  4. <gelöst>Zigbee ist tod
update problem zigbeezigbeezigbee läuft nicht mehr
58 Beiträge 8 Kommentatoren 8.4k Aufrufe 8 Beobachtet
  • WinniW Winni
    @crunchip Würde ich gerne, aber das ist leider nichts.
    Jetzt ist was gekommen.
    zigbee.0
    Zeit
    info
    Nachricht
    zigbee.0
    2025-01-01 10:30:58.370	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    zigbee.0
    2025-01-01 10:30:39.253	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    zigbee.0
    2025-01-01 10:25:57.540	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups'
    crunchipC Abwesend
    crunchipC Abwesend
    @winni sagte in Zigbee ist tod:
    Würde ich gerne
    lass doch beides auf Info
    Adapter neu starten
    danach kopierst du das gesamte zigbee
    • WinniW Winni
      v7.3.2
      Log-Größe: 10.0 KB
      zigbee.0
      Zeit
      silly
      Nachricht
      zigbee.0
      2025-01-01 10:39:31.405	silly	States user redis pmessage zigbee.0.*/zigbee.0.a4c138c68ce14507.state:{"val":true,"ack":false,"ts":1735724371402,"q":0,"c":"script.js.Sonstiges.Küche2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1735715195532}
      zigbee.0
      2025-01-01 10:39:27.906	silly	States user redis pmessage zigbee.0.*/zigbee.0.a4c13852a125023b.state:{"val":false,"ack":false,"ts":1735724367904,"q":0,"c":"script.js.Sonstiges.Dose_Küche_","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1735724367904}
      zigbee.0
      2025-01-01 10:38:53.533	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1735724333531,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1735686673059}
      zigbee.0
      2025-01-01 10:38:53.525	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-10_38_53.tar.gz success
      zigbee.0
      2025-01-01 10:38:53.413	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      2025-01-01 10:38:53.280	debug	Starting zigbee-herdsman...
      zigbee.0
      2025-01-01 10:38:53.273	silly	States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1735724333255,"q":0,"from":"system.adapter.zigbee.0","lc":1735724333255}
      zigbee.0
      2025-01-01 10:38:53.254	info	Starting Zigbee npm ...
      zigbee.0
      2025-01-01 10:38:53.232	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyUSB0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
      zigbee.0
      2025-01-01 10:38:53.220	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
      zigbee.0
      2025-01-01 10:38:53.130	debug	Plugin sentry Do not initialize Plugin (enabled=false)
      Sorry für den verhunzt Post, aber ich kriegs im Moment nicht besser hin.
      aber ich ;-)
      WinniW 1 Antwort Letzte Antwort
      • WinniW Winni
        Guten Morgen und ein gutes neues Jahr.
        Ich habe folgendes Problem. Ich habe den Zigbee Adapter von der 1.10.9 auf die 1.10.13 upgedatet. Seitdem sind alle Geräte verschwunden.
        Statt dessen dieser Fehlerhinweis.
        Im Log steht diese Meldung:
        zigbee.0
        2025-01-01 08:50:25.199 error getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        Was ich bisher gemacht habe: iob stop, iob fix, iob Start. Versuch eine ältere Version des Adapters zu installieren, es wird aber nur bis 1.1.11 angeboten. Eine Backitup Sicherung einzuspielen, alles leider ohne Erfolg.
        Was ich noch machen kann, ich habe eine Kopie der ganzen Platte, die ist allerdings ein paar Tage alt. Auf diese dann die Backitup Sicherung von heute Nacht zurück spielen.
        Hat jemand eine andere Idee?
        Danke im voraus.
