  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.9k Aufrufe 40 Beobachtet
    @shadowhunter23 sagte in iob diag - Skript:
    dmesg: read kernel buffer failed: Operation not permitted
    fehlende Gruppe für den user (adm?)
    #647
    @homoran sagte in iob diag - Skript:
    Nee, LXC-Eigenheit.
    Bei Meister Mopper wird auch richtig Bookworm erkannt...
    Meister MopperM T 3 Antworten Letzte Antwort
      Nee, LXC-Eigenheit.
      Meister MopperM Online
      Meister Mopper
      #648
      Jetzt mal die Variante als root user:
      Script v.2024-09-07
      *** BASE SYSTEM ***
      Static hostname: ioTest
            Icon name: computer-container
              Chassis: container ☐
       Virtualization: lxc
               Kernel: Linux 6.8.12-1-pve
         Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      17:46:56 up 50 min,  1 user,  load average: 0.65, 0.48, 0.44
      CPU threads: 1
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                    Local time: Sun 2024-09-08 17:46:56 CEST
                Universal time: Sun 2024-09-08 15:46:56 UTC
                      RTC time: n/a
                   NTP service: inactive
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev redis
      A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
      A root login is not required in most Linux Distributions.
      Enter the username for a new user (Not 'root' and not 'iobroker'!): testuser
      Enter the password for the new user:
      Confirm the password for the new user:
      Adding new user account...
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            2.1G        1.1G        1.0G        110K         64M        1.1G
      Swap:             0B          0B          0B
      Total:          2.1G        1.1G        1.0G
      Active iob-Instances:   5
              2048 M total memory
              1022 M used memory
              1048 M active memory
                 0 M inactive memory
               964 M free memory
                 0 M buffer memory
                61 M swap cache
                 0 M total swap
                 0 M used swap
                 0 M free swap
      top - 17:47:31 up 50 min,  1 user,  load average: 0.41, 0.44, 0.43
      Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   2048.0 total,    962.5 free,   1024.3 used,     61.2 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1023.7 avail Mem
      *** FAILED SERVICES ***
       UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
      3 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                   Type      Size  Used Avail Use% Mounted on
      rpool/data/subvol-300-disk-0 zfs        12G  6.0G  6.1G  50% /
      none                         tmpfs     492K  4.0K  488K   1% /dev
      udev                         devtmpfs   16G     0   16G   0% /dev/tty
      tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                        tmpfs     6.3G  104K  6.3G   1% /run
      tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1001
      Show mounted filesystems:
      TARGET SOURCE                       FSTYPE OPTIONS
      /      rpool/data/subvol-300-disk-0 zfs    rw,noatime,xattr,posixacl,casesensitive
      /var:
      1.1G    /var/
      603M    /var/log
      602M    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
      369M    /var/lib
      Archived and active journals take up 601.1M in the file system.
      /opt/iobroker/backups:
      489M    /opt/iobroker/backups/
      8.5K    /opt/iobroker/backups/scripte0
      /opt/iobroker/iobroker-data:
      164M    /opt/iobroker/iobroker-data/
      105M    /opt/iobroker/iobroker-data/files
      47M     /opt/iobroker/iobroker-data/files/javascript.admin
      40M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
      3.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
      3.4M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
      3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
      3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
       Installed: 20.17.0-1nodesource1
       Candidate: 20.17.0-1nodesource1
       Version table:
      *** 20.17.0-1nodesource1 1001
             500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
          20.16.0-1nodesource1 1001
          20.15.1-1nodesource1 1001
          20.15.0-1nodesource1 1001
          20.14.0-1nodesource1 1001
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          18.19.0+dfsg-6~deb12u2 500
             500 http://deb.debian.org/debian bookworm/main amd64 Packages
          18.19.0+dfsg-6~deb12u1 500
             500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 1351)
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.0.23
      javascript:     8.7.6
      nodejs modules from github:     2
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
       system.adapter.alias-manager.0          : alias-manager         : ioTest                                   -  enabled
      + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
       system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioTest                                   - disabled
       system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioTest                                   - disabled
      + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
       system.adapter.vis-bars.0               : vis-bars              : ioTest                                   - disabled
       system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioTest                                   - disabled
