  3. Einsteigerfragen
  4. NUC-Proxmox-steigender Ram
    5.4k
137 Beiträge 13 Kommentatoren 30.3k Aufrufe 12 Beobachtet
  • M marko67
    @crunchip
    Der Log ab der Installation:
    2024-09-24 18:40:34.656 - info: host.ioB24 iobroker.js-controller version 6.0.11 js-controller starting
    2024-09-24 18:40:34.660 - info: host.ioB24 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-09-24 18:40:34.661 - info: host.ioB24 hostname: ioB24, node: v20.17.0
    2024-09-24 18:40:34.661 - info: host.ioB24 ip addresses: 192.168.1.152 2a02:810c:1bf:f826:be24:11ff:fe42:4bab fe80::be24:11ff:fe42:4bab
    2024-09-24 18:40:34.947 - info: host.ioB24 connected to Objects and States
    2024-09-24 18:40:34.972 - info: host.ioB24 Node.js version has changed from unknown to 20.17.0
    2024-09-24 18:40:34.987 - info: host.ioB24 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2024-09-24 18:40:34.991 - info: host.ioB24 added notifications configuration of host
    2024-09-24 18:40:35.222 - info: host.ioB24 3 instances found
    2024-09-24 18:40:35.226 - info: host.ioB24 starting 3 instances
    2024-09-24 18:40:35.257 - info: host.ioB24 instance system.adapter.admin.0 in version "7.1.2" started with pid 10305
    2024-09-24 18:40:36.702 - info: admin.0 (10305) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
    2024-09-24 18:40:36.725 - info: admin.0 (10305) requesting all objects
    2024-09-24 18:40:36.832 - info: admin.0 (10305) received all objects
    2024-09-24 18:40:36.844 - info: admin.0 (10305) Request actual repository...
    2024-09-24 18:40:36.863 - info: host.ioB24 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2024-09-24 18:40:36.870 - info: admin.0 (10305) socket.io server listening on port 8081
    2024-09-24 18:40:36.875 - info: admin.0 (10305) http server listening on port 8081
    2024-09-24 18:40:36.876 - info: admin.0 (10305) Use link "http://127.0.0.1:8081" to configure.
    2024-09-24 18:40:37.012 - warn: admin.0 (10305) Repository cannot be read: Active repo - stable
    2024-09-24 18:40:37.028 - warn: admin.0 (10305) Active repository "stable" cannot be read
    2024-09-24 18:40:38.942 - info: admin.0 (10305) Repository received successfully.
    2024-09-24 18:40:39.642 - info: host.ioB24 instance system.adapter.backitup.0 in version "3.0.22" started with pid 10358
    2024-09-24 18:40:40.935 - info: backitup.0 (10358) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
    2024-09-24 18:40:40.978 - info: backitup.0 (10358) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-09-24 18:40:43.416 - info: host.ioB24 instance system.adapter.discovery.0 in version "5.0.0" started with pid 10373
    2024-09-24 18:40:44.539 - info: discovery.0 (10373) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
    2024-09-24 18:41:03.833 - info: admin.0 (10305) ==> Connected system.user.admin from ::ffff:192.168.1.35
    2024-09-24 18:43:05.770 - info: host.ioB24 "system.adapter.discovery.0" disabled
    2024-09-24 18:43:05.772 - info: host.ioB24 stopInstance system.adapter.discovery.0 (force=false, process=true)
    2024-09-24 18:43:05.775 - info: discovery.0 (10373) Got terminate signal TERMINATE_YOURSELF
    2024-09-24 18:43:05.777 - info: discovery.0 (10373) terminating
    2024-09-24 18:43:05.778 - info: discovery.0 (10373) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-09-24 18:43:05.815 - info: host.ioB24 stopInstance system.adapter.discovery.0 send kill signal
    2024-09-24 18:43:06.279 - info: discovery.0 (10373) terminating
    2024-09-24 18:43:06.335 - info: host.ioB24 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-09-24 18:43:35.689 - info: host.ioB24 iobroker del discovery --debug
    2024-09-24 18:43:36.747 - info: host.ioB24 iobroker Delete adapter "discovery"
    2024-09-24 18:43:36.754 - info: host.ioB24 iobroker host.ioB24 Counted 1 instances of discovery
    2024-09-24 18:43:36.763 - info: host.ioB24 iobroker host.ioB24 Counted 1 meta of discovery
    2024-09-24 18:43:36.767 - info: host.ioB24 iobroker host.ioB24 Counted 1 adapter for discovery
    2024-09-24 18:43:36.775 - info: host.ioB24 iobroker host.ioB24 Counted 5 states of discovery
    2024-09-24 18:43:36.781 - info: host.ioB24 iobroker host.ioB24 Counted 15 states of system.adapter.discovery
    2024-09-24 18:43:36.783 - info: host.ioB24 iobroker host.ioB24 Counted 1 states (io.discovery.*) from states
    2024-09-24 18:43:36.788 - info: host.ioB24 iobroker host.ioB24 Counted 7 states (system.adapter.discovery.*) from states
    2024-09-24 18:43:37.060 - info: host.ioB24 iobroker host.ioB24 Counted 1 objects of discovery
    2024-09-24 18:43:37.127 - info: host.ioB24 iobroker host.ioB24 file discovery.admin deleted
    2024-09-24 18:43:37.131 - info: host.ioB24 iobroker host.ioB24 object discovery deleted
    2024-09-24 18:43:37.139 - info: host.ioB24 iobroker host.ioB24 object discovery.admin deleted
    2024-09-24 18:43:37.141 - info: host.ioB24 iobroker host.ioB24 Deleting 25 object(s).
