  3. Einsteigerfragen
  4. NUC-Proxmox-steigender Ram
    apollon77A
137 Beiträge 13 Kommentatoren 37.5k Aufrufe 12 Beobachtet
  • P peterfido
    @marko67 Dein Kernel ist aktueller.
    Den Proxmox-Host aktualisiere ich erst am Wochenende.
    CodierknechtC
    CodierknechtC
    Codierknecht
    #101
    @peterfido
    Hab' auch Kernel 6.8.12-2-pve. Funzt problemlos und dümpelt nach frischer Installation um 320 MB rum.
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: ioBroker-TEST
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-2-pve
        Architecture: x86-64
    model name      : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:07:57 up  8:11,  2 users,  load average: 0.27, 0.19, 0.18
    CPU threads: 1
    *** Time and Time Zones ***
                   Local time: Wed 2024-09-25 20:07:57 UTC
               Universal time: Wed 2024-09-25 20:07:57 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    codierknecht
    HOME=/home/codierknecht
    GROUPS=codierknecht sudo users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            2.1G        340M        972M        131K        834M        1.8G
    Swap:           2.1G        4.1K        2.1G
    Total:          4.3G        340M        3.1G
    Active iob-Instances:   3
             2048 M total memory
              325 M used memory
              471 M active memory
              551 M inactive memory
              927 M free memory
                0 M buffer memory
              795 M swap cache
             2048 M total swap
                0 M used swap
             2047 M free swap
    top - 20:07:57 up  8:11,  2 users,  load average: 0.25, 0.19, 0.18
    Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   2048.0 total,    925.5 free,    326.9 used,    795.7 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1721.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--300--disk--0 ext4      7.8G  2.2G  5.3G  29% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G  124K  3.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET                                                  SOURCE                           FSTYPE     OPTIONS
    /                                                       /dev/mapper/pve-vm--300--disk--0 ext4       rw,relatime,stripe=16
    |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3253060k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
    | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    | |-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | `-/run/credentials/systemd-firstboot.service          ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
    | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
    | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
    | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
    | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
    | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
    | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
    | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
    | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
    | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
    | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
    | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
      |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
      |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    419M    /var/
    249M    /var/cache
    245M    /var/cache/apt
    169M    /var/cache/apt/archives
    146M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    79M     /opt/iobroker/iobroker-data/
    62M     /opt/iobroker/iobroker-data/files
    31M     /opt/iobroker/iobroker-data/files/backitup.admin
    31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
    9.6M    /opt/iobroker/iobroker-data/objects.jsonl
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
    5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.17.0
    /usr/bin/node           v20.17.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.17.0-1nodesource1
      Candidate: 20.17.0-1nodesource1
      Version table:
     *** 20.17.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.1.2
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker-TEST                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBroker-TEST                            -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.2    , installed 7.1.2
    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Objects and States
    Objects:        124
    States:         89
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          29808714   301/master
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29958647   10404/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29958642   10404/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          29957141   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          29957143   1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          29806168   1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          29808715   301/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       29959052   10500/io.admin.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29806275   93/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          29957142   1/init
    udp        0      0 0.0.0.0:161             0.0.0.0:*                           0          30040554   10843/snmpd
    udp6       0      0 :::111                  :::*                                0          29957144   1/init
    2024-09-25 12:37:35.644  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 5 states of discovery
    2024-09-25 12:37:35.646  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 15 states of system.adapter.discovery
    2024-09-25 12:37:35.647  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 1 states (io.discovery.*) from states
    2024-09-25 12:37:35.653  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 16 states (system.adapter.discovery.*) from states
    2024-09-25 12:37:35.856  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 1 objects of discovery
    2024-09-25 12:37:35.892  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST file discovery.admin deleted
    2024-09-25 12:37:35.894  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST object discovery deleted
    2024-09-25 12:37:35.898  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST object discovery.admin deleted
    2024-09-25 12:37:35.899  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Deleting 25 object(s).
    2024-09-25 12:37:35.933  - info: host.ioBroker-TEST object deleted system.adapter.discovery.0
    2024-09-25 12:37:35.935  - info: host.ioBroker-TEST stopInstance system.adapter.discovery.0 (force=false, process=true)
    2024-09-25 12:37:35.937  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Deleting 17 state(s).
    2024-09-25 12:37:35.938  - info: discovery.0 (10568) Got terminate signal TERMINATE_YOURSELF
    2024-09-25 12:37:35.938  - info: discovery.0 (10568) terminating
    2024-09-25 12:37:35.939  - info: discovery.0 (10568) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-09-25 12:37:35.977  - info: host.ioBroker-TEST stopInstance system.adapter.discovery.0 send kill signal
    2024-09-25 12:37:36.442  - info: discovery.0 (10568) terminating
    2024-09-25 12:37:36.514  - info: host.ioBroker-TEST instance system.adapter.discovery.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2024-09-25 12:37:36.514  - info: host.ioBroker-TEST Do not restart adapter system.adapter.discovery.0 because desired by instance
    2024-09-25 12:37:37.304  - info: host.ioBroker-TEST iobroker removed 42 packages in 1s
    2024-09-25 12:37:37.305  - info: host.ioBroker-TEST iobroker
    2024-09-25 12:37:37.306  - info: host.ioBroker-TEST iobroker 58 packages are looking for funding
    2024-09-25 12:37:37.307  - info: host.ioBroker-TEST iobroker   run `npm fund` for details
    2024-09-25 12:37:38.328  - info: host.ioBroker-TEST iobroker exit 0
    2024-09-25 12:42:43.671  - info: admin.0 (10500) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • M marko67
      @martinp
      iob stop ausgeführt. Ist mit 157 MB neu gestartet und nun wieder bei fast 1,5 GB steigend
      Anbei nochmals iob diag
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: ioB24
        Virtualization: lxc
      model name      : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
       21:13:08 up  4:34,  2 users,  load average: 0.19, 0.27, 0.25
      CPU threads: 2
                     Local time: Wed 2024-09-25 21:13:08 CEST
                 Universal time: Wed 2024-09-25 19:13:08 UTC
                       RTC time: n/a
                RTC in local TZ: no
      dirk
      HOME=/home/dirk
      GROUPS=dirk sudo users iobroker
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            7.4G        1.6G        5.4G        114K        373M        5.8G
      Swap:           536M          0B        536M
      Total:          7.9G        1.6G        5.9G
               7048 M total memory
               1541 M used memory
               1617 M active memory
                238 M inactive memory
               5149 M free memory
                  0 M buffer memory
                356 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 21:13:08 up  4:34,  2 users,  load average: 0.19, 0.27, 0.25
      Tasks:  27 total,   1 running,  26 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7048.0 total,   5148.3 free,   1543.3 used,    356.6 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5504.7 avail Mem
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      2 loaded units listed.
