  4. Test : Wasserenthärtung judo i-soft plus Adapter
i-softjudowasserenthärtung
216 Beiträge 22 Kommentatoren 48.5k Aufrufe 22 Beobachtet
  • arteckA arteck
    ich hab gerade auf GIT die 1.1.2 gemacht.. bitte mal Testen..
    krodon
    #192
    @arteck Hallo,
    ich habe es eben installiert und habe folgende Meldungen::
    judoisoft.0
    	2025-01-05 10:06:18.236	error	getInfos ERROR
    judoisoft.0
    	2025-01-05 10:06:18.148	info	State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    judoisoft.0
    	2025-01-05 10:06:18.142	debug	get Consumption data Local
    judoisoft.0
    	2025-01-05 10:06:18.142	error	ServiceDate ERROR
    judoisoft.0
    	2025-01-05 10:06:18.133	error	InstallationDate ERROR
    judoisoft.0
    	2025-01-05 10:06:18.117	error	HardwareVersion ERROR
    judoisoft.0
    	2025-01-05 10:06:18.110	error	SoftwareVersion ERROR
    judoisoft.0
    	2025-01-05 10:06:18.097	debug	get Information Static Local
    judoisoft.0
    	2025-01-05 10:06:18.097	error	Check Login data (user:psw)
    judoisoft.0
    	2025-01-05 10:06:17.721	debug	get statusURL for local
    judoisoft.0
    	2025-01-05 10:06:17.584	debug	create state
    judoisoft.0
    	2025-01-05 10:06:17.584	debug	base url https://192.168.1.190:8124/?group=
    judoisoft.0
    	2025-01-05 10:06:17.575	info	starting. Version 1.1.2 (non-npm: arteck/ioBroker.judoisoft#458c284c16cc21f5b1b439134f480986a0a047d5) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
    judoisoft.0
    	2025-01-05 10:06:17.520	debug	States connected to redis: 127.0.0.1:9000
    judoisoft.0
    	2025-01-05 10:06:17.466	debug	States create User PubSub Client
    judoisoft.0
    	2025-01-05 10:06:17.466	debug	States create System PubSub Client
    judoisoft.0
    	2025-01-05 10:06:17.458	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    judoisoft.0
    	2025-01-05 10:06:17.441	debug	Objects connected to redis: 127.0.0.1:9001
    judoisoft.0
    	2025-01-05 10:06:17.438	debug	Objects client initialize lua scripts
    judoisoft.0
    	2025-01-05 10:06:17.413	debug	Objects create User PubSub Client
    judoisoft.0
    	2025-01-05 10:06:17.412	debug	Objects create System PubSub Client
    judoisoft.0
    	2025-01-05 10:06:17.412	debug	Objects client ready ... initialize now
    judoisoft.0
    	2025-01-05 10:06:17.394	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    Krodon
    • K krodon
      @arteck Hallo,
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      judoisoft.0
      Krodon
      arteckA Offline
      arteckA Offline
      arteck
      #193
      @krodon sagemal geht das auch mal Ordntlich mit einem kompletten LOG..und nicht mitten drin.. was soll ich mit den infos
      nochmal... der Adapter kann sich NICHT in der cloud einlogen..
      • arteckA arteck
        krodon
        #194
        @arteck bei mir ist der Haken bei Cloud Login nicht gesetzt. Die Logs habe ich nach judisoft.0 gefiltert und den Level auf debug gesetzt. Sind die Einstellungen für das Log so richtig?
        Ich habe es komplett gelöscht und den Adapter neu gestartet.
