  4. js-controller Lucy (Version 7.0) jetzt im Stable Repository
backupdynamic notificationsjs-controllerlucystabletest
116 Beiträge 35 Kommentatoren 44.1k Aufrufe 29 Beobachtet
  • jolicJ jolic
    Sorry, war wegen "iob fix", sicherheitshalber mache ich nun ein reboot und dann nocheinmal eine "iob diag".
    jolicJ Offline
    jolicJ Offline
    jolic
    schrieb am zuletzt editiert von jolic
    2ter Versuch, ioB läuft und keine Fehler im Webinterface Protokoll, iob diag:
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: manjaro-arm
           Icon name: computer
    Operating System: Manjaro ARM Linux
              Kernel: Linux 6.6.59-1-MANJARO-RPI4
        Architecture: arm64
    OS is similar to: arch
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     00:02:46 up 5 min,  2 users,  load average: 1.13, 1.00, 0.48
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'n/a'. Please check yourself if the Operating System is actively maintained.
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-12-01 00:02:47 CET
               Universal time: Sat 2024-11-30 23:02:47 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi4m
    HOME=/home/pi4m
    GROUPS=sys network power users video storage lp input audio wheel pi4m iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/pi4m
    GROUPS=tty video uucp audio iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.2G        1.4G        6.2G        2.7M        660M        6.8G
    Swap:            12G          0B         12G
    Total:           20G        1.4G         18G
    Active iob-Instances:   15
             7806 M total memory
             1335 M used memory
             1321 M active memory
              347 M inactive memory
             5950 M free memory
               77 M buffer memory
              552 M swap cache
            11709 M total swap
                0 M used swap
            11709 M free swap
    top - 00:02:48 up 5 min,  2 users,  load average: 1.13, 1.00, 0.48
    Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.0 us,  3.9 sy,  0.0 ni, 94.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7806.6 total,   5949.5 free,   1336.6 used,    630.3 buff/cache
    MiB Swap:  11710.0 total,  11710.0 free,      0.0 used.   6470.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    dev            devtmpfs  3.8G     0  3.8G   0% /dev
    run            tmpfs     3.9G  744K  3.9G   1% /run
    /dev/sda2      ext4      917G  7.1G  873G   1% /
    tmpfs          tmpfs     3.9G  1.9M  3.9G   1% /dev/shm
    tmpfs          tmpfs     3.9G   20K  3.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-network-generator.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-udev-load-credentials.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysctl.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev-early.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-vconsole-setup.service
    /dev/sda1      vfat      458M   51M  407M  12% /boot
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     781M  4.0K  781M   1% /run/user/1000
    [Sat Nov 30 23:57:45 2024] EXT4-fs (sda2): mounted filesystem 4f15f9f9-8c71-4493-986e-d850a02a0242 r/w with ordered data mode. Quota mode: none.
    [Sat Nov 30 23:57:48 2024] EXT4-fs (sda2): re-mounted 4f15f9f9-8c71-4493-986e-d850a02a0242 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,nodev,noexec,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,errors=remount-ro
    /var:
    456M    /var/
    428M    /var/log
    427M    /var/log/journal/256940e9bd0e49078df2cc99156a71f7
    23M     /var/lib/pacman
    Archived and active journals take up 426.2M in the file system.
    /opt/iobroker/backups:
    11M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    950M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.9.0
    /usr/bin/npx            10.9.0
    /usr/bin/corepack       0.29.3
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    manjaro-arm         manjaro-arm (version: 7.0.3, hostname: manjaro-arm   , alive, uptime: 306)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : manjaro-arm                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : manjaro-arm                              -  enabled
      system.adapter.dwd.0                    : dwd                   : manjaro-arm                              -  enabled
    + system.adapter.email.0                  : email                 : manjaro-arm                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : manjaro-arm                              -  enabled
      system.adapter.ical.0                   : ical                  : manjaro-arm                              -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : manjaro-arm                              - disabled
    + system.adapter.javascript.0             : javascript            : manjaro-arm                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : manjaro-arm                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : manjaro-arm                              -  enabled
    + system.adapter.shelly.0                 : shelly                : manjaro-arm                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : manjaro-arm                              -  enabled, port: 8087, bind: 192.168.0.164, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : manjaro-arm                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: manjaro-arm                              -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : manjaro-arm                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : manjaro-arm                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : manjaro-arm                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : manjaro-arm                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : manjaro-arm                              -  enabled
      system.adapter.vis.0                    : vis                   : manjaro-arm                              -  enabled
    + system.adapter.web.0                    : web                   : manjaro-arm                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : manjaro-arm                              -  enabled
    + system.adapter.zwave2.0                 : zwave2                : manjaro-arm                              -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
    Objects and States
    Objects:        2325
    States:         1952
    No Debian-based Linux detected.
