  4. Updateschwierigkeiten js-controller 4.0.23
33 Beiträge 4 Kommentatoren 5.9k Aufrufe 6 Beobachtet
  • F Offline
    Flowski
    @thomas-braun danke für deinen support, jetzt erscheint folgendes im Terminal:
    fabio@IoBroker:/home/pi $ iob stop
    fabio@IoBroker:/home/pi $ sudo reboot
    [sudo] password for fabio:
    Connection to 192.168.178.46 closed by remote host.
    Connection to 192.168.178.46 closed.
    PS C:\Users\mulla> ssh pi@192.168.178.46
    pi@192.168.178.46's password:
    Linux IoBroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
    permitted by applicable law.
    Last login: Tue Oct  8 20:04:34 2024 from 192.168.178.131
    Wi-Fi is currently blocked by rfkill.
    Use raspi-config to set the country before use.
    pi@IoBroker:~ $ iob update
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.0.22 [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.22   , installed 2.10.11 [Updatable]
    Adapter    "daikin-cloud" : 0.4.8    , installed 0.3.0  [Updatable]
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.16.0 [Updatable]
    Adapter    "homeconnect"  : 1.4.1    , installed 1.3.0  [Updatable]
    Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
    Controller "js-controller": 6.0.11   , installed 4.0.23 [Updatable]
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 3.8.6  [Updatable]
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 2.0.0    , installed 1.6.3  [Updatable]
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.0.3  [Updatable]
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.1.0  [Updatable]
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
    Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
    Adapter    "yeelight-2"   : 1.4.0    , installed 1.2.1  [Updatable]
    Adapter    "zigbee"       : 1.10.3   , installed 1.8.10 [Updatable]
    pi@IoBroker:~ $ cu fabio
    -bash: cu: command not found
    pi@IoBroker:~ $ ssh fabio@192.168.178.46
    The authenticity of host '192.168.178.46 (192.168.178.46)' can't be established.
    ECDSA key fingerprint is SHA256:FIhsIFzSsCA3qcV8rP3HPxSWGbgQ71sBXmHraXwu1t0.
    Are you sure you want to continue connecting (yes/no/[fingerprint])? n
    Please type 'yes', 'no' or the fingerprint: no
    Host key verification failed.
    pi@IoBroker:~ $ su fabio
    Password:
    fabio@IoBroker:/home/pi $ iob update
    fabio@IoBroker:/home/pi $ iob upgrade all -y
    Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.19
    Update hm-rega from @4.0.0 to @5.0.0
    NPM version: 10.8.2
    Installing iobroker.hm-rega@5.0.0... (System call)
    added 2 packages, removed 399 packages, and changed 2 packages in 16s
    131 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.hm-rega.0"
    upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
    upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
    upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
    upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
    Update discovery from @4.5.0 to @5.0.0
    NPM version: 10.8.2
    Installing iobroker.discovery@5.0.0... (System call)
    changed 1 package in 11s
    Update "system.adapter.discovery.0"
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    Update admin from @7.0.22 to @7.1.5
    host.IoBroker Adapter "system.adapter.admin.0" is stopped.
    NPM version: 10.8.2
    Installing iobroker.admin@7.1.5... (System call)
    added 11 packages, removed 3 packages, and changed 11 packages in 21s
    Update "system.adapter.admin.0"
    upload [68] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    host.IoBroker Adapter "system.adapter.admin.0" is started
    Update zigbee from @1.8.10 to @1.10.3
    host.IoBroker Adapter "system.adapter.zigbee.0" is stopped.
    NPM version: 10.8.2
    Installing iobroker.zigbee@1.10.3... (System call)
    added 18 packages, removed 19 packages, and changed 24 packages in 33s
    120 packages are looking for funding
    Update "system.adapter.zigbee.0"
    upload [331] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/E2213.png img/E2213.png image/png
    upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
    upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue-smart-button.png img/hue-smart-button.png image/png
    upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
    upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_fuzo_outdoor_wall_light.png img/philips_fuzo_outdoor_wall_light.png image/png
    upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_4.png img/philips_hue_argenta_4.png image/png
    upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_ambiance.png img/philips_hue_gu10_ambiance.png image/png
    upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
    upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/previous_track.png img/previous_track.png image/png
    upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
    upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
    upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
    upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
    upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
    upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
    upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
    upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
    upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
    upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
    upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
    upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
    upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
    upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
    upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
    upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
    upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
    upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
    upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
    upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
    upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
    upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
    upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
    upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
    host.IoBroker Adapter "system.adapter.zigbee.0" is started
    Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.0
    • F Flowski
      Password:
      NPM version: 10.8.2
      NPM version: 10.8.2
      NPM version: 10.8.2
      NPM version: 10.8.2
      @flowski sagte in Updateschwierigkeiten js-controller 4.0.23:
      Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users.
