  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.9k Aufrufe 40 Beobachtet
  • K Knirpso
    Anbei noch der gewünschte Log aus https://forum.iobroker.net/topic/76922/schaltverhalten-iot-adapter-mit-alexa/4
    Script v.2024-09-16
    *** BASE SYSTEM ***
    Hardware Vendor : Synology Inc.
    Kernel          : x86_64
    Userland        : 64 bit
    Docker          : v9.1.2
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
    Tue Sep 17 15:25:15 UTC 2024
    Tue Sep 17 17:25:15 CEST 2024
    CEST +0200
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             67G        7.4G        1.0G        215M         59G         59G
    Swap:            42G        307M         42G
    Total:          109G        7.7G         43G
    Active iob-Instances:   17
            64084 M total memory
             7067 M used memory
             7965 M active memory
            52969 M inactive memory
              971 M free memory
               84 M buffer memory
            56764 M swap cache
            40499 M total swap
              293 M used swap
            40206 M free swap
    top - 17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
    Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  64084.8 total,    969.7 free,   7068.6 used,  56848.9 buff/cache
    MiB Swap:  40499.9 total,  40206.6 free,    293.3 used.  57016.2 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /
    tmpfs          tmpfs   64M     0   64M   0% /dev
    tmpfs          tmpfs   32G     0   32G   0% /sys/fs/cgroup
    shm            tmpfs   64M     0   64M   0% /dev/shm
    /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /opt/iobroker
    /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /etc/hosts
    tmpfs          tmpfs   32G     0   32G   0% /proc/acpi
    tmpfs          tmpfs   32G     0   32G   0% /proc/scsi
    tmpfs          tmpfs   32G     0   32G   0% /sys/firmware
    Show mounted filesystems:
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  /dev/synorbd_1[/@syno/@docker/btrfs/subvolumes/43c485044ed9f1e230e9f082f08e839ece82e19c0db5e0e02d5f344f954dfa66]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
    |-/opt/iobroker    /dev/synorbd_1[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
    |-/etc/resolv.conf /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
    |-/etc/hostname    /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
    `-/etc/hosts       /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
    /var:
    34M     /var/
    32M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    33M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    756M    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    117M    /opt/iobroker/iobroker-data/states.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.4-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
     *** 18.20.4-1nodesource1 1001
           1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.3-1nodesource1 1001
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1308286)
    slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 268408)
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.0.23
    javascript:     8.7.6
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mystrom.0                : mystrom               : iobroker                                 -  enabled
    + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
    + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.1                 : zigbee                : slave1-raspberrypi                       -  enabled, port: /dev/ttyACM0
    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "roborock"     : 0.6.4    , installed 0.6.4
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
    Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        3786
    States:         2647
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 26
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3946312486 -
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3946312479 -
    tcp        0      0 127.0.0.11:42340        0.0.0.0:*               LISTEN      0          3946306647 -
    tcp6       0      0 :::6824                 :::*                    LISTEN      1000       78218444   -
    tcp6       0      0 :::8554                 :::*                    LISTEN      1000       78220248   -
    tcp6       0      0 :::8555                 :::*                    LISTEN      1000       78220249   -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3946310901 -
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3946317922 -
    tcp6       0      0 :::8083                 :::*                    LISTEN      1000       3946324298 -
    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3946324745 -
    tcp6       0      0 :::1984                 :::*                    LISTEN      1000       78243001   -
    tcp6       0      0 :::7906                 :::*                    LISTEN      1000       78218445   -
    udp        0      0 127.0.0.11:56032        0.0.0.0:*                           0          3946306646 -
    udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1000       38730773   -
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       3946311323 -
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       3946311324 -
    2024-09-17 17:01:23.903  - error: mystrom.0 (386) 200
    2024-09-17 17:01:23.903  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
    2024-09-17 17:01:23.903  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
    2024-09-17 17:01:23.904  - info: mystrom.0 (386) Set update interval for FCF5C418FF54 to 60
    2024-09-17 17:01:23.920  - info: mystrom.0 (386) Set update interval for FCF5C418FB0C to 60
    2024-09-17 17:01:23.922  - error: mystrom.0 (386) 200
    2024-09-17 17:01:23.922  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
    2024-09-17 17:01:23.922  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
    2024-09-17 17:01:23.923  - error: mystrom.0 (386) 200
    2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
    2024-09-17 17:01:23.924  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
    2024-09-17 17:01:23.924  - error: mystrom.0 (386) 200
    2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
    2024-09-17 17:01:23.930  - error: mystrom.0 (386) 200
    2024-09-17 17:01:23.930  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
    2024-09-17 17:01:23.930  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
    2024-09-17 17:01:23.936  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
    2024-09-17 17:01:23.937  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
    2024-09-17 17:01:23.941  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
    2024-09-17 17:01:23.942  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
    2024-09-17 17:01:23.962  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
    2024-09-17 17:01:23.966  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
    2024-09-17 17:03:36.237  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
    Edit: Log von Skriptversion 2024-09-16 angehängt.
    #665
    @knirpso Bitte die aktuelle Version 2024-09-16 verwenden.
    • K Knirpso
      Script v.2024-09-16
      *** BASE SYSTEM ***
      Kernel          : x86_64
      Userland        : 64 bit
      Docker          : v9.1.2
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 8
      CEST +0200
      Etc/UTC
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/opt/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:            42G        307M         42G
               7067 M used memory
                971 M free memory
                 84 M buffer memory
              56764 M swap cache
              40499 M total swap
                293 M used swap
              40206 M free swap
      *** FILESYSTEM ***
      /var:
      34M     /var/
      32M     /var/lib
      19M     /var/lib/apt
      13M     /var/lib/dpkg
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      HINT:
      /dev/ttyACM0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.0.23
      javascript:     8.7.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        3786
      States:         2647
      Pending Updates: 26
      #666
      @knirpso
      Hm. Kannst du mal die Ausgabe von
      pgrep -l '[X]|[w]ayland|X11|wayfire'
      posten?
      Oder auch die anderen Dockeristen.
        @knirpso
        posten?
        Knirpso
        #667
        root@iobroker:/opt/iobroker# pgrep -l '[X]|[w]ayland|X11|wayfire'
        pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
        Try `pgrep -f' option to match against the complete command line.
        • K Knirpso
          #668
          @knirpso sagte in iob diag - Skript:
          pgrep -lf '[X]|[w]ayland|X11|wayfire'
            Knirpso
            schrieb am zuletzt editiert von Knirpso
            #669
            root@iobroker:/opt/iobroker# pgrep -lf '[X]|[w]ayland|X11|wayfire'
            1966 go2rtc_linux_am
            root@pihole:/# pgrep -lf '[X]|[w]ayland|X11|wayfire'
            root@pihole:/#
            Mehr hab ich nicht
            • K Knirpso
              root@pihole:/#
              Mehr hab ich nicht
              #670
              @knirpso
              Danke, Grund für den 'flase positive' gefunden.