        Dies habe ich dann erhalten:
        judoisoft.0
        	2025-01-05 11:51:41.408	error	getInfos ERROR
        judoisoft.0
        	2025-01-05 11:51:41.405	info	State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
        judoisoft.0
        	2025-01-05 11:51:41.402	debug	get Consumption data Local
        judoisoft.0
        	2025-01-05 11:51:41.401	error	ServiceDate ERROR
        judoisoft.0
        	2025-01-05 11:51:41.387	error	InstallationDate ERROR
        judoisoft.0
        	2025-01-05 11:51:41.377	error	HardwareVersion ERROR
        judoisoft.0
        	2025-01-05 11:51:41.367	error	SoftwareVersion ERROR
        judoisoft.0
        	2025-01-05 11:51:41.355	debug	get Information Static Local
        judoisoft.0
        	2025-01-05 11:51:41.354	error	Check Login data (user:psw)
        judoisoft.0
        	2025-01-05 11:51:40.924	debug	get statusURL for local
        judoisoft.0
        	2025-01-05 11:51:40.778	debug	create state
        judoisoft.0
        	2025-01-05 11:51:40.777	debug	base url https://192.168.1.190:8124/?group=
        judoisoft.0
        	2025-01-05 11:51:40.768	info	starting. Version 1.1.2 (non-npm: arteck/ioBroker.judoisoft#458c284c16cc21f5b1b439134f480986a0a047d5) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
        judoisoft.0
        	2025-01-05 11:51:40.712	debug	States connected to redis: 127.0.0.1:9000
        judoisoft.0
        	2025-01-05 11:51:40.657	debug	States create User PubSub Client
        judoisoft.0
        	2025-01-05 11:51:40.657	debug	States create System PubSub Client
        judoisoft.0
        	2025-01-05 11:51:40.649	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        judoisoft.0
        	2025-01-05 11:51:40.632	debug	Objects connected to redis: 127.0.0.1:9001
        judoisoft.0
        	2025-01-05 11:51:40.628	debug	Objects client initialize lua scripts
        judoisoft.0
        	2025-01-05 11:51:40.604	debug	Objects create User PubSub Client
        judoisoft.0
        	2025-01-05 11:51:40.603	debug	Objects create System PubSub Client
        judoisoft.0
        	2025-01-05 11:51:40.602	debug	Objects client ready ... initialize now
        judoisoft.0
        	2025-01-05 11:51:40.585	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        judoisoft.0
        	2025-01-05 11:51:36.861	info	terminating
        judoisoft.0
        	2025-01-05 11:51:36.360	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        judoisoft.0
        	2025-01-05 11:51:36.360	info	terminating
        judoisoft.0
        	2025-01-05 11:51:36.360	info	cleaned everything up...
        judoisoft.0
        	2025-01-05 11:51:36.359	info	Got terminate signal TERMINATE_YOURSELF
        Krodon
        • K krodon
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          judoisoft.0
          Krodon
          arteckA Offline
          arteckA Offline
          arteck
          #195
          @krodon sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
          ich schreib es jetzt zum letztn mal..
          dein user und psw stimmen nicht... egal obs Cloud oder intern.. es stimmt nicht
          und es hat nichts damit zu tun
          checkmal das Object judoisoft.0.Connection status da wird bestimmt ERROR drin stehen
          K S 2 Antworten Letzte Antwort
          • arteckA arteck
            krodon
            #196
            @arteck meinst Du dies?
            Krodon
            • K krodon
              Krodon
              arteckA Offline
              arteckA Offline
              arteck
              #197
              @krodon jaha.
              • arteckA arteck
                @krodon jaha.
                krodon
                schrieb am zuletzt editiert von krodon
                #198
                @arteck wäre es für dich hilfreich, wenn ich das Gerät per NAT teile?
                Wenn ja, welche Ports?
                Krodon
                • arteckA arteck
                  SmartHomer 0
                  #199
                  @arteck
                  Hallo @arteck,
                  Danke für die neue Adapter-Version!
                  Ich habe mir jetzt auch die 1.1.2 von GIT installiert, folgende Feststellungen:
                  "Altes Connectivity-Modul" in der judo i-soft + eingebaut:
                  • der "Cloud-Zugriff" funktioniert weiterhin problemlos
                  • der "Offline-Zugriff" ohne Cloud funktioniert weiterhin nicht
                  Dann habe ich das alte Connectivity-Modul ausgebaut und das neue (mit LAN, WLAN, API) eingebaut.
                  "Neues Connectivity-Modul" in der judo i-soft + eingebaut:
                  In der Oberfläche vom Connectivity-Modul [Standard-Verbindung: LAN]" ausgewählt:
                  • der "Cloud-Zugriff" mit der 1.1.2 funktioniert jetzt ebenfalls problemlos (dies war mit der 1.1.1 noch nicht möglich, insofern schon mal eine echte Verbesserung).