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:38919         0.0.0.0:*               LISTEN      1001       15199      1131/io.yahka.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7840       557/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1015       557/iobroker.js-con
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      968        6421       571/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          919        559/sshd: /usr/bin/
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      968        7466       571/pihole-FTL
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8248       471/lighttpd
    tcp        0      0 192.168.0.164:8087      0.0.0.0:*               LISTEN      1001       15568      1092/io.simple-api.
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6669       997/io.mqtt.0
    tcp        0      0 0.0.0.0:42169           0.0.0.0:*               LISTEN      1001       15193      1131/io.yahka.0
    tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN      0          7390       460/unbound
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8446       789/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15166      1112/io.web.0
    tcp6       0      0 ::1:4711                :::*                    LISTEN      968        6422       571/pihole-FTL
    tcp6       0      0 :::22                   :::*                    LISTEN      0          921        559/sshd: /usr/bin/
    tcp6       0      0 :::53                   :::*                    LISTEN      968        7468       571/pihole-FTL
    udp        0      0 127.0.0.1:5335          0.0.0.0:*                           0          7389       460/unbound
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15195      1131/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15194      1131/io.yahka.0
    udp        0      0 192.168.0.164:5353      0.0.0.0:*                           1001       13543      1037/io.tr-064.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11209      1026/io.shelly.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           968        7465       571/pihole-FTL
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6273       457/dhcpcd: [networ
    udp6       0      0 :::53                   :::*                                968        7467       571/pihole-FTL
    udp6       0      0 :::546                  :::*                                0          6275       457/dhcpcd: [networ
    2024-12-01 00:00:00.111  - info: host.manjaro-arm instance system.adapter.ical.0 in version "1.16.1" started with pid 1177
    2024-12-01 00:00:02.735  - info: admin.0 (789) failed connection to socket.io from ::ffff:192.168.0.45: Passport was not initialized
    2024-12-01 00:00:03.497  - info: ical.0 (1177) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 7.0.3
    2024-12-01 00:00:04.045  - info: ical.0 (1177) processing URL: AbfuhrkalenderMasholder https://art-trier.de/ics-feed/54634:Bitburg-Masholder::Masholder@.ics
    2024-12-01 00:00:04.097  - info: javascript.0 (860) script.js.common.Abfall: <table class='Abfall'><tr><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/gelber_sack_und_papierabfall.png'></td><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/restmuell.png'></td><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/restmuell.png'></td><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/gelber_sack_und_papierabfall.png'></td></tr><tr><td class='AbfallText'>02.12.2024</td><td class='AbfallText'>12.12.2024</td><td class='AbfallText'>27.12.2024</td><td class='AbfallText'>30.12.2024</td></tr></table>
    2024-12-01 00:00:07.559  - info: admin.0 (789) ==> Connected system.user.admin from ::ffff:192.168.0.45
    2024-12-01 00:00:09.334  - info: ical.0 (1177) Terminated (NO_ERROR): Without reason
    2024-12-01 00:00:10.238  - info: host.manjaro-arm instance system.adapter.ical.0 having pid 1177 terminated with code 0 (NO_ERROR)
    2024-12-01 00:00:45.047  - info: host.manjaro-arm instance system.adapter.dwd.0 in version "2.8.5" started with pid 1280
    2024-12-01 00:00:47.463  - info: dwd.0 (1280) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 7.0.3
    2024-12-01 00:00:48.030  - info: dwd.0 (1280) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
    2024-12-01 00:00:48.079  - info: dwd.0 (1280) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
