  5. Skript funktionieren nicht nach Neustart - Gelöst
    6.5k
30 Beiträge 6 Kommentatoren 1.8k Aufrufe 3 Beobachtet
  • SvaggyS Svaggy
    Danke, erledigt. Funktioniert leider immer noch nicht.
    Hier der erneute iob diag output:
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-2-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     13:14:43 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2024-11-08 13:14:43 CET
               Universal time: Fri 2024-11-08 12:14:43 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    svaggy
    HOME=/home/svaggy
    GROUPS=svaggy adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            4.3G        1.7G        2.2G        114K        468M        2.6G
    Swap:           536M          0B        536M
    Total:          4.8G        1.7G        2.7G
    Active iob-Instances:   25
             4096 M total memory
             1599 M used memory
             1576 M active memory
              321 M inactive memory
             2049 M free memory
                0 M buffer memory
              446 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 13:14:44 up 4 min,  2 users,  load average: 0.46, 0.80, 0.49
    Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,   2048.3 free,   1601.2 used,    446.7 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2494.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       63G  5.1G   55G   9% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  108K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    493M    /var/
    251M    /var/cache
    247M    /var/cache/apt
    171M    /var/cache/apt/archives
    146M    /var/lib
    Archived and active journals take up 95.3M in the file system.
    /opt/iobroker/backups:
    62M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    945M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 196)
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 8080
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
    + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
    + system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.6
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "deconz"       : 1.4.1    , installed 1.4.1
    Adapter    "eusec"        : 1.3.3    , installed 1.3.3
    Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fhem"         : 3.0.0    , installed 3.0.0
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "homekit-controller": 0.5.10, installed 0.5.10
    Adapter    "hue"          : 3.12.0   , installed 3.12.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
    Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        10290
    States:         6704
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       5074162    1448/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5074157    1448/iobroker.js-co
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5066049    296/master
    tcp        0      0 192.168.2.250:9093      0.0.0.0:*               LISTEN      1000       5077678    1733/io.fakeroku.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5065778    1/init
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       5074725    1628/io.shelly.1
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5066050    296/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5078488    1808/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5075216    1466/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5065378    1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          5065780    1/init
    tcp6       0      0 :::61991                :::*                    LISTEN      1000       5077623    1718/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       5079643    1838/io.homekit-con
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       5074578    1583/io.shelly.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5078315    1763/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       5077679    1733/io.fakeroku.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5065779    1/init
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       5077624    1718/io.harmony.0
    udp6       0      0 :::1900                 :::*                                1000       5078317    1763/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1000       5078316    1763/io.deconz.0
    udp6       0      0 :::111                  :::*                                0          5065781    1/init
    2024-11-08 13:12:58.868  - info: vis.0 (1853) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
    2024-11-08 13:12:59.476  - info: vis.0 (1853) Terminated (NO_ERROR): Without reason
    2024-11-08 13:13:00.002  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
    2024-11-08 13:13:01.400  - warn: homekit-controller.0 (1838) IP-58:03:3A:5D:47:0C Could not initialize device: connect EHOSTUNREACH 192.168.2.88:60274 Error: connect EHOSTUNREACH 192.168.2.88:60274
        at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1607:16)
    2024-11-08 13:13:02.491  - info: host.iobroker instance system.adapter.maxcul.0 in version "1.3.1" started with pid 1868
    2024-11-08 13:13:03.119  - info: maxcul.0 (1868) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.18.0, js-controller: 6.0.11
    2024-11-08 13:13:03.215  - info: maxcul.0 (1868) using serial device /dev/ttyACM0@38400
    2024-11-08 13:13:03.221  - info: maxcul.0 (1868) serialPort /dev/ttyACM0 is open!