      *** FILESYSTEM ***
      /dev/mapper/pve-vm--110--disk--0 ext4      9.8G  2.2G  7.2G  24% /
      tmpfs                            tmpfs     3.2G  108K  3.2G   1% /run
      /                                                       /dev/mapper/pve-vm--110--disk--0 ext4       rw,relatime,stripe=16
      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3260368k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
      | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
      | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
      | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
      | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
      | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
      /var:
      435M    /var/
      248M    /var/cache
      245M    /var/cache/apt
      146M    /var/lib
      1.6M    /opt/iobroker/backups/
      85M     /opt/iobroker/iobroker-data/
      9.8M    /opt/iobroker/iobroker-data/objects.jsonl
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.1.2
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioB24                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : ioB24                                    -  enabled
      + instance is alive
      Objects and States
      Objects:        124
      States:         88
      Pending Updates: 0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1055632    974/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1055625    974/iobroker.js-con
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          744091     318/master
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          742063     1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1055693    992/io.admin.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          744092     318/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          743832     1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          742065     1/init
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          742064     1/init
      udp6       0      0 :::111                  :::*                                0          742066     1/init
      2024-09-25 19:30:24.571  - info: backitup.0 (390) Terminated (NO_ERROR): Without reason
      2024-09-25 19:30:25.059  - info: backitup.0 (390) terminating
      2024-09-25 19:30:25.101  - info: host.ioB24 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2024-09-25 19:30:25.385  - info: host.ioB24 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2024-09-25 19:30:25.386  - info: host.ioB24 All instances are stopped.
      2024-09-25 19:30:25.567  - info: host.ioB24 terminated
      2024-09-25 19:39:53.260  - info: host.ioB24 iobroker.js-controller version 6.0.11 js-controller starting
      2024-09-25 19:39:53.264  - info: host.ioB24 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2024-09-25 19:39:53.264  - info: host.ioB24 hostname: ioB24, node: v20.17.0
      2024-09-25 19:39:53.265  - info: host.ioB24 ip addresses: 192.168.1.152 2a02:810c:1bf:f826:be24:11ff:fe42:4bab fe80::be24:11ff:fe42:4bab
      2024-09-25 19:39:53.858  - info: host.ioB24 connected to Objects and States
      2024-09-25 19:39:53.873  - info: host.ioB24 added notifications configuration of host
      2024-09-25 19:39:54.102  - info: host.ioB24 2 instances found
      2024-09-25 19:39:54.106  - info: host.ioB24 starting 2 instances
      2024-09-25 19:39:54.339  - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeCurrent"
      2024-09-25 19:39:54.356  - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewest"
      2024-09-25 19:39:54.360  - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewestNext"
      2024-09-25 19:39:54.363  - info: host.ioB24 Delete state "system.host.ioB24.versions.npmCurrent"
      2024-09-25 19:39:54.370  - info: host.ioB24 instance system.adapter.admin.0 in version "7.1.2" started with pid 992
      2024-09-25 19:39:54.374  - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewest"
      2024-09-25 19:39:54.418  - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewestNext"
      2024-09-25 19:39:54.420  - info: host.ioB24 Some obsolete host states deleted.
      2024-09-25 19:39:58.307  - info: host.ioB24 instance system.adapter.backitup.0 in version "3.0.22" started with pid 1033
      2024-09-25 19:39:59.553  - info: backitup.0 (1033) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
      2024-09-25 19:39:59.587  - info: backitup.0 (1033) [iobroker] backup will be activated at 02:48 every 1 day(s)
                              v.2024-05-22
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1000
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs 20.17.0 and npm 10.8.2
      MEMORY:
      Mem:            7.4G        1.6G        5.4G        114K        373M        5.7G
      Swap:           536M          0B        536M
      ioBroker Core:          js-controller           6.0.11
                              admin                   7.1.2
      Objects type: jsonl
      States  type: jsonl
      Objects:                124
      States:                 88
      Size of iob-Database:
      5.4M    /opt/iobroker/iobroker-data/states.jsonl
      crunchipC
      crunchipC
      Developer Global Moderator Most Active Forum Testing
      #102
      @marko67 sagte in NUC-Proxmox-steigender Ram:
      und immer noch das Problem admin?
      schalt mal auf Experten Modus und zeig die Instanz(Ein/Ausgänge)
      und schalt den admin mal auf logstufe debug und zeig das log dazu
      Wie sieht es mit deinem Netzwerk aus? --> Wie ist die Frage gemeint?
      bin zwar kein Netzwerkspezialist, aber hast du vllt. irgend etwas spezielles eingerichtet (firewall, pihole... oder irgend etwas in der Richtung), sodass sich der admin zu tote läuft?
      bezogen auf
      024-09-24 18:40:37.012 - warn: admin.0 (10305) Repository cannot be read: Active repo - stable 2024-09-24 18:40:37.028 - warn: admin.0 (10305) Active repository "stable" cannot be read
        bezogen auf
        M
        M
        marko67
        schrieb am zuletzt editiert von marko67
        #103
        @crunchip said in NUC-Proxmox-steigender Ram:
        Nein. Wie gesagt jede Einstellung beim erstellen des Containers und von ioB 1:1 aus der bebilderten Anleitung übernommen
        2024-09-25 23:04:25.191 - debug: admin.0 (3465) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-09-25 23:04:25.210 - debug: admin.0 (3465) Objects client ready ... initialize now
        2024-09-25 23:04:25.212 - debug: admin.0 (3465) Objects create System PubSub Client
        2024-09-25 23:04:25.213 - debug: admin.0 (3465) Objects create User PubSub Client
        2024-09-25 23:04:25.225 - debug: admin.0 (3465) Objects client initialize lua scripts
        2024-09-25 23:04:25.232 - debug: admin.0 (3465) Objects connected to redis: 127.0.0.1:9001
        2024-09-25 23:04:25.243 - debug: admin.0 (3465) Redis States: Use Redis connection: 127.0.0.1:9000
        2024-09-25 23:04:25.247 - debug: admin.0 (3465) States create System PubSub Client
        2024-09-25 23:04:25.248 - debug: admin.0 (3465) States create User PubSub Client
        2024-09-25 23:04:25.254 - debug: admin.0 (3465) States connected to redis: 127.0.0.1:9000
        2024-09-25 23:04:25.271 - debug: admin.0 (3465) Plugin sentry Initialize Plugin (enabled=true)
        2024-09-25 23:04:25.498 - info: admin.0 (3465) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
        2024-09-25 23:04:25.526 - info: admin.0 (3465) requesting all objects
        2024-09-25 23:04:25.996 - info: admin.0 (3465) received all objects
        2024-09-25 23:04:26.005 - debug: admin.0 (3465) Secure connection not enabled - using http createServer
        2024-09-25 23:04:26.235 - debug: admin.0 (3465) Next repo update on 9/28/2024, 7:41:16 PM
        2024-09-25 23:04:26.257 - info: admin.0 (3465) socket.io server listening on port 8081
        2024-09-25 23:04:26.259 - info: admin.0 (3465) http server listening on port 8081
        2024-09-25 23:04:26.259 - info: admin.0 (3465) Use link "http://127.0.0.1:8081" to configure.