    2024-12-01 00:00:48.185  - info: dwd.0 (1280) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-01 00:00:48.769  - info: host.manjaro-arm instance system.adapter.dwd.0 having pid 1280 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-12-01 00:00:49.838  - info: web.0 (1112) ==> Connected system.user.admin from ::ffff:192.168.0.3
    2024-12-01 00:00:52.057  - info: web.0 (1112) <== Disconnect system.user.admin from ::ffff:192.168.0.3 vis-2
    2024-12-01 00:00:56.783  - info: web.0 (1112) ==> Connected system.user.admin from ::ffff:192.168.0.3
    2024-12-01 00:00:57.410  - info: javascript.0 (860) script.js.common.tabletLadestatus: Tablet Akku 30%  -> Ladestrom einschalten
                            v.2024-10-19
           Icon name: computer
        Architecture: arm64
    Kernel:                 aarch64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/npm            10.9.0
    /usr/bin/npx            10.9.0
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            8.2G        1.5G        5.3G        2.7M        1.5G        6.7G
    Swap:            12G          0B         12G
    Total:           20G        1.5G         17G
    ioBroker Core:          js-controller           7.0.3
                            admin                   7.1.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                2325
    States:                 1952
    Size of iob-Database:
    728K    /opt/iobroker/iobroker-data/states.jsonl
    ioBroker | RPi 4 (SSD) | EndeavourOS (headless)
    • jolicJ jolic
      Script v.2024-10-19
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi4m
      HOME=/home/pi4m
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            12G          0B         12G
      Total:           20G        1.4G         18G
               7806 M total memory
               1335 M used memory
               5950 M free memory
                 77 M buffer memory
                552 M swap cache
              11709 M total swap
                  0 M used swap
              11709 M free swap
      *** FILESYSTEM ***
      /var:
      456M    /var/
      428M    /var/log
      23M     /var/lib/pacman
      USB-Devices by-id:
      /usr/bin/npm            10.9.0
      /usr/bin/npx            10.9.0
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.1.5
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        2325
      States:         1952
                              v.2024-10-19
             Icon name: computer
          Architecture: arm64
      Kernel:                 aarch64
      Userland:               64 bit
      User-ID:                1000
      /usr/bin/npm            10.9.0
      /usr/bin/npx            10.9.0
      MEMORY:
      Swap:            12G          0B         12G
      Total:           20G        1.5G         17G
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                2325
      States:                 1952
      @jolic
      Schaut doch gut aus.
      Zu vis2 und cams kann ich aber nix sagen.
      jolicJ 1 Antwort Letzte Antwort
        @jolic
        jolicJ Offline
        jolicJ Offline
        jolic
        OK, trotzdem vielen Dank für deine großartige Unterstützung und den Hinweis auf die "distro-info"!
        Das mit dem Refresh der Bilder ist wirklich kurios. Mal sehen, ob es an mir liegt oder ob jemand anderes ein ähnliches Problem hat. Falls jemand das bestätigen oder eine Lösung anbieten kann, gerne Bescheid geben!
        Ich habe mir das im Browser über die Konsole (F12) im Tab "Netzwerk" angesehen. Dort sehe ich, dass der Webcam-Snapshot geladen wird, aber es gibt scheinbar keinen "Refresh". Das könnte also an VIS2 liegen. Blöd, dass mir das nicht früher aufgefallen ist. Ich werde mal weiter nachforschen...
        • jolicJ jolic
          jolicJ Offline
          jolicJ Offline
          jolic
          Es scheint ein Bug in VIS2 zu sein. Tatsächlich ist mir das zunächst nicht aufgefallen – es handelt sich ja um Standbilder, die nur alle paar Sekunden wechseln. Ich lasse nun die Uhrzeit im Bild einblenden.
          github Quellen:
          Basic image does not refresh itself anymore when using a binding
          und
          Basic Image Updatezeit V2.9.50
          Sorry, dass ich den Thread dafür genutzt habe. Anfangs sah es so aus, als würde das Problem am neuen JS-Controller liegen – dieser läuft aber absolut problemlos!