              • K Knirpso
                root@pihole:/#
                Mehr hab ich nicht
                #671
                @knirpso
                Zieh bitte die aktuelle Version nochmal.
                  @knirpso
                  Knirpso
                  #672
                  Script v.2024-09-17
                  *** BASE SYSTEM ***
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Docker          : v9.1.2
                  Kernel          : x86_64
                  Userland        : 64 bit
                   18:05:31 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
                  CPU threads: 8
                  Wed Sep 18 16:05:31 UTC 2024
                  Wed Sep 18 18:05:31 CEST 2024
                  CEST +0200
                  Etc/UTC
                  root
                  HOME=/root
                  GROUPS=root
                  iobroker
                  HOME=/opt/iobroker
                  Display-Server: false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:             67G        7.5G        849M        216M         59G         59G
                  Swap:            42G        305M         42G
                  Total:          109G        7.8G         43G
                  Active iob-Instances:   16
                           7174 M used memory
                           8048 M active memory
                          53007 M inactive memory
                            810 M free memory
                             84 M buffer memory
                          56817 M swap cache
                          40499 M total swap
                            290 M used swap
                          40209 M free swap
                  top - 18:05:32 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
                  Tasks:  34 total,   2 running,  32 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :  64084.8 total,    809.2 free,   7175.6 used,  56902.5 buff/cache
                  MiB Swap:  40499.9 total,  40209.0 free,    290.9 used.  56909.1 avail Mem
                  *** FILESYSTEM ***
                  /var:
                  34M     /var/
                  32M     /var/lib
                  19M     /var/lib/apt
                  13M     /var/lib/dpkg
                  40M     /opt/iobroker/backups/
                  1017M   /opt/iobroker/iobroker-data/
                  20M     /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyACM0
                  HINT:
                  /dev/ttyACM0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1397104)
                  slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 357226)
                  admin:          7.0.23
                  javascript:     8.7.6
                  Adapter State
                    system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                  + instance is alive
                  Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
                  Objects and States
                  Objects:        3786
                  States:         2638
                  Pending Updates: 28
                  2024-09-18 18:01:23.039  - error: mystrom.0 (386) 200
                  2024-09-18 18:01:23.039  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
                  2024-09-18 18:01:23.039  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                  2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
                  2024-09-18 18:01:23.040  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                  2024-09-18 18:01:23.040  - error: mystrom.0 (386) 200
                  2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
                  2024-09-18 18:01:23.046  - error: mystrom.0 (386) 200
                  2024-09-18 18:01:23.046  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
                  2024-09-18 18:01:23.046  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                  2024-09-18 18:01:23.048  - error: mystrom.0 (386) 200
                  2024-09-18 18:01:23.048  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
                  2024-09-18 18:01:23.048  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                  2024-09-18 18:01:23.051  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                  2024-09-18 18:01:23.052  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                  2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
                  2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
                  2024-09-18 18:01:23.062  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                  2024-09-18 18:01:23.068  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                  2024-09-18 18:01:23.075  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                  2024-09-18 18:05:46.619  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                  2024-09-18 18:05:49.032  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                  2024-09-18 18:05:49.037  - info: admin.0 (157) <== Disconnect system.user.admin from ::ffff:192.168.212.23 iot
                  • S Abwesend
                    S Abwesend
                    Shadowhunter23
                    schrieb am zuletzt editiert von Shadowhunter23
                    #673
                    Script v.2024-09-17
                    *** BASE SYSTEM ***
                     Static hostname: iobroker
                           Icon name: computer-container
                             Chassis: container ☐
                      Virtualization: lxc
                              Kernel: Linux 6.8.12-1-pve
                        Architecture: x86-64
                    OS is similar to:
                    model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                    Docker          : false
                    Virtualization  : lxc
                    Kernel          : x86_64
                    Userland        : 64 bit
                     18:19:46 up 4 days,  6:33,  1 user,  load average: 0.12, 0.12, 0.10
                    CPU threads: 4
                    Operating System is the current Debian stable version codenamed 'bookworm'!
                                   Local time: Wed 2024-09-18 18:19:46 CEST
                               Universal time: Wed 2024-09-18 16:19:46 UTC
                                     RTC time: n/a
                                  NTP service: n/a
                              RTC in local TZ: no
                    tobias
                    HOME=/home/tobias
                    GROUPS=tobias sudo users iobroker
                    iobroker
                    HOME=/home/iobroker
                    GROUPS=iobroker tty dialout audio video plugdev redis
                    Desktop:
                    Terminal:       tty
                    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Do you want to switch to 'multi-user.target'? (y/n)
                    @Thomas-Braun
                    Kannst du mir diese Frage erklären? Was ändert sich wenn ich mit y weiter mache?
                    edit
                    Ist ein LXC unter Proxmox.
                    Noch ein edit
                    Google hilft:
                    multi-user.target -> The multiuser target in Linux is a Command Line Interface and it's like a mode where multiple people can use the computer at the same time. It's perfect for situations where several users need to log in and do their own stuff on the computer simultaneously. So, when your system is in the multiuser target, it's ready for several users to work on it together.
                    graphical.target -> The multiuser target in Linux is a Graphical User Interface and it's like a mode where multiple people can use the computer at the same time. It's perfect for situations where several users need to log in and do their own stuff on the computer simultaneously. So, when your system is in the multiuser target, it's ready for several users to work on it together.
                    Steht das jetzt nicht im Gegensatz zu Display-Server: false?
                    Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                    ioBroker Backup Analyzer
                    • S Shadowhunter23
                      Script v.2024-09-17
                      *** BASE SYSTEM ***
                        Virtualization: lxc
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                      CPU threads: 4
                                       RTC time: n/a
                                    NTP service: n/a
                                RTC in local TZ: no
                      tobias
                      HOME=/home/tobias
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      @Thomas-Braun
                      edit
                      Noch ein edit
                      Google hilft:
                      #674
                      @shadowhunter23 sagte in iob diag - Skript:
                      Nein, das boot.target ist unabhängig davon ob da wirklich ein Display-Server installiert ist und gestartet werden kann.
                      Das boot.target auf einem Server sollte aber dennoch multi-user sein. Deswegen der Vorschlag das so einzurichten.
                      S Thomas BraunT 2 Antworten Letzte Antwort
                        S Abwesend
                        S Abwesend
                        Shadowhunter23
                        #675
                        Danke, hab's umgestellt und muss das aufnehmen in meine Neuinstallation Routine.
                          #676
                          An die Tester:
                          Es darf wieder getestet werden!
                          Bitte mal die TEST-Version (siehe erster Eintrag) unter die Äuglein nehmen.
                          (Nicht von der Benennung als raspbian irritieren lassen, das sollte auf allen Systemen laufen).
                          • Neue Sektion *** ZigBee Settings ***
                            Wenn eine Instanz des zigbee-Adapters gefunden wird erscheint diese neue Sektion:
                          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          • Neue Option --unmask beim Aufruf des Skripts lüftet dann die Maske und die entsprechenden Werte erscheinen im Klartext und können dann in den Einstellungen des zigbee-Adapters eingetragen werden.
