  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.9k Aufrufe 40 Beobachtet
    @homoran sagte in iob diag - Skript:
    fehlende Gruppe für den user (adm?)
    Nee, LXC-Eigenheit.
    Bei Meister Mopper wird auch richtig Bookworm erkannt...
    Meister MopperM Online
    Meister Mopper
    #653
    So, jetzt noch timedatectl:
    Auf Normalzeit umgestellt:
    Current default time zone: 'Etc/UTC'
    Local time is now:      Sun Sep  8 16:09:36 UTC 2024.
    Universal Time is now:  Sun Sep  8 16:09:36 UTC 2024.
    thomas@ioTest:~$
    Skript gestartet:
    Script v.2024-09-07
    *** BASE SYSTEM ***
    Static hostname: ioTest
          Icon name: computer-container
            Chassis: container ☐
     Virtualization: lxc
             Kernel: Linux 6.8.12-1-pve
       Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
    16:12:51 up 4 min,  2 users,  load average: 0.20, 0.27, 0.33
    CPU threads: 1
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                  Local time: Sun 2024-09-08 16:12:51 UTC
              Universal time: Sun 2024-09-08 16:12:51 UTC
                    RTC time: n/a
                   Time zone: Etc/UTC (UTC, +0000)
                 NTP service: inactive
             RTC in local TZ: no
    Timezone is probably wrong. Do you want to reconfigure it? (y/n)
    Setting up timezone
    Enter the timezone for the server (default is Europe/Berlin):
    Setting up time synchronization with systemd-timesyncd
    *** Users and Groups ***
    User that called 'iob diag':
    thomas
    HOME=/home/thomas
    GROUPS=thomas adm sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            2.1G        1.1G        1.1G        118K         10M        1.1G
    Swap:             0B          0B          0B
    Total:          2.1G        1.1G        1.1G
    Active iob-Instances:   5
            2048 M total memory
            1019 M used memory
            1009 M active memory
               0 M inactive memory
            1018 M free memory
               0 M buffer memory
              10 M swap cache
               0 M total swap
               0 M used swap
               0 M free swap
    top - 18:13:07 up 4 min,  2 users,  load average: 0.22, 0.27, 0.33
    Tasks:  28 total,   1 running,  27 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   2048.0 total,   1016.4 free,   1021.2 used,     10.6 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1026.8 avail Mem
    *** FAILED SERVICES ***
     UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
    3 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                   Type      Size  Used Avail Use% Mounted on
    rpool/data/subvol-300-disk-0 zfs        12G  6.0G  6.1G  50% /
    none                         tmpfs     492K  4.0K  488K   1% /dev
    udev                         devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                        tmpfs     6.3G  112K  6.3G   1% /run
    tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1001
    Show mounted filesystems:
    TARGET SOURCE                       FSTYPE OPTIONS
    /      rpool/data/subvol-300-disk-0 zfs    rw,noatime,xattr,posixacl,casesensitive
    /var:
    1.1G    /var/
    603M    /var/log
    602M    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
    369M    /var/lib
    Archived and active journals take up 601.2M in the file system.
