Test : Wasserenthärtung judo i-soft plus Adapter
@arteck ich habe den Adapter installiert.
Lokal bekomme ich folgende Fehlermeldung
judoisoft.0 2025-01-01 16:09:38.132 error getInfos ERROR judoisoft.0 2025-01-01 16:09:38.066 error ServiceDate ERROR judoisoft.0 2025-01-01 16:09:38.052 error InstallationDate ERROR judoisoft.0 2025-01-01 16:09:38.045 error HardwareVersion ERROR judoisoft.0 2025-01-01 16:09:38.036 error SoftwareVersion ERROR judoisoft.0 2025-01-01 16:09:38.029 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-01 16:09:38.132 error getInfos ERROR judoisoft.0 2025-01-01 16:09:38.066 error ServiceDate ERROR judoisoft.0 2025-01-01 16:09:38.052 error InstallationDate ERROR judoisoft.0 2025-01-01 16:09:38.045 error HardwareVersion ERROR judoisoft.0 2025-01-01 16:09:38.036 error SoftwareVersion ERROR judoisoft.0 2025-01-01 16:09:38.029 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"Und Online folgende:
udoisoft.0 2025-01-01 16:30:34.434 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-01 16:30:34.432 error getInfosCloud ERROR reconnect wait 5 min judoisoft.0 2025-01-01 16:30:34.371 info reconnect 1735745434371 judoisoft.0 2025-01-01 16:30:34.322 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-01 16:30:34.066 info starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6Kann ich Dich bei der Entwicklung des Adapters unterstützen?
Krodon
Krodon
@krodon ganzes LOG bitte nicht nur paar schnippsel.
aber so wie es aussieht bekommst du keine Verbindung zu der cloud
@arteck danke für die schnelle Rückmeldung!
Dies ist das komplette log ohne Cloud Login::
judoisoft.0 2025-01-02 17:20:11.540 error getInfos ERROR judoisoft.0 2025-01-02 17:20:11.533 error ServiceDate ERROR judoisoft.0 2025-01-02 17:20:11.526 error InstallationDate ERROR judoisoft.0 2025-01-02 17:20:11.481 error HardwareVersion ERROR judoisoft.0 2025-01-02 17:20:11.467 error SoftwareVersion ERROR judoisoft.0 2025-01-02 17:20:11.465 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-02 17:20:11.145 info starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6Und dies mit
v7.1.5 61 Log-Größe: 1.8 KB Zeit judoisoft.0 2025-01-02 17:31:27.035 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-02 17:31:27.034 error getInfosCloud ERROR reconnect wait 5 min judoisoft.0 2025-01-02 17:31:26.935 info reconnect 1735835486935 judoisoft.0 2025-01-02 17:31:26.819 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-02 17:31:26.284 info starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6 judoisoft.0 2025-01-02 17:30:54.820 warn Terminated (UNCAUGHT_EXCEPTION): Without reason judoisoft.0 2025-01-02 17:30:54.820 info terminating judoisoft.0 2025-01-02 17:30:54.819 info cleaned everything up... judoisoft.0 2025-01-02 17:30:54.817 error this.getTokenFirst is not a function judoisoft.0 2025-01-02 17:30:54.817 error TypeError: this.getTokenFirst is not a function at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.judoisoft/main.js:293:39) at listOnTimeout (node:internal/timers:581:17) at process.processTimers (node:internal/timers:519:7) judoisoft.0 2025-01-02 17:30:54.816 error uncaught exception: this.getTokenFirst is not a function judoisoft.0 2025-01-02 17:25:54.816 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-02 17:25:54.814 error getInfosCloud ERROR reconnect wait 5 min judoisoft.0 2025-01-02 17:25:54.751 info reconnect 1735835154751 judoisoft.0 2025-01-02 17:25:54.689 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-02 17:25:54.431 info starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6Fall es nicht ausführlich ist, sage mir bitte wie ich es richtig ziehe.
Krodon
@arteck irgendwie ist bei mir der Wurm drinnen.