    2024-09-24 18:43:37.204 - info: host.ioB24 object deleted system.adapter.discovery.0
    2024-09-24 18:43:37.205 - info: host.ioB24 iobroker host.ioB24 Deleting 8 state(s).
    2024-09-24 18:43:39.170 - info: host.ioB24 iobroker removed 42 packages in 2s58 packages are looking for funding run `npm fund` for details
    2024-09-24 18:43:40.206 - info: host.ioB24 iobroker exit 0
    2024-09-24 19:24:41.310 - info: host.ioB24 received SIGTERM
    2024-09-24 19:24:41.309 - info: backitup.0 (10358) cleaned everything up...
    2024-09-24 19:24:41.312 - info: host.ioB24 stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-09-24 19:24:41.313 - info: host.ioB24 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2024-09-24 19:24:41.318 - info: backitup.0 (10358) Got terminate signal TERMINATE_YOURSELF
    2024-09-24 19:24:41.313 - info: admin.0 (10305) terminating http server on port 8081
    2024-09-24 19:24:41.330 - info: host.ioB24 stopInstance system.adapter.admin.0 send kill signal
    2024-09-24 19:24:41.332 - info: host.ioB24 stopInstance system.adapter.backitup.0 send kill signal
    2024-09-24 19:24:41.351 - info: admin.0 (10305) Got terminate signal TERMINATE_YOURSELF
    2024-09-24 19:24:41.356 - info: admin.0 (10305) terminating
    2024-09-24 19:24:41.359 - info: admin.0 (10305) Terminated (NO_ERROR): Without reason
    2024-09-24 19:24:41.363 - info: backitup.0 (10358) terminating
    2024-09-24 19:24:41.365 - info: backitup.0 (10358) Terminated (NO_ERROR): Without reason
    2024-09-24 19:24:41.817 - info: backitup.0 (10358) terminating
    2024-09-24 19:24:41.842 - info: admin.0 (10305) terminating
    2024-09-24 19:24:41.897 - info: host.ioB24 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2024-09-24 19:24:41.977 - info: host.ioB24 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2024-09-24 19:24:41.977 - info: host.ioB24 All instances are stopped.
    2024-09-24 19:24:42.123 - info: host.ioB24 terminated
    2024-09-24 19:26:00.209 - info: host.ioB24 iobroker.js-controller version 6.0.11 js-controller starting
    2024-09-24 19:26:00.213 - info: host.ioB24 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-09-24 19:26:00.213 - info: host.ioB24 hostname: ioB24, node: v20.17.0
    2024-09-24 19:26:00.214 - info: host.ioB24 ip addresses: 192.168.1.152 2a02:810c:1bf:f826:be24:11ff:fe42:4bab fe80::be24:11ff:fe42:4bab
    2024-09-24 19:26:00.718 - info: host.ioB24 connected to Objects and States
    2024-09-24 19:26:00.733 - info: host.ioB24 added notifications configuration of host
    2024-09-24 19:26:01.069 - info: host.ioB24 2 instances found
    2024-09-24 19:26:01.074 - info: host.ioB24 starting 2 instances
    2024-09-24 19:26:01.352 - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeCurrent"
    2024-09-24 19:26:01.373 - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewest"
    2024-09-24 19:26:01.389 - info: host.ioB24 instance system.adapter.admin.0 in version "7.1.2" started with pid 329
    2024-09-24 19:26:01.420 - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewestNext"
    2024-09-24 19:26:01.423 - info: host.ioB24 Delete state "system.host.ioB24.versions.npmCurrent"
    2024-09-24 19:26:01.426 - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewest"
    2024-09-24 19:26:01.429 - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewestNext"
    2024-09-24 19:26:01.435 - info: host.ioB24 Some obsolete host states deleted.
    2024-09-24 19:26:03.503 - info: admin.0 (329) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
    2024-09-24 19:26:03.548 - info: admin.0 (329) requesting all objects
    2024-09-24 19:26:04.785 - info: admin.0 (329) received all objects
    2024-09-24 19:26:05.818 - info: admin.0 (329) socket.io server listening on port 8081
    2024-09-24 19:26:05.831 - info: host.ioB24 instance system.adapter.backitup.0 in version "3.0.22" started with pid 352
    2024-09-24 19:26:05.825 - info: admin.0 (329) http server listening on port 8081
    2024-09-24 19:26:05.825 - info: admin.0 (329) Use link "http://127.0.0.1:8081" to configure.
    2024-09-24 19:26:08.544 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.1.35
    2024-09-24 19:26:09.007 - info: backitup.0 (352) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
    2024-09-24 19:26:09.075 - info: backitup.0 (352) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-09-24 20:35:39.916 - info: host.ioB24 received SIGTERM
    2024-09-24 20:35:39.921 - info: backitup.0 (352) cleaned everything up...
    2024-09-24 20:35:39.919 - info: admin.0 (329) terminating http server on port 8081
    2024-09-24 20:35:39.923 - info: host.ioB24 stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-09-24 20:35:39.924 - info: host.ioB24 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2024-09-24 20:35:39.940 - info: backitup.0 (352) Got terminate signal TERMINATE_YOURSELF
    2024-09-24 20:35:39.943 - info: backitup.0 (352) terminating
    2024-09-24 20:35:39.945 - info: host.ioB24 stopInstance system.adapter.admin.0 send kill signal
    2024-09-24 20:35:39.947 - info: host.ioB24 stopInstance system.adapter.backitup.0 send kill signal
    2024-09-24 20:35:39.948 - info: backitup.0 (352) Terminated (NO_ERROR): Without reason
    2024-09-24 20:35:39.952 - info: admin.0 (329) Got terminate signal TERMINATE_YOURSELF
    2024-09-24 20:35:39.965 - info: admin.0 (329) terminating
    2024-09-24 20:35:39.966 - info: admin.0 (329) Terminated (NO_ERROR): Without reason
    2024-09-24 20:35:40.425 - info: backitup.0 (352) terminating
    2024-09-24 20:35:40.440 - info: admin.0 (329) terminating
    2024-09-24 20:35:40.515 - info: host.ioB24 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2024-09-24 20:35:40.612 - info: host.ioB24 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2024-09-24 20:35:40.612 - info: host.ioB24 All instances are stopped.
