  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.9k Aufrufe 40 Beobachtet
  • T TT-Tom
    @tt-tom
    @Thomas-Braun
    nochmal mit iobroker Installation. User tom wurde angelegt und die Timezone wurde geändert.
    root@testsystem:~# ./iob_diag.sh
    You should not be root on your system!
    Better use your standard user!
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    ```bash
    Script v.2024-09-07
    *** BASE SYSTEM ***
     Static hostname: testsystem
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-1-pve
        Architecture: x86-64
    Package configuration
                      ┌───────────────────────┤ Configuring tzdata ├───────────────────────┐
                      │ Please select the city or region corresponding to your time zone.  │
                      │ Time zone:                                                         │
                      │                           Amsterdam       -                        │
                      │                           Andorra         ▒                        │
                      │                           Astrakhan       0                        │
                      │                           Athens          ▒                        │
                      │                           Belfast         ▒                        │
                      │                           Belgrade        ▒                        │
                      │                           Berlin          ▒                        │
                      │                           Bratislava      ▒                        │
                      │                           Brussels        ▒                        │
                      │                           Bucharest       ▒                        │
                      │                           Budapest        ▒                        │
                      │                           Busingen        .                        │
                      │                 <Ok>                     <Cancel>                  │
    Current default time zone: 'Europe/Berlin'
    Local time is now:      Sun Sep  8 20:07:44 CEST 2024.
    Universal Time is now:  Sun Sep  8 18:07:44 UTC 2024.
    Setting up time synchronization with systemd-timesyncd
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Enter the username for a new user (Not 'root' and not 'iobroker'!): tom
    Enter the password for the new user:
    Confirm the password for the new user:
    Adding new user account...
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            2.1G        284M        1.6G        118K        229M        1.9G
    Swap:           1.1G          0B        1.1G
    Total:          3.2G        284M        2.7G
    Active iob-Instances:   4
             2048 M total memory
              271 M used memory
              399 M active memory
               66 M inactive memory
             1557 M free memory
                0 M buffer memory
              219 M swap cache
             1024 M total swap
                0 M used swap
             1024 M free swap
    top - 20:08:01 up 5 min,  1 user,  load average: 0.04, 0.17, 0.16
    Tasks:  25 total,   1 running,  24 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   2048.0 total,   1555.1 free,    273.6 used,    219.4 buff/cache
    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   1774.4 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--106--disk--0 ext4      7.8G  2.1G  5.3G  29% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--106--disk--0 ext4   rw,relatime,stripe=16
    /var:
    400M    /var/
    237M    /var/cache
    234M    /var/cache/apt
    158M    /var/cache/apt/archives
    146M    /var/lib
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    62M     /opt/iobroker/iobroker-data/
    57M     /opt/iobroker/iobroker-data/files
    31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    8.4M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.70cad8ba.js
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
    5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
    5.0M    /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.17.0
    /usr/bin/node           v20.17.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.17.0-1nodesource1
      Candidate: 20.17.0-1nodesource1
      Version table:
     *** 20.17.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    testsystem          testsystem (version: 6.0.11, hostname: testsystem    , alive, uptime: 316)
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.0.23
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : testsystem                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : testsystem                               -  enabled
    + system.adapter.discovery.0              : discovery             : testsystem                               -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "backitup"     : 3.0.19   , installed 3.0.19
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Objects and States
    Objects:        148
    States:         103
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       80745598   155/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       80745603   155/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          80743343   319/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          80742867   1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       80751205   436/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          80743344   319/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          80742219   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          80742869   1/init
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          80742305   95/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          80742868   1/init
    udp6       0      0 :::111                  :::*                                0          80742870   1/init
    2024-09-08 18:02:43.093  - info: backitup.0 (371) starting. Version 3.0.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 18:02:43.111  - info: backitup.0 (371) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-09-08 18:02:46.482  - info: host.testsystem instance system.adapter.discovery.0 in version "4.5.0" started with pid 386
    2024-09-08 18:02:47.002  - info: discovery.0 (386) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 18:03:34.073  - info: admin.0 (330) ==> Connected system.user.admin from ::ffff:192.168.178.12
    2024-09-08 18:04:30.739  - info: host.testsystem stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-09-08 18:04:30.741  - info: admin.0 (330) Got terminate signal TERMINATE_YOURSELF
    2024-09-08 18:04:30.741  - info: admin.0 (330) terminating http server on port 8081
    2024-09-08 18:04:30.743  - info: admin.0 (330) terminating
    2024-09-08 18:04:30.743  - info: admin.0 (330) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-09-08 18:04:30.781  - info: host.testsystem stopInstance system.adapter.admin.0 send kill signal
    2024-09-08 18:04:31.244  - info: admin.0 (330) terminating
    2024-09-08 18:04:31.281  - info: host.testsystem instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-09-08 18:04:34.403  - info: host.testsystem instance system.adapter.admin.0 in version "7.0.23" started with pid 436
    2024-09-08 18:04:35.068  - info: admin.0 (436) starting. Version 7.0.23 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 18:04:35.079  - info: admin.0 (436) requesting all objects
    2024-09-08 18:04:35.285  - info: admin.0 (436) received all objects
    2024-09-08 18:04:35.382  - info: admin.0 (436) socket.io server listening on port 8081
    2024-09-08 18:04:35.383  - info: admin.0 (436) http server listening on port 8081
    2024-09-08 18:04:35.383  - info: admin.0 (436) Use link "http://127.0.0.1:8081" to configure.