      Den Fingerpring für den fabio musst du schon akzeptieren, damit das funktioniert.
      Und warum hast du nicht gleich den 'pi' verwendet, wenn es denn doch schon gab?
      iob stop
      iob ugrade self
      iob upgrade all -y
      • F Offline
        Flowski
        schrieb am zuletzt editiert von Flowski
        puh ok 🤕 :)
        heisst ssh fabio@192.168.178.46
        dann ecdsa key ... mit yes
        Zitat:
        Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users. sorry stehe auf dem Schlauch :( muss da sicherlich noch was umstellen bevor ich die drei Befehle eingebe aber begreife es grad nicht
        • F Flowski
          puh ok 🤕 :)
          @flowski
          Jeder user hat auf einem Linux-System ein eigenes home-Verzeichnis, indem die eigenen Dateien abgelegt werden.
          F 1 Antwort Letzte Antwort
            @flowski
            Flowski
            @thomas-braun so: fabio@IoBroker:~ $?
            • F Flowski
              @flowski
              Ja. Die Tilde repräsentiert das home des users.
                @flowski
                Flowski
                @thomas-braun anbei der log, iobroker ist jetzt aktuell nicht erreichbar im Browser.. brauchts jetzt nochmal ein iob reboot?
                fabio@IoBroker:/home/pi $  ssh fabio@192.168.178.46
                Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
                Warning: Permanently added '192.168.178.46' (ECDSA) to the list of known hosts.
                fabio@192.168.178.46's password:
                fabio@IoBroker:~ $ iob stop
                fabio@IoBroker:~ $ iob upgrade self
                Update js-controller from @4.0.23 to @6.0.11
                Stopped Objects DB
                Stopped States DB
                NPM version: 10.8.2
                Installing iobroker.js-controller@6.0.11... (System call)
                added 10 packages, removed 67 packages, and changed 44 packages in 52s
                121 packages are looking for funding
                fabio@IoBroker:~ $ iob upgrade all -y
                Update yeelight-2 from @1.2.1 to @1.4.0
                NPM version: 10.8.2
                Installing iobroker.yeelight-2@1.4.0... (System call)
                added 2 packages, removed 32 packages, and changed 5 packages in 12s
                Update "system.adapter.yeelight-2.0"
                upload [20] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/1.png icons/1.png image/png
                upload [19] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/2.png icons/2.png image/png
                upload [18] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/3.png icons/3.png image/png
                upload [17] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/4.png icons/4.png image/png
                upload [16] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/5.png icons/5.png image/png
                upload [15] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/6.png icons/6.png image/png
                upload [14] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/7.png icons/7.png image/png
                upload [13] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/bslamp1.png icons/bslamp1.png image/png
                upload [12] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling1.png icons/ceiling1.png image/png
                upload [11] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling10.png icons/ceiling10.png image/png
                upload [10] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling3.png icons/ceiling3.png image/png
                upload [9] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling4.png icons/ceiling4.png image/png
                upload [8] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/color.png icons/color.png image/png
                upload [7] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/desklamp.png icons/desklamp.png image/png
                upload [6] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/mono.png icons/mono.png image/png
                upload [5] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/stripe.png icons/stripe.png image/png
                upload [4] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index.html index.html text/html
                upload [3] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index_m.html index_m.html text/html
                upload [2] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/lan.jpg lan.jpg image/jpeg
                upload [1] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/words.js words.js application/javascript
                upload [0] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/yeelight.png yeelight.png image/png
                Update whatsapp-cmb from @0.2.3 to @0.3.0
                NPM version: 10.8.2
                Installing iobroker.whatsapp-cmb@0.3.0... (System call)
                changed 1 package in 8s
                Update "system.adapter.whatsapp-cmb.0"
                Update "system.adapter.whatsapp-cmb.1"
                upload [17] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/admin.d.ts admin.d.ts video/mp2t
                upload [16] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/blockly.js blockly.js application/javascript
                upload [15] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [14] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [13] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [12] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [11] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [10] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [9] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [8] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [7] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [6] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [5] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [4] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/index_m.html index_m.html text/html
                upload [3] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/style.css style.css text/css
                upload [2] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/tsconfig.json tsconfig.json application/json
                upload [1] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/whatsapp-cmb.png whatsapp-cmb.png image/png
                upload [0] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/words.js words.js application/javascript
                Update tuya from @3.15.0 to @3.16.0
                NPM version: 10.8.2
                Installing iobroker.tuya@3.16.0... (System call)
                added 73 packages, removed 1 package, and changed 3 packages in 24s
                124 packages are looking for funding
