  4. <gelöst>Zigbee ist tod
update problem zigbeezigbeezigbee läuft nicht mehr
58 Beiträge 8 Kommentatoren 8.4k Aufrufe 8 Beobachtet
  • WinniW Winni
    v7.3.2
    Log-Größe: 10.0 KB
    zigbee.0
    Zeit
    silly
    Nachricht
    zigbee.0
    2025-01-01 10:39:31.405	silly	States user redis pmessage zigbee.0.*/zigbee.0.a4c138c68ce14507.state:{"val":true,"ack":false,"ts":1735724371402,"q":0,"c":"script.js.Sonstiges.Küche2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1735715195532}
    zigbee.0
    2025-01-01 10:39:27.906	silly	States user redis pmessage zigbee.0.*/zigbee.0.a4c13852a125023b.state:{"val":false,"ack":false,"ts":1735724367904,"q":0,"c":"script.js.Sonstiges.Dose_Küche_","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1735724367904}
    zigbee.0
    2025-01-01 10:38:53.533	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1735724333531,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1735686673059}
    zigbee.0
    2025-01-01 10:38:53.525	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-10_38_53.tar.gz success
    zigbee.0
    2025-01-01 10:38:53.413	info	Installed Version: iobroker.zigbee@1.10.3
    zigbee.0
    2025-01-01 10:38:53.280	debug	Starting zigbee-herdsman...
    zigbee.0
    2025-01-01 10:38:53.273	silly	States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1735724333255,"q":0,"from":"system.adapter.zigbee.0","lc":1735724333255}
    zigbee.0
    2025-01-01 10:38:53.254	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-01 10:38:53.232	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyUSB0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
    zigbee.0
    2025-01-01 10:38:53.220	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
    zigbee.0
    2025-01-01 10:38:53.130	debug	Plugin sentry Do not initialize Plugin (enabled=false)
    Sorry für den verhunzt Post, aber ich kriegs im Moment nicht besser hin.
    @winni sagte in Zigbee ist tod:
    aber ich ;-)
    WinniW 1 Antwort Letzte Antwort
    • WinniW Winni
      Guten Morgen und ein gutes neues Jahr.
      Ich habe folgendes Problem. Ich habe den Zigbee Adapter von der 1.10.9 auf die 1.10.13 upgedatet. Seitdem sind alle Geräte verschwunden.
      Statt dessen dieser Fehlerhinweis.
      Im Log steht diese Meldung:
      zigbee.0
      2025-01-01 08:50:25.199 error getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      Was ich bisher gemacht habe: iob stop, iob fix, iob Start. Versuch eine ältere Version des Adapters zu installieren, es wird aber nur bis 1.1.11 angeboten. Eine Backitup Sicherung einzuspielen, alles leider ohne Erfolg.
      Was ich noch machen kann, ich habe eine Kopie der ganzen Platte, die ist allerdings ein paar Tage alt. Auf diese dann die Backitup Sicherung von heute Nacht zurück spielen.
      Hat jemand eine andere Idee?
      Danke im voraus.
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.62+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       09:29:41 up  9:19,  4 users,  load average: 12.42, 12.23, 11.39
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2025-01-01 09:29:42 CET
                 Universal time: Wed 2025-01-01 08:29:42 UTC
                       RTC time: Wed 2025-01-01 08:29:42
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      winni
      HOME=/home/winni
      GROUPS=winni adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.4G        4.3G        439M        129M        4.0G        4.2G
      Swap:           209M          0B        209M
      Total:          8.7G        4.3G        649M
      Active iob-Instances:   49
               8052 M total memory
               4053 M used memory
               4325 M active memory
               2432 M inactive memory
                419 M free memory
                226 M buffer memory
               3576 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 09:29:42 up  9:19,  4 users,  load average: 12.42, 12.23, 11.39
      Tasks: 295 total,   1 running, 294 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8052.2 total,    418.8 free,   4054.6 used,   3802.7 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3997.6 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      15 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     806M  8.8M  797M   2% /run
      /dev/sda2      ext4      219G   30G  178G  15% /
      tmpfs          tmpfs     4.0G   23M  4.0G   1% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/sda1      vfat      511M   77M  435M  15% /boot/firmware
      tmpfs          tmpfs     806M  192K  806M   1% /run/user/1000
      [Wed Jan  1 00:10:21 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=D8:3A:DD:BA:ED:B0 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=6bc658c1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Wed Jan  1 00:10:23 2025] EXT4-fs (sda2): mounted filesystem b8316dab-786b-45e8-815c-3d4bbf198d98 ro with ordered data mode. Quota mode: none.