                  • der "Offline-Zugriff" ohne Cloud funktioniert weiterhin nicht (war aber vermutlich auch nicht Ziel Deiner V1.1.2)
                  In der Oberfläche vom Connectivity-Modul [Standard-Verbindung: WLAN]" ausgewählt:
                  Info-Auskunft aus dem judo-Webportal:
                  Ich werde jetzt das neue Connectivity-Modul eingebaut lassen, da ich mit Deiner neuen Adapter-Version 1.1.2 alle Funktionen des alten Moduls auf ioBroker ebenfalls habe. Zusätzlich habe ich die Möglichkeit der lokalen API-Abfrage, falls sich da in Zukunft doch noch etwas tut (Adaper oder Skript - siehe Link Text
                  • S SmartHomer 0
                    @arteck
                    Hallo @arteck,
                    krodon
                    #200
                    @smarthomer-0 said in Test : Wasserenthärtung judo i-soft plus Adapter:
                    Welche URL hat das judo-Webportal?
                    VVG
                    Krodon
                    • arteckA arteck
                      SmartHomer 0
                      schrieb am zuletzt editiert von SmartHomer 0
                      #201
                      @krodon
                      @arteck
                      Hallo @krodon,
                      wie im vorstehenden Beitrag geschrieben, habe ich jetzt bei mir auch das neue Connectivity-Modul mit dem Adapter judo i-soft plus von arteck am Laufen, es funktioniert also grundsäztlich.
                      Vielleicht nochmal einige Hinweise dazu aus Anwender-Sicht:
                      1. Ich gehe davon aus, dass Du Dir bei judo einen Account angelegt hast und Dich mit Handy-App oder Browser auf "www.myjudo.eu" anmelden kannst und dort auch die Daten zu Deiner Anlage online einsehen kannst.
                      1. Du hast Dein Connectivity-Modul wie in der Anleitung von judo beschrieben installiert, entsprechend müsstest Du über die IP des Moduls auf die Oberfläche des Connectivity-Modul direkt zugreifen können. Dort muss unter Reiter "Einstellungen" ganz unten auch die CheckBox "Portal-Server" angehakt sein:
                      Dann wird auch in der Übersicht vom Connectivity Modul der Portal-Server Status mit "Verbunden" angezeigt:
                      Und eben auf diese Informationen aus dem judo-Account bzw. judo Portal-Server greift der Adapter von @arteck zu (nicht lokal auf das Modul).
                      Meine Einstellungen im Adapter:
                      Ich nehme an, diese Anwender-Informationen waren schon alle bekannt bei Dir, evtl. hilft es aber dennoch etwas weiter.
                      • S SmartHomer 0
                        @krodon
                        @arteck
                        Hallo @krodon,
                        krodon
                        #202
                        Hallo @smarthomer danke für die Anleitung!
                        Online funktioniert es nun bei mir. :-)
                        Krodon
                        • K krodon
                          Krodon
                          SmartHomer 0
                          #203
                          Wo finde ich diese Anleitung?
                          Quellen für Infos dazu z.B.:
                          https://judo.eu/produkte/connectivity-modul-wlan/
                          https://judo.eu/app/downloads/files/de/8203521/manuals/1702574_202405.pdf
                          Sollte bei der Lieferung des Connectivity-Modul dabei gewesen sein, hier mal ein Link (zwar für Softwell, aber genauso gültig): https://judo.eu/app/downloads/files/de/8000000/manuals/1702929_202301.pdf
                          • S SmartHomer 0
                            krodon
                            #204
                            @smarthomer-0 Danke!
                            Dies hatte ich gleich am Anfang gemacht.
                            Mich hatte das Menü gewundert, nun weiß ich wo ich es finde
                            Bei mir werden aber keine Menüpunkte wie Körper Pflegen angezeigt, ist das Normal?
                            Krodon
                            • S SmartHomer 0
                              @arteck
                              Hallo @arteck,
                              SmartHomer 0
                              #205
                              @arteck
                              Danke für die Adapter-Version 1.1.2!