    /opt/iobroker/backups:
    489M    /opt/iobroker/backups/
    8.5K    /opt/iobroker/backups/scripte0
    /opt/iobroker/iobroker-data:
    164M    /opt/iobroker/iobroker-data/
    105M    /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/javascript.admin
    40M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    3.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
    3.4M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
    3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
    3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.17.0
    /usr/bin/node           v20.17.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
     Installed: 20.17.0-1nodesource1
     Candidate: 20.17.0-1nodesource1
     Version table:
    *** 20.17.0-1nodesource1 1001
           500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
        20.16.0-1nodesource1 1001
        20.15.1-1nodesource1 1001
        20.15.0-1nodesource1 1001
        20.14.0-1nodesource1 1001
        20.13.1-1nodesource1 1001
        20.13.0-1nodesource1 1001
        20.12.2-1nodesource1 1001
        20.12.1-1nodesource1 1001
        20.12.0-1nodesource1 1001
        20.11.1-1nodesource1 1001
        20.11.0-1nodesource1 1001
        20.10.0-1nodesource1 1001
        20.9.0-1nodesource1 1001
        20.8.1-1nodesource1 1001
        20.8.0-1nodesource1 1001
        20.7.0-1nodesource1 1001
        20.6.1-1nodesource1 1001
        20.6.0-1nodesource1 1001
        20.5.1-1nodesource1 1001
        20.5.0-1nodesource1 1001
        20.4.0-1nodesource1 1001
        20.3.1-1nodesource1 1001
        20.3.0-1nodesource1 1001
        20.2.0-1nodesource1 1001
        20.1.0-1nodesource1 1001
        20.0.0-1nodesource1 1001
        18.19.0+dfsg-6~deb12u2 500
           500 http://deb.debian.org/debian bookworm/main amd64 Packages
        18.19.0+dfsg-6~deb12u1 500
           500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Hosts:
    ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 286)
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.0.23
    javascript:     8.7.6
    nodejs modules from github:     2
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
     system.adapter.alias-manager.0          : alias-manager         : ioTest                                   -  enabled
    + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioTest                                   - disabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioTest                                   - disabled
    + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
     system.adapter.vis-bars.0               : vis-bars              : ioTest                                   - disabled
     system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioTest                                   - disabled
     system.adapter.vis-fancyswitch.0        : vis                   : ioTest                                   - disabled
     system.adapter.vis-history.0            : vis-history           : ioTest                                   - disabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioTest                                   - disabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioTest                                   - disabled
     system.adapter.vis-justgage.0           : vis-justgage          : ioTest                                   - disabled
     system.adapter.vis-metro.0              : vis                   : ioTest                                   - disabled
     system.adapter.vis-plumb.0              : vis                   : ioTest                                   - disabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioTest                                   - disabled
     system.adapter.vis.0                    : vis                   : ioTest                                   -  enabled
    + system.adapter.web.0                    : web                   : ioTest                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.19   , installed 3.0.19
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "heos"         : 2.2.1    , installed 2.2.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "modbus"       : 6.2.3    , installed 6.2.3
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "openligadb"   : 1.4.11   , installed 1.4.11
    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
    Adapter    "samsung"      : 0.6.0    , installed 0.6.0
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "solax"        : 0.9.9    , installed 0.9.9
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "traccar"      : 1.1.4    , installed 1.1.4
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        453
    States:         337
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146965130  1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146967666  123/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146967727  113/redis-server 12
    tcp6       0      0 :::111                  :::*                    LISTEN      0          146965132  1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          146967677  123/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146968429  237/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146967920  151/io.admin.0
    tcp6       0      0 :::6556                 :::*                    LISTEN      0          146965446  1/init
    tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146967728  113/redis-server 12
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146965131  1/init
    udp6       0      0 :::111                  :::*                                0          146965133  1/init
    2024-09-08 16:57:11.031  - info: javascript.0 (193) received all states
    2024-09-08 16:57:11.518  - info: javascript.0 (193) received all objects
    2024-09-08 17:24:26.513  - info: javascript.0 (193) terminating
    2024-09-08 17:24:26.514  - info: javascript.0 (193) Terminated (NO_ERROR): Without reason
    2024-09-08 17:24:26.518  - info: javascript.0 (193) Got terminate signal TERMINATE_YOURSELF
    2024-09-08 17:24:27.005  - info: javascript.0 (193) terminating
    2024-09-08 17:25:05.872  - info: javascript.0 (5358) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 17:25:06.028  - info: javascript.0 (5358) requesting all states
    2024-09-08 17:25:06.029  - info: javascript.0 (5358) requesting all objects
    2024-09-08 17:25:06.044  - info: javascript.0 (5358) received all states
    2024-09-08 17:25:06.261  - info: javascript.0 (5358) received all objects
    2024-09-08 17:56:50.232  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 17:56:50.378  - info: javascript.0 (192) requesting all states
    2024-09-08 17:56:50.379  - info: javascript.0 (192) requesting all objects
    2024-09-08 17:56:50.395  - info: javascript.0 (192) received all states
    2024-09-08 17:56:50.615  - info: javascript.0 (192) received all objects
    2024-09-08 17:58:03.057  - info: javascript.0 (192) terminating
    2024-09-08 17:58:03.060  - info: javascript.0 (192) Terminated (NO_ERROR): Without reason
    2024-09-08 17:58:03.071  - info: javascript.0 (192) Got terminate signal TERMINATE_YOURSELF
    2024-09-08 17:58:03.545  - info: javascript.0 (192) terminating
    2024-09-08 18:08:28.307  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 18:08:28.451  - info: javascript.0 (192) requesting all states
    2024-09-08 18:08:28.452  - info: javascript.0 (192) requesting all objects
    2024-09-08 18:08:28.468  - info: javascript.0 (192) received all states
    2024-09-08 18:08:28.700  - info: javascript.0 (192) received all objects
    Kontrolle:
    thomas@ioTest:~$ timedatectl
                   Local time: So 2024-09-08 18:15:10 CEST
               Universal time: So 2024-09-08 16:15:10 UTC
                     RTC time: n/a
              RTC in local TZ: no
    Ich sag mal: Perfekt!