        2024-09-25 23:04:28.999 - info: admin.0 (3465) ==> Connected system.user.admin from ::ffff:192.168.1.35
        2024-09-25 23:04:29.011 - debug: admin.0 (3465) Subscribes: dummy
        2024-09-25 23:04:29.013 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*
        2024-09-25 23:04:29.013 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive
        2024-09-25 23:04:29.014 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive
        2024-09-25 23:04:29.014 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive
        2024-09-25 23:04:29.015 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected
        2024-09-25 23:04:29.015 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount
        2024-09-25 23:04:29.016 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss
        2024-09-25 23:04:29.016 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount
        2024-09-25 23:04:29.017 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel
        2024-09-25 23:04:29.017 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled
        2024-09-25 23:04:29.018 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree
        2024-09-25 23:04:29.018 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize
        2024-09-25 23:04:29.019 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning
        2024-09-25 23:04:29.019 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem
        2024-09-25 23:04:29.019 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection
        2024-09-25 23:04:29.020 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension
        2024-09-25 23:04:29.020 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:04:29.064 - debug: admin.0 (3465) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        2024-09-25 23:05:25.755 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.755 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.756 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.756 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.756 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.757 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.759 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.760 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.760 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.761 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.761 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, *.info.connection, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.761 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, *.info.extension, admin.0.info.newsFeed
        2024-09-25 23:05:25.762 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed
        crunchipC CodierknechtC 2 Antworten Letzte Antwort
        • M marko67
          crunchipC
          crunchipC
          #104
          Diese ganzen Meldungen dürften doch eigentlich gar nicht mehr auftauchen?
          • M marko67
            CodierknechtC
            CodierknechtC
            Codierknecht
            #105
            @marko67
            Seit wann ist denn von "Redis" die Rede?
            M crunchipC 2 Antworten Letzte Antwort
              M
              M
              marko67
              #106
              @crunchip
              Nein. Haben den Adapter gelöscht. 1x über ioB Adapter und dann mal über die Konsole. Meldung taucht immer wieder auf??
              • CodierknechtC Codierknecht
                @marko67
                M
                M
                marko67
                #107
                @codierknecht
                Was meinst Du damit??
                  @marko67
                  crunchipC
                  crunchipC
                  #108
                  @codierknecht siehe Port 9000/9001, das ist die iobroker interne Redis Datenbank
                  https://www.iobroker.net/#de/documentation/config/redis.md
                  P CodierknechtC 2 Antworten Letzte Antwort
                    P
                    P
                    peterfido
                    schrieb am zuletzt editiert von peterfido
                    #109
                    @marko67
                    DIE bebilderte Anleitung habe ich nicht gefunden.
                    Unter Proxmox nutze ich VMs.
                    Einen CT habe ich jetzt mal für diesen Test hier erstellt.
                    Dazu erstmal im Proxmox Host die aktuelle Debian 12 Vorlage heruntergeladen.
                    Dann auf erstelle CT klicken, das Template auswählen, 20GB Disk, 4 CPU Kerne in einem Sockel, 8 GB RAM, bei Netzwerk evtl. noch das VLAN setzen, DHCP an, starten.
                    Dann als root sudo installieren.
                    apt update
                    apt install sudo
                    apt install curl
                    adduser benutzername
                    usermod benutzername -aG sudo
                    exit
                    Dann als benutzername einloggen
                    sudo apt update
                    sudo apt install qemu-guest-agent
                    curl -sLf https://iobroker.net/install.sh | bash -
                    Das ist das Grundsystem, welches bei mir seit gestern testet.
                    Unter Objekte werden noch System freies RAM, RAM-Prozent und der Speicher vom admin in die History geloggt.
                    Peterfido
                      CodierknechtC
                      CodierknechtC
                      Codierknecht
                      #110
                      @crunchip sagte in NUC-Proxmox-steigender Ram:
                      Da muss dann aber jemand auf Redis umgestellt haben.
                      In meinem Test-LXC taucht jedenfalls im Log kein "Redis" auf.
                        crunchipC
                        crunchipC
                        #111
                        @codierknecht sagte in NUC-Proxmox-steigender Ram:
                        Das wurde schon glaub seit controller Version 3.3 eingeführt, nagel mich aber bitte nicht fest
                        P 1 Antwort Letzte Antwort
                          P
                          P
                          peterfido
                          #112
                          @crunchip
                          Redis ist bei meinem Testsystem nicht aktiv.
                          2024-09-25 10:57:57.542 - info: host.ioTest iobroker.js-controller version 6.0.11 js-controller starting
                          2024-09-25 10:57:57.543 - info: host.ioTest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                          2024-09-25 10:57:57.543 - info: host.ioTest hostname: ioTest, node: v20.17.0
                          2024-09-25 10:57:57.544 - info: host.ioTest ip addresses: 192.168.56.243 fe80::be24:11ff:fee6:705f
                          2024-09-25 10:57:57.771 - info: host.ioTest connected to Objects and States
                          2024-09-25 10:57:57.780 - info: host.ioTest Node.js version has changed from unknown to 20.17.0
                          2024-09-25 10:57:57.786 - info: host.ioTest Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                          2024-09-25 10:57:57.786 - info: host.ioTest added notifications configuration of host
                          2024-09-25 10:57:57.892 - info: host.ioTest 3 instances found
                          2024-09-25 10:57:57.894 - info: host.ioTest starting 3 instances
                          2024-09-25 10:57:57.906 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 10717
                          2024-09-25 10:57:58.391 - info: admin.0 (10717) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 10:57:58.399 - info: admin.0 (10717) requesting all objects
                          2024-09-25 10:57:58.434 - info: admin.0 (10717) received all objects
                          2024-09-25 10:57:58.438 - info: admin.0 (10717) Request actual repository...
                          2024-09-25 10:57:58.445 - info: host.ioTest Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                          2024-09-25 10:57:58.447 - info: admin.0 (10717) socket.io server listening on port 8081
                          2024-09-25 10:57:58.447 - info: admin.0 (10717) http server listening on port 8081
                          2024-09-25 10:57:58.448 - info: admin.0 (10717) Use link "http://127.0.0.1:8081" to configure.
                          2024-09-25 10:57:58.549 - warn: admin.0 (10717) Repository cannot be read: Active repo - stable
                          2024-09-25 10:57:58.556 - warn: admin.0 (10717) Active repository "stable" cannot be read
                          2024-09-25 10:58:00.709 - info: admin.0 (10717) Repository received successfully.
                          2024-09-25 10:58:01.977 - info: host.ioTest instance system.adapter.backitup.0 in version "3.0.22" started with pid 10758
                          2024-09-25 10:58:02.421 - info: backitup.0 (10758) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 10:58:02.435 - info: backitup.0 (10758) [iobroker] backup will be activated at 02:48 every 1 day(s)
                          2024-09-25 10:58:05.976 - info: host.ioTest instance system.adapter.discovery.0 in version "5.0.0" started with pid 10773
                          2024-09-25 10:58:06.372 - info: discovery.0 (10773) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 11:34:33.609 - info: admin.0 (10717) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 11:35:16.156 - info: backitup.0 (10758) cleaned everything up...