                              Evtl. für Dich als Entwickler ergänzend noch interessant zwei Debug-Logs (jeweils mit dem "neuen Connectivity-Modul" von judo):
                              1. Bei funktionierendem Adapter-Zugriff über das judo-Portal/Cloud:
                              judoisoft.0
                              2025-01-05 15:23:28.686	debug	-> Battery75
                              judoisoft.0
                              2025-01-05 15:23:28.680	debug	-> StandByValue0
                              judoisoft.0
                              2025-01-05 15:23:28.672	debug	-> WaterCurrent
                              judoisoft.0
                              2025-01-05 15:23:28.663	debug	-> SaltQuantity
                              judoisoft.0
                              2025-01-05 15:23:28.615	debug	-> ResidualHardness
                              judoisoft.0
                              2025-01-05 15:23:28.614	debug	--> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
                              judoisoft.0
                              2025-01-05 15:23:28.604	debug	-> NaturalHardness
                              judoisoft.0
                              2025-01-05 15:23:28.596	debug	-> SaltRange
                              judoisoft.0
                              2025-01-05 15:23:28.586	debug	-> WaterTotal
                              judoisoft.0
                              2025-01-05 15:23:28.567	debug	-> Maintenance 341
                              judoisoft.0
                              2025-01-05 15:23:28.538	debug	-> ServiceDays 4.Aug.2022
                              judoisoft.0
                              2025-01-05 15:23:28.467	debug	-> InstallationDate 4.Aug.2022
                              judoisoft.0
                              2025-01-05 15:23:28.467	debug	-> _dt 0x33
                              judoisoft.0
                              2025-01-05 15:23:28.467	debug	-> _da 0x1
                              judoisoft.0
                              2025-01-05 15:23:28.466	debug	-> HardwareVersion
                              judoisoft.0
                              2025-01-05 15:23:28.455	debug	-> SoftwareVersion
                              judoisoft.0
                              2025-01-05 15:23:28.448	debug	-> SerialNumber
                              judoisoft.0
                              2025-01-05 15:23:28.421	debug	all fine {"data":[{"ewuid":"5de7c74a-9e3b-11ef-af7e-005056930189","serialnumber":"e8eb1bf3a0ee","installation_date":"2022-08-07T09:53:37","status":"offline","bct":"rs485","sv":"1.13","hv":"1.0","data":[{"da":"0x1","dt":"0x33","sv":"2.20j","hv":"5.10","data":{"1":{"data":"6A1402","st":"OK","er":""},"2":{"data":"0A05","st":"OK","er":""},"3":{"data":"AED20300","st":"OK","er":""},"5":{"data":"04167403","st":"OK","er":""},"6":{"data":"62EBCBD4","st":"OK","er":""},"7":{"data":"0C2002000300","st":"OK","er":""},"8":{"data":"D4140700","st":"OK","er":""},"9":{"data":"06F60300","st":"OK","er":""},"10":{"data":"00","st":"OK","er":""},"12":{"data":"00","st":"OK","er":""},"14":{"data":"04167403","st":"OK","er":""},"63":{"data":"24","st":"OK","er":""},"90":{"data":"0D00","st":"OK","er":""},"92":{"data":"0000","st":"OK","er":""},"93":{"data":"02010D4BA80F000013","st":"OK","er":""},"94":{"data":"CC5B9400","st":"OK","er":""},"790":{"data":"0:00630F380000100008080D00E50166000000000000006E605F04100238088300","st":"OK","er":""},"791":{"data":"1:C000000000331906031578008600000040002D00000001000A00910C09068103","st":"OK","er":""},"792":{"data":"2:003C3C000000000047000000A00F90013C006302A00F90010038AD033C000000","st":"OK","er":""},"793":null,"794":null,"lu":"2025-01-05 