                          Bitte mal schauen ob das alles wie gedacht funktioniert, insbesondere Installationen mit mehr als einer Instanz oder per tcp angebunden wären interressant zu sehen.
                          Danke schön!
                          L 1 Antwort Letzte Antwort
                          • NashraN Offline
                            NashraN Offline
                            Nashra
                            Most Active Forum Testing
                            schrieb am zuletzt editiert von Nashra
                            #677
                            @Thomas-Braun
                            Proxmox lxc
                            ```bash
                            Script v.2024-12-08 Raspbian+zigbee diag+masking
                            *** BASE SYSTEM ***
                             Static hostname: ioBroker
                              Virtualization: lxc
                                      Kernel: Linux 6.8.12-4-pve
                            OS is similar to:
                            model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             09:19:11 up 16 days, 22:59,  1 user,  load average: 1.12, 1.17, 1.11
                            CPU threads: 4
                            Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
                                           Local time: Mon 2024-12-09 09:19:11 CET
                                       Universal time: Mon 2024-12-09 08:19:11 UTC
                                             RTC time: n/a
                                          NTP service: inactive
                                      RTC in local TZ: no
                            jack
                            HOME=/home/jack
                            GROUPS=jack sudo iobroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:
                            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                            *** MEMORY ***
                            Mem:             12G        4.9G        6.8G        131K        1.1G        8.0G
                            Swap:             0B          0B          0B
                            Total:           12G        4.9G        6.8G
                            Active iob-Instances:   47
                                    12288 M total memory
                                     4686 M used memory
                                     3030 M active memory
                                     2479 M inactive memory
                                     6506 M free memory
                                        0 M buffer memory
                                     1094 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            top - 09:19:11 up 16 days, 22:59,  1 user,  load average: 1.12, 1.17, 1.11
                            Tasks:  75 total,   1 running,  74 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 50.0 us, 50.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :  12288.0 total,   6505.2 free,   4688.0 used,   1094.9 buff/cache
                            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7600.0 avail Mem
                            *** FAILED SERVICES ***
                              UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
                            * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
                            * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
                            * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                            3 loaded units listed.
                            dmesg: read kernel buffer failed: Operation not permitted
                            *** FILESYSTEM ***
                            /dev/mapper/pve-vm--100--disk--0 ext4       20G   15G  3.7G  81% /
                            none                             tmpfs     492K  4.0K  488K   1% /dev
                            udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                            tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                            tmpfs                            tmpfs     3.2G  120K  3.2G   1% /run
                            tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                            /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                            /var:
                            2.6G    /var/
                            2.1G    /var/log
                            2.0G    /var/log/journal/5cd6ef18c5fb4a33b292b16e63f26ce7
                            351M    /var/cache
                            Archived and active journals take up 95.6M in the file system.
                            1.3G    /opt/iobroker/backups/
                            2.6G    /opt/iobroker/iobroker-data/
                            1.7G    /opt/iobroker/iobroker-data/files
                            617M    /opt/iobroker/iobroker-data/files/javascript.admin
                            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            135M    /opt/iobroker/iobroker-data/states.jsonl
                            63M     /opt/iobroker/iobroker-data/objects.jsonl
                            33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
                            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                            USB-Devices by-id:
                            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
                            HINT:
                            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                            /dev/ttyUSB0
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/nodejs         v20.18.1
                            /usr/bin/node           v20.18.1
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.29.4
                            nodejs:
                              Installed: 20.18.1-1nodesource1
                              Candidate: 20.18.1-1nodesource1
                              Version table:
                             *** 20.18.1-1nodesource1 600
                                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                 20.18.0-1nodesource1 600
                                 20.17.0-1nodesource1 600
                                 20.16.0-1nodesource1 600
                                 20.15.1-1nodesource1 600
                                 20.15.0-1nodesource1 600
                                 20.14.0-1nodesource1 600
                                 20.13.1-1nodesource1 600
                                 20.13.0-1nodesource1 600
                                 20.12.2-1nodesource1 600
                                 20.12.1-1nodesource1 600
                                 20.12.0-1nodesource1 600
                                 20.11.1-1nodesource1 600
                                 20.11.0-1nodesource1 600
                                 20.10.0-1nodesource1 600
                                 20.9.0-1nodesource1 600
                                 20.8.1-1nodesource1 600
                                 20.8.0-1nodesource1 600
                                 20.7.0-1nodesource1 600
                                 20.6.1-1nodesource1 600
                                 20.6.0-1nodesource1 600
                                 20.5.1-1nodesource1 600
                                 20.5.0-1nodesource1 600
                                 20.4.0-1nodesource1 600
                                 20.3.1-1nodesource1 600
                                 20.3.0-1nodesource1 600
                                 20.2.0-1nodesource1 600
                                 20.1.0-1nodesource1 600
                                 20.0.0-1nodesource1 600
                                    500 http://security.debian.org bookworm-security/main amd64 Packages
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 954147)
                            js-controller:  7.0.3
                            admin:          7.1.5
                            javascript:     8.8.3
                            nodejs modules from github:     6
                            +-- iobroker.energiefluss-erweitert@0.5.1-alpha.11 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#ac743deb1d81e364ec7f0a9edd2f9da21329f5b6)
                            +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
                            +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
                            | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                            +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                            +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                            Adapter State
                              system.adapter.accuweather.0            : accuweather           : ioBroker                                 - disabled
                            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                              system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
                            + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                              system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                              system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
                              system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                              system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
                            + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
                              system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                            + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                            + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
                            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                              system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                              system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                            + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                              system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                              system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                              system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                              system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
                              system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                              system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
                            + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                            + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
                            + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                            + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                              system.adapter.labcom.0                 : labcom                : ioBroker                                 -  enabled
                            + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
                            + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
                            + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                            + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                              system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 - disabled
                              system.adapter.meteoalarm.1             : meteoalarm            : ioBroker                                 - disabled
                              system.adapter.meteoalarm.2             : meteoalarm            : ioBroker                                 - disabled
                              system.adapter.meteoalarm.3             : meteoalarm            : ioBroker                                 - disabled
                            + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                            + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
                            + system.adapter.nut.2                    : nut                   : ioBroker                                 -  enabled
                              system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                            + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
                              system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 - disabled
                              system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
                            + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                            + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                            + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
                            + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                            + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
                            + system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 -  enabled
                            + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                            + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
                              system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
                            + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
                            + system.adapter.synology.2               : synology              : ioBroker                                 -  enabled, port: 5000
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                            + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                            + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                            + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                            + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
                              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
                              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
                              system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
                              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
                            + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                              system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                              system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 - disabled
                              system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                              system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                              system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                              system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                              system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                            + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
                              system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
                              system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
