  4. Updateschwierigkeiten js-controller 4.0.23
33 Beiträge 4 Kommentatoren 5.9k Aufrufe 6 Beobachtet
  • F Flowski
    @thomas-braun heißt jetzt für Dummies? Sorry aber bin mit den Befehlen noch nicht ganz fit
    @flowski
    iob stop
    sudo reboot
    Wenn die Kiste wieder erreichbar ist
    iob update
    iob upgrade all -y
    • F Offline
      Flowski
      @thomas-braun danke für deinen support, jetzt erscheint folgendes im Terminal:
      fabio@IoBroker:/home/pi $ iob stop
      fabio@IoBroker:/home/pi $ sudo reboot
      [sudo] password for fabio:
      Connection to 192.168.178.46 closed by remote host.
      Connection to 192.168.178.46 closed.
      PS C:\Users\mulla> ssh pi@192.168.178.46
      pi@192.168.178.46's password:
      Linux IoBroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
      permitted by applicable law.
      Last login: Tue Oct  8 20:04:34 2024 from 192.168.178.131
      Wi-Fi is currently blocked by rfkill.
      Use raspi-config to set the country before use.
      pi@IoBroker:~ $ iob update
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.0.22 [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.22   , installed 2.10.11 [Updatable]
      Adapter    "daikin-cloud" : 0.4.8    , installed 0.3.0  [Updatable]
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
      Adapter    "hm-rpc"       : 2.0.2    , installed 1.16.0 [Updatable]
      Adapter    "homeconnect"  : 1.4.1    , installed 1.3.0  [Updatable]
      Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
      Controller "js-controller": 6.0.11   , installed 4.0.23 [Updatable]
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 4.2.0    , installed 3.8.6  [Updatable]
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 2.0.0    , installed 1.6.3  [Updatable]
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.0.3  [Updatable]
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.1.0  [Updatable]
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
      Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
      Adapter    "yeelight-2"   : 1.4.0    , installed 1.2.1  [Updatable]
      Adapter    "zigbee"       : 1.10.3   , installed 1.8.10 [Updatable]
      pi@IoBroker:~ $ cu fabio
      -bash: cu: command not found
      pi@IoBroker:~ $ ssh fabio@192.168.178.46
      The authenticity of host '192.168.178.46 (192.168.178.46)' can't be established.
      ECDSA key fingerprint is SHA256:FIhsIFzSsCA3qcV8rP3HPxSWGbgQ71sBXmHraXwu1t0.
      Are you sure you want to continue connecting (yes/no/[fingerprint])? n
      Please type 'yes', 'no' or the fingerprint: no
      Host key verification failed.
      pi@IoBroker:~ $ su fabio
      Password:
      fabio@IoBroker:/home/pi $ iob update
      fabio@IoBroker:/home/pi $ iob upgrade all -y
      Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.19
      Update hm-rega from @4.0.0 to @5.0.0
      NPM version: 10.8.2
      Installing iobroker.hm-rega@5.0.0... (System call)
      added 2 packages, removed 399 packages, and changed 2 packages in 16s
      131 packages are looking for funding
        run `npm fund` for details
      Update "system.adapter.hm-rega.0"
      upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
      upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
      upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
      upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
      Update discovery from @4.5.0 to @5.0.0
      NPM version: 10.8.2
      Installing iobroker.discovery@5.0.0... (System call)
      changed 1 package in 11s
      Update "system.adapter.discovery.0"
      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      Update admin from @7.0.22 to @7.1.5
      host.IoBroker Adapter "system.adapter.admin.0" is stopped.
      NPM version: 10.8.2
      Installing iobroker.admin@7.1.5... (System call)
      added 11 packages, removed 3 packages, and changed 11 packages in 21s
      Update "system.adapter.admin.0"
      upload [68] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      host.IoBroker Adapter "system.adapter.admin.0" is started
      Update zigbee from @1.8.10 to @1.10.3
      host.IoBroker Adapter "system.adapter.zigbee.0" is stopped.