    Proxmox und HA ...
    • T TT-Tom
      @wildbill
      ich nutze die Konsole von Proxmox nicht, da Safari mich da immer ärgert. Darum die Frage, ob es vielleicht kleine Abweichungen gibt.
      @Thomas-Braun nutzt du lsb_release -a zur Abfrage des OS?
      ich habe nur das Standard Template für den LXC genommen und folgende Pakete nach installiert.
      apt install -y curl gnupg ca-certificates sudo mc
      W Online
      W Online
      Wildbill
      #654
      @tt-tom Läuft bei mir mit Safari problemlos. Wobei ich auch lieber direkt per SSH-Terminal einsteige, da dann manche Funktionalität (z.B. Menüs in mc) funktionieren, die die Proxmox-Konsole nicht hergibt. Aber alle Befehle, die man im Terminal direkt eingibt, ergeben dasselbe. Vorausgesetzt natürlich, man meldet sich per SSH oder in der Proxmox-Konsole mit demselben User an.
      Aber genug OT.
      Gruss, Jürgen
        TT-Tom
        #655
        @Thomas-Braun
        ein Auszug vom User root. Ich habe ein LXC mit Debian 12 neu aufgesetzt und nur den root user. Iobroker habe ich jetzt nicht installiert, wollte nur das Anlegen eines Standarduser testen. Hat so nicht ganz funktioniert, wenn ich es heute noch schaffe, lege ich eine komplette iobroker Installation als root an und teste dann nochmal.
        root
        HOME=/root
        GROUPS=root
        js-controller is not running
        A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
        A root login is not required in most Linux Distributions.
        Enter the username for a new user (Not 'root' and not 'iobroker'!): tom
        Enter the password for the new user:
        Confirm the password for the new user:
        Adding new user account...
        useradd: group 'iobroker' does not exist
        chpasswd: (user tom) pam_chauthtok() failed, error:
        Authentication token manipulation error
        chpasswd: (line 1, user tom) password not changed
        Gruß Tom
        Public Transport
        NSPanel Adapter Wiki
        T Thomas BraunT 2 Antworten Letzte Antwort
        • T TT-Tom
          @wildbill
          #656
          @tt-tom sagte in iob diag - Skript:
          Jein, -a gibt alles aus, ich lese den Codename per
          lsb_release -sc
          aus. Scheint also kein default package zu sein.
          • T TT-Tom
            @Thomas-Braun
            root
            HOME=/root
            GROUPS=root
            TT-Tom
            #657
            @tt-tom
            @Thomas-Braun
            nochmal mit iobroker Installation. User tom wurde angelegt und die Timezone wurde geändert.
            root@testsystem:~# ./iob_diag.sh
            You should not be root on your system!
            Better use your standard user!
            *** ioBroker Diagnosis ***
            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
            https://forum.iobroker.net
            Just copy and paste the Summary Page, including the ``` characters at start and end.
            It helps us to help you!
            Press any key to continue
            ```bash
            Script v.2024-09-07
            *** BASE SYSTEM ***
             Static hostname: testsystem
              Virtualization: lxc
            Package configuration
                              ┌───────────────────────┤ Configuring tzdata ├───────────────────────┐
                              │ Please select the city or region corresponding to your time zone.  │
                              │ Time zone:                                                         │
                              │                           Amsterdam       -                        │
                              │                           Andorra         ▒                        │
                              │                           Astrakhan       0                        │
                              │                           Athens          ▒                        │
                              │                           Belfast         ▒                        │
                              │                           Belgrade        ▒                        │
                              │                           Berlin          ▒                        │
                              │                           Bratislava      ▒                        │
                              │                           Brussels        ▒                        │
                              │                           Bucharest       ▒                        │
                              │                           Budapest        ▒                        │
                              │                           Busingen        .                        │
                              │                 <Ok>                     <Cancel>                  │
            Current default time zone: 'Europe/Berlin'
            Local time is now:      Sun Sep  8 20:07:44 CEST 2024.