                Update "system.adapter.tuya.0"
                upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                Update trashschedule from @3.2.0 to @3.3.0
                NPM version: 10.8.2
                Installing iobroker.trashschedule@3.3.0... (System call)
                added 1 package, and changed 1 package in 9s
                Update "system.adapter.trashschedule.0"
                upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                Update tankerkoenig from @3.1.0 to @3.4.0
                host.IoBroker Adapter "system.adapter.tankerkoenig.0" is stopped.
                NPM version: 10.8.2
                Installing iobroker.tankerkoenig@3.4.0... (System call)
                removed 1 package, and changed 1 package in 10s
                Update "system.adapter.tankerkoenig.0"
                upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
                upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
                upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
                upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                host.IoBroker Adapter "system.adapter.tankerkoenig.0" is started
                Update sonoff from @3.0.3 to @3.1.2
                NPM version: 10.8.2
                Installing iobroker.sonoff@3.1.2... (System call)
                Update "system.adapter.sonoff.0"
                upload [15] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [14] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [13] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [12] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [11] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
                upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
                upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
                Update mqtt-client from @1.6.3 to @2.0.0
                NPM version: 10.8.2
                Installing iobroker.mqtt-client@2.0.0... (System call)
                added 15 packages, and changed 1 package in 10s
                upload [13] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [12] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [11] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [10] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [9] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [8] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [7] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [6] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [5] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [4] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [3] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [2] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonConfig.json jsonConfig.json application/json
                upload [1] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonCustom.json jsonCustom.json application/json
                upload [0] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/mqtt-client.png mqtt-client.png image/png
                Update mihome-vacuum from @3.8.6 to @4.2.0
                NPM version: 10.8.2
                Installing iobroker.mihome-vacuum@4.2.0... (System call)
                added 3 packages, removed 4 packages, and changed 9 packages in 2m
                Update "system.adapter.mihome-vacuum.0"
                upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                Update javascript from @7.8.0 to @8.8.3
                NPM version: 10.8.2
                Installing iobroker.javascript@8.8.3... (System call)
                added 1 package, removed 1 package, and changed 6 packages in 1m
                Update "system.adapter.javascript.0"
                upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                Update ical from @1.14.3 to @1.15.0
                NPM version: 10.8.2
                Installing iobroker.ical@1.15.0... (System call)
                added 1 package, and changed 1 package in 11s
                Update "system.adapter.ical.0"
                upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                Update homeconnect from @1.3.0 to @1.4.1
                NPM version: 10.8.2
                Installing iobroker.homeconnect@1.4.1... (System call)
                added 1 package, and changed 2 packages in 16s
                Update "system.adapter.homeconnect.0"
                upload [15] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect-880x800.png homeconnect-880x800.png image/png
                upload [14] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect.png homeconnect.png image/png
                upload [13] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [12] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [11] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [10] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [9] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [8] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [7] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [6] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [5] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [4] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [3] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [2] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/index_m.html index_m.html text/html
                upload [1] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/style.css style.css text/css
                upload [0] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/words.js words.js application/javascript
                Update hm-rpc from @1.16.0 to @2.0.2
                NPM version: 10.8.2
                Installing iobroker.hm-rpc@2.0.2... (System call)
                added 1 package, and changed 2 packages in 10s
                Update "system.adapter.hm-rpc.0"
                Update "system.adapter.hm-rpc.1"
                upload [279] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/157_hmip-broll_hmip-bbl_thumb.png icons/157_hmip-broll_hmip-bbl_thumb.png image/png
                upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/202_hmip-wrcr_thumb_right.png icons/202_hmip-wrcr_thumb_right.png image/png
                upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/3_hm-lc-sw4-sm_thumb.png icons/3_hm-lc-sw4-sm_thumb.png image/png
                upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/50_hm-sec-mdir_thumb.png icons/50_hm-sec-mdir_thumb.png image/png
                upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/58_hmw-sen-sc-12-fm_thumb.png icons/58_hmw-sen-sc-12-fm_thumb.png image/png
                upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/68_hm-lc-sw4-dr_thumb.png icons/68_hm-lc-sw4-dr_thumb.png image/png
                upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/78_hm-ou-led16_thumb.png icons/78_hm-ou-led16_thumb.png image/png
                upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/86_hm-rc-sec4-2_thumb.png icons/86_hm-rc-sec4-2_thumb.png image/png
                upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/98_hm-sec-sco_thumb.png icons/98_hm-sec-sco_thumb.png image/png
                upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/HmIPW-FALMOT-C12.png icons/HmIPW-FALMOT-C12.png image/png
                upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/group_hm-cc-vg-1.png icons/group_hm-cc-vg-1.png image/png
                upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-cap-moist.png icons/hb-uni-sen-cap-moist.png image/png
                upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
                upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
                upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
                upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
                upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
                upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
                upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
                upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
                upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
                upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
                upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
                upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
                upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
                upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
                upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
                upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
                upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
                upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/jsonConfig.json jsonConfig.json application/json
                upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
                Update daikin-cloud from @0.3.0 to @0.4.8
                NPM version: 10.8.2
                Installing iobroker.daikin-cloud@0.4.8... (System call)
                added 2 packages, removed 14 packages, and changed 4 packages in 11s
                113 packages are looking for funding
                Update "system.adapter.daikin-cloud.0"
                upload [16] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                upload [15] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                upload [14] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
                upload [13] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [12] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [11] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [10] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [9] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [8] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [7] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/jsonConfig.json jsonConfig.json application/json
                upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                Update backitup from @2.10.11 to @3.0.22
                host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
                NPM version: 10.8.2
                Installing iobroker.backitup@3.0.22... (System call)
                added 5 packages, and changed 20 packages in 17s
                Update "system.adapter.backitup.0"
                upload [90] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                upload [80] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                upload [70] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/main.0fac7bdb.js custom/static/js/main.0fac7bdb.js application/javascript
                upload [60] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js application/javascript
                upload [50] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js application/javascript
                upload [40] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/googledrive.jsonConfig.json5 googledrive.jsonConfig.json5 application/json5
                upload [30] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/main.jsonConfig.json5 main.jsonConfig.json5 application/json5
                upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
                upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
                upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
                upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
                upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
                upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
                upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
                upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
                upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css static/css/main.bd1167d4.css text/css
                upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/245.7caf1dae.chunk.js static/js/245.7caf1dae.chunk.js application/javascript
                upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js static/js/main.2cca4954.js application/javascript
                upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js.LICENSE.txt static/js/main.2cca4954.js.LICENSE.txt text/plain
                upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/media/history.d21dcfa508bd8a624c85.png static/media/history.d21dcfa508bd8a624c85.png image/png
                upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
                upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
                host.IoBroker Adapter "system.adapter.backitup.0" is started
                fabio@IoBroker:~ $
                • F Flowski
                  Linux IoBroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                  permitted by applicable law.
                  Wi-Fi is currently blocked by rfkill.
                  Use raspi-config to set the country before use.
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  NPM version: 10.8.2
                  fabio@IoBroker:~ $
                  @flowski
                  Was kommt bei einem
                  iob update
                  um's Eck?
                    @flowski
                    Was kommt bei einem
                    iob update
                    um's Eck?