      NPM version: 10.8.2
      Installing iobroker.zigbee@1.10.3... (System call)
      added 18 packages, removed 19 packages, and changed 24 packages in 33s
      120 packages are looking for funding
      Update "system.adapter.zigbee.0"
      upload [331] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
      upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/E2213.png img/E2213.png image/png
      upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
      upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue-smart-button.png img/hue-smart-button.png image/png
      upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
      upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_fuzo_outdoor_wall_light.png img/philips_fuzo_outdoor_wall_light.png image/png
      upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_4.png img/philips_hue_argenta_4.png image/png
      upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_ambiance.png img/philips_hue_gu10_ambiance.png image/png
      upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
      upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/previous_track.png img/previous_track.png image/png
      upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
      upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
      upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
      upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
      upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
      upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
      upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
      upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
      upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
      upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
      upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
      upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
      upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
      upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
      upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
      upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
      upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
      upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
      upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
      upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
      upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
      upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
      upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
      upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
      host.IoBroker Adapter "system.adapter.zigbee.0" is started
      Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.0
      • F Flowski
        Password:
        NPM version: 10.8.2
        NPM version: 10.8.2
        NPM version: 10.8.2
        NPM version: 10.8.2
        @flowski sagte in Updateschwierigkeiten js-controller 4.0.23:
        Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users.
        Den Fingerpring für den fabio musst du schon akzeptieren, damit das funktioniert.
        Und warum hast du nicht gleich den 'pi' verwendet, wenn es denn doch schon gab?
        iob stop
        iob ugrade self
        iob upgrade all -y
        • F Offline
          Flowski
          schrieb am zuletzt editiert von Flowski
          puh ok 🤕 :)
          heisst ssh fabio@192.168.178.46
          dann ecdsa key ... mit yes
          Zitat:
          Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users. sorry stehe auf dem Schlauch :( muss da sicherlich noch was umstellen bevor ich die drei Befehle eingebe aber begreife es grad nicht
          • F Flowski
            puh ok 🤕 :)
            @flowski
            Jeder user hat auf einem Linux-System ein eigenes home-Verzeichnis, indem die eigenen Dateien abgelegt werden.
            F 1 Antwort Letzte Antwort
              @flowski
              Flowski
              @thomas-braun so: fabio@IoBroker:~ $?
              • F Flowski
                @flowski
                Ja. Die Tilde repräsentiert das home des users.
                  @flowski
                  Flowski
                  @thomas-braun anbei der log, iobroker ist jetzt aktuell nicht erreichbar im Browser.. brauchts jetzt nochmal ein iob reboot?
                  fabio@IoBroker:/home/pi $  ssh fabio@192.168.178.46
                  Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
                  Warning: Permanently added '192.168.178.46' (ECDSA) to the list of known hosts.
                  fabio@192.168.178.46's password:
                  fabio@IoBroker:~ $ iob stop
                  fabio@IoBroker:~ $ iob upgrade self
                  Update js-controller from @4.0.23 to @6.0.11
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 10.8.2
                  Installing iobroker.js-controller@6.0.11... (System call)
                  added 10 packages, removed 67 packages, and changed 44 packages in 52s
                  121 packages are looking for funding
                  fabio@IoBroker:~ $ iob upgrade all -y
                  Update yeelight-2 from @1.2.1 to @1.4.0
                  NPM version: 10.8.2
                  Installing iobroker.yeelight-2@1.4.0... (System call)
                  added 2 packages, removed 32 packages, and changed 5 packages in 12s
                  Update "system.adapter.yeelight-2.0"
                  upload [20] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/1.png icons/1.png image/png
                  upload [19] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/2.png icons/2.png image/png
                  upload [18] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/3.png icons/3.png image/png
                  upload [17] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/4.png icons/4.png image/png
                  upload [16] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/5.png icons/5.png image/png
                  upload [15] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/6.png icons/6.png image/png
                  upload [14] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/7.png icons/7.png image/png
                  upload [13] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/bslamp1.png icons/bslamp1.png image/png
                  upload [12] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling1.png icons/ceiling1.png image/png
                  upload [11] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling10.png icons/ceiling10.png image/png
                  upload [10] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling3.png icons/ceiling3.png image/png
                  upload [9] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling4.png icons/ceiling4.png image/png
                  upload [8] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/color.png icons/color.png image/png
                  upload [7] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/desklamp.png icons/desklamp.png image/png
                  upload [6] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/mono.png icons/mono.png image/png
                  upload [5] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/stripe.png icons/stripe.png image/png
                  upload [4] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index.html index.html text/html
                  upload [3] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index_m.html index_m.html text/html
                  upload [2] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/lan.jpg lan.jpg image/jpeg
                  upload [1] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/words.js words.js application/javascript
                  upload [0] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/yeelight.png yeelight.png image/png
                  Update whatsapp-cmb from @0.2.3 to @0.3.0
                  NPM version: 10.8.2
                  Installing iobroker.whatsapp-cmb@0.3.0... (System call)
                  changed 1 package in 8s
                  Update "system.adapter.whatsapp-cmb.0"
                  Update "system.adapter.whatsapp-cmb.1"
                  upload [17] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/admin.d.ts admin.d.ts video/mp2t
                  upload [16] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/blockly.js blockly.js application/javascript
                  upload [15] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [14] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [13] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [12] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [11] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [10] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [9] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [8] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [7] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [6] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [5] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [4] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/index_m.html index_m.html text/html
                  upload [3] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/style.css style.css text/css
                  upload [2] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/tsconfig.json tsconfig.json application/json
                  upload [1] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/whatsapp-cmb.png whatsapp-cmb.png image/png
                  upload [0] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/words.js words.js application/javascript
