  4. Test Adapter iobroker.Zigbee 1.10.10
190 Beiträge 19 Kommentatoren 48.8k Aufrufe 23 Beobachtet
  • R Ritter
    @asgothian Nach nochmaliger Installation deiner Version und Neueintrag der Lampe kommen wieder Log Daten:
    zigbee.0
    2024-10-21 19:18:39.088	warn	ELEVATED: convert state, "ON", {} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:39.086	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 19:18:39.075	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:39.025	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":true,"ack":false,"ts":1729531119023,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531119023}
    zigbee.0
    2024-10-21 19:18:35.434	warn	ELEVATED: convert state, "OFF", {} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:35.431	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 19:18:35.423	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:35.368	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":false,"ack":false,"ts":1729531115360,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531115360}
    zigbee.0
    2024-10-21 19:18:29.740	warn	ELEVATED: convert state, "ON", {} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:29.737	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 19:18:29.727	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:29.672	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":true,"ack":false,"ts":1729531109664,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531109664}
    zigbee.0
    2024-10-21 19:18:25.567	warn	ELEVATED: convert color_temp, 228, {"brightness":39,"transition":0} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:25.567	warn	ELEVATED: Setting' converter to converter with key(s)'["color_temp","color_temp_percent"]}
    zigbee.0
    2024-10-21 19:18:25.564	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:25.512	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":228,"ack":false,"ts":1729531105509,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531105509}
    zigbee.0
    2024-10-21 19:18:19.326	warn	ELEVATED: convert brightness, 99, {"brightness":99,"transition":0} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:19.323	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 19:18:19.315	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:19.266	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":39,"ack":false,"ts":1729531099263,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531099263}
    zigbee.0
    2024-10-21 19:18:15.036	warn	ELEVATED: convert effect, "stop_effect", {} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:15.035	warn	ELEVATED: Setting' converter to converter with key(s)'["effect","alert","flash"]}
    zigbee.0
    2024-10-21 19:18:15.023	warn	ELEVATED Change state 'effect' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:14.970	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.effect {"val":"stop_effect","ack":false,"ts":1729531094962,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531094962}
    zigbee.0
    2024-10-21 19:18:10.892	warn	ELEVATED: convert effect, "blink", {} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:10.891	warn	ELEVATED: Setting' converter to converter with key(s)'["effect","alert","flash"]}
    zigbee.0
    2024-10-21 19:18:10.883	warn	ELEVATED Change state 'effect' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:10.826	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.effect {"val":"blink","ack":false,"ts":1729531090818,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531090818}
    zigbee.0
    2024-10-21 19:18:06.308	warn	ELEVATED: convert state, "OFF", {} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:06.306	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 19:18:06.299	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:06.251	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":false,"ack":false,"ts":1729531086248,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531086248}
    zigbee.0
    2024-10-21 19:18:04.448	warn	ELEVATED: convert color_temp, 481, {"brightness":13,"transition":0} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:04.447	warn	ELEVATED: Setting' converter to converter with key(s)'["color_temp","color_temp_percent"]}
    zigbee.0
    2024-10-21 19:18:04.442	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:04.392	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":481,"ack":false,"ts":1729531084389,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531084389}
    zigbee.0
    2024-10-21 19:18:02.706	warn	ELEVATED: convert brightness, 33, {"brightness":33,"transition":0} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:18:02.703	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 19:18:02.695	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:18:02.638	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":13,"ack":false,"ts":1729531082629,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729531082629}
    zigbee.0
    2024-10-21 19:17:37.394	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-21 19:17:37.394	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:17:37.386	warn	ELEVATED: Zigbee Event of Type commandQueryNextImageRequest from device "0x943469fffe55fc9e", incoming event: {"type":"commandQueryNextImageRequest","device":"0x943469fffe55fc9e","endpoint":1,"data":{"fieldControl":1,"manufacturerCode":4476,"imageType":8709,"fileVersion":65554},"linkquality":76,"groupID":0,"cluster":"genOta"}
    zigbee.0