          Nachtrag: Ich habe als Workaround ein Script geschrieben, das mit mehreren Widgets funktioniert (GitHub Link).
            steinchen
            Leider startet nach update des js-controllers mein Lupusec Adapter nicht mehr.
            eine neuinstallation des Adapters hat nicht geholfen.
            Was könnte ich denn da tun ?
            vg steinchen
            Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
            • S steinchen
              vg steinchen
              @steinchen
              Du könntest den Text aus dem LogFile
              iob logs --watch
              in Textform in CodeTags eingebettet posten und nicht als Screenshot.
              Und du könntest die empfohlene nodejs-Version verwenden...
              iob nodejs-update
              S 2 Antworten Letzte Antwort
                @steinchen
                iob logs --watch
                iob nodejs-update
                steinchen
                so hier ein neuer Versuch
                2024-12-02 13:22:07.346  - info: host.lichtenhain instance system.adapter.lupusec.0 terminated with code 0 (NO_ERROR)
                2024-12-02 13:22:07.347  - info: host.lichtenhain Restart adapter system.adapter.lupusec.0 because enabled
                2024-12-02 13:22:38.156  - info: host.lichtenhain instance system.adapter.lupusec.0 in version "1.3.6" started with pid 1867
                2024-12-02 13:22:41.378  - info: lupusec.0 (1867) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                2024-12-02 13:22:41.553  - info: lupusec.0 (1867) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.lupusec, node: v18.20.4, js-controller: 7.0.3
                2024-12-02 13:22:41.579  - info: lupusec.0 (1867) Starting Adapter lupusec.0 in version 1.3.6
                2024-12-02 13:22:41.693  - info: lupusec.0 (1867) Restarting Adapter because of changeing Sentry settings
                2024-12-02 13:22:41.694  - warn: lupusec.0 (1867) Restart initiated
                2024-12-02 13:22:41.704  - info: lupusec.0 (1867) terminating
                2024-12-02 13:22:41.706  - info: lupusec.0 (1867) Terminated (NO_ERROR): Without reason
                2024-12-02 13:22:42.202  - info: lupusec.0 (1867) terminating
                2024-12-02 13:22:42.305  - info: host.lichtenhain instance system.adapter.lupusec.0 terminated with code 0 (NO_ERROR)
                2024-12-02 13:22:42.306  - info: host.lichtenhain Restart adapter system.adapter.lupusec.0 because enabled
                  @steinchen
                  iob logs --watch
                  iob nodejs-update
                  steinchen
                  hab leider noch Debian Buster
                  Debian 10 'Buster' has reached End of Life and is not supported anymore.
                  Recent versions of nodejs won't install.
                  Please install the current Debian Stable
                  • S steinchen
                    @steinchen sagte in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
                    Dann musst du das als erstes ändern. Buster ist mehr als tot.
                    • S steinchen
                      vg steinchen
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @steinchen said in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
                      vg steinchen
                      Welche Version des js-controllers hattest du vorher drauf?
                      An sich ist es bekannt, dass der Adapter Probleme macht:
                      https://github.com/schmupu/ioBroker.lupusec/issues/84
                      Versuch mal ausnahmsweise (!) die Version 2.0 von Github zu installieren - vorzugsweise auf einem Testsystem. Von dIrekten GitHub Installationen wird jedenfalls weiterhin abgeraten und ich sage ausdrücklich nur bei einwandfreiem Backup und unter dem Bewuußtsein eine ALPHA Version zu installieren eventuell ausprobieren.
                      Und schreib dem Maintainer an dass er doch bitte eine saubere Releas 2.x.x erstellen soll...
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      • mcm1957M mcm1957
                        vg steinchen
                        steinchen
                        @mcm1957
                        jo, mit der 2.x von Github geht es
                        ich habe Ihn auf Git angeschrieben, hattest du ja auch :)
                        danke erstmal.