    2024-09-08 18:04:37.576  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
    2024-09-08 18:04:37.615  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
    2024-09-08 18:04:37.645  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
    2024-09-08 18:04:45.342  - info: admin.0 (436) ==> Connected system.user.admin from ::ffff:192.168.178.12
    2024-09-08 18:04:57.657  - info: admin.0 (436) <== Disconnect system.user.admin from ::ffff:192.168.178.12 admin
    iob diag has finished.
    #659
    @tt-tom sagte in iob diag - Skript:
    Also mit vorheriger Installation des ioBroker funktioniert es?
      TT-Tom
      #660
      ja mit iobroker ist alles sauber durchgelaufen.
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      • T TT-Tom
        #661
        Na dann....
        Das Skript kommt ja im Normalfall auch erst mit dem ioBroker auf das System.
          @tt-tom
          Den
          chpasswd: (user tom) pam_chauthtok() failed, error:
          kann ich mir gerade nicht so wirklich erklären. Zumal es bei @Meister-Mopper alles wie gedacht funktioniert...
          TT-Tom
          #662
          Den
          der User konnte ja nicht der Gruppe iobroker zugeordnet werden.
          Gruß Tom
          Public Transport
          • T TT-Tom
            Den
            #663
            Das sollte aber nicht der Grund für die Meldung sein.
            Wie dem auch sei, das Skript ruft man ja in der Realität nur bei vorhandener Installation des ioBrokers auf.
              Knirpso
              schrieb am zuletzt editiert von Knirpso
              #664
              Anbei noch der gewünschte Log aus https://forum.iobroker.net/topic/76922/schaltverhalten-iot-adapter-mit-alexa/4
              Script v.2024-09-16
              *** BASE SYSTEM ***
              Hardware Vendor : Synology Inc.
              Kernel          : x86_64
              Userland        : 64 bit
              Docker          : v9.1.2
              Virtualization  : Docker
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
              CPU threads: 8
              *** LIFE CYCLE STATUS ***
              Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
              *** TIME AND TIMEZONES ***
              Tue Sep 17 15:25:15 UTC 2024
              Tue Sep 17 17:25:15 CEST 2024
              CEST +0200
              Etc/UTC
              root
              HOME=/root
              GROUPS=root
              iobroker
              HOME=/opt/iobroker
              Display-Server: true
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:             67G        7.4G        1.0G        215M         59G         59G
              Swap:            42G        307M         42G
              Total:          109G        7.7G         43G
              Active iob-Instances:   17
                      64084 M total memory
                       7067 M used memory
                       7965 M active memory
                      52969 M inactive memory
                        971 M free memory
                         84 M buffer memory
                      56764 M swap cache
                      40499 M total swap
                        293 M used swap
                      40206 M free swap
              top - 17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
              Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
              MiB Mem :  64084.8 total,    969.7 free,   7068.6 used,  56848.9 buff/cache
              MiB Swap:  40499.9 total,  40206.6 free,    293.3 used.  57016.2 avail Mem
              *** FILESYSTEM ***
              /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /
              tmpfs          tmpfs   64M     0   64M   0% /dev
              tmpfs          tmpfs   32G     0   32G   0% /sys/fs/cgroup
              shm            tmpfs   64M     0   64M   0% /dev/shm
              /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /opt/iobroker
              /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /etc/hosts
              tmpfs          tmpfs   32G     0   32G   0% /proc/acpi
              tmpfs          tmpfs   32G     0   32G   0% /proc/scsi
              tmpfs          tmpfs   32G     0   32G   0% /sys/firmware
              /                  /dev/synorbd_1[/@syno/@docker/btrfs/subvolumes/43c485044ed9f1e230e9f082f08e839ece82e19c0db5e0e02d5f344f954dfa66]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
              |-/opt/iobroker    /dev/synorbd_1[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
              |-/etc/resolv.conf /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
              |-/etc/hostname    /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
              `-/etc/hosts       /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
              /var:
              34M     /var/
              32M     /var/lib
              19M     /var/lib/apt/lists
              19M     /var/lib/apt
              13M     /var/lib/dpkg
              33M     /opt/iobroker/backups/
              1.1G    /opt/iobroker/iobroker-data/
              756M    /opt/iobroker/iobroker-data/files
              441M    /opt/iobroker/iobroker-data/files/javascript.admin
              409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              117M    /opt/iobroker/iobroker-data/states.jsonl
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
              19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
              USB-Devices by-id:
              HINT:
              Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
              /dev/ttyACM0
              HINT:
              Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
              /dev/ttyACM0
              /usr/bin/nodejs         v18.20.4
              /usr/bin/node           v18.20.4
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.28.0
              nodejs:
                Installed: 18.20.4-1nodesource1
                Candidate: 18.20.4-1nodesource1
                Version table:
               *** 18.20.4-1nodesource1 1001
                     1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                   18.20.3-1nodesource1 1001
                   18.20.2-1nodesource1 1001
                   18.20.1-1nodesource1 1001
                   18.20.0-1nodesource1 1001
                   18.19.1-1nodesource1 1001
                      500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                   18.19.0-1nodesource1 1001
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1308286)
              slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 268408)
              admin:          7.0.23
              javascript:     8.7.6
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