    2024-10-21 19:17:34.478	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-21 19:17:34.478	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:17:34.435	warn	ELEVATED: Zigbee Event of Type commandQueryNextImageRequest from device "0x943469fffe55fc9e", incoming event: {"type":"commandQueryNextImageRequest","device":"0x943469fffe55fc9e","endpoint":1,"data":{"fieldControl":1,"manufacturerCode":4476,"imageType":8709,"fileVersion":65554},"linkquality":76,"groupID":0,"cluster":"genOta"}
    zigbee.0
    2024-10-21 19:17:31.413	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-21 19:17:31.413	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:17:31.396	warn	ELEVATED: Zigbee Event of Type commandQueryNextImageRequest from device "0x943469fffe55fc9e", incoming event: {"type":"commandQueryNextImageRequest","device":"0x943469fffe55fc9e","endpoint":1,"data":{"fieldControl":1,"manufacturerCode":4476,"imageType":8709,"fileVersion":65554},"linkquality":76,"groupID":0,"cluster":"genOta"}
    zigbee.0
    2024-10-21 19:17:28.396	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-21 19:17:28.396	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:17:28.391	warn	ELEVATED: Zigbee Event of Type commandQueryNextImageRequest from device "0x943469fffe55fc9e", incoming event: {"type":"commandQueryNextImageRequest","device":"0x943469fffe55fc9e","endpoint":1,"data":{"fieldControl":1,"manufacturerCode":4476,"imageType":8709,"fileVersion":65554},"linkquality":76,"groupID":0,"cluster":"genOta"}
    zigbee.0
    2024-10-21 19:17:25.418	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-21 19:17:25.418	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:17:25.401	warn	ELEVATED: Zigbee Event of Type commandQueryNextImageRequest from device "0x943469fffe55fc9e", incoming event: {"type":"commandQueryNextImageRequest","device":"0x943469fffe55fc9e","endpoint":1,"data":{"fieldControl":1,"manufacturerCode":4476,"imageType":8709,"fileVersion":65554},"linkquality":76,"groupID":0,"cluster":"genOta"}
    zigbee.0
    2024-10-21 19:16:04.068	warn	ELEVATED: convert state, "ON", {} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:16:04.067	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 19:16:04.064	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:16:03.840	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":true,"ack":false,"ts":1729530963838,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729530963838}
    zigbee.0
    2024-10-21 19:16:02.765	warn	ELEVATED: convert color_temp, 383, {"brightness":91,"transition":0} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:16:02.764	warn	ELEVATED: Setting' converter to converter with key(s)'["color_temp","color_temp_percent"]}
    zigbee.0
    2024-10-21 19:16:02.760	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:16:02.696	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":383,"ack":false,"ts":1729530962687,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729530962687}
    zigbee.0
    2024-10-21 19:16:02.088	warn	ELEVATED: convert brightness, 231, {"brightness":231,"transition":0} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:16:02.082	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 19:16:02.075	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:16:02.023	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":91,"ack":false,"ts":1729530962015,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729530962015}
    zigbee.0
    2024-10-21 19:14:35.002	warn	ELEVATED: convert brightness, 83, {"brightness":83,"transition":0} for device 0x943469fffe55fc9e
    zigbee.0
    2024-10-21 19:14:34.998	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 19:14:34.987	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:14:34.933	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":33,"ack":false,"ts":1729530874925,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729530874925}
    zigbee.0
    2024-10-21 19:13:36.323	warn	ELEVATED publishToState: value generated '10' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-21 19:13:36.323	warn	ELEVATED publishToState: message received '{"linkquality":10}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:13:36.323	warn	ELEVATED publishToState: value generated 'true' from device 943469fffe55fc9e for 'Available'
    zigbee.0
    2024-10-21 19:13:36.323	warn	ELEVATED publishToState: message received '{"available":true}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-21 19:13:35.321	info	Device '0x385b44fffe9a79c2' announced itself
    zigbee.0
    2024-10-21 19:13:35.318	info	Device '0x187a3efffe6ddf74' announced itself
    zigbee.0
    2024-10-21 19:13:35.314	info	Device '0x943469fffe55fc9e' announced itself
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @ritter Da kommen einige Meldungen - die entscheidenden bleiben aber weiter aus.
    ein identischer Schaltversuch bei mir mit einer identischen Version sieht so aus:
    zigbee.0
    2024-10-21 21:08:49.341	warn	ELEVATED: convert result {"state":{"state":"OFF"},"readAfterWriteTime":0} for device 0x0017880109bab68f
    zigbee.0
    2024-10-21 21:08:49.285	warn	ELEVATED: convert state, "OFF", {} for device 0x0017880109bab68f
    zigbee.0
    2024-10-21 21:08:49.283	warn	ELEVATED: Setting' converter to converter with key(s)'["state","brightness","brightness_percent","on_time"]}
    zigbee.0
    2024-10-21 21:08:49.278	warn	ELEVATED Change state 'state' at device 0x0017880109bab68f type '8718699703424'
    Der Unterschied sollte offensichtlich sein. Der Inhalt vergleichbar.