       system.adapter.vis-fancyswitch.0        : vis                   : ioTest                                   - disabled
       system.adapter.vis-history.0            : vis-history           : ioTest                                   - disabled
       system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioTest                                   - disabled
       system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioTest                                   - disabled
       system.adapter.vis-justgage.0           : vis-justgage          : ioTest                                   - disabled
       system.adapter.vis-metro.0              : vis                   : ioTest                                   - disabled
       system.adapter.vis-plumb.0              : vis                   : ioTest                                   - disabled
       system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioTest                                   - disabled
       system.adapter.vis.0                    : vis                   : ioTest                                   -  enabled
      + system.adapter.web.0                    : web                   : ioTest                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.23   , installed 7.0.23
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 3.0.19   , installed 3.0.19
      Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "heos"         : 2.2.1    , installed 2.2.1
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "openligadb"   : 1.4.11   , installed 1.4.11
      Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
      Adapter    "samsung"      : 0.6.0    , installed 0.6.0
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "solax"        : 0.9.9    , installed 0.9.9
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "traccar"      : 1.1.4    , installed 1.1.4
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Objects and States
      Objects:        453
      States:         337
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146671219  117/redis-server 12
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146671191  124/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146670661  1/systemd
      tcp6       0      0 :::6556                 :::*                    LISTEN      0          146670958  1/systemd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146791638  5317/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146791954  5388/io.web.0
      tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146671220  117/redis-server 12
      tcp6       0      0 :::22                   :::*                    LISTEN      0          146671202  124/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          146670663  1/systemd
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146670662  1/systemd
      udp6       0      0 :::111                  :::*                                0          146670664  1/systemd
      2024-09-08 16:57:10.689  - info: javascript.0 (193) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
      2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all states
      2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all objects
      2024-09-08 16:57:11.031  - info: javascript.0 (193) received all states
      2024-09-08 16:57:11.518  - info: javascript.0 (193) received all objects
      2024-09-08 17:24:26.513  - info: javascript.0 (193) terminating
      2024-09-08 17:24:26.514  - info: javascript.0 (193) Terminated (NO_ERROR): Without reason
      2024-09-08 17:24:26.518  - info: javascript.0 (193) Got terminate signal TERMINATE_YOURSELF
      2024-09-08 17:24:27.005  - info: javascript.0 (193) terminating
      2024-09-08 17:25:05.872  - info: javascript.0 (5358) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
      2024-09-08 17:25:06.028  - info: javascript.0 (5358) requesting all states
      2024-09-08 17:25:06.029  - info: javascript.0 (5358) requesting all objects
      2024-09-08 17:25:06.044  - info: javascript.0 (5358) received all states
      2024-09-08 17:25:06.261  - info: javascript.0 (5358) received all objects
      Mein eingerichteter testuser hat auch die richtigen Rechte bekommen.
      testuser@ioTest:~$ groups
      testuser adm dialout sudo audio video plugdev users iobroker
      Proxmox und HA ...
        Nee, LXC-Eigenheit.
        TT-Tom
        #649
        @Meister-Mopper
        @Shadowhunter23
        von welcher Konsole habt ihr das script gestartet? aus der Proxmox oder per ssh aus einem Terminal?
        Gruß Tom
        Public Transport
        NSPanel Adapter Wiki
        Meister MopperM W 2 Antworten Letzte Antwort
        • T TT-Tom
          @Meister-Mopper
          @Shadowhunter23
          Meister Mopper
          #650
          @tt-tom sagte in iob diag - Skript:
          @Meister-Mopper
          @Shadowhunter23
          ssh vom windows terminal
          Proxmox und HA ...
          • T TT-Tom
            @Meister-Mopper
            @Shadowhunter23
            W Online
            W Online
            Wildbill
            #651
            @tt-tom Das sollte egal sein. Wenn Du Dich per SSH in einem LXC anmeldest landest Du im selben Userspace, als wenn Du Dich über die Proxmox-Konsole im LXC anmeldest.
            Gruss, Jürgen
            • W Wildbill
              Gruss, Jürgen
              TT-Tom
              #652
              @wildbill
              ich nutze die Konsole von Proxmox nicht, da Safari mich da immer ärgert. Darum die Frage, ob es vielleicht kleine Abweichungen gibt.
