  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.9k Aufrufe 40 Beobachtet
  • NashraN Offline
    NashraN Offline
    Nashra
    Most Active Forum Testing
    schrieb am zuletzt editiert von Nashra
    #677
    @Thomas-Braun
    Proxmox lxc
    ```bash
    Script v.2024-12-08 Raspbian+zigbee diag+masking
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-4-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     09:19:11 up 16 days, 22:59,  1 user,  load average: 1.12, 1.17, 1.11
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2024-12-09 09:19:11 CET
               Universal time: Mon 2024-12-09 08:19:11 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    jack
    HOME=/home/jack
    GROUPS=jack sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             12G        4.9G        6.8G        131K        1.1G        8.0G
    Swap:             0B          0B          0B
    Total:           12G        4.9G        6.8G
    Active iob-Instances:   47
            12288 M total memory
             4686 M used memory
             3030 M active memory
             2479 M inactive memory
             6506 M free memory
                0 M buffer memory
             1094 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 09:19:11 up 16 days, 22:59,  1 user,  load average: 1.12, 1.17, 1.11
    Tasks:  75 total,   1 running,  74 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us, 50.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  12288.0 total,   6505.2 free,   4688.0 used,   1094.9 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7600.0 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    3 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       20G   15G  3.7G  81% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G  120K  3.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    2.6G    /var/
    2.1G    /var/log
    2.0G    /var/log/journal/5cd6ef18c5fb4a33b292b16e63f26ce7
    351M    /var/cache
    Archived and active journals take up 95.6M in the file system.
    /opt/iobroker/backups:
    1.3G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.6G    /opt/iobroker/iobroker-data/
    1.7G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    135M    /opt/iobroker/iobroker-data/states.jsonl
    63M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 954147)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     6
    +-- iobroker.energiefluss-erweitert@0.5.1-alpha.11 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#ac743deb1d81e364ec7f0a9edd2f9da21329f5b6)
    +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
    +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
    Adapter State
      system.adapter.accuweather.0            : accuweather           : ioBroker                                 - disabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
      system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.labcom.0                 : labcom                : ioBroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 - disabled
      system.adapter.meteoalarm.1             : meteoalarm            : ioBroker                                 - disabled
      system.adapter.meteoalarm.2             : meteoalarm            : ioBroker                                 - disabled
      system.adapter.meteoalarm.3             : meteoalarm            : ioBroker                                 - disabled
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.nut.2                    : nut                   : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
      system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 - disabled
      system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
    + system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
      system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
    + system.adapter.synology.2               : synology              : ioBroker                                 -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
      system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
    Adapter    "deyeidc"      : 0.1.1    , installed 0.1.1
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.11
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "lgtv"         : 2.2.0    , installed 2.3.0
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "pegelalarm"   : 1.3.5    , installed 1.3.5
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
    Adapter    "rssfeed"      : 3.1.0    , installed 3.1.0
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "weather-warnings": 0.6.11, installed 0.6.11
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        55071
    States:         51750
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          28017      1140/master
    tcp        0      0 192.168.1.14:8082       0.0.0.0:*               LISTEN      1001       60490678   4018371/io.web.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17497      1/init
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       60462657   4015570/iobroker.js
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       60460940   4015570/iobroker.js
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       60475909   4017307/io.shelly.1
    tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       171017909  3079198/nc
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          28018      1140/master
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       60487396   4018286/io.simple-a
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       60493088   4018385/io.ws.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60462774   4015859/io.admin.0
    tcp6       0      0 :::8093                 :::*                    LISTEN      1001       60487711   4017938/io.rest-api
    tcp6       0      0 :::111                  :::*                    LISTEN      0          17499      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16838      1/init
    udp        0      0 0.0.0.0:50381           0.0.0.0:*                           1001       60470790   4016716/io.snmp.0
    udp        0      0 0.0.0.0:58778           0.0.0.0:*                           1001       60491897   4018341/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       60494417   4018341/io.upnp.0
    udp        0      0 0.0.0.0:46235           0.0.0.0:*                           1001       60470190   4016716/io.snmp.0
    udp        0      0 192.168.1.14:5353       0.0.0.0:*                           1001       60474435   4016795/io.tr-064.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       60468082   4016698/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       60474506   4016825/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       60474507   4016825/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16795      90/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17498      1/init
    udp6       0      0 :::111                  :::*                                0          17500      1/init
    2024-12-09 09:13:00.018  - info: host.ioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3075148
    2024-12-09 09:13:01.656  - info: javascript.0 (4016006) script.js.Kalender.ICal-farben-Kalender: <table style='font-size:0.9em;'><tbody><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>15.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Dritter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>22.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Vierter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heiligabend (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Jack</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>25.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Erster Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>26.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Zweiter Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>31.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Silvester (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>01.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Neujahrstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>01.01.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Hühner</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>05.01.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Michael</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>06.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heilige Drei Könige (regionaler Feiertag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#0080c0'>01.02.</td><td style='font-size:1.1em; padding-left:5px;color:#0080c0'>Jubiläum 2002</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>14.02.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Valentinstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>14.02.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Anouk</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>17.02.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Manny & Sunny</td></tr></body></table>
    2024-12-09 09:13:07.181  - info: host.ioBroker instance system.adapter.ical.0 having pid 3075148 terminated with code 0 (NO_ERROR)
    2024-12-09 09:13:22.136  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2024-12-09 09:13:37.016  - info: host.ioBroker instance system.adapter.daswetter.1 in version "3.1.16" started with pid 3075580
    2024-12-09 09:13:38.099  - info: daswetter.1 (3075580) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.3
    2024-12-09 09:13:43.335  - info: daswetter.1 (3075580) still wrong data structure from server received! repaired...