      [Wed Jan  1 00:10:24 2025] EXT4-fs (sda2): re-mounted b8316dab-786b-45e8-815c-3d4bbf198d98 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET               SOURCE    FSTYPE      OPTIONS
      /                    /dev/sda2 ext4        rw,noatime
      |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      5.5G    /var/
      4.3G    /var/cache/apt
      4.3G    /var/cache
      4.2G    /var/cache/apt/archives
      830M    /var/log
      Archived and active journals take up 745.5M in the file system.
      /opt/iobroker/backups:
      449M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      3.4G    /opt/iobroker/iobroker-data/
      1.9G    /opt/iobroker/iobroker-data/history
      1.4G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      38M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1502)
      Core adapters versions
      admin:          7.3.2
      javascript:     8.8.3
      nodejs modules from github:     4
      +-- iobroker.bluelink@3.1.0 (git+ssh://git@github.com/Newan/ioBroker.bluelink.git#ba4ca016c51236979f898af6d5310defe0e6a2a5)
      +-- iobroker.innogy-smarthome@1.2.6 (git+ssh://git@github.com/PArns/ioBroker.innogy-smarthome.git#8d8039c470db61972352f4578dd80e741e4640e8)
      +-- iobroker.nuki@2.0.0 (git+ssh://git@github.com/smaragdschlange/ioBroker.nuki.git#7bb88d9d2502908c7eadb3b573138b1ed72be910)
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#87a9b7837569274a136c4fa03ee6fbfd8a20f183)
      Adapter State
      + system.adapter.bluelink.0               : bluelink              : raspberrypi                              -  enabled
        system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              - disabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
        system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
      + system.adapter.hue.1                    : hue                   : raspberrypi                              -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
        system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: raspberrypi                              - disabled
        system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
        system.adapter.icons-smarthome.0        : icons-smarthome       : raspberrypi                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      + system.adapter.innogy-smarthome.0       : innogy-smarthome      : raspberrypi                              -  enabled
      + system.adapter.innogy-smarthome.1       : innogy-smarthome      : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.2                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
      + system.adapter.nuki.0                   : nuki                  : raspberrypi                              -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.sma-em.0                 : sma-em                : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonoff.10                : sonoff                : raspberrypi                              -  enabled, port: 1893, bind: 0.0.0.0
      + system.adapter.sonoff.11                : sonoff                : raspberrypi                              -  enabled, port: 1896, bind: 0.0.0.0
      + system.adapter.sonoff.12                : sonoff                : raspberrypi                              -  enabled, port: 1897, bind: 0.0.0.0
      + system.adapter.sonoff.13                : sonoff                : raspberrypi                              -  enabled, port: 1898, bind: 0.0.0.0
      + system.adapter.sonoff.14                : sonoff                : raspberrypi                              -  enabled, port: 1899, bind: 0.0.0.0
      + system.adapter.sonoff.15                : sonoff                : raspberrypi                              -  enabled, port: 1900, bind: 0.0.0.0
      + system.adapter.sonoff.2                 : sonoff                : raspberrypi                              -  enabled, port: 1894, bind: 0.0.0.0
      + system.adapter.sonoff.3                 : sonoff                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.sonoff.4                 : sonoff                : raspberrypi                              -  enabled, port: 1887, bind: 0.0.0.0
      + system.adapter.sonoff.5                 : sonoff                : raspberrypi                              -  enabled, port: 1888, bind: 0.0.0.0
      + system.adapter.sonoff.6                 : sonoff                : raspberrypi                              -  enabled, port: 1889, bind: 0.0.0.0
      + system.adapter.sonoff.7                 : sonoff                : raspberrypi                              -  enabled, port: 1890, bind: 0.0.0.0