Ich hatte den Adapter deinstalliert und über
https://github.com/arteck/ioBroker.judoisoft neu installiert, es war die Version 111
Unter Instanzen wurde auch nach einem reboot nichts angezeigt. Also habe ich ihn deinstalliert und die neue installiert, anschließend ein Update über github die Fehler sind noch immer die alten :-(VG
Krodon
P.S. Online hat sich der Fehler geändert, user und PW sind aber richtig
judoisoft.0 2025-01-03 13:48:12.952 warn Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason judoisoft.0 2025-01-03 13:48:12.903 error adapter disabled judoisoft.0 2025-01-03 13:47:41.993 info terminating judoisoft.0 2025-01-03 13:47:41.493 info Terminated (NO_ERROR): Without reason judoisoft.0 2025-01-03 13:47:41.493 info terminating judoisoft.0 2025-01-03 13:47:41.490 info cleaned everything up... judoisoft.0 2025-01-03 13:47:41.489 error getInfosCloud login faild, adapter STOP judoisoft.0 2025-01-03 13:47:41.426 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-03 13:47:41.420 debug get Consumption data Cloud judoisoft.0 2025-01-03 13:47:41.252 debug get statusURL for Cloud judoisoft.0 2025-01-03 13:47:41.146 debug create state judoisoft.0 2025-01-03 13:47:41.145 debug base url https://www.myjudo.eu/interface/ judoisoft.0 2025-01-03 13:47:41.137 info starting. Version 1.1.1 (non-npm: arteck/ioBroker.judoisoft#7dcc4dd39b2fe933dedefe3173d950dd1ca44a43) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6 -
Krodon
judoisoft.0 2025-01-03 13:48:12.952 warn Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason judoisoft.0 2025-01-03 13:48:12.903 error adapter disabled judoisoft.0 2025-01-03 13:47:41.993 info terminating judoisoft.0 2025-01-03 13:47:41.493 info Terminated (NO_ERROR): Without reason judoisoft.0 2025-01-03 13:47:41.493 info terminating judoisoft.0 2025-01-03 13:47:41.490 info cleaned everything up... judoisoft.0 2025-01-03 13:47:41.489 error getInfosCloud login faild, adapter STOP judoisoft.0 2025-01-03 13:47:41.426 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-03 13:47:41.420 debug get Consumption data Cloud judoisoft.0 2025-01-03 13:47:41.252 debug get statusURL for Cloud judoisoft.0 2025-01-03 13:47:41.146 debug create state judoisoft.0 2025-01-03 13:47:41.145 debug base url https://www.myjudo.eu/interface/ judoisoft.0 2025-01-03 13:47:41.137 info starting. Version 1.1.1 (non-npm: arteck/ioBroker.judoisoft#7dcc4dd39b2fe933dedefe3173d950dd1ca44a43) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6@krodon sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
die Version 1.1.1 ist richtig ..
aber der adapter kann sich immer noch nicht in der cloud anmleden
@arteck Ohne Cloud habe ich folgende Fehler:
udoisoft.0 2025-01-04 09:23:42.980 error getInfos ERROR judoisoft.0 2025-01-04 09:23:42.974 debug get Consumption data Local judoisoft.0 2025-01-04 09:23:42.974 error ServiceDate ERROR judoisoft.0 2025-01-04 09:23:42.968 error InstallationDate ERROR judoisoft.0 2025-01-04 09:23:42.959 error HardwareVersion ERROR judoisoft.0 2025-01-04 09:23:42.947 error SoftwareVersion ERROR judoisoft.0 2025-01-04 09:23:42.944 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-04 09:23:42.939 debug get Information Static Local judoisoft.0 2025-01-04 09:23:42.534 debug get statusURL for local judoisoft.0 2025-01-04 09:23:42.403 debug create state judoisoft.0 2025-01-04 09:23:42.402 debug base url https://192.168.1.190:8124/?group= judoisoft.0 2025-01-04 09:23:42.394 info starting. Version 1.1.1 (non-npm: arteck/ioBroker.judoisoft#7dcc4dd39b2fe933dedefe3173d950dd1ca44a43) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6 judoisoft.0 2025-01-04 09:23:42.344 debug States connected to redis: 127.0.0.1:9000 judoisoft.0 2025-01-04 09:23:42.291 debug States create User PubSub Client judoisoft.0 2025-01-04 09:23:42.290 debug States create System PubSub Client judoisoft.0 2025-01-04 09:23:42.274 debug Redis States: Use Redis connection: 127.0.0.1:9000 judoisoft.0 2025-01-04 09:23:42.257 debug Objects connected to redis: 127.0.0.1:9001 judoisoft.0 2025-01-04 09:23:42.254 debug Objects client initialize lua scripts judoisoft.0 2025-01-04 09:23:42.230 debug Objects create User PubSub Client judoisoft.0 2025-01-04 09:23:42.229 debug Objects create System PubSub Client judoisoft.0 2025-01-04 09:23:42.229 debug Objects client ready ... initialize now judoisoft.0 2025-01-04 09:23:42.212 debug Redis Objects: Use Redis connection: 127.0.0.1:9001VG
Krodon
Krodon
Hallo @krodon, @arteck,
wenn ich mich richtig erinnere, hatte ich diese Fehlermeldungen auch so, als ich testweise mal das seit einiger Zeit von judo in einer neuen Version ausgelieferte Connectivity-Modul eingesetzt hatte (mit API, mit WLAN, mit LAN).
Ebenfalls judo i-soft plus Adapter Version 1.1.1.
