  4. js-controller Lucy (Version 7.0) jetzt im Stable Repository
backupdynamic notificationsjs-controllerlucystabletest
116 Beiträge 35 Kommentatoren 44.1k Aufrufe 29 Beobachtet
    @jolic
    Der ioBroker läuft halt nicht.
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    Startet der nicht per
    iob start
    Dann mal in den
    systemctl status iobroker.service
    werfen.
    jolicJ Offline
    jolicJ Offline
    jolic
    Sorry, war wegen "iob fix", sicherheitshalber mache ich nun ein reboot und dann nocheinmal eine "iob diag".
    ioBroker | RPi 4 (SSD) | EndeavourOS (headless)
    jolicJ 1 Antwort Letzte Antwort
    • jolicJ jolic
      jolicJ Offline
      jolicJ Offline
      jolic
      schrieb am zuletzt editiert von jolic
      2ter Versuch, ioB läuft und keine Fehler im Webinterface Protokoll, iob diag:
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: manjaro-arm
             Icon name: computer
      Operating System: Manjaro ARM Linux
                Kernel: Linux 6.6.59-1-MANJARO-RPI4
          Architecture: arm64
      OS is similar to: arch
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       00:02:46 up 5 min,  2 users,  load average: 1.13, 1.00, 0.48
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed 'n/a'. Please check yourself if the Operating System is actively maintained.
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2024-12-01 00:02:47 CET
                 Universal time: Sat 2024-11-30 23:02:47 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi4m
      HOME=/home/pi4m
      GROUPS=sys network power users video storage lp input audio wheel pi4m iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/pi4m
      GROUPS=tty video uucp audio iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.2G        1.4G        6.2G        2.7M        660M        6.8G
      Swap:            12G          0B         12G
      Total:           20G        1.4G         18G
      Active iob-Instances:   15
               7806 M total memory
               1335 M used memory
               1321 M active memory
                347 M inactive memory
               5950 M free memory
                 77 M buffer memory
                552 M swap cache
              11709 M total swap
                  0 M used swap
              11709 M free swap
      top - 00:02:48 up 5 min,  2 users,  load average: 1.13, 1.00, 0.48
      Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.0 us,  3.9 sy,  0.0 ni, 94.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7806.6 total,   5949.5 free,   1336.6 used,    630.3 buff/cache
      MiB Swap:  11710.0 total,  11710.0 free,      0.0 used.   6470.1 avail Mem
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      dev            devtmpfs  3.8G     0  3.8G   0% /dev
      run            tmpfs     3.9G  744K  3.9G   1% /run
      /dev/sda2      ext4      917G  7.1G  873G   1% /
      tmpfs          tmpfs     3.9G  1.9M  3.9G   1% /dev/shm
      tmpfs          tmpfs     3.9G   20K  3.9G   1% /tmp
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-network-generator.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-udev-load-credentials.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysctl.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev-early.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-vconsole-setup.service
      /dev/sda1      vfat      458M   51M  407M  12% /boot
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     781M  4.0K  781M   1% /run/user/1000
      [Sat Nov 30 23:57:45 2024] EXT4-fs (sda2): mounted filesystem 4f15f9f9-8c71-4493-986e-d850a02a0242 r/w with ordered data mode. Quota mode: none.
      [Sat Nov 30 23:57:48 2024] EXT4-fs (sda2): re-mounted 4f15f9f9-8c71-4493-986e-d850a02a0242 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,nodev,noexec,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,errors=remount-ro
      /var:
      456M    /var/
      428M    /var/log
      427M    /var/log/journal/256940e9bd0e49078df2cc99156a71f7
      23M     /var/lib/pacman
      Archived and active journals take up 426.2M in the file system.