                  Update tuya from @3.15.0 to @3.16.0
                  NPM version: 10.8.2
                  Installing iobroker.tuya@3.16.0... (System call)
                  added 73 packages, removed 1 package, and changed 3 packages in 24s
                  124 packages are looking for funding
                  Update "system.adapter.tuya.0"
                  upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                  upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                  upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                  upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                  Update trashschedule from @3.2.0 to @3.3.0
                  NPM version: 10.8.2
                  Installing iobroker.trashschedule@3.3.0... (System call)
                  added 1 package, and changed 1 package in 9s
                  Update "system.adapter.trashschedule.0"
                  upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                  upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                  Update tankerkoenig from @3.1.0 to @3.4.0
                  host.IoBroker Adapter "system.adapter.tankerkoenig.0" is stopped.
                  NPM version: 10.8.2
                  Installing iobroker.tankerkoenig@3.4.0... (System call)
                  removed 1 package, and changed 1 package in 10s
                  Update "system.adapter.tankerkoenig.0"
                  upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
                  upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
                  upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                  upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
                  upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                  host.IoBroker Adapter "system.adapter.tankerkoenig.0" is started
                  Update sonoff from @3.0.3 to @3.1.2
                  NPM version: 10.8.2
                  Installing iobroker.sonoff@3.1.2... (System call)
                  Update "system.adapter.sonoff.0"
                  upload [15] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [14] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [13] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [12] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [11] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                  upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
                  upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
                  upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                  upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
                  Update mqtt-client from @1.6.3 to @2.0.0
                  NPM version: 10.8.2
                  Installing iobroker.mqtt-client@2.0.0... (System call)
                  added 15 packages, and changed 1 package in 10s
                  upload [13] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [12] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [11] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [10] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [9] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [8] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [7] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [6] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [5] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [4] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [3] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [2] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonConfig.json jsonConfig.json application/json
                  upload [1] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonCustom.json jsonCustom.json application/json
                  upload [0] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/mqtt-client.png mqtt-client.png image/png
                  Update mihome-vacuum from @3.8.6 to @4.2.0
                  NPM version: 10.8.2
                  Installing iobroker.mihome-vacuum@4.2.0... (System call)
                  added 3 packages, removed 4 packages, and changed 9 packages in 2m
                  Update "system.adapter.mihome-vacuum.0"
                  upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                  upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                  upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                  upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                  upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                  upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                  upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                  upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                  upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                  upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                  upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                  Update javascript from @7.8.0 to @8.8.3
                  NPM version: 10.8.2
                  Installing iobroker.javascript@8.8.3... (System call)
                  added 1 package, removed 1 package, and changed 6 packages in 1m
                  Update "system.adapter.javascript.0"
                  upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                  upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                  upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                  upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                  upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                  upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                  upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                  upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                  upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                  upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                  upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                  upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                  upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                  upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                  upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                  upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                  upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                  upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                  upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                  upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                  upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                  upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                  upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                  upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                  upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                  upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                  upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                  upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                  upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                  upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                  upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                  upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                  upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                  upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                  upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                  upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                  upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                  upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                  upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                  upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                  upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                  upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                  upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                  upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                  upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                  upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                  upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                  upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                  upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                  upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                  upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                  Update ical from @1.14.3 to @1.15.0
                  NPM version: 10.8.2
                  Installing iobroker.ical@1.15.0... (System call)
                  added 1 package, and changed 1 package in 11s
                  Update "system.adapter.ical.0"
                  upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                  upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                  upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                  upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                  Update homeconnect from @1.3.0 to @1.4.1
