einertype: numberund da ist es laut doku erlaubt. -
@rene55
Bekannt ist ein schema fehler :)"params":{"additionalProperty":"unit"},unit steht nur in einertype: numberund da ist es laut doku erlaubt.@ticaki said in Test Adapter Tagesschau 0.2.x:
@rene55
Bekannt ist ein schema fehler :)"params":{"additionalProperty":"unit"},unit steht nur in einertype: numberund da ist es laut doku erlaubt.Hast du den Link aufs Issue dazu?
Und unit gibts eigentlich in allen numerischen Typen (number, slider, state, staticInfo).
ABER unit erfordert admin >= 7.4.9 -
@armilar
Danke.Hier nur die VIS-View
964e1112-1566-4440-9b2d-acb31a14c41c-tagesschau_view.jsonUnd hier die Funktionen die ich aktuell in VIS benutze (im Tab Eigenschaften/Skripte)
function calcDate(datum) { if (datum != 'undefined') { return '• Datum: ' + datum.slice(8,10) + '.' + datum.slice(5,7) + '.' + datum.slice(0,4) + ' ' + datum.slice(11,13) + ':' + datum.slice(14,16) + ' Uhr'; } else { return '' } } function toMinSek(laenge) { return '• Länge: ' + new Date(laenge * 1000).toISOString().substring(14, 19) } function checkContent(topline, title) { if (topline == 'null' || topline == 'undefined' || topline === '' || title == 'null' || title == 'undefined' || title === '' ) { return '<b>Content wird geladen</b>'; } else { topline1 = topline.toString().replaceAll(/"/g, '\\'); title1 = title.toString().replaceAll(/"/g, '\\'); return '<b>• ' + topline1 + '</b> - ' + title1; } } function setState(id, value) { this.vis.setValue(id, value); }Evtl. müsst ihr noch an der Auflösung arbeiten, da die mir recht hoch ist.
Seitdem @ticaki jetzt auch den Date-String aus der API via JS-Date (V.0.2.X) bereitstellt (z.B. tagesschau.0.videos.channels.01.jsDate) ergeben sich in der Formatierung des Datums/Uhrzeit auch neue Möglichkeiten...
Das hier entspricht noch der ursprünglichen API. Funktioniert natürlich auch weiterhin.
Aktuelle Test Version 0.6.x Veröffentlichungsdatum 18.09.25 Github Link https://github.com/ticaki/ioBroker.tagesschau Der Adapter ruft aktuelle Nachrichten mit Bildern, sowie Links zu Nachrichtenvideos der Tagesschau ab.
Sollte soweit selbst erklären sein. @Armilar macht schon länger mit den Daten rum und hat mir die Idee angetragen.
@rene55
ABER unit erfordert admin >= 7.4.9@mcm1957 sagte in Test Adapter Tagesschau 0.2.x:
@rene55
@rene55
@ticaki sehr stark!
da hab ich eine frage ich nutze die vis nicht.. kann man da auch was für Telegram oder so was machen? das man einmal am tag die Nachrichten aufs Handy geschickt bekommt? oder ist das nicht möglich lg Dave
Ja ne vielleicht :D Bin da mit was am rum spinnen. Ich könnte ja meinen anderen adapter mit sendto empfangsmöglichkeiten ausstatten und ein Skript anbieten, dass die Nachrichten als Wetter tarnt und den anderen Adapter zweck entfremdet... Mal sehen wie ich lust bekomme.
Was aber schnell gehen würde, wäre ein Skript das breaking news überwacht und die per Telegram raushaut.
Exakt so mache ich es auch. Die VIS View ist nur eines von diversen Anwendungsbeispielen und eher bei mir für den Test konzipiert. Lässt sich dennoch für VIS Freunde nutzen...
Trigger auf Breaking News (newsCount) und dann die Top-Line mit Titel an das NSPanel im Screensaver oder an Telegram mit dem Link zur Nachricht...
Wenn jetzt eine wichtig eingestufte Meldung kommt, dann direkt weitersenden...
Ich denke der Phantasie sollten hier keine Grenzen gesetzt sein...
@ticaki
Ich meinte einen Link aufs Issue wo der Schema Fehler gemeldet wird. Ohne Isse wird den niemand behaben ...@mcm1957 sagte in Test Adapter Tagesschau 0.2.x:
@ticaki
Ich meinte einen Link aufs Issue wo der Schema Fehler gemeldet wird. Ohne Isse wird den niemand behaben ... -
0.3.0 (2025-01-05)
- (ticaki) States are only updated when changes are made.
- (ticaki) Last update Data point added with timestamp of the last successful data access
- (ticaki) Emptying of data points improved
- (ticaki) Placeholder images inserted for no news.
- (ticaki) User-defined keywords with
* - (ticaki) Requires admin version 7.4.9 or higher
DeepL meint dazu:
0.3.0 (2025-01-05)
- (ticaki) Zustände werden nur bei Änderungen aktualisiert.
- (ticaki) Letzte Aktualisierung Datenpunkt mit Zeitstempel des letzten erfolgreichen Datenzugriffs hinzugefügt
- (ticaki) Leeren von Datenpunkten verbessert
- (ticaki) Platzhalterbilder für keine Nachrichten eingefügt.
- (ticaki) Benutzerdefinierte Schlüsselwörter mit
* - (ticaki) Benötigt Admin-Version 7.4.9 oder höher