              @Thomas-Braun nutzt du lsb_release -a zur Abfrage des OS?
              ich habe nur das Standard Template für den LXC genommen und folgende Pakete nach installiert.
              apt install -y curl gnupg ca-certificates sudo mc
              Gruß Tom
              Public Transport
              W Thomas BraunT 2 Antworten Letzte Antwort
                Nee, LXC-Eigenheit.
                Meister Mopper
                #653
                So, jetzt noch timedatectl:
                Auf Normalzeit umgestellt:
                Current default time zone: 'Etc/UTC'
                Local time is now:      Sun Sep  8 16:09:36 UTC 2024.
                Universal Time is now:  Sun Sep  8 16:09:36 UTC 2024.
                thomas@ioTest:~$
                Skript gestartet:
                Script v.2024-09-07
                *** BASE SYSTEM ***
                 Virtualization: lxc
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                16:12:51 up 4 min,  2 users,  load average: 0.20, 0.27, 0.33
                CPU threads: 1
                              Local time: Sun 2024-09-08 16:12:51 UTC
                          Universal time: Sun 2024-09-08 16:12:51 UTC
                                RTC time: n/a
                               Time zone: Etc/UTC (UTC, +0000)
                         RTC in local TZ: no
                Timezone is probably wrong. Do you want to reconfigure it? (y/n)
                Setting up timezone
                Enter the timezone for the server (default is Europe/Berlin):
                Setting up time synchronization with systemd-timesyncd
                thomas
                HOME=/home/thomas
                GROUPS=thomas adm sudo iobroker
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            2.1G        1.1G        1.1G        118K         10M        1.1G
                Swap:             0B          0B          0B
                Total:          2.1G        1.1G        1.1G
                        2048 M total memory
                        1019 M used memory
                        1009 M active memory
                           0 M inactive memory
                        1018 M free memory
                           0 M buffer memory
                          10 M swap cache
                           0 M total swap
                           0 M used swap
                           0 M free swap
                top - 18:13:07 up 4 min,  2 users,  load average: 0.22, 0.27, 0.33
                Tasks:  28 total,   1 running,  27 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   2048.0 total,   1016.4 free,   1021.2 used,     10.6 buff/cache
                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1026.8 avail Mem
                *** FILESYSTEM ***
                tmpfs                        tmpfs     6.3G  112K  6.3G   1% /run
                /var:
                1.1G    /var/
                603M    /var/log
                369M    /var/lib
                Archived and active journals take up 601.2M in the file system.
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                 Version table:
                ioBroker Status
                Objects type: redis
                States  type: redis
                Hosts:
                ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 286)
                admin:          7.0.23
                javascript:     8.7.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        453
                States:         337
                Pending Updates: 0
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146965130  1/init
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146967666  123/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146967727  113/redis-server 12
                tcp6       0      0 :::111                  :::*                    LISTEN      0          146965132  1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          146967677  123/sshd: /usr/sbin
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146968429  237/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146967920  151/io.admin.0
                tcp6       0      0 :::6556                 :::*                    LISTEN      0          146965446  1/init
                tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146967728  113/redis-server 12
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146965131  1/init
                udp6       0      0 :::111                  :::*                                0          146965133  1/init
                2024-09-08 17:56:50.232  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                2024-09-08 17:56:50.378  - info: javascript.0 (192) requesting all states
                2024-09-08 17:56:50.379  - info: javascript.0 (192) requesting all objects
                2024-09-08 17:56:50.395  - info: javascript.0 (192) received all states
                2024-09-08 17:56:50.615  - info: javascript.0 (192) received all objects
                2024-09-08 17:58:03.057  - info: javascript.0 (192) terminating
                2024-09-08 17:58:03.060  - info: javascript.0 (192) Terminated (NO_ERROR): Without reason
                2024-09-08 17:58:03.071  - info: javascript.0 (192) Got terminate signal TERMINATE_YOURSELF
                2024-09-08 17:58:03.545  - info: javascript.0 (192) terminating
                2024-09-08 18:08:28.307  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                2024-09-08 18:08:28.451  - info: javascript.0 (192) requesting all states
                2024-09-08 18:08:28.452  - info: javascript.0 (192) requesting all objects
                2024-09-08 18:08:28.468  - info: javascript.0 (192) received all states
                2024-09-08 18:08:28.700  - info: javascript.0 (192) received all objects
                Kontrolle:
                thomas@ioTest:~$ timedatectl
                               Local time: So 2024-09-08 18:15:10 CEST
                           Universal time: So 2024-09-08 16:15:10 UTC
                                 RTC time: n/a
                          RTC in local TZ: no
                Ich sag mal: Perfekt!