                    Flowski
                    fabio@IoBroker:~ $ iob update
                    Used repository: stable
                    Adapter    "admin"        : 7.1.5    , installed 7.1.5
                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                    Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
                    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                    Adapter    "ham"          : 5.3.1    , installed 5.3.1
                    Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                    Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                    Adapter    "ical"         : 1.15.0   , installed 1.15.0
                    Adapter    "iot"          : 3.3.0    , installed 3.3.0
                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                    Controller "js-controller": 6.0.11   , installed 6.0.11
                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                    Adapter    "meross"       : 1.17.0   , installed 1.17.0
                    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                    Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
                    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                    Adapter    "web"          : 6.2.5    , installed 6.2.5
                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                    Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                    fabio@IoBroker:~ $
                    • F Flowski
                      fabio@IoBroker:~ $
                      @flowski
                      Gut.
                      iob start admin
                      und die Kiste sollte wieder an den Start kommen.
                        @flowski
                        Gut.
                        iob start admin
                        Flowski
                        @thomas-braun bislang tut sich nix
                        fabio@IoBroker:~ $ iob start admin
                        fabio@IoBroker:~ $
                        • F Flowski
                          fabio@IoBroker:~ $
                          @flowski
                          iob diag
                            @flowski
                            iob diag
                            Flowski
                            bash
                            Skript v.2024-08-12
                            *** BASE SYSTEM ***
                               Static hostname: IoBroker
                                     Icon name: computer
                              Operating System: Debian GNU/Linux 11 (bullseye)
                                        Kernel: Linux 6.1.21-v8+
                                  Architecture: arm64
                            OS is similar to:
                            Model           : Raspberry Pi 4 Model B Rev 1.2
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             21:35:42 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                            CPU threads: 4
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            ~ Under-voltage has occurred
                            ~ Arm frequency capping has occurred
                            ~ Throttling has occurred
                            ~ Soft temperature limit has occurred
                            *** Time and Time Zones ***
                                           Local time: Tue 2024-10-08 21:35:42 CEST
                                       Universal time: Tue 2024-10-08 19:35:42 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            fabio
                            HOME=/home/fabio
                            GROUPS=fabio sudo iobroker
                            js-controller is not running
                            *** Display-Server-Setup ***
                            Display-Server: false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            3.8G        107M        920M        1.0M        2.8G        3.6G
                            Swap:            99M          0B         99M
                            Total:          3.9G        107M        1.0G
                            Active iob-Instances:   1
                                     3794 M total memory
                                      107 M used memory
                                      213 M active memory
                                     2439 M inactive memory
                                      920 M free memory
                                       68 M buffer memory
                                     2698 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            top - 21:35:43 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                            Tasks: 162 total,   1 running, 161 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3794.3 total,    919.3 free,    107.8 used,   2767.3 buff/cache
                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3610.0 avail Mem
                            *** FAILED SERVICES ***
                              UNIT                LOAD   ACTIVE SUB    DESCRIPTION
                            * iobroker.service    loaded failed failed ioBroker Server
                            * pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
                            2 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4       59G  8.7G   48G  16% /
                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                            tmpfs          tmpfs     759M  1.2M  758M   1% /run
                            /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
                            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                            tmpfs          tmpfs     380M     0  380M   0% /run/user/1002
                            [Tue Oct  8 20:46:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:83:48 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=2a0531f8-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Tue Oct  8 20:46:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Tue Oct  8 20:46:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Tue Oct  8 20:46:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            Show mounted filesystems:
                            TARGET  SOURCE         FSTYPE OPTIONS
                            /       /dev/mmcblk0p2 ext4   rw,noatime
                            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                            3.7G    /var/
                            2.1G    /var/log/journal/664a8e581ec84405863df59a10cf9293
                            2.1G    /var/log
                            817M    /var/lib
                            Archived and active journals take up 8.0M in the file system.
