  4. Updateschwierigkeiten js-controller 4.0.23
33 Beiträge 4 Kommentatoren 5.9k Aufrufe 6 Beobachtet
  • F Offline
    Flowski
    Hi, also ich habe das update soeben durchgeführt, anbei der Log. Was ich jetzt festgestellt habe, mein Homematic funktioniert nicht, der js-controller scheint nicht aktualisiert worden sein. Wie bekomme ich die neuen Fehler weg, bzw. was kann ich als nächstes probieren?
    ```bash
    Skript v.2024-08-12
    *** BASE SYSTEM ***
       Static hostname: IoBroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.76-v8+
          Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     20:28:52 up 68 days, 23:24,  1 user,  load average: 0.59, 0.91, 0.96
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    This system needs to be REBOOTED!
    *** Time and Time Zones ***
                   Local time: Tue 2024-10-08 20:28:52 CEST
               Universal time: Tue 2024-10-08 18:28:52 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    fabio
    HOME=/home/fabio
    GROUPS=fabio sudo iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.2G        467M        1.0M        2.1G        2.5G
    Swap:            99M        4.0M         95M
    Total:          3.9G        1.2G        562M
    Active iob-Instances:   25
             3794 M total memory
             1214 M used memory
              686 M active memory
             2214 M inactive memory
              467 M free memory
              246 M buffer memory
             1866 M swap cache
               99 M total swap
                4 M used swap
               95 M free swap
    top - 20:28:53 up 68 days, 23:24,  1 user,  load average: 0.59, 0.91, 0.96
    Tasks: 178 total,   1 running, 177 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  5.9 us,  1.5 sy,  0.0 ni, 91.2 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
    MiB Mem :   3794.4 total,    467.5 free,   1214.3 used,   2112.5 buff/cache
    MiB Swap:    100.0 total,     95.2 free,      4.8 used.   2503.5 avail Mem
    *** FAILED SERVICES ***
      UNIT                LOAD   ACTIVE SUB    DESCRIPTION
    * pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  7.3G   49G  13% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Wed Jul 31 21:04:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:5A:83:48 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=2a0531f8-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Jul 31 21:04:31 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Wed Jul 31 21:04:31 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Wed Jul 31 21:04:32 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Wed Jul 31 21:04:32 2024] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
    [Wed Jul 31 21:04:32 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Wed Jul 31 21:04:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Wed Jul 31 21:04:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Jul 31 21:04:33 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    3.7G    /var/
    2.1G    /var/log/journal/664a8e581ec84405863df59a10cf9293
    2.1G    /var/log
    817M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    58M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    289M    /opt/iobroker/iobroker-data/
    223M    /opt/iobroker/iobroker-data/files
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    49M     /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/iot.admin
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    13M     /opt/iobroker/iobroker-data/objects.jsonl
    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03D64S-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u5 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          7.0.22
    javascript:     7.8.0
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
      system.adapter.daikin-cloud.0           : daikin-cloud          : IoBroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled
    + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
    + system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
      system.adapter.mihome.0                 : mihome                : IoBroker                                 - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : IoBroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
    + system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
      system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.0.22 [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.22   , installed 2.10.11 [Updatable]
    Adapter    "daikin-cloud" : 0.4.8    , installed 0.3.0  [Updatable]
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.16.0 [Updatable]
    Adapter    "homeconnect"  : 1.4.1    , installed 1.3.0  [Updatable]
    Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
    Controller "js-controller": 6.0.11   , installed 4.0.23 [Updatable]
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 3.8.6  [Updatable]
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 2.0.0    , installed 1.6.3  [Updatable]
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.0.3  [Updatable]
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.1.0  [Updatable]
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
    Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
    Adapter    "yeelight-2"   : 1.4.0    , installed 1.2.1  [Updatable]
    Adapter    "zigbee"       : 1.10.3   , installed 1.8.10 [Updatable]
    Objects and States
    Objects:        7483
    States:         5874
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       58165914   2710235/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          58154890   2703367/sshd: /usr/