                          2024-09-25 11:35:16.156 - info: admin.0 (10717) terminating http server on port 8081
                          2024-09-25 11:35:16.155 - info: host.ioTest received SIGTERM
                          2024-09-25 11:35:16.157 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
                          2024-09-25 11:35:16.157 - info: host.ioTest stopInstance system.adapter.backitup.0 (force=false, process=true)
                          2024-09-25 11:35:16.157 - info: host.ioTest stopInstance system.adapter.discovery.0 (force=false, process=true)
                          2024-09-25 11:35:16.161 - info: admin.0 (10717) Got terminate signal TERMINATE_YOURSELF
                          2024-09-25 11:35:16.161 - info: backitup.0 (10758) Got terminate signal TERMINATE_YOURSELF
                          2024-09-25 11:35:16.161 - info: discovery.0 (10773) Got terminate signal TERMINATE_YOURSELF
                          2024-09-25 11:35:16.162 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
                          2024-09-25 11:35:16.162 - info: discovery.0 (10773) terminating
                          2024-09-25 11:35:16.161 - info: backitup.0 (10758) terminating
                          2024-09-25 11:35:16.162 - info: backitup.0 (10758) Terminated (NO_ERROR): Without reason
                          2024-09-25 11:35:16.162 - info: discovery.0 (10773) Terminated (NO_ERROR): Without reason
                          2024-09-25 11:35:16.162 - info: admin.0 (10717) terminating
                          2024-09-25 11:35:16.163 - info: host.ioTest stopInstance system.adapter.backitup.0 send kill signal
                          2024-09-25 11:35:16.163 - info: host.ioTest stopInstance system.adapter.discovery.0 send kill signal
                          2024-09-25 11:35:16.163 - info: admin.0 (10717) Terminated (NO_ERROR): Without reason
                          2024-09-25 11:35:16.657 - info: discovery.0 (10773) terminating
                          2024-09-25 11:35:16.658 - info: backitup.0 (10758) terminating
                          2024-09-25 11:35:16.659 - info: admin.0 (10717) terminating
                          2024-09-25 11:35:16.694 - info: host.ioTest instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                          2024-09-25 11:35:16.694 - info: host.ioTest instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                          2024-09-25 11:35:16.735 - info: host.ioTest instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                          2024-09-25 11:35:16.735 - info: host.ioTest All instances are stopped.
                          2024-09-25 11:35:16.779 - info: host.ioTest terminated
                          2024-09-25 11:35:23.318 - info: host.ioTest iobroker.js-controller version 6.0.11 js-controller starting
                          2024-09-25 11:35:23.320 - info: host.ioTest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                          2024-09-25 11:35:23.320 - info: host.ioTest hostname: ioTest, node: v20.17.0
                          2024-09-25 11:35:23.320 - info: host.ioTest ip addresses: 192.168.56.243 fe80::be24:11ff:fee6:705f
                          2024-09-25 11:35:23.606 - info: host.ioTest connected to Objects and States
                          2024-09-25 11:35:23.612 - info: host.ioTest added notifications configuration of host
                          2024-09-25 11:35:23.785 - info: host.ioTest 3 instances found
                          2024-09-25 11:35:23.787 - info: host.ioTest starting 3 instances
                          2024-09-25 11:35:23.836 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeCurrent"
                          2024-09-25 11:35:23.934 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 329
                          2024-09-25 11:35:23.972 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewest"
                          2024-09-25 11:35:23.973 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewestNext"
                          2024-09-25 11:35:23.975 - info: host.ioTest Delete state "system.host.ioTest.versions.npmCurrent"
                          2024-09-25 11:35:23.977 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewest"
                          2024-09-25 11:35:23.978 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewestNext"
                          2024-09-25 11:35:23.979 - info: host.ioTest Some obsolete host states deleted.
                          2024-09-25 11:35:24.476 - info: admin.0 (329) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 11:35:24.486 - info: admin.0 (329) requesting all objects
                          2024-09-25 11:35:24.655 - info: admin.0 (329) received all objects
                          2024-09-25 11:35:24.732 - info: admin.0 (329) socket.io server listening on port 8081
                          2024-09-25 11:35:24.733 - info: admin.0 (329) http server listening on port 8081
                          2024-09-25 11:35:24.733 - info: admin.0 (329) Use link "http://127.0.0.1:8081" to configure.
                          2024-09-25 11:35:27.900 - info: host.ioTest instance system.adapter.backitup.0 in version "3.0.22" started with pid 370
                          2024-09-25 11:35:28.009 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 11:35:28.315 - info: backitup.0 (370) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 11:35:28.327 - info: backitup.0 (370) [iobroker] backup will be activated at 02:48 every 1 day(s)
                          2024-09-25 11:35:31.888 - info: host.ioTest instance system.adapter.discovery.0 in version "5.0.0" started with pid 385
                          2024-09-25 11:35:32.281 - info: discovery.0 (385) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 11:35:36.379 - info: admin.0 (329) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 11:35:36.698 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 11:38:43.322 - info: host.ioTest iobroker add javascript
                          2024-09-25 11:38:43.887 - info: host.ioTest iobroker NPM version: 10.8.2
                          2024-09-25 11:38:43.888 - info: host.ioTest iobroker Installing iobroker.javascript@8.7.6... (System call)
                          2024-09-25 11:38:49.868 - info: host.ioTest iobroker
                          2024-09-25 11:38:49.869 - info: host.ioTest iobroker added 16 packages in 6s72 packages are looking for funding run `npm fund` for details
                          2024-09-25 11:38:49.881 - info: host.ioTest iobroker host.ioTest install adapter javascript
                          2024-09-25 11:38:49.897 - info: host.ioTest iobroker upload [881] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                          2024-09-25 11:38:49.981 - info: host.ioTest iobroker upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js application/javascript
                          2024-09-25 11:38:50.136 - info: host.ioTest iobroker upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_object.js google-blockly/own/blocks_object.js application/javascript
                          2024-09-25 11:38:50.226 - info: host.ioTest iobroker upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/864.4c85ffd6.chunk.css static/css/864.4c85ffd6.chunk.css text/css
                          2024-09-25 11:38:50.596 - info: host.ioTest iobroker upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/173.4e774f7f.chunk.js static/js/173.4e774f7f.chunk.js application/javascript
                          2024-09-25 11:38:50.745 - info: host.ioTest iobroker upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/26.79c81b4e.chunk.js static/js/26.79c81b4e.chunk.js application/javascript
                          2024-09-25 11:38:51.495 - info: host.ioTest iobroker upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/320.d9816b46.chunk.js.map static/js/320.d9816b46.chunk.js.map application/json
                          2024-09-25 11:38:51.817 - info: host.ioTest iobroker upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.168f947c.chunk.js.map static/js/409.168f947c.chunk.js.map application/json
                          2024-09-25 11:38:52.050 - info: host.ioTest iobroker upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/456.97a46315.chunk.js.LICENSE.txt static/js/456.97a46315.chunk.js.LICENSE.txt text/plain
                          2024-09-25 11:38:52.655 - info: host.ioTest iobroker upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/61.913ccfa8.chunk.js.map static/js/61.913ccfa8.chunk.js.map application/json
                          2024-09-25 11:38:53.181 - info: host.ioTest iobroker upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/709.88d87b7c.chunk.js.map static/js/709.88d87b7c.chunk.js.map application/json
                          2024-09-25 11:38:53.457 - info: host.ioTest iobroker upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/826.76c09000.chunk.js.map static/js/826.76c09000.chunk.js.map application/json
                          2024-09-25 11:38:53.957 - info: host.ioTest iobroker upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/880.e4029d50.chunk.js static/js/880.e4029d50.chunk.js application/javascript
                          2024-09-25 11:38:54.341 - info: host.ioTest iobroker upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/961.02d44700.chunk.js.map static/js/961.02d44700.chunk.js.map application/json
                          2024-09-25 11:38:54.428 - info: host.ioTest iobroker upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.720010c8.js static/js/main.720010c8.js application/javascript
                          2024-09-25 11:38:54.517 - info: host.ioTest iobroker upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Cellar.7ec1b1803a2437c8b78c.svg static/media/Cellar.7ec1b1803a2437c8b78c.svg image/svg+xml
                          2024-09-25 11:38:54.604 - info: host.ioTest iobroker upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Living Room.3c380ab767be35f904e1.svg static/media/Living Room.3c380ab767be35f904e1.svg image/svg+xml