    2024-09-24 20:35:40.735 - info: host.ioB24 terminated
    2024-09-24 20:36:58.199 - info: host.ioB24 iobroker.js-controller version 6.0.11 js-controller starting
    2024-09-24 20:36:58.204 - info: host.ioB24 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-09-24 20:36:58.204 - info: host.ioB24 hostname: ioB24, node: v20.17.0
    2024-09-24 20:36:58.205 - info: host.ioB24 ip addresses: 192.168.1.152 2a02:810c:1bf:f826:be24:11ff:fe42:4bab fe80::be24:11ff:fe42:4bab
    2024-09-24 20:36:58.713 - info: host.ioB24 connected to Objects and States
    2024-09-24 20:36:58.729 - info: host.ioB24 added notifications configuration of host
    2024-09-24 20:36:59.043 - info: host.ioB24 2 instances found
    2024-09-24 20:36:59.048 - info: host.ioB24 starting 2 instances
    2024-09-24 20:36:59.157 - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeCurrent"
    2024-09-24 20:36:59.298 - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewest"
    2024-09-24 20:36:59.305 - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewestNext"
    2024-09-24 20:36:59.318 - info: host.ioB24 instance system.adapter.admin.0 in version "7.1.2" started with pid 329
    2024-09-24 20:36:59.349 - info: host.ioB24 Delete state "system.host.ioB24.versions.npmCurrent"
    2024-09-24 20:36:59.356 - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewest"
    2024-09-24 20:36:59.360 - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewestNext"
    2024-09-24 20:36:59.363 - info: host.ioB24 Some obsolete host states deleted.
    2024-09-24 20:37:01.262 - info: admin.0 (329) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
    2024-09-24 20:37:01.299 - info: admin.0 (329) requesting all objects
    2024-09-24 20:37:02.345 - info: admin.0 (329) received all objects
    2024-09-24 20:37:03.127 - info: admin.0 (329) socket.io server listening on port 8081
    2024-09-24 20:37:03.140 - info: admin.0 (329) http server listening on port 8081
    2024-09-24 20:37:03.141 - info: admin.0 (329) Use link "http://127.0.0.1:8081" to configure.
    2024-09-24 20:37:04.051 - info: host.ioB24 instance system.adapter.backitup.0 in version "3.0.22" started with pid 356
    2024-09-24 20:37:06.560 - info: backitup.0 (356) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
    2024-09-24 20:37:06.616 - info: backitup.0 (356) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-09-24 20:37:06.927 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.1.35
    MartinPM Online
    MartinPM Online
    MartinP
    #91
    @marko67 Ein Experiment wäre interessant:
    Wie verhält sich der Speicher, wenn man
    iob stop
    ausführt?
    Ist der nach dem Herunterfahren der ganzen iobroker Prozesse wieder "gesund"?
    • M marko67
      @crunchip @Codierknecht @Ro75
      Guten Abend
      Heute kpl. mit neuer Hardware gestartet.
      • Proxmox
      • ioBroker nach dieser Anleitung installiert: https://www.iobroker.net/#de/documentation/install/proxmox.md
      Ich kann mit 1000% Sicherheit sagen, dass alles genau nach Anleitung installiert ist.... das Verhalten das gleich ist wie vorher. Man mag mich für Verrückt halten, ich behaupt nun, dass wo anders ein Fehler ist.
      Kein Root, kein Discovery, keine billigen defekten RAM-Riegel. Und nun??
      arteckA Offline
      arteckA Offline
      arteck
      #92
      @marko67 ja und nu..hab ich auch
      wo ist jetzt dein problem ?? ist aber ne VM
      der LXC sieht so aus
      werkeln aber weniger adapter drauf
      im Grafana kann man es auch sehen
      die letzten 90 Tage...
      MartinPM M 2 Antworten Letzte Antwort
      • arteckA arteck
        MartinPM Online
        MartinPM Online
        MartinP
        #93
        @arteck Das Problem ist ja nicht der absolute Wert der Memory usage - das kann ja durchaus bei einem "fetten" System der Fall sein, sondern der stetige Anstieg zeugt von Problemen ...
        Meiner Meinung nach sollte nach ein paar Tagen ein stabiles "Plateau" erreicht sein.... hier mein System:
        Dazu stand im iob diag listing ....
        Objects and States
        Objects:        196
        States:         128
        wenn für so ein kleines System der Speicher so anschwillt ...
        So sieht es auf meinem System mit 15 x mehr Objekten - was nicht einmal 2 GB belegt - aus:
        Objects and States
        Objects:        2773
        States:         2338
        • MartinPM MartinP
          Objects and States
          Objects:        196
          States:         128
          Objects and States
          Objects:        2773
          States:         2338
          arteckA Offline
          arteckA Offline
          arteck
          #94
          @martinp darst aber nicht auf die Proxmox statistik gucken
          schau dirket inden container mit htop oder top
          da siehst du den belegten..
          Proxmix nutzt alles was geht.. schliesslich ist der dafür da der Arbeitsspeicher.. und nicht um 80% leer zu stehen
          • CodierknechtC Online
            Codierknecht
            #95
            Hier mal ein längerer Zeitraum meines Produktivsystems:
            Und hier der nagelneue LXC ... zeigt bislang keine Auffälligkeiten:
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            • arteckA arteck
              marko67
              #96
              @arteck
              Mein Problem ist, dass der RAM bis auf 100% hoch läuft und dann auch andere Container einfrieren. So war es auf dem vorherigen System.