                            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
                            + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
                            + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
                            + instance is alive
                            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                            │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                            │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                            Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                            Adapter    "admin"        : 7.1.5    , installed 7.1.5
                            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                            Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                            Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
                            Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                            Adapter    "deyeidc"      : 0.1.1    , installed 0.1.1
                            Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                            Adapter    "email"        : 1.3.1    , installed 1.3.1
                            Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.11
                            Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                            Adapter    "ical"         : 1.16.1   , installed 1.16.1
                            Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                            Controller "js-controller": 7.0.3    , installed 7.0.3
                            Adapter    "lgtv"         : 2.2.0    , installed 2.3.0
                            Adapter    "linux-control": 1.1.5    , installed 1.1.5
                            Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                            Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
                            Adapter    "nut"          : 1.6.0    , installed 1.6.0
                            Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                            Adapter    "pegelalarm"   : 1.3.5    , installed 1.3.5
                            Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                            Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                            Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                            Adapter    "rssfeed"      : 3.1.0    , installed 3.1.0
                            Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                            Adapter    "snmp"         : 3.2.0    , installed 3.2.0
                            Adapter    "synology"     : 3.1.0    , installed 3.1.0
                            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                            Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                            Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                            Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                            Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                            Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                            Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
                            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                            Adapter    "weather-warnings": 0.6.11, installed 0.6.11
                            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                            Adapter    "yr"           : 5.3.0    , installed 5.3.0
                            Objects and States
                            Objects:        55071
                            States:         51750
                            Hit:2 http://security.debian.org bookworm-security InRelease
                            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          28017      1140/master
                            tcp        0      0 192.168.1.14:8082       0.0.0.0:*               LISTEN      1001       60490678   4018371/io.web.0
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17497      1/init
                            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       60462657   4015570/iobroker.js
                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       60460940   4015570/iobroker.js
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       60475909   4017307/io.shelly.1
                            tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       171017909  3079198/nc
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          28018      1140/master
                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       60487396   4018286/io.simple-a
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       60493088   4018385/io.ws.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60462774   4015859/io.admin.0
                            tcp6       0      0 :::8093                 :::*                    LISTEN      1001       60487711   4017938/io.rest-api
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          17499      1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          16838      1/init
                            udp        0      0 0.0.0.0:50381           0.0.0.0:*                           1001       60470790   4016716/io.snmp.0
                            udp        0      0 0.0.0.0:58778           0.0.0.0:*                           1001       60491897   4018341/io.upnp.0
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       60494417   4018341/io.upnp.0
                            udp        0      0 0.0.0.0:46235           0.0.0.0:*                           1001       60470190   4016716/io.snmp.0
                            udp        0      0 192.168.1.14:5353       0.0.0.0:*                           1001       60474435   4016795/io.tr-064.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       60468082   4016698/io.shelly.0
                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       60474506   4016825/io.tuya.0
                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       60474507   4016825/io.tuya.0
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16795      90/dhclient
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17498      1/init
                            udp6       0      0 :::111                  :::*                                0          17500      1/init
                            2024-12-09 09:13:00.018  - info: host.ioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3075148
                            2024-12-09 09:13:01.656  - info: javascript.0 (4016006) script.js.Kalender.ICal-farben-Kalender: <table style='font-size:0.9em;'><tbody><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>15.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Dritter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>22.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Vierter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heiligabend (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Jack</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>25.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Erster Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>26.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Zweiter Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>31.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Silvester (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>01.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Neujahrstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>01.01.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Hühner</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>05.01.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Michael</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>06.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heilige Drei Könige (regionaler Feiertag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#0080c0'>01.02.</td><td style='font-size:1.1em; padding-left:5px;color:#0080c0'>Jubiläum 2002</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>14.02.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Valentinstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>14.02.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Anouk</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>17.02.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Manny & Sunny</td></tr></body></table>
                            2024-12-09 09:13:07.181  - info: host.ioBroker instance system.adapter.ical.0 having pid 3075148 terminated with code 0 (NO_ERROR)
                            2024-12-09 09:13:22.136  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                            2024-12-09 09:13:37.016  - info: host.ioBroker instance system.adapter.daswetter.1 in version "3.1.16" started with pid 3075580
                            2024-12-09 09:13:38.099  - info: daswetter.1 (3075580) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.3
                            2024-12-09 09:13:43.335  - info: daswetter.1 (3075580) still wrong data structure from server received! repaired...
                            2024-12-09 09:13:45.176  - info: daswetter.1 (3075580) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                            2024-12-09 09:13:45.680  - info: daswetter.1 (3075580) cleaned everything up...
                            2024-12-09 09:13:45.688  - info: host.ioBroker instance system.adapter.daswetter.1 having pid 3075580 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-12-09 09:13:45.689  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md-gitti: Material Design Widgets: Wetter Skript triggered by 'system.adapter.daswetter.1.alive'
                            2024-12-09 09:14:23.090  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                            2024-12-09 09:14:53.769  - info: javascript.0 (4016006) script.js.Ereignisse.Flurlicht: #### Flurlicht eingeschaltet
                            2024-12-09 09:15:00.035  - info: javascript.0 (4016006) script.js.Allerlei.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 2
                            2024-12-09 09:15:00.047  - info: javascript.0 (4016006) script.js.Allerlei.Shelly-Verbrauch-MQTT: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
                            2024-12-09 09:15:30.108  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                            2024-12-09 09:16:00.199  - info: javascript.0 (4016006) script.js.Netzwerk.IP-Adresse2: IP-Adresse (ausgelesen von http://ipecho.net/plain): 94.31.88.205
                            2024-12-09 09:16:34.100  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                            2024-12-09 09:16:58.013  - info: history.0 (4015915) Delete old history "/opt/iobroker/iobroker-data/history/20241130/history.deyeidc.0.3918369324.Apo_t1.json"
                            2024-12-09 09:17:38.264  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                            2024-12-09 09:18:36.343  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                            2024-12-09 09:18:53.020  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3079218
                            2024-12-09 09:18:54.021  - info: dwd.0 (3079218) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
                            2024-12-09 09:18:54.384  - info: dwd.0 (3079218) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-12-09 09:18:54.896  - info: host.ioBroker instance system.adapter.dwd.0 having pid 3079218 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               64 bit
                            Timezone:               Europe/Berlin (CET, +0100)
                            User-ID:                1000
                            Pending OS-Updates:     0
                            Pending iob updates:    0
                            Nodejs-Installation:
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            Recommended versions are nodejs 20.18.1 and npm 10.8.2
                            nodeJS installation is correct
                            MEMORY:
                            Mem:             12G        4.9G        6.9G        139K        1.2G        8.0G
                            Swap:             0B          0B          0B
                            Total:           12G        4.9G        6.9G
                            ioBroker Core:          js-controller           7.0.3
                                                    admin                   7.1.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                55071
                            States:                 51750
                            Size of iob-Database:
                            144M    /opt/iobroker/iobroker-data/states.jsonl
                            Gruß Ralf
                            • NashraN Nashra
                              @Thomas-Braun
                              Proxmox lxc
                              ```bash
                              *** BASE SYSTEM ***
                                Virtualization: lxc
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                                               RTC time: n/a
                                        RTC in local TZ: no
                              jack
                              HOME=/home/jack
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                              Swap:             0B          0B          0B
                                       4686 M used memory
                                       6506 M free memory
                                          0 M buffer memory
                                       1094 M swap cache
                                          0 M total swap
                                          0 M used swap
                                          0 M free swap
                              *** FILESYSTEM ***
                              /var:
                              2.6G    /var/
                              2.1G    /var/log
                              351M    /var/cache
                              USB-Devices by-id:
                              HINT:
                              /dev/ttyUSB0
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.1.5
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        55071
                              States:         51750
                              Pending Updates: 0
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               64 bit
                              User-ID:                1000
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              MEMORY:
                              Swap:             0B          0B          0B
                                                      admin                   7.1.5
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                55071
                              States:                 51750
                              #678
                              @nashra sagte in iob diag - Skript:
                              Danke.
