  3. Einsteigerfragen
  4. NUC-Proxmox-steigender Ram
    apollon77A
137 Beiträge 13 Kommentatoren 37.2k Aufrufe 12 Beobachtet
  • P peterfido
    @crunchip
    Redis ist bei meinem Testsystem nicht aktiv.
    2024-09-25 10:57:57.542 - info: host.ioTest iobroker.js-controller version 6.0.11 js-controller starting
    2024-09-25 10:57:57.543 - info: host.ioTest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-09-25 10:57:57.543 - info: host.ioTest hostname: ioTest, node: v20.17.0
    2024-09-25 10:57:57.544 - info: host.ioTest ip addresses: 192.168.56.243 fe80::be24:11ff:fee6:705f
    2024-09-25 10:57:57.771 - info: host.ioTest connected to Objects and States
    2024-09-25 10:57:57.780 - info: host.ioTest Node.js version has changed from unknown to 20.17.0
    2024-09-25 10:57:57.786 - info: host.ioTest Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2024-09-25 10:57:57.786 - info: host.ioTest added notifications configuration of host
    2024-09-25 10:57:57.892 - info: host.ioTest 3 instances found
    2024-09-25 10:57:57.894 - info: host.ioTest starting 3 instances
    2024-09-25 10:57:57.906 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 10717
    2024-09-25 10:57:58.391 - info: admin.0 (10717) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 10:57:58.399 - info: admin.0 (10717) requesting all objects
    2024-09-25 10:57:58.434 - info: admin.0 (10717) received all objects
    2024-09-25 10:57:58.438 - info: admin.0 (10717) Request actual repository...
    2024-09-25 10:57:58.445 - info: host.ioTest Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2024-09-25 10:57:58.447 - info: admin.0 (10717) socket.io server listening on port 8081
    2024-09-25 10:57:58.447 - info: admin.0 (10717) http server listening on port 8081
    2024-09-25 10:57:58.448 - info: admin.0 (10717) Use link "http://127.0.0.1:8081" to configure.
    2024-09-25 10:57:58.549 - warn: admin.0 (10717) Repository cannot be read: Active repo - stable
    2024-09-25 10:57:58.556 - warn: admin.0 (10717) Active repository "stable" cannot be read
    2024-09-25 10:58:00.709 - info: admin.0 (10717) Repository received successfully.
    2024-09-25 10:58:01.977 - info: host.ioTest instance system.adapter.backitup.0 in version "3.0.22" started with pid 10758
    2024-09-25 10:58:02.421 - info: backitup.0 (10758) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 10:58:02.435 - info: backitup.0 (10758) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-09-25 10:58:05.976 - info: host.ioTest instance system.adapter.discovery.0 in version "5.0.0" started with pid 10773
    2024-09-25 10:58:06.372 - info: discovery.0 (10773) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 11:34:33.609 - info: admin.0 (10717) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 11:35:16.156 - info: backitup.0 (10758) cleaned everything up...
    2024-09-25 11:35:16.156 - info: admin.0 (10717) terminating http server on port 8081
    2024-09-25 11:35:16.155 - info: host.ioTest received SIGTERM
    2024-09-25 11:35:16.157 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-09-25 11:35:16.157 - info: host.ioTest stopInstance system.adapter.backitup.0 (force=false, process=true)
    2024-09-25 11:35:16.157 - info: host.ioTest stopInstance system.adapter.discovery.0 (force=false, process=true)
    2024-09-25 11:35:16.161 - info: admin.0 (10717) Got terminate signal TERMINATE_YOURSELF
    2024-09-25 11:35:16.161 - info: backitup.0 (10758) Got terminate signal TERMINATE_YOURSELF
    2024-09-25 11:35:16.161 - info: discovery.0 (10773) Got terminate signal TERMINATE_YOURSELF
    2024-09-25 11:35:16.162 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
    2024-09-25 11:35:16.162 - info: discovery.0 (10773) terminating
    2024-09-25 11:35:16.161 - info: backitup.0 (10758) terminating
    2024-09-25 11:35:16.162 - info: backitup.0 (10758) Terminated (NO_ERROR): Without reason
    2024-09-25 11:35:16.162 - info: discovery.0 (10773) Terminated (NO_ERROR): Without reason
    2024-09-25 11:35:16.162 - info: admin.0 (10717) terminating
    2024-09-25 11:35:16.163 - info: host.ioTest stopInstance system.adapter.backitup.0 send kill signal
    2024-09-25 11:35:16.163 - info: host.ioTest stopInstance system.adapter.discovery.0 send kill signal
    2024-09-25 11:35:16.163 - info: admin.0 (10717) Terminated (NO_ERROR): Without reason
    2024-09-25 11:35:16.657 - info: discovery.0 (10773) terminating
    2024-09-25 11:35:16.658 - info: backitup.0 (10758) terminating
    2024-09-25 11:35:16.659 - info: admin.0 (10717) terminating
    2024-09-25 11:35:16.694 - info: host.ioTest instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2024-09-25 11:35:16.694 - info: host.ioTest instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2024-09-25 11:35:16.735 - info: host.ioTest instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2024-09-25 11:35:16.735 - info: host.ioTest All instances are stopped.