      /opt/iobroker/backups:
      11M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      950M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.9.0
      /usr/bin/npx            10.9.0
      /usr/bin/corepack       0.29.3
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      manjaro-arm         manjaro-arm (version: 7.0.3, hostname: manjaro-arm   , alive, uptime: 306)
      Core adapters versions
      js-controller:  7.0.3
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : manjaro-arm                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : manjaro-arm                              -  enabled
        system.adapter.dwd.0                    : dwd                   : manjaro-arm                              -  enabled
      + system.adapter.email.0                  : email                 : manjaro-arm                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : manjaro-arm                              -  enabled
        system.adapter.ical.0                   : ical                  : manjaro-arm                              -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : manjaro-arm                              - disabled
      + system.adapter.javascript.0             : javascript            : manjaro-arm                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : manjaro-arm                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : manjaro-arm                              -  enabled
      + system.adapter.shelly.0                 : shelly                : manjaro-arm                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : manjaro-arm                              -  enabled, port: 8087, bind: 192.168.0.164, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : manjaro-arm                              -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: manjaro-arm                              -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : manjaro-arm                              -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : manjaro-arm                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : manjaro-arm                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : manjaro-arm                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : manjaro-arm                              -  enabled
        system.adapter.vis.0                    : vis                   : manjaro-arm                              -  enabled
      + system.adapter.web.0                    : web                   : manjaro-arm                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : manjaro-arm                              -  enabled
      + system.adapter.zwave2.0                 : zwave2                : manjaro-arm                              -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Instances
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.3    , installed 7.0.3
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
      Objects and States
      Objects:        2325
      States:         1952
      No Debian-based Linux detected.
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:38919         0.0.0.0:*               LISTEN      1001       15199      1131/io.yahka.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7840       557/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1015       557/iobroker.js-con
      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      968        6421       571/pihole-FTL
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          919        559/sshd: /usr/bin/
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      968        7466       571/pihole-FTL
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8248       471/lighttpd
      tcp        0      0 192.168.0.164:8087      0.0.0.0:*               LISTEN      1001       15568      1092/io.simple-api.
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6669       997/io.mqtt.0
      tcp        0      0 0.0.0.0:42169           0.0.0.0:*               LISTEN      1001       15193      1131/io.yahka.0
      tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN      0          7390       460/unbound
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8446       789/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15166      1112/io.web.0
      tcp6       0      0 ::1:4711                :::*                    LISTEN      968        6422       571/pihole-FTL
      tcp6       0      0 :::22                   :::*                    LISTEN      0          921        559/sshd: /usr/bin/
      tcp6       0      0 :::53                   :::*                    LISTEN      968        7468       571/pihole-FTL
      udp        0      0 127.0.0.1:5335          0.0.0.0:*                           0          7389       460/unbound
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15195      1131/io.yahka.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15194      1131/io.yahka.0
      udp        0      0 192.168.0.164:5353      0.0.0.0:*                           1001       13543      1037/io.tr-064.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11209      1026/io.shelly.0
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           968        7465       571/pihole-FTL
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6273       457/dhcpcd: [networ
      udp6       0      0 :::53                   :::*                                968        7467       571/pihole-FTL
      udp6       0      0 :::546                  :::*                                0          6275       457/dhcpcd: [networ