      + system.adapter.sonoff.8                 : sonoff                : raspberrypi                              -  enabled, port: 1891, bind: 0.0.0.0
      + system.adapter.sonoff.9                 : sonoff                : raspberrypi                              -  enabled, port: 1892, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.3.2
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "bluelink"     : 2.3.6    , installed 3.1.0
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
      Adapter    "hs100"        : 2.2.2    , installed 2.2.2
      Adapter    "hue"          : 3.13.1   , installed 3.13.1
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
      Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
      Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "operating-hours": 1.2.0  , installed 1.2.0
      Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
      Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
      Adapter    "sma-em"       : 1.1.0    , installed 1.1.0
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
      Objects and States
      Objects:        32913
      States:         26614
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       491202     42720/io.sonoff.7
      tcp        0      0 0.0.0.0:1891            0.0.0.0:*               LISTEN      1001       492692     42765/io.sonoff.8
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       491725     42679/io.sonoff.5
      tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       492607     42701/io.sonoff.6
      tcp        0      0 0.0.0.0:1894            0.0.0.0:*               LISTEN      1001       491695     42626/io.sonoff.2
      tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       491909     42794/io.sonoff.9
      tcp        0      0 0.0.0.0:1893            0.0.0.0:*               LISTEN      1001       489455     42509/io.sonoff.10
      tcp        0      0 0.0.0.0:1898            0.0.0.0:*               LISTEN      1001       491603     42569/io.sonoff.13
      tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       491642     42587/io.sonoff.14
      tcp        0      0 0.0.0.0:1896            0.0.0.0:*               LISTEN      1001       490312     42532/io.sonoff.11
      tcp        0      0 0.0.0.0:1897            0.0.0.0:*               LISTEN      1001       490970     42550/io.sonoff.12
      tcp        0      0 0.0.0.0:1900            0.0.0.0:*               LISTEN      1001       491671     42606/io.sonoff.15
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       488215     42491/io.sonoff.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       491090     42644/io.sonoff.3
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       491117     42662/io.sonoff.4
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          8674       1243/smbd
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8594       1227/lighttpd
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        10575      1221/pihole-FTL
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6082       955/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          8675       1243/smbd
      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        10581      1221/pihole-FTL
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8301       934/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       486392     42034/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       486386     42034/iobroker.js-c
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8300       934/cupsd
      tcp6       0      0 ::1:4711                :::*                    LISTEN      999        10582      1221/pihole-FTL
      tcp6       0      0 :::445                  :::*                    LISTEN      0          8672       1243/smbd
      tcp6       0      0 :::80                   :::*                    LISTEN      0          8593       1227/lighttpd
      tcp6       0      0 :::53                   :::*                    LISTEN      999        10577      1221/pihole-FTL
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6084       955/sshd: /usr/sbin
      tcp6       0      0 :::139                  :::*                    LISTEN      0          8673       1243/smbd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       493842     42873/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       486988     42052/io.admin.0
      udp        0      0 0.0.0.0:40165           0.0.0.0:*                           1001       488102     42415/io.ping.0
      udp        0      0 0.0.0.0:60746           0.0.0.0:*                           104        6032       735/avahi-daemon: r