    2024-09-25 11:35:16.779 - info: host.ioTest terminated
    2024-09-25 11:35:23.318 - info: host.ioTest iobroker.js-controller version 6.0.11 js-controller starting
    2024-09-25 11:35:23.320 - info: host.ioTest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-09-25 11:35:23.320 - info: host.ioTest hostname: ioTest, node: v20.17.0
    2024-09-25 11:35:23.320 - info: host.ioTest ip addresses: 192.168.56.243 fe80::be24:11ff:fee6:705f
    2024-09-25 11:35:23.606 - info: host.ioTest connected to Objects and States
    2024-09-25 11:35:23.612 - info: host.ioTest added notifications configuration of host
    2024-09-25 11:35:23.785 - info: host.ioTest 3 instances found
    2024-09-25 11:35:23.787 - info: host.ioTest starting 3 instances
    2024-09-25 11:35:23.836 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeCurrent"
    2024-09-25 11:35:23.934 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 329
    2024-09-25 11:35:23.972 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewest"
    2024-09-25 11:35:23.973 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewestNext"
    2024-09-25 11:35:23.975 - info: host.ioTest Delete state "system.host.ioTest.versions.npmCurrent"
    2024-09-25 11:35:23.977 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewest"
    2024-09-25 11:35:23.978 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewestNext"
    2024-09-25 11:35:23.979 - info: host.ioTest Some obsolete host states deleted.
    2024-09-25 11:35:24.476 - info: admin.0 (329) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 11:35:24.486 - info: admin.0 (329) requesting all objects
    2024-09-25 11:35:24.655 - info: admin.0 (329) received all objects
    2024-09-25 11:35:24.732 - info: admin.0 (329) socket.io server listening on port 8081
    2024-09-25 11:35:24.733 - info: admin.0 (329) http server listening on port 8081
    2024-09-25 11:35:24.733 - info: admin.0 (329) Use link "http://127.0.0.1:8081" to configure.
    2024-09-25 11:35:27.900 - info: host.ioTest instance system.adapter.backitup.0 in version "3.0.22" started with pid 370
    2024-09-25 11:35:28.009 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 11:35:28.315 - info: backitup.0 (370) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 11:35:28.327 - info: backitup.0 (370) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-09-25 11:35:31.888 - info: host.ioTest instance system.adapter.discovery.0 in version "5.0.0" started with pid 385
    2024-09-25 11:35:32.281 - info: discovery.0 (385) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 11:35:36.379 - info: admin.0 (329) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 11:35:36.698 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 11:38:43.322 - info: host.ioTest iobroker add javascript
    2024-09-25 11:38:43.887 - info: host.ioTest iobroker NPM version: 10.8.2
    2024-09-25 11:38:43.888 - info: host.ioTest iobroker Installing iobroker.javascript@8.7.6... (System call)
    2024-09-25 11:38:49.868 - info: host.ioTest iobroker
    2024-09-25 11:38:49.869 - info: host.ioTest iobroker added 16 packages in 6s72 packages are looking for funding run `npm fund` for details
    2024-09-25 11:38:49.881 - info: host.ioTest iobroker host.ioTest install adapter javascript
    2024-09-25 11:38:49.897 - info: host.ioTest iobroker upload [881] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    2024-09-25 11:38:49.981 - info: host.ioTest iobroker upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js application/javascript
    2024-09-25 11:38:50.136 - info: host.ioTest iobroker upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_object.js google-blockly/own/blocks_object.js application/javascript
    2024-09-25 11:38:50.226 - info: host.ioTest iobroker upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/864.4c85ffd6.chunk.css static/css/864.4c85ffd6.chunk.css text/css
    2024-09-25 11:38:50.596 - info: host.ioTest iobroker upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/173.4e774f7f.chunk.js static/js/173.4e774f7f.chunk.js application/javascript
    2024-09-25 11:38:50.745 - info: host.ioTest iobroker upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/26.79c81b4e.chunk.js static/js/26.79c81b4e.chunk.js application/javascript
    2024-09-25 11:38:51.495 - info: host.ioTest iobroker upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/320.d9816b46.chunk.js.map static/js/320.d9816b46.chunk.js.map application/json
    2024-09-25 11:38:51.817 - info: host.ioTest iobroker upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.168f947c.chunk.js.map static/js/409.168f947c.chunk.js.map application/json
    2024-09-25 11:38:52.050 - info: host.ioTest iobroker upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/456.97a46315.chunk.js.LICENSE.txt static/js/456.97a46315.chunk.js.LICENSE.txt text/plain
    2024-09-25 11:38:52.655 - info: host.ioTest iobroker upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/61.913ccfa8.chunk.js.map static/js/61.913ccfa8.chunk.js.map application/json
    2024-09-25 11:38:53.181 - info: host.ioTest iobroker upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/709.88d87b7c.chunk.js.map static/js/709.88d87b7c.chunk.js.map application/json
    2024-09-25 11:38:53.457 - info: host.ioTest iobroker upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/826.76c09000.chunk.js.map static/js/826.76c09000.chunk.js.map application/json
    2024-09-25 11:38:53.957 - info: host.ioTest iobroker upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/880.e4029d50.chunk.js static/js/880.e4029d50.chunk.js application/javascript
    2024-09-25 11:38:54.341 - info: host.ioTest iobroker upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/961.02d44700.chunk.js.map static/js/961.02d44700.chunk.js.map application/json
    2024-09-25 11:38:54.428 - info: host.ioTest iobroker upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.720010c8.js static/js/main.720010c8.js application/javascript
    2024-09-25 11:38:54.517 - info: host.ioTest iobroker upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Cellar.7ec1b1803a2437c8b78c.svg static/media/Cellar.7ec1b1803a2437c8b78c.svg image/svg+xml
    2024-09-25 11:38:54.604 - info: host.ioTest iobroker upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Living Room.3c380ab767be35f904e1.svg static/media/Living Room.3c380ab767be35f904e1.svg image/svg+xml
    2024-09-25 11:38:54.623 - info: host.ioTest iobroker upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/People.12a7e9127e72f3259186.svg static/media/People.12a7e9127e72f3259186.svg image/svg+xml