        Script v.2024-10-19
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.6.62+rpt-rpi-2712
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 5 Model B Rev 1.0
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         09:29:41 up  9:19,  4 users,  load average: 12.42, 12.23, 11.39
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Wed 2025-01-01 09:29:42 CET
                   Universal time: Wed 2025-01-01 08:29:42 UTC
                         RTC time: Wed 2025-01-01 08:29:42
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        winni
        HOME=/home/winni
        GROUPS=winni adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server: true
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            8.4G        4.3G        439M        129M        4.0G        4.2G
        Swap:           209M          0B        209M
        Total:          8.7G        4.3G        649M
        Active iob-Instances:   49
                 8052 M total memory
                 4053 M used memory
                 4325 M active memory
                 2432 M inactive memory
                  419 M free memory
                  226 M buffer memory
                 3576 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        top - 09:29:42 up  9:19,  4 users,  load average: 12.42, 12.23, 11.39
        Tasks: 295 total,   1 running, 294 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   8052.2 total,    418.8 free,   4054.6 used,   3802.7 buff/cache
        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3997.6 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        15 CRITICAL ERRORS DETECTED!
        Check 'sudo dmesg --level=emerg,alert,crit -T' for details
        *** FILESYSTEM ***
        udev           devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs          tmpfs     806M  8.8M  797M   2% /run
        /dev/sda2      ext4      219G   30G  178G  15% /
        tmpfs          tmpfs     4.0G   23M  4.0G   1% /dev/shm
        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
        /dev/sda1      vfat      511M   77M  435M  15% /boot/firmware
        tmpfs          tmpfs     806M  192K  806M   1% /run/user/1000
        [Wed Jan  1 00:10:21 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=D8:3A:DD:BA:ED:B0 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=6bc658c1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Wed Jan  1 00:10:23 2025] EXT4-fs (sda2): mounted filesystem b8316dab-786b-45e8-815c-3d4bbf198d98 ro with ordered data mode. Quota mode: none.
        [Wed Jan  1 00:10:24 2025] EXT4-fs (sda2): re-mounted b8316dab-786b-45e8-815c-3d4bbf198d98 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET               SOURCE    FSTYPE      OPTIONS
        /                    /dev/sda2 ext4        rw,noatime
        |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        5.5G    /var/
        4.3G    /var/cache/apt
        4.3G    /var/cache
        4.2G    /var/cache/apt/archives
        830M    /var/log
        Archived and active journals take up 745.5M in the file system.
        /opt/iobroker/backups:
        449M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        3.4G    /opt/iobroker/iobroker-data/
        1.9G    /opt/iobroker/iobroker-data/history
        1.4G    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        38M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyUSB0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1502)
        Core adapters versions
        admin:          7.3.2
        javascript:     8.8.3
        nodejs modules from github:     4
        +-- iobroker.bluelink@3.1.0 (git+ssh://git@github.com/Newan/ioBroker.bluelink.git#ba4ca016c51236979f898af6d5310defe0e6a2a5)
        +-- iobroker.innogy-smarthome@1.2.6 (git+ssh://git@github.com/PArns/ioBroker.innogy-smarthome.git#8d8039c470db61972352f4578dd80e741e4640e8)
        +-- iobroker.nuki@2.0.0 (git+ssh://git@github.com/smaragdschlange/ioBroker.nuki.git#7bb88d9d2502908c7eadb3b573138b1ed72be910)
        +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#87a9b7837569274a136c4fa03ee6fbfd8a20f183)
        Adapter State
        + system.adapter.bluelink.0               : bluelink              : raspberrypi                              -  enabled
          system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              - disabled
          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
          system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
        + system.adapter.hue.1                    : hue                   : raspberrypi                              -  enabled, port: 80
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
          system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: raspberrypi                              - disabled
          system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi                              - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
          system.adapter.icons-smarthome.0        : icons-smarthome       : raspberrypi                              - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
        + system.adapter.innogy-smarthome.0       : innogy-smarthome      : raspberrypi                              -  enabled
        + system.adapter.innogy-smarthome.1       : innogy-smarthome      : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
        + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
        + system.adapter.modbus.2                 : modbus                : raspberrypi                              -  enabled
        + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
        + system.adapter.nuki.0                   : nuki                  : raspberrypi                              -  enabled
        + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.sma-em.0                 : sma-em                : raspberrypi                              -  enabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sonoff.10                : sonoff                : raspberrypi                              -  enabled, port: 1893, bind: 0.0.0.0
        + system.adapter.sonoff.11                : sonoff                : raspberrypi                              -  enabled, port: 1896, bind: 0.0.0.0
        + system.adapter.sonoff.12                : sonoff                : raspberrypi                              -  enabled, port: 1897, bind: 0.0.0.0
        + system.adapter.sonoff.13                : sonoff                : raspberrypi                              -  enabled, port: 1898, bind: 0.0.0.0
        + system.adapter.sonoff.14                : sonoff                : raspberrypi                              -  enabled, port: 1899, bind: 0.0.0.0
        + system.adapter.sonoff.15                : sonoff                : raspberrypi                              -  enabled, port: 1900, bind: 0.0.0.0
        + system.adapter.sonoff.2                 : sonoff                : raspberrypi                              -  enabled, port: 1894, bind: 0.0.0.0
        + system.adapter.sonoff.3                 : sonoff                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.sonoff.4                 : sonoff                : raspberrypi                              -  enabled, port: 1887, bind: 0.0.0.0
        + system.adapter.sonoff.5                 : sonoff                : raspberrypi                              -  enabled, port: 1888, bind: 0.0.0.0
        + system.adapter.sonoff.6                 : sonoff                : raspberrypi                              -  enabled, port: 1889, bind: 0.0.0.0
        + system.adapter.sonoff.7                 : sonoff                : raspberrypi                              -  enabled, port: 1890, bind: 0.0.0.0
        + system.adapter.sonoff.8                 : sonoff                : raspberrypi                              -  enabled, port: 1891, bind: 0.0.0.0
        + system.adapter.sonoff.9                 : sonoff                : raspberrypi                              -  enabled, port: 1892, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
          system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.3.2
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "bluelink"     : 2.3.6    , installed 3.1.0
        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
        Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
        Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
        Adapter    "hs100"        : 2.2.2    , installed 2.2.2
        Adapter    "hue"          : 3.13.1   , installed 3.13.1
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
        Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
        Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
        Adapter    "operating-hours": 1.2.0  , installed 1.2.0
        Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
        Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
        Adapter    "sma-em"       : 1.1.0    , installed 1.1.0
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
        Objects and States
        Objects:        32913
        States:         26614
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       491202     42720/io.sonoff.7
        tcp        0      0 0.0.0.0:1891            0.0.0.0:*               LISTEN      1001       492692     42765/io.sonoff.8
        tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       491725     42679/io.sonoff.5
        tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       492607     42701/io.sonoff.6
        tcp        0      0 0.0.0.0:1894            0.0.0.0:*               LISTEN      1001       491695     42626/io.sonoff.2
        tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       491909     42794/io.sonoff.9
        tcp        0      0 0.0.0.0:1893            0.0.0.0:*               LISTEN      1001       489455     42509/io.sonoff.10
        tcp        0      0 0.0.0.0:1898            0.0.0.0:*               LISTEN      1001       491603     42569/io.sonoff.13
        tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       491642     42587/io.sonoff.14
        tcp        0      0 0.0.0.0:1896            0.0.0.0:*               LISTEN      1001       490312     42532/io.sonoff.11
        tcp        0      0 0.0.0.0:1897            0.0.0.0:*               LISTEN      1001       490970     42550/io.sonoff.12
        tcp        0      0 0.0.0.0:1900            0.0.0.0:*               LISTEN      1001       491671     42606/io.sonoff.15
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       488215     42491/io.sonoff.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       491090     42644/io.sonoff.3
        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       491117     42662/io.sonoff.4
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          8674       1243/smbd
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8594       1227/lighttpd
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        10575      1221/pihole-FTL
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6082       955/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          8675       1243/smbd
        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        10581      1221/pihole-FTL
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8301       934/cupsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       486392     42034/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       486386     42034/iobroker.js-c
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8300       934/cupsd
        tcp6       0      0 ::1:4711                :::*                    LISTEN      999        10582      1221/pihole-FTL