                  NPM version: 10.8.2
                  Installing iobroker.homeconnect@1.4.1... (System call)
                  added 1 package, and changed 2 packages in 16s
                  Update "system.adapter.homeconnect.0"
                  upload [15] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect-880x800.png homeconnect-880x800.png image/png
                  upload [14] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect.png homeconnect.png image/png
                  upload [13] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [12] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [11] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [10] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [9] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [8] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [7] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [6] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [5] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [4] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [3] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [2] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/index_m.html index_m.html text/html
                  upload [1] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/style.css style.css text/css
                  upload [0] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/words.js words.js application/javascript
                  Update hm-rpc from @1.16.0 to @2.0.2
                  NPM version: 10.8.2
                  Installing iobroker.hm-rpc@2.0.2... (System call)
                  added 1 package, and changed 2 packages in 10s
                  Update "system.adapter.hm-rpc.0"
                  Update "system.adapter.hm-rpc.1"
                  upload [279] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                  upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                  upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/157_hmip-broll_hmip-bbl_thumb.png icons/157_hmip-broll_hmip-bbl_thumb.png image/png
                  upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/202_hmip-wrcr_thumb_right.png icons/202_hmip-wrcr_thumb_right.png image/png
                  upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/3_hm-lc-sw4-sm_thumb.png icons/3_hm-lc-sw4-sm_thumb.png image/png
                  upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/50_hm-sec-mdir_thumb.png icons/50_hm-sec-mdir_thumb.png image/png
                  upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/58_hmw-sen-sc-12-fm_thumb.png icons/58_hmw-sen-sc-12-fm_thumb.png image/png
                  upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/68_hm-lc-sw4-dr_thumb.png icons/68_hm-lc-sw4-dr_thumb.png image/png
                  upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/78_hm-ou-led16_thumb.png icons/78_hm-ou-led16_thumb.png image/png
                  upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/86_hm-rc-sec4-2_thumb.png icons/86_hm-rc-sec4-2_thumb.png image/png
                  upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/98_hm-sec-sco_thumb.png icons/98_hm-sec-sco_thumb.png image/png
                  upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/HmIPW-FALMOT-C12.png icons/HmIPW-FALMOT-C12.png image/png
                  upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/group_hm-cc-vg-1.png icons/group_hm-cc-vg-1.png image/png
                  upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-cap-moist.png icons/hb-uni-sen-cap-moist.png image/png
                  upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
                  upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
                  upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
                  upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
                  upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
                  upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
                  upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
                  upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
                  upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
                  upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
                  upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
                  upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
                  upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
                  upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
                  upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
                  upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
                  upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
                  upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/jsonConfig.json jsonConfig.json application/json
                  upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
                  Update daikin-cloud from @0.3.0 to @0.4.8
                  NPM version: 10.8.2
                  Installing iobroker.daikin-cloud@0.4.8... (System call)
                  added 2 packages, removed 14 packages, and changed 4 packages in 11s
                  113 packages are looking for funding
                  Update "system.adapter.daikin-cloud.0"
                  upload [16] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                  upload [15] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                  upload [14] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
                  upload [13] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [12] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [11] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [10] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [9] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [8] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [7] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/jsonConfig.json jsonConfig.json application/json
                  upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                  upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                  Update backitup from @2.10.11 to @3.0.22
                  host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
                  NPM version: 10.8.2
                  Installing iobroker.backitup@3.0.22... (System call)
                  added 5 packages, and changed 20 packages in 17s
                  Update "system.adapter.backitup.0"
                  upload [90] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                  upload [80] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                  upload [70] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/main.0fac7bdb.js custom/static/js/main.0fac7bdb.js application/javascript
                  upload [60] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js application/javascript
                  upload [50] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js application/javascript
                  upload [40] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/googledrive.jsonConfig.json5 googledrive.jsonConfig.json5 application/json5
                  upload [30] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/main.jsonConfig.json5 main.jsonConfig.json5 application/json5
                  upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
                  upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
                  upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
                  upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
                  upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
                  upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
                  upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
                  upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
                  upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css static/css/main.bd1167d4.css text/css
                  upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/245.7caf1dae.chunk.js static/js/245.7caf1dae.chunk.js application/javascript
                  upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js static/js/main.2cca4954.js application/javascript
                  upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js.LICENSE.txt static/js/main.2cca4954.js.LICENSE.txt text/plain
                  upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/media/history.d21dcfa508bd8a624c85.png static/media/history.d21dcfa508bd8a624c85.png image/png
                  upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                  upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                  upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                  upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                  upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
                  upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                  upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
                  host.IoBroker Adapter "system.adapter.backitup.0" is started
                  fabio@IoBroker:~ $
                  • F Flowski
                    Linux IoBroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                    permitted by applicable law.