Ich bin deshalb wieder zurück auf das "alte" judo-Modul (müsste ich oben im Verlauf auch mal so ähnlich berichtet haben).@krodon: Hast Du ein relativ neues Connectivity-Modul (mit WLAN)/eine relativ neue judo-Anlage?
Falls für euch interessant, kann ich evtl. mal am So. oder Mo. als Gegenprüfung nochmal auf das andere Modul umbauen und die Meldungen hier reinstellen.
@smarthomer-0 meine Anlage ist etwas über ein Jahr alt
Ich habe wenig Ahnung, schätze aber das dies die Ursache isthas to be type "boolean" but received type "string"VG
Krodon
@arteck Hallo,
ich habe es eben installiert und habe folgende Meldungen::
judoisoft.0 2025-01-05 10:06:18.236 error getInfos ERROR judoisoft.0 2025-01-05 10:06:18.148 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-05 10:06:18.142 debug get Consumption data Local judoisoft.0 2025-01-05 10:06:18.142 error ServiceDate ERROR judoisoft.0 2025-01-05 10:06:18.133 error InstallationDate ERROR judoisoft.0 2025-01-05 10:06:18.117 error HardwareVersion ERROR judoisoft.0 2025-01-05 10:06:18.110 error SoftwareVersion ERROR judoisoft.0 2025-01-05 10:06:18.097 debug get Information Static Local judoisoft.0 2025-01-05 10:06:18.097 error Check Login data (user:psw) judoisoft.0 2025-01-05 10:06:17.721 debug get statusURL for local judoisoft.0 2025-01-05 10:06:17.584 debug create state judoisoft.0 2025-01-05 10:06:17.584 debug base url https://192.168.1.190:8124/?group= judoisoft.0 2025-01-05 10:06:17.575 info starting. Version 1.1.2 (non-npm: arteck/ioBroker.judoisoft#458c284c16cc21f5b1b439134f480986a0a047d5) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6 judoisoft.0 2025-01-05 10:06:17.520 debug States connected to redis: 127.0.0.1:9000 judoisoft.0 2025-01-05 10:06:17.466 debug States create User PubSub Client judoisoft.0 2025-01-05 10:06:17.466 debug States create System PubSub Client judoisoft.0 2025-01-05 10:06:17.458 debug Redis States: Use Redis connection: 127.0.0.1:9000 judoisoft.0 2025-01-05 10:06:17.441 debug Objects connected to redis: 127.0.0.1:9001 judoisoft.0 2025-01-05 10:06:17.438 debug Objects client initialize lua scripts judoisoft.0 2025-01-05 10:06:17.413 debug Objects create User PubSub Client judoisoft.0 2025-01-05 10:06:17.412 debug Objects create System PubSub Client judoisoft.0 2025-01-05 10:06:17.412 debug Objects client ready ... initialize now judoisoft.0 2025-01-05 10:06:17.394 debug Redis Objects: Use Redis connection: 127.0.0.1:9001VG
Krodon
@arteck Hallo,
Krodon
@krodon sagemal geht das auch mal Ordntlich mit einem kompletten LOG..und nicht mitten drin.. was soll ich mit den infos
nochmal... der Adapter kann sich NICHT in der cloud einlogen..
@arteck bei mir ist der Haken bei Cloud Login nicht gesetzt. Die Logs habe ich nach judisoft.0 gefiltert und den Level auf debug gesetzt. Sind die Einstellungen für das Log so richtig?
Ich habe es komplett gelöscht und den Adapter neu gestartet.