    2024-09-25 11:38:54.641 - info: host.ioTest iobroker upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Security.1ec78971bd34efa950f8.svg static/media/Security.1ec78971bd34efa950f8.svg image/svg+xml
    2024-09-25 11:38:54.656 - info: host.ioTest iobroker upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Storeroom.7de4e6f3364554459b8a.svg static/media/Storeroom.7de4e6f3364554459b8a.svg image/svg+xml
    2024-09-25 11:38:54.674 - info: host.ioTest iobroker upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
    2024-09-25 11:38:54.690 - info: host.ioTest iobroker upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
    2024-09-25 11:38:54.706 - info: host.ioTest iobroker upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
    2024-09-25 11:38:54.729 - info: host.ioTest iobroker upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
    2024-09-25 11:38:54.768 - info: host.ioTest iobroker upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
    2024-09-25 11:38:54.770 - info: host.ioTest iobroker upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
    2024-09-25 11:38:54.773 - info: host.ioTest iobroker upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
    2024-09-25 11:38:54.775 - info: host.ioTest iobroker upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
    2024-09-25 11:38:54.778 - info: host.ioTest iobroker upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
    2024-09-25 11:38:54.780 - info: host.ioTest iobroker upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
    2024-09-25 11:38:54.790 - info: host.ioTest iobroker upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
    2024-09-25 11:38:54.793 - info: host.ioTest iobroker upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
    2024-09-25 11:38:54.797 - info: host.ioTest iobroker upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
    2024-09-25 11:38:54.800 - info: host.ioTest iobroker upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
    2024-09-25 11:38:54.814 - info: host.ioTest iobroker upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
    2024-09-25 11:38:54.817 - info: host.ioTest iobroker upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
    2024-09-25 11:38:54.819 - info: host.ioTest iobroker upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
    2024-09-25 11:38:54.821 - info: host.ioTest iobroker upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
    2024-09-25 11:38:54.866 - info: host.ioTest iobroker upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
    2024-09-25 11:38:54.871 - info: host.ioTest iobroker upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
    2024-09-25 11:38:54.875 - info: host.ioTest iobroker upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
    2024-09-25 11:38:54.877 - info: host.ioTest iobroker upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
    2024-09-25 11:38:54.879 - info: host.ioTest iobroker upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
    2024-09-25 11:38:54.881 - info: host.ioTest iobroker upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
    2024-09-25 11:38:54.883 - info: host.ioTest iobroker upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
    2024-09-25 11:38:54.902 - info: host.ioTest iobroker host.ioTest object _design/script created/updated
    2024-09-25 11:38:54.903 - info: host.ioTest iobroker host.ioTest object script.js created/updated
    2024-09-25 11:38:54.904 - info: host.ioTest iobroker host.ioTest object script.js.common created/updated
    2024-09-25 11:38:54.904 - info: host.ioTest iobroker host.ioTest object script.js.global created/updated
    2024-09-25 11:38:54.906 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript created/updated
    2024-09-25 11:38:54.924 - info: host.ioTest iobroker host.ioTest create instance javascript
    2024-09-25 11:38:54.926 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.alive created
    2024-09-25 11:38:54.926 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.connected created
    2024-09-25 11:38:54.927 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.compactMode created
    2024-09-25 11:38:54.928 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.cpu created
    2024-09-25 11:38:54.929 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.cputime created
    2024-09-25 11:38:54.931 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.memHeapUsed created
    2024-09-25 11:38:54.932 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.memHeapTotal created
    2024-09-25 11:38:54.933 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.memRss created
    2024-09-25 11:38:54.934 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.uptime created
    2024-09-25 11:38:54.935 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.inputCount created
    2024-09-25 11:38:54.936 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.outputCount created
    2024-09-25 11:38:54.937 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.eventLoopLag created
    2024-09-25 11:38:54.938 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.sigKill created
    2024-09-25 11:38:54.942 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.logLevel created
    2024-09-25 11:38:54.942 - info: host.ioTest iobroker host.ioTest object javascript.0.variables created
    2024-09-25 11:38:54.943 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.astro created
    2024-09-25 11:38:54.945 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.isDayTime created
    2024-09-25 11:38:54.946 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.isDaylightSaving created
    2024-09-25 11:38:54.946 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.dayTime created
    2024-09-25 11:38:54.947 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.rulesTour created
    2024-09-25 11:38:54.948 - info: host.ioTest iobroker host.ioTest object javascript.0.debug created
    2024-09-25 11:38:54.949 - info: host.ioTest iobroker host.ioTest object javascript.0.debug.to created
    2024-09-25 11:38:54.950 - info: host.ioTest iobroker host.ioTest object javascript.0.debug.from created
    2024-09-25 11:38:54.951 - info: host.ioTest iobroker host.ioTest object javascript.0.debug.rules created
    2024-09-25 11:38:54.958 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0 created
    2024-09-25 11:38:55.979 - info: host.ioTest iobroker exit 0