    2024-12-09 09:13:45.176  - info: daswetter.1 (3075580) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2024-12-09 09:13:45.680  - info: daswetter.1 (3075580) cleaned everything up...
    2024-12-09 09:13:45.688  - info: host.ioBroker instance system.adapter.daswetter.1 having pid 3075580 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-12-09 09:13:45.689  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md-gitti: Material Design Widgets: Wetter Skript triggered by 'system.adapter.daswetter.1.alive'
    2024-12-09 09:14:23.090  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2024-12-09 09:14:53.769  - info: javascript.0 (4016006) script.js.Ereignisse.Flurlicht: #### Flurlicht eingeschaltet
    2024-12-09 09:15:00.035  - info: javascript.0 (4016006) script.js.Allerlei.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2024-12-09 09:15:00.047  - info: javascript.0 (4016006) script.js.Allerlei.Shelly-Verbrauch-MQTT: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
    2024-12-09 09:15:30.108  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2024-12-09 09:16:00.199  - info: javascript.0 (4016006) script.js.Netzwerk.IP-Adresse2: IP-Adresse (ausgelesen von http://ipecho.net/plain): 94.31.88.205
    2024-12-09 09:16:34.100  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2024-12-09 09:16:58.013  - info: history.0 (4015915) Delete old history "/opt/iobroker/iobroker-data/history/20241130/history.deyeidc.0.3918369324.Apo_t1.json"
    2024-12-09 09:17:38.264  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2024-12-09 09:18:36.343  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2024-12-09 09:18:53.020  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3079218
    2024-12-09 09:18:54.021  - info: dwd.0 (3079218) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
    2024-12-09 09:18:54.384  - info: dwd.0 (3079218) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-09 09:18:54.896  - info: host.ioBroker instance system.adapter.dwd.0 having pid 3079218 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:             12G        4.9G        6.9G        139K        1.2G        8.0G
    Swap:             0B          0B          0B
    Total:           12G        4.9G        6.9G
    ioBroker Core:          js-controller           7.0.3
                            admin                   7.1.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                55071
    States:                 51750
    Size of iob-Database:
    144M    /opt/iobroker/iobroker-data/states.jsonl
    Gruß Ralf
    • NashraN Nashra
      @Thomas-Braun
      Proxmox lxc
      ```bash
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      jack
      HOME=/home/jack
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:             0B          0B          0B
               4686 M used memory
               6506 M free memory
                  0 M buffer memory
               1094 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      2.6G    /var/
      2.1G    /var/log
      351M    /var/cache
      USB-Devices by-id:
      HINT:
      /dev/ttyUSB0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.1.5
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        55071
      States:         51750
      Pending Updates: 0
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1000
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
      Swap:             0B          0B          0B
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                55071
      States:                 51750
      #678
      @nashra sagte in iob diag - Skript:
      Danke.
      Und
      iob diag --unmask
      deckt die Zigbee-Werte auf?
        Danke.
        Und
        iob diag --unmask
        NashraN Offline
        NashraN Offline
        Nashra
        #679
        @thomas-braun sagte in iob diag - Skript:
        Danke.
        Und
        iob diag --unmask
        Ja, werden angezeigt
        Gruß Ralf
          An die Tester:
          Es darf wieder getestet werden!
          Bitte mal die TEST-Version (siehe erster Eintrag) unter die Äuglein nehmen.