                          2024-09-25 11:38:54.623 - info: host.ioTest iobroker upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/People.12a7e9127e72f3259186.svg static/media/People.12a7e9127e72f3259186.svg image/svg+xml
                          2024-09-25 11:38:54.641 - info: host.ioTest iobroker upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Security.1ec78971bd34efa950f8.svg static/media/Security.1ec78971bd34efa950f8.svg image/svg+xml
                          2024-09-25 11:38:54.656 - info: host.ioTest iobroker upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Storeroom.7de4e6f3364554459b8a.svg static/media/Storeroom.7de4e6f3364554459b8a.svg image/svg+xml
                          2024-09-25 11:38:54.674 - info: host.ioTest iobroker upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                          2024-09-25 11:38:54.690 - info: host.ioTest iobroker upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                          2024-09-25 11:38:54.706 - info: host.ioTest iobroker upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                          2024-09-25 11:38:54.729 - info: host.ioTest iobroker upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                          2024-09-25 11:38:54.768 - info: host.ioTest iobroker upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                          2024-09-25 11:38:54.770 - info: host.ioTest iobroker upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                          2024-09-25 11:38:54.773 - info: host.ioTest iobroker upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                          2024-09-25 11:38:54.775 - info: host.ioTest iobroker upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                          2024-09-25 11:38:54.778 - info: host.ioTest iobroker upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                          2024-09-25 11:38:54.780 - info: host.ioTest iobroker upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                          2024-09-25 11:38:54.790 - info: host.ioTest iobroker upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                          2024-09-25 11:38:54.793 - info: host.ioTest iobroker upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                          2024-09-25 11:38:54.797 - info: host.ioTest iobroker upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                          2024-09-25 11:38:54.800 - info: host.ioTest iobroker upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                          2024-09-25 11:38:54.814 - info: host.ioTest iobroker upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                          2024-09-25 11:38:54.817 - info: host.ioTest iobroker upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                          2024-09-25 11:38:54.819 - info: host.ioTest iobroker upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                          2024-09-25 11:38:54.821 - info: host.ioTest iobroker upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                          2024-09-25 11:38:54.866 - info: host.ioTest iobroker upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                          2024-09-25 11:38:54.871 - info: host.ioTest iobroker upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                          2024-09-25 11:38:54.875 - info: host.ioTest iobroker upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                          2024-09-25 11:38:54.877 - info: host.ioTest iobroker upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                          2024-09-25 11:38:54.879 - info: host.ioTest iobroker upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                          2024-09-25 11:38:54.881 - info: host.ioTest iobroker upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                          2024-09-25 11:38:54.883 - info: host.ioTest iobroker upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                          2024-09-25 11:38:54.902 - info: host.ioTest iobroker host.ioTest object _design/script created/updated
                          2024-09-25 11:38:54.903 - info: host.ioTest iobroker host.ioTest object script.js created/updated
                          2024-09-25 11:38:54.904 - info: host.ioTest iobroker host.ioTest object script.js.common created/updated
                          2024-09-25 11:38:54.904 - info: host.ioTest iobroker host.ioTest object script.js.global created/updated
                          2024-09-25 11:38:54.906 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript created/updated
                          2024-09-25 11:38:54.924 - info: host.ioTest iobroker host.ioTest create instance javascript
                          2024-09-25 11:38:54.926 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.alive created
                          2024-09-25 11:38:54.926 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.connected created
                          2024-09-25 11:38:54.927 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.compactMode created
                          2024-09-25 11:38:54.928 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.cpu created
                          2024-09-25 11:38:54.929 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.cputime created
                          2024-09-25 11:38:54.931 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.memHeapUsed created
                          2024-09-25 11:38:54.932 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.memHeapTotal created
                          2024-09-25 11:38:54.933 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.memRss created
                          2024-09-25 11:38:54.934 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.uptime created
                          2024-09-25 11:38:54.935 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.inputCount created
                          2024-09-25 11:38:54.936 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.outputCount created
                          2024-09-25 11:38:54.937 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.eventLoopLag created
                          2024-09-25 11:38:54.938 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.sigKill created
                          2024-09-25 11:38:54.942 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.logLevel created
                          2024-09-25 11:38:54.942 - info: host.ioTest iobroker host.ioTest object javascript.0.variables created
                          2024-09-25 11:38:54.943 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.astro created
                          2024-09-25 11:38:54.945 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.isDayTime created
                          2024-09-25 11:38:54.946 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.isDaylightSaving created
                          2024-09-25 11:38:54.946 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.dayTime created
                          2024-09-25 11:38:54.947 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.rulesTour created
                          2024-09-25 11:38:54.948 - info: host.ioTest iobroker host.ioTest object javascript.0.debug created
                          2024-09-25 11:38:54.949 - info: host.ioTest iobroker host.ioTest object javascript.0.debug.to created
                          2024-09-25 11:38:54.950 - info: host.ioTest iobroker host.ioTest object javascript.0.debug.from created
                          2024-09-25 11:38:54.951 - info: host.ioTest iobroker host.ioTest object javascript.0.debug.rules created
                          2024-09-25 11:38:54.958 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0 created
                          2024-09-25 11:38:55.979 - info: host.ioTest iobroker exit 0
                          2024-09-25 11:38:56.110 - info: host.ioTest iobroker add history
                          2024-09-25 11:38:56.688 - info: host.ioTest iobroker NPM version: 10.8.2
                          2024-09-25 11:38:56.688 - info: host.ioTest iobroker Installing iobroker.history@3.0.1... (System call)
                          2024-09-25 11:38:58.072 - info: host.ioTest instance system.adapter.javascript.0 in version "8.7.6" started with pid 496
                          2024-09-25 11:38:58.218 - info: host.ioTest iobroker
                          2024-09-25 11:38:58.219 - info: host.ioTest iobroker added 1 package in 1s72 packages are looking for funding run `npm fund` for details
                          2024-09-25 11:38:58.229 - info: host.ioTest iobroker host.ioTest install adapter history
                          2024-09-25 11:38:58.242 - info: host.ioTest iobroker upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                          2024-09-25 11:38:58.247 - info: host.ioTest iobroker upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          2024-09-25 11:38:58.249 - info: host.ioTest iobroker upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          2024-09-25 11:38:58.251 - info: host.ioTest iobroker upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          2024-09-25 11:38:58.253 - info: host.ioTest iobroker upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          2024-09-25 11:38:58.255 - info: host.ioTest iobroker upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          2024-09-25 11:38:58.257 - info: host.ioTest iobroker upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          2024-09-25 11:38:58.259 - info: host.ioTest iobroker upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          2024-09-25 11:38:58.261 - info: host.ioTest iobroker upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          2024-09-25 11:38:58.264 - info: host.ioTest iobroker upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          2024-09-25 11:38:58.267 - info: host.ioTest iobroker upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          2024-09-25 11:38:58.268 - info: host.ioTest iobroker upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                          2024-09-25 11:38:58.270 - info: host.ioTest iobroker upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                          2024-09-25 11:38:58.272 - info: host.ioTest iobroker upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                          2024-09-25 11:38:58.282 - info: host.ioTest iobroker host.ioTest object system.adapter.history created/updated