      udp        0      0 0.0.0.0:60835           0.0.0.0:*                           1001       489154     42316/io.modbus.1
      udp        0      0 0.0.0.0:56822           0.0.0.0:*                           1001       492759     42843/io.vis-invent
      udp        0      0 0.0.0.0:60919           0.0.0.0:*                           1001       490674     42332/io.modbus.2
      udp        0      0 0.0.0.0:60922           0.0.0.0:*                           1001       493009     43013/io.hs100.0
      udp        0      0 0.0.0.0:56974           0.0.0.0:*                           1001       488182     42472/io.sma-em.0
      udp        0      0 0.0.0.0:40618           0.0.0.0:*                           1001       489991     42348/io.netatmo.0
      udp        0      0 0.0.0.0:52946           0.0.0.0:*                           1001       487409     42201/io.alexa2.0
      udp        0      0 0.0.0.0:40855           0.0.0.0:*                           1001       490152     42441/io.rpi2.0
      udp        0      0 0.0.0.0:44999           0.0.0.0:*                           1001       494888     43120/io.echarts.0
      udp        0      0 0.0.0.0:45038           0.0.0.0:*                           1001       493924     42944/io.energieflu
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        10574      1221/pihole-FTL
      udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          9730       1239/nmbd
      udp        0      0 192.168.1.134:137       0.0.0.0:*                           0          9729       1239/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          9711       1239/nmbd
      udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          9732       1239/nmbd
      udp        0      0 192.168.1.134:138       0.0.0.0:*                           0          9731       1239/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          9712       1239/nmbd
      udp        0      0 0.0.0.0:41243           0.0.0.0:*                           1001       490080     42389/io.operating-
      udp        0      0 0.0.0.0:53605           0.0.0.0:*                           1001       490512     42221/io.backitup.0
      udp        0      0 0.0.0.0:33194           0.0.0.0:*                           1001       488560     42034/iobroker.js-c
      udp        0      0 0.0.0.0:41404           0.0.0.0:*                           1001       492898     42961/io.fb-checkpr
      udp        0      0 0.0.0.0:41412           0.0.0.0:*                           1001       493095     43085/io.pvforecast
      udp        0      0 0.0.0.0:45509           0.0.0.0:*                           1001       494855     43102/io.sourceanal
      udp        0      0 0.0.0.0:41527           0.0.0.0:*                           1001       488764     42145/io.email.0
      udp        0      0 0.0.0.0:33344           0.0.0.0:*                           1001       487717     42129/io.javascript
      udp        0      0 0.0.0.0:54131           0.0.0.0:*                           1001       488939     42241/io.hue.1
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6030       735/avahi-daemon: r
      udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       488183     42472/io.sma-em.0
      udp        0      0 0.0.0.0:58763           0.0.0.0:*                           1001       492809     42893/io.bluelink.0
      udp        0      0 0.0.0.0:51029           0.0.0.0:*                           1001       491980     42824/io.tr-064.1
      udp        0      0 0.0.0.0:42850           0.0.0.0:*                           1001       487911     42286/io.innogy-sma
      udp        0      0 0.0.0.0:42883           0.0.0.0:*                           1001       487386     42190/io.zigbee.0
      udp        0      0 0.0.0.0:47513           0.0.0.0:*                           1001       487946     42301/io.modbus.0
      udp        0      0 0.0.0.0:39328           0.0.0.0:*                           1001       488605     42052/io.admin.0
      udp        0      0 0.0.0.0:60156           0.0.0.0:*                           1001       493066     43060/io.iot.0
      udp6       0      0 :::35986                :::*                                104        6033       735/avahi-daemon: r
      udp6       0      0 :::53                   :::*                                999        10576      1221/pihole-FTL
      udp6       0      0 fe80::67fb:be67:45b:546 :::*                                0          10548      896/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        6031       735/avahi-daemon: r
      2025-01-01 09:08:05.587  - info: sourceanalytix.0 (43102) Successfully activated SourceAnalytix for 6 of 6 states, will do my Job until you stop me!