                Proxmox und HA ...
                • T TT-Tom
                  @wildbill
                  W Online
                  W Online
                  Wildbill
                  #654
                  @tt-tom Läuft bei mir mit Safari problemlos. Wobei ich auch lieber direkt per SSH-Terminal einsteige, da dann manche Funktionalität (z.B. Menüs in mc) funktionieren, die die Proxmox-Konsole nicht hergibt. Aber alle Befehle, die man im Terminal direkt eingibt, ergeben dasselbe. Vorausgesetzt natürlich, man meldet sich per SSH oder in der Proxmox-Konsole mit demselben User an.
                  Aber genug OT.
                  Gruss, Jürgen
                    TT-Tom
                    #655
                    @Thomas-Braun
                    ein Auszug vom User root. Ich habe ein LXC mit Debian 12 neu aufgesetzt und nur den root user. Iobroker habe ich jetzt nicht installiert, wollte nur das Anlegen eines Standarduser testen. Hat so nicht ganz funktioniert, wenn ich es heute noch schaffe, lege ich eine komplette iobroker Installation als root an und teste dann nochmal.
                    root
                    HOME=/root
                    GROUPS=root
                    js-controller is not running
                    Enter the username for a new user (Not 'root' and not 'iobroker'!): tom
                    useradd: group 'iobroker' does not exist
                    chpasswd: (user tom) pam_chauthtok() failed, error:
                    Authentication token manipulation error
                    chpasswd: (line 1, user tom) password not changed
                    Gruß Tom
                    Public Transport
                    T Thomas BraunT 2 Antworten Letzte Antwort
                    • T TT-Tom
                      @wildbill
                      #656
                      Jein, -a gibt alles aus, ich lese den Codename per
                      lsb_release -sc
                      aus. Scheint also kein default package zu sein.
                      • T TT-Tom
                        @Thomas-Braun
                        root
                        HOME=/root
                        GROUPS=root
                        TT-Tom
                        #657
                        @tt-tom
                        @Thomas-Braun
                        nochmal mit iobroker Installation. User tom wurde angelegt und die Timezone wurde geändert.
                        root@testsystem:~# ./iob_diag.sh
                        You should not be root on your system!
                        Better use your standard user!
                        *** ioBroker Diagnosis ***
                        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                        https://forum.iobroker.net
                        Just copy and paste the Summary Page, including the ``` characters at start and end.
                        It helps us to help you!
                        Press any key to continue
                        ```bash
                        Script v.2024-09-07
                        *** BASE SYSTEM ***
                         Static hostname: testsystem
                          Virtualization: lxc
                        Package configuration
                                          ┌───────────────────────┤ Configuring tzdata ├───────────────────────┐
                                          │ Please select the city or region corresponding to your time zone.  │
                                          │ Time zone:                                                         │
                                          │                           Amsterdam       -                        │
                                          │                           Andorra         ▒                        │
                                          │                           Astrakhan       0                        │
                                          │                           Athens          ▒                        │
                                          │                           Belfast         ▒                        │
                                          │                           Belgrade        ▒                        │
                                          │                           Berlin          ▒                        │
                                          │                           Bratislava      ▒                        │
                                          │                           Brussels        ▒                        │
                                          │                           Bucharest       ▒                        │
                                          │                           Budapest        ▒                        │
                                          │                           Busingen        .                        │
                                          │                 <Ok>                     <Cancel>                  │
                        Current default time zone: 'Europe/Berlin'
                        Local time is now:      Sun Sep  8 20:07:44 CEST 2024.
                        Universal Time is now:  Sun Sep  8 18:07:44 UTC 2024.