    tcp        0      0 192.168.178.46:1883     0.0.0.0:*               LISTEN      1001       58165795   2710044/io.sonoff.0
    tcp        0      0 192.168.178.46:2010     0.0.0.0:*               LISTEN      1001       58169080   2711660/io.hm-rpc.1
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12078      1002/dnsmasq
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       58165557   2709771/iobroker.js
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       58165562   2709771/iobroker.js
    tcp6       0      0 :::22                   :::*                    LISTEN      0          58154892   2703367/sshd: /usr/
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       58163825   2710216/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       58163169   2709798/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       58166661   2710413/io.terminal
    udp        0      0 0.0.0.0:40873           0.0.0.0:*                           108        58158484   2704192/avahi-daemo
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12077      1002/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12074      1002/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12788      818/dhclient
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       58164896   2710024/io.mihome-v
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       58163791   2710178/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       58163792   2710178/io.tuya.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       58165133   2710082/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        58158482   2704192/avahi-daemo
    udp6       0      0 :::37109                :::*                                108        58158485   2704192/avahi-daemo
    udp6       0      0 :::5353                 :::*                                108        58158483   2704192/avahi-daemo
    2024-10-08 20:29:00.150  - info: hm-rpc.0 (2711496) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.18.0, js-controller: 4.0.23
    2024-10-08 20:29:00.528  - info: hm-rpc.0 (2711496) xmlrpc server is trying to listen on 192.168.178.46:2001
    2024-10-08 20:29:00.530  - info: hm-rpc.0 (2711496) xmlrpc client is trying to connect to 192.168.178.47:2001/ with ["http://192.168.178.46:2001","IoBroker:hm-rpc.0:9ad5b2ff275462b51f6c8398ac38d247"]
    2024-10-08 20:29:01.222  - error: hm-rega.0 (2709942) CCU 192.168.178.47 unreachable
    2024-10-08 20:29:01.236  - error: hm-rpc.0 (2711496) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2001
    2024-10-08 20:29:03.134  - info: netatmo-crawler.0 (2711519) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 4.0.23
    2024-10-08 20:29:03.224  - info: netatmo-crawler.0 (2711519) Getting data for stationid:70:ee:50:22:e4:6e
    2024-10-08 20:29:04.358  - info: netatmo-crawler.0 (2711519) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-10-08 20:29:04.909  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-10-08 20:29:18.018  - info: host.IoBroker instance system.adapter.hm-rpc.1 started with pid 2711660
    2024-10-08 20:29:20.587  - info: hm-rpc.1 (2711660) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.18.0, js-controller: 4.0.23
    2024-10-08 20:29:20.822  - info: hm-rpc.1 (2711660) xmlrpc server is trying to listen on 192.168.178.46:2010
    2024-10-08 20:29:20.824  - info: hm-rpc.1 (2711660) xmlrpc client is trying to connect to 192.168.178.47:2010/ with ["http://192.168.178.46:2010","IoBroker:hm-rpc.1:cad2942d81e0f42acf3bc327e357494b"]
    2024-10-08 20:29:23.907  - error: hm-rpc.1 (2711660) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2010
    2024-10-08 20:29:30.101  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 started with pid 2712236
    2024-10-08 20:29:31.242  - info: hm-rpc.0 (2711496) xmlrpc -> 192.168.178.47:2001/ init ["http://192.168.178.46:2001",""]
    2024-10-08 20:29:32.258  - info: hm-rpc.0 (2711496) terminating
    2024-10-08 20:29:32.260  - info: hm-rpc.0 (2711496) Terminated (NO_ERROR): Without reason
    2024-10-08 20:29:32.869  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2024-10-08 20:29:32.870  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.0 because enabled
    2024-10-08 20:29:33.296  - info: netatmo-crawler.0 (2712236) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 4.0.23
    2024-10-08 20:29:33.388  - info: netatmo-crawler.0 (2712236) Getting data for stationid:70:ee:50:22:e4:6e
    2024-10-08 20:29:33.630  - error: hm-rega.0 (2709942) CCU 192.168.178.47 unreachable
    2024-10-08 20:29:34.686  - info: netatmo-crawler.0 (2712236) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-10-08 20:29:35.245  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    • F Flowski
      ```bash
      Skript v.2024-08-12
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      fabio
      HOME=/home/fabio
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M        4.0M         95M
               3794 M total memory
               1214 M used memory
                686 M active memory
                467 M free memory
                246 M buffer memory
               1866 M swap cache
                 99 M total swap
                  4 M used swap
                 95 M free swap
      *** FILESYSTEM ***
      /var:
      3.7G    /var/
      2.1G    /var/log
      817M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.0.22
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        7483
      States:         5874
      Pending Updates: 0
      @flowski sagte in Updateschwierigkeiten js-controller 4.0.23:
      F 1 Antwort Letzte Antwort
        Flowski
        @thomas-braun iobroker restart?