              Hier mal der RAM Verbrauch nach knapp 3 Stunden
              P MartinPM 2 Antworten Letzte Antwort
              • M marko67
                @arteck
                peterfido
                #97
                @marko67 nach über fünf Stunden ist alles so, wie es sein soll.
                Wenn das Problem bei Dir bei einer frischen "nackten" Installation auftritt, muss irgendwas bei Deinem System anders sein.
                Peterfido
                  marko67
                  schrieb am zuletzt editiert von marko67
                  #98
                  @martinp
                  iob stop ausgeführt. Ist mit 157 MB neu gestartet und nun wieder bei fast 1,5 GB steigend
                  Anbei nochmals iob diag
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                   Static hostname: ioB24
                         Icon name: computer-container
                           Chassis: container ☐
                    Virtualization: lxc
                            Kernel: Linux 6.8.12-2-pve
                      Architecture: x86-64
                  model name      : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
                  Docker          : false
                  Virtualization  : lxc
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   21:13:08 up  4:34,  2 users,  load average: 0.19, 0.27, 0.25
                  CPU threads: 2
                  *** Time and Time Zones ***
                                 Local time: Wed 2024-09-25 21:13:08 CEST
                             Universal time: Wed 2024-09-25 19:13:08 UTC
                                   RTC time: n/a
                                NTP service: inactive
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  dirk
                  HOME=/home/dirk
                  GROUPS=dirk sudo users iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev
                  *** Display-Server-Setup ***
                  Display-Server: false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:            7.4G        1.6G        5.4G        114K        373M        5.8G
                  Swap:           536M          0B        536M
                  Total:          7.9G        1.6G        5.9G
                  Active iob-Instances:   3
                           7048 M total memory
                           1541 M used memory
                           1617 M active memory
                            238 M inactive memory
                           5149 M free memory
                              0 M buffer memory
                            356 M swap cache
                            512 M total swap
                              0 M used swap
                            512 M free swap
                  top - 21:13:08 up  4:34,  2 users,  load average: 0.19, 0.27, 0.25
                  Tasks:  27 total,   1 running,  26 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7048.0 total,   5148.3 free,   1543.3 used,    356.6 buff/cache
                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5504.7 avail Mem
                  *** FAILED SERVICES ***
                    UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                  * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                  * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                  2 loaded units listed.
                  *** FILESYSTEM ***
                  Filesystem                       Type      Size  Used Avail Use% Mounted on
                  /dev/mapper/pve-vm--110--disk--0 ext4      9.8G  2.2G  7.2G  24% /
                  none                             tmpfs     492K  4.0K  488K   1% /dev
                  udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                  tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                  tmpfs                            tmpfs     3.2G  108K  3.2G   1% /run
                  tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                  dmesg: read kernel buffer failed: Operation not permitted
                  Show mounted filesystems:
                  TARGET                                                  SOURCE                           FSTYPE     OPTIONS
                  /                                                       /dev/mapper/pve-vm--110--disk--0 ext4       rw,relatime,stripe=16
                  |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3260368k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                  | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                  | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                  | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                  |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                  | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
                  | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
                  | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
                  | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
                  | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
                  | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
                  | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
                  | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
                  | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
                  | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
                  | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
                  | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
                  | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
                  | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                  | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
                  | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
                    |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
                    |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
                    |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
                    `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  /var:
                  435M    /var/
                  248M    /var/cache
                  245M    /var/cache/apt
                  169M    /var/cache/apt/archives
                  146M    /var/lib
                  Archived and active journals take up 8.0M in the file system.
                  /opt/iobroker/backups:
                  1.6M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  85M     /opt/iobroker/iobroker-data/
                  62M     /opt/iobroker/iobroker-data/files
                  31M     /opt/iobroker/iobroker-data/files/backitup.admin
                  31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                  14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                  9.8M    /opt/iobroker/iobroker-data/objects.jsonl
                  7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                  5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                  5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.17.0
                  /usr/bin/node           v20.17.0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.3
                  nodejs:
                    Installed: 20.17.0-1nodesource1
                    Candidate: 20.17.0-1nodesource1
                    Version table:
                   *** 20.17.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u2 500
                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://security.debian.org bookworm-security/main amd64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  admin:          7.1.2
                  javascript:     "javascript" not found
                  nodejs modules from github:     0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : ioB24                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : ioB24                                    -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Upgrade policy: none
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 7.1.2    , installed 7.1.2
                  Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                  Controller "js-controller": 6.0.11   , installed 6.0.11
                  Objects and States
                  Objects:        124
                  States:         88
                  Hit:1 http://security.debian.org bookworm-security InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1055632    974/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1055625    974/iobroker.js-con
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          744091     318/master
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          742063     1/init
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1055693    992/io.admin.0
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          744092     318/master
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          743832     1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          742065     1/init
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          742064     1/init
                  udp6       0      0 :::111                  :::*                                0          742066     1/init
                  2024-09-25 19:30:24.571  - info: backitup.0 (390) Terminated (NO_ERROR): Without reason
                  2024-09-25 19:30:25.059  - info: backitup.0 (390) terminating
                  2024-09-25 19:30:25.101  - info: host.ioB24 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2024-09-25 19:30:25.385  - info: host.ioB24 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                  2024-09-25 19:30:25.386  - info: host.ioB24 All instances are stopped.