      2024-12-01 00:00:00.111  - info: host.manjaro-arm instance system.adapter.ical.0 in version "1.16.1" started with pid 1177
      2024-12-01 00:00:02.735  - info: admin.0 (789) failed connection to socket.io from ::ffff:192.168.0.45: Passport was not initialized
      2024-12-01 00:00:03.497  - info: ical.0 (1177) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 7.0.3
      2024-12-01 00:00:04.045  - info: ical.0 (1177) processing URL: AbfuhrkalenderMasholder https://art-trier.de/ics-feed/54634:Bitburg-Masholder::Masholder@.ics
      2024-12-01 00:00:04.097  - info: javascript.0 (860) script.js.common.Abfall: <table class='Abfall'><tr><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/gelber_sack_und_papierabfall.png'></td><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/restmuell.png'></td><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/restmuell.png'></td><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/gelber_sack_und_papierabfall.png'></td></tr><tr><td class='AbfallText'>02.12.2024</td><td class='AbfallText'>12.12.2024</td><td class='AbfallText'>27.12.2024</td><td class='AbfallText'>30.12.2024</td></tr></table>
      2024-12-01 00:00:07.559  - info: admin.0 (789) ==> Connected system.user.admin from ::ffff:192.168.0.45
      2024-12-01 00:00:09.334  - info: ical.0 (1177) Terminated (NO_ERROR): Without reason
      2024-12-01 00:00:10.238  - info: host.manjaro-arm instance system.adapter.ical.0 having pid 1177 terminated with code 0 (NO_ERROR)
      2024-12-01 00:00:45.047  - info: host.manjaro-arm instance system.adapter.dwd.0 in version "2.8.5" started with pid 1280
      2024-12-01 00:00:47.463  - info: dwd.0 (1280) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 7.0.3
      2024-12-01 00:00:48.030  - info: dwd.0 (1280) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
      2024-12-01 00:00:48.079  - info: dwd.0 (1280) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
      2024-12-01 00:00:48.185  - info: dwd.0 (1280) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-12-01 00:00:48.769  - info: host.manjaro-arm instance system.adapter.dwd.0 having pid 1280 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-12-01 00:00:49.838  - info: web.0 (1112) ==> Connected system.user.admin from ::ffff:192.168.0.3
      2024-12-01 00:00:52.057  - info: web.0 (1112) <== Disconnect system.user.admin from ::ffff:192.168.0.3 vis-2
      2024-12-01 00:00:56.783  - info: web.0 (1112) ==> Connected system.user.admin from ::ffff:192.168.0.3
      2024-12-01 00:00:57.410  - info: javascript.0 (860) script.js.common.tabletLadestatus: Tablet Akku 30%  -> Ladestrom einschalten
                              v.2024-10-19
             Icon name: computer
          Architecture: arm64
      Kernel:                 aarch64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/npm            10.9.0
      /usr/bin/npx            10.9.0
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            8.2G        1.5G        5.3G        2.7M        1.5G        6.7G
      Swap:            12G          0B         12G
      Total:           20G        1.5G         17G
      ioBroker Core:          js-controller           7.0.3
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                2325
      States:                 1952
      Size of iob-Database:
      728K    /opt/iobroker/iobroker-data/states.jsonl
      • jolicJ jolic
        Script v.2024-10-19
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi4m
        HOME=/home/pi4m
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            12G          0B         12G
        Total:           20G        1.4G         18G
                 7806 M total memory
                 1335 M used memory
                 5950 M free memory
                   77 M buffer memory
                  552 M swap cache
                11709 M total swap
                    0 M used swap
                11709 M free swap
        *** FILESYSTEM ***
        /var:
        456M    /var/
        428M    /var/log
        23M     /var/lib/pacman
        USB-Devices by-id:
        /usr/bin/npm            10.9.0
        /usr/bin/npx            10.9.0
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.1.5
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        2325
        States:         1952
                                v.2024-10-19
               Icon name: computer
            Architecture: arm64
        Kernel:                 aarch64
        Userland:               64 bit
        User-ID:                1000
        /usr/bin/npm            10.9.0
        /usr/bin/npx            10.9.0
        MEMORY:
        Swap:            12G          0B         12G
        Total:           20G        1.5G         17G
                                admin                   7.1.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                2325
        States:                 1952
        @jolic
        Schaut doch gut aus.
        Zu vis2 und cams kann ich aber nix sagen.
          @jolic
          jolicJ Offline
          jolicJ Offline
          jolic
          OK, trotzdem vielen Dank für deine großartige Unterstützung und den Hinweis auf die "distro-info"!
          Das mit dem Refresh der Bilder ist wirklich kurios. Mal sehen, ob es an mir liegt oder ob jemand anderes ein ähnliches Problem hat. Falls jemand das bestätigen oder eine Lösung anbieten kann, gerne Bescheid geben!
          Ich habe mir das im Browser über die Konsole (F12) im Tab "Netzwerk" angesehen. Dort sehe ich, dass der Webcam-Snapshot geladen wird, aber es gibt scheinbar keinen "Refresh". Das könnte also an VIS2 liegen. Blöd, dass mir das nicht früher aufgefallen ist. Ich werde mal weiter nachforschen...