              + system.adapter.history.0                : history               : iobroker                                 -  enabled
              + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.mystrom.0                : mystrom               : iobroker                                 -  enabled
              + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
              + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
                system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
              + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
              + system.adapter.zigbee.1                 : zigbee                : slave1-raspberrypi                       -  enabled, port: /dev/ttyACM0
              + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
              + instance is alive
              │ (index) │   name   │                           url                           │ auto upgrade │
              │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
              │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 3.0.22   , installed 3.0.22
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
              Adapter    "roborock"     : 0.6.4    , installed 0.6.4
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
              Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
              Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
              Adapter    "web"          : 6.2.5    , installed 6.2.5
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Objects and States
              Objects:        3786
              States:         2647
              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Pending Updates: 26
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3946312486 -
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3946312479 -
              tcp        0      0 127.0.0.11:42340        0.0.0.0:*               LISTEN      0          3946306647 -
              tcp6       0      0 :::6824                 :::*                    LISTEN      1000       78218444   -
              tcp6       0      0 :::8554                 :::*                    LISTEN      1000       78220248   -
              tcp6       0      0 :::8555                 :::*                    LISTEN      1000       78220249   -
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3946310901 -
              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3946317922 -
              tcp6       0      0 :::8083                 :::*                    LISTEN      1000       3946324298 -
              tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3946324745 -
              tcp6       0      0 :::1984                 :::*                    LISTEN      1000       78243001   -
              tcp6       0      0 :::7906                 :::*                    LISTEN      1000       78218445   -
              udp        0      0 127.0.0.11:56032        0.0.0.0:*                           0          3946306646 -
              udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1000       38730773   -
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       3946311323 -
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       3946311324 -
              2024-09-17 17:01:23.903  - error: mystrom.0 (386) 200
              2024-09-17 17:01:23.903  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
              2024-09-17 17:01:23.903  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
              2024-09-17 17:01:23.904  - info: mystrom.0 (386) Set update interval for FCF5C418FF54 to 60
              2024-09-17 17:01:23.920  - info: mystrom.0 (386) Set update interval for FCF5C418FB0C to 60
              2024-09-17 17:01:23.922  - error: mystrom.0 (386) 200
              2024-09-17 17:01:23.922  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
              2024-09-17 17:01:23.922  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
              2024-09-17 17:01:23.923  - error: mystrom.0 (386) 200
              2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
              2024-09-17 17:01:23.924  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
              2024-09-17 17:01:23.924  - error: mystrom.0 (386) 200
              2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
              2024-09-17 17:01:23.930  - error: mystrom.0 (386) 200
              2024-09-17 17:01:23.930  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
              2024-09-17 17:01:23.930  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
              2024-09-17 17:01:23.936  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
              2024-09-17 17:01:23.937  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
              2024-09-17 17:01:23.941  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
              2024-09-17 17:01:23.942  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
              2024-09-17 17:01:23.962  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
              2024-09-17 17:01:23.966  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
              2024-09-17 17:03:36.237  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
              Edit: Log von Skriptversion 2024-09-16 angehängt.
              • K Knirpso
                Script v.2024-09-16
                *** BASE SYSTEM ***
                Kernel          : x86_64
                Userland        : 64 bit
                Docker          : v9.1.2
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 8
                CEST +0200
                Etc/UTC
                root
                HOME=/root
                GROUPS=root
                iobroker
                HOME=/opt/iobroker
                Desktop:
                Terminal:
                *** MEMORY ***
                Swap:            42G        307M         42G
                         7067 M used memory
                          971 M free memory
                           84 M buffer memory
                        56764 M swap cache
                        40499 M total swap
                          293 M used swap
                        40206 M free swap
                *** FILESYSTEM ***
                /var:
                34M     /var/
                32M     /var/lib
                19M     /var/lib/apt
                13M     /var/lib/dpkg
                USB-Devices by-id:
                HINT:
                /dev/ttyACM0
                HINT:
                /dev/ttyACM0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.0.23
                javascript:     8.7.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        3786
                States:         2647
                Pending Updates: 26
                #665
                @knirpso Bitte die aktuelle Version 2024-09-16 verwenden.
