  4. nach dem Update, geht nichts mehr.....
44 Beiträge 7 Kommentatoren 5.4k Aufrufe 5 Beobachtet
  • Z Zimbl
    So ich habe wieder mal ein aktuelles Ergebnis :
    ```bash
    Script v.2024-12-09 Raspbian+zigbee diag+masking
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 2 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     18:52:41 up 50 min,  1 user,  load average: 1.45, 1.87, 1.47
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2024-12-10 18:52:41 CET
               Universal time: Tue 2024-12-10 17:52:41 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            921M        517M         75M        0.0K        328M        344M
    Swap:            99M         92M        7.0M
    Total:          1.0G        610M         82M
    Active iob-Instances:   10
              921 M total memory
              517 M used memory
              300 M active memory
              466 M inactive memory
               74 M free memory
               22 M buffer memory
              307 M swap cache
               99 M total swap
               92 M used swap
                7 M free swap
    top - 18:52:43 up 50 min,  1 user,  load average: 1.41, 1.86, 1.47
    Tasks: 133 total,   1 running, 132 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.6 us,  3.9 sy,  0.0 ni, 93.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    922.0 total,     74.4 free,    518.1 used,    329.4 buff/cache
    MiB Swap:    100.0 total,      7.3 free,     92.7 used.    343.8 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * rc-local.service loaded failed failed /etc/rc.local Compatibility
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    1 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    /dev/root      ext4       59G  7.0G   49G  13% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
    tmpfs          tmpfs     185M  944K  184M   1% /run
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    [Tue Dec 10 18:02:05 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=a13bd72e-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Dec 10 18:02:09 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Dec 10 18:02:09 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Dec 10 18:02:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc
    /var:
    2.2G    /var/
    1.9G    /var/log/journal/b4db8c2bf1074a1ba2ba6c07d9465d9d
    1.9G    /var/log
    123M    /var/cache
    Archived and active journals take up 1.8G in the file system.
    /opt/iobroker/backups:
    97M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    818M    /opt/iobroker/iobroker-data/
    722M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u5 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.3, hostname: raspberrypi   , alive, uptime: 495)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "deconz"       : 1.4.1    , installed 1.4.1
    Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.43
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        974
    States:         665
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       33968      3854/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       33963      3854/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11824      446/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34103      3872/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11826      446/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12579      344/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       34921      3919/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       34922      3919/io.tuya.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33344      3950/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          448        571/dhcpcd
    udp        0      0 0.0.0.0:46688           0.0.0.0:*                           108        12581      344/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12580      344/avahi-daemon: r
    udp6       0      0 :::58708                :::*                                108        12582      344/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13728      571/dhcpcd
    2024-12-10 18:51:53.743  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=true)
    2024-12-10 18:51:53.811  - info: rpi2.0 (5014) Got terminate signal TERMINATE_YOURSELF
    2024-12-10 18:51:53.828  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 send kill signal
    2024-12-10 18:51:53.823  - info: rpi2.0 (5014) terminating
    2024-12-10 18:51:53.830  - info: rpi2.0 (5014) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-10 18:51:54.454  - info: rpi2.0 (5014) terminating
    2024-12-10 18:51:54.529  - error: rpi2.0 (5014) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-12-10 18:51:54.531  - error: rpi2.0 (5014) unhandled promise rejection: DB closed
    2024-12-10 18:51:54.540  - error: rpi2.0 (5014) Error: DB closed
        at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
        at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
        at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2333:37)
        at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2374:29)
        at process.processImmediate (node:internal/timers:485:21)
    2024-12-10 18:51:54.543  - error: rpi2.0 (5014) DB closed
    2024-12-10 18:51:54.668  - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-12-10 18:51:59.938  - info: host.raspberrypi instance system.adapter.rpi2.0 in version "2.2.1" started with pid 5085
    2024-12-10 18:52:07.710  - info: rpi2.0 (5085) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
    2024-12-10 18:53:10.144  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
    2024-12-10 18:53:11.238  - info: zigbee.0 (3932) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"ceccc8e6cbc9eb119edf8b4f1d69213e","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0","vendorId":"10c4","productId":"ea60"}]
    2024-12-10 18:53:16.482  - info: admin.0 (3872) <== Disconnect system.user.admin from ::ffff:192.168.178.82
    2024-12-10 18:53:24.487  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
    2024-12-10 18:53:46.635  - info: admin.0 (3872) <== Disconnect system.user.admin from ::ffff:192.168.178.82 javascript
    2024-12-10 18:53:57.051  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
    2024-12-10 18:54:58.672  - warn: backitup.0 (3886) [iobroker/clean] No older backup files are deleted, because this backup was started manually
    iob diag has finished.