                          2024-09-25 11:38:58.291 - info: host.ioTest iobroker host.ioTest create instance history
                          2024-09-25 11:38:58.294 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.alive created
                          2024-09-25 11:38:58.295 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.connected created
                          2024-09-25 11:38:58.297 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.compactMode created
                          2024-09-25 11:38:58.298 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.cpu created
                          2024-09-25 11:38:58.299 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.cputime created
                          2024-09-25 11:38:58.300 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.memHeapUsed created
                          2024-09-25 11:38:58.302 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.memHeapTotal created
                          2024-09-25 11:38:58.303 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.memRss created
                          2024-09-25 11:38:58.304 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.uptime created
                          2024-09-25 11:38:58.305 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.inputCount created
                          2024-09-25 11:38:58.306 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.outputCount created
                          2024-09-25 11:38:58.308 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.eventLoopLag created
                          2024-09-25 11:38:58.309 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.sigKill created
                          2024-09-25 11:38:58.311 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.logLevel created
                          2024-09-25 11:38:58.312 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0 created
                          2024-09-25 11:38:58.707 - info: javascript.0 (496) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 11:38:58.742 - info: javascript.0 (496) requesting all states
                          2024-09-25 11:38:58.743 - info: javascript.0 (496) requesting all objects
                          2024-09-25 11:38:58.800 - info: javascript.0 (496) received all states
                          2024-09-25 11:38:58.849 - info: javascript.0 (496) received all objects
                          2024-09-25 11:38:59.322 - info: host.ioTest iobroker exit 0
                          2024-09-25 11:39:10.927 - info: host.ioTest instance system.adapter.history.0 in version "3.0.1" started with pid 511
                          2024-09-25 11:39:11.319 - info: history.0 (511) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 11:39:11.374 - info: history.0 (511) Set default history instance to "history.0"
                          2024-09-25 11:39:15.959 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
                          2024-09-25 11:39:15.963 - info: admin.0 (329) Got terminate signal TERMINATE_YOURSELF
                          2024-09-25 11:39:15.964 - info: admin.0 (329) terminating http server on port 8081
                          2024-09-25 11:39:15.965 - info: admin.0 (329) terminating
                          2024-09-25 11:39:15.966 - info: admin.0 (329) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-09-25 11:39:16.004 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
                          2024-09-25 11:39:16.466 - info: admin.0 (329) terminating
                          2024-09-25 11:39:16.482 - info: host.ioTest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-09-25 11:39:19.585 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 526
                          2024-09-25 11:39:20.093 - info: admin.0 (526) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 11:39:20.105 - info: admin.0 (526) requesting all objects
                          2024-09-25 11:39:20.289 - info: admin.0 (526) received all objects
                          2024-09-25 11:39:20.363 - info: admin.0 (526) Secure socket.io server listening on port 8081
                          2024-09-25 11:39:20.364 - info: admin.0 (526) https server listening on port 8081
                          2024-09-25 11:39:20.364 - info: admin.0 (526) Use link "https://127.0.0.1:8081" to configure.
                          2024-09-25 11:39:37.141 - info: admin.0 (526) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
                          2024-09-25 11:39:48.042 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 11:40:17.163 - info: discovery.0 (385) Discovering devices with a HF-LPB100 chipset...
                          2024-09-25 11:40:17.169 - info: discovery.0 (385) Discovering mDNS devices...
                          2024-09-25 11:40:17.170 - info: discovery.0 (385) Discovering ping devices...
                          2024-09-25 11:40:17.195 - info: discovery.0 (385) Discovering UPnP devices...
                          2024-09-25 11:40:17.197 - info: discovery.0 (385) Discovering wifi-mi-light devices...
                          2024-09-25 11:40:17.205 - warn: discovery.0 (385) tr-064.0 not installed
                          2024-09-25 11:40:17.205 - info: discovery.0 (385) Done discovering tr064 devices. 0 packages received
                          2024-09-25 11:40:18.697 - info: discovery.0 (385) Done discovering RESOL VBus devices. 0 packages received
                          2024-09-25 11:40:19.198 - info: discovery.0 (385) Done discovering wifi-mi-light devices. 0 packages received
                          2024-09-25 11:40:22.174 - info: discovery.0 (385) Done discovering SMA Speedwire devices. 0 packages received
                          2024-09-25 11:40:22.174 - info: discovery.0 (385) Done discovering udp devices. 1 packages received
                          2024-09-25 11:40:27.165 - info: discovery.0 (385) Done discovering HF-LPB100 devices. 0 packages received
                          2024-09-25 11:40:30.509 - info: discovery.0 (385) Done discovering ping devices. 1 packages received
                          2024-09-25 11:40:32.171 - info: discovery.0 (385) Done discovering mdns devices. 0 packages received
                          2024-09-25 11:40:32.196 - info: discovery.0 (385) Done discovering upnp devices. 18 packages received
                          2024-09-25 11:40:32.199 - info: discovery.0 (385) Found 4 addresses
                          2024-09-25 11:40:49.408 - info: discovery.0 (385) Discovery finished. Found new or modified 7 instances
                          2024-09-25 11:40:49.464 - info: discovery.0 (385) Discovery finished
                          2024-09-25 11:44:05.124 - info: history.0 (511) enabled logging of system.host.ioTest.freemem, Alias=false, WriteNulls=true
                          2024-09-25 11:44:31.505 - info: history.0 (511) enabled logging of system.host.ioTest.mem, Alias=false, WriteNulls=true
                          2024-09-25 12:00:43.151 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 12:06:08.821 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 12:07:37.652 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 12:07:38.465 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 12:13:18.504 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 12:31:49.466 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 12:33:56.558 - info: history.0 (511) enabled logging of system.adapter.admin.0.memRss, Alias=false, WriteNulls=true
                          2024-09-25 12:36:54.832 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 12:44:43.508 - info: admin.0 (526) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
                          2024-09-25 13:16:34.592 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 13:21:12.611 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 13:21:13.292 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 13:26:16.181 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 13:26:16.903 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 13:33:01.954 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 13:42:08.890 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 13:42:12.205 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 14:28:19.717 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 14:30:59.723 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 17:58:14.049 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 18:02:04.070 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 18:02:26.241 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 18:02:37.756 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 18:13:53.085 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 18:13:57.028 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 18:28:33.016 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 18:28:38.116 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 18:43:11.126 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 18:48:25.001 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 19:17:26.663 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 19:17:30.918 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 19:28:25.578 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 19:29:25.582 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 19:53:29.746 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 19:58:39.494 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 19:58:40.510 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 20:02:05.439 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 20:02:10.921 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 20:02:16.615 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 20:02:17.150 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 20:02:44.103 - info: backitup.0 (370) cleaned everything up...