                        root
                        HOME=/root
                        GROUPS=root
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Mem:            2.1G        284M        1.6G        118K        229M        1.9G
                        Swap:           1.1G          0B        1.1G
                        Total:          3.2G        284M        2.7G
                        Active iob-Instances:   4
                                 2048 M total memory
                                  271 M used memory
                                  399 M active memory
                                   66 M inactive memory
                                 1557 M free memory
                                    0 M buffer memory
                                  219 M swap cache
                                 1024 M total swap
                                    0 M used swap
                                 1024 M free swap
                        top - 20:08:01 up 5 min,  1 user,  load average: 0.04, 0.17, 0.16
                        Tasks:  25 total,   1 running,  24 sleeping,   0 stopped,   0 zombie
                        MiB Mem :   2048.0 total,   1555.1 free,    273.6 used,    219.4 buff/cache
                        MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   1774.4 avail Mem
                        2 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/mapper/pve-vm--106--disk--0 ext4      7.8G  2.1G  5.3G  29% /
                        udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
                        tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                        tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
                        /      /dev/mapper/pve-vm--106--disk--0 ext4   rw,relatime,stripe=16
                        /var:
                        400M    /var/
                        237M    /var/cache
                        234M    /var/cache/apt
                        158M    /var/cache/apt/archives
                        146M    /var/lib
                        Archived and active journals take up 16.0M in the file system.
                        4.0K    /opt/iobroker/backups/
                        62M     /opt/iobroker/iobroker-data/
                        57M     /opt/iobroker/iobroker-data/files
                        31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                        8.4M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.70cad8ba.js
                        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                        5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                        5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
                        5.0M    /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                                500 http://security.debian.org bookworm-security/main amd64 Packages
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        testsystem          testsystem (version: 6.0.11, hostname: testsystem    , alive, uptime: 316)
                        admin:          7.0.23
                        javascript:     "javascript" not found
                        nodejs modules from github:     0
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : testsystem                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.backitup.0               : backitup              : testsystem                               -  enabled
                        + system.adapter.discovery.0              : discovery             : testsystem                               -  enabled
                        + instance is alive
                        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                        Objects and States
                        Objects:        148
                        States:         103
                        Hit:1 http://security.debian.org bookworm-security InRelease
                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       80745598   155/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       80745603   155/iobroker.js-con
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          80743343   319/master
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          80742867   1/init
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       80751205   436/io.admin.0
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          80743344   319/master
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          80742219   1/init
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          80742869   1/init
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          80742305   95/dhclient
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          80742868   1/init
                        udp6       0      0 :::111                  :::*                                0          80742870   1/init
                        2024-09-08 18:02:43.093  - info: backitup.0 (371) starting. Version 3.0.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                        2024-09-08 18:02:43.111  - info: backitup.0 (371) [iobroker] backup will be activated at 02:48 every 1 day(s)
                        2024-09-08 18:02:46.482  - info: host.testsystem instance system.adapter.discovery.0 in version "4.5.0" started with pid 386
                        2024-09-08 18:02:47.002  - info: discovery.0 (386) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                        2024-09-08 18:03:34.073  - info: admin.0 (330) ==> Connected system.user.admin from ::ffff:192.168.178.12
                        2024-09-08 18:04:30.739  - info: host.testsystem stopInstance system.adapter.admin.0 (force=false, process=true)
                        2024-09-08 18:04:30.741  - info: admin.0 (330) Got terminate signal TERMINATE_YOURSELF
                        2024-09-08 18:04:30.741  - info: admin.0 (330) terminating http server on port 8081
                        2024-09-08 18:04:30.743  - info: admin.0 (330) terminating
                        2024-09-08 18:04:30.743  - info: admin.0 (330) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-09-08 18:04:30.781  - info: host.testsystem stopInstance system.adapter.admin.0 send kill signal
                        2024-09-08 18:04:31.244  - info: admin.0 (330) terminating
                        2024-09-08 18:04:31.281  - info: host.testsystem instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-09-08 18:04:34.403  - info: host.testsystem instance system.adapter.admin.0 in version "7.0.23" started with pid 436
                        2024-09-08 18:04:35.068  - info: admin.0 (436) starting. Version 7.0.23 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                        2024-09-08 18:04:35.079  - info: admin.0 (436) requesting all objects
                        2024-09-08 18:04:35.285  - info: admin.0 (436) received all objects
                        2024-09-08 18:04:35.382  - info: admin.0 (436) socket.io server listening on port 8081
                        2024-09-08 18:04:35.383  - info: admin.0 (436) http server listening on port 8081
                        2024-09-08 18:04:35.383  - info: admin.0 (436) Use link "http://127.0.0.1:8081" to configure.