Dies habe ich dann erhalten:judoisoft.0 2025-01-05 11:51:41.408 error getInfos ERROR judoisoft.0 2025-01-05 11:51:41.405 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string" judoisoft.0 2025-01-05 11:51:41.402 debug get Consumption data Local judoisoft.0 2025-01-05 11:51:41.401 error ServiceDate ERROR judoisoft.0 2025-01-05 11:51:41.387 error InstallationDate ERROR judoisoft.0 2025-01-05 11:51:41.377 error HardwareVersion ERROR judoisoft.0 2025-01-05 11:51:41.367 error SoftwareVersion ERROR judoisoft.0 2025-01-05 11:51:41.355 debug get Information Static Local judoisoft.0 2025-01-05 11:51:41.354 error Check Login data (user:psw) judoisoft.0 2025-01-05 11:51:40.924 debug get statusURL for local judoisoft.0 2025-01-05 11:51:40.778 debug create state judoisoft.0 2025-01-05 11:51:40.777 debug base url https://192.168.1.190:8124/?group= judoisoft.0 2025-01-05 11:51:40.768 info starting. Version 1.1.2 (non-npm: arteck/ioBroker.judoisoft#458c284c16cc21f5b1b439134f480986a0a047d5) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6 judoisoft.0 2025-01-05 11:51:40.712 debug States connected to redis: 127.0.0.1:9000 judoisoft.0 2025-01-05 11:51:40.657 debug States create User PubSub Client judoisoft.0 2025-01-05 11:51:40.657 debug States create System PubSub Client judoisoft.0 2025-01-05 11:51:40.649 debug Redis States: Use Redis connection: 127.0.0.1:9000 judoisoft.0 2025-01-05 11:51:40.632 debug Objects connected to redis: 127.0.0.1:9001 judoisoft.0 2025-01-05 11:51:40.628 debug Objects client initialize lua scripts judoisoft.0 2025-01-05 11:51:40.604 debug Objects create User PubSub Client judoisoft.0 2025-01-05 11:51:40.603 debug Objects create System PubSub Client judoisoft.0 2025-01-05 11:51:40.602 debug Objects client ready ... initialize now judoisoft.0 2025-01-05 11:51:40.585 debug Redis Objects: Use Redis connection: 127.0.0.1:9001 judoisoft.0 2025-01-05 11:51:36.861 info terminating judoisoft.0 2025-01-05 11:51:36.360 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason judoisoft.0 2025-01-05 11:51:36.360 info terminating judoisoft.0 2025-01-05 11:51:36.360 info cleaned everything up... judoisoft.0 2025-01-05 11:51:36.359 info Got terminate signal TERMINATE_YOURSELFVG
Krodon
Krodon
ich schreib es jetzt zum letztn mal..
dein user und psw stimmen nicht... egal obs Cloud oder intern.. es stimmt nicht
und es hat nichts damit zu tun
2025-01-05 11:51:41.405 info State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"checkmal das Object judoisoft.0.Connection status da wird bestimmt ERROR drin stehen
Danke für die neue Adapter-Version!
Ich habe mir jetzt auch die 1.1.2 von GIT installiert, folgende Feststellungen:
"Altes Connectivity-Modul" in der judo i-soft + eingebaut:
- der "Cloud-Zugriff" funktioniert weiterhin problemlos
- der "Offline-Zugriff" ohne Cloud funktioniert weiterhin nicht
Dann habe ich das alte Connectivity-Modul ausgebaut und das neue (mit LAN, WLAN, API) eingebaut.
"Neues Connectivity-Modul" in der judo i-soft + eingebaut:
In der Oberfläche vom Connectivity-Modul [Standard-Verbindung: LAN]" ausgewählt:
- der "Cloud-Zugriff" mit der 1.1.2 funktioniert jetzt ebenfalls problemlos (dies war mit der 1.1.1 noch nicht möglich, insofern schon mal eine echte Verbesserung).
- der "Offline-Zugriff" ohne Cloud funktioniert weiterhin nicht (war aber vermutlich auch nicht Ziel Deiner V1.1.2)
In der Oberfläche vom Connectivity-Modul [Standard-Verbindung: WLAN]" ausgewählt:
Info-Auskunft aus dem judo-Webportal:
Ich werde jetzt das neue Connectivity-Modul eingebaut lassen, da ich mit Deiner neuen Adapter-Version 1.1.2 alle Funktionen des alten Moduls auf ioBroker ebenfalls habe. Zusätzlich habe ich die Möglichkeit der lokalen API-Abfrage, falls sich da in Zukunft doch noch etwas tut (Adaper oder Skript - siehe Link Text
@smarthomer-0 said in Test : Wasserenthärtung judo i-soft plus Adapter:
Welche URL hat das judo-Webportal?
VVG
Krodon
Hallo @krodon,
wie im vorstehenden Beitrag geschrieben, habe ich jetzt bei mir auch das neue Connectivity-Modul mit dem Adapter judo i-soft plus von arteck am Laufen, es funktioniert also grundsäztlich.
Vielleicht nochmal einige Hinweise dazu aus Anwender-Sicht:
- Ich gehe davon aus, dass Du Dir bei judo einen Account angelegt hast und Dich mit Handy-App oder Browser auf "www.myjudo.eu" anmelden kannst und dort auch die Daten zu Deiner Anlage online einsehen kannst.
- Du hast Dein Connectivity-Modul wie in der Anleitung von judo beschrieben installiert, entsprechend müsstest Du über die IP des Moduls auf die Oberfläche des Connectivity-Modul direkt zugreifen können. Dort muss unter Reiter "Einstellungen" ganz unten auch die CheckBox "Portal-Server" angehakt sein:
Dann wird auch in der Übersicht vom Connectivity Modul der Portal-Server Status mit "Verbunden" angezeigt:
Und eben auf diese Informationen aus dem judo-Account bzw. judo Portal-Server greift der Adapter von @arteck zu (nicht lokal auf das Modul).
Meine Einstellungen im Adapter:
Ich nehme an, diese Anwender-Informationen waren schon alle bekannt bei Dir, evtl. hilft es aber dennoch etwas weiter.