                  2024-09-25 19:30:25.567  - info: host.ioB24 terminated
                  2024-09-25 19:39:53.260  - info: host.ioB24 iobroker.js-controller version 6.0.11 js-controller starting
                  2024-09-25 19:39:53.264  - info: host.ioB24 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                  2024-09-25 19:39:53.264  - info: host.ioB24 hostname: ioB24, node: v20.17.0
                  2024-09-25 19:39:53.265  - info: host.ioB24 ip addresses: 192.168.1.152 2a02:810c:1bf:f826:be24:11ff:fe42:4bab fe80::be24:11ff:fe42:4bab
                  2024-09-25 19:39:53.858  - info: host.ioB24 connected to Objects and States
                  2024-09-25 19:39:53.873  - info: host.ioB24 added notifications configuration of host
                  2024-09-25 19:39:54.102  - info: host.ioB24 2 instances found
                  2024-09-25 19:39:54.106  - info: host.ioB24 starting 2 instances
                  2024-09-25 19:39:54.339  - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeCurrent"
                  2024-09-25 19:39:54.356  - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewest"
                  2024-09-25 19:39:54.360  - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewestNext"
                  2024-09-25 19:39:54.363  - info: host.ioB24 Delete state "system.host.ioB24.versions.npmCurrent"
                  2024-09-25 19:39:54.370  - info: host.ioB24 instance system.adapter.admin.0 in version "7.1.2" started with pid 992
                  2024-09-25 19:39:54.374  - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewest"
                  2024-09-25 19:39:54.418  - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewestNext"
                  2024-09-25 19:39:54.420  - info: host.ioB24 Some obsolete host states deleted.
                  2024-09-25 19:39:58.307  - info: host.ioB24 instance system.adapter.backitup.0 in version "3.0.22" started with pid 1033
                  2024-09-25 19:39:59.553  - info: backitup.0 (1033) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                  2024-09-25 19:39:59.587  - info: backitup.0 (1033) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                          v.2024-05-22
                    Virtualization: lxc
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               64 bit
                  User-ID:                1000
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  Recommended versions are nodejs 20.17.0 and npm 10.8.2
                  MEMORY:
                  Mem:            7.4G        1.6G        5.4G        114K        373M        5.7G
                  Swap:           536M          0B        536M
                  ioBroker Core:          js-controller           6.0.11
                                          admin                   7.1.2
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                124
                  States:                 88
                  Size of iob-Database:
                  5.4M    /opt/iobroker/iobroker-data/states.jsonl
                  P crunchipC 2 Antworten Letzte Antwort
                  • M marko67
                    @martinp
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 2
                                     RTC time: n/a
                              RTC in local TZ: no
                    dirk
                    HOME=/home/dirk
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           536M          0B        536M
                             7048 M total memory
                             1541 M used memory
                             5149 M free memory
                                0 M buffer memory
                              356 M swap cache
                              512 M total swap
                                0 M used swap
                              512 M free swap
                    *** FILESYSTEM ***
                    /var:
                    435M    /var/
                    248M    /var/cache
                    245M    /var/cache/apt
                    146M    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          7.1.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        124
                    States:         88
                    Pending Updates: 0
                                            v.2024-05-22
                      Virtualization: lxc
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               64 bit
                    User-ID:                1000
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    MEMORY:
                    Swap:           536M          0B        536M
                                            admin                   7.1.2
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                124
                    States:                 88
                    peterfido
                    #99
                    @marko67
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                     Static hostname: ioTest
                      Virtualization: lxc
                              Kernel: Linux 6.8.12-1-pve
                    model name      : 12th Gen Intel(R) Core(TM) i5-1240P
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                     19:39:29 up  8:04,  3 users,  load average: 1.29, 1.43, 1.57
                    CPU threads: 4
                                   Local time: Wed 2024-09-25 19:39:29 UTC
                               Universal time: Wed 2024-09-25 19:39:29 UTC
                                     RTC time: n/a
                                    Time zone: Etc/UTC (UTC, +0000)
                              RTC in local TZ: no
                    peter
                    HOME=/home/peter
                    GROUPS=peter sudo users iobroker
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            8.5G        797M        5.1G        139K        2.6G        7.7G
                    Swap:             0B          0B          0B
                    Total:          8.5G        797M        5.1G
                    Active iob-Instances:   6
                             8096 M total memory
                              760 M used memory
                              792 M active memory
                             2297 M inactive memory
                             4896 M free memory
                                0 M buffer memory
                             2438 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    top - 19:39:30 up  8:04,  3 users,  load average: 1.51, 1.48, 1.58
                    Tasks:  36 total,   1 running,  35 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   8096.0 total,   4895.1 free,    762.3 used,   2438.6 buff/cache
                    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7333.7 avail Mem
                    1 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/loop0     ext4       20G  3.2G   16G  17% /
                    udev           devtmpfs   32G     0   32G   0% /dev/tty
                    tmpfs          tmpfs      32G     0   32G   0% /dev/shm
                    tmpfs          tmpfs      13G  132K   13G   1% /run
                    tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/1000
                    /                                                       /dev/loop0                     ext4       rw,relatime
                    |-/run                                                  tmpfs                          tmpfs      rw,nosuid,nodev,size=13089324k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                    | |-/run/user/1000                                      tmpfs                          tmpfs      rw,nosuid,nodev,relatime,size=6544660k,nr_inodes=1636165,mode=700,uid=101000,gid=101000,inode64
                    |-/dev                                                  none                           tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64| |-/dev/shm                                            tmpfs                          tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
                    | |-/dev/full                                           udev[/full]                    devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
                    | |-/dev/null                                           udev[/null]                    devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
                    | |-/dev/random                                         udev[/random]                  devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
                    | |-/dev/tty                                            udev[/tty]                     devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