                    Wi-Fi is currently blocked by rfkill.
                    Use raspi-config to set the country before use.
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    fabio@IoBroker:~ $
                    @flowski
                    Was kommt bei einem
                    iob update
                    um's Eck?
                      @flowski
                      Was kommt bei einem
                      iob update
                      um's Eck?
                      Flowski
                      fabio@IoBroker:~ $ iob update
                      Used repository: stable
                      Adapter    "admin"        : 7.1.5    , installed 7.1.5
                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                      Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
                      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                      Adapter    "ham"          : 5.3.1    , installed 5.3.1
                      Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                      Adapter    "ical"         : 1.15.0   , installed 1.15.0
                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                      Controller "js-controller": 6.0.11   , installed 6.0.11
                      Adapter    "linux-control": 1.1.5    , installed 1.1.5
                      Adapter    "meross"       : 1.17.0   , installed 1.17.0
                      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                      Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
                      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                      Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                      fabio@IoBroker:~ $
                      • F Flowski
                        fabio@IoBroker:~ $
                        @flowski
                        Gut.
                        iob start admin
                        und die Kiste sollte wieder an den Start kommen.
                          @flowski
                          Gut.
                          iob start admin
                          Flowski
                          @thomas-braun bislang tut sich nix
                          fabio@IoBroker:~ $ iob start admin
                          fabio@IoBroker:~ $
                          • F Flowski
                            fabio@IoBroker:~ $
                            @flowski
                            iob diag
                              @flowski
                              iob diag
                              Flowski
                              bash
                              Skript v.2024-08-12
                              *** BASE SYSTEM ***
                                 Static hostname: IoBroker
                                       Icon name: computer
                                Operating System: Debian GNU/Linux 11 (bullseye)
                                          Kernel: Linux 6.1.21-v8+
                                    Architecture: arm64
                              OS is similar to:
                              Model           : Raspberry Pi 4 Model B Rev 1.2
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : 64 bit
                              Systemuptime and Load:
                               21:35:42 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                              CPU threads: 4
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              ~ Under-voltage has occurred
                              ~ Arm frequency capping has occurred
                              ~ Throttling has occurred
                              ~ Soft temperature limit has occurred
                              *** Time and Time Zones ***
                                             Local time: Tue 2024-10-08 21:35:42 CEST
                                         Universal time: Tue 2024-10-08 19:35:42 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              fabio
                              HOME=/home/fabio
                              GROUPS=fabio sudo iobroker
                              js-controller is not running
                              *** Display-Server-Setup ***
                              Display-Server: false
                              Desktop:
                              Terminal:       tty
                              Boot Target:    multi-user.target
                              *** MEMORY ***
                              Mem:            3.8G        107M        920M        1.0M        2.8G        3.6G
                              Swap:            99M          0B         99M
                              Total:          3.9G        107M        1.0G
                              Active iob-Instances:   1
                                       3794 M total memory
                                        107 M used memory
                                        213 M active memory
                                       2439 M inactive memory
                                        920 M free memory
                                         68 M buffer memory
                                       2698 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              top - 21:35:43 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                              Tasks: 162 total,   1 running, 161 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   3794.3 total,    919.3 free,    107.8 used,   2767.3 buff/cache
                              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3610.0 avail Mem
                              *** FAILED SERVICES ***
                                UNIT                LOAD   ACTIVE SUB    DESCRIPTION
                              * iobroker.service    loaded failed failed ioBroker Server
                              * pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
                              2 loaded units listed.
                              *** FILESYSTEM ***
                              /dev/root      ext4       59G  8.7G   48G  16% /
                              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                              tmpfs          tmpfs     759M  1.2M  758M   1% /run
                              /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
                              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                              tmpfs          tmpfs     380M     0  380M   0% /run/user/1002
                              [Tue Oct  8 20:46:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:83:48 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=2a0531f8-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Tue Oct  8 20:46:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Tue Oct  8 20:46:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              [Tue Oct  8 20:46:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              Show mounted filesystems:
                              TARGET  SOURCE         FSTYPE OPTIONS
                              /       /dev/mmcblk0p2 ext4   rw,noatime
                              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                              3.7G    /var/
                              2.1G    /var/log/journal/664a8e581ec84405863df59a10cf9293
                              2.1G    /var/log
                              817M    /var/lib
                              Archived and active journals take up 8.0M in the file system.