        • F Flowski
          Flowski
          @flowski oder sudo reboot?
          • F Flowski
            @flowski
            Das komplette System. Offenbar war da ein Kernel-Update dabei, weswegen da jetzt per dkms z.B. der pivccu neugebaut werden muss.
              @flowski
              Flowski
              @thomas-braun heißt jetzt für Dummies? Sorry aber bin mit den Befehlen noch nicht ganz fit
              • F Flowski
                @flowski
                iob stop
                sudo reboot
                Wenn die Kiste wieder erreichbar ist
                iob update
                iob upgrade all -y
                • F Offline
                  Flowski
                  @thomas-braun danke für deinen support, jetzt erscheint folgendes im Terminal:
                  fabio@IoBroker:/home/pi $ iob stop
                  fabio@IoBroker:/home/pi $ sudo reboot
                  [sudo] password for fabio:
                  Connection to 192.168.178.46 closed by remote host.
                  Connection to 192.168.178.46 closed.
                  PS C:\Users\mulla> ssh pi@192.168.178.46
                  pi@192.168.178.46's password:
                  Linux IoBroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                  permitted by applicable law.
                  Last login: Tue Oct  8 20:04:34 2024 from 192.168.178.131
                  Wi-Fi is currently blocked by rfkill.
                  Use raspi-config to set the country before use.
                  pi@IoBroker:~ $ iob update
                  pi@IoBroker:~ $ cu fabio
                  -bash: cu: command not found
                  pi@IoBroker:~ $ ssh fabio@192.168.178.46
                  The authenticity of host '192.168.178.46 (192.168.178.46)' can't be established.
                  ECDSA key fingerprint is SHA256:FIhsIFzSsCA3qcV8rP3HPxSWGbgQ71sBXmHraXwu1t0.
                  Are you sure you want to continue connecting (yes/no/[fingerprint])? n
                  Please type 'yes', 'no' or the fingerprint: no
                  Host key verification failed.
                  pi@IoBroker:~ $ su fabio
                  Password:
                  fabio@IoBroker:/home/pi $ iob update
                  fabio@IoBroker:/home/pi $ iob upgrade all -y
                  Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.19
                  Update hm-rega from @4.0.0 to @5.0.0
                  NPM version: 10.8.2
                  Installing iobroker.hm-rega@5.0.0... (System call)
                  added 2 packages, removed 399 packages, and changed 2 packages in 16s
                  131 packages are looking for funding
                    run `npm fund` for details
                  Update "system.adapter.hm-rega.0"
                  upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                  upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                  upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                  upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                  Update discovery from @4.5.0 to @5.0.0
                  NPM version: 10.8.2
                  Installing iobroker.discovery@5.0.0... (System call)
                  changed 1 package in 11s
                  Update "system.adapter.discovery.0"
                  upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                  upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                  upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                  upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                  upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                  upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                  upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                  Update admin from @7.0.22 to @7.1.5
                  host.IoBroker Adapter "system.adapter.admin.0" is stopped.
                  NPM version: 10.8.2
                  Installing iobroker.admin@7.1.5... (System call)
                  added 11 packages, removed 3 packages, and changed 11 packages in 21s
                  Update "system.adapter.admin.0"
                  upload [68] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                  upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                  upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
                  upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
                  upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
                  upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
                  upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
                  upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
                  upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
                  upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
                  upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
                  upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
                  upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
                  upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                  upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                  host.IoBroker Adapter "system.adapter.admin.0" is started
                  Update zigbee from @1.8.10 to @1.10.3
                  host.IoBroker Adapter "system.adapter.zigbee.0" is stopped.
                  NPM version: 10.8.2
                  Installing iobroker.zigbee@1.10.3... (System call)
                  added 18 packages, removed 19 packages, and changed 24 packages in 33s
                  120 packages are looking for funding
                  Update "system.adapter.zigbee.0"
                  upload [331] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                  upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/E2213.png img/E2213.png image/png
                  upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
                  upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue-smart-button.png img/hue-smart-button.png image/png
                  upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
                  upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_fuzo_outdoor_wall_light.png img/philips_fuzo_outdoor_wall_light.png image/png
                  upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_4.png img/philips_hue_argenta_4.png image/png
                  upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_ambiance.png img/philips_hue_gu10_ambiance.png image/png
                  upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
                  upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/previous_track.png img/previous_track.png image/png
                  upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                  upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                  upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                  upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                  upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                  upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                  upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                  upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                  upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                  upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                  upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                  upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                  upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                  upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                  upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                  upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                  upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                  upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                  upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                  upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                  upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                  upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                  upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                  upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                  host.IoBroker Adapter "system.adapter.zigbee.0" is started
                  Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.0
                  • F Flowski
                    Password:
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    NPM version: 10.8.2
                    Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users.