    Press any key for a summary
    @zimbl
    Grundsätzlich sollte das Ding jetzt wieder schnurren.
    Z 1 Antwort Letzte Antwort
      @zimbl
      Z Offline
      Z Offline
      Zimbl
      schrieb am zuletzt editiert von Zimbl
      Hallo Thomas,
      ich habe mir nun einen Pi5 geholt und mit dem PI Imager auch das
      Image drauf gemacht, soweit auch alles wie immer Konfiguriert.
      Was nur komisch ist, meine ETH0 Schnittstelle funktioniert nicht,
      ich stecke das Kabel rein, aber nichts.
      Keine Verbindung.
      ich meine früher war die immer Standard aktiv.
      ist das nun nicht mehr ?
      • Z Zimbl
        Hallo Thomas,
        Keine Verbindung.
        @zimbl
        Ja, eine Ethernet-Schnittstelle ist i.d.R. aktiv.
        schau dir
        ip a
        und
        ifconfig
        an.
        • Z Zimbl
          Hallo Thomas,
          Keine Verbindung.
          @zimbl sagte in nach dem Update, geht nichts mehr.....:
          auch keine Aktionen an den LED der Netzwerkbuchse?
            Z Offline
            Z Offline
            Zimbl
            Ne überhaupt nichts.
            Das komische ist irgendwie auch, das in der dhcpcd.conf auch nichts
            drin steht.
            Gut aber wenn die nicht aktiv ist, würden ja die LEDs auch
            nicht funktionieren..
            Mit dem PI Imager habe ich 64-Bit Light installiert...
            • Z Zimbl
              drin steht.
              @zimbl kann ja noch ein Hardwaredefekt sein.
              Allerdings hatte ich so einen Effekt mal bei Armbian.
              Mit einer Version funktionierte das Netzwerk nicht.
              Aber ich glaube nicht dass das hier auch so ist.
              drin steht.
              ich kann dir gar nicht sagen, welche Konfiguration im aktuellen OS verwendet wird.
              Gibts da nicht auch was in raspi-config?
                drin steht.
                Z Offline
                Z Offline
                Zimbl
                ja ich hatte das bisher auch noch nicht und wenn ich die Befehle ausführe die Thomas geschrieben hat, da kann man auch nicht sehen, das die Schnittstelle ein Problem hat.
                1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                    inet 127.0.0.1/8 scope host lo
                       valid_lft forever preferred_lft forever
                    inet6 ::1/128 scope host noprefixroute
                2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
                    link/ether 2c:cf:67:97:18:01 brd ff:ff:ff:ff:ff:ff
                3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                    link/ether 2c:cf:67:97:18:02 brd ff:ff:ff:ff:ff:ff
                    inet 192.168.1.114/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
                       valid_lft 863543sec preferred_lft 863543sec
                    inet6 2001:9e:d5e8:9100:134b:4abc:41f3:b3b0/64 scope global dynamic noprefixroute
                       valid_lft 6747sec preferred_lft 3147sec
                    inet6 fe80::4bfa:4f8a:169e:c02e/64 scope link noprefixroute
                Für mich sieht das so aus, das die Schnittstelle einen Defekt hat?
                oder?
                mcm1957M HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                • Z Zimbl
                  oder?
                  mcm1957M Offline
                  mcm1957M Offline
                  mcm1957
                  @zimbl
                  Ich kann nur sagen dass ich vor kurzem nen Pi mit dem Imager aufgesetzt habe und die LAN Schnittstelle war sofort und ohne irgendwelche Aktionen einsatzbereit und funktionierte. Hat auch ganz normal im Netz den DHCP Server gefunden und sich eine Addresse geholt.