12:42:28","df":161}}],"errors":[],"waterscene_time":null,"waterscene_time_garden":2,"waterscene_time_heater":null,"waterscene_time_washing":null,"waterscene":"normal","disable_time":"","waterscene_normal":8,"hardness_shower":4,"hardness_watering":12,"hardness_heater":1,"hardness_washing":1,"sleepmode_time":null,"holiday_mode":null,"update":"0","utc_offset":99},{"ewuid":"6fa81941-9e3b-11ef-af7e-005056930189","serialnumber":"002187E80831","installation_date":"2023-11-11T09:48:10","status":"online","bct":"LAN","sv":"3.20","hv":"4.0","data":[{"da":"0x1","dt":"0x33","sv":"3.2n","hv":"5.10","data":{"1":{"data":"6E0203","st":"OK","er":""},"2":{"data":"0A05","st":"OK","er":""},"3":{"data":"AED20300","st":"OK","er":""},"5":{"data":"25007503","st":"OK","er":""},"6":{"data":"62EBCC5D","st":"OK","er":""},"7":{"data":"0A2002000300","st":"OK","er":""},"8":{"data":"12150700","st":"OK","er":""},"9":{"data":"22F60300","st":"OK","er":""},"10":{"data":"00","st":"OK","er":""},"12":{"data":"00","st":"OK","er":""},"14":{"data":"26007503","st":"OK","er":""},"63":{"data":"24","st":"OK","er":""},"90":{"data":"0E00","st":"OK","er":""},"92":{"data":"0000","st":"OK","er":""},"93":{"data":"02019B000000000013","st":"OK","er":""},"94":{"data":"CC5B9400","st":"OK","er":""},"790":{"data":"0:00630F380000110008020E00E7016A000000000000006E603404104238087F00","st":"OK","er":""},"791":{"data":"1:C00000000031D007101378008600000000000000000000000000910C09068103","st":"OK","er":""},"792":{"data":"2:003A3C000000000047000000A00F90013C006302A00F90010415AD033C0000A0","st":"OK","er":""},"793":null,"794":null,"lu":"2025-01-05 15:22:43","df":0}}],"errors":[],"waterscene_time":null,"waterscene_time_garden":null,"waterscene_time_heater":null,"waterscene_time_washing":null,"waterscene":null,"disable_time":null,"waterscene_normal":8,"hardness_shower":4,"hardness_watering":10,"hardness_heater":1,"hardness_washing":1,"sleepmode_time":null,"holiday_mode":null,"update":"0","utc_offset":99}],"status":"ok","token":"45a1531fc2bb5a0a4c6cbf3edb5a499e","command":"get device data"}
                              judoisoft.0
                              2025-01-05 15:23:28.332	debug	get Consumption data Cloud
                              judoisoft.0
                              2025-01-05 15:18:28.323	debug	-> Battery75
                              judoisoft.0
                              2025-01-05 15:18:28.314	debug	-> StandByValue0
                              judoisoft.0
                              2025-01-05 15:18:28.306	debug	-> WaterCurrent
                              judoisoft.0
                              2025-01-05 15:18:28.298	debug	-> SaltQuantity
                              judoisoft.0
                              2025-01-05 15:18:28.250	debug	-> ResidualHardness
                              judoisoft.0
                              2025-01-05 15:18:28.249	debug	--> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
                              judoisoft.0
                              2025-01-05 15:18:28.240	debug	-> NaturalHardness
                              judoisoft.0
                              2025-01-05 15:18:28.230	debug	-> SaltRange
                              judoisoft.0
                              2025-01-05 15:18:28.221	debug	-> WaterTotal
                              judoisoft.0
                              2025-01-05 15:18:28.207	debug	-> Maintenance 341
                              judoisoft.0
                              2025-01-05 15:18:28.173	debug	-> ServiceDays 4.Aug.2022
                              judoisoft.0
                              2025-01-05 15:18:28.076	debug	-> InstallationDate 4.Aug.2022
                              judoisoft.0
                              2025-01-05 15:18:28.075	debug	-> _dt 0x33
                              judoisoft.0
                              2025-01-05 15:18:28.075	debug	-> _da 0x1
                              judoisoft.0
                              2025-01-05 15:18:28.074	debug	-> HardwareVersion
                              judoisoft.0
                              2025-01-05 15:18:28.056	debug	-> SoftwareVersion
                              judoisoft.0
                              2025-01-05 15:18:28.044	debug	-> SerialNumber
                              judoisoft.0