        tcp6       0      0 :::445                  :::*                    LISTEN      0          8672       1243/smbd
        tcp6       0      0 :::80                   :::*                    LISTEN      0          8593       1227/lighttpd
        tcp6       0      0 :::53                   :::*                    LISTEN      999        10577      1221/pihole-FTL
        tcp6       0      0 :::22                   :::*                    LISTEN      0          6084       955/sshd: /usr/sbin
        tcp6       0      0 :::139                  :::*                    LISTEN      0          8673       1243/smbd
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       493842     42873/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       486988     42052/io.admin.0
        udp        0      0 0.0.0.0:40165           0.0.0.0:*                           1001       488102     42415/io.ping.0
        udp        0      0 0.0.0.0:60746           0.0.0.0:*                           104        6032       735/avahi-daemon: r
        udp        0      0 0.0.0.0:60835           0.0.0.0:*                           1001       489154     42316/io.modbus.1
        udp        0      0 0.0.0.0:56822           0.0.0.0:*                           1001       492759     42843/io.vis-invent
        udp        0      0 0.0.0.0:60919           0.0.0.0:*                           1001       490674     42332/io.modbus.2
        udp        0      0 0.0.0.0:60922           0.0.0.0:*                           1001       493009     43013/io.hs100.0
        udp        0      0 0.0.0.0:56974           0.0.0.0:*                           1001       488182     42472/io.sma-em.0
        udp        0      0 0.0.0.0:40618           0.0.0.0:*                           1001       489991     42348/io.netatmo.0
        udp        0      0 0.0.0.0:52946           0.0.0.0:*                           1001       487409     42201/io.alexa2.0
        udp        0      0 0.0.0.0:40855           0.0.0.0:*                           1001       490152     42441/io.rpi2.0
        udp        0      0 0.0.0.0:44999           0.0.0.0:*                           1001       494888     43120/io.echarts.0
        udp        0      0 0.0.0.0:45038           0.0.0.0:*                           1001       493924     42944/io.energieflu
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        10574      1221/pihole-FTL
        udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          9730       1239/nmbd
        udp        0      0 192.168.1.134:137       0.0.0.0:*                           0          9729       1239/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          9711       1239/nmbd
        udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          9732       1239/nmbd
        udp        0      0 192.168.1.134:138       0.0.0.0:*                           0          9731       1239/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          9712       1239/nmbd
        udp        0      0 0.0.0.0:41243           0.0.0.0:*                           1001       490080     42389/io.operating-
        udp        0      0 0.0.0.0:53605           0.0.0.0:*                           1001       490512     42221/io.backitup.0
        udp        0      0 0.0.0.0:33194           0.0.0.0:*                           1001       488560     42034/iobroker.js-c
        udp        0      0 0.0.0.0:41404           0.0.0.0:*                           1001       492898     42961/io.fb-checkpr
        udp        0      0 0.0.0.0:41412           0.0.0.0:*                           1001       493095     43085/io.pvforecast
        udp        0      0 0.0.0.0:45509           0.0.0.0:*                           1001       494855     43102/io.sourceanal
        udp        0      0 0.0.0.0:41527           0.0.0.0:*                           1001       488764     42145/io.email.0
        udp        0      0 0.0.0.0:33344           0.0.0.0:*                           1001       487717     42129/io.javascript
        udp        0      0 0.0.0.0:54131           0.0.0.0:*                           1001       488939     42241/io.hue.1
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6030       735/avahi-daemon: r
        udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       488183     42472/io.sma-em.0
        udp        0      0 0.0.0.0:58763           0.0.0.0:*                           1001       492809     42893/io.bluelink.0
        udp        0      0 0.0.0.0:51029           0.0.0.0:*                           1001       491980     42824/io.tr-064.1
        udp        0      0 0.0.0.0:42850           0.0.0.0:*                           1001       487911     42286/io.innogy-sma
        udp        0      0 0.0.0.0:42883           0.0.0.0:*                           1001       487386     42190/io.zigbee.0
        udp        0      0 0.0.0.0:47513           0.0.0.0:*                           1001       487946     42301/io.modbus.0
        udp        0      0 0.0.0.0:39328           0.0.0.0:*                           1001       488605     42052/io.admin.0
        udp        0      0 0.0.0.0:60156           0.0.0.0:*                           1001       493066     43060/io.iot.0
        udp6       0      0 :::35986                :::*                                104        6033       735/avahi-daemon: r
        udp6       0      0 :::53                   :::*                                999        10576      1221/pihole-FTL
        udp6       0      0 fe80::67fb:be67:45b:546 :::*                                0          10548      896/NetworkManager
        udp6       0      0 :::5353                 :::*                                104        6031       735/avahi-daemon: r
        2025-01-01 09:08:05.587  - info: sourceanalytix.0 (43102) Successfully activated SourceAnalytix for 6 of 6 states, will do my Job until you stop me!