                • K Knirpso
                  Script v.2024-09-16
                  *** BASE SYSTEM ***
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Docker          : v9.1.2
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 8
                  CEST +0200
                  Etc/UTC
                  root
                  HOME=/root
                  GROUPS=root
                  iobroker
                  HOME=/opt/iobroker
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:            42G        307M         42G
                           7067 M used memory
                            971 M free memory
                             84 M buffer memory
                          56764 M swap cache
                          40499 M total swap
                            293 M used swap
                          40206 M free swap
                  *** FILESYSTEM ***
                  /var:
                  34M     /var/
                  32M     /var/lib
                  19M     /var/lib/apt
                  13M     /var/lib/dpkg
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyACM0
                  HINT:
                  /dev/ttyACM0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.0.23
                  javascript:     8.7.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        3786
                  States:         2647
                  Pending Updates: 26
                  #666
                  @knirpso
                  Hm. Kannst du mal die Ausgabe von
                  pgrep -l '[X]|[w]ayland|X11|wayfire'
                  posten?
                  Oder auch die anderen Dockeristen.
                    @knirpso
                    posten?
                    Knirpso
                    #667
                    root@iobroker:/opt/iobroker# pgrep -l '[X]|[w]ayland|X11|wayfire'
                    pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                    Try `pgrep -f' option to match against the complete command line.
                    • K Knirpso
                      #668
                      @knirpso sagte in iob diag - Skript:
                      pgrep -lf '[X]|[w]ayland|X11|wayfire'
                        Knirpso
                        #669
                        root@iobroker:/opt/iobroker# pgrep -lf '[X]|[w]ayland|X11|wayfire'
                        1966 go2rtc_linux_am
                        root@pihole:/# pgrep -lf '[X]|[w]ayland|X11|wayfire'
                        root@pihole:/#
                        Mehr hab ich nicht
                        • K Knirpso
                          root@pihole:/#
                          Mehr hab ich nicht
                          #670
                          @knirpso
                          Danke, Grund für den 'flase positive' gefunden.
                          • K Knirpso
                            root@pihole:/#
                            Mehr hab ich nicht
                            #671
                            @knirpso
                            Zieh bitte die aktuelle Version nochmal.
                              @knirpso
                              Knirpso
                              #672
                              Script v.2024-09-17
                              *** BASE SYSTEM ***
                              Kernel          : x86_64
                              Userland        : 64 bit
                              Docker          : v9.1.2
                              Kernel          : x86_64
                              Userland        : 64 bit
                               18:05:31 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
                              CPU threads: 8
                              Wed Sep 18 16:05:31 UTC 2024
                              Wed Sep 18 18:05:31 CEST 2024
                              CEST +0200
                              Etc/UTC
                              root
                              HOME=/root
                              GROUPS=root
                              iobroker
                              HOME=/opt/iobroker
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                              Mem:             67G        7.5G        849M        216M         59G         59G
                              Swap:            42G        305M         42G
                              Total:          109G        7.8G         43G
                              Active iob-Instances:   16
                                       7174 M used memory
                                       8048 M active memory
                                      53007 M inactive memory
                                        810 M free memory
                                         84 M buffer memory
                                      56817 M swap cache
                                      40499 M total swap
                                        290 M used swap
                                      40209 M free swap
                              top - 18:05:32 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
                              Tasks:  34 total,   2 running,  32 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :  64084.8 total,    809.2 free,   7175.6 used,  56902.5 buff/cache
                              MiB Swap:  40499.9 total,  40209.0 free,    290.9 used.  56909.1 avail Mem
                              *** FILESYSTEM ***
                              /var:
                              34M     /var/
                              32M     /var/lib
                              19M     /var/lib/apt
                              13M     /var/lib/dpkg
                              40M     /opt/iobroker/backups/
                              1017M   /opt/iobroker/iobroker-data/
                              20M     /opt/iobroker/iobroker-data/states.jsonl
                              USB-Devices by-id:
                              HINT:
                              /dev/ttyACM0
                              HINT:
                              /dev/ttyACM0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1397104)
                              slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 357226)
                              admin:          7.0.23
                              javascript:     8.7.6
                              Adapter State
                                system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                              + instance is alive
                              Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
                              Objects and States
                              Objects:        3786
                              States:         2638
                              Pending Updates: 28
                              2024-09-18 18:01:23.039  - error: mystrom.0 (386) 200
                              2024-09-18 18:01:23.039  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
                              2024-09-18 18:01:23.039  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                              2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
                              2024-09-18 18:01:23.040  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                              2024-09-18 18:01:23.040  - error: mystrom.0 (386) 200
                              2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
                              2024-09-18 18:01:23.046  - error: mystrom.0 (386) 200