                              Und
                              iob diag --unmask
                              deckt die Zigbee-Werte auf?
                                Danke.
                                Und
                                iob diag --unmask
                                NashraN Offline
                                NashraN Offline
                                Nashra
                                #679
                                @thomas-braun sagte in iob diag - Skript:
                                Danke.
                                Und
                                iob diag --unmask
                                Ja, werden angezeigt
                                Gruß Ralf
                                  An die Tester:
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  Danke schön!
                                  L Online
                                  L Online
                                  Lucky_ESA
                                  schrieb am zuletzt editiert von Lucky_ESA
                                  #680
                                  Command: pi@iobroker:~ $ ./iob_diag.sh -de | tee iob_diag.log
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                            Kernel: Linux 6.6.62+rpt-rpi-2712
                                      Architecture: arm64
                                  OS is similar to:
                                  Model           : Raspberry Pi 5 Model B Rev 1.0
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   10:21:35 up 18 min,  1 user,  load average: 0.42, 0.47, 0.56
                                  CPU threads: 4
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                                 Local time: Mon 2024-12-09 10:21:36 CET
                                             Universal time: Mon 2024-12-09 09:21:36 UTC
                                                   RTC time: Mon 2024-12-09 09:21:36
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  HOME=/home/pi
                                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            8.4G        4.2G        2.9G        5.7M        1.5G        4.2G
                                  Swap:           209M          0B        209M
                                  Total:          8.7G        4.2G        3.1G
                                  Active iob-Instances:   44
                                           8052 M total memory
                                           4025 M used memory
                                           3791 M active memory
                                           1094 M inactive memory
                                           2721 M free memory
                                            143 M buffer memory
                                           1263 M swap cache
                                            199 M total swap
                                              0 M used swap
                                            199 M free swap
                                  top - 10:21:36 up 18 min,  1 user,  load average: 0.42, 0.47, 0.56
                                  Tasks: 198 total,   1 running, 197 sleeping,   0 stopped,   0 zombie
                                  MiB Mem :   8052.2 total,   2720.8 free,   4026.7 used,   1407.1 buff/cache
                                  MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4025.6 avail Mem
                                  0 loaded units listed.
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  3.9G     0  3.9G   0% /dev
                                  tmpfs          tmpfs     806M  5.4M  800M   1% /run
                                  /dev/mmcblk0p2 ext4      117G   21G   91G  19% /
                                  tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                  tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                  /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
                                  tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                                  tmpfs          tmpfs     806M     0  806M   0% /run/user/0
                                  [Mon Dec  9 10:03:12 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=D8:3A:DD:99:6E:9A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=675ae9ae-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Mon Dec  9 10:04:31 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
                                  [Mon Dec  9 10:04:33 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
                                  /                /dev/mmcblk0p2 ext4   rw,noatime
                                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  3.0G    /var/
                                  2.2G    /var/log/journal/87fcd42a64fb499e969e09ffa538a8fe
                                  2.2G    /var/log
                                  409M    /var/cache
                                  Archived and active journals take up 2.1G in the file system.
                                  4.0K    /opt/iobroker/backups/
                                  2.0G    /opt/iobroker/iobroker-data/
                                  1.5G    /opt/iobroker/iobroker-data/files
                                  207M    /opt/iobroker/iobroker-data/files/0_userdata.0/ram/cpu
                                  73M     /opt/iobroker/iobroker-data/objects.jsonl
                                  41M     /opt/iobroker/iobroker-data/states.jsonl
                                  19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                                  19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                  USB-Devices by-id:
                                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                          500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                          500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1005)
                                  js-controller:  7.0.6
                                  admin:          7.4.4
                                  javascript:     8.8.3
                                  nodejs modules from github:     7
                                  +-- iobroker.e2-openwebif@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.e2-openwebif.git#aedac36b2975e02bdcdf0133cca24cd54483d339)
                                  +-- iobroker.fritzboxdect@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.fritzboxdect.git#6c0d80663cce795eff92460421f42a8d0b5d0fef)
                                  +-- iobroker.hiobs@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.hiobs.git#07971db72cce7a5a01169c120e32de199d313f09)
                                  +-- iobroker.netgear@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.netgear.git#fbe57dc2de2516d66e4d76d61df2021553d85cfe)
                                  +-- iobroker.philips-android-tv@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.philips-android-tv.git#1e9c610c86a9790d13efe3c212a2ed61cab57238)
                                  Adapter State
                                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                  + system.adapter.e2-openwebif.0           : e2-openwebif          : iobroker                                 -  enabled
                                  + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                    system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                  + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                                  + system.adapter.fritzboxdect.0           : fritzboxdect          : iobroker                                 -  enabled
                                  + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                    system.adapter.hiob.0                   : hiob                  : iobroker                                 - disabled, port: 8097
                                  + system.adapter.hiobs.0                  : hiobs                 : iobroker                                 -  enabled, port: 8095
                                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                  + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                  + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                                  + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
                                  + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                  + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                                  + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
                                  + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                                  + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
                                    system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
                                  + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.netgear.0                : netgear               : iobroker                                 -  enabled
                                  + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 90, 8088, 8999, 554
                                  + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                                  + system.adapter.philips-android-tv.0     : philips-android-tv    : iobroker                                 -  enabled
                                  + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                  + system.adapter.schedule-switcher.0      : schedule-switcher     : iobroker                                 -  enabled
                                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                    system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                                    system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                    system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                                    system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                  + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
                                    system.adapter.worx.0                   : worx                  : iobroker                                 - disabled
                                  + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
                                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
                                  + instance is alive
                                  Active repo(s): beta
                                  Used repository: beta
                                  Adapter    "admin"        : 7.4.4    , installed 7.4.4
                                  Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
                                  Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                  Adapter    "daswetter"    : 3.2.1    , installed 3.2.1
                                  Adapter    "email"        : 1.3.1    , installed 1.4.0
                                  Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                                  Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                  Adapter    "hiob"         : 0.1.6    , installed 0.1.6
                                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                  Adapter    "imap"         : 0.3.0    , installed 0.3.0
                                  Adapter    "iot"          : 3.4.4    , installed 3.4.4
                                  Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                                  Controller "js-controller": 7.0.6    , installed 7.0.6
                                  Adapter    "lg-thinq"     : 1.0.7    , installed 1.0.7
                                  Adapter    "lgtv"         : 2.3.1    , installed 2.3.1
                                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                  Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                                  Adapter    "parcel"       : 0.2.8    , installed 0.2.8
                                  Adapter    "rpi2"         : 2.2.2    , installed 2.2.2
                                  Adapter    "schedule-switcher": 0.0.8, installed 0.0.8
                                  Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                  Adapter    "trashschedule": 3.4.1    , installed 3.4.1
                                  Adapter    "vis-2"        : 2.11.1   , installed 2.11.1
                                  Adapter    "vis-icontwo"  : 1.10.1   , installed 1.10.1
                                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                  Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                                  Adapter    "web"          : 6.3.1    , installed 6.3.1
                                  Adapter    "worx"         : 3.1.1    , installed 3.1.1
                                  Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
                                  Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
                                  Objects and States
                                  Objects:        31186
                                  States:         26419
                                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8862       1412/io.mqtt.0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4073       804/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7559       1/init
                                  tcp        0      0 0.0.0.0:57413           0.0.0.0:*               LISTEN      103        7586       1194/rpc.statd
                                  tcp        0      0 192.168.2.66:9292       0.0.0.0:*               LISTEN      1001       8740       1313/io.hm-rpc.2
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6351       787/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6356       787/iobroker.js-con
                                  tcp        0      0 192.168.2.66:2010       0.0.0.0:*               LISTEN      1001       7747       1289/io.hm-rpc.0
                                  tcp        0      0 192.168.2.66:8701       0.0.0.0:*               LISTEN      1001       8743       1312/io.hm-rpc.1
                                  tcp6       0      0 :::49453                :::*                    LISTEN      103        7592       1194/rpc.statd
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          4075       804/sshd: /usr/sbin
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          6711       1/init
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10374      1589/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7300       898/io.admin.0
                                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10155      2288/io.simple-api.