                    | |-/dev/urandom                                        udev[/urandom]                 devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
                    | |-/dev/zero                                           udev[/zero]                    devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
                    /var:
                    419M    /var/
                    248M    /var/cache
                    245M    /var/cache/apt
                    146M    /var/lib
                    4.0K    /opt/iobroker/backups/
                    525M    /opt/iobroker/iobroker-data/
                    503M    /opt/iobroker/iobroker-data/files
                    441M    /opt/iobroker/iobroker-data/files/javascript.admin
                    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                    9.9M    /opt/iobroker/iobroker-data/objects.jsonl
                    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
                    USB-Devices by-id:
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          7.1.2
                    javascript:     8.7.6
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run
                    as: admin
                    + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
                    + system.adapter.discovery.0              : discovery             : ioTest                                   -  enabled
                    + system.adapter.history.0                : history               : ioTest                                   -  enabled
                    + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
                    + instance is alive
                    as: admin
                    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                    Objects and States
                    Objects:        217
                    States:         158
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       203631894  154/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       203631881  154/iobroker.js-con
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          203629897  324/master
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          203631661  1/init
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          203629770  1/init
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          203631663  1/init
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       203656306  526/io.admin.0
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          203629898  324/master
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          203631777  87/dhclient
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          203631662  1/init
                    udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       203677868  385/io.discovery.0
                    udp6       0      0 :::111                  :::*                                0          203631664  1/init
                    2024-09-25 12:44:43.508  - info: admin.0 (526) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
                    2024-09-25 13:16:34.592  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 13:21:12.611  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 13:21:13.292  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 13:26:16.181  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 13:26:16.903  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 13:33:01.954  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 13:42:08.890  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 13:42:12.205  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 14:28:19.717  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 14:30:59.723  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 17:58:14.049  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 18:02:04.070  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 18:02:26.241  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 18:02:37.756  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 18:13:53.085  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 18:13:57.028  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 18:28:33.016  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 18:28:38.116  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 18:43:11.126  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 18:48:25.001  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 19:17:26.663  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 19:17:30.918  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                    2024-09-25 19:28:25.578  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                    2024-09-25 19:29:25.582  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                            v.2024-05-22
                      Virtualization: lxc
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               64 bit
                    Timezone:               Etc/UTC (UTC, +0000)
                    User-ID:                1000
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    MEMORY:
                    Mem:            8.5G        799M        5.1G        139K        2.6G        7.7G
                    Swap:             0B          0B          0B
                    Total:          8.5G        799M        5.1G
                                            admin                   7.1.2
                    Objects type: jsonl
                    States  type: jsonl
                    as: admin
                    Objects:                217
                    States:                 158
                    5.7M    /opt/iobroker/iobroker-data/states.jsonl
                    Peterfido
                    P 1 Antwort Letzte Antwort
                    • P peterfido
                      @marko67
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                        Virtualization: lxc
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                      CPU threads: 4
                                       RTC time: n/a
                                RTC in local TZ: no
                      peter
                      HOME=/home/peter
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:             0B          0B          0B
                               8096 M total memory
                                760 M used memory
                                792 M active memory
                               4896 M free memory
                                  0 M buffer memory
                               2438 M swap cache
                                  0 M total swap
                                  0 M used swap
                                  0 M free swap
                      *** FILESYSTEM ***
                      /var:
                      419M    /var/
                      248M    /var/cache
                      245M    /var/cache/apt
                      146M    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          7.1.2
                      javascript:     8.7.6
                      Adapter State
                      as: admin
                      + instance is alive
                      as: admin
                      Objects and States
                      Objects:        217
                      States:         158
                      Pending Updates: 0
                                              v.2024-05-22
                        Virtualization: lxc
                      Installation:           lxc
                      Kernel:                 x86_64
                      Userland:               64 bit
                      User-ID:                1000
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      MEMORY:
                      Swap:             0B          0B          0B
                                              admin                   7.1.2
                      Objects type: jsonl
                      States  type: jsonl
                      as: admin
                      Objects:                217
                      States:                 158
                      peterfido
                      #100
                      @marko67 Dein Kernel ist aktueller.
                      Den Proxmox-Host aktualisiere ich erst am Wochenende.
                      Peterfido
                      • P peterfido
                        Codierknecht
                        #101
                        @peterfido
                        Hab' auch Kernel 6.8.12-2-pve. Funzt problemlos und dümpelt nach frischer Installation um 320 MB rum.