    2024-11-08 13:13:03.224  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
    2024-11-08 13:13:03.228  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
    2024-11-08 13:13:03.229  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f7d"
    2024-11-08 13:13:04.622  - info: homekit-controller.0 (1838) IP-66:7A:54:63:50:00 (eufy HomeBase2-0F53) found without pairing data but available for pairing: Create basic objects
    2024-11-08 13:13:04.792  - warn: homekit-controller.0 (1838) IP-D2:B6:84:EF:1D:70 Could not initialize device: connect EHOSTUNREACH 192.168.2.65:61818 Error: connect EHOSTUNREACH 192.168.2.65:61818
    2024-11-08 13:13:05.224  - info: maxcul.0 (1868) CUL FW Version: V 1.66_nocredits CUL868
    2024-11-08 13:13:06.255  - info: host.iobroker instance system.adapter.iot.0 in version "3.3.0" started with pid 1883
    2024-11-08 13:13:07.061  - info: iot.0 (1883) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.0, js-controller: 6.0.11
    2024-11-08 13:13:07.099  - info: iot.0 (1883) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2024-11-08 13:13:07.679  - info: iot.0 (1883) Connection changed: connect "xxxxx_gmail_com"
    2024-11-08 13:13:07.784  - info: alexa2.0 (1643) Initialization Done ...
    2024-11-08 13:13:45.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
    2024-11-08 13:13:50.750  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
    2024-11-08 13:13:55.751  - info: maxcul.0 (1868) deviceRequestTimeInformation: "076f5e"
    2024-11-08 13:15:00.209  - error: host.iobroker cannot call visUtils: Not exists
    iob diag has finished.
    Press any key for a summary
    ====================== SUMMARY =======================
    v.2024-10-19
    Virtualization: lxc
    Installation: lxc
    Kernel: x86_64
    Userland: 64 bit
    Timezone: Europe/Berlin (CET, +0100)
    User-ID: 1001
    Boot Target: multi-user.target
    Pending OS-Updates: 0
    Pending iob updates: 0
    Nodejs-Installation:
    /usr/bin/npm 10.8.2
    /usr/bin/npx 10.8.2
    Recommended versions are nodejs 20.18.0 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    total used free shared buff/cache available
    Mem: 4.3G 1.8G 2.1G 114K 470M 2.5G
    Swap: 536M 0B 536M
    Total: 4.8G 1.8G 2.6G
    ioBroker Core: js-controller 6.0.11
    admin 7.1.5
    ioBroker Status: iobroker is running on this host.
    Objects type: jsonl
    States type: jsonl
    • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 10290
    States: 6704
    Size of iob-Database:
    31M /opt/iobroker/iobroker-data/objects.jsonl
    2.8M /opt/iobroker/iobroker-data/states.jsonl
    @svaggy sagte in Skript funktionieren nicht nach Neustart:
    Aber jetzt ist die Ausgangsbasis eine andere.
    Objects: 10290
    States: 6704
    sieht schon mal anders aus.
    SvaggyS 1 Antwort Letzte Antwort
      Objects: 10290
      States: 6704
      SvaggyS Offline
      SvaggyS Offline
      Svaggy
      Habt ihr noch Ideen, was ich machen kann/ probieren sollte?
      Ro75R 1 Antwort Letzte Antwort
      • SvaggyS Svaggy
        Ro75R Offline
        Ro75R Offline
        Ro75
        @svaggy auf welcher Logstufe steht der JS-Adapter?
        Ro75.
        • Ro75R Ro75
          Ro75.
          SvaggyS Offline
          SvaggyS Offline
          Svaggy
          @ro75 Meinst du die Protokollebene? Die steht auf "info"
          • SvaggyS Svaggy
            Ro75R Offline
            Ro75R Offline
            Ro75
            @svaggy OK. Was taucht denn im Log nach einem Neustart vom Docker-Container bzgl. JS/JS-Adapter auf. Alos bei mir kommen auf alle Fälle ne Menge an Einträgen. Jeder Start eines Skriptes wird dokumentiert. Also, wie sieht es bei dir konkret aus?
            Ro75.
            • Ro75R Ro75
              Ro75.