                            /opt/iobroker/backups:
                            58M     /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            913M    /opt/iobroker/iobroker-data/
                            840M    /opt/iobroker/iobroker-data/files
                            617M    /opt/iobroker/iobroker-data/files/javascript.admin
                            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                            16M     /opt/iobroker/iobroker-data/objects.jsonl
                            14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                            USB-Devices by-id:
                            /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                            /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03D64S-if00-port0
                            Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v20.18.0
                            /usr/bin/node           v20.18.0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.29.3
                            nodejs:
                              Installed: 20.18.0-1nodesource1
                              Candidate: 20.18.0-1nodesource1
                              Version table:
                             *** 20.18.0-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                 20.17.0-1nodesource1 1001
                                 20.16.0-1nodesource1 1001
                                 20.15.1-1nodesource1 1001
                                 20.15.0-1nodesource1 1001
                                 20.14.0-1nodesource1 1001
                                 20.13.1-1nodesource1 1001
                                 20.13.0-1nodesource1 1001
                                 20.12.2-1nodesource1 1001
                                 20.12.1-1nodesource1 1001
                                 20.12.0-1nodesource1 1001
                                 20.11.1-1nodesource1 1001
                                 20.11.0-1nodesource1 1001
                                 20.10.0-1nodesource1 1001
                                 20.9.0-1nodesource1 1001
                                 20.8.1-1nodesource1 1001
                                 20.8.0-1nodesource1 1001
                                 20.7.0-1nodesource1 1001
                                 20.6.1-1nodesource1 1001
                                 20.6.0-1nodesource1 1001
                                 20.5.1-1nodesource1 1001
                                 20.5.0-1nodesource1 1001
                                 20.4.0-1nodesource1 1001
                                 20.3.1-1nodesource1 1001
                                 20.3.0-1nodesource1 1001
                                 20.2.0-1nodesource1 1001
                                 20.1.0-1nodesource1 1001
                                 20.0.0-1nodesource1 1001
                                 12.22.12~dfsg-1~deb11u5 500
                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                 12.22.12~dfsg-1~deb11u4 500
                                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            iobroker is not running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  6.0.11
                            admin:          7.1.5
                            javascript:     8.8.3
                            nodejs modules from github:     0
                            Adapter State
                              system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                              system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                              system.adapter.daikin-cloud.0           : daikin-cloud          : IoBroker                                 - disabled
                              system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                              system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                              system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                              system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled
                              system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                              system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                              system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
                              system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                              system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                              system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                              system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                              system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                              system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                              system.adapter.mihome.0                 : mihome                : IoBroker                                 - disabled, port: 9898, bind: 0.0.0.0
                              system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 - disabled, port: 1883, bind: 0.0.0.0
                              system.adapter.netatmo-crawler.0        : netatmo-crawler       : IoBroker                                 -  enabled
                              system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                              system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                              system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                              system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                              system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                              system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                              system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                              system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                              system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                              system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): stable
                            Upgrade policy: none
                            Installed ioBroker-Instances
                            Objects and States
                            Objects:        7521
                            States:         5852
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14606      1044/dnsmasq
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13147      1036/sshd: /usr/sbi
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          13149      1036/sshd: /usr/sbi
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12941      433/avahi-daemon: r
                            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14605      1044/dnsmasq
                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14602      1044/dnsmasq
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13052      849/dhclient
                            udp        0      0 0.0.0.0:33135           0.0.0.0:*                           108        12943      433/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        12942      433/avahi-daemon: r
                            udp6       0      0 :::58117                :::*                                108        12944      433/avahi-daemon: r
                            2024-10-08 21:11:10.669  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:10.732  - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:10.733  - info: host.IoBroker instance system.adapter.ham.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:10.734  - info: host.IoBroker instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:10.747  - info: host.IoBroker instance system.adapter.whatsapp-cmb.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:11.096  - info: host.IoBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.whatsapp-cmb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.tankerkoenig.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rega.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:11.098  - warn: host.IoBroker instance system.adapter.hm-rpc.0 terminated due to SIGTERM
                            2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code null ()
                            2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.sonoff.0 terminated due to SIGTERM
                            2024-10-08 21:11:11.099  - info: host.IoBroker instance system.adapter.sonoff.0 terminated with code null ()
                            2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.web.0 terminated due to SIGTERM
                            2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.web.0 terminated with code null ()
                            2024-10-08 21:11:11.100  - warn: host.IoBroker instance system.adapter.zigbee.0 terminated due to SIGTERM
                            2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.zigbee.0 terminated with code null ()
                            2024-10-08 21:11:11.101  - warn: host.IoBroker instance system.adapter.hm-rpc.1 terminated due to SIGTERM
                            2024-10-08 21:11:11.101  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code null ()
                            2024-10-08 21:11:11.859  - info: tuya.0 (1498) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                            2024-10-08 21:11:12.433  - info: host.IoBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-10-08 21:11:13.061  - info: meross.0 (1382) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-10-08 21:11:13.634  - info: host.IoBroker instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-10-08 21:11:13.635  - info: host.IoBroker All instances are stopped.