          (Nicht von der Benennung als raspbian irritieren lassen, das sollte auf allen Systemen laufen).
          • Neue Sektion *** ZigBee Settings ***
            Wenn eine Instanz des zigbee-Adapters gefunden wird erscheint diese neue Sektion:
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          • Neue Option --unmask beim Aufruf des Skripts lüftet dann die Maske und die entsprechenden Werte erscheinen im Klartext und können dann in den Einstellungen des zigbee-Adapters eingetragen werden.
          Bitte mal schauen ob das alles wie gedacht funktioniert, insbesondere Installationen mit mehr als einer Instanz oder per tcp angebunden wären interressant zu sehen.
          Danke schön!
          L Online
          L Online
          Lucky_ESA
          schrieb am zuletzt editiert von Lucky_ESA
          #680
          Command: pi@iobroker:~ $ ./iob_diag.sh -de | tee iob_diag.log
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
                    Kernel: Linux 6.6.62+rpt-rpi-2712
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
           10:21:35 up 18 min,  1 user,  load average: 0.42, 0.47, 0.56
          CPU threads: 4
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
                         Local time: Mon 2024-12-09 10:21:36 CET
                     Universal time: Mon 2024-12-09 09:21:36 UTC
                           RTC time: Mon 2024-12-09 09:21:36
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.4G        4.2G        2.9G        5.7M        1.5G        4.2G
          Swap:           209M          0B        209M
          Total:          8.7G        4.2G        3.1G
          Active iob-Instances:   44
                   8052 M total memory
                   4025 M used memory
                   3791 M active memory
                   1094 M inactive memory
                   2721 M free memory
                    143 M buffer memory
                   1263 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 10:21:36 up 18 min,  1 user,  load average: 0.42, 0.47, 0.56
          Tasks: 198 total,   1 running, 197 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8052.2 total,   2720.8 free,   4026.7 used,   1407.1 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4025.6 avail Mem
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs          tmpfs     806M  5.4M  800M   1% /run
          /dev/mmcblk0p2 ext4      117G   21G   91G  19% /
          tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
          tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
          tmpfs          tmpfs     806M     0  806M   0% /run/user/0
          [Mon Dec  9 10:03:12 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=D8:3A:DD:99:6E:9A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=675ae9ae-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Mon Dec  9 10:04:31 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
          [Mon Dec  9 10:04:33 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.0G    /var/
          2.2G    /var/log/journal/87fcd42a64fb499e969e09ffa538a8fe
          2.2G    /var/log
          409M    /var/cache
          Archived and active journals take up 2.1G in the file system.
          4.0K    /opt/iobroker/backups/
          2.0G    /opt/iobroker/iobroker-data/
          1.5G    /opt/iobroker/iobroker-data/files
          207M    /opt/iobroker/iobroker-data/files/0_userdata.0/ram/cpu
          73M     /opt/iobroker/iobroker-data/objects.jsonl
          41M     /opt/iobroker/iobroker-data/states.jsonl
          19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
          19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  500 http://deb.debian.org/debian bookworm/main arm64 Packages
                  500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1005)
          js-controller:  7.0.6
          admin:          7.4.4
          javascript:     8.8.3
          nodejs modules from github:     7
          +-- iobroker.e2-openwebif@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.e2-openwebif.git#aedac36b2975e02bdcdf0133cca24cd54483d339)
          +-- iobroker.fritzboxdect@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.fritzboxdect.git#6c0d80663cce795eff92460421f42a8d0b5d0fef)
          +-- iobroker.hiobs@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.hiobs.git#07971db72cce7a5a01169c120e32de199d313f09)
          +-- iobroker.netgear@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.netgear.git#fbe57dc2de2516d66e4d76d61df2021553d85cfe)
          +-- iobroker.philips-android-tv@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.philips-android-tv.git#1e9c610c86a9790d13efe3c212a2ed61cab57238)
          Adapter State
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.e2-openwebif.0           : e2-openwebif          : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
          + system.adapter.fritzboxdect.0           : fritzboxdect          : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
            system.adapter.hiob.0                   : hiob                  : iobroker                                 - disabled, port: 8097
          + system.adapter.hiobs.0                  : hiobs                 : iobroker                                 -  enabled, port: 8095
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
          + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
            system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
          + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.netgear.0                : netgear               : iobroker                                 -  enabled
          + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 90, 8088, 8999, 554
          + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
          + system.adapter.philips-android-tv.0     : philips-android-tv    : iobroker                                 -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          + system.adapter.schedule-switcher.0      : schedule-switcher     : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
            system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
            system.adapter.worx.0                   : worx                  : iobroker                                 - disabled
          + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
          + instance is alive
          Active repo(s): beta
          Used repository: beta
          Adapter    "admin"        : 7.4.4    , installed 7.4.4
          Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "daswetter"    : 3.2.1    , installed 3.2.1
          Adapter    "email"        : 1.3.1    , installed 1.4.0