        2025-01-01 09:08:09.352  - info: fb-checkpresence.0 (42961) createFbDeviceObjects finished successfully
        2025-01-01 09:08:09.353  - info: fb-checkpresence.0 (42961) states successfully subscribed
        2025-01-01 09:08:09.354  - info: fb-checkpresence.0 (42961) loop successfully started2025-01-01 09:08:34.234  - info: admin.0 (42052) ==> Connected system.user.admin from ::ffff:192.168.1.134
        2025-01-01 09:08:53.130  - info: admin.0 (42052) ==> Connected system.user.admin from ::ffff:192.168.1.134
        2025-01-01 09:08:58.890  - info: admin.0 (42052) <== Disconnect system.user.admin from ::ffff:192.168.1.134
        2025-01-01 09:09:00.045  - info: javascript.0 (42129) script.js.Sonstiges.Zieltemperaturen-Pruefen: Achtung im Mariazimmer wurde die Zieltemperatur nicht übernommen
        2025-01-01 09:09:00.045  - info: javascript.0 (42129) script.js.Sonstiges.ZieltemperaCopy text starting here:
        ```bash
        ======================= SUMMARY =======================                                                      v.2024-10-19
         Static hostname: raspberrypi                                                               Icon name: computer
        Operating System: Debian GNU/Linux 12 (bookworm)                                               Kernel: Linux 6.6.62+rpt-rpi-2712
            Architecture: arm64
        Installation:           native                                                       Kernel:                 aarch64
        Userland:               64 bit                                                       Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000                                                         Display-Server:         true
        Pending OS-Updates:     0                                                            Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/nodejs         v20.18.1                                                     /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2                                                       /usr/bin/npx            10.8.2
        Recommended versions are nodejs 20.18.1 and npm 10.8.2                               nodeJS installation is correct
        MEMORY:
        Mem:            8.4G        4.3G        878M        129M        3.5G        4.1G
        Swap:           209M          0B        209M
        Total:          8.7G        4.3G        1.1G
        ioBroker Core:          js-controller           7.0.6
                                admin                   7.3.2
        Objects type: jsonl
        States  type: jsonl
        Objects:                32913
        States:                 26614
        Size of iob-Database:
        48M     /opt/iobroker/iobroker-data/objects.jsonl
        22M     /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        winni
        HOME=/home/winni
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 8052 M total memory
                 4053 M used memory
                  419 M free memory
                  226 M buffer memory
                 3576 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        5.5G    /var/
        4.3G    /var/cache/apt
        4.3G    /var/cache
        830M    /var/log
        USB-Devices by-id:
        HINT:
        /dev/ttyUSB0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.3.2
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        32913
        States:         26614
        Pending Updates: 0
        ```bash
            Architecture: arm64
        MEMORY:
        Swap:           209M          0B        209M
                                admin                   7.3.2
        Objects type: jsonl
        States  type: jsonl
        Objects:                32913
        States:                 26614
        Das schaut nicht gut aus.
        winni@raspberrypi:~ $ sudo dmesg --level=emerg,alert,crit -T
        [Mi Jan  1 00:10:26 2025] Unable to handle kernel paging request at virtual address ffffc000809b3f04
        [Mi Jan  1 00:10:26 2025] Mem abort info:
        [Mi Jan  1 00:10:26 2025]   ESR = 0x0000000096000047
        [Mi Jan  1 00:10:26 2025]   EC = 0x25: DABT (current EL), IL = 32 bits
        [Mi Jan  1 00:10:26 2025]   SET = 0, FnV = 0
        [Mi Jan  1 00:10:26 2025]   EA = 0, S1PTW = 0
        [Mi Jan  1 00:10:26 2025]   FSC = 0x07: level 3 translation fault
        [Mi Jan  1 00:10:26 2025] Data abort info:
        [Mi Jan  1 00:10:26 2025]   ISV = 0, ISS = 0x00000047, ISS2 = 0x00000000
        [Mi Jan  1 00:10:26 2025]   CM = 0, WnR = 1, TnD = 0, TagAccess = 0
        [Mi Jan  1 00:10:26 2025]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
        [Mi Jan  1 00:10:26 2025] swapper pgtable: 16k pages, 47-bit VAs, pgdp=0000000001398000
        [Mi Jan  1 00:10:26 2025] [ffffc000809b3f04] pgd=100000010019c003, p4d=1000000
        Wenn ich mir
        CPU threads: 4
        und
        und
        Vermute ich ein Fehler auf tieferer Ebene.