              SvaggyS Offline
              SvaggyS Offline
              Svaggy
              @ro75
              Wenn ich die "Testinstanz" starte kommt das. Hierbei auch der untenstehende Fehler:
              javascript.1
              2024-11-08 18:24:21.401 error Cannot find view "script" for search "javascript"
              javascript.1
              2024-11-08 18:24:21.346 info received all objects
              javascript.1
              2024-11-08 18:24:21.124 info received all states
              javascript.1
              2024-11-08 18:24:20.698 info requesting all objects
              javascript.1
              2024-11-08 18:24:20.697 info requesting all states
              javascript.1
              2024-11-08 18:24:20.401 info starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
              Ro75R Thomas BraunT 2 Antworten Letzte Antwort
              • SvaggyS Svaggy
                @ro75
                javascript.1
                javascript.1
                javascript.1
                javascript.1
                javascript.1
                javascript.1
                Ro75R Offline
                Ro75R Offline
                Ro75
                @svaggy bitte den Container neu starten lassen und dann das gesamte Log mal rein.
                Ro75.
                • SvaggyS Svaggy
                  @ro75
                  javascript.1
                  javascript.1
                  javascript.1
                  javascript.1
                  javascript.1
                  javascript.1
                  @svaggy
                  Das Log am besten aus
                  iob logs
                  nehmen und in CodeTags posten. Das ist besser formatiert und chronologisch sortiert.
                    @svaggy
                    iob logs
                    SvaggyS Offline
                    SvaggyS Offline
                    Svaggy
                    Bekomme den log hier nicht rein iob logs ist zeitlich abgeschnitten und für ein Reinkopieren hat er zu viel Zeichen..
                    • SvaggyS Svaggy
                      Nein, das ist eben nicht abgeschnitten, das ist immer das volle log seit 0 Uhr.
                      Es interessiert aber eh im Moment nur der Neustart des adapters.
                        SvaggyS Offline
                        SvaggyS Offline
                        Svaggy
                        Reicht das?
                        2024-11-08 19:06:51.057  - info: host.iobroker "system.adapter.javascript.1" disabled
                        2024-11-08 19:06:51.057  - info: host.iobroker stopInstance system.adapter.javascript.1 (force=false, process=true)
                        2024-11-08 19:06:51.060  - info: javascript.1 (2032) Got terminate signal TERMINATE_YOURSELF
                        2024-11-08 19:06:51.062  - info: javascript.1 (2032) terminating
                        2024-11-08 19:06:51.063  - info: javascript.1 (2032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-11-08 19:06:51.100  - info: host.iobroker stopInstance system.adapter.javascript.1 send kill signal
                        2024-11-08 19:06:51.561  - info: javascript.1 (2032) terminating
                        2024-11-08 19:06:51.599  - info: host.iobroker instance system.adapter.javascript.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-11-08 19:06:52.309  - info: host.iobroker "system.adapter.javascript.1" enabled
                        2024-11-08 19:06:52.582  - info: host.iobroker instance system.adapter.javascript.1 in version "8.8.3" started with pid 2047
                        2024-11-08 19:06:53.565  - info: javascript.1 (2047) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                        2024-11-08 19:06:53.810  - info: javascript.1 (2047) requesting all states
                        2024-11-08 19:06:53.811  - info: javascript.1 (2047) requesting all objects
                        2024-11-08 19:06:54.226  - info: javascript.1 (2047) received all states
                        2024-11-08 19:06:54.442  - info: javascript.1 (2047) received all objects
                        2024-11-08 19:06:54.493  - error: javascript.1 (2047) Cannot find view "script" for search "javascript"
                        • SvaggyS Svaggy
                          Reicht das?
                          @svaggy
                          Und was ist mit javascript.0?
                          Warum überhaupt zwei Instanzen?