          Adapter    "followthesun" : 0.5.1    , installed 0.5.1
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "hiob"         : 0.1.6    , installed 0.1.6
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "imap"         : 0.3.0    , installed 0.3.0
          Adapter    "iot"          : 3.4.4    , installed 3.4.4
          Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "lg-thinq"     : 1.0.7    , installed 1.0.7
          Adapter    "lgtv"         : 2.3.1    , installed 2.3.1
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "onvif"        : 1.1.4    , installed 1.1.4
          Adapter    "parcel"       : 0.2.8    , installed 0.2.8
          Adapter    "rpi2"         : 2.2.2    , installed 2.2.2
          Adapter    "schedule-switcher": 0.0.8, installed 0.0.8
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "trashschedule": 3.4.1    , installed 3.4.1
          Adapter    "vis-2"        : 2.11.1   , installed 2.11.1
          Adapter    "vis-icontwo"  : 1.10.1   , installed 1.10.1
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
          Adapter    "web"          : 6.3.1    , installed 6.3.1
          Adapter    "worx"         : 3.1.1    , installed 3.1.1
          Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
          Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
          Objects and States
          Objects:        31186
          States:         26419
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8862       1412/io.mqtt.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4073       804/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7559       1/init
          tcp        0      0 0.0.0.0:57413           0.0.0.0:*               LISTEN      103        7586       1194/rpc.statd
          tcp        0      0 192.168.2.66:9292       0.0.0.0:*               LISTEN      1001       8740       1313/io.hm-rpc.2
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6351       787/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6356       787/iobroker.js-con
          tcp        0      0 192.168.2.66:2010       0.0.0.0:*               LISTEN      1001       7747       1289/io.hm-rpc.0
          tcp        0      0 192.168.2.66:8701       0.0.0.0:*               LISTEN      1001       8743       1312/io.hm-rpc.1
          tcp6       0      0 :::49453                :::*                    LISTEN      103        7592       1194/rpc.statd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          4075       804/sshd: /usr/sbin
          tcp6       0      0 :::111                  :::*                    LISTEN      0          6711       1/init
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10374      1589/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7300       898/io.admin.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10155      2288/io.simple-api.
          tcp6       0      0 :::8095                 :::*                    LISTEN      1001       11919      2539/io.hiobs.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6709       1/init
          udp        0      0 0.0.0.0:53647           0.0.0.0:*                           103        7583       1194/rpc.statd
          udp        0      0 127.0.0.1:946           0.0.0.0:*                           0          7578       1194/rpc.statd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       13828      2604/io.philips-and
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4035       685/avahi-daemon: r
          udp        0      0 192.168.2.66:50593      0.0.0.0:*                           1001       8933       1556/io.yamaha.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       8934       1556/io.yamaha.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       9477       1470/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       9478       1470/io.tuya.0
          udp        0      0 0.0.0.0:35984           0.0.0.0:*                           104        4037       685/avahi-daemon: r
          udp6       0      0 :::111                  :::*                                0          6713       1/init
          udp6       0      0 :::33111                :::*                                104        4038       685/avahi-daemon: r
          udp6       0      0 fe80::eb3e:7926:d35:546 :::*                                0          7202       767/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        4036       685/avahi-daemon: r
          udp6       0      0 :::35689                :::*                                103        7589       1194/rpc.statd
          2024-12-09 10:09:54.486  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz vis-inventwo.0 alive läuft wieder
          2024-12-09 10:09:54.910  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz wallpanel.0 alive läuft wieder
          2024-12-09 10:09:55.691  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz trashschedule.0 alive läuft wieder
          2024-12-09 10:09:57.759  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz text2command.0 alive läuft wieder
          2024-12-09 10:10:01.056  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz fritzboxdect.0 alive läuft wieder
          2024-12-09 10:10:04.984  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz hiobs.0 alive läuft wieder
          2024-12-09 10:10:10.318  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz parcel.0 alive läuft wieder
          2024-12-09 10:10:13.413  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz onvif.0 alive läuft wieder
          2024-12-09 10:10:18.722  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz philips-android-tv.0 alive läuft wieder
          2024-12-09 10:10:23.595  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz netgear.0 alive läuft wieder
          2024-12-09 10:10:27.121  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz schedule-switcher.0 alive läuft wieder
          2024-12-09 10:12:33.089  - info: admin.0 (898) ==> Connected system.user.admin from ::ffff:192.168.2.164
          2024-12-09 10:12:43.512  - info: admin.0 (898) <== Disconnect system.user.admin from ::ffff:192.168.2.164
          2024-12-09 10:12:50.519  - info: admin.0 (898) ==> Connected system.user.admin from ::ffff:192.168.2.164
          2024-12-09 10:15:42.021  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.1" started with pid 4970
          2024-12-09 10:15:43.390  - info: daswetter.0 (4970) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
          2024-12-09 10:15:52.637  - info: daswetter.0 (4970) still wrong data structure from server received! repaired...