      2025-01-01 09:08:09.352  - info: fb-checkpresence.0 (42961) createFbDeviceObjects finished successfully
      2025-01-01 09:08:09.353  - info: fb-checkpresence.0 (42961) states successfully subscribed
      2025-01-01 09:08:09.354  - info: fb-checkpresence.0 (42961) loop successfully started2025-01-01 09:08:34.234  - info: admin.0 (42052) ==> Connected system.user.admin from ::ffff:192.168.1.134
      2025-01-01 09:08:53.130  - info: admin.0 (42052) ==> Connected system.user.admin from ::ffff:192.168.1.134
      2025-01-01 09:08:58.890  - info: admin.0 (42052) <== Disconnect system.user.admin from ::ffff:192.168.1.134
      2025-01-01 09:09:00.045  - info: javascript.0 (42129) script.js.Sonstiges.Zieltemperaturen-Pruefen: Achtung im Mariazimmer wurde die Zieltemperatur nicht übernommen
      2025-01-01 09:09:00.045  - info: javascript.0 (42129) script.js.Sonstiges.ZieltemperaCopy text starting here:
      ```bash
      ======================= SUMMARY =======================                                                      v.2024-10-19
       Static hostname: raspberrypi                                                               Icon name: computer
      Operating System: Debian GNU/Linux 12 (bookworm)                                               Kernel: Linux 6.6.62+rpt-rpi-2712
          Architecture: arm64
      Installation:           native                                                       Kernel:                 aarch64
      Userland:               64 bit                                                       Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000                                                         Display-Server:         true
      Pending OS-Updates:     0                                                            Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.1                                                     /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2                                                       /usr/bin/npx            10.8.2
      Recommended versions are nodejs 20.18.1 and npm 10.8.2                               nodeJS installation is correct
      MEMORY:
      Mem:            8.4G        4.3G        878M        129M        3.5G        4.1G
      Swap:           209M          0B        209M
      Total:          8.7G        4.3G        1.1G
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.3.2
      Objects type: jsonl
      States  type: jsonl
      Objects:                32913
      States:                 26614
      Size of iob-Database:
      48M     /opt/iobroker/iobroker-data/objects.jsonl
      22M     /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      winni
      HOME=/home/winni
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               8052 M total memory
               4053 M used memory
                419 M free memory
                226 M buffer memory
               3576 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      5.5G    /var/
      4.3G    /var/cache/apt
      4.3G    /var/cache
      830M    /var/log
      USB-Devices by-id:
      HINT:
      /dev/ttyUSB0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.3.2
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        32913
      States:         26614
      Pending Updates: 0
      ```bash
          Architecture: arm64
      MEMORY:
      Swap:           209M          0B        209M
                              admin                   7.3.2
      Objects type: jsonl
      States  type: jsonl
      Objects:                32913
      States:                 26614
      Das schaut nicht gut aus.
      winni@raspberrypi:~ $ sudo dmesg --level=emerg,alert,crit -T
      [Mi Jan  1 00:10:26 2025] Unable to handle kernel paging request at virtual address ffffc000809b3f04
      [Mi Jan  1 00:10:26 2025] Mem abort info:
      [Mi Jan  1 00:10:26 2025]   ESR = 0x0000000096000047
      [Mi Jan  1 00:10:26 2025]   EC = 0x25: DABT (current EL), IL = 32 bits
      [Mi Jan  1 00:10:26 2025]   SET = 0, FnV = 0
      [Mi Jan  1 00:10:26 2025]   EA = 0, S1PTW = 0
      [Mi Jan  1 00:10:26 2025]   FSC = 0x07: level 3 translation fault
      [Mi Jan  1 00:10:26 2025] Data abort info:
      [Mi Jan  1 00:10:26 2025]   ISV = 0, ISS = 0x00000047, ISS2 = 0x00000000
      [Mi Jan  1 00:10:26 2025]   CM = 0, WnR = 1, TnD = 0, TagAccess = 0
      [Mi Jan  1 00:10:26 2025]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
      [Mi Jan  1 00:10:26 2025] swapper pgtable: 16k pages, 47-bit VAs, pgdp=0000000001398000
      [Mi Jan  1 00:10:26 2025] [ffffc000809b3f04] pgd=100000010019c003, p4d=1000000
      Wenn ich mir
      CPU threads: 4
      und
      und
      Vermute ich ein Fehler auf tieferer Ebene.
      Dem
      HINT:
      solltest du für ein 'rundes' Setup von Zigbee auch nachkommen.