                  Ob man ev. im Imager die Netzwerkschnittstelle aktiv disablen kann oder ob sie disabled wird wenn man WLAN aktiviert hab ich mir nicht angesehen. Der Default ist / war jedenfalls LAN Buchse aktiiv.
                  Und zur Sicherheit check auch noch mal der Kabel und verbind den Raspi ggF mit einem Kabel direkt zu Router um allfällge Schäden an einer Hausverkabelung auszuschließen.
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • Z Zimbl
                    oder?
                    oder das Kabel/der Switch
                    • Z Zimbl
                      oder?
                      state DOWN
                      Was sagt
                      systemctl status NetworkManager.service
                      und
                      sowie
                      nmcli general
                        state DOWN
                        Was sagt
                        und
                        sowie
                        nmcli general
                        Z Offline
                        Z Offline
                        Zimbl
                        ich habe doch wirklich mal den Pi an den Switch direkt angeschlossen...
                        und da ging dann auch die ETH Schnittstelle...
                        Kann es nicht so richtig nachvollziehen, weil alle anderen Geräte funktionieren
                        an dieser Dose.
                        Naja es scheint gelöst zu sein.
                        Ich möchte mich auf diesem Weg bei allen bedanken die mich hier unterstützt haben.
                        VIELEN DANK.
                        • Z Zimbl
                          an dieser Dose.
                          VIELEN DANK.
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          @zimbl
                          Check mal die Dose durch. Insbesondere ob die funktionierenden Geräte 1GB Verbindung aufbauen. Prinzipiell ist aber ein (auch einfacher) Kabeltester da anzuraten.
                          Ev. kann die auf Grund eines Fehlers nur 10MB / 100MB und der Raspi 5 nur höhere Geschwindigkeiten. Oder er geht auf Störung weil die 1GB Verbindung "halb" funktioniert.
                          100MB braucht nur 4 Adern und 1GB alle 8 - soweit ich es richtig im Kopf habe. Hab im Keller auch ne Dose wo über ein Kabel per Splitter 2 getrennte 100MB Verbindungen laufen - für nen Drucker reicht das allemal :-)
                          • mcm1957M mcm1957
                            @zimbl
                            @mcm1957
                            @Zimbl
                            Möglicherweise hat auch das Umstecken zu einer neuen Anfrage beim DHCP geführt.
                            Wahrscheinlicher ist für mich aber auch ein Defekt in "der Leitung"
                              @mcm1957
                              @Zimbl
                              mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              Auch ohne dhcp sollte m.e. die LAN Leds Aktivitäten zeigen. Wenn die ganz finster sind ist ein Defekt auf der untersten Ebene wahrscheinlich. Kann aber natürlich auch am Kontakt der Dose ("Federchen verbogen") liegen.
                              Und theoretisch könnte es noch an gerader oder gekreuzter Verbindung liegen wenn nicht mindestesn eines der beiden Geräte eine automatische Anpassung vornimmt. Wobei das m.W. nach alle modernen Geräte tun - würd mich also wundern wenn der Pi da empfindlich ist. Weiß nicht mehr wann ich zuletzt auf gekreuztes oder geraded Patchkabel geachtet habe.
                              • mcm1957M mcm1957
                                Z Offline
                                Z Offline
                                Zimbl
                                Nachdem ich nun auf einen anderen Raspberry Pi umgestiegen bin und den Pi 2 höchstens noch für gelegentliche Aufgaben wie das Flashen von Tasmota oder Ähnliches nutzen werde, möchte ich nun mit dem Pi 5 ein neues Problem angehen:
                                Ich arbeite mit verschiedenen Skripten, die GPIO-Pins ansprechen. Diese konfiguriere ich im Vorfeld mit der Raspberry Pi App (Android) als Ausgänge und passe sie anschließend über IO-Broker an. Das Problem ist jedoch, dass diese Einstellungen nach jedem Neustart des Pis wieder auf die Standardwerte zurückgesetzt werden.
                                Muss ich zusätzliche Schritte unternehmen, um diese Konfigurationen dauerhaft (persistent) zu speichern?