                              /opt/iobroker/backups:
                              58M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              913M    /opt/iobroker/iobroker-data/
                              840M    /opt/iobroker/iobroker-data/files
                              617M    /opt/iobroker/iobroker-data/files/javascript.admin
                              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                              27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                              16M     /opt/iobroker/iobroker-data/objects.jsonl
                              14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                              /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03D64S-if00-port0
                              Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v20.18.0
                              /usr/bin/node           v20.18.0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              /usr/bin/corepack       0.29.3
                              nodejs:
                                Installed: 20.18.0-1nodesource1
                                Candidate: 20.18.0-1nodesource1
                                Version table:
                               *** 20.18.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                   20.17.0-1nodesource1 1001
                                   20.16.0-1nodesource1 1001
                                   20.15.1-1nodesource1 1001
                                   20.15.0-1nodesource1 1001
                                   20.14.0-1nodesource1 1001
                                   20.13.1-1nodesource1 1001
                                   20.13.0-1nodesource1 1001
                                   20.12.2-1nodesource1 1001
                                   20.12.1-1nodesource1 1001
                                   20.12.0-1nodesource1 1001
                                   20.11.1-1nodesource1 1001
                                   20.11.0-1nodesource1 1001
                                   20.10.0-1nodesource1 1001
                                   20.9.0-1nodesource1 1001
                                   20.8.1-1nodesource1 1001
                                   20.8.0-1nodesource1 1001
                                   20.7.0-1nodesource1 1001
                                   20.6.1-1nodesource1 1001
                                   20.6.0-1nodesource1 1001
                                   20.5.1-1nodesource1 1001
                                   20.5.0-1nodesource1 1001
                                   20.4.0-1nodesource1 1001
                                   20.3.1-1nodesource1 1001
                                   20.3.0-1nodesource1 1001
                                   20.2.0-1nodesource1 1001
                                   20.1.0-1nodesource1 1001
                                   20.0.0-1nodesource1 1001
                                   12.22.12~dfsg-1~deb11u5 500
                                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                   12.22.12~dfsg-1~deb11u4 500
                                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                              iobroker is not running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  6.0.11
                              admin:          7.1.5
                              javascript:     8.8.3
                              nodejs modules from github:     0
                              Adapter State
                                system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                                system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                                system.adapter.daikin-cloud.0           : daikin-cloud          : IoBroker                                 - disabled
                                system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                                system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                                system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                                system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled
                                system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                                system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                                system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
                                system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                                system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                                system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                                system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                                system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                                system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                                system.adapter.mihome.0                 : mihome                : IoBroker                                 - disabled, port: 9898, bind: 0.0.0.0
                                system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 - disabled, port: 1883, bind: 0.0.0.0
                                system.adapter.netatmo-crawler.0        : netatmo-crawler       : IoBroker                                 -  enabled
                                system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                                system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                                system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                                system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                                system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                                system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                                system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                                system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                                system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): stable
                              Upgrade policy: none
                              Installed ioBroker-Instances
                              Objects and States
                              Objects:        7521
                              States:         5852
                              Hit:1 http://deb.debian.org/debian bullseye InRelease
                              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14606      1044/dnsmasq
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13147      1036/sshd: /usr/sbi
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          13149      1036/sshd: /usr/sbi
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12941      433/avahi-daemon: r
                              udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14605      1044/dnsmasq
                              udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14602      1044/dnsmasq
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13052      849/dhclient
                              udp        0      0 0.0.0.0:33135           0.0.0.0:*                           108        12943      433/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                108        12942      433/avahi-daemon: r
                              udp6       0      0 :::58117                :::*                                108        12944      433/avahi-daemon: r
                              2024-10-08 21:11:10.669  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:10.732  - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:10.733  - info: host.IoBroker instance system.adapter.ham.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:10.734  - info: host.IoBroker instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:10.747  - info: host.IoBroker instance system.adapter.whatsapp-cmb.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:11.096  - info: host.IoBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.whatsapp-cmb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.tankerkoenig.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rega.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:11.098  - warn: host.IoBroker instance system.adapter.hm-rpc.0 terminated due to SIGTERM
                              2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code null ()
                              2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.sonoff.0 terminated due to SIGTERM
                              2024-10-08 21:11:11.099  - info: host.IoBroker instance system.adapter.sonoff.0 terminated with code null ()
                              2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.web.0 terminated due to SIGTERM
                              2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.web.0 terminated with code null ()
                              2024-10-08 21:11:11.100  - warn: host.IoBroker instance system.adapter.zigbee.0 terminated due to SIGTERM
                              2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.zigbee.0 terminated with code null ()
                              2024-10-08 21:11:11.101  - warn: host.IoBroker instance system.adapter.hm-rpc.1 terminated due to SIGTERM
                              2024-10-08 21:11:11.101  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code null ()
                              2024-10-08 21:11:11.859  - info: tuya.0 (1498) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2024-10-08 21:11:12.433  - info: host.IoBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2024-10-08 21:11:13.061  - info: meross.0 (1382) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2024-10-08 21:11:13.634  - info: host.IoBroker instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-10-08 21:11:13.635  - info: host.IoBroker All instances are stopped.