      Und warum hat man 16 Instanzen vom sonoff-Adapter laufen?
      • WinniW Winni
        v7.3.2
        Log-Größe: 10.0 KB
        zigbee.0
        Zeit
        silly
        Nachricht
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @winni mit den 3 Zeilen werden wir nix. Ein komplettes Log des Startup des Zigbee Adapters hat so 10 - 40 Zeilen.
        Ansonsten - ich bin im Discord - 2 User Only
        A.
          aber ich ;-)
          WinniW Offline
          WinniW Offline
          Winni
          @homoran danke 😀
            Wenn ich mir
            CPU threads: 4
            und
            und
            Dem
            HINT:
            WinniW Offline
            WinniW Offline
            Winni
            @thomas-braun ich habe 16 Tasmota Dosen. Ist im Laufe der Jahre einges zusammen gekommen.
            • WinniW Winni
              @winni
              Und warum muss jede Dose eine eigene Instanz haben? Versteh ich nicht...
              Kiste mal ganz einfach sauber durchgestartet?
              • WinniW Offline
                WinniW Offline
                Winni
                Hier nochmal der Versuch den richtigen Log zu senden.
                terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-01-01 11:05:00.603 - info: host.raspberrypi instance system.adapter.zigbee.0 in version "1.10.3" started with pid 56493
                2025-01-01 11:05:02.766 - info: zigbee.0 (56493) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
                2025-01-01 11:05:02.804 - info: zigbee.0 (56493) Starting Zigbee npm ...
                2025-01-01 11:05:02.969 - info: zigbee.0 (56493) Installed Version: iobroker.zigbee@1.10.3
                2025-01-01 11:05:41.859 - info: admin.0 (50672) <== Disconnect system.user.admin from ::ffff:192.168.1.21 admin
                • WinniW Winni
                  den richtigen Log
                  @asgothian sagte in Zigbee ist tod:
                    @winni
                    WinniW Offline
                    WinniW Offline
                    Winni
                    @thomas-braun Naja, ich wusste es nicht besser. Ich wusste nicht dass man mehrere Dosen auf eine Inzanz legen kann. Werde den Raspi gleich mal neu starten.
                    • WinniW Offline
                      WinniW Offline
                      Winni
                      Beim Neustart des Raspberry stehen diese Meldungen im Log:
                      zigbee.0
                      2025-01-01 11:23:48.228	error	Error herdsman start
                      zigbee.0
                      2025-01-01 11:23:48.227	error	Failed to start Zigbee
                      zigbee.0
                      2025-01-01 11:23:48.226	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                      zigbee.0
                      2025-01-01 11:23:48.050	info	Installed Version: iobroker.zigbee@1.10.3
                      zigbee.0
                      2025-01-01 11:23:48.027	info	Starting Zigbee npm ...
                      zigbee.0
                      2025-01-01 11:23:48.026	info	Try to reconnect. 1 attempts left
                      zigbee.0
                      2025-01-01 11:23:38.024	error	Error herdsman start
                      zigbee.0
                      2025-01-01 11:23:38.023	error	Failed to start Zigbee
                      zigbee.0
                      2025-01-01 11:23:38.019	error	Starting zigbee-herdsman problem : "Attempt to access memory outside buffer bounds"
                      zigbee.0
                      2025-01-01 11:23:37.239	info	Installed Version: iobroker.zigbee@1.10.3
                      zigbee.0
                      2025-01-01 11:23:36.242	info	Starting Zigbee npm ...
                      zigbee.0
                      2025-01-01 11:23:36.181	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
                      Hoffe dass das aussagekräftiger ist.
                      • WinniW Winni
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @winni Ist es. Bitte schau im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 nach, da liegen verschiedene tgz Dateien. Du musst folgendes tun:
                        • Zigbee Adapter anhalten (wichtig, auch wenn er nicht vollständig läuft)
                        • besagte Datei entpacken, damit shepherd.db und nvbackup.json zurück setzen
                        • Zigbee-Adapter starten
                        A,
                        • AsgothianA Asgothian
                          A,
                          WinniW Offline
                          WinniW Offline
                          Winni
                          @asgothian das ist der Inhalt des Verzeichnis, welche Dateien meinst du?