                            2024-10-08 21:11:13.863  - info: host.IoBroker terminated
                                                    v.2024-08-12
                                     Icon name: computer
                                  Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               64 bit
                            User-ID:                1002
                            Pending OS-Updates:     0
                            Pending iob updates:    0
                            Nodejs-Installation:
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            Recommended versions are nodejs 20.18.0 and npm 10.8.2
                            MEMORY:
                            Mem:            3.8G        111M        920M        1.0M        2.8G        3.6G
                            Swap:            99M          0B         99M
                            Total:          3.9G        111M        1.0G
                            ioBroker Core:          js-controller           6.0.11
                                                    admin                   7.1.5
                            ioBroker Status:        iobroker is not running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                7521
                            States:                 5852
                            Size of iob-Database:
                            7.2M    /opt/iobroker/iobroker-data/states.jsonl
                            • F Flowski
                              bash
                              Skript v.2024-08-12
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              fabio
                              HOME=/home/fabio
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       3794 M total memory
                                        107 M used memory
                                        213 M active memory
                                        920 M free memory
                                         68 M buffer memory
                                       2698 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              /var:
                              3.7G    /var/
                              2.1G    /var/log
                              817M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          7.1.5
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        7521
                              States:         5852
                              Pending Updates: 0
                                                      v.2024-08-12
                                       Icon name: computer
                                    Architecture: arm64
                              Kernel:                 aarch64
                              Userland:               64 bit
                              User-ID:                1002
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              MEMORY:
                              Swap:            99M          0B         99M
                                                      admin                   7.1.5
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                7521
                              States:                 5852
                              @flowski sagte in Updateschwierigkeiten js-controller 4.0.23:
                              • iobroker.service loaded failed failed ioBroker Server
                              iobroker start
                              F 1 Antwort Letzte Antwort
                                iobroker start
                                Flowski
                                @thomas-braun jetzt ist iobroker, jarvis usw. wieder erreichbar. lediglich homematic steht in den Adaptern auf rot, ne idee?
                                bash
                                Skript v.2024-08-12
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                 21:47:18 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                                CPU threads: 4
                                Current issues:
                                               Local time: Tue 2024-10-08 21:47:18 CEST
                                           Universal time: Tue 2024-10-08 19:47:18 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                fabio
                                HOME=/home/fabio
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        1.5G        597M        1.0M        1.7G        2.2G
                                Swap:            99M          0B         99M
                                Total:          3.9G        1.5G        697M
                                Active iob-Instances:   25
                                         3794 M total memory
                                         1542 M used memory
                                         1624 M active memory
                                         1292 M inactive memory
                                          597 M free memory
                                          127 M buffer memory
                                         1526 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                top - 21:47:19 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                                Tasks: 191 total,   1 running, 190 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   3794.3 total,    597.5 free,   1542.4 used,   1654.4 buff/cache
                                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2175.3 avail Mem
                                1 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/root      ext4       59G  8.8G   48G  16% /
                                /var:
                                3.7G    /var/
                                2.1G    /var/log
                                817M    /var/lib
                                909M    /opt/iobroker/iobroker-data/
                                10M     /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          7.1.5
                                javascript:     8.8.3
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                                + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                                + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                                + system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                                + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                                + system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                                + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                                + system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                                + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                                + system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                                + system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                                + system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                                + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                                + system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                                + system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                                + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                                + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                                + system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                + instance is alive