                              2024-10-08 21:11:13.863  - info: host.IoBroker terminated
                                                      v.2024-08-12
                                       Icon name: computer
                                    Architecture: arm64
                              Kernel:                 aarch64
                              Userland:               64 bit
                              User-ID:                1002
                              Pending OS-Updates:     0
                              Pending iob updates:    0
                              Nodejs-Installation:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              Recommended versions are nodejs 20.18.0 and npm 10.8.2
                              MEMORY:
                              Mem:            3.8G        111M        920M        1.0M        2.8G        3.6G
                              Swap:            99M          0B         99M
                              Total:          3.9G        111M        1.0G
                              ioBroker Core:          js-controller           6.0.11
                                                      admin                   7.1.5
                              ioBroker Status:        iobroker is not running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                7521
                              States:                 5852
                              Size of iob-Database:
                              7.2M    /opt/iobroker/iobroker-data/states.jsonl
                              • F Flowski
                                bash
                                Skript v.2024-08-12
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                fabio
                                HOME=/home/fabio
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         3794 M total memory
                                          107 M used memory
                                          213 M active memory
                                          920 M free memory
                                           68 M buffer memory
                                         2698 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                *** FILESYSTEM ***
                                /var:
                                3.7G    /var/
                                2.1G    /var/log
                                817M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          7.1.5
                                javascript:     8.8.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        7521
                                States:         5852
                                Pending Updates: 0
                                                        v.2024-08-12
                                         Icon name: computer
                                      Architecture: arm64
                                Kernel:                 aarch64
                                Userland:               64 bit
                                User-ID:                1002
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                MEMORY:
                                Swap:            99M          0B         99M
                                                        admin                   7.1.5
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                7521
                                States:                 5852
                                @flowski sagte in Updateschwierigkeiten js-controller 4.0.23:
                                • iobroker.service loaded failed failed ioBroker Server
                                iobroker start
                                F 1 Antwort Letzte Antwort
                                  iobroker start
                                  Flowski
                                  @thomas-braun jetzt ist iobroker, jarvis usw. wieder erreichbar. lediglich homematic steht in den Adaptern auf rot, ne idee?
                                  bash
                                  Skript v.2024-08-12
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   21:47:18 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Tue 2024-10-08 21:47:18 CEST
                                             Universal time: Tue 2024-10-08 19:47:18 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  fabio
                                  HOME=/home/fabio
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            3.8G        1.5G        597M        1.0M        1.7G        2.2G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        1.5G        697M
                                  Active iob-Instances:   25
                                           3794 M total memory
                                           1542 M used memory
                                           1624 M active memory
                                           1292 M inactive memory
                                            597 M free memory
                                            127 M buffer memory
                                           1526 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  top - 21:47:19 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                                  Tasks: 191 total,   1 running, 190 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   3794.3 total,    597.5 free,   1542.4 used,   1654.4 buff/cache
                                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2175.3 avail Mem
                                  1 loaded units listed.