                        2024-09-08 18:04:37.576  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
                        2024-09-08 18:04:37.615  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
                        2024-09-08 18:04:37.645  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
                        2024-09-08 18:04:45.342  - info: admin.0 (436) ==> Connected system.user.admin from ::ffff:192.168.178.12
                        2024-09-08 18:04:57.657  - info: admin.0 (436) <== Disconnect system.user.admin from ::ffff:192.168.178.12 admin
                        iob diag has finished.
                        Gruß Tom
                        Public Transport
                        • T TT-Tom
                          @Thomas-Braun
                          root
                          HOME=/root
                          GROUPS=root
                          #658
                          @tt-tom
                          Den
                          kann ich mir gerade nicht so wirklich erklären. Zumal es bei @Meister-Mopper alles wie gedacht funktioniert...
                          • T TT-Tom
                            @tt-tom
                            @Thomas-Braun
                            ```bash
                            Script v.2024-09-07
                            *** BASE SYSTEM ***
                              Virtualization: lxc
                                              │ Time zone:                                                         │
                                              │                           Amsterdam       -                        │
                                              │                           Andorra         ▒                        │
                                              │                           Astrakhan       0                        │
                                              │                           Athens          ▒                        │
                                              │                           Belfast         ▒                        │
                                              │                           Belgrade        ▒                        │
                                              │                           Berlin          ▒                        │
                                              │                           Bratislava      ▒                        │
                                              │                           Brussels        ▒                        │
                                              │                           Bucharest       ▒                        │
                                              │                           Budapest        ▒                        │
                                              │                           Busingen        .                        │
                                              │                 <Ok>                     <Cancel>                  │
                            root
                            HOME=/root
                            GROUPS=root
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                            Swap:           1.1G          0B        1.1G
                                     2048 M total memory
                                      271 M used memory
                                      399 M active memory
                                     1557 M free memory
                                        0 M buffer memory
                                      219 M swap cache
                                     1024 M total swap
                                        0 M used swap
                                     1024 M free swap
                            *** FILESYSTEM ***
                            /var:
                            400M    /var/
                            237M    /var/cache
                            234M    /var/cache/apt
                            146M    /var/lib
                            USB-Devices by-id:
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.0.23
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        148
                            States:         103
                            Pending Updates: 0
                            #659
                            Also mit vorheriger Installation des ioBroker funktioniert es?
                              TT-Tom
                              #660
                              ja mit iobroker ist alles sauber durchgelaufen.
                              Gruß Tom
                              Public Transport
                              • T TT-Tom
                                #661
                                Na dann....
                                Das Skript kommt ja im Normalfall auch erst mit dem ioBroker auf das System.
                                  @tt-tom
                                  Den
                                  TT-Tom
                                  #662
                                  Den
                                  der User konnte ja nicht der Gruppe iobroker zugeordnet werden.
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    Den
                                    #663
                                    Das sollte aber nicht der Grund für die Meldung sein.
                                    Wie dem auch sei, das Skript ruft man ja in der Realität nur bei vorhandener Installation des ioBrokers auf.
                                      Knirpso
                                      schrieb am zuletzt editiert von Knirpso
                                      #664
                                      Anbei noch der gewünschte Log aus https://forum.iobroker.net/topic/76922/schaltverhalten-iot-adapter-mit-alexa/4
                                      Script v.2024-09-16
                                      *** BASE SYSTEM ***
                                      Hardware Vendor : Synology Inc.