    2024-09-25 11:38:56.110 - info: host.ioTest iobroker add history
    2024-09-25 11:38:56.688 - info: host.ioTest iobroker NPM version: 10.8.2
    2024-09-25 11:38:56.688 - info: host.ioTest iobroker Installing iobroker.history@3.0.1... (System call)
    2024-09-25 11:38:58.072 - info: host.ioTest instance system.adapter.javascript.0 in version "8.7.6" started with pid 496
    2024-09-25 11:38:58.218 - info: host.ioTest iobroker
    2024-09-25 11:38:58.219 - info: host.ioTest iobroker added 1 package in 1s72 packages are looking for funding run `npm fund` for details
    2024-09-25 11:38:58.229 - info: host.ioTest iobroker host.ioTest install adapter history
    2024-09-25 11:38:58.242 - info: host.ioTest iobroker upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
    2024-09-25 11:38:58.247 - info: host.ioTest iobroker upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
    2024-09-25 11:38:58.249 - info: host.ioTest iobroker upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
    2024-09-25 11:38:58.251 - info: host.ioTest iobroker upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
    2024-09-25 11:38:58.253 - info: host.ioTest iobroker upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    2024-09-25 11:38:58.255 - info: host.ioTest iobroker upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
    2024-09-25 11:38:58.257 - info: host.ioTest iobroker upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    2024-09-25 11:38:58.259 - info: host.ioTest iobroker upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    2024-09-25 11:38:58.261 - info: host.ioTest iobroker upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    2024-09-25 11:38:58.264 - info: host.ioTest iobroker upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    2024-09-25 11:38:58.267 - info: host.ioTest iobroker upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    2024-09-25 11:38:58.268 - info: host.ioTest iobroker upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
    2024-09-25 11:38:58.270 - info: host.ioTest iobroker upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
    2024-09-25 11:38:58.272 - info: host.ioTest iobroker upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
    2024-09-25 11:38:58.282 - info: host.ioTest iobroker host.ioTest object system.adapter.history created/updated
    2024-09-25 11:38:58.291 - info: host.ioTest iobroker host.ioTest create instance history
    2024-09-25 11:38:58.294 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.alive created
    2024-09-25 11:38:58.295 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.connected created
    2024-09-25 11:38:58.297 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.compactMode created
    2024-09-25 11:38:58.298 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.cpu created
    2024-09-25 11:38:58.299 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.cputime created
    2024-09-25 11:38:58.300 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.memHeapUsed created
    2024-09-25 11:38:58.302 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.memHeapTotal created
    2024-09-25 11:38:58.303 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.memRss created
    2024-09-25 11:38:58.304 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.uptime created
    2024-09-25 11:38:58.305 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.inputCount created
    2024-09-25 11:38:58.306 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.outputCount created
    2024-09-25 11:38:58.308 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.eventLoopLag created
    2024-09-25 11:38:58.309 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.sigKill created
    2024-09-25 11:38:58.311 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.logLevel created
    2024-09-25 11:38:58.312 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0 created
    2024-09-25 11:38:58.707 - info: javascript.0 (496) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 11:38:58.742 - info: javascript.0 (496) requesting all states
    2024-09-25 11:38:58.743 - info: javascript.0 (496) requesting all objects
    2024-09-25 11:38:58.800 - info: javascript.0 (496) received all states
    2024-09-25 11:38:58.849 - info: javascript.0 (496) received all objects
    2024-09-25 11:38:59.322 - info: host.ioTest iobroker exit 0
    2024-09-25 11:39:10.927 - info: host.ioTest instance system.adapter.history.0 in version "3.0.1" started with pid 511
    2024-09-25 11:39:11.319 - info: history.0 (511) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 11:39:11.374 - info: history.0 (511) Set default history instance to "history.0"
    2024-09-25 11:39:15.959 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-09-25 11:39:15.963 - info: admin.0 (329) Got terminate signal TERMINATE_YOURSELF
    2024-09-25 11:39:15.964 - info: admin.0 (329) terminating http server on port 8081
    2024-09-25 11:39:15.965 - info: admin.0 (329) terminating
    2024-09-25 11:39:15.966 - info: admin.0 (329) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-09-25 11:39:16.004 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
    2024-09-25 11:39:16.466 - info: admin.0 (329) terminating
    2024-09-25 11:39:16.482 - info: host.ioTest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-09-25 11:39:19.585 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 526
    2024-09-25 11:39:20.093 - info: admin.0 (526) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 11:39:20.105 - info: admin.0 (526) requesting all objects
    2024-09-25 11:39:20.289 - info: admin.0 (526) received all objects
    2024-09-25 11:39:20.363 - info: admin.0 (526) Secure socket.io server listening on port 8081
    2024-09-25 11:39:20.364 - info: admin.0 (526) https server listening on port 8081
    2024-09-25 11:39:20.364 - info: admin.0 (526) Use link "https://127.0.0.1:8081" to configure.
    2024-09-25 11:39:37.141 - info: admin.0 (526) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
    2024-09-25 11:39:48.042 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 11:40:17.163 - info: discovery.0 (385) Discovering devices with a HF-LPB100 chipset...
    2024-09-25 11:40:17.169 - info: discovery.0 (385) Discovering mDNS devices...
    2024-09-25 11:40:17.170 - info: discovery.0 (385) Discovering ping devices...
    2024-09-25 11:40:17.195 - info: discovery.0 (385) Discovering UPnP devices...
    2024-09-25 11:40:17.197 - info: discovery.0 (385) Discovering wifi-mi-light devices...