                                  tcp6       0      0 :::8095                 :::*                    LISTEN      1001       11919      2539/io.hiobs.0
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6709       1/init
                                  udp        0      0 0.0.0.0:53647           0.0.0.0:*                           103        7583       1194/rpc.statd
                                  udp        0      0 127.0.0.1:946           0.0.0.0:*                           0          7578       1194/rpc.statd
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       13828      2604/io.philips-and
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4035       685/avahi-daemon: r
                                  udp        0      0 192.168.2.66:50593      0.0.0.0:*                           1001       8933       1556/io.yamaha.0
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       8934       1556/io.yamaha.0
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       9477       1470/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       9478       1470/io.tuya.0
                                  udp        0      0 0.0.0.0:35984           0.0.0.0:*                           104        4037       685/avahi-daemon: r
                                  udp6       0      0 :::111                  :::*                                0          6713       1/init
                                  udp6       0      0 :::33111                :::*                                104        4038       685/avahi-daemon: r
                                  udp6       0      0 fe80::eb3e:7926:d35:546 :::*                                0          7202       767/NetworkManager
                                  udp6       0      0 :::5353                 :::*                                104        4036       685/avahi-daemon: r
                                  udp6       0      0 :::35689                :::*                                103        7589       1194/rpc.statd
                                  2024-12-09 10:09:54.486  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz vis-inventwo.0 alive läuft wieder
                                  2024-12-09 10:09:54.910  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz wallpanel.0 alive läuft wieder
                                  2024-12-09 10:09:55.691  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz trashschedule.0 alive läuft wieder
                                  2024-12-09 10:09:57.759  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz text2command.0 alive läuft wieder
                                  2024-12-09 10:10:01.056  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz fritzboxdect.0 alive läuft wieder
                                  2024-12-09 10:10:04.984  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz hiobs.0 alive läuft wieder
                                  2024-12-09 10:10:10.318  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz parcel.0 alive läuft wieder
                                  2024-12-09 10:10:13.413  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz onvif.0 alive läuft wieder
                                  2024-12-09 10:10:18.722  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz philips-android-tv.0 alive läuft wieder
                                  2024-12-09 10:10:23.595  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz netgear.0 alive läuft wieder
                                  2024-12-09 10:10:27.121  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz schedule-switcher.0 alive läuft wieder
                                  2024-12-09 10:12:33.089  - info: admin.0 (898) ==> Connected system.user.admin from ::ffff:192.168.2.164
                                  2024-12-09 10:12:43.512  - info: admin.0 (898) <== Disconnect system.user.admin from ::ffff:192.168.2.164
                                  2024-12-09 10:12:50.519  - info: admin.0 (898) ==> Connected system.user.admin from ::ffff:192.168.2.164
                                  2024-12-09 10:15:42.021  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.1" started with pid 4970
                                  2024-12-09 10:15:43.390  - info: daswetter.0 (4970) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                  2024-12-09 10:15:52.637  - info: daswetter.0 (4970) still wrong data structure from server received! repaired...
                                  2024-12-09 10:15:54.956  - info: daswetter.0 (4970) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                  2024-12-09 10:15:55.467  - info: daswetter.0 (4970) cleaned everything up...
                                  2024-12-09 10:15:55.475  - info: host.iobroker instance system.adapter.daswetter.0 having pid 4970 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-12-09 10:17:08.952  - info: javascript.0 (942) script.js.Scripts.Thinq.Kühlschrank: Kühlschrank
                                  2024-12-09 10:17:08.964  - info: javascript.0 (942) script.js.Scripts.Thinq.Kühlschrank: Kühlschrank
                                  2024-12-09 10:17:47.309  - info: fritzboxdect.0 (2510) Check successfully!
                                         Icon name: computer
                                      Architecture: arm64
                                  Kernel:                 aarch64
                                  Userland:               64 bit
                                  User-ID:                1000
                                  Boot Target:            multi-user.target
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  MEMORY:
                                  Mem:            8.4G        4.1G        2.9G        5.7M        1.5G        4.3G
                                  Swap:           209M          0B        209M
                                  Total:          8.7G        4.1G        3.1G
                                  ioBroker Core:          js-controller           7.0.6
                                                          admin                   7.4.4
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                31186
                                  States:                 26288
                                  42M     /opt/iobroker/iobroker-data/states.jsonl
                                  Command: pi@iobroker:~ $ ./iob_diag.sh -de --unmask | tee iob_diag.log
                                  Zeigt alles an
                                  Edit: Zigbee Log mit SN entfernt
                                  Gruß//Lucky
                                    WIP: Übersetzung auf Deutsch in Arbeit. Wird aber nur teilweise möglich sein.