            Universal Time is now:  Sun Sep  8 18:07:44 UTC 2024.
            root
            HOME=/root
            GROUPS=root
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:            2.1G        284M        1.6G        118K        229M        1.9G
            Swap:           1.1G          0B        1.1G
            Total:          3.2G        284M        2.7G
            Active iob-Instances:   4
                     2048 M total memory
                      271 M used memory
                      399 M active memory
                       66 M inactive memory
                     1557 M free memory
                        0 M buffer memory
                      219 M swap cache
                     1024 M total swap
                        0 M used swap
                     1024 M free swap
            top - 20:08:01 up 5 min,  1 user,  load average: 0.04, 0.17, 0.16
            Tasks:  25 total,   1 running,  24 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   2048.0 total,   1555.1 free,    273.6 used,    219.4 buff/cache
            MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   1774.4 avail Mem
            2 loaded units listed.
            *** FILESYSTEM ***
            /dev/mapper/pve-vm--106--disk--0 ext4      7.8G  2.1G  5.3G  29% /
            udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
            tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
            tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
            /      /dev/mapper/pve-vm--106--disk--0 ext4   rw,relatime,stripe=16
            /var:
            400M    /var/
            237M    /var/cache
            234M    /var/cache/apt
            158M    /var/cache/apt/archives
            146M    /var/lib
            Archived and active journals take up 16.0M in the file system.
            4.0K    /opt/iobroker/backups/
            62M     /opt/iobroker/iobroker-data/
            57M     /opt/iobroker/iobroker-data/files
            31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            8.4M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.70cad8ba.js
            7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
            5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
            5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
            5.0M    /opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
                    500 http://security.debian.org bookworm-security/main amd64 Packages
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            testsystem          testsystem (version: 6.0.11, hostname: testsystem    , alive, uptime: 316)
            admin:          7.0.23
            javascript:     "javascript" not found
            nodejs modules from github:     0
            Adapter State
            + system.adapter.admin.0                  : admin                 : testsystem                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : testsystem                               -  enabled
            + system.adapter.discovery.0              : discovery             : testsystem                               -  enabled
            + instance is alive
            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
            Objects and States
            Objects:        148
            States:         103
            Hit:1 http://security.debian.org bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Pending Updates: 0
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       80745598   155/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       80745603   155/iobroker.js-con
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          80743343   319/master
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          80742867   1/init
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       80751205   436/io.admin.0
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          80743344   319/master
            tcp6       0      0 :::22                   :::*                    LISTEN      0          80742219   1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          80742869   1/init
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          80742305   95/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          80742868   1/init
            udp6       0      0 :::111                  :::*                                0          80742870   1/init
            2024-09-08 18:02:43.093  - info: backitup.0 (371) starting. Version 3.0.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
            2024-09-08 18:02:43.111  - info: backitup.0 (371) [iobroker] backup will be activated at 02:48 every 1 day(s)
            2024-09-08 18:02:46.482  - info: host.testsystem instance system.adapter.discovery.0 in version "4.5.0" started with pid 386
            2024-09-08 18:02:47.002  - info: discovery.0 (386) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
            2024-09-08 18:03:34.073  - info: admin.0 (330) ==> Connected system.user.admin from ::ffff:192.168.178.12
            2024-09-08 18:04:30.739  - info: host.testsystem stopInstance system.adapter.admin.0 (force=false, process=true)
            2024-09-08 18:04:30.741  - info: admin.0 (330) Got terminate signal TERMINATE_YOURSELF
            2024-09-08 18:04:30.741  - info: admin.0 (330) terminating http server on port 8081
            2024-09-08 18:04:30.743  - info: admin.0 (330) terminating
            2024-09-08 18:04:30.743  - info: admin.0 (330) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-09-08 18:04:30.781  - info: host.testsystem stopInstance system.adapter.admin.0 send kill signal
            2024-09-08 18:04:31.244  - info: admin.0 (330) terminating
            2024-09-08 18:04:31.281  - info: host.testsystem instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-09-08 18:04:34.403  - info: host.testsystem instance system.adapter.admin.0 in version "7.0.23" started with pid 436
            2024-09-08 18:04:35.068  - info: admin.0 (436) starting. Version 7.0.23 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
            2024-09-08 18:04:35.079  - info: admin.0 (436) requesting all objects
            2024-09-08 18:04:35.285  - info: admin.0 (436) received all objects
            2024-09-08 18:04:35.382  - info: admin.0 (436) socket.io server listening on port 8081
            2024-09-08 18:04:35.383  - info: admin.0 (436) http server listening on port 8081
            2024-09-08 18:04:35.383  - info: admin.0 (436) Use link "http://127.0.0.1:8081" to configure.