    2024-09-25 11:40:17.205 - warn: discovery.0 (385) tr-064.0 not installed
    2024-09-25 11:40:17.205 - info: discovery.0 (385) Done discovering tr064 devices. 0 packages received
    2024-09-25 11:40:18.697 - info: discovery.0 (385) Done discovering RESOL VBus devices. 0 packages received
    2024-09-25 11:40:19.198 - info: discovery.0 (385) Done discovering wifi-mi-light devices. 0 packages received
    2024-09-25 11:40:22.174 - info: discovery.0 (385) Done discovering SMA Speedwire devices. 0 packages received
    2024-09-25 11:40:22.174 - info: discovery.0 (385) Done discovering udp devices. 1 packages received
    2024-09-25 11:40:27.165 - info: discovery.0 (385) Done discovering HF-LPB100 devices. 0 packages received
    2024-09-25 11:40:30.509 - info: discovery.0 (385) Done discovering ping devices. 1 packages received
    2024-09-25 11:40:32.171 - info: discovery.0 (385) Done discovering mdns devices. 0 packages received
    2024-09-25 11:40:32.196 - info: discovery.0 (385) Done discovering upnp devices. 18 packages received
    2024-09-25 11:40:32.199 - info: discovery.0 (385) Found 4 addresses
    2024-09-25 11:40:49.408 - info: discovery.0 (385) Discovery finished. Found new or modified 7 instances
    2024-09-25 11:40:49.464 - info: discovery.0 (385) Discovery finished
    2024-09-25 11:44:05.124 - info: history.0 (511) enabled logging of system.host.ioTest.freemem, Alias=false, WriteNulls=true
    2024-09-25 11:44:31.505 - info: history.0 (511) enabled logging of system.host.ioTest.mem, Alias=false, WriteNulls=true
    2024-09-25 12:00:43.151 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 12:06:08.821 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 12:07:37.652 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 12:07:38.465 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 12:13:18.504 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 12:31:49.466 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 12:33:56.558 - info: history.0 (511) enabled logging of system.adapter.admin.0.memRss, Alias=false, WriteNulls=true
    2024-09-25 12:36:54.832 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 12:44:43.508 - info: admin.0 (526) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
    2024-09-25 13:16:34.592 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 13:21:12.611 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 13:21:13.292 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 13:26:16.181 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 13:26:16.903 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 13:33:01.954 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 13:42:08.890 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 13:42:12.205 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 14:28:19.717 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 14:30:59.723 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 17:58:14.049 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 18:02:04.070 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 18:02:26.241 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 18:02:37.756 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 18:13:53.085 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 18:13:57.028 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 18:28:33.016 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 18:28:38.116 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 18:43:11.126 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 18:48:25.001 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 19:17:26.663 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 19:17:30.918 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 19:28:25.578 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 19:29:25.582 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 19:53:29.746 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 19:58:39.494 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 19:58:40.510 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 20:02:05.439 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 20:02:10.921 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 20:02:16.615 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 20:02:17.150 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 20:02:44.103 - info: backitup.0 (370) cleaned everything up...
    2024-09-25 20:02:44.103 - info: host.ioTest received SIGTERM
    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.backitup.0 (force=false, process=true)
    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.discovery.0 (force=false, process=true)
    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.javascript.0 (force=false, process=true)
    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.history.0 (force=false, process=true)
    2024-09-25 20:02:44.107 - info: discovery.0 (385) Got terminate signal TERMINATE_YOURSELF
    2024-09-25 20:02:44.106 - info: javascript.0 (496) Got terminate signal TERMINATE_YOURSELF
    2024-09-25 20:02:44.105 - info: admin.0 (526) terminating https server on port 8081
    2024-09-25 20:02:44.108 - info: javascript.0 (496) terminating
    2024-09-25 20:02:44.109 - info: javascript.0 (496) Terminated (NO_ERROR): Without reason
    2024-09-25 20:02:44.108 - info: backitup.0 (370) Got terminate signal TERMINATE_YOURSELF
    2024-09-25 20:02:44.111 - info: admin.0 (526) Got terminate signal TERMINATE_YOURSELF
    2024-09-25 20:02:44.110 - info: history.0 (511) terminating
    2024-09-25 20:02:44.112 - info: history.0 (511) Terminated (NO_ERROR): Without reason
    2024-09-25 20:02:44.113 - info: admin.0 (526) terminating
    2024-09-25 20:02:44.114 - info: admin.0 (526) Terminated (NO_ERROR): Without reason
    2024-09-25 20:02:44.147 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
    2024-09-25 20:02:44.147 - info: host.ioTest stopInstance system.adapter.backitup.0 send kill signal
    2024-09-25 20:02:44.147 - info: host.ioTest stopInstance system.adapter.discovery.0 send kill signal
    2024-09-25 20:02:44.148 - info: host.ioTest stopInstance system.adapter.javascript.0 send kill signal
    2024-09-25 20:02:44.150 - info: discovery.0 (385) terminating
    2024-09-25 20:02:44.151 - info: backitup.0 (370) terminating
    2024-09-25 20:02:44.151 - info: discovery.0 (385) Terminated (NO_ERROR): Without reason
    2024-09-25 20:02:44.151 - info: backitup.0 (370) Terminated (NO_ERROR): Without reason
    2024-09-25 20:02:44.573 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 20:02:44.608 - info: javascript.0 (496) terminating
    2024-09-25 20:02:44.608 - info: backitup.0 (370) terminating
    2024-09-25 20:02:44.608 - info: discovery.0 (385) terminating
    2024-09-25 20:02:44.609 - info: admin.0 (526) terminating
    2024-09-25 20:02:44.634 - info: host.ioTest instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2024-09-25 20:02:44.634 - info: host.ioTest instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2024-09-25 20:02:44.638 - info: host.ioTest instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2024-09-25 20:02:44.666 - info: host.ioTest instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2024-09-25 20:02:44.668 - info: host.ioTest instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2024-09-25 20:02:44.668 - info: host.ioTest All instances are stopped.