                                    Skript einfach mal mit der Option '--de' starten. Also ./iob_diag.sh --de
                                    TEST-Version:
                                    curl  https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/master/diag.sh > iob_diag.sh
                                    chmod 744 iob_diag.sh
                                    ./iob_diag.sh
                                    Weitere Optionen:
                                    ./iob_diag.sh --unmask           <--- Zeigt maskierte Ausgaben im Klartext
                                    ./iob_diag.sh --de               <--- Ausgabe tw. auf deutsch
                                    ./iob_diag.sh --de --unmask      <--- Kombination aus deutsch und Klartext
                                    Mit Ausgabe in eine Logdatei namens iob_diag.log sähe der Aufruf so aus:
                                    ./iob_diag.sh | tee iob_diag.log
                                    Vielleicht mag ja jemand mit Docker oder LXC das mal ausführen und den Output zeigen?
                                    Hier werden die üblichen Dinge relativ kompakt aufgelistet, die immer wieder bei Anfragen im Forum vermisst werden.
                                    Hier mal als ersten Einblick, vielleicht fällt ja noch etwas ein, was auch interessant zu wissen wäre, bevor man im Nebel stochert:
                                    *** ioBroker Diagnose ***
                                    Bitte das Fenster von puTTY breit ziehen oder auf Vollbild setzen
                                    Den nachfolgenden Output 1:1 in das ioBroker-Forum unter
                                    https://forum.iobroker.net
                                    vollständig posten ,inkl der jeweils drei Steuerzeichen ``` am Anfang und Ende:
                                    ===========Ab hier kopieren =========
                                    *** BASISSYSTEM ***
                                    CPU-Architektur: aarch64
                                    Docker: Nein
                                    No LSB modules are available.
                                    Distributor ID: Debian
                                    Description:    Debian GNU/Linux 11 (bullseye)
                                    Release:        11
                                    Codename:       bullseye
                                    *** Zeit und Zeitzonen ***
                                                   Local time: Tue 2022-11-01 16:53:39 CET
                                               Universal time: Tue 2022-11-01 15:53:39 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** ARBEITSSPEICHER ***
                                    Mem:           7.7Gi       2.3Gi       3.2Gi       0.0Ki       2.2Gi       5.2Gi
                                    Swap:           99Mi          0B        99Mi
                                    Total:         7.8Gi       2.3Gi       3.3Gi
                                    *** Nodejs-Installation ***
                                    /usr/bin/nodejs         v18.12.0
                                    /usr/bin/node           v18.12.0
                                    /usr/bin/npm            8.19.2
                                    js-controller:  4.0.23
                                    Updates + Repos:
                                    *** User und Gruppen ***
                                    echad
                                    /home/echad
                                    echad adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    *** Server-Setup ***
                                    Konsole: tty
                                    Desktop:
                                    *** Repositories und OS-Updates ***
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
                                    Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                                    Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:7 http://packages.azlux.fr/debian bullseye InRelease
                                    Hit:8 https://packages.grafana.com/oss/deb stable InRelease
                                    Hit:9 https://deb.nodesource.com/node_10.x bullseye InRelease
                                    Hit:10 https://repos.influxdata.com/debian bullseye InRelease
                                    Hit:11 https://deb.nodesource.com/node_12.x bullseye InRelease
                                    Hit:12 https://deb.nodesource.com/node_14.x bullseye InRelease
                                    Hit:13 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    Hit:14 https://packages.redis.io/deb bullseye InRelease
                                    Hit:15 https://deb.volian.org/volian scar InRelease
                                    Hit:16 https://deb.nodesource.com/node_18.x bullseye InRelease
                                    Hit:18 https://deb.nodesource.com/node_19.x bullseye InRelease
                                    Get:19 https://pkgs.tailscale.com/stable/debian bullseye InRelease
                                    Hit:17 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                    Fetched 5,545 B in 3s (1,694 B/s)
                                    All packages are up to date.
                                    nodejs:
                                      Installed: 18.12.0-deb-1nodesource1
                                      Candidate: 18.12.0-deb-1nodesource1
                                      Version table:
                                         19.0.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_19.x bullseye/main arm64 Packages
                                     *** 18.12.0-deb-1nodesource1 501
                                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                         16.18.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                         14.20.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                                         12.22.12-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_12.x bullseye/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u1 500
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                         12.22.5~dfsg-2~11u1 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                         10.24.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_10.x bullseye/main arm64 Packages
                                    ========== Bis hier kopieren ===========
                                    iob diag wurde beendet.
                                    Bitte nicht über den wilden Zoo an Repos wundern, das ist mein Test/Frickel-System, das soll so! :-D
                                    S Abwesend
                                    S Abwesend
                                    Shadowhunter23
                                    #681
                                    Bei mir im LXC mit 5 Zigbee Instanzen werden gleich alle Parameter von 4 Instanzen angezeigt. Meine Koordinatoren sind per TCP eingebunden. Kann / soll ich die Ausgabe zeigen oder muss ich das zensieren?
                                    curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
                                    ./iob_diag.sh
                                    • S Shadowhunter23
                                      ./iob_diag.sh
                                      #682
                                      @shadowhunter23
                                      Ja, 4 Instanzen sind im Moment das Limit.
                                      Es werden zigbee.0 bis zigbee.3 angezeigt.
                                      Ja, das würde ich gerne mal in Gänze sehen.
                                      Kannst ja die Schlüssel mit Platzhaltern/Phantasiewerten ersetzen.
                                        @shadowhunter23
                                        S Abwesend
                                        S Abwesend
                                        Shadowhunter23
                                        #683
                                        Leerzeichen bei zigbee.2 und .3 kamen so, ich hab jetzt nur meine Daten geändert:
                                        *** BASE SYSTEM ***
                                          Virtualization: lxc
                                        OS is similar to:
                                        model name      : Intel(R) Core(TM) i7-10700T CPU @ 2.00GHz
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         18:12:42 up 1 day, 23:11,  1 user,  load average: 0.06, 0.06, 0.08
                                        CPU threads: 6
                                        *** LIFE CYCLE STATUS ***
                                        *** TIME AND TIMEZONES ***
                                                       Local time: Mon 2024-12-09 18:12:42 CET
                                                   Universal time: Mon 2024-12-09 17:12:42 UTC
                                                         RTC time: n/a
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        tobias
                                        HOME=/home/tobias
                                        GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
                                        iobroker
                                        [sudo] password for tobias:
                                        HOME=/home/iobroker
                                        *** DISPLAY-SERVER SETUP ***
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:             10G        4.0G        5.3G        491K        1.4G        6.7G
                                        Swap:             0B          0B          0B
                                        Total:           10G        4.0G        5.3G
                                        Active iob-Instances:   49
                                                10240 M total memory
                                                 3825 M used memory
                                                 3730 M active memory
                                                 1121 M inactive memory
                                                 5083 M free memory
                                                    0 M buffer memory
                                                 1331 M swap cache
                                                    0 M total swap
                                                    0 M used swap
                                                    0 M free swap
                                        top - 18:12:55 up 1 day, 23:11,  1 user,  load average: 0.05, 0.06, 0.08
                                        Tasks:  78 total,   1 running,  77 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :  10240.0 total,   5082.5 free,   3826.9 used,   1331.1 buff/cache
                                        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6413.1 avail Mem
                                        1 loaded units listed.