                                Objects and States
                                Objects:        7600
                                States:         5939
                                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:2 http://deb.debian.org/debian bullseye InRelease
                                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Pending Updates: 0
                                tcp        0      0 192.168.178.46:1883     0.0.0.0:*               LISTEN      1001       38656      11108/io.sonoff.0
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35395      10803/iobroker.js-c
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       36274      10803/iobroker.js-c
                                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       39945      11336/io.jarvis.0
                                tcp6       0      0 :::8088                 :::*                    LISTEN      1001       37795      11464/io.terminal.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35443      10826/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38884      11317/io.web.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       41098      11184/io.ham.0
                                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       35719      11093/io.mihome-vac
                                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       37615      11234/io.tuya.0
                                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       37616      11234/io.tuya.0
                                2024-10-08 21:47:30.711  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                                2024-10-08 21:47:33.801  - info: netatmo-crawler.0 (12424) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                2024-10-08 21:47:33.907  - info: netatmo-crawler.0 (12424) Getting data for stationid:70:ee:50:22:e4:6e
                                2024-10-08 21:47:34.887  - info: netatmo-crawler.0 (12424) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                2024-10-08 21:47:35.441  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12424 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-10-08 21:47:50.799  - info: hm-rpc.1 (12180) xmlrpc -> 192.168.178.47:2010/ init ["http://192.168.178.46:2010",""]
                                2024-10-08 21:47:50.799  - info: hm-rpc.0 (12186) xmlrpc -> 192.168.178.47:2001/ init ["http://192.168.178.46:2001",""]
                                2024-10-08 21:47:50.807  - error: hm-rpc.1 (12180) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2010
                                2024-10-08 21:47:50.809  - error: hm-rpc.0 (12186) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2001
                                2024-10-08 21:47:50.808  - warn: hm-rpc.1 (12180) setTimeout called, but adapter is shutting down
                                2024-10-08 21:47:50.810  - warn: hm-rpc.0 (12186) setTimeout called, but adapter is shutting down
                                2024-10-08 21:47:51.812  - info: hm-rpc.1 (12180) terminating
                                2024-10-08 21:47:51.814  - info: hm-rpc.1 (12180) Terminated (NO_ERROR): Without reason
                                2024-10-08 21:47:51.821  - info: hm-rpc.0 (12186) terminating
                                2024-10-08 21:47:51.823  - info: hm-rpc.0 (12186) Terminated (NO_ERROR): Without reason
                                2024-10-08 21:47:52.477  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                                2024-10-08 21:47:52.479  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.1 because enabled
                                2024-10-08 21:47:52.538  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                                2024-10-08 21:47:52.538  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.0 because enabled
                                2024-10-08 21:48:00.110  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 12970
                                2024-10-08 21:48:03.799  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                                2024-10-08 21:48:04.085  - info: netatmo-crawler.0 (12970) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                2024-10-08 21:48:04.178  - info: netatmo-crawler.0 (12970) Getting data for stationid:70:ee:50:22:e4:6e
                                2024-10-08 21:48:05.463  - info: netatmo-crawler.0 (12970) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                2024-10-08 21:48:06.020  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12970 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                • F Flowski
                                  bash
                                  Skript v.2024-08-12
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  fabio
                                  HOME=/home/fabio
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           3794 M total memory
                                           1542 M used memory
                                            597 M free memory
                                            127 M buffer memory
                                           1526 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  3.7G    /var/
                                  2.1G    /var/log
                                  817M    /var/lib
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          7.1.5
                                  javascript:     8.8.3
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        7600
                                  States:         5939
                                  Pending Updates: 0
                                  • pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
                                  Hat das mit homematic zu tun? Kenn mich in dem Bereich aber auch Null aus.
                                    Flowski
                                    @thomas-braun mir wurde damals eine virtuelle ccu aufgespielt? das sollte es sein
                                    • F Flowski
                                      @flowski
                                      Wie gesagt, mit pivCCU und Co. kenn ich mich nicht aus.
                                      Muss sich wohl wer anders anschauen.
                                      Mach am besten einen neuen Thread mit eigener Beschreibung dazu auf.
                                      Da kannst du auch die Ausgabe von
                                      systemctl status pivccu-dkms
                                      posten.
                                      • F Offline
                                        Flowski
                                        schrieb am zuletzt editiert von Flowski
                                        @thomas-braun said in Updateschwierigkeiten js-controller 4.0.23:
                                        Ok werde ich machen. Nochmal tausend Dank für deinen Support, hast mir sehr geholfen.. dann mache ich mal einen neuen Beitrag auf.
                                        Schönen Abend
                                        EDIT: Neuer Beitrag zur CCU-Problematik