    Ich verstehe es nicht, da die weiteren Meldungen eigentlich alle über entsprechenden Code abgesichert sind. Kannst du bitte mal die Zeilen 624 bis 824 von der Date /opt/iobroker/node-modules/iobroker.zigbee/main.js hier posten (in code tags, und ggf. hinter einem Spoiler ?
    Auch: könnt ihr bitte prüfen ob sich mit der 1.10.10 Geräte löschen und neu anlernen lassen ?
    A.
    R 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      A.
      Ritter
      @asgothian mainjs.txt
        @ritter gibt es irgend welche Fehlermeldungen innerhalb von 60 Sekunden ab dem Versuch etwas zu schalten ?
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @asgothian
        Bekannte Fehler in der 1.10.10 - in Arbeit
        • Geräte löschen geht nicht - fix found
        • Darstellung der Gruppenmitglieder geht nicht - fix found
        • Geräte aus Gruppen entfernen geht nicht - fix found
        • Veränderungen an Shepherd.db und nvbackup.json verhindern ein downgrade auf 1.10.3
        • Channel scan geht nicht
        Bekannt gelöste Dinge
        • responsive design mit admin 7.2.6
        Unklare Situationen:
        • bei @ritter lassen sich Geräte nicht schalten - das kann ich aktuell nicht nachstellen
        Ich brauche deutlich mehr Tester um dem auf de Grund zu gehen.
        A.
        arteckA AsgothianA 2 Antworten Letzte Antwort
          @asgothian
          A.
          arteckA Offline
          arteckA Offline
          arteck
          @asgothian ich bin heute ab 15 uhr.. sollen wir in Discord ne session starten ?
          • arteckA arteck
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @arteck können wir versuchen. Ich kann nicht versprechen wie gut das geht.
              @asgothian
              A.
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              Stand heute gibt es eine neue Variante 1.10.10:
              • Geräte löschen: Fixed
              • Gruppen löschen: Fixed
              • Darstellung der Gruppenmitglieder: Fixed
              • Geräte aus Gruppen entfernen: Fixed
              • Responsive Design für Admin 7.2.6 oder neuer: Fixed
              • Vorbereitung für JS Controller 7: Angefangen - nicht vollständig
              • ChannelScan: Immer noch defunct - führt aber nicht mehr zum Absturz
              Bitte testen !
              @arteck: Ich hab versucht die Umstellung von deleteState auf delObject durchzuführen, bin aber gegen eine Wand gelaufen - da bräuchte ich nochmal Hilfe. Ansonsten sollten wir die Versionsnummer auf 1.11.0 hochziehen sobald wir JS Controller 7 Kompatibel sind.
              ? 2 Antworten Letzte Antwort
                Bitte testen !
                @asgothian @arteck
                euch beiden schonmal vielen lieben Dank !!
                Bevor ich hier die aktuelle Git version ziehe, um es in Prod. zu testen, was genau ist nicht kompatibel zu Admin 7? (geht es "nur" um resp.Design? oder was mit der json-konfig?)
                Genau der ist hier im prod. recht stable..
                  @asgothian @arteck
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @ilovegym sagte in Test Adapter iobroker.Zigbee 1.10.10:
                  Denkfehler - es geht um JS Controller 7, nicht Admin 7. Ich passe den Post an.
                  Ich hab Probleme alle Aufrufe von deleteState sauber auf DelObject umzustellen.
                  Admin 7.2.6 läuft ohne Probleme.
                  Ob wir auf json-config umstellen oder nicht ist noch unklar - ich denke das hat noch weiter reichende Implikationen.
                  A.
                    A.
                    @asgothian
                    ah, danke, ja, den js-controller 7.0.1 hab ich hier auch installiert, ja, da hatte ich mal was gelesen im log mit "in future unsupported" das wird das deleteState gewesen sein..
                    Solange json-config kein Zwang ist, ist doch alles gut.. und immer der Reihe nach, erstmal das eine..
                      Bitte testen !
                      @asgothian
                      aktuelle Version 1.10.10 von Git vom 26.10.24 11:00 Uhr laeuft hier einwandfrei, mit Admin 7.2.6, js-controller 7.0.1 ( hab noch keine devices geloescht ).