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                         Static hostname: ioBroker-TEST
                          Virtualization: lxc
                        model name      : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         20:07:57 up  8:11,  2 users,  load average: 0.27, 0.19, 0.18
                        CPU threads: 1
                                       Local time: Wed 2024-09-25 20:07:57 UTC
                                   Universal time: Wed 2024-09-25 20:07:57 UTC
                                         RTC time: n/a
                                  RTC in local TZ: no
                        codierknecht
                        HOME=/home/codierknecht
                        GROUPS=codierknecht sudo users iobroker
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Mem:            2.1G        340M        972M        131K        834M        1.8G
                        Swap:           2.1G        4.1K        2.1G
                        Total:          4.3G        340M        3.1G
                                 2048 M total memory
                                  325 M used memory
                                  471 M active memory
                                  551 M inactive memory
                                  927 M free memory
                                    0 M buffer memory
                                  795 M swap cache
                                 2048 M total swap
                                    0 M used swap
                                 2047 M free swap
                        top - 20:07:57 up  8:11,  2 users,  load average: 0.25, 0.19, 0.18
                        Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                        MiB Mem :   2048.0 total,    925.5 free,    326.9 used,    795.7 buff/cache
                        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1721.1 avail Mem
                        *** FILESYSTEM ***
                        /dev/mapper/pve-vm--300--disk--0 ext4      7.8G  2.2G  5.3G  29% /
                        tmpfs                            tmpfs     3.2G  124K  3.2G   1% /run
                        /                                                       /dev/mapper/pve-vm--300--disk--0 ext4       rw,relatime,stripe=16
                        |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3253060k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                        | `-/run/credentials/systemd-firstboot.service          ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                        | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
                        | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
                        | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
                        | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
                        | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
                        | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
                        /var:
                        419M    /var/
                        249M    /var/cache
                        245M    /var/cache/apt
                        146M    /var/lib
                        79M     /opt/iobroker/iobroker-data/
                        9.6M    /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          7.1.2
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : ioBroker-TEST                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.backitup.0               : backitup              : ioBroker-TEST                            -  enabled
                        + instance is alive
                        Objects and States
                        Objects:        124
                        States:         89
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          29808714   301/master
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29958647   10404/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29958642   10404/iobroker.js-c
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          29957141   1/init
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          29957143   1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          29806168   1/init
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          29808715   301/master
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       29959052   10500/io.admin.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29806275   93/dhclient
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          29957142   1/init
                        udp        0      0 0.0.0.0:161             0.0.0.0:*                           0          30040554   10843/snmpd
                        udp6       0      0 :::111                  :::*                                0          29957144   1/init
                        2024-09-25 12:37:35.644  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 5 states of discovery
                        2024-09-25 12:37:35.646  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 15 states of system.adapter.discovery
                        2024-09-25 12:37:35.647  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 1 states (io.discovery.*) from states
                        2024-09-25 12:37:35.653  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 16 states (system.adapter.discovery.*) from states
                        2024-09-25 12:37:35.856  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 1 objects of discovery
                        2024-09-25 12:37:35.892  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST file discovery.admin deleted
                        2024-09-25 12:37:35.894  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST object discovery deleted
                        2024-09-25 12:37:35.898  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST object discovery.admin deleted
                        2024-09-25 12:37:35.899  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Deleting 25 object(s).
                        2024-09-25 12:37:35.933  - info: host.ioBroker-TEST object deleted system.adapter.discovery.0
                        2024-09-25 12:37:35.935  - info: host.ioBroker-TEST stopInstance system.adapter.discovery.0 (force=false, process=true)
                        2024-09-25 12:37:35.937  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Deleting 17 state(s).
                        2024-09-25 12:37:35.938  - info: discovery.0 (10568) Got terminate signal TERMINATE_YOURSELF
                        2024-09-25 12:37:35.938  - info: discovery.0 (10568) terminating
                        2024-09-25 12:37:35.939  - info: discovery.0 (10568) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-09-25 12:37:35.977  - info: host.ioBroker-TEST stopInstance system.adapter.discovery.0 send kill signal
                        2024-09-25 12:37:36.442  - info: discovery.0 (10568) terminating
                        2024-09-25 12:37:36.514  - info: host.ioBroker-TEST instance system.adapter.discovery.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                        2024-09-25 12:37:36.514  - info: host.ioBroker-TEST Do not restart adapter system.adapter.discovery.0 because desired by instance
                        2024-09-25 12:37:37.304  - info: host.ioBroker-TEST iobroker removed 42 packages in 1s
                        2024-09-25 12:37:37.305  - info: host.ioBroker-TEST iobroker
                        2024-09-25 12:37:37.306  - info: host.ioBroker-TEST iobroker 58 packages are looking for funding
                        2024-09-25 12:37:37.307  - info: host.ioBroker-TEST iobroker   run `npm fund` for details
                        2024-09-25 12:37:38.328  - info: host.ioBroker-TEST iobroker exit 0
                        2024-09-25 12:42:43.671  - info: admin.0 (10500) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
                        • M marko67
                          @martinp
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 2
                                           RTC time: n/a
                                    RTC in local TZ: no
                          dirk
                          HOME=/home/dirk
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Swap:           536M          0B        536M
                                   7048 M total memory
                                   1541 M used memory
                                   5149 M free memory
                                      0 M buffer memory
                                    356 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          *** FILESYSTEM ***
                          /var:
                          435M    /var/
                          248M    /var/cache
                          245M    /var/cache/apt
                          146M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          7.1.2
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        124
                          States:         88
                          Pending Updates: 0
                                                  v.2024-05-22
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               64 bit
                          User-ID:                1000
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          MEMORY:
                          Swap:           536M          0B        536M
                                                  admin                   7.1.2
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                124
                          States:                 88
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #102
                          @marko67 sagte in NUC-Proxmox-steigender Ram:
                          und immer noch das Problem admin?
                          schalt mal auf Experten Modus und zeig die Instanz(Ein/Ausgänge)
                          und schalt den admin mal auf logstufe debug und zeig das log dazu
                          Wie sieht es mit deinem Netzwerk aus? --> Wie ist die Frage gemeint?
                          bin zwar kein Netzwerkspezialist, aber hast du vllt. irgend etwas spezielles eingerichtet (firewall, pihole... oder irgend etwas in der Richtung), sodass sich der admin zu tote läuft?