                              2024-09-18 18:01:23.046  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
                              2024-09-18 18:01:23.046  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                              2024-09-18 18:01:23.048  - error: mystrom.0 (386) 200
                              2024-09-18 18:01:23.048  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
                              2024-09-18 18:01:23.048  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                              2024-09-18 18:01:23.051  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                              2024-09-18 18:01:23.052  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                              2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
                              2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
                              2024-09-18 18:01:23.062  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                              2024-09-18 18:01:23.068  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                              2024-09-18 18:01:23.075  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                              2024-09-18 18:05:46.619  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                              2024-09-18 18:05:49.032  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                              2024-09-18 18:05:49.037  - info: admin.0 (157) <== Disconnect system.user.admin from ::ffff:192.168.212.23 iot
                              • S Abwesend
                                S Abwesend
                                Shadowhunter23
                                schrieb am zuletzt editiert von Shadowhunter23
                                #673
                                Script v.2024-09-17
                                *** BASE SYSTEM ***
                                 Static hostname: iobroker
                                  Virtualization: lxc
                                OS is similar to:
                                model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                                Docker          : false
                                Virtualization  : lxc
                                Kernel          : x86_64
                                Userland        : 64 bit
                                 18:19:46 up 4 days,  6:33,  1 user,  load average: 0.12, 0.12, 0.10
                                CPU threads: 4
                                Operating System is the current Debian stable version codenamed 'bookworm'!
                                               Local time: Wed 2024-09-18 18:19:46 CEST
                                           Universal time: Wed 2024-09-18 16:19:46 UTC
                                                 RTC time: n/a
                                              NTP service: n/a
                                          RTC in local TZ: no
                                tobias
                                HOME=/home/tobias
                                GROUPS=tobias sudo users iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev redis
                                Desktop:
                                Terminal:       tty
                                System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Do you want to switch to 'multi-user.target'? (y/n)
                                @Thomas-Braun
                                Kannst du mir diese Frage erklären? Was ändert sich wenn ich mit y weiter mache?
                                edit
                                Ist ein LXC unter Proxmox.
                                Noch ein edit
                                Google hilft:
                                multi-user.target -> The multiuser target in Linux is a Command Line Interface and it's like a mode where multiple people can use the computer at the same time. It's perfect for situations where several users need to log in and do their own stuff on the computer simultaneously. So, when your system is in the multiuser target, it's ready for several users to work on it together.
                                graphical.target -> The multiuser target in Linux is a Graphical User Interface and it's like a mode where multiple people can use the computer at the same time. It's perfect for situations where several users need to log in and do their own stuff on the computer simultaneously. So, when your system is in the multiuser target, it's ready for several users to work on it together.
                                Steht das jetzt nicht im Gegensatz zu Display-Server: false?
                                Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                                ioBroker Backup Analyzer
                                • S Shadowhunter23
                                  Script v.2024-09-17
                                  *** BASE SYSTEM ***
                                    Virtualization: lxc
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                  CPU threads: 4
                                                   RTC time: n/a
                                                NTP service: n/a
                                            RTC in local TZ: no
                                  tobias
                                  HOME=/home/tobias
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  @Thomas-Braun
                                  edit
                                  Noch ein edit
                                  Google hilft:
                                  #674
                                  @shadowhunter23 sagte in iob diag - Skript:
                                  Nein, das boot.target ist unabhängig davon ob da wirklich ein Display-Server installiert ist und gestartet werden kann.
                                  Das boot.target auf einem Server sollte aber dennoch multi-user sein. Deswegen der Vorschlag das so einzurichten.
                                  S Thomas BraunT 2 Antworten Letzte Antwort
                                    S Abwesend
                                    S Abwesend
                                    Shadowhunter23
                                    #675
                                    Danke, hab's umgestellt und muss das aufnehmen in meine Neuinstallation Routine.
                                      #676
                                      An die Tester:
                                      Es darf wieder getestet werden!
                                      Bitte mal die TEST-Version (siehe erster Eintrag) unter die Äuglein nehmen.
                                      (Nicht von der Benennung als raspbian irritieren lassen, das sollte auf allen Systemen laufen).
                                      • Neue Sektion *** ZigBee Settings ***
                                        Wenn eine Instanz des zigbee-Adapters gefunden wird erscheint diese neue Sektion:
                                      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      • Neue Option --unmask beim Aufruf des Skripts lüftet dann die Maske und die entsprechenden Werte erscheinen im Klartext und können dann in den Einstellungen des zigbee-Adapters eingetragen werden.
                                      Bitte mal schauen ob das alles wie gedacht funktioniert, insbesondere Installationen mit mehr als einer Instanz oder per tcp angebunden wären interressant zu sehen.
                                      Danke schön!