    2024-09-25 20:02:44.836 - info: host.ioTest terminated
    2024-09-25 20:02:46.206 - info: host.ioTest iobroker.js-controller version 6.0.11 js-controller starting
    2024-09-25 20:02:46.208 - info: host.ioTest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-09-25 20:02:46.208 - info: host.ioTest hostname: ioTest, node: v20.17.0
    2024-09-25 20:02:46.208 - info: host.ioTest ip addresses: 192.168.56.243 fe80::be24:11ff:fee6:705f
    2024-09-25 20:02:46.578 - info: host.ioTest connected to Objects and States
    2024-09-25 20:02:46.583 - info: host.ioTest added notifications configuration of host
    2024-09-25 20:02:46.727 - info: host.ioTest 5 instances found
    2024-09-25 20:02:46.729 - info: host.ioTest starting 5 instances
    2024-09-25 20:02:46.833 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeCurrent"
    2024-09-25 20:02:46.840 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewest"
    2024-09-25 20:02:46.848 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 4493
    2024-09-25 20:02:46.848 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewestNext"
    2024-09-25 20:02:46.850 - info: host.ioTest Delete state "system.host.ioTest.versions.npmCurrent"
    2024-09-25 20:02:46.891 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewest"
    2024-09-25 20:02:46.892 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewestNext"
    2024-09-25 20:02:46.893 - info: host.ioTest Some obsolete host states deleted.
    2024-09-25 20:02:47.330 - info: admin.0 (4493) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 20:02:47.339 - info: admin.0 (4493) requesting all objects
    2024-09-25 20:02:47.505 - info: admin.0 (4493) received all objects
    2024-09-25 20:02:47.578 - info: admin.0 (4493) Secure socket.io server listening on port 8081
    2024-09-25 20:02:47.579 - info: admin.0 (4493) https server listening on port 8081
    2024-09-25 20:02:47.579 - info: admin.0 (4493) Use link "https://127.0.0.1:8081" to configure.
    2024-09-25 20:02:50.860 - info: host.ioTest instance system.adapter.javascript.0 in version "8.7.6" started with pid 4534
    2024-09-25 20:02:51.452 - info: javascript.0 (4534) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 20:02:51.491 - info: javascript.0 (4534) requesting all states
    2024-09-25 20:02:51.491 - info: javascript.0 (4534) requesting all objects
    2024-09-25 20:02:51.550 - info: javascript.0 (4534) received all states
    2024-09-25 20:02:51.598 - info: javascript.0 (4534) received all objects
    2024-09-25 20:02:51.682 - info: admin.0 (4493) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
    2024-09-25 20:02:54.822 - info: host.ioTest instance system.adapter.history.0 in version "3.0.1" started with pid 4549
    2024-09-25 20:02:55.216 - info: history.0 (4549) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 20:02:55.267 - info: history.0 (4549) enabled logging of system.adapter.admin.0.memRss (Count=1), Alias=false
    2024-09-25 20:02:55.268 - info: history.0 (4549) enabled logging of system.host.ioTest.mem (Count=2), Alias=false
    2024-09-25 20:02:55.268 - info: history.0 (4549) enabled logging of system.host.ioTest.freemem (Count=3), Alias=false
    2024-09-25 20:02:58.825 - info: host.ioTest instance system.adapter.backitup.0 in version "3.0.22" started with pid 4564
    2024-09-25 20:02:59.241 - info: backitup.0 (4564) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 20:02:59.258 - info: backitup.0 (4564) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-09-25 20:03:02.822 - info: host.ioTest instance system.adapter.discovery.0 in version "5.0.0" started with pid 4579
    2024-09-25 20:03:03.220 - info: discovery.0 (4579) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
    2024-09-25 20:03:09.139 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 20:04:10.889 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 20:04:11.635 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 20:08:24.918 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 20:20:28.303 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 20:20:33.031 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 20:34:43.640 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 20:34:47.954 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 21:08:27.999 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 21:08:38.367 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    2024-09-25 22:08:44.182 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
    2024-09-25 22:09:09.131 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
    crunchipC
    crunchipC
    Developer Global Moderator Most Active Forum Testing
    #113
    @peterfido wir reden hier auch nicht von einem Redis Server um von jsonl auf Redis um zu stellen., sondern von der internen DB.
    Iobroker wurde ab einer bestimmten Version optimiert und auf Redis umgestellt.
    Wie oben schon geschrieben, nicht sicher ab welcher Version das eingeführt wurde.
      CodierknechtC
      CodierknechtC
      Codierknecht
      #114
      @crunchip
      Gerade gesehen, dass der Admin ja auf "Debug" steht. Darum sehe ich diese Einträge bei mir nicht.
      Dann brauche ich mich ja nicht zu wundern. Alles gut.
      Bleibt trotzdem ein Mysterium.
      Kann mir kaum vorstellen, dass es an ioBroker liegt. Das würde hier sonst dutzendfach aufschlagen.
      Irgendetwas ist an der Installation von Proxmox anders als bei allen anderen.
      Wobei ich zugeben muss, dass ich meines auch nicht stringent nach irgend einer Anleitung installiert habe. Bootfähigen Stick erzeugt und dann gestartet. Der Rest ist eigentlich selbsterklärend.
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      crunchipC M 2 Antworten Letzte Antwort
      • CodierknechtC Codierknecht
        @crunchip
        crunchipC
        crunchipC
        #115
        @codierknecht sagte in NUC-Proxmox-steigender Ram:
        korrekt
        und extra chatgpt bemüht(zu faul zum suchen)😁
        Die Umstellung von der internen ioBroker-Datenbank auf Redis erfolgte mit der Einführung der Version 1.5.0 des ioBroker.js-Controllers, die am 16. September 2018 veröffentlicht wurde
        keine Ahnung, daher fragte ich ja nach dem syslog
        P 1 Antwort Letzte Antwort
          korrekt
          P
          P
          peterfido
          schrieb am zuletzt editiert von peterfido
          #116
          @crunchip
          okay, auf debug wird es aufgeführt.