                          2024-09-25 20:02:44.103 - info: host.ioTest received SIGTERM
                          2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
                          2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.backitup.0 (force=false, process=true)
                          2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.discovery.0 (force=false, process=true)
                          2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.javascript.0 (force=false, process=true)
                          2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.history.0 (force=false, process=true)
                          2024-09-25 20:02:44.107 - info: discovery.0 (385) Got terminate signal TERMINATE_YOURSELF
                          2024-09-25 20:02:44.106 - info: javascript.0 (496) Got terminate signal TERMINATE_YOURSELF
                          2024-09-25 20:02:44.105 - info: admin.0 (526) terminating https server on port 8081
                          2024-09-25 20:02:44.108 - info: javascript.0 (496) terminating
                          2024-09-25 20:02:44.109 - info: javascript.0 (496) Terminated (NO_ERROR): Without reason
                          2024-09-25 20:02:44.108 - info: backitup.0 (370) Got terminate signal TERMINATE_YOURSELF
                          2024-09-25 20:02:44.111 - info: admin.0 (526) Got terminate signal TERMINATE_YOURSELF
                          2024-09-25 20:02:44.110 - info: history.0 (511) terminating
                          2024-09-25 20:02:44.112 - info: history.0 (511) Terminated (NO_ERROR): Without reason
                          2024-09-25 20:02:44.113 - info: admin.0 (526) terminating
                          2024-09-25 20:02:44.114 - info: admin.0 (526) Terminated (NO_ERROR): Without reason
                          2024-09-25 20:02:44.147 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
                          2024-09-25 20:02:44.147 - info: host.ioTest stopInstance system.adapter.backitup.0 send kill signal
                          2024-09-25 20:02:44.147 - info: host.ioTest stopInstance system.adapter.discovery.0 send kill signal
                          2024-09-25 20:02:44.148 - info: host.ioTest stopInstance system.adapter.javascript.0 send kill signal
                          2024-09-25 20:02:44.150 - info: discovery.0 (385) terminating
                          2024-09-25 20:02:44.151 - info: backitup.0 (370) terminating
                          2024-09-25 20:02:44.151 - info: discovery.0 (385) Terminated (NO_ERROR): Without reason
                          2024-09-25 20:02:44.151 - info: backitup.0 (370) Terminated (NO_ERROR): Without reason
                          2024-09-25 20:02:44.573 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 20:02:44.608 - info: javascript.0 (496) terminating
                          2024-09-25 20:02:44.608 - info: backitup.0 (370) terminating
                          2024-09-25 20:02:44.608 - info: discovery.0 (385) terminating
                          2024-09-25 20:02:44.609 - info: admin.0 (526) terminating
                          2024-09-25 20:02:44.634 - info: host.ioTest instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                          2024-09-25 20:02:44.634 - info: host.ioTest instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                          2024-09-25 20:02:44.638 - info: host.ioTest instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                          2024-09-25 20:02:44.666 - info: host.ioTest instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                          2024-09-25 20:02:44.668 - info: host.ioTest instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                          2024-09-25 20:02:44.668 - info: host.ioTest All instances are stopped.
                          2024-09-25 20:02:44.836 - info: host.ioTest terminated
                          2024-09-25 20:02:46.206 - info: host.ioTest iobroker.js-controller version 6.0.11 js-controller starting
                          2024-09-25 20:02:46.208 - info: host.ioTest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                          2024-09-25 20:02:46.208 - info: host.ioTest hostname: ioTest, node: v20.17.0
                          2024-09-25 20:02:46.208 - info: host.ioTest ip addresses: 192.168.56.243 fe80::be24:11ff:fee6:705f
                          2024-09-25 20:02:46.578 - info: host.ioTest connected to Objects and States
                          2024-09-25 20:02:46.583 - info: host.ioTest added notifications configuration of host
                          2024-09-25 20:02:46.727 - info: host.ioTest 5 instances found
                          2024-09-25 20:02:46.729 - info: host.ioTest starting 5 instances
                          2024-09-25 20:02:46.833 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeCurrent"
                          2024-09-25 20:02:46.840 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewest"
                          2024-09-25 20:02:46.848 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 4493
                          2024-09-25 20:02:46.848 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewestNext"
                          2024-09-25 20:02:46.850 - info: host.ioTest Delete state "system.host.ioTest.versions.npmCurrent"
                          2024-09-25 20:02:46.891 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewest"
                          2024-09-25 20:02:46.892 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewestNext"
                          2024-09-25 20:02:46.893 - info: host.ioTest Some obsolete host states deleted.
                          2024-09-25 20:02:47.330 - info: admin.0 (4493) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 20:02:47.339 - info: admin.0 (4493) requesting all objects
                          2024-09-25 20:02:47.505 - info: admin.0 (4493) received all objects
                          2024-09-25 20:02:47.578 - info: admin.0 (4493) Secure socket.io server listening on port 8081
                          2024-09-25 20:02:47.579 - info: admin.0 (4493) https server listening on port 8081
                          2024-09-25 20:02:47.579 - info: admin.0 (4493) Use link "https://127.0.0.1:8081" to configure.
                          2024-09-25 20:02:50.860 - info: host.ioTest instance system.adapter.javascript.0 in version "8.7.6" started with pid 4534
                          2024-09-25 20:02:51.452 - info: javascript.0 (4534) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 20:02:51.491 - info: javascript.0 (4534) requesting all states
                          2024-09-25 20:02:51.491 - info: javascript.0 (4534) requesting all objects
                          2024-09-25 20:02:51.550 - info: javascript.0 (4534) received all states
                          2024-09-25 20:02:51.598 - info: javascript.0 (4534) received all objects
                          2024-09-25 20:02:51.682 - info: admin.0 (4493) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
                          2024-09-25 20:02:54.822 - info: host.ioTest instance system.adapter.history.0 in version "3.0.1" started with pid 4549
                          2024-09-25 20:02:55.216 - info: history.0 (4549) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 20:02:55.267 - info: history.0 (4549) enabled logging of system.adapter.admin.0.memRss (Count=1), Alias=false
                          2024-09-25 20:02:55.268 - info: history.0 (4549) enabled logging of system.host.ioTest.mem (Count=2), Alias=false
                          2024-09-25 20:02:55.268 - info: history.0 (4549) enabled logging of system.host.ioTest.freemem (Count=3), Alias=false
                          2024-09-25 20:02:58.825 - info: host.ioTest instance system.adapter.backitup.0 in version "3.0.22" started with pid 4564
                          2024-09-25 20:02:59.241 - info: backitup.0 (4564) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 20:02:59.258 - info: backitup.0 (4564) [iobroker] backup will be activated at 02:48 every 1 day(s)
                          2024-09-25 20:03:02.822 - info: host.ioTest instance system.adapter.discovery.0 in version "5.0.0" started with pid 4579
                          2024-09-25 20:03:03.220 - info: discovery.0 (4579) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                          2024-09-25 20:03:09.139 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 20:04:10.889 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 20:04:11.635 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 20:08:24.918 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 20:20:28.303 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 20:20:33.031 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 20:34:43.640 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 20:34:47.954 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 21:08:27.999 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 21:08:38.367 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          2024-09-25 22:08:44.182 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                          2024-09-25 22:09:09.131 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                          Peterfido
                          • P peterfido
                            @crunchip
                            crunchipC
                            crunchipC
                            #113
                            @peterfido wir reden hier auch nicht von einem Redis Server um von jsonl auf Redis um zu stellen., sondern von der internen DB.