                                        *** DMESG CRITICAL ERRORS ***
                                        No critical errors detected
                                        *** FILESYSTEM ***
                                        Filesystem                       Type      Size  Used Avail Use% Mounted on
                                        /dev/mapper/pve-vm--400--disk--0 ext4       20G  6.5G   13G  35% /
                                        udev                             devtmpfs   16G     0   16G   0% /dev/tty
                                        tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
                                        tmpfs                            tmpfs     6.3G  136K  6.3G   1% /run
                                        tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1000
                                        Show mounted filesystems:
                                        TARGET SOURCE                           FSTYPE OPTIONS
                                        /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
                                        /var:
                                        831M    /var/
                                        534M    /var/lib
                                        383M    /var/lib/redis
                                        226M    /var/cache
                                        222M    /var/cache/apt
                                        Archived and active journals take up 67.8M in the file system.
                                        /opt/iobroker/backups:
                                        355M    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        128M    /opt/iobroker/iobroker-data/files
                                        99M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                        16M     /opt/iobroker/iobroker-data/objects.jsonl
                                        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                                        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                                        5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        ./iob_diag.sh: line 617: [: too many arguments
                                        HINT:
                                        tcp
                                        HINT:
                                        Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        tcp
                                        HINT:
                                        Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        tcp
                                        HINT:
                                        Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        tcp
                                        ./iob_diag.sh: line 676: [: too many arguments
                                        zigbee.0
                                        Extended Pan ID:
                                        ghnjghgh
                                        Pan ID:
                                        1234
                                        Channel:
                                        00
                                        Network Key:
                                        gfhjnhhf
                                        zigbee.1
                                        Extended Pan ID:
                                        ghnjghgh
                                        Pan ID:
                                        1234
                                        Channel:
                                        00
                                        Network Key:
                                        gfhjnhhf
                                        zigbee.2
                                        Extended Pan ID:
                                        ghnjghgh
                                        Pan ID:
                                        1234
                                        Channel:
                                        00
                                        Network Key:
                                        gfhjnhhf
                                        zigbee.3
                                        Extended Pan ID:
                                        ghnjghgh
                                        Pan ID:
                                        1234
                                        Channel:
                                        00
                                        Network Key:
                                        gfhjnhhf
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Version table:
                                         *** 20.18.1-1nodesource1 1001
                                             20.18.0-1nodesource1 1001
                                             20.17.0-1nodesource1 1001
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             18.19.0+dfsg-6~deb12u2 500
                                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                             18.19.0+dfsg-6~deb12u1 500
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        At least one iobroker host is running.
                                        Objects type: redis
                                        States  type: redis
                                        Hosts:
                                        iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 5746)
                                        Core adapters versions
                                        admin:          7.4.4
                                        javascript:     8.8.3
                                        nodejs modules from github:     0
                                        Adapter State
                                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                        + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                                        + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                        + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                                        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                          system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                                        + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1883
                                          system.adapter.mqtt.1                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                                        + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                                        + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                                        + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                                          system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                                          system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
                                        + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                                        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                        + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                                        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                        + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                                        + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
                                        + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                                        + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                                        + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                                        + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                                        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                          system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                                        + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                                        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                                        + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                                        + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                                        + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                                        + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                                        + instance is alive
                                        ioBroker-Repositories
                                        Upgrade policy: none
                                        Installed ioBroker-Instances
                                        Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
                                        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                                        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                        Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
                                        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                        Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                                        Adapter    "mytime"       : 1.2.2    , installed 1.2.2
                                        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                        Adapter    "notification-manager": 1.3.0, installed 1.3.0
                                        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                                        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                        Adapter    "operating-hours": 1.2.0  , installed 1.2.0
                                        Adapter    "ping"         : 1.7.9    , installed 1.7.9
                                        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                                        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                        Objects and States
                                        Objects:        13487
                                        States:         11924
                                        Hit:1 http://security.debian.org bookworm-security InRelease
                                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                                        Hit:5 https://packages.redis.io/deb bookworm InRelease
                                        Reading package lists... Done
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       11999557   207697/io.nuki.0
                                        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      103        16776      153/redis-server 12
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          689        1/init
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11997884   207652/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11998035   207800/io.shelly.1
                                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15869      384/master
                                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15870      384/master
                                        tcp6       0      0 ::1:6379                :::*                    LISTEN      103        16777      153/redis-server 12
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       11999063   208020/io.fullybrow
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          11649      1/init
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          691        1/init
                                        tcp6       0      0 :::80                   :::*                    LISTEN      0          6137       176/apache2
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       12007886   208176/io.simple-ap
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12015647   208292/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11995807   207272/io.admin.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11996105   207567/io.chromecas
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11999591   207780/io.shelly.0
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       11998078   207822/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       11998079   207822/io.tuya.0
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          690        1/init
                                        udp6       0      0 :::111                  :::*                                0          692        1/init
                                        • S Shadowhunter23
                                          *** BASE SYSTEM ***
                                            Virtualization: lxc
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          CPU threads: 6
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          tobias
                                          HOME=/home/tobias
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:             0B          0B          0B
                                                   3825 M used memory
                                                   5083 M free memory
                                                      0 M buffer memory
                                                   1331 M swap cache
                                                      0 M total swap
                                                      0 M used swap
                                                      0 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          831M    /var/
                                          534M    /var/lib
                                          383M    /var/lib/redis
                                          226M    /var/cache
                                          222M    /var/cache/apt
                                          USB-Devices by-id:
                                          HINT:
                                          tcp
                                          HINT:
                                          tcp
                                          HINT:
                                          tcp
                                          HINT:
                                          tcp
                                          zigbee.0
                                          Extended Pan ID:
                                          ghnjghgh
                                          Pan ID:
                                          1234
                                          Channel:
                                          00
                                          Network Key:
                                          gfhjnhhf
                                          zigbee.1
                                          Extended Pan ID:
                                          ghnjghgh
                                          Pan ID:
                                          1234
                                          Channel:
                                          00
                                          Network Key:
                                          gfhjnhhf
                                          zigbee.2
                                          Extended Pan ID:
                                          ghnjghgh
                                          Pan ID:
                                          1234
                                          Channel:
                                          00
                                          Network Key:
                                          gfhjnhhf
                                          zigbee.3
                                          Extended Pan ID:
                                          ghnjghgh
                                          Pan ID:
                                          1234
                                          Channel:
                                          00
                                          Network Key:
                                          gfhjnhhf
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: redis
                                          States  type: redis
                                          Hosts:
                                          admin:          7.4.4
                                          javascript:     8.8.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        13487
                                          States:         11924
                                          Pending Updates: 0
                                          #684
                                          Muss ich schauen.
                                          Da sollte eigentlich keine Leerzeichen kommen und die Ausgabe als kompaktes Päckchen pro Instanz erscheinen. Ist aber nur noch Kosmetik an der Stelle.