                    Den Fingerpring für den fabio musst du schon akzeptieren, damit das funktioniert.
                    Und warum hast du nicht gleich den 'pi' verwendet, wenn es denn doch schon gab?
                    iob stop
                    iob ugrade self
                    iob upgrade all -y
                    • F Offline
                      Flowski
                      schrieb am zuletzt editiert von Flowski
                      puh ok 🤕 :)
                      heisst ssh fabio@192.168.178.46
                      dann ecdsa key ... mit yes
                      Zitat:
                      Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users. sorry stehe auf dem Schlauch :( muss da sicherlich noch was umstellen bevor ich die drei Befehle eingebe aber begreife es grad nicht
                      • F Flowski
                        puh ok 🤕 :)
                        @flowski
                        Jeder user hat auf einem Linux-System ein eigenes home-Verzeichnis, indem die eigenen Dateien abgelegt werden.
                          @flowski
                          Flowski
                          @thomas-braun so: fabio@IoBroker:~ $?
                          • F Flowski
                            @flowski
                            Ja. Die Tilde repräsentiert das home des users.
                              @flowski
                              Flowski
                              @thomas-braun anbei der log, iobroker ist jetzt aktuell nicht erreichbar im Browser.. brauchts jetzt nochmal ein iob reboot?
                              fabio@IoBroker:/home/pi $  ssh fabio@192.168.178.46
                              Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
                              Warning: Permanently added '192.168.178.46' (ECDSA) to the list of known hosts.
                              fabio@192.168.178.46's password:
                              fabio@IoBroker:~ $ iob stop
                              fabio@IoBroker:~ $ iob upgrade self
                              Update js-controller from @4.0.23 to @6.0.11
                              Stopped Objects DB
                              Stopped States DB
                              NPM version: 10.8.2
                              Installing iobroker.js-controller@6.0.11... (System call)
                              added 10 packages, removed 67 packages, and changed 44 packages in 52s
                              121 packages are looking for funding
                              fabio@IoBroker:~ $ iob upgrade all -y
                              Update yeelight-2 from @1.2.1 to @1.4.0
                              NPM version: 10.8.2
                              Installing iobroker.yeelight-2@1.4.0... (System call)
                              added 2 packages, removed 32 packages, and changed 5 packages in 12s
                              Update "system.adapter.yeelight-2.0"
                              upload [20] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/1.png icons/1.png image/png
                              upload [19] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/2.png icons/2.png image/png
                              upload [18] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/3.png icons/3.png image/png
                              upload [17] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/4.png icons/4.png image/png
                              upload [16] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/5.png icons/5.png image/png
                              upload [15] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/6.png icons/6.png image/png
                              upload [14] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/7.png icons/7.png image/png
                              upload [13] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/bslamp1.png icons/bslamp1.png image/png
                              upload [12] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling1.png icons/ceiling1.png image/png
                              upload [11] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling10.png icons/ceiling10.png image/png
                              upload [10] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling3.png icons/ceiling3.png image/png
                              upload [9] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling4.png icons/ceiling4.png image/png
                              upload [8] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/color.png icons/color.png image/png
                              upload [7] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/desklamp.png icons/desklamp.png image/png
                              upload [6] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/mono.png icons/mono.png image/png
                              upload [5] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/stripe.png icons/stripe.png image/png
                              upload [4] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index.html index.html text/html
                              upload [3] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index_m.html index_m.html text/html
                              upload [2] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/lan.jpg lan.jpg image/jpeg
                              upload [1] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/words.js words.js application/javascript
                              upload [0] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/yeelight.png yeelight.png image/png
                              Update whatsapp-cmb from @0.2.3 to @0.3.0
                              NPM version: 10.8.2
                              Installing iobroker.whatsapp-cmb@0.3.0... (System call)
                              changed 1 package in 8s
                              Update "system.adapter.whatsapp-cmb.0"
                              Update "system.adapter.whatsapp-cmb.1"
                              upload [17] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/admin.d.ts admin.d.ts video/mp2t
                              upload [16] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/blockly.js blockly.js application/javascript
                              upload [15] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [14] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [13] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [12] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [11] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [10] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [9] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [8] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [7] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [6] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [5] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [4] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/index_m.html index_m.html text/html
                              upload [3] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/style.css style.css text/css
                              upload [2] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/tsconfig.json tsconfig.json application/json
                              upload [1] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/whatsapp-cmb.png whatsapp-cmb.png image/png
                              upload [0] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/words.js words.js application/javascript
                              Update tuya from @3.15.0 to @3.16.0
                              NPM version: 10.8.2
                              Installing iobroker.tuya@3.16.0... (System call)
                              added 73 packages, removed 1 package, and changed 3 packages in 24s
                              124 packages are looking for funding
                              Update "system.adapter.tuya.0"
                              upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                              upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                              upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                              upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                              Update trashschedule from @3.2.0 to @3.3.0
                              NPM version: 10.8.2
                              Installing iobroker.trashschedule@3.3.0... (System call)
                              added 1 package, and changed 1 package in 9s
                              Update "system.adapter.trashschedule.0"
                              upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                              upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                              Update tankerkoenig from @3.1.0 to @3.4.0
                              host.IoBroker Adapter "system.adapter.tankerkoenig.0" is stopped.