                            Iobroker wurde ab einer bestimmten Version optimiert und auf Redis umgestellt.
                            Wie oben schon geschrieben, nicht sicher ab welcher Version das eingeführt wurde.
                              CodierknechtC
                              CodierknechtC
                              Codierknecht
                              #114
                              @crunchip
                              Gerade gesehen, dass der Admin ja auf "Debug" steht. Darum sehe ich diese Einträge bei mir nicht.
                              Dann brauche ich mich ja nicht zu wundern. Alles gut.
                              Bleibt trotzdem ein Mysterium.
                              Kann mir kaum vorstellen, dass es an ioBroker liegt. Das würde hier sonst dutzendfach aufschlagen.
                              Irgendetwas ist an der Installation von Proxmox anders als bei allen anderen.
                              Wobei ich zugeben muss, dass ich meines auch nicht stringent nach irgend einer Anleitung installiert habe. Bootfähigen Stick erzeugt und dann gestartet. Der Rest ist eigentlich selbsterklärend.
                              HmIP|ZigBee|Tasmota|Unifi
                              Zabbix Certified Specialist
                              crunchipC M 2 Antworten Letzte Antwort
                                @crunchip
                                crunchipC
                                crunchipC
                                Developer Global Moderator Most Active Forum Testing
                                #115
                                korrekt
                                und extra chatgpt bemüht(zu faul zum suchen)😁
                                Die Umstellung von der internen ioBroker-Datenbank auf Redis erfolgte mit der Einführung der Version 1.5.0 des ioBroker.js-Controllers, die am 16. September 2018 veröffentlicht wurde
                                keine Ahnung, daher fragte ich ja nach dem syslog
                                  korrekt
                                  P
                                  P
                                  peterfido
                                  #116
                                  @crunchip
                                  okay, auf debug wird es aufgeführt.
                                  2024-09-26 06:42:42.326 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
                                  2024-09-26 06:42:42.330 - info: admin.0 (4493) Got terminate signal TERMINATE_YOURSELF
                                  2024-09-26 06:42:42.331 - info: admin.0 (4493) terminating https server on port 8081
                                  2024-09-26 06:42:42.332 - info: admin.0 (4493) terminating
                                  2024-09-26 06:42:42.332 - info: admin.0 (4493) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2024-09-26 06:42:42.371 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
                                  2024-09-26 06:42:42.833 - info: admin.0 (4493) terminating
                                  2024-09-26 06:42:42.859 - info: host.ioTest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-09-26 06:42:45.965 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 5251
                                  2024-09-26 06:42:46.371 - debug: admin.0 (5251) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2024-09-26 06:42:46.378 - debug: admin.0 (5251) Objects client ready ... initialize now
                                  2024-09-26 06:42:46.379 - debug: admin.0 (5251) Objects create System PubSub Client
                                  2024-09-26 06:42:46.379 - debug: admin.0 (5251) Objects create User PubSub Client
                                  2024-09-26 06:42:46.383 - debug: admin.0 (5251) Objects client initialize lua scripts
                                  2024-09-26 06:42:46.385 - debug: admin.0 (5251) Objects connected to redis: 127.0.0.1:9001
                                  2024-09-26 06:42:46.389 - debug: admin.0 (5251) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2024-09-26 06:42:46.390 - debug: admin.0 (5251) States create System PubSub Client
                                  2024-09-26 06:42:46.390 - debug: admin.0 (5251) States create User PubSub Client
                                  2024-09-26 06:42:46.392 - debug: admin.0 (5251) States connected to redis: 127.0.0.1:9000
                                  2024-09-26 06:42:46.398 - debug: admin.0 (5251) Plugin sentry Initialize Plugin (enabled=true)
                                  2024-09-26 06:42:46.462 - info: admin.0 (5251) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                                  2024-09-26 06:42:46.472 - info: admin.0 (5251) requesting all objects
                                  peter@ioTest:~$ iob status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  peter@ioTest:~$
                                  Peterfido
                                  • P peterfido
                                    @marko67
                                    apt update
                                    apt install sudo
                                    apt install curl
                                    exit
                                    sudo apt update
                                    crunchipC
                                    crunchipC
                                    #117
                                    @peterfido sagte in NUC-Proxmox-steigender Ram:
                                    diese Dreiecke sind aufklappbar
                                    @marko67 sagte in NUC-Proxmox-steigender Ram:
                                    seltsam
                                    kannst du testweise einen neuen LXC erstellen, diesmal aber ein ubuntu template nehmen und mal nur eine reine Installation, ohne irgend etwas einzurichten oder zu löschen, nach der iobroker Installation
                                    • M marko67
                                      @arteck
                                      Mein Problem ist, dass der RAM bis auf 100% hoch läuft und dann auch andere Container einfrieren. So war es auf dem vorherigen System.
                                      Hier mal der RAM Verbrauch nach knapp 3 Stunden
                                      MartinPM
                                      MartinPM
                                      MartinP
                                      #118
                                      1. Wenn man ein sicheres System haben will, darf man in Summe nur so viel RAM auf die Container verteilen, wie Proxmox bereitstellen kann ...
                                        Hast Du ein System mit 8 GB RAM und drei Containern, sollte man nicht mehr als ca 7,5 GB auf die drei Container verteilen, also z.B. 2,5 + 2,5 + 2,5
                                        Verteilt man mehr, als vorhanden ist auf die Container, gibt es die von Dir beobachteten Symptome, wenn einer der Container amok läuft, und ausnutzt, was ihm zusteht.
                                      2. Meine Frage war, wie sich das RAM verhält, WÄHREND der iobroker durch "iob stop" gestoppt ist.
                                        Sinkt die "Memory usage" wieder?
                                        Auf den ursprünglichen Stand vor dem ersten Start des iob?
                                      • MartinPM MartinP
                                        crunchipC
                                        crunchipC
                                        #119
                                        @martinp laut seiner Aussage hat er doch 16GB Gesamt
                                        8Gb für iobroker und 2weitere LXC mit 1 und 2 GB Ram, sollte in Summe dann ja passen
                                        @martinp sagte in NUC-Proxmox-steigender Ram:
                                        ja, hat er oben doch schon gezeigt
                                        • MartinPM
                                          MartinPM
                                          MartinP
                                          #120
                                          iob stop ausgeführt. Ist mit 157 MB neu gestartet und nun wieder bei fast 1,5 GB steigend
                                          Sorry, hatte nur die grafische Auswertung beachtet, und da keinen Abfall der RAM-Nutzung durch IOB gesehen
                                          Ist "Nesting" im Lxc-Container aktiviert?
                                          Und hier die Netzwerk-Einstellungen des Containers:
                                          Da habe ich gegenüber der Fritzbox getrickst ...
                                          84.0k