          • jolicJ jolic
            jolicJ Offline
            jolicJ Offline
            jolic
            Es scheint ein Bug in VIS2 zu sein. Tatsächlich ist mir das zunächst nicht aufgefallen – es handelt sich ja um Standbilder, die nur alle paar Sekunden wechseln. Ich lasse nun die Uhrzeit im Bild einblenden.
            github Quellen:
            Basic image does not refresh itself anymore when using a binding
            und
            Basic Image Updatezeit V2.9.50
            Sorry, dass ich den Thread dafür genutzt habe. Anfangs sah es so aus, als würde das Problem am neuen JS-Controller liegen – dieser läuft aber absolut problemlos!
            Nachtrag: Ich habe als Workaround ein Script geschrieben, das mit mehreren Widgets funktioniert (GitHub Link).
              steinchen
              Leider startet nach update des js-controllers mein Lupusec Adapter nicht mehr.
              eine neuinstallation des Adapters hat nicht geholfen.
              Was könnte ich denn da tun ?
              vg steinchen
              Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
              • S steinchen
                vg steinchen
                @steinchen
                Du könntest den Text aus dem LogFile
                iob logs --watch
                in Textform in CodeTags eingebettet posten und nicht als Screenshot.
                Und du könntest die empfohlene nodejs-Version verwenden...
                iob nodejs-update
                S 2 Antworten Letzte Antwort
                  @steinchen
                  iob logs --watch
                  iob nodejs-update
                  steinchen
                  so hier ein neuer Versuch
                  2024-12-02 13:22:07.346  - info: host.lichtenhain instance system.adapter.lupusec.0 terminated with code 0 (NO_ERROR)
                  2024-12-02 13:22:07.347  - info: host.lichtenhain Restart adapter system.adapter.lupusec.0 because enabled
                  2024-12-02 13:22:38.156  - info: host.lichtenhain instance system.adapter.lupusec.0 in version "1.3.6" started with pid 1867
                  2024-12-02 13:22:41.378  - info: lupusec.0 (1867) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  2024-12-02 13:22:41.553  - info: lupusec.0 (1867) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.lupusec, node: v18.20.4, js-controller: 7.0.3
                  2024-12-02 13:22:41.579  - info: lupusec.0 (1867) Starting Adapter lupusec.0 in version 1.3.6
                  2024-12-02 13:22:41.693  - info: lupusec.0 (1867) Restarting Adapter because of changeing Sentry settings
                  2024-12-02 13:22:41.694  - warn: lupusec.0 (1867) Restart initiated
                  2024-12-02 13:22:41.704  - info: lupusec.0 (1867) terminating
                  2024-12-02 13:22:41.706  - info: lupusec.0 (1867) Terminated (NO_ERROR): Without reason
                  2024-12-02 13:22:42.202  - info: lupusec.0 (1867) terminating
                  2024-12-02 13:22:42.305  - info: host.lichtenhain instance system.adapter.lupusec.0 terminated with code 0 (NO_ERROR)
                  2024-12-02 13:22:42.306  - info: host.lichtenhain Restart adapter system.adapter.lupusec.0 because enabled
                    @steinchen
                    iob logs --watch
                    iob nodejs-update
                    steinchen
                    hab leider noch Debian Buster
                    Debian 10 'Buster' has reached End of Life and is not supported anymore.
                    Recent versions of nodejs won't install.
                    Please install the current Debian Stable
                    • S steinchen
                      @steinchen sagte in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
                      Dann musst du das als erstes ändern. Buster ist mehr als tot.
                      • S steinchen
                        vg steinchen
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @steinchen said in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
                        vg steinchen
                        Welche Version des js-controllers hattest du vorher drauf?
                        An sich ist es bekannt, dass der Adapter Probleme macht:
                        https://github.com/schmupu/ioBroker.lupusec/issues/84
                        Versuch mal ausnahmsweise (!) die Version 2.0 von Github zu installieren - vorzugsweise auf einem Testsystem. Von dIrekten GitHub Installationen wird jedenfalls weiterhin abgeraten und ich sage ausdrücklich nur bei einwandfreiem Backup und unter dem Bewuußtsein eine ALPHA Version zu installieren eventuell ausprobieren.