                      Adapter start unauffaellig, Werte kommen von ueberall rein, Leuchten lassen sich steuern, ohne Fehlermeldungen.
                      Alles gut im Moment..
                        @asgothian
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @ilovegym kannst du bitte die beiden folgenden Tests durchführen ?
                        • eine Gruppe anlegen, dieser ein Gerät zuordnen, dann die Gruppe löschen ?
                        • einen Gerätetyp der "Exclude-Liste" hinzufügen und dann aus der Liste wieder löschen ?
                        Beide Tests sollten keinen Einfluss auf die genutzten Geräte haben.
                        A
                          A
                          @asgothian
                          Gruppen:
                          Gruppe anlegen funktioniert, (hatte vorher keine), habe dann 2 Gruppen angelegt mit verschiedenen Namen.
                          Dann beiden Gruppen jeweils 2 Geraete zugeordnet.
                          Dann in einer Gruppe erstmal ein Geraet geloescht, geht auch.
                          Dann in der anderen Gruppe, in der noch 2 Geraete waren, die Gruppe geloescht.
                          Ging auch, alles ohne Fehler.
                          Im Objektbaum wird allerdings nur der Name der Gruppe geloescht, die hat jetzt keinen Namen mehr, und keine Devices, weil diese ja eigentlich nicht mehr da sein sollte.
                          Die zweite Gruppe exestiert und funktioniert auch noch.
                            A
                            @asgothian
                            Exclude Liste:
                            Habe ich mit einem Taster https://www.zigbee2mqtt.io/devices/WXKG01LM.html gemacht, ging, ohne Probleme, wie du beschrieben hast.
                            Keine Fehler im Log.
                            Edit:
                            vorgehensweise:
                            Device in Exclude hinzugefuegt, Adapter gestoppt, 60sek gewartet, Adapter gestartet.
                            Taster getestet, ob Datenpunkte angelegt werden oder sich etwas aendert.
                            Hat sich bei diesem Device nicht.
                            Device aus Exclude Liste entfernt, Adapter gestoppt, gewartet und neu gestartet.
                            Funktioniert noch wie gehabt.
                              @asgothian
                              Gruppen:
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @asgothian
                              Ok - das muss ich mir anschauen, das muss aus dem Wechsel deleteDevice / delObject kommen. Wird noch gefixed.
                              Danke für die ausführliche Beschreibung
                              A.
                                @asgothian
                                A.
                                #66
                                @asgothian sagte in Test Adapter iobroker.Zigbee 1.10.10:
                                n
                                gerne !
                                Hatte gerade gestern mal wieder ein User, der ganz dringend 3.rd line support brauchte.. war wohl keiner von den anderen mehr da.. und ich musste mal wieder dran glauben.. :)
                                " if I shut down the machine, it's not working anymore.. if it's up, it's fine.."
                                Finde den Fehler.. ;)
                                • H Offline
                                  hahne
                                  #67
                                  Moin,
                                  hab`s auch mal getestet.
                                  System:
                                  • js-controller: 7.0.1
                                  • coordinator: CC2652P
                                  • version: 2-1.2.7.1.
                                  • revision: 20240710
                                  • type: zStack3x0
                                  Alle Geräte lassen sich Steuern, keine Auffälligkeiten.
                                  Gruppen lassen sich erstellen, löschen und belegen.
                                  Nur das selbe verhalten wie bei @ilovegym das die Ordner der gelöschten Gruppen übrig bleiben.
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #68
                                    ich hab das Gruppen löschen korrigert
                                    ich machmal eine 1.10.11
                                    bekannte Bugs :
                                    ChannelScan - geht noch nicht
                                    ? haselchenH 2 Antworten Letzte Antwort
                                    • arteckA arteck
                                      bekannte Bugs :
                                      #69
                                      @arteck
                                      Danke, laeuft bei mir ( lxc bookworm, js-controller 7.0.2, admin 7.2.6, Zigbee 1.10.11 )
                                      Gruppe Loeschen - geht wieder
                                      Keine weiteren Auffaelligkeiten. Gesamt 247 Devices.
                                      • arteckA arteck
                                        bekannte Bugs :
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #70
                                        @arteck
                                        "Kleiner" Schönheitsfehler. (1.10.11)
                                        Im Reiter links wird die GUI auf Englisch aufgerufen.
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #71
                                          ups zu viel aufgeräumt