                        @Thomas-Braun
                        update wird auf einem pi5 gemacht, ist schon in der Vorbereitung.
                        trotzdem meinen Dank
                        • S steinchen
                          @mcm1957
                          danke erstmal.
                          @Thomas-Braun
                          Neuinstallation. Vob Buster führt keine Weg zu Bookworm.
                            steinchen
                            mein ich doch :)
                            neuer Pi mit Neuinstallation
                              mrhary
                              Seit dem Update auf Js-controller Lucy läuft der Radar2 Adapter nicht mehr, hat außer mir noch jemand dieses Problem?
                              mcm1957M F 2 Antworten Letzte Antwort
                              • M mrhary
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                @mrhary said in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
                                Bei mir läuft er auch nicht.
                                Kann aber daran liegen dass er nicht installiert ist ....
                                Im Ernst:
                                Meinst du wirklich dass jemand eine Fehleranalyse vornehmen kann ohne dass due den Fehler auch nur irgendwie beschreibst? Und ohne dass du irgendwelche Versionsinfos nennst?
                                Also:
                                Adapter version ?
                                js-controller jatz (7.0.3) / vor dem Upgrade: ?
                                Log mit Level DEBUG ?
                                O 1 Antwort Letzte Antwort
                                • mcm1957M mcm1957
                                  Im Ernst:
                                  Also:
                                  Adapter version ?
                                  O Offline
                                  O Offline
                                  oFbEQnpoLKKl6mbY5e13
                                  @apollon77
                                  @foxriver76
                                  Beim Upgrade von 7.0.3 auf 7.0.4 (Buanet-Container) über den Admin kam:
                                  SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
                                  Gefunden habe ich das dazu:
                                  https://github.com/ioBroker/ioBroker.js-controller/issues/2352
                                  • M mrhary
                                    Fabian1
                                    @mrhary bei mir läuft der Radar2 ohne probleme mit der 7.0.3. Hast du die readme auf github gelesen und alle Schritte befolgt?
                                    • O oFbEQnpoLKKl6mbY5e13
                                      @apollon77
                                      @foxriver76
                                      foxriver76F Offline
                                      foxriver76F Offline
                                      foxriver76
                                      @ofbeqnpolkkl6mby5e13 ja vermutlich passt iwas nicht auf dem Docker nur ich kanns nicht testen derzeit https://github.com/ioBroker/ioBroker.js-controller/issues/2964
                                      Videotutorials & mehr
                                      • T Nicht stören
                                        T Nicht stören
                                        ticaki
                                        bei mir schlägt das GUI gesteuerte Upgrade des JS-Controllers immer fehl. Die Logausgabe sieht so aus:
                                        2024-12-08 10:30:15.728  - info: host.iobroker-lxc [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                                        2024-12-08 10:30:15.776  - error: host.iobroker-lxc [CONTROLLER_AUTO_UPGRADE] Uncaught Exception: Error: listen EACCES: permission denied 0.0.0.0:443
                                            at Server.setupListenHandle [as _listen2] (node:net:1886:21)
                                            at listenInCluster (node:net:1965:12)
                                            at Server.listen (node:net:2067:7)
                                            at UpgradeManager.startSecureWebServer (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/upgradeManager.ts:331:21)
                                            at UpgradeManager.startWebServer (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/upgradeManager.ts:242:18)
                                            at main (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/upgradeManager.ts:446:20)
                                        Der Fehler sieht für mich aus als wenn ich was falsch eingestellt hätte:
                                        Weiß nur nicht was. :) Hm vielleicht im Admin die IP fest vorgeben auf der er erreichbar ist?
                                        Spenden
                                        Dr. BakteriusD foxriver76F 2 Antworten Letzte Antwort
                                        • T ticaki
                                          Dr. BakteriusD Offline
                                          Dr. Bakterius
                                          @ticaki sagte in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
                                          Weiß nur nicht was.
                                          Port 443 ist für HTTPS, also gesicherter Zugang. Vielleicht das mal deaktivieren?