                        Und schreib dem Maintainer an dass er doch bitte eine saubere Releas 2.x.x erstellen soll...
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • mcm1957M mcm1957
                          vg steinchen
                          steinchen
                          @mcm1957
                          jo, mit der 2.x von Github geht es
                          ich habe Ihn auf Git angeschrieben, hattest du ja auch :)
                          danke erstmal.
                          @Thomas-Braun
                          update wird auf einem pi5 gemacht, ist schon in der Vorbereitung.
                          trotzdem meinen Dank
                          • S steinchen
                            @mcm1957
                            danke erstmal.
                            @Thomas-Braun
                            Neuinstallation. Vob Buster führt keine Weg zu Bookworm.
                              steinchen
                              mein ich doch :)
                              neuer Pi mit Neuinstallation
                                mrhary
                                Seit dem Update auf Js-controller Lucy läuft der Radar2 Adapter nicht mehr, hat außer mir noch jemand dieses Problem?
                                mcm1957M F 2 Antworten Letzte Antwort
                                • M mrhary
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  @mrhary said in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
                                  Bei mir läuft er auch nicht.
                                  Kann aber daran liegen dass er nicht installiert ist ....
                                  Im Ernst:
                                  Meinst du wirklich dass jemand eine Fehleranalyse vornehmen kann ohne dass due den Fehler auch nur irgendwie beschreibst? Und ohne dass du irgendwelche Versionsinfos nennst?
                                  Also:
                                  Adapter version ?
                                  js-controller jatz (7.0.3) / vor dem Upgrade: ?
                                  Log mit Level DEBUG ?
                                  O 1 Antwort Letzte Antwort
                                  • mcm1957M mcm1957
                                    Im Ernst:
                                    Also:
                                    Adapter version ?
                                    O Offline
                                    O Offline
                                    oFbEQnpoLKKl6mbY5e13
                                    @apollon77
                                    @foxriver76
                                    Beim Upgrade von 7.0.3 auf 7.0.4 (Buanet-Container) über den Admin kam:
                                    SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
                                    Gefunden habe ich das dazu:
                                    https://github.com/ioBroker/ioBroker.js-controller/issues/2352
                                    • M mrhary
                                      Fabian1
                                      @mrhary bei mir läuft der Radar2 ohne probleme mit der 7.0.3. Hast du die readme auf github gelesen und alle Schritte befolgt?
                                      • O oFbEQnpoLKKl6mbY5e13
                                        @apollon77
                                        @foxriver76
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        @ofbeqnpolkkl6mby5e13 ja vermutlich passt iwas nicht auf dem Docker nur ich kanns nicht testen derzeit https://github.com/ioBroker/ioBroker.js-controller/issues/2964
                                        Videotutorials & mehr
                                        • T Nicht stören
                                          T Nicht stören
                                          ticaki
                                          bei mir schlägt das GUI gesteuerte Upgrade des JS-Controllers immer fehl. Die Logausgabe sieht so aus:
                                          2024-12-08 10:30:15.728  - info: host.iobroker-lxc [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                                          2024-12-08 10:30:15.776  - error: host.iobroker-lxc [CONTROLLER_AUTO_UPGRADE] Uncaught Exception: Error: listen EACCES: permission denied 0.0.0.0:443
                                              at Server.setupListenHandle [as _listen2] (node:net:1886:21)
                                              at listenInCluster (node:net:1965:12)
                                              at Server.listen (node:net:2067:7)
                                              at UpgradeManager.startSecureWebServer (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/upgradeManager.ts:331:21)
                                              at UpgradeManager.startWebServer (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/upgradeManager.ts:242:18)
                                              at main (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/upgradeManager.ts:446:20)
                                          Der Fehler sieht für mich aus als wenn ich was falsch eingestellt hätte:
                                          Weiß nur nicht was. :) Hm vielleicht im Admin die IP fest vorgeben auf der er erreichbar ist?
                                          Spenden
                                          Dr. BakteriusD foxriver76F 2 Antworten Letzte Antwort