                              NPM version: 10.8.2
                              Installing iobroker.tankerkoenig@3.4.0... (System call)
                              removed 1 package, and changed 1 package in 10s
                              Update "system.adapter.tankerkoenig.0"
                              upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
                              upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
                              upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                              upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
                              upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                              host.IoBroker Adapter "system.adapter.tankerkoenig.0" is started
                              Update sonoff from @3.0.3 to @3.1.2
                              NPM version: 10.8.2
                              Installing iobroker.sonoff@3.1.2... (System call)
                              Update "system.adapter.sonoff.0"
                              upload [15] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [14] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [13] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [12] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [11] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                              upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
                              upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
                              upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                              upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
                              Update mqtt-client from @1.6.3 to @2.0.0
                              NPM version: 10.8.2
                              Installing iobroker.mqtt-client@2.0.0... (System call)
                              added 15 packages, and changed 1 package in 10s
                              upload [13] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [12] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [11] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [10] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [9] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [8] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [7] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [5] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [4] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [3] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [2] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonConfig.json jsonConfig.json application/json
                              upload [1] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonCustom.json jsonCustom.json application/json
                              upload [0] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/mqtt-client.png mqtt-client.png image/png
                              Update mihome-vacuum from @3.8.6 to @4.2.0
                              NPM version: 10.8.2
                              Installing iobroker.mihome-vacuum@4.2.0... (System call)
                              added 3 packages, removed 4 packages, and changed 9 packages in 2m
                              Update "system.adapter.mihome-vacuum.0"
                              upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                              upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                              upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                              upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                              upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                              upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                              upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                              upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                              upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                              upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                              upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                              Update javascript from @7.8.0 to @8.8.3
                              NPM version: 10.8.2
                              Installing iobroker.javascript@8.8.3... (System call)
                              added 1 package, removed 1 package, and changed 6 packages in 1m
                              Update "system.adapter.javascript.0"
                              upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                              upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                              upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                              upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                              upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                              upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                              upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                              upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                              upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                              upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                              upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                              upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                              upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                              upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                              upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                              upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                              upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                              upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                              upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                              upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                              upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                              upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                              upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                              upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                              upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                              upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                              upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                              upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                              upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                              upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                              upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                              upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                              upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                              upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                              upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                              upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                              upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                              upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                              upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                              upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                              upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                              upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                              upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                              upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                              upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                              upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                              upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                              upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                              upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                              upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                              upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                              Update ical from @1.14.3 to @1.15.0
                              NPM version: 10.8.2
                              Installing iobroker.ical@1.15.0... (System call)
                              added 1 package, and changed 1 package in 11s
                              Update "system.adapter.ical.0"
                              upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                              upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                              upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                              upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                              Update homeconnect from @1.3.0 to @1.4.1
                              NPM version: 10.8.2
                              Installing iobroker.homeconnect@1.4.1... (System call)
                              added 1 package, and changed 2 packages in 16s
                              Update "system.adapter.homeconnect.0"
                              upload [15] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect-880x800.png homeconnect-880x800.png image/png
                              upload [14] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect.png homeconnect.png image/png