          2024-12-09 10:15:54.956  - info: daswetter.0 (4970) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2024-12-09 10:15:55.467  - info: daswetter.0 (4970) cleaned everything up...
          2024-12-09 10:15:55.475  - info: host.iobroker instance system.adapter.daswetter.0 having pid 4970 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-12-09 10:17:08.952  - info: javascript.0 (942) script.js.Scripts.Thinq.Kühlschrank: Kühlschrank
          2024-12-09 10:17:08.964  - info: javascript.0 (942) script.js.Scripts.Thinq.Kühlschrank: Kühlschrank
          2024-12-09 10:17:47.309  - info: fritzboxdect.0 (2510) Check successfully!
                 Icon name: computer
              Architecture: arm64
          Kernel:                 aarch64
          Userland:               64 bit
          User-ID:                1000
          Boot Target:            multi-user.target
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Mem:            8.4G        4.1G        2.9G        5.7M        1.5G        4.3G
          Swap:           209M          0B        209M
          Total:          8.7G        4.1G        3.1G
          ioBroker Core:          js-controller           7.0.6
                                  admin                   7.4.4
          Objects type: jsonl
          States  type: jsonl
          Objects:                31186
          States:                 26288
          42M     /opt/iobroker/iobroker-data/states.jsonl
          Command: pi@iobroker:~ $ ./iob_diag.sh -de --unmask | tee iob_diag.log
          Zeigt alles an
          Edit: Zigbee Log mit SN entfernt
          Gruß//Lucky
            WIP: Übersetzung auf Deutsch in Arbeit. Wird aber nur teilweise möglich sein.
            Skript einfach mal mit der Option '--de' starten. Also ./iob_diag.sh --de
            TEST-Version:
            curl  https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/master/diag.sh > iob_diag.sh
            chmod 744 iob_diag.sh
            ./iob_diag.sh
            Weitere Optionen:
            ./iob_diag.sh --unmask           <--- Zeigt maskierte Ausgaben im Klartext
            ./iob_diag.sh --de               <--- Ausgabe tw. auf deutsch
            ./iob_diag.sh --de --unmask      <--- Kombination aus deutsch und Klartext
            Mit Ausgabe in eine Logdatei namens iob_diag.log sähe der Aufruf so aus:
            ./iob_diag.sh | tee iob_diag.log
            Vielleicht mag ja jemand mit Docker oder LXC das mal ausführen und den Output zeigen?
            Hier werden die üblichen Dinge relativ kompakt aufgelistet, die immer wieder bei Anfragen im Forum vermisst werden.
            Hier mal als ersten Einblick, vielleicht fällt ja noch etwas ein, was auch interessant zu wissen wäre, bevor man im Nebel stochert:
            *** ioBroker Diagnose ***
            Bitte das Fenster von puTTY breit ziehen oder auf Vollbild setzen
            Den nachfolgenden Output 1:1 in das ioBroker-Forum unter
            https://forum.iobroker.net
            vollständig posten ,inkl der jeweils drei Steuerzeichen ``` am Anfang und Ende:
            ===========Ab hier kopieren =========
            *** BASISSYSTEM ***
            CPU-Architektur: aarch64
            Docker: Nein
            No LSB modules are available.