          2024-09-26 06:42:42.326 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
          2024-09-26 06:42:42.330 - info: admin.0 (4493) Got terminate signal TERMINATE_YOURSELF
          2024-09-26 06:42:42.331 - info: admin.0 (4493) terminating https server on port 8081
          2024-09-26 06:42:42.332 - info: admin.0 (4493) terminating
          2024-09-26 06:42:42.332 - info: admin.0 (4493) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-09-26 06:42:42.371 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
          2024-09-26 06:42:42.833 - info: admin.0 (4493) terminating
          2024-09-26 06:42:42.859 - info: host.ioTest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-09-26 06:42:45.965 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 5251
          2024-09-26 06:42:46.371 - debug: admin.0 (5251) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2024-09-26 06:42:46.378 - debug: admin.0 (5251) Objects client ready ... initialize now
          2024-09-26 06:42:46.379 - debug: admin.0 (5251) Objects create System PubSub Client
          2024-09-26 06:42:46.379 - debug: admin.0 (5251) Objects create User PubSub Client
          2024-09-26 06:42:46.383 - debug: admin.0 (5251) Objects client initialize lua scripts
          2024-09-26 06:42:46.385 - debug: admin.0 (5251) Objects connected to redis: 127.0.0.1:9001
          2024-09-26 06:42:46.389 - debug: admin.0 (5251) Redis States: Use Redis connection: 127.0.0.1:9000
          2024-09-26 06:42:46.390 - debug: admin.0 (5251) States create System PubSub Client
          2024-09-26 06:42:46.390 - debug: admin.0 (5251) States create User PubSub Client
          2024-09-26 06:42:46.392 - debug: admin.0 (5251) States connected to redis: 127.0.0.1:9000
          2024-09-26 06:42:46.398 - debug: admin.0 (5251) Plugin sentry Initialize Plugin (enabled=true)
          2024-09-26 06:42:46.462 - info: admin.0 (5251) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
          2024-09-26 06:42:46.472 - info: admin.0 (5251) requesting all objects
          peter@ioTest:~$ iob status
          Objects type: jsonl
          States  type: jsonl
          peter@ioTest:~$
          Peterfido
          • P peterfido
            @marko67
            DIE bebilderte Anleitung habe ich nicht gefunden.
            Unter Proxmox nutze ich VMs.
            Einen CT habe ich jetzt mal für diesen Test hier erstellt.
            Dazu erstmal im Proxmox Host die aktuelle Debian 12 Vorlage heruntergeladen.
            Dann auf erstelle CT klicken, das Template auswählen, 20GB Disk, 4 CPU Kerne in einem Sockel, 8 GB RAM, bei Netzwerk evtl. noch das VLAN setzen, DHCP an, starten.
            Dann als root sudo installieren.
            apt update
            apt install sudo
            apt install curl
            adduser benutzername
            usermod benutzername -aG sudo
            exit
            Dann als benutzername einloggen
            sudo apt update
            sudo apt install qemu-guest-agent
            curl -sLf https://iobroker.net/install.sh | bash -
            Das ist das Grundsystem, welches bei mir seit gestern testet.
            Unter Objekte werden noch System freies RAM, RAM-Prozent und der Speicher vom admin in die History geloggt.
            crunchipC
            crunchipC
            #117
            @peterfido sagte in NUC-Proxmox-steigender Ram:
            diese Dreiecke sind aufklappbar
            @marko67 sagte in NUC-Proxmox-steigender Ram:
            Haben den Adapter gelöscht. 1x über ioB Adapter und dann mal über die Konsole. Meldung taucht immer wieder auf??
            seltsam
            kannst du testweise einen neuen LXC erstellen, diesmal aber ein ubuntu template nehmen und mal nur eine reine Installation, ohne irgend etwas einzurichten oder zu löschen, nach der iobroker Installation
            • M marko67
              @arteck
              Mein Problem ist, dass der RAM bis auf 100% hoch läuft und dann auch andere Container einfrieren. So war es auf dem vorherigen System.
              Hier mal der RAM Verbrauch nach knapp 3 Stunden
              MartinPM
              MartinPM
              MartinP
              #118
              1. Wenn man ein sicheres System haben will, darf man in Summe nur so viel RAM auf die Container verteilen, wie Proxmox bereitstellen kann ...
                Hast Du ein System mit 8 GB RAM und drei Containern, sollte man nicht mehr als ca 7,5 GB auf die drei Container verteilen, also z.B. 2,5 + 2,5 + 2,5
                Verteilt man mehr, als vorhanden ist auf die Container, gibt es die von Dir beobachteten Symptome, wenn einer der Container amok läuft, und ausnutzt, was ihm zusteht.
              2. Meine Frage war, wie sich das RAM verhält, WÄHREND der iobroker durch "iob stop" gestoppt ist.
                Sinkt die "Memory usage" wieder?
                Auf den ursprünglichen Stand vor dem ersten Start des iob?
              • MartinPM MartinP
                crunchipC
                crunchipC
                #119
                @martinp laut seiner Aussage hat er doch 16GB Gesamt
                8Gb für iobroker und 2weitere LXC mit 1 und 2 GB Ram, sollte in Summe dann ja passen
                @martinp sagte in NUC-Proxmox-steigender Ram:
                ja, hat er oben doch schon gezeigt
                • MartinPM
                  MartinPM
                  MartinP
                  #120
                  iob stop ausgeführt. Ist mit 157 MB neu gestartet und nun wieder bei fast 1,5 GB steigend
                  Sorry, hatte nur die grafische Auswertung beachtet, und da keinen Abfall der RAM-Nutzung durch IOB gesehen
                  Ist "Nesting" im Lxc-Container aktiviert?