                              upload [13] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [12] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [11] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [10] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [9] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [8] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [7] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [5] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [4] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [3] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [2] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/index_m.html index_m.html text/html
                              upload [1] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/style.css style.css text/css
                              upload [0] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/words.js words.js application/javascript
                              Update hm-rpc from @1.16.0 to @2.0.2
                              NPM version: 10.8.2
                              Installing iobroker.hm-rpc@2.0.2... (System call)
                              added 1 package, and changed 2 packages in 10s
                              Update "system.adapter.hm-rpc.0"
                              Update "system.adapter.hm-rpc.1"
                              upload [279] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                              upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                              upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/157_hmip-broll_hmip-bbl_thumb.png icons/157_hmip-broll_hmip-bbl_thumb.png image/png
                              upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/202_hmip-wrcr_thumb_right.png icons/202_hmip-wrcr_thumb_right.png image/png
                              upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/3_hm-lc-sw4-sm_thumb.png icons/3_hm-lc-sw4-sm_thumb.png image/png
                              upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/50_hm-sec-mdir_thumb.png icons/50_hm-sec-mdir_thumb.png image/png
                              upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/58_hmw-sen-sc-12-fm_thumb.png icons/58_hmw-sen-sc-12-fm_thumb.png image/png
                              upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/68_hm-lc-sw4-dr_thumb.png icons/68_hm-lc-sw4-dr_thumb.png image/png
                              upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/78_hm-ou-led16_thumb.png icons/78_hm-ou-led16_thumb.png image/png
                              upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/86_hm-rc-sec4-2_thumb.png icons/86_hm-rc-sec4-2_thumb.png image/png
                              upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/98_hm-sec-sco_thumb.png icons/98_hm-sec-sco_thumb.png image/png
                              upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/HmIPW-FALMOT-C12.png icons/HmIPW-FALMOT-C12.png image/png
                              upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/group_hm-cc-vg-1.png icons/group_hm-cc-vg-1.png image/png
                              upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-cap-moist.png icons/hb-uni-sen-cap-moist.png image/png
                              upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
                              upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
                              upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
                              upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
                              upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
                              upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
                              upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
                              upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
                              upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
                              upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
                              upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
                              upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
                              upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
                              upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
                              upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
                              upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
                              upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
                              upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/jsonConfig.json jsonConfig.json application/json
                              upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
                              Update daikin-cloud from @0.3.0 to @0.4.8
                              NPM version: 10.8.2
                              Installing iobroker.daikin-cloud@0.4.8... (System call)
                              added 2 packages, removed 14 packages, and changed 4 packages in 11s
                              113 packages are looking for funding
                              Update "system.adapter.daikin-cloud.0"
                              upload [16] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                              upload [15] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                              upload [14] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
                              upload [13] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [12] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [11] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [10] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [9] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [8] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [7] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/jsonConfig.json jsonConfig.json application/json
                              upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                              upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                              Update backitup from @2.10.11 to @3.0.22
                              host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
                              NPM version: 10.8.2
                              Installing iobroker.backitup@3.0.22... (System call)
                              added 5 packages, and changed 20 packages in 17s
                              Update "system.adapter.backitup.0"
                              upload [90] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                              upload [80] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                              upload [70] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/main.0fac7bdb.js custom/static/js/main.0fac7bdb.js application/javascript
                              upload [60] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js application/javascript
                              upload [50] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js application/javascript
                              upload [40] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/googledrive.jsonConfig.json5 googledrive.jsonConfig.json5 application/json5
                              upload [30] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/main.jsonConfig.json5 main.jsonConfig.json5 application/json5
                              upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
                              upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
                              upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
                              upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
                              upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
                              upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
                              upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
                              upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
                              upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css static/css/main.bd1167d4.css text/css
                              upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/245.7caf1dae.chunk.js static/js/245.7caf1dae.chunk.js application/javascript
                              upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js static/js/main.2cca4954.js application/javascript
                              upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js.LICENSE.txt static/js/main.2cca4954.js.LICENSE.txt text/plain
                              upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/media/history.d21dcfa508bd8a624c85.png static/media/history.d21dcfa508bd8a624c85.png image/png
                              upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                              upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                              upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                              upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                              upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
                              upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                              upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
                              host.IoBroker Adapter "system.adapter.backitup.0" is started
                              fabio@IoBroker:~ $
                              • F Flowski
                                Stopped Objects DB
                                Stopped States DB
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                NPM version: 10.8.2
                                fabio@IoBroker:~ $
                                @flowski
                                Was kommt bei einem
                                iob update
                                um's Eck?
                                F 1 Antwort Letzte Antwort
                                  @flowski
                                  Was kommt bei einem
                                  iob update
                                  um's Eck?