                              2025-01-05 15:18:28.031	debug	all fine {"data":[{"ewuid":"5de7c74a-9e3b-11ef-af7e-005056930189","serialnumber":"e8eb1bf3a0ee","installation_date":"2022-08-07T09:53:37","status":"offline","bct":"rs485","sv":"1.13","hv":"1.0","data":[{"da":"0x1","dt":"0x33","sv":"2.20j","hv":"5.10","data":{"1":{"data":"6A1402","st":"OK","er":""},"2":{"data":"0A05","st":"OK","er":""},"3":{"data":"AED20300","st":"OK","er":""},"5":{"data":"04167403","st":"OK","er":""},"6":{"data":"62EBCBD4","st":"OK","er":""},"7":{"data":"0C2002000300","st":"OK","er":""},"8":{"data":"D4140700","st":"OK","er":""},"9":{"data":"06F60300","st":"OK","er":""},"10":{"data":"00","st":"OK","er":""},"12":{"data":"00","st":"OK","er":""},"14":{"data":"04167403","st":"OK","er":""},"63":{"data":"24","st":"OK","er":""},"90":{"data":"0D00","st":"OK","er":""},"92":{"data":"0000","st":"OK","er":""},"93":{"data":"02010D4BA80F000013","st":"OK","er":""},"94":{"data":"CC5B9400","st":"OK","er":""},"790":{"data":"0:00630F380000100008080D00E50166000000000000006E605F04100238088300","st":"OK","er":""},"791":{"data":"1:C000000000331906031578008600000040002D00000001000A00910C09068103","st":"OK","er":""},"792":{"data":"2:003C3C000000000047000000A00F90013C006302A00F90010038AD033C000000","st":"OK","er":""},"793":null,"794":null,"lu":"2025-01-05 12:42:28","df":156}}],"errors":[],"waterscene_time":null,"waterscene_time_garden":2,"waterscene_time_heater":null,"waterscene_time_washing":null,"waterscene":"normal","disable_time":"","waterscene_normal":8,"hardness_shower":4,"hardness_watering":12,"hardness_heater":1,"hardness_washing":1,"sleepmode_time":null,"holiday_mode":null,"update":"0","utc_offset":99},{"ewuid":"6fa81941-9e3b-11ef-af7e-005056930189","serialnumber":"002187E80831","installation_date":"2023-11-11T09:48:10","status":"online","bct":"LAN","sv":"3.20","hv":"4.0","data":[{"da":"0x1","dt":"0x33","sv":"3.2n","hv":"5.10","data":{"1":{"data":"6E0203","st":"OK","er":""},"2":{"data":"0A05","st":"OK","er":""},"3":{"data":"AED20300","st":"OK","er":""},"5":{"data":"1B007503","st":"OK","er":""},"6":{"data":"62EBCC5D","st":"OK","er":""},"7":{"data":"0A2002000300","st":"OK","er":""},"8":{"data":"12150700","st":"OK","er":""},"9":{"data":"22F60300","st":"OK","er":""},"10":{"data":"00","st":"OK","er":""},"12":{"data":"00","st":"OK","er":""},"14":{"data":"21007503","st":"OK","er":""},"63":{"data":"24","st":"OK","er":""},"90":{"data":"0E00","st":"OK","er":""},"92":{"data":"0000","st":"OK","er":""},"93":{"data":"02019B000000000013","st":"OK","er":""},"94":{"data":"CC5B9400","st":"OK","er":""},"790":{"data":"0:00630F380000110008020E00E7016A000000000000006E603404104238087F00","st":"OK","er":""},"791":{"data":"1:C00000000031D007101378008600000000000000000000000000910C09068103","st":"OK","er":""},"792":{"data":"2:003C3C000000000047000000A00F90013C006302A00F9001001AAD033C00009D","st":"OK","er":""},"793":null,"794":null,"lu":"2025-01-05 15:18:25","df":0}}],"errors":[],"waterscene_time":null,"waterscene_time_garden":null,"waterscene_time_heater":null,"waterscene_time_washing":null,"waterscene":null,"disable_time":null,"waterscene_normal":8,"hardness_shower":4,"hardness_watering":10,"hardness_heater":1,"hardness_washing":1,"sleepmode_time":null,"holiday_mode":null,"update":"0","utc_offset":99}],"status":"ok","token":"45a1531fc2bb5a0a4c6cbf3edb5a499e","command":"get device data"}
                              judoisoft.0
                              2025-01-05 15:18:27.943	debug	get Consumption data Cloud
                              judoisoft.0
                              2025-01-05 15:18:27.673	debug	get statusURL for Cloud
                              judoisoft.0
                              2025-01-05 15:18:27.162	debug	create state
                              judoisoft.0
                              2025-01-05 15:18:27.156	debug	base url https://www.myjudo.eu/interface/
                              judoisoft.0
                              2025-01-05 15:18:27.104	info	starting. Version 1.1.2 (non-npm: arteck/ioBroker.judoisoft) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
                              1. Im Fall, dass man versucht lokal zuzugreifen (Adapter-Checkbox "cloud" nicht angehakt):
                              judoisoft.0
                              2025-01-05 15:29:02.761	info	State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
                              judoisoft.0
                              2025-01-05 15:29:02.758	error	getInfos ERROR
                              judoisoft.0
                              2025-01-05 15:29:02.750	debug	get Consumption data Local
                              judoisoft.0
                              2025-01-05 15:29:02.748	error	ServiceDate ERROR
                              judoisoft.0