            2024-09-08 18:04:37.576  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
            2024-09-08 18:04:37.615  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
            2024-09-08 18:04:37.645  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
            2024-09-08 18:04:45.342  - info: admin.0 (436) ==> Connected system.user.admin from ::ffff:192.168.178.12
            2024-09-08 18:04:57.657  - info: admin.0 (436) <== Disconnect system.user.admin from ::ffff:192.168.178.12 admin
            iob diag has finished.
            Gruß Tom
            Public Transport
            • T TT-Tom
              @Thomas-Braun
              root
              HOME=/root
              GROUPS=root
              #658
              @tt-tom
              Den
              kann ich mir gerade nicht so wirklich erklären. Zumal es bei @Meister-Mopper alles wie gedacht funktioniert...
              • T TT-Tom
                @tt-tom
                @Thomas-Braun
                ```bash
                Script v.2024-09-07
                *** BASE SYSTEM ***
                  Virtualization: lxc
                                  │ Time zone:                                                         │
                                  │                           Amsterdam       -                        │
                                  │                           Andorra         ▒                        │
                                  │                           Astrakhan       0                        │
                                  │                           Athens          ▒                        │
                                  │                           Belfast         ▒                        │
                                  │                           Belgrade        ▒                        │
                                  │                           Berlin          ▒                        │
                                  │                           Bratislava      ▒                        │
                                  │                           Brussels        ▒                        │
                                  │                           Bucharest       ▒                        │
                                  │                           Budapest        ▒                        │
                                  │                           Busingen        .                        │
                                  │                 <Ok>                     <Cancel>                  │
                root
                HOME=/root
                GROUPS=root
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:
                *** MEMORY ***
                Swap:           1.1G          0B        1.1G
                         2048 M total memory
                          271 M used memory
                          399 M active memory
                         1557 M free memory
                            0 M buffer memory
                          219 M swap cache
                         1024 M total swap
                            0 M used swap
                         1024 M free swap
                *** FILESYSTEM ***
                /var:
                400M    /var/
                237M    /var/cache
                234M    /var/cache/apt
                146M    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.0.23
                Adapter State
                + instance is alive
                Objects and States
                Objects:        148
                States:         103
                Pending Updates: 0
                #659
                Also mit vorheriger Installation des ioBroker funktioniert es?
                  TT-Tom
                  #660
                  ja mit iobroker ist alles sauber durchgelaufen.
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    #661
                    Na dann....
                    Das Skript kommt ja im Normalfall auch erst mit dem ioBroker auf das System.
                      @tt-tom
                      Den
                      TT-Tom
                      #662
                      Den
                      der User konnte ja nicht der Gruppe iobroker zugeordnet werden.
                      Gruß Tom
                      Public Transport
                      • T TT-Tom
                        Den
                        #663
                        Das sollte aber nicht der Grund für die Meldung sein.
                        Wie dem auch sei, das Skript ruft man ja in der Realität nur bei vorhandener Installation des ioBrokers auf.
                          Knirpso
                          schrieb am zuletzt editiert von Knirpso
                          #664
                          Anbei noch der gewünschte Log aus https://forum.iobroker.net/topic/76922/schaltverhalten-iot-adapter-mit-alexa/4
                          Script v.2024-09-16
                          *** BASE SYSTEM ***
                          Hardware Vendor : Synology Inc.