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      Docker          : v9.1.2
                                      Virtualization  : Docker
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                       17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
                                      CPU threads: 8
                                      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                      Tue Sep 17 15:25:15 UTC 2024
                                      Tue Sep 17 17:25:15 CEST 2024
                                      CEST +0200
                                      Etc/UTC
                                      root
                                      HOME=/root
                                      GROUPS=root
                                      iobroker
                                      HOME=/opt/iobroker
                                      Display-Server: true
                                      Desktop:
                                      Terminal:
                                      *** MEMORY ***
                                      Mem:             67G        7.4G        1.0G        215M         59G         59G
                                      Swap:            42G        307M         42G
                                      Total:          109G        7.7G         43G
                                      Active iob-Instances:   17
                                              64084 M total memory
                                               7067 M used memory
                                               7965 M active memory
                                              52969 M inactive memory
                                                971 M free memory
                                                 84 M buffer memory
                                              56764 M swap cache
                                              40499 M total swap
                                                293 M used swap
                                              40206 M free swap
                                      top - 17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
                                      Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
                                      MiB Mem :  64084.8 total,    969.7 free,   7068.6 used,  56848.9 buff/cache
                                      MiB Swap:  40499.9 total,  40206.6 free,    293.3 used.  57016.2 avail Mem
                                      *** FILESYSTEM ***
                                      /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /
                                      tmpfs          tmpfs   64M     0   64M   0% /dev
                                      tmpfs          tmpfs   32G     0   32G   0% /sys/fs/cgroup
                                      shm            tmpfs   64M     0   64M   0% /dev/shm
                                      /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /opt/iobroker
                                      /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /etc/hosts
                                      tmpfs          tmpfs   32G     0   32G   0% /proc/acpi
                                      tmpfs          tmpfs   32G     0   32G   0% /proc/scsi
                                      tmpfs          tmpfs   32G     0   32G   0% /sys/firmware
                                      /                  /dev/synorbd_1[/@syno/@docker/btrfs/subvolumes/43c485044ed9f1e230e9f082f08e839ece82e19c0db5e0e02d5f344f954dfa66]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                      |-/opt/iobroker    /dev/synorbd_1[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                      |-/etc/resolv.conf /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                      |-/etc/hostname    /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                      `-/etc/hosts       /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                      /var:
                                      34M     /var/
                                      32M     /var/lib
                                      19M     /var/lib/apt/lists
                                      19M     /var/lib/apt
                                      13M     /var/lib/dpkg
                                      33M     /opt/iobroker/backups/
                                      1.1G    /opt/iobroker/iobroker-data/
                                      756M    /opt/iobroker/iobroker-data/files
                                      441M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                      117M    /opt/iobroker/iobroker-data/states.jsonl
                                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                                      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
                                      USB-Devices by-id:
                                      HINT:
                                      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      /dev/ttyACM0
                                      HINT:
                                      Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      /dev/ttyACM0
                                      /usr/bin/nodejs         v18.20.4
                                      /usr/bin/node           v18.20.4
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      /usr/bin/corepack       0.28.0
                                      nodejs:
                                        Installed: 18.20.4-1nodesource1
                                        Candidate: 18.20.4-1nodesource1
                                        Version table:
                                       *** 18.20.4-1nodesource1 1001
                                             1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                           18.20.3-1nodesource1 1001
                                           18.20.2-1nodesource1 1001
                                           18.20.1-1nodesource1 1001
                                           18.20.0-1nodesource1 1001
                                           18.19.1-1nodesource1 1001
                                              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                                           18.19.0-1nodesource1 1001
                                           18.18.2-1nodesource1 1001
                                           18.18.1-1nodesource1 1001
                                           18.18.0-1nodesource1 1001
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1308286)
                                      slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 268408)
                                      admin:          7.0.23
                                      javascript:     8.7.6
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                      + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                                      + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                      + system.adapter.mystrom.0                : mystrom               : iobroker                                 -  enabled
                                      + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                                      + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
                                        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                                      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                      + system.adapter.zigbee.1                 : zigbee                : slave1-raspberrypi                       -  enabled, port: /dev/ttyACM0
                                      + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                                      + instance is alive
                                      │ (index) │   name   │                           url                           │ auto upgrade │
                                      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                                      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                      Adapter    "roborock"     : 0.6.4    , installed 0.6.4
                                      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                                      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                                      Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
                                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                      Objects and States
                                      Objects:        3786
                                      States:         2647
                                      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Pending Updates: 26
                                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3946312486 -