                                  Flowski
                                  fabio@IoBroker:~ $ iob update
                                  Used repository: stable
                                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                  Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                                  Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
                                  Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                  Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                  Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                  Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                                  Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                  Controller "js-controller": 6.0.11   , installed 6.0.11
                                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                  Adapter    "meross"       : 1.17.0   , installed 1.17.0
                                  Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                  Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                  Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
                                  Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                  Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                  Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                  Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                  Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                  Adapter    "web"          : 6.2.5    , installed 6.2.5
                                  Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                  Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                  fabio@IoBroker:~ $
                                  • F Flowski
                                    fabio@IoBroker:~ $
                                    @flowski
                                    Gut.
                                    iob start admin
                                    und die Kiste sollte wieder an den Start kommen.
                                      @flowski
                                      Gut.
                                      iob start admin
                                      Flowski
                                      @thomas-braun bislang tut sich nix
                                      fabio@IoBroker:~ $ iob start admin
                                      fabio@IoBroker:~ $
                                      • F Flowski
                                        fabio@IoBroker:~ $
                                        @flowski
                                        iob diag
                                          @flowski
                                          iob diag
                                          Flowski
                                          bash
                                          Skript v.2024-08-12
                                          *** BASE SYSTEM ***
                                             Static hostname: IoBroker
                                                   Icon name: computer
                                            Operating System: Debian GNU/Linux 11 (bullseye)
                                                      Kernel: Linux 6.1.21-v8+
                                                Architecture: arm64
                                          OS is similar to:
                                          Model           : Raspberry Pi 4 Model B Rev 1.2
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          Systemuptime and Load:
                                           21:35:42 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                                          CPU threads: 4
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          ~ Under-voltage has occurred
                                          ~ Arm frequency capping has occurred
                                          ~ Throttling has occurred
                                          ~ Soft temperature limit has occurred
                                          *** Time and Time Zones ***
                                                         Local time: Tue 2024-10-08 21:35:42 CEST
                                                     Universal time: Tue 2024-10-08 19:35:42 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          fabio
                                          HOME=/home/fabio
                                          GROUPS=fabio sudo iobroker
                                          js-controller is not running
                                          *** Display-Server-Setup ***
                                          Display-Server: false
                                          Desktop:
                                          Terminal:       tty
                                          Boot Target:    multi-user.target
                                          *** MEMORY ***
                                          Mem:            3.8G        107M        920M        1.0M        2.8G        3.6G
                                          Swap:            99M          0B         99M
                                          Total:          3.9G        107M        1.0G
                                          Active iob-Instances:   1
                                                   3794 M total memory
                                                    107 M used memory
                                                    213 M active memory
                                                   2439 M inactive memory
                                                    920 M free memory
                                                     68 M buffer memory
                                                   2698 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          top - 21:35:43 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                                          Tasks: 162 total,   1 running, 161 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   3794.3 total,    919.3 free,    107.8 used,   2767.3 buff/cache
                                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3610.0 avail Mem
                                          *** FAILED SERVICES ***
                                            UNIT                LOAD   ACTIVE SUB    DESCRIPTION
                                          * iobroker.service    loaded failed failed ioBroker Server
                                          * pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
                                          2 loaded units listed.
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       59G  8.7G   48G  16% /
                                          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                          tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                          /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
                                          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                          tmpfs          tmpfs     380M     0  380M   0% /run/user/1002
                                          [Tue Oct  8 20:46:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:83:48 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=2a0531f8-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Tue Oct  8 20:46:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Tue Oct  8 20:46:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Tue Oct  8 20:46:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          Show mounted filesystems:
                                          TARGET  SOURCE         FSTYPE OPTIONS
                                          /       /dev/mmcblk0p2 ext4   rw,noatime
                                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                          3.7G    /var/
                                          2.1G    /var/log/journal/664a8e581ec84405863df59a10cf9293
                                          2.1G    /var/log
                                          817M    /var/lib
                                          Archived and active journals take up 8.0M in the file system.
                                          /opt/iobroker/backups:
                                          58M     /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          913M    /opt/iobroker/iobroker-data/
                                          840M    /opt/iobroker/iobroker-data/files
                                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                          16M     /opt/iobroker/iobroker-data/objects.jsonl
                                          14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                                          USB-Devices by-id:
                                          /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                          /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03D64S-if00-port0
                                          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v20.18.0
                                          /usr/bin/node           v20.18.0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          /usr/bin/corepack       0.29.3
                                          nodejs:
                                            Installed: 20.18.0-1nodesource1
                                            Candidate: 20.18.0-1nodesource1
                                            Version table:
                                           *** 20.18.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                               20.17.0-1nodesource1 1001
                                               20.16.0-1nodesource1 1001
                                               20.15.1-1nodesource1 1001
                                               20.15.0-1nodesource1 1001
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                               12.22.12~dfsg-1~deb11u5 500
                                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                               12.22.12~dfsg-1~deb11u4 500
                                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          iobroker is not running on this host.