                            @svaggy
                            SvaggyS Offline
                            SvaggyS Offline
                            Svaggy
                            Zwei Instanzen, weil ich zum Probieren nicht immer wieder alle benötigten Skripte neustarten wollte ;-). Hier Instanz 0
                            2024-11-08 19:11:15.349  - info: host.iobroker "system.adapter.javascript.0" disabled
                            2024-11-08 19:11:15.349  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                            2024-11-08 19:11:15.351  - info: javascript.0 (348) Got terminate signal TERMINATE_YOURSELF
                            2024-11-08 19:11:15.354  - info: javascript.0 (348) terminating
                            2024-11-08 19:11:15.354  - info: javascript.0 (348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-11-08 19:11:15.392  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
                            2024-11-08 19:11:15.853  - info: javascript.0 (348) terminating
                            2024-11-08 19:11:15.886  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-11-08 19:11:18.596  - info: host.iobroker "system.adapter.javascript.0" enabled
                            2024-11-08 19:11:18.865  - info: host.iobroker instance system.adapter.javascript.0 in version "8.8.3" started with pid 2081
                            2024-11-08 19:11:19.820  - info: javascript.0 (2081) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
                            2024-11-08 19:11:20.060  - info: javascript.0 (2081) requesting all states
                            2024-11-08 19:11:20.061  - info: javascript.0 (2081) requesting all objects
                            2024-11-08 19:11:20.680  - info: javascript.0 (2081) received all objects
                            2024-11-08 19:11:20.682  - info: javascript.0 (2081) received all states
                            2024-11-08 19:11:20.748  - error: javascript.0 (2081) Cannot find view "script" for search "javascript"
                            • SvaggyS Svaggy
                              Ro75R Offline
                              Ro75R Offline
                              Ro75
                              @svaggy zeig mal bitte bildlich deine Skripte / Blockly's
                              Ro75.
                              • Ro75R Ro75
                                Ro75.
                                SvaggyS Offline
                                SvaggyS Offline
                                Svaggy
                                @ro75
                                Ganz oben habe ich doch ein super simples aus der Instanz 1 gezeigt, was nicht funktioniert
                                Hier was größeres aus der Instanz 0
                                • SvaggyS Svaggy
                                  @ro75
                                  Ro75R Offline
                                  Ro75R Offline
                                  Ro75
                                  @svaggy das meinte ich nicht. Eher so:
                                  Ro75.
                                  • Ro75R Ro75
                                    Ro75.
                                    SvaggyS Offline
                                    SvaggyS Offline
                                    Svaggy
                                    @ro75 Ah.. :-)
                                    • SvaggyS Svaggy
                                      ich habe das Problem, dass meine Blockly Skripte nach einem Neustart nicht funktionieren.
                                      Hierbei scheint es bereits auszureichen, wenn die Javaskript Instanz neugestartet wird. Die Skripte werden alle als laufend angezeigt, funktionieren jedoch nicht. Erst ein manuelles Neustarten der Skripte lässt diese wieder arbeiten.
                                      Was kann hierfür die Ursache sein?
                                      Hardware/ SW Infos:
                                      NUK
                                      Proxmox
                                      iobroker im lxc container
                                      Grüße,
                                      Sven
                                      crunchipC Offline
                                      crunchipC Offline
                                      nach einem Neustart
                                      nur ein einfacher Neustart, oder vllt doch das ein odere andere Update gemacht?
                                      mach mal im terminal ein
                                      iob upload all
                                        nach einem Neustart
                                        iob upload all
                                        SvaggyS Offline
                                        SvaggyS Offline
                                        Svaggy
                                        @crunchip
                                        Yeah :-) Das hat´s gebracht!! Vielen Dank!!
                                        Kannst du mir noch sagen, was der Befehl gemacht hat/ wo mein Problem war?
                                        • crunchipC Offline
                                          crunchipC Offline
                                          @svaggy wahrscheinlich sind Pakete beim upgrade irgendwo auf der Strecke geblieben und mit diesem Befehl nochmals neu hochgeladen...vereinfacht ausgedrückt