                                      L 1 Antwort Letzte Antwort
                                      • NashraN Offline
                                        NashraN Offline
                                        Nashra
                                        Most Active Forum Testing
                                        schrieb am zuletzt editiert von Nashra
                                        #677
                                        @Thomas-Braun
                                        Proxmox lxc
                                        ```bash
                                        Script v.2024-12-08 Raspbian+zigbee diag+masking
                                        *** BASE SYSTEM ***
                                         Static hostname: ioBroker
                                          Virtualization: lxc
                                                  Kernel: Linux 6.8.12-4-pve
                                        OS is similar to:
                                        model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         09:19:11 up 16 days, 22:59,  1 user,  load average: 1.12, 1.17, 1.11
                                        CPU threads: 4
                                        Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
                                                       Local time: Mon 2024-12-09 09:19:11 CET
                                                   Universal time: Mon 2024-12-09 08:19:11 UTC
                                                         RTC time: n/a
                                                      NTP service: inactive
                                                  RTC in local TZ: no
                                        jack
                                        HOME=/home/jack
                                        GROUPS=jack sudo iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:
                                        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                        *** MEMORY ***
                                        Mem:             12G        4.9G        6.8G        131K        1.1G        8.0G
                                        Swap:             0B          0B          0B
                                        Total:           12G        4.9G        6.8G
                                        Active iob-Instances:   47
                                                12288 M total memory
                                                 4686 M used memory
                                                 3030 M active memory
                                                 2479 M inactive memory
                                                 6506 M free memory
                                                    0 M buffer memory
                                                 1094 M swap cache
                                                    0 M total swap
                                                    0 M used swap
                                                    0 M free swap
                                        top - 09:19:11 up 16 days, 22:59,  1 user,  load average: 1.12, 1.17, 1.11
                                        Tasks:  75 total,   1 running,  74 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 50.0 us, 50.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :  12288.0 total,   6505.2 free,   4688.0 used,   1094.9 buff/cache
                                        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7600.0 avail Mem
                                        * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                                        3 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/mapper/pve-vm--100--disk--0 ext4       20G   15G  3.7G  81% /
                                        udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                                        tmpfs                            tmpfs     3.2G  120K  3.2G   1% /run
                                        /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                                        /var:
                                        2.6G    /var/
                                        2.1G    /var/log
                                        2.0G    /var/log/journal/5cd6ef18c5fb4a33b292b16e63f26ce7
                                        351M    /var/cache
                                        Archived and active journals take up 95.6M in the file system.
                                        1.3G    /opt/iobroker/backups/
                                        2.6G    /opt/iobroker/iobroker-data/
                                        1.7G    /opt/iobroker/iobroker-data/files
                                        617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        135M    /opt/iobroker/iobroker-data/states.jsonl
                                        63M     /opt/iobroker/iobroker-data/objects.jsonl
                                        33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
                                        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
                                        HINT:
                                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        /dev/ttyUSB0
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/nodejs         v20.18.1
                                        /usr/bin/node           v20.18.1
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.29.4
                                        nodejs:
                                          Installed: 20.18.1-1nodesource1
                                          Candidate: 20.18.1-1nodesource1
                                          Version table:
                                         *** 20.18.1-1nodesource1 600
                                             20.18.0-1nodesource1 600
                                             20.17.0-1nodesource1 600
                                             20.16.0-1nodesource1 600
                                             20.15.1-1nodesource1 600
                                             20.15.0-1nodesource1 600
                                             20.14.0-1nodesource1 600
                                             20.13.1-1nodesource1 600
                                             20.13.0-1nodesource1 600
                                             20.12.2-1nodesource1 600
                                             20.12.1-1nodesource1 600
                                             20.12.0-1nodesource1 600
                                             20.11.1-1nodesource1 600
                                             20.11.0-1nodesource1 600
                                             20.10.0-1nodesource1 600
                                             20.9.0-1nodesource1 600
                                             20.8.1-1nodesource1 600
                                             20.8.0-1nodesource1 600
                                             20.7.0-1nodesource1 600
                                             20.6.1-1nodesource1 600
                                             20.6.0-1nodesource1 600
                                             20.5.1-1nodesource1 600
                                             20.5.0-1nodesource1 600
                                             20.4.0-1nodesource1 600
                                             20.3.1-1nodesource1 600
                                             20.3.0-1nodesource1 600
                                             20.2.0-1nodesource1 600
                                             20.1.0-1nodesource1 600
                                             20.0.0-1nodesource1 600
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 954147)
                                        js-controller:  7.0.3
                                        admin:          7.1.5
                                        javascript:     8.8.3
                                        nodejs modules from github:     6
                                        +-- iobroker.energiefluss-erweitert@0.5.1-alpha.11 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#ac743deb1d81e364ec7f0a9edd2f9da21329f5b6)
                                        +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
                                        +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
                                        | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                        +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                                        Adapter State
                                          system.adapter.accuweather.0            : accuweather           : ioBroker                                 - disabled
                                        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                                          system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
                                        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                                          system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                                          system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
                                          system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                                          system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
                                        + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
                                          system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                                        + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                                        + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
                                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                                          system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                                          system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                                        + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                                          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                                          system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                                          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                                          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
                                          system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                                          system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
                                        + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                        + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                        + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                                        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                                          system.adapter.labcom.0                 : labcom                : ioBroker                                 -  enabled
                                        + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
                                        + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
                                        + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                                        + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                                          system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 - disabled
                                          system.adapter.meteoalarm.1             : meteoalarm            : ioBroker                                 - disabled
                                          system.adapter.meteoalarm.2             : meteoalarm            : ioBroker                                 - disabled
                                          system.adapter.meteoalarm.3             : meteoalarm            : ioBroker                                 - disabled
                                        + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                                        + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
                                        + system.adapter.nut.2                    : nut                   : ioBroker                                 -  enabled
                                          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                                        + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
                                          system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 - disabled