                  Und hier die Netzwerk-Einstellungen des Containers:
                  Da habe ich gegenüber der Fritzbox getrickst ...
                    @crunchip
                    M
                    M
                    marko67
                    #121
                    @codierknecht
                    Genau so habe ich es gemacht. Da kann man ja eigentlich nichts falsch machen. Habe es mit der bebilderten Anleitung verglichen und 1:1 genau so gemacht.
                      seltsam
                      M
                      M
                      marko67
                      schrieb am zuletzt editiert von marko67
                      #122
                      @crunchip
                      Mach ich
                      Erledigt:
                      Nach über 2 Std.
                      • MartinPM MartinP
                        M
                        M
                        marko67
                        #123
                        @martinp
                        Das neue System (Hardware / neuer NUC) hat 16 GB Speicher.
                        der 1. Container iob hat 8GB der 2. iob-Test hat 4 GB
                        Sinkt die "Memory usage" wieder? --> Ja!! Ich gl. ich hatte davon einen Screenshot bereits gepostet.
                        • MartinPM MartinP
                          M
                          M
                          marko67
                          #124
                          @martinp
                          Ist "Nesting" im Lxc-Container aktiviert? --> Ja
                          • M marko67
                            @martinp
                            MartinPM
                            MartinPM
                            MartinP
                            #125
                            @marko67 und bei der statisch zugewiesenen 192.168.1.152 spuckt kein anderes Device in die Suppe? Lieg die Adresse im Range, den Dein Router per DHCP vergibt?
                            • MartinPM MartinP
                              M
                              M
                              marko67
                              #126
                              @martinp
                              Fritz.Box sagt nein. Kein anderes Gerät mit gleicher IP. Range geht bis 200.
                              Alle meine SH Geräte haben statische Nummern. --> Betreibe parallel seit 13 Jahren FHEM.
                              Bisher lief alles sehr gut parallel (seit ca. 8 Jahren)
                              C 1 Antwort Letzte Antwort
                              • M marko67
                                @martinp
                                C
                                C
                                Chrunchy
                                #127
                                Feste IPs sind kein Problem, allerdings sollte diese immer außerhalb der IP-Range des DHCP-Servers liegen. GGf. den Bereich des DHCP verkleiner.
                                Gruß Chrunchy
                                • M marko67
                                  @crunchip
                                  Mach ich
                                  Erledigt:
                                  Nach über 2 Std.
                                  crunchipC
                                  crunchipC
                                  #128
                                  @marko67 dann gehen mir langsam die Ideen aus
                                  • Dr. BakteriusD
                                    Dr. BakteriusD
                                    Dr. Bakterius
                                    schrieb am zuletzt editiert von Dr. Bakterius
                                    #129
                                    Hat jemand von Euch in den letzten Tagen einen neuen LXC aufgesetzt mit aktueller Software und ioB?? Nur um mal den Gegentest zu machen.
                                    Nun habe auch ich einen neuen LXC auf meinem Proxmox 8.2.6 aufgesetzt (Mini-PC mit einem n100 und 32 GB RAM). Und zwar mit dem aktuellen debian Template debian-12-standard_12.7-1_amd64.tar.zst.
                                    Die weitere Vorgangsweise genau wie in der Anleitung durchgeführt. Nur den javascript-Adapter mit dem Assistenten installiert. Sonst nichts weiter installiert oder gelöscht.
                                    Nach etwa einer Stunde bin ich stabil bei etwa 670 MB RAM-Belegung. top sagt noch:
                                    top - 16:51:30 up 55 min,  1 user,  load average: 0.42, 0.47, 0.53
                                    Tasks:  21 total,   1 running,  20 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  8.1 us,  2.4 sy,  0.0 ni, 88.2 id,  0.3 wa,  0.0 hi,  0.8 si,  0.0 st
                                    MiB Mem :   8192.0 total,   4706.1 free,    671.2 used,   2814.7 buff/cache
                                    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7520.8 avail Mem
                                    Edit: Nach über 3 Stunden 720 MB Auslastung - davon hat der Admin 145 MB.
                                      MartinPM
                                      MartinPM
                                      MartinP
                                      #130
                                      @dr-bakterius Im stable Repository wird aktuell admin 7.1.5 zum Aktualisieren angeboten ...
                                      In den Releasenotes des Update Fensters aber keine Hinweise, dass ein Speicherleck gefixt wurde...
                                      Dr. BakteriusD 1 Antwort Letzte Antwort
                                      • MartinPM MartinP
                                        Dr. BakteriusD
                                        Dr. BakteriusD
                                        Dr. Bakterius
                                        #131
                                        Vermutlich weil es keines gibt.
                                        Ich habe auf meinem Produktivsystem gestern das Admin-Update installiert - keine Änderung feststellbar was den RAM-Bedarf angeht. Und auch bei der vorherigen Version keine Auffälligkeiten. Jetzt nach knapp 21 Stunden bin ich bei 765 MB. Also nur moderat gestiegen was völlig normal ist. Das ist offensichtlich ein Problem das nur @marko67 betrifft und mit ziemlicher Sicherheit nichts mit ioBroker zu tun hat.
                                          M
                                          M
                                          marko67
                                          #132
                                          @dr-bakterius @MartinP
                                          Nach dem Hinweis auf die IP (spuckt ein anderes Gerät in die Suppe) habe ich festgestellt, dass ioB relativ viel Traffic produziert.
                                          Da kam mir eine Einstellung im Admin Adapter in den Sinn. Nicht https und Passwort sondern "Prüfen ob aus dem Internet erreichbar"
                                          Weiß jemand wofür das ist?
                                          84.0k