                          Kernel          : x86_64
                          Userland        : 64 bit
                          Docker          : v9.1.2
                          Virtualization  : Docker
                          Kernel          : x86_64
                          Userland        : 64 bit
                           17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
                          CPU threads: 8
                          Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                          Tue Sep 17 15:25:15 UTC 2024
                          Tue Sep 17 17:25:15 CEST 2024
                          CEST +0200
                          Etc/UTC
                          root
                          HOME=/root
                          GROUPS=root
                          iobroker
                          HOME=/opt/iobroker
                          Display-Server: true
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Mem:             67G        7.4G        1.0G        215M         59G         59G
                          Swap:            42G        307M         42G
                          Total:          109G        7.7G         43G
                          Active iob-Instances:   17
                                  64084 M total memory
                                   7067 M used memory
                                   7965 M active memory
                                  52969 M inactive memory
                                    971 M free memory
                                     84 M buffer memory
                                  56764 M swap cache
                                  40499 M total swap
                                    293 M used swap
                                  40206 M free swap
                          top - 17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
                          Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
                          MiB Mem :  64084.8 total,    969.7 free,   7068.6 used,  56848.9 buff/cache
                          MiB Swap:  40499.9 total,  40206.6 free,    293.3 used.  57016.2 avail Mem
                          *** FILESYSTEM ***
                          /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /
                          tmpfs          tmpfs   64M     0   64M   0% /dev
                          tmpfs          tmpfs   32G     0   32G   0% /sys/fs/cgroup
                          shm            tmpfs   64M     0   64M   0% /dev/shm
                          /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /opt/iobroker
                          /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /etc/hosts
                          tmpfs          tmpfs   32G     0   32G   0% /proc/acpi
                          tmpfs          tmpfs   32G     0   32G   0% /proc/scsi
                          tmpfs          tmpfs   32G     0   32G   0% /sys/firmware
                          /                  /dev/synorbd_1[/@syno/@docker/btrfs/subvolumes/43c485044ed9f1e230e9f082f08e839ece82e19c0db5e0e02d5f344f954dfa66]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                          |-/opt/iobroker    /dev/synorbd_1[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                          |-/etc/resolv.conf /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                          |-/etc/hostname    /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                          `-/etc/hosts       /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                          /var:
                          34M     /var/
                          32M     /var/lib
                          19M     /var/lib/apt/lists
                          19M     /var/lib/apt
                          13M     /var/lib/dpkg
                          33M     /opt/iobroker/backups/
                          1.1G    /opt/iobroker/iobroker-data/
                          756M    /opt/iobroker/iobroker-data/files
                          441M    /opt/iobroker/iobroker-data/files/javascript.admin
                          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                          408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                          117M    /opt/iobroker/iobroker-data/states.jsonl
                          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
                          USB-Devices by-id:
                          HINT:
                          Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                          /dev/ttyACM0
                          HINT:
                          Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                          /dev/ttyACM0
                          /usr/bin/nodejs         v18.20.4
                          /usr/bin/node           v18.20.4
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          /usr/bin/corepack       0.28.0
                          nodejs:
                            Installed: 18.20.4-1nodesource1
                            Candidate: 18.20.4-1nodesource1
                            Version table:
                           *** 18.20.4-1nodesource1 1001
                                 1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                               18.20.3-1nodesource1 1001
                               18.20.2-1nodesource1 1001
                               18.20.1-1nodesource1 1001
                               18.20.0-1nodesource1 1001
                               18.19.1-1nodesource1 1001
                                  500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                               18.19.0-1nodesource1 1001
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1308286)
                          slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 268408)
                          admin:          7.0.23
                          javascript:     8.7.6
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                            system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                          + system.adapter.history.0                : history               : iobroker                                 -  enabled
                          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                          + system.adapter.mystrom.0                : mystrom               : iobroker                                 -  enabled
                          + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                          + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                          + system.adapter.zigbee.1                 : zigbee                : slave1-raspberrypi                       -  enabled, port: /dev/ttyACM0
                          + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                          + instance is alive
                          │ (index) │   name   │                           url                           │ auto upgrade │
                          │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                          │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                          Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                          Adapter    "iot"          : 3.3.0    , installed 3.3.0
                          Adapter    "roborock"     : 0.6.4    , installed 0.6.4
                          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                          Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                          Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
                          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                          Objects and States
                          Objects:        3786
                          States:         2647
                          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 26
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3946312486 -
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3946312479 -
                          tcp        0      0 127.0.0.11:42340        0.0.0.0:*               LISTEN      0          3946306647 -