        Dem
        HINT:
        solltest du für ein 'rundes' Setup von Zigbee auch nachkommen.
        Und warum hat man 16 Instanzen vom sonoff-Adapter laufen?
        • WinniW Winni
          v7.3.2
          Log-Größe: 10.0 KB
          zigbee.0
          Zeit
          silly
          Nachricht
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @winni mit den 3 Zeilen werden wir nix. Ein komplettes Log des Startup des Zigbee Adapters hat so 10 - 40 Zeilen.
          Ansonsten - ich bin im Discord - 2 User Only
          A.
            aber ich ;-)
            WinniW Offline
            WinniW Offline
            Winni
            @homoran danke 😀
              Wenn ich mir
              CPU threads: 4
              und
              und
              Dem
              HINT:
              WinniW Offline
              WinniW Offline
              Winni
              @thomas-braun ich habe 16 Tasmota Dosen. Ist im Laufe der Jahre einges zusammen gekommen.
              • WinniW Winni
                @winni
                Und warum muss jede Dose eine eigene Instanz haben? Versteh ich nicht...
                Kiste mal ganz einfach sauber durchgestartet?
                • WinniW Offline
                  WinniW Offline
                  Winni
                  Hier nochmal der Versuch den richtigen Log zu senden.
                  terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-01-01 11:05:00.603 - info: host.raspberrypi instance system.adapter.zigbee.0 in version "1.10.3" started with pid 56493
                  2025-01-01 11:05:02.766 - info: zigbee.0 (56493) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
                  2025-01-01 11:05:02.804 - info: zigbee.0 (56493) Starting Zigbee npm ...
                  2025-01-01 11:05:02.969 - info: zigbee.0 (56493) Installed Version: iobroker.zigbee@1.10.3
                  2025-01-01 11:05:41.859 - info: admin.0 (50672) <== Disconnect system.user.admin from ::ffff:192.168.1.21 admin
                  • WinniW Winni
                    den richtigen Log
                    @asgothian sagte in Zigbee ist tod:
                      @winni
                      WinniW Offline
                      WinniW Offline
                      Winni
                      @thomas-braun Naja, ich wusste es nicht besser. Ich wusste nicht dass man mehrere Dosen auf eine Inzanz legen kann. Werde den Raspi gleich mal neu starten.
                      • WinniW Offline
                        WinniW Offline
                        Winni
                        Beim Neustart des Raspberry stehen diese Meldungen im Log:
                        zigbee.0
                        2025-01-01 11:23:48.228	error	Error herdsman start
                        zigbee.0
                        2025-01-01 11:23:48.227	error	Failed to start Zigbee
                        zigbee.0
                        2025-01-01 11:23:48.226	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                        zigbee.0
                        2025-01-01 11:23:48.050	info	Installed Version: iobroker.zigbee@1.10.3
                        zigbee.0
                        2025-01-01 11:23:48.027	info	Starting Zigbee npm ...
                        zigbee.0
                        2025-01-01 11:23:48.026	info	Try to reconnect. 1 attempts left
                        zigbee.0
                        2025-01-01 11:23:38.024	error	Error herdsman start
                        zigbee.0
                        2025-01-01 11:23:38.023	error	Failed to start Zigbee
                        zigbee.0
                        2025-01-01 11:23:38.019	error	Starting zigbee-herdsman problem : "Attempt to access memory outside buffer bounds"
                        zigbee.0
                        2025-01-01 11:23:37.239	info	Installed Version: iobroker.zigbee@1.10.3
                        zigbee.0
                        2025-01-01 11:23:36.242	info	Starting Zigbee npm ...