                          bezogen auf
                          024-09-24 18:40:37.012 - warn: admin.0 (10305) Repository cannot be read: Active repo - stable 2024-09-24 18:40:37.028 - warn: admin.0 (10305) Active repository "stable" cannot be read
                            bezogen auf
                            marko67
                            #103
                            @crunchip said in NUC-Proxmox-steigender Ram:
                            Nein. Wie gesagt jede Einstellung beim erstellen des Containers und von ioB 1:1 aus der bebilderten Anleitung übernommen
                            2024-09-25 23:04:25.191 - debug: admin.0 (3465) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2024-09-25 23:04:25.210 - debug: admin.0 (3465) Objects client ready ... initialize now
                            2024-09-25 23:04:25.212 - debug: admin.0 (3465) Objects create System PubSub Client
                            2024-09-25 23:04:25.213 - debug: admin.0 (3465) Objects create User PubSub Client
                            2024-09-25 23:04:25.225 - debug: admin.0 (3465) Objects client initialize lua scripts
                            2024-09-25 23:04:25.232 - debug: admin.0 (3465) Objects connected to redis: 127.0.0.1:9001
                            2024-09-25 23:04:25.243 - debug: admin.0 (3465) Redis States: Use Redis connection: 127.0.0.1:9000
                            2024-09-25 23:04:25.247 - debug: admin.0 (3465) States create System PubSub Client
                            2024-09-25 23:04:25.248 - debug: admin.0 (3465) States create User PubSub Client
                            2024-09-25 23:04:25.254 - debug: admin.0 (3465) States connected to redis: 127.0.0.1:9000
                            2024-09-25 23:04:25.271 - debug: admin.0 (3465) Plugin sentry Initialize Plugin (enabled=true)
                            2024-09-25 23:04:25.498 - info: admin.0 (3465) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                            2024-09-25 23:04:25.526 - info: admin.0 (3465) requesting all objects
                            2024-09-25 23:04:25.996 - info: admin.0 (3465) received all objects
                            2024-09-25 23:04:26.005 - debug: admin.0 (3465) Secure connection not enabled - using http createServer
                            2024-09-25 23:04:26.235 - debug: admin.0 (3465) Next repo update on 9/28/2024, 7:41:16 PM
                            2024-09-25 23:04:26.257 - info: admin.0 (3465) socket.io server listening on port 8081
                            2024-09-25 23:04:26.259 - info: admin.0 (3465) http server listening on port 8081
                            2024-09-25 23:04:26.259 - info: admin.0 (3465) Use link "http://127.0.0.1:8081" to configure.
                            2024-09-25 23:04:28.999 - info: admin.0 (3465) ==> Connected system.user.admin from ::ffff:192.168.1.35
                            2024-09-25 23:04:29.011 - debug: admin.0 (3465) Subscribes: dummy
                            2024-09-25 23:04:29.013 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*
                            2024-09-25 23:04:29.013 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive
                            2024-09-25 23:04:29.014 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive
                            2024-09-25 23:04:29.014 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive
                            2024-09-25 23:04:29.015 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected
                            2024-09-25 23:04:29.015 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount
                            2024-09-25 23:04:29.016 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss
                            2024-09-25 23:04:29.016 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount
                            2024-09-25 23:04:29.017 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel
                            2024-09-25 23:04:29.017 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled
                            2024-09-25 23:04:29.018 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree
                            2024-09-25 23:04:29.018 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize
                            2024-09-25 23:04:29.019 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning
                            2024-09-25 23:04:29.019 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem
                            2024-09-25 23:04:29.019 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection
                            2024-09-25 23:04:29.020 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension
                            2024-09-25 23:04:29.020 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:04:29.064 - debug: admin.0 (3465) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                            2024-09-25 23:05:25.755 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.755 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.756 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.756 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.756 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.757 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.759 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.760 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.760 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.761 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.761 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, *.info.connection, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.761 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, *.info.extension, admin.0.info.newsFeed
                            2024-09-25 23:05:25.762 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed
                            crunchipC CodierknechtC 2 Antworten Letzte Antwort
                            • M marko67
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #104
                              Diese ganzen Meldungen dürften doch eigentlich gar nicht mehr auftauchen?
                              • M marko67
                                Codierknecht
                                #105
                                @marko67
                                Seit wann ist denn von "Redis" die Rede?
                                M crunchipC 2 Antworten Letzte Antwort
                                  marko67
                                  #106
                                  @crunchip
                                  Nein. Haben den Adapter gelöscht. 1x über ioB Adapter und dann mal über die Konsole. Meldung taucht immer wieder auf??
                                  • CodierknechtC Codierknecht
                                    @marko67
                                    marko67
                                    #107
                                    @codierknecht
                                    Was meinst Du damit??
                                      @marko67
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #108
                                      @codierknecht siehe Port 9000/9001, das ist die iobroker interne Redis Datenbank
                                      https://www.iobroker.net/#de/documentation/config/redis.md
                                      P CodierknechtC 2 Antworten Letzte Antwort
                                        peterfido
                                        schrieb am zuletzt editiert von peterfido
                                        #109
                                        @marko67
                                        DIE bebilderte Anleitung habe ich nicht gefunden.
                                        Unter Proxmox nutze ich VMs.
                                        Einen CT habe ich jetzt mal für diesen Test hier erstellt.
                                        Dazu erstmal im Proxmox Host die aktuelle Debian 12 Vorlage heruntergeladen.
                                        Dann auf erstelle CT klicken, das Template auswählen, 20GB Disk, 4 CPU Kerne in einem Sockel, 8 GB RAM, bei Netzwerk evtl. noch das VLAN setzen, DHCP an, starten.
                                        Dann als root sudo installieren.
                                        apt update
                                        apt install sudo
                                        apt install curl
                                        adduser benutzername
                                        usermod benutzername -aG sudo
                                        exit
                                        Dann als benutzername einloggen
                                        sudo apt update
                                        sudo apt install qemu-guest-agent
                                        curl -sLf https://iobroker.net/install.sh | bash -
                                        Das ist das Grundsystem, welches bei mir seit gestern testet.
                                        Unter Objekte werden noch System freies RAM, RAM-Prozent und der Speicher vom admin in die History geloggt.
                                        Peterfido
                                          Codierknecht
                                          #110
                                          @crunchip sagte in NUC-Proxmox-steigender Ram:
                                          Da muss dann aber jemand auf Redis umgestellt haben.
                                          In meinem Test-LXC taucht jedenfalls im Log kein "Redis" auf.