            Distributor ID: Debian
            Description:    Debian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            *** Zeit und Zeitzonen ***
                           Local time: Tue 2022-11-01 16:53:39 CET
                       Universal time: Tue 2022-11-01 15:53:39 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** ARBEITSSPEICHER ***
            Mem:           7.7Gi       2.3Gi       3.2Gi       0.0Ki       2.2Gi       5.2Gi
            Swap:           99Mi          0B        99Mi
            Total:         7.8Gi       2.3Gi       3.3Gi
            *** Nodejs-Installation ***
            /usr/bin/nodejs         v18.12.0
            /usr/bin/node           v18.12.0
            /usr/bin/npm            8.19.2
            js-controller:  4.0.23
            Updates + Repos:
            *** User und Gruppen ***
            echad
            /home/echad
            echad adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** Server-Setup ***
            Konsole: tty
            Desktop:
            *** Repositories und OS-Updates ***
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
            Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
            Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:7 http://packages.azlux.fr/debian bullseye InRelease
            Hit:8 https://packages.grafana.com/oss/deb stable InRelease
            Hit:9 https://deb.nodesource.com/node_10.x bullseye InRelease
            Hit:10 https://repos.influxdata.com/debian bullseye InRelease
            Hit:11 https://deb.nodesource.com/node_12.x bullseye InRelease
            Hit:12 https://deb.nodesource.com/node_14.x bullseye InRelease
            Hit:13 https://deb.nodesource.com/node_16.x bullseye InRelease
            Hit:14 https://packages.redis.io/deb bullseye InRelease
            Hit:15 https://deb.volian.org/volian scar InRelease
            Hit:16 https://deb.nodesource.com/node_18.x bullseye InRelease
            Hit:18 https://deb.nodesource.com/node_19.x bullseye InRelease
            Get:19 https://pkgs.tailscale.com/stable/debian bullseye InRelease
            Hit:17 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
            Fetched 5,545 B in 3s (1,694 B/s)
            All packages are up to date.
            nodejs:
              Installed: 18.12.0-deb-1nodesource1
              Candidate: 18.12.0-deb-1nodesource1
              Version table:
                 19.0.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_19.x bullseye/main arm64 Packages
             *** 18.12.0-deb-1nodesource1 501
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                 16.18.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                 14.20.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                 12.22.12-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x bullseye/main arm64 Packages
                 12.22.12~dfsg-1~deb11u1 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.5~dfsg-2~11u1 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                 10.24.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x bullseye/main arm64 Packages
            ========== Bis hier kopieren ===========
            iob diag wurde beendet.
            Bitte nicht über den wilden Zoo an Repos wundern, das ist mein Test/Frickel-System, das soll so! :-D
            S Abwesend
            S Abwesend
            Shadowhunter23
            schrieb am zuletzt editiert von Shadowhunter23
            #681
            Bei mir im LXC mit 5 Zigbee Instanzen werden gleich alle Parameter von 4 Instanzen angezeigt. Meine Koordinatoren sind per TCP eingebunden. Kann / soll ich die Ausgabe zeigen oder muss ich das zensieren?
            curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
            ./iob_diag.sh
            Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
            ioBroker Backup Analyzer
            • S Shadowhunter23
              ./iob_diag.sh
              #682
              @shadowhunter23
              Ja, 4 Instanzen sind im Moment das Limit.
              Es werden zigbee.0 bis zigbee.3 angezeigt.
              Ja, das würde ich gerne mal in Gänze sehen.
              Kannst ja die Schlüssel mit Platzhaltern/Phantasiewerten ersetzen.
                @shadowhunter23
                S Abwesend
                S Abwesend
                Shadowhunter23
                #683
                Leerzeichen bei zigbee.2 und .3 kamen so, ich hab jetzt nur meine Daten geändert:
                *** BASE SYSTEM ***
                  Virtualization: lxc
                OS is similar to:
                model name      : Intel(R) Core(TM) i7-10700T CPU @ 2.00GHz
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 18:12:42 up 1 day, 23:11,  1 user,  load average: 0.06, 0.06, 0.08
                CPU threads: 6
                               Local time: Mon 2024-12-09 18:12:42 CET
                           Universal time: Mon 2024-12-09 17:12:42 UTC
                                 RTC time: n/a
                          RTC in local TZ: no
                tobias
                HOME=/home/tobias
                GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
                iobroker
                [sudo] password for tobias:
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev redis
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:             10G        4.0G        5.3G        491K        1.4G        6.7G
                Swap:             0B          0B          0B
                Total:           10G        4.0G        5.3G
                Active iob-Instances:   49
                        10240 M total memory
                         3825 M used memory
                         3730 M active memory
                         1121 M inactive memory
                         5083 M free memory
                            0 M buffer memory
                         1331 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                top - 18:12:55 up 1 day, 23:11,  1 user,  load average: 0.05, 0.06, 0.08
                Tasks:  78 total,   1 running,  77 sleeping,   0 stopped,   0 zombie
                MiB Mem :  10240.0 total,   5082.5 free,   3826.9 used,   1331.1 buff/cache
                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6413.1 avail Mem
                1 loaded units listed.