                        zigbee.0
                        2025-01-01 11:23:36.181	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
                        Hoffe dass das aussagekräftiger ist.
                        • WinniW Winni
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @winni Ist es. Bitte schau im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 nach, da liegen verschiedene tgz Dateien. Du musst folgendes tun:
                          • Zigbee Adapter anhalten (wichtig, auch wenn er nicht vollständig läuft)
                          • besagte Datei entpacken, damit shepherd.db und nvbackup.json zurück setzen
                          • Zigbee-Adapter starten
                          A,
                          • AsgothianA Asgothian
                            A,
                            WinniW Offline
                            WinniW Offline
                            Winni
                            @asgothian das ist der Inhalt des Verzeichnis, welche Dateien meinst du?
                             /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-10_29_50.tar.gz
                            /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-10_33_16.tar.gz
                            /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-10_37_18.tar.gz
                            /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_02_51.tar.gz
                            /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_04_27.tar.gz
                            /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_05_02.tar.gz
                            /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_23_36.tar.gz
                            /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_47_19.tar.gz
                            /opt/iobroker/iobroker-data/zigbee_0/dev_names.json
                            /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-09-04T06-44-44.442Z
                            /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-09-14T16-55-53.337Z
                            /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-09-28T14-21-20.762Z
                            /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-09-28T15-39-41.769Z
                            /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-11-08T05-14-11.384Z
                            • WinniW Winni
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @winni ich fürchte die Datei ist da nicht mehr - du hast den Adapter mehr als 10 mal neu gestartet. Bitte via backitup ausschliesslich das letzte Zigbee Backup zurück spielen. Wirklich nur das, der Rest darf bleiben
                              A.
                                A.
                                WinniW Offline
                                WinniW Offline
                                Winni
                                @asgothian jetzt schaut es so aus:
                                Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                                • WinniW Winni
                                  @winni
                                  Manchmal sieht man anhand der Dateigröße etwas. Schau dir die Daten also per
                                  ls -lh /opt/iobroker/iobroker-data/zigbee_0/
                                  an.
                                  • WinniW Winni
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @winni wie es aussieht ist nicht wichtig - solange das zurück gespielte backup des Zigbee Adapters von gestern ist, kannst du den jetzt starten und er sollte laufen
                                    A.
                                      @winni
                                      an.
                                      WinniW Offline
                                      WinniW Offline
                                      Winni
                                      @thomas-braun sagte in Zigbee ist tod:
                                      -rw-rw-r--+ 1 iobroker iobroker 4,6K  1. Jan 12:17 backup_2025_01_01-12_17_17.tar.gz
                                      -rw-r-xr--+ 1 iobroker iobroker  992  1. Jan 12:11 dev_names.json
                                      -rw-r--r--+ 1 iobroker iobroker 6,5K  1. Jan 12:11 nvbackup.json
                                      -rw-r--r--+ 1 iobroker iobroker  41K  1. Jan 12:11 shepherd.db
                                      -rw-r-xr--+ 1 iobroker iobroker  33K  1. Jan 12:11 shepherd.db.tmp.2024-09-04T06-44-44.442Z
                                      -rw-r-xr--+ 1 iobroker iobroker  33K  1. Jan 12:11 shepherd.db.tmp.2024-09-14T16-55-53.337Z
                                      -rw-r-xr--+ 1 iobroker iobroker    0  1. Jan 12:11 shepherd.db.tmp.2024-09-28T14-21-20.762Z
                                      -rw-r-xr--+ 1 iobroker iobroker    0  1. Jan 12:11 shepherd.db.tmp.2024-09-28T15-39-41.769Z
                                        A.
                                        WinniW Offline
                                        WinniW Offline
                                        Winni
                                        @asgothian Leider nicht, alles so wie vorher
                                        HomoranH AsgothianA 2 Antworten Letzte Antwort
                                        • WinniW Winni
                                          Leider nicht
                                          was?
                                          nicht von gestern?