                          tcp6       0      0 :::6824                 :::*                    LISTEN      1000       78218444   -
                          tcp6       0      0 :::8554                 :::*                    LISTEN      1000       78220248   -
                          tcp6       0      0 :::8555                 :::*                    LISTEN      1000       78220249   -
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3946310901 -
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3946317922 -
                          tcp6       0      0 :::8083                 :::*                    LISTEN      1000       3946324298 -
                          tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3946324745 -
                          tcp6       0      0 :::1984                 :::*                    LISTEN      1000       78243001   -
                          tcp6       0      0 :::7906                 :::*                    LISTEN      1000       78218445   -
                          udp        0      0 127.0.0.11:56032        0.0.0.0:*                           0          3946306646 -
                          udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1000       38730773   -
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       3946311323 -
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       3946311324 -
                          2024-09-17 17:01:23.903  - error: mystrom.0 (386) 200
                          2024-09-17 17:01:23.903  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
                          2024-09-17 17:01:23.903  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                          2024-09-17 17:01:23.904  - info: mystrom.0 (386) Set update interval for FCF5C418FF54 to 60
                          2024-09-17 17:01:23.920  - info: mystrom.0 (386) Set update interval for FCF5C418FB0C to 60
                          2024-09-17 17:01:23.922  - error: mystrom.0 (386) 200
                          2024-09-17 17:01:23.922  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
                          2024-09-17 17:01:23.922  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                          2024-09-17 17:01:23.923  - error: mystrom.0 (386) 200
                          2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
                          2024-09-17 17:01:23.924  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                          2024-09-17 17:01:23.924  - error: mystrom.0 (386) 200
                          2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
                          2024-09-17 17:01:23.930  - error: mystrom.0 (386) 200
                          2024-09-17 17:01:23.930  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
                          2024-09-17 17:01:23.930  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                          2024-09-17 17:01:23.936  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
                          2024-09-17 17:01:23.937  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
                          2024-09-17 17:01:23.941  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                          2024-09-17 17:01:23.942  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                          2024-09-17 17:01:23.962  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                          2024-09-17 17:01:23.966  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                          2024-09-17 17:03:36.237  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                          Edit: Log von Skriptversion 2024-09-16 angehängt.
                          • K Knirpso
                            Script v.2024-09-16
                            *** BASE SYSTEM ***
                            Kernel          : x86_64
                            Userland        : 64 bit
                            Docker          : v9.1.2
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 8
                            CEST +0200
                            Etc/UTC
                            root
                            HOME=/root
                            GROUPS=root
                            iobroker
                            HOME=/opt/iobroker
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                            Swap:            42G        307M         42G
                                     7067 M used memory
                                      971 M free memory
                                       84 M buffer memory
                                    56764 M swap cache
                                    40499 M total swap
                                      293 M used swap
                                    40206 M free swap
                            *** FILESYSTEM ***
                            /var:
                            34M     /var/
                            32M     /var/lib
                            19M     /var/lib/apt
                            13M     /var/lib/dpkg
                            USB-Devices by-id:
                            HINT:
                            /dev/ttyACM0
                            HINT:
                            /dev/ttyACM0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.0.23
                            javascript:     8.7.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        3786
                            States:         2647
                            Pending Updates: 26
                            #665
                            @knirpso Bitte die aktuelle Version 2024-09-16 verwenden.
                            • K Knirpso
                              Script v.2024-09-16
                              *** BASE SYSTEM ***
                              Kernel          : x86_64
                              Userland        : 64 bit
                              Docker          : v9.1.2
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 8
                              CEST +0200
                              Etc/UTC
                              root
                              HOME=/root
                              GROUPS=root
                              iobroker
                              HOME=/opt/iobroker
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                              Swap:            42G        307M         42G
                                       7067 M used memory
                                        971 M free memory
                                         84 M buffer memory
                                      56764 M swap cache
                                      40499 M total swap
                                        293 M used swap
                                      40206 M free swap
                              *** FILESYSTEM ***
                              /var:
                              34M     /var/
                              32M     /var/lib
                              19M     /var/lib/apt
                              13M     /var/lib/dpkg
                              USB-Devices by-id:
                              HINT:
                              /dev/ttyACM0
                              HINT:
                              /dev/ttyACM0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.0.23
                              javascript:     8.7.6
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        3786
                              States:         2647
                              Pending Updates: 26
                              #666
                              @knirpso
                              Hm. Kannst du mal die Ausgabe von
                              pgrep -l '[X]|[w]ayland|X11|wayfire'
                              posten?
                              Oder auch die anderen Dockeristen.
                                @knirpso
                                posten?
                                Knirpso
                                #667
                                root@iobroker:/opt/iobroker# pgrep -l '[X]|[w]ayland|X11|wayfire'
                                pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                                Try `pgrep -f' option to match against the complete command line.