                *** FILESYSTEM ***
                /dev/mapper/pve-vm--400--disk--0 ext4       20G  6.5G   13G  35% /
                udev                             devtmpfs   16G     0   16G   0% /dev/tty
                tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
                tmpfs                            tmpfs     6.3G  136K  6.3G   1% /run
                tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1000
                /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
                /var:
                831M    /var/
                534M    /var/lib
                383M    /var/lib/redis
                226M    /var/cache
                222M    /var/cache/apt
                Archived and active journals take up 67.8M in the file system.
                355M    /opt/iobroker/backups/
                128M    /opt/iobroker/iobroker-data/files
                99M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                16M     /opt/iobroker/iobroker-data/objects.jsonl
                12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                USB-Devices by-id:
                No Devices found 'by-id'
                ./iob_diag.sh: line 617: [: too many arguments
                HINT:
                tcp
                HINT:
                Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                HINT:
                Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                HINT:
                Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                ./iob_diag.sh: line 676: [: too many arguments
                zigbee.0
                Extended Pan ID:
                ghnjghgh
                Pan ID:
                1234
                Channel:
                00
                Network Key:
                gfhjnhhf
                zigbee.1
                Extended Pan ID:
                ghnjghgh
                Pan ID:
                1234
                Channel:
                00
                Network Key:
                gfhjnhhf
                zigbee.2
                Extended Pan ID:
                ghnjghgh
                Pan ID:
                1234
                Channel:
                00
                Network Key:
                gfhjnhhf
                zigbee.3
                Extended Pan ID:
                ghnjghgh
                Pan ID:
                1234
                Channel:
                00
                Network Key:
                gfhjnhhf
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                 *** 20.18.1-1nodesource1 1001
                     20.18.0-1nodesource1 1001
                     20.17.0-1nodesource1 1001
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                ioBroker Status
                At least one iobroker host is running.
                Objects type: redis
                States  type: redis
                Hosts:
                iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 5746)
                admin:          7.4.4
                javascript:     8.8.3
                nodejs modules from github:     0
                Adapter State
                + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                  system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1883
                  system.adapter.mqtt.1                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
                + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                  system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                  system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
                + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
                + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                  system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                + instance is alive
                Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
                Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
                Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                Adapter    "mytime"       : 1.2.2    , installed 1.2.2
                Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                Adapter    "notification-manager": 1.3.0, installed 1.3.0
                Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                Adapter    "operating-hours": 1.2.0  , installed 1.2.0
                Adapter    "ping"         : 1.7.9    , installed 1.7.9
                Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                Objects and States
                Objects:        13487
                States:         11924
                Hit:1 http://security.debian.org bookworm-security InRelease
                Hit:2 http://deb.debian.org/debian bookworm InRelease
                Hit:5 https://packages.redis.io/deb bookworm InRelease
                Pending Updates: 0
                tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       11999557   207697/io.nuki.0
                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      103        16776      153/redis-server 12
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          689        1/init
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11997884   207652/io.mqtt.0
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11998035   207800/io.shelly.1
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15869      384/master
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15870      384/master
                tcp6       0      0 ::1:6379                :::*                    LISTEN      103        16777      153/redis-server 12
                tcp6       0      0 :::3000                 :::*                    LISTEN      1001       11999063   208020/io.fullybrow
                tcp6       0      0 :::22                   :::*                    LISTEN      0          11649      1/init
                tcp6       0      0 :::111                  :::*                    LISTEN      0          691        1/init
                tcp6       0      0 :::80                   :::*                    LISTEN      0          6137       176/apache2
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       12007886   208176/io.simple-ap
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12015647   208292/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11995807   207272/io.admin.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11996105   207567/io.chromecas
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11999591   207780/io.shelly.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       11998078   207822/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       11998079   207822/io.tuya.0
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          690        1/init
                udp6       0      0 :::111                  :::*                                0          692        1/init
                • S Shadowhunter23
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 6
                                   RTC time: n/a
                            RTC in local TZ: no
                  tobias
                  HOME=/home/tobias
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:             0B          0B          0B
                           3825 M used memory
                           5083 M free memory
                              0 M buffer memory
                           1331 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  *** FILESYSTEM ***
                  /var:
                  831M    /var/
                  534M    /var/lib
                  383M    /var/lib/redis
                  226M    /var/cache
                  222M    /var/cache/apt
                  USB-Devices by-id:
                  HINT:
                  tcp
                  HINT:
                  tcp
                  HINT:
                  tcp
                  HINT:
                  tcp
                  zigbee.0
                  Extended Pan ID:
                  ghnjghgh
                  Pan ID:
                  1234
                  Channel:
                  00
                  Network Key:
                  gfhjnhhf
                  zigbee.1
                  Extended Pan ID:
                  ghnjghgh
                  Pan ID:
                  1234
                  Channel:
                  00
                  Network Key:
                  gfhjnhhf
                  zigbee.2
                  Extended Pan ID:
                  ghnjghgh
                  Pan ID:
                  1234
                  Channel:
                  00
                  Network Key:
                  gfhjnhhf
                  zigbee.3
                  Extended Pan ID:
                  ghnjghgh
                  Pan ID:
                  1234
                  Channel:
                  00
                  Network Key:
                  gfhjnhhf
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: redis
                  States  type: redis
                  Hosts:
                  admin:          7.4.4
                  javascript:     8.8.3
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        13487
                  States:         11924
                  Pending Updates: 0
                  #684
                  @shadowhunter23 sagte in iob diag - Skript:
                  Muss ich schauen.