                           /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-10_29_50.tar.gz
                          /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-10_33_16.tar.gz
                          /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-10_37_18.tar.gz
                          /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_02_51.tar.gz
                          /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_04_27.tar.gz
                          /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_05_02.tar.gz
                          /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_23_36.tar.gz
                          /opt/iobroker/iobroker-data/zigbee_0/backup_2025_01_01-11_47_19.tar.gz
                          /opt/iobroker/iobroker-data/zigbee_0/dev_names.json
                          /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-09-04T06-44-44.442Z
                          /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-09-14T16-55-53.337Z
                          /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-09-28T14-21-20.762Z
                          /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-09-28T15-39-41.769Z
                          /opt/iobroker/iobroker-data/zigbee_0/shepherd.db.tmp.2024-11-08T05-14-11.384Z
                          • WinniW Winni
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @winni ich fürchte die Datei ist da nicht mehr - du hast den Adapter mehr als 10 mal neu gestartet. Bitte via backitup ausschliesslich das letzte Zigbee Backup zurück spielen. Wirklich nur das, der Rest darf bleiben
                            A.
                              A.
                              WinniW Offline
                              WinniW Offline
                              Winni
                              @asgothian jetzt schaut es so aus:
                              Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                              • WinniW Winni
                                @winni
                                Manchmal sieht man anhand der Dateigröße etwas. Schau dir die Daten also per
                                ls -lh /opt/iobroker/iobroker-data/zigbee_0/
                                an.
                                • WinniW Winni
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @winni wie es aussieht ist nicht wichtig - solange das zurück gespielte backup des Zigbee Adapters von gestern ist, kannst du den jetzt starten und er sollte laufen
                                  A.
                                    @winni
                                    an.
                                    WinniW Offline
                                    WinniW Offline
                                    Winni
                                    @thomas-braun sagte in Zigbee ist tod:
                                    -rw-rw-r--+ 1 iobroker iobroker 4,6K  1. Jan 12:17 backup_2025_01_01-12_17_17.tar.gz
                                    -rw-r-xr--+ 1 iobroker iobroker  992  1. Jan 12:11 dev_names.json
                                    -rw-r--r--+ 1 iobroker iobroker 6,5K  1. Jan 12:11 nvbackup.json
                                    -rw-r--r--+ 1 iobroker iobroker  41K  1. Jan 12:11 shepherd.db
                                    -rw-r-xr--+ 1 iobroker iobroker  33K  1. Jan 12:11 shepherd.db.tmp.2024-09-04T06-44-44.442Z
                                    -rw-r-xr--+ 1 iobroker iobroker  33K  1. Jan 12:11 shepherd.db.tmp.2024-09-14T16-55-53.337Z
                                    -rw-r-xr--+ 1 iobroker iobroker    0  1. Jan 12:11 shepherd.db.tmp.2024-09-28T14-21-20.762Z
                                    -rw-r-xr--+ 1 iobroker iobroker    0  1. Jan 12:11 shepherd.db.tmp.2024-09-28T15-39-41.769Z
                                      A.
                                      WinniW Offline
                                      WinniW Offline
                                      Winni
                                      @asgothian Leider nicht, alles so wie vorher
                                      HomoranH AsgothianA 2 Antworten Letzte Antwort
                                      • WinniW Winni
                                        Leider nicht
                                        was?
                                        nicht von gestern?
                                        • WinniW Winni
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          Du hattest vorher eine 1.10.9. Ich habe zu dem Zeitpunkt jedem der auf die Github Version updated angewiesen eine Kopie der nvbackup.json anzulegen. Hast du die noch ? Wenn ja - einspielen. Wenn Nein: 1.10.13 aus dem Stable einspielen, Log vom Startup zeigen
                                          A.