                                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3946312479 -
                                      tcp        0      0 127.0.0.11:42340        0.0.0.0:*               LISTEN      0          3946306647 -
                                      tcp6       0      0 :::6824                 :::*                    LISTEN      1000       78218444   -
                                      tcp6       0      0 :::8554                 :::*                    LISTEN      1000       78220248   -
                                      tcp6       0      0 :::8555                 :::*                    LISTEN      1000       78220249   -
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3946310901 -
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3946317922 -
                                      tcp6       0      0 :::8083                 :::*                    LISTEN      1000       3946324298 -
                                      tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3946324745 -
                                      tcp6       0      0 :::1984                 :::*                    LISTEN      1000       78243001   -
                                      tcp6       0      0 :::7906                 :::*                    LISTEN      1000       78218445   -
                                      udp        0      0 127.0.0.11:56032        0.0.0.0:*                           0          3946306646 -
                                      udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1000       38730773   -
                                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       3946311323 -
                                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       3946311324 -
                                      2024-09-17 17:01:23.903  - error: mystrom.0 (386) 200
                                      2024-09-17 17:01:23.903  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
                                      2024-09-17 17:01:23.903  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                      2024-09-17 17:01:23.904  - info: mystrom.0 (386) Set update interval for FCF5C418FF54 to 60
                                      2024-09-17 17:01:23.920  - info: mystrom.0 (386) Set update interval for FCF5C418FB0C to 60
                                      2024-09-17 17:01:23.922  - error: mystrom.0 (386) 200
                                      2024-09-17 17:01:23.922  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
                                      2024-09-17 17:01:23.922  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                      2024-09-17 17:01:23.923  - error: mystrom.0 (386) 200
                                      2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
                                      2024-09-17 17:01:23.924  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                      2024-09-17 17:01:23.924  - error: mystrom.0 (386) 200
                                      2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
                                      2024-09-17 17:01:23.930  - error: mystrom.0 (386) 200
                                      2024-09-17 17:01:23.930  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
                                      2024-09-17 17:01:23.930  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                      2024-09-17 17:01:23.936  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
                                      2024-09-17 17:01:23.937  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
                                      2024-09-17 17:01:23.941  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                      2024-09-17 17:01:23.942  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                      2024-09-17 17:01:23.962  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                      2024-09-17 17:01:23.966  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                      2024-09-17 17:03:36.237  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                                      Edit: Log von Skriptversion 2024-09-16 angehängt.
                                      • K Knirpso
                                        Script v.2024-09-16
                                        *** BASE SYSTEM ***
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        Docker          : v9.1.2
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        CPU threads: 8
                                        CEST +0200
                                        Etc/UTC
                                        root
                                        HOME=/root
                                        GROUPS=root
                                        iobroker
                                        HOME=/opt/iobroker
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Swap:            42G        307M         42G
                                                 7067 M used memory
                                                  971 M free memory
                                                   84 M buffer memory
                                                56764 M swap cache
                                                40499 M total swap
                                                  293 M used swap
                                                40206 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        34M     /var/
                                        32M     /var/lib
                                        19M     /var/lib/apt
                                        13M     /var/lib/dpkg
                                        USB-Devices by-id:
                                        HINT:
                                        /dev/ttyACM0
                                        HINT:
                                        /dev/ttyACM0
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        admin:          7.0.23
                                        javascript:     8.7.6
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        3786
                                        States:         2647
                                        Pending Updates: 26
                                        #665
                                        @knirpso Bitte die aktuelle Version 2024-09-16 verwenden.
                                        • K Knirpso
                                          Script v.2024-09-16
                                          *** BASE SYSTEM ***
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          Docker          : v9.1.2
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          CPU threads: 8
                                          CEST +0200
                                          Etc/UTC
                                          root
                                          HOME=/root
                                          GROUPS=root
                                          iobroker
                                          HOME=/opt/iobroker
                                          Desktop:
                                          Terminal:
                                          *** MEMORY ***
                                          Swap:            42G        307M         42G
                                                   7067 M used memory
                                                    971 M free memory
                                                     84 M buffer memory
                                                  56764 M swap cache
                                                  40499 M total swap
                                                    293 M used swap
                                                  40206 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          34M     /var/
                                          32M     /var/lib
                                          19M     /var/lib/apt
                                          13M     /var/lib/dpkg
                                          USB-Devices by-id:
                                          HINT:
                                          /dev/ttyACM0
                                          HINT:
                                          /dev/ttyACM0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.0.23
                                          javascript:     8.7.6
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        3786
                                          States:         2647
                                          Pending Updates: 26
                                          #666
                                          @knirpso
                                          Hm. Kannst du mal die Ausgabe von
                                          pgrep -l '[X]|[w]ayland|X11|wayfire'
                                          posten?
                                          Oder auch die anderen Dockeristen.