                                          system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
                                        + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                                        + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                                        + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
                                        + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                                        + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
                                        + system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 -  enabled
                                        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                        + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
                                          system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                        + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
                                        + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
                                        + system.adapter.synology.2               : synology              : ioBroker                                 -  enabled, port: 5000
                                        + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                                        + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                                        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                                        + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                                        + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                                        + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
                                          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
                                          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
                                          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
                                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
                                        + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                                          system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 - disabled
                                          system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                                          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                                          system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                                          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                                          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                                        + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
                                          system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
                                          system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
                                        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
                                        + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                          system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
                                        + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
                                        + instance is alive
                                        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                                        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                        │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                                        │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                                        Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                                        Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                                        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                        Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
                                        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                                        Adapter    "deyeidc"      : 0.1.1    , installed 0.1.1
                                        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                        Adapter    "email"        : 1.3.1    , installed 1.3.1
                                        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.11
                                        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                        Adapter    "ical"         : 1.16.1   , installed 1.16.1
                                        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                        Controller "js-controller": 7.0.3    , installed 7.0.3
                                        Adapter    "lgtv"         : 2.2.0    , installed 2.3.0
                                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                                        Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
                                        Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                        Adapter    "pegelalarm"   : 1.3.5    , installed 1.3.5
                                        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                                        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                                        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                                        Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                                        Adapter    "rssfeed"      : 3.1.0    , installed 3.1.0
                                        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                        Adapter    "snmp"         : 3.2.0    , installed 3.2.0
                                        Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                                        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                                        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                                        Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                                        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
                                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                        Adapter    "weather-warnings": 0.6.11, installed 0.6.11
                                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                        Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                        Objects and States
                                        Objects:        55071
                                        States:         51750
                                        Hit:2 http://security.debian.org bookworm-security InRelease
                                        Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                                        Pending Updates: 0
                                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          28017      1140/master
                                        tcp        0      0 192.168.1.14:8082       0.0.0.0:*               LISTEN      1001       60490678   4018371/io.web.0
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17497      1/init
                                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       60462657   4015570/iobroker.js
                                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       60460940   4015570/iobroker.js
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       60475909   4017307/io.shelly.1
                                        tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       171017909  3079198/nc
                                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          28018      1140/master
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       60487396   4018286/io.simple-a
                                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       60493088   4018385/io.ws.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60462774   4015859/io.admin.0
                                        tcp6       0      0 :::8093                 :::*                    LISTEN      1001       60487711   4017938/io.rest-api
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          17499      1/init
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          16838      1/init
                                        udp        0      0 0.0.0.0:50381           0.0.0.0:*                           1001       60470790   4016716/io.snmp.0
                                        udp        0      0 0.0.0.0:58778           0.0.0.0:*                           1001       60491897   4018341/io.upnp.0
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       60494417   4018341/io.upnp.0
                                        udp        0      0 0.0.0.0:46235           0.0.0.0:*                           1001       60470190   4016716/io.snmp.0
                                        udp        0      0 192.168.1.14:5353       0.0.0.0:*                           1001       60474435   4016795/io.tr-064.0
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       60468082   4016698/io.shelly.0
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       60474506   4016825/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       60474507   4016825/io.tuya.0
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16795      90/dhclient
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17498      1/init
                                        udp6       0      0 :::111                  :::*                                0          17500      1/init
                                        2024-12-09 09:13:00.018  - info: host.ioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3075148
                                        2024-12-09 09:13:01.656  - info: javascript.0 (4016006) script.js.Kalender.ICal-farben-Kalender: <table style='font-size:0.9em;'><tbody><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>15.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Dritter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>22.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Vierter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heiligabend (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Jack</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>25.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Erster Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>26.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Zweiter Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>31.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Silvester (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>01.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Neujahrstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>01.01.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Hühner</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>05.01.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Michael</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>06.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heilige Drei Könige (regionaler Feiertag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#0080c0'>01.02.</td><td style='font-size:1.1em; padding-left:5px;color:#0080c0'>Jubiläum 2002</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>14.02.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Valentinstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>14.02.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Anouk</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>17.02.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Manny & Sunny</td></tr></body></table>
                                        2024-12-09 09:13:07.181  - info: host.ioBroker instance system.adapter.ical.0 having pid 3075148 terminated with code 0 (NO_ERROR)
                                        2024-12-09 09:13:22.136  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                                        2024-12-09 09:13:37.016  - info: host.ioBroker instance system.adapter.daswetter.1 in version "3.1.16" started with pid 3075580
                                        2024-12-09 09:13:38.099  - info: daswetter.1 (3075580) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.3
                                        2024-12-09 09:13:43.335  - info: daswetter.1 (3075580) still wrong data structure from server received! repaired...