                                • K Knirpso
                                  #668
                                  @knirpso sagte in iob diag - Skript:
                                  pgrep -lf '[X]|[w]ayland|X11|wayfire'
                                    Knirpso
                                    #669
                                    root@iobroker:/opt/iobroker# pgrep -lf '[X]|[w]ayland|X11|wayfire'
                                    1966 go2rtc_linux_am
                                    root@pihole:/# pgrep -lf '[X]|[w]ayland|X11|wayfire'
                                    root@pihole:/#
                                    Mehr hab ich nicht
                                    • K Knirpso
                                      root@pihole:/#
                                      Mehr hab ich nicht
                                      #670
                                      @knirpso
                                      Danke, Grund für den 'flase positive' gefunden.
                                      • K Knirpso
                                        root@pihole:/#
                                        Mehr hab ich nicht
                                        #671
                                        @knirpso
                                        Zieh bitte die aktuelle Version nochmal.
                                          @knirpso
                                          Knirpso
                                          #672
                                          Script v.2024-09-17
                                          *** BASE SYSTEM ***
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          Docker          : v9.1.2
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                           18:05:31 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
                                          CPU threads: 8
                                          Wed Sep 18 16:05:31 UTC 2024
                                          Wed Sep 18 18:05:31 CEST 2024
                                          CEST +0200
                                          Etc/UTC
                                          root
                                          HOME=/root
                                          GROUPS=root
                                          iobroker
                                          HOME=/opt/iobroker
                                          Desktop:
                                          Terminal:
                                          *** MEMORY ***
                                          Mem:             67G        7.5G        849M        216M         59G         59G
                                          Swap:            42G        305M         42G
                                          Total:          109G        7.8G         43G
                                          Active iob-Instances:   16
                                                   7174 M used memory
                                                   8048 M active memory
                                                  53007 M inactive memory
                                                    810 M free memory
                                                     84 M buffer memory
                                                  56817 M swap cache
                                                  40499 M total swap
                                                    290 M used swap
                                                  40209 M free swap
                                          top - 18:05:32 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
                                          Tasks:  34 total,   2 running,  32 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :  64084.8 total,    809.2 free,   7175.6 used,  56902.5 buff/cache
                                          MiB Swap:  40499.9 total,  40209.0 free,    290.9 used.  56909.1 avail Mem
                                          *** FILESYSTEM ***
                                          /var:
                                          34M     /var/
                                          32M     /var/lib
                                          19M     /var/lib/apt
                                          13M     /var/lib/dpkg
                                          40M     /opt/iobroker/backups/
                                          1017M   /opt/iobroker/iobroker-data/
                                          20M     /opt/iobroker/iobroker-data/states.jsonl
                                          USB-Devices by-id:
                                          HINT:
                                          /dev/ttyACM0
                                          HINT:
                                          /dev/ttyACM0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1397104)
                                          slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 357226)
                                          admin:          7.0.23
                                          javascript:     8.7.6
                                          Adapter State
                                            system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                                          + instance is alive
                                          Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
                                          Objects and States
                                          Objects:        3786
                                          States:         2638
                                          Pending Updates: 28
                                          2024-09-18 18:01:23.039  - error: mystrom.0 (386) 200
                                          2024-09-18 18:01:23.039  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
                                          2024-09-18 18:01:23.039  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                          2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
                                          2024-09-18 18:01:23.040  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                          2024-09-18 18:01:23.040  - error: mystrom.0 (386) 200
                                          2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
                                          2024-09-18 18:01:23.046  - error: mystrom.0 (386) 200
                                          2024-09-18 18:01:23.046  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
                                          2024-09-18 18:01:23.046  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                          2024-09-18 18:01:23.048  - error: mystrom.0 (386) 200
                                          2024-09-18 18:01:23.048  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
                                          2024-09-18 18:01:23.048  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                          2024-09-18 18:01:23.051  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                          2024-09-18 18:01:23.052  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                          2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
                                          2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
                                          2024-09-18 18:01:23.062  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                          2024-09-18 18:01:23.068  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                          2024-09-18 18:01:23.075  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                          2024-09-18 18:05:46.619  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                                          2024-09-18 18:05:49.032  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                                          2024-09-18 18:05:49.037  - info: admin.0 (157) <== Disconnect system.user.admin from ::ffff:192.168.212.23 iot