                              2025-01-05 15:29:02.740	error	InstallationDate ERROR
                              judoisoft.0
                              2025-01-05 15:29:02.730	error	HardwareVersion ERROR
                              judoisoft.0
                              2025-01-05 15:29:02.722	error	SoftwareVersion ERROR
                              judoisoft.0
                              2025-01-05 15:29:02.710	debug	get Information Static Local
                              judoisoft.0
                              2025-01-05 15:29:02.709	error	Check Login data (user:psw)
                              judoisoft.0
                              2025-01-05 15:29:02.602	debug	get statusURL for local
                              judoisoft.0
                              2025-01-05 15:29:01.708	debug	create state
                              judoisoft.0
                              2025-01-05 15:29:01.705	debug	base url https://192.168.1.107:8124/?group=
                              judoisoft.0
                              2025-01-05 15:29:01.683	info	starting. Version 1.1.2 (non-npm: arteck/ioBroker.judoisoft) in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
                              • K krodon
                                Krodon
                                SmartHomer 0
                                #206
                                Evtl. hast Du noch eine ältere Software-Version auf Deiner judo-Anlage installiert.
                                Im JU-Control-Portal müsste sich in diesem Fall eine Anzeige finden wie z.B.: "Software-Update verfügbar".
                                Das Update dauert aber gute 15-30 Minuten
                                • S SmartHomer 0
                                  krodon
                                  #207
                                  Du hast mir heute sehr viel geholfen, der Techniker hatte es nur aufgestellt und gezeigt, wie man Salz auffüllt. Wlan habe ich anschließend selber gemacht. Von Batterien hatte auch nichts gesagt.
                                  Meine Softwareversion ist 1.0.12. Das Update muss ich über die EMail machen
                                  Hast Du eine Ahnung was die Firma bei der Wartung macht?
                                  • K krodon
                                    SmartHomer 0
                                    #208
                                    Sehr gerne
                                    Im Detail nicht, aber: Neben einigen Einstellungen und Messungen ist im Wartungspreis enthalten lt. Angebot/Rechnung auch ein "Verschleissteil-Set", das getauscht wird (Leitwert-Sensor / Ansaug-Sieb).
                                    • Fredi Van WensenF Offline
                                      Fredi Van Wensen
                                      #209
                                      Guten Tag!
                                      Hat es jetzt bei jedem nur bei mir nicht funktioniert? Habe wirklich alles versucht aber es funktioniert einfach nicht. Hat bis vor ca 2 bis 3 Wochen ohne Problmen funktioniert, und jetzt über IOBroker nicht mehr
                                        Fredi Van Wensen
                                        #210
                                        Habe SW Update vom Judo und Adapter gemacht. Welche Connectivity SW soll man haben?
                                        • Fredi Van WensenF Fredi Van Wensen
                                          Guten Tag!
                                          SmartHomer 0
                                          #211
                                          @fredi-van-wensen
                                          Dazu reiht sich auch dieser Thread ein:
                                          Fehler nach update judo soft adapter
                                          Auch bei mir funktioniert es wieder nicht mehr, sieht aus als ob judo erneut was gemacht hat.
                                          Meine Connectivity-Modul Softwareversion: 3.2
                                          judo-App und judo-Portal funktionieren weiterhin, obwohl auf dieselben Cloud-Informationen zugegriffen wird und die App kein Update hatte (?)
                                          HeimerdingerH 1 Antwort Letzte Antwort