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       59G  8.8G   48G  16% /
                                  /var:
                                  3.7G    /var/
                                  2.1G    /var/log
                                  817M    /var/lib
                                  909M    /opt/iobroker/iobroker-data/
                                  10M     /opt/iobroker/iobroker-data/objects.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          7.1.5
                                  javascript:     8.8.3
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                                  + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                                  + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                                  + system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                                  + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                                  + system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                                  + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                                  + system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                                  + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                                  + system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                                  + system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                                  + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                                  + system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                                  + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                                  + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                                  + system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                  + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                                  + system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                                  + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                                  + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                                  + system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                                  + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                  + instance is alive
                                  Objects and States
                                  Objects:        7600
                                  States:         5939
                                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                  Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                  Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Pending Updates: 0
                                  tcp        0      0 192.168.178.46:1883     0.0.0.0:*               LISTEN      1001       38656      11108/io.sonoff.0
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35395      10803/iobroker.js-c
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       36274      10803/iobroker.js-c
                                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       39945      11336/io.jarvis.0
                                  tcp6       0      0 :::8088                 :::*                    LISTEN      1001       37795      11464/io.terminal.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35443      10826/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38884      11317/io.web.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       41098      11184/io.ham.0
                                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       35719      11093/io.mihome-vac
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       37615      11234/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       37616      11234/io.tuya.0
                                  2024-10-08 21:47:30.711  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                                  2024-10-08 21:47:33.801  - info: netatmo-crawler.0 (12424) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                  2024-10-08 21:47:33.907  - info: netatmo-crawler.0 (12424) Getting data for stationid:70:ee:50:22:e4:6e
                                  2024-10-08 21:47:34.887  - info: netatmo-crawler.0 (12424) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                  2024-10-08 21:47:35.441  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12424 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-10-08 21:47:50.799  - info: hm-rpc.1 (12180) xmlrpc -> 192.168.178.47:2010/ init ["http://192.168.178.46:2010",""]
                                  2024-10-08 21:47:50.799  - info: hm-rpc.0 (12186) xmlrpc -> 192.168.178.47:2001/ init ["http://192.168.178.46:2001",""]
                                  2024-10-08 21:47:50.807  - error: hm-rpc.1 (12180) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2010
                                  2024-10-08 21:47:50.809  - error: hm-rpc.0 (12186) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2001
                                  2024-10-08 21:47:50.808  - warn: hm-rpc.1 (12180) setTimeout called, but adapter is shutting down
                                  2024-10-08 21:47:50.810  - warn: hm-rpc.0 (12186) setTimeout called, but adapter is shutting down
                                  2024-10-08 21:47:51.812  - info: hm-rpc.1 (12180) terminating
                                  2024-10-08 21:47:51.814  - info: hm-rpc.1 (12180) Terminated (NO_ERROR): Without reason
                                  2024-10-08 21:47:51.821  - info: hm-rpc.0 (12186) terminating
                                  2024-10-08 21:47:51.823  - info: hm-rpc.0 (12186) Terminated (NO_ERROR): Without reason
                                  2024-10-08 21:47:52.477  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                                  2024-10-08 21:47:52.479  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.1 because enabled
                                  2024-10-08 21:47:52.538  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                                  2024-10-08 21:47:52.538  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.0 because enabled
                                  2024-10-08 21:48:00.110  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 12970
                                  2024-10-08 21:48:03.799  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                                  2024-10-08 21:48:04.085  - info: netatmo-crawler.0 (12970) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                  2024-10-08 21:48:04.178  - info: netatmo-crawler.0 (12970) Getting data for stationid:70:ee:50:22:e4:6e
                                  2024-10-08 21:48:05.463  - info: netatmo-crawler.0 (12970) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                  2024-10-08 21:48:06.020  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12970 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  • F Flowski
                                    bash
                                    Skript v.2024-08-12
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    fabio
                                    HOME=/home/fabio
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             3794 M total memory
                                             1542 M used memory
                                              597 M free memory
                                              127 M buffer memory
                                             1526 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    3.7G    /var/
                                    2.1G    /var/log
                                    817M    /var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          7.1.5
                                    javascript:     8.8.3
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        7600
                                    States:         5939
                                    Pending Updates: 0
                                    • pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
                                    Hat das mit homematic zu tun? Kenn mich in dem Bereich aber auch Null aus.
                                      Flowski
                                      @thomas-braun mir wurde damals eine virtuelle ccu aufgespielt? das sollte es sein
                                      • F Flowski
                                        @flowski
                                        Wie gesagt, mit pivCCU und Co. kenn ich mich nicht aus.
                                        Muss sich wohl wer anders anschauen.
                                        Mach am besten einen neuen Thread mit eigener Beschreibung dazu auf.
                                        Da kannst du auch die Ausgabe von
                                        systemctl status pivccu-dkms
                                        posten.
                                        • F Offline
                                          Flowski
                                          schrieb am zuletzt editiert von Flowski
                                          @thomas-braun said in Updateschwierigkeiten js-controller 4.0.23:
                                          Ok werde ich machen. Nochmal tausend Dank für deinen Support, hast mir sehr geholfen.. dann mache ich mal einen neuen Beitrag auf.
                                          Schönen Abend
                                          EDIT: Neuer Beitrag zur CCU-Problematik