                                        2024-12-09 09:13:45.176  - info: daswetter.1 (3075580) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                        2024-12-09 09:13:45.680  - info: daswetter.1 (3075580) cleaned everything up...
                                        2024-12-09 09:13:45.688  - info: host.ioBroker instance system.adapter.daswetter.1 having pid 3075580 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2024-12-09 09:13:45.689  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md-gitti: Material Design Widgets: Wetter Skript triggered by 'system.adapter.daswetter.1.alive'
                                        2024-12-09 09:14:23.090  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                                        2024-12-09 09:14:53.769  - info: javascript.0 (4016006) script.js.Ereignisse.Flurlicht: #### Flurlicht eingeschaltet
                                        2024-12-09 09:15:00.035  - info: javascript.0 (4016006) script.js.Allerlei.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 2
                                        2024-12-09 09:15:00.047  - info: javascript.0 (4016006) script.js.Allerlei.Shelly-Verbrauch-MQTT: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
                                        2024-12-09 09:15:30.108  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                                        2024-12-09 09:16:00.199  - info: javascript.0 (4016006) script.js.Netzwerk.IP-Adresse2: IP-Adresse (ausgelesen von http://ipecho.net/plain): 94.31.88.205
                                        2024-12-09 09:16:34.100  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                                        2024-12-09 09:16:58.013  - info: history.0 (4015915) Delete old history "/opt/iobroker/iobroker-data/history/20241130/history.deyeidc.0.3918369324.Apo_t1.json"
                                        2024-12-09 09:17:38.264  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                                        2024-12-09 09:18:36.343  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                                        2024-12-09 09:18:53.020  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3079218
                                        2024-12-09 09:18:54.021  - info: dwd.0 (3079218) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
                                        2024-12-09 09:18:54.384  - info: dwd.0 (3079218) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2024-12-09 09:18:54.896  - info: host.ioBroker instance system.adapter.dwd.0 having pid 3079218 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          Virtualization: lxc
                                        Installation:           lxc
                                        Kernel:                 x86_64
                                        Userland:               64 bit
                                        Timezone:               Europe/Berlin (CET, +0100)
                                        User-ID:                1000
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        Recommended versions are nodejs 20.18.1 and npm 10.8.2
                                        nodeJS installation is correct
                                        MEMORY:
                                        Mem:             12G        4.9G        6.9G        139K        1.2G        8.0G
                                        Swap:             0B          0B          0B
                                        Total:           12G        4.9G        6.9G
                                        ioBroker Core:          js-controller           7.0.3
        admin                   7.1.5
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                55071
                                        States:                 51750
                                        Size of iob-Database:
                                        144M    /opt/iobroker/iobroker-data/states.jsonl
                                        Gruß Ralf
                                        • NashraN Nashra
                                          @Thomas-Braun
                                          Proxmox lxc
                                          ```bash
                                          *** BASE SYSTEM ***
                                            Virtualization: lxc
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          CPU threads: 4
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          jack
                                          HOME=/home/jack
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:
                                          *** MEMORY ***
                                          Swap:             0B          0B          0B
                                                   4686 M used memory
                                                   6506 M free memory
                                                      0 M buffer memory
                                                   1094 M swap cache
                                                      0 M total swap
                                                      0 M used swap
                                                      0 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          2.6G    /var/
                                          2.1G    /var/log
                                          351M    /var/cache
                                          USB-Devices by-id:
                                          HINT:
                                          /dev/ttyUSB0
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.1.5
                                          javascript:     8.8.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        55071
                                          States:         51750
                                          Pending Updates: 0
                                            Virtualization: lxc
                                          Installation:           lxc
                                          Kernel:                 x86_64
                                          Userland:               64 bit
                                          User-ID:                1000
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          MEMORY:
                                          Swap:             0B          0B          0B
        admin                   7.1.5
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                55071
                                          States:                 51750
                                          #678
                                          @nashra sagte in iob diag - Skript:
                                          Danke.
                                          Und
                                          iob diag --unmask
                                          deckt die Zigbee-Werte auf?