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  6.0.11
                                          admin:          7.1.5
                                          javascript:     8.8.3
                                          nodejs modules from github:     0
                                          Adapter State
                                            system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                                            system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                                            system.adapter.daikin-cloud.0           : daikin-cloud          : IoBroker                                 - disabled
                                            system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                                            system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                                            system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                                            system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled
                                            system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                                            system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                                            system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
                                            system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                                            system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                                            system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                                            system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                                            system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                                            system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                                            system.adapter.mihome.0                 : mihome                : IoBroker                                 - disabled, port: 9898, bind: 0.0.0.0
                                            system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 - disabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.netatmo-crawler.0        : netatmo-crawler       : IoBroker                                 -  enabled
                                            system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                                            system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                                            system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                                            system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                            system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                                            system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                                            system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                                            system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                                            system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                                            system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): stable
                                          Upgrade policy: none
                                          Installed ioBroker-Instances
                                          Objects and States
                                          Objects:        7521
                                          States:         5852
                                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                                          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14606      1044/dnsmasq
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13147      1036/sshd: /usr/sbi
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          13149      1036/sshd: /usr/sbi
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12941      433/avahi-daemon: r
                                          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14605      1044/dnsmasq
                                          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14602      1044/dnsmasq
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13052      849/dhclient
                                          udp        0      0 0.0.0.0:33135           0.0.0.0:*                           108        12943      433/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                108        12942      433/avahi-daemon: r
                                          udp6       0      0 :::58117                :::*                                108        12944      433/avahi-daemon: r
                                          2024-10-08 21:11:10.669  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:10.732  - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:10.733  - info: host.IoBroker instance system.adapter.ham.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:10.734  - info: host.IoBroker instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:10.747  - info: host.IoBroker instance system.adapter.whatsapp-cmb.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:11.096  - info: host.IoBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.whatsapp-cmb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.tankerkoenig.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rega.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:11.098  - warn: host.IoBroker instance system.adapter.hm-rpc.0 terminated due to SIGTERM
                                          2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code null ()
                                          2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.sonoff.0 terminated due to SIGTERM
                                          2024-10-08 21:11:11.099  - info: host.IoBroker instance system.adapter.sonoff.0 terminated with code null ()
                                          2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.web.0 terminated due to SIGTERM
                                          2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.web.0 terminated with code null ()
                                          2024-10-08 21:11:11.100  - warn: host.IoBroker instance system.adapter.zigbee.0 terminated due to SIGTERM
                                          2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.zigbee.0 terminated with code null ()
                                          2024-10-08 21:11:11.101  - warn: host.IoBroker instance system.adapter.hm-rpc.1 terminated due to SIGTERM
                                          2024-10-08 21:11:11.101  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code null ()
                                          2024-10-08 21:11:11.859  - info: tuya.0 (1498) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2024-10-08 21:11:12.433  - info: host.IoBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2024-10-08 21:11:13.061  - info: meross.0 (1382) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2024-10-08 21:11:13.634  - info: host.IoBroker instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2024-10-08 21:11:13.635  - info: host.IoBroker All instances are stopped.
                                          2024-10-08 21:11:13.863  - info: host.IoBroker terminated
        v.2024-08-12
                                                   Icon name: computer
                                                Architecture: arm64
                                          Kernel:                 aarch64
                                          Userland:               64 bit
                                          User-ID:                1002
                                          Pending OS-Updates:     0
                                          Pending iob updates:    0
                                          Nodejs-Installation:
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                          MEMORY:
                                          Mem:            3.8G        111M        920M        1.0M        2.8G        3.6G
                                          Swap:            99M          0B         99M
                                          Total:          3.9G        111M        1.0G
                                          ioBroker Core:          js-controller           6.0.11
        admin                   7.1.5
                                          ioBroker Status:        iobroker is not running on this host.
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                7521
                                          States:                 5852
                                          Size of iob-Database:
                                          7.2M    /opt/iobroker/iobroker-data/states.jsonl