                  Da sollte eigentlich keine Leerzeichen kommen und die Ausgabe als kompaktes Päckchen pro Instanz erscheinen. Ist aber nur noch Kosmetik an der Stelle.
                    Muss ich schauen.
                    S Abwesend
                    S Abwesend
                    Shadowhunter23
                    #685
                    Wollte es nur korrekt angeben, nicht dass du denkst ich habe die Leerzeichen eingefügt.
                    • S Shadowhunter23
                      #686
                      Das ist genau richtig, solche 'Fehler' suche ich.
                      • S Shadowhunter23
                        #687
                        @shadowhunter23
                        Kannst du nochmal testen?
                        Es sollten nun auch die Werte für alle deine Instanzen angezeigt werden.
                        Jedenfalls solange die Instanznummer einstellig ist... :-)
                          @shadowhunter23
                          S Abwesend
                          S Abwesend
                          Shadowhunter23
                          #688
                          Ich mache wohl was falsch?
                          ./iob_diag.sh
                          USB-Devices by-id:
                          HINT:
                          tcp
                          HINT:
                          tcp
                          HINT:
                          tcp
                          HINT:
                          tcp
                          • S Shadowhunter23
                            ./iob_diag.sh
                            USB-Devices by-id:
                            HINT:
                            tcp
                            HINT:
                            tcp
                            HINT:
                            tcp
                            HINT:
                            tcp
                            #689
                            @shadowhunter23
                            Hast du die Datei nochmal frisch geladen?
                              @shadowhunter23
                              S Abwesend
                              S Abwesend
                              Shadowhunter23
                              #690
                              Ja aber ich lösche sie jetzt zuerst und versuche es nochmals.
                              • S Shadowhunter23
                                #691
                                @shadowhunter23
                                Versionsnummer ist
                                2024-12-09 Raspbian+zigbee diag+masking
                                  @shadowhunter23
                                  Versionsnummer ist
                                  S Abwesend
                                  S Abwesend
                                  Shadowhunter23
                                  #692
                                  Lag an mir:
                                  USB-Devices by-id:
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  Mit --unmask sehe ich dann die komplette Ausgabe.
                                  edit
                                  Die Leerzeichen/Absätze sind auch weg bei --unmask.
                                  • S Shadowhunter23
                                    Lag an mir:
                                    USB-Devices by-id:
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    edit
                                    #693
                                    Also alle 5 Instanzen in kompakten Blöcken, ohne komische Leerzeichen?
                                    So soll es sein.
                                    Dann schau ich auch mal wie ich das für die 'by-id'-Links hinbekommen kann, für den Fall, das jemand da ein halbes Dutzend zigbee-Stöckchen betreibt.
                                      So soll es sein.
                                      S Abwesend
                                      S Abwesend
                                      Shadowhunter23
                                      #694
                                      Ja 5 von 5!
                                      edit doch alle fünf!!
                                      • S Shadowhunter23
                                        Ja 5 von 5!
                                        #695
                                        Nein nur 4 von 5, zigbee.4 wird nicht angezeigt.
                                        Und die vierte gibt es auch? Kann eigentlich nicht sein, weil ich da in einer Schleife durch das Verzeichnis gehe...
                                          S Abwesend
                                          S Abwesend
                                          Shadowhunter23
                                          #696
                                          Sorry Thomas ist wohl zu spät für mich! Es passt alles.
