  4. jarvis v3.2.x - just another remarkable vis
961 Beiträge 46 Kommentatoren 344.7k Aufrufe 43 Beobachtet
  • M MCU
    @tritanium Bitte rc.5 nutzen, damit soll es korrekt umgesetzt werden.
    Bitte probieren.
    tritanium
    #325
    @mcu okay, jetzt rc5, leider keine Besserung, gleiches Verhalten:
    dann geht der Pro Honweis weg, und das wars... hmm, zurück zu 3.1.19 alpha ??
    • T tritanium
      MCU
      #326
      @tritanium Nein. Der CSS muss umgesetzt werden
      Schick mal den inhalt hier in </> Code-Tags
      • M MCU
        tritanium
        #327
        @mcu ```
        .jarvis-page-container {
        background-image: url('https://images.hdqwalls.com/download/the-avengers-metal-logo-4k-id-1920x1080.jpg');
        .body--dark .jarvis-header {
        background-color: rgba(0,0,0,0.3) !important;
        .jarvis-tabs-container,
        .jarvis-widget-container {
        background-color: transparent !important;
        .body--dark .jarvis-widget {
        background: rgba(0,0,0,0.6);
        .body--light .jarvis-widget {
        background: rgba(255,255,255,1);
        @keyframes up_down {
        0% {
        background-position: 50% 0%;
        50% {
        	background-position: 50% 100%;
        100% {
        .impuls {
        animation: rechteck-puls 1s infinite;
        @keyframes rechteck-puls {
        0% {
        box-shadow: 0 0 0 0px rgba(255, 255, 0, 0.9);
        100% {
        	box-shadow: 0 0 0 10px rgba(255, 255, 0, 0);
        .Calendar {
        width: 100%;
        • T tritanium
          @mcu ```
          0% {
          50% {
          100% {
          .impuls {
          0% {
          100% {
          .Calendar {
          width: 100%;
          MCU
          #328
          @tritanium Dann bitte dies in den css-DP Inhalt setzen
            "version": 3.2,
            "signature": 1234,
            "styles": ".jarvis-page-container {\nbackground-image: url(\\\"https://images.hdqwalls.com/download/the-avengers-metal-logo-4k-id-1920x1080.jpg\\\");\n}\n\n.body--dark .jarvis-header {\nbackground-color: rgba(0,0,0,0.3) !important;\n}\n\n.jarvis-tabs-container,\n.jarvis-widget-container {\nbackground-color: transparent !important;\n}\n\n.body--dark .jarvis-widget {\nbackground: rgba(0,0,0,0.6);\n}\n\n.body--light .jarvis-widget {\nbackground: rgba(255,255,255,1);\n}\n\n@keyframes up_down {\n0% {\nbackground-position: 50% 0%;\n}\n\n50% {\n\tbackground-position: 50% 100%;\n}\n\n100% {\n\tbackground-position: 50% 0%;\n}\n}\n\n.impuls {\nanimation: rechteck-puls 1s infinite;\n}\n\n@keyframes rechteck-puls {\n0% {\nbox-shadow: 0 0 0 0px rgba(255, 255, 0, 0.9);\n}\n\n100% {\n\tbox-shadow: 0 0 0 10px rgba(255, 255, 0, 0);\n}\n}\n\n.Calendar {\nwidth: 100%;\n}\n"
          • M MCU
              "version": 3.2,
              "signature": 1234,
            tritanium
            #329
            @mcu
            :-) Okay, ich sehe wieder was, aber das ist alles voll "unförmig":
            • Hintergrundbild ist weg
            • durchsichtigkeit der Widgets ist weg...
            und einige sehen so aus, obwohl bis unten an den Rand noch viel platz ist....
            • T tritanium
              @mcu
              MCU
              #330
              @tritanium Zeig mal bitte die CSS / Styles was er daraus gemacht hat in jarvis, nicht den DP-Inhalt
              • M MCU
                tritanium
                #331
                @mcu
                das sieht dann so aus:
                	background-image: url(\"https://images.hdqwalls.com/download/the-avengers-metal-logo-4k-id-1920x1080.jpg\");
                	0% {
                	50% {
                	100% {
                .impuls {
                	0% {
                	100% {
                .Calendar {
                	width: 100%;
                • T tritanium
                  @mcu
                  	0% {
                  	50% {
                  	100% {
                  .impuls {
                  	0% {
                  	100% {
                  .Calendar {
                  	width: 100%;
                  MCU
                  #332
                  @tritanium Nimm in jarvis in Styles die \ vor " raus und dann speichern, dann müsste das Bild wieder da sein.
                  • M MCU
                    tritanium
                    #333
                    @mcu
                    seufz ...leider nein.... aber egal... daran werde ich erst einmal nicht sterben :-)
                    Noch Ideen ?
                    • T tritanium
                      @mcu
                      Noch Ideen ?
                      MCU
                      #334
                      @tritanium Muss man sich im Detail anschauen, schick mal die DPs als txt oder eine Sicherung, dann schau ich mal morgen.
                      Sicherung nur kurz rein setzen und nach meine OK sofort wieder rausnehmen.
                      Keiner zurzeit nicht helfen System defekt bis auf Weiteres.
                        Titanflex
                        #335
                        nachdem ich ein Update bei Jarvis auf v3.2.0-rc.5 gemacht habe, geht gar nix mehr :)
                        Was muss gemacht werden? Ab wann fängt die Fehlerbehandlung hier im Beitrag an ?
                        hotspot_2H 1 Antwort Letzte Antwort
                        • T Titanflex
                          hotspot_2H Offline
                          hotspot_2H Offline
                          hotspot_2
                          #336
                          @titanflex Hi! Bei mir funktioniert auch mit rc5 alles Bestens. Wenn ich den lila Screen sehe lösche ich immer den Cache (alles) und dann klappt es meistens wieder wenn man jarvis neu aufruft. Nur so als Tipp.
                            Titanflex
                            #337
                            @hotspot_2
                            Nun kommt der Startbildschirm und fertig :)
                            MeinzIsAsM 1 Antwort Letzte Antwort
                            • T Titanflex
                              @hotspot_2
                              MeinzIsAsM Offline
                              MeinzIsAsM Offline
                              MeinzIsAs
                              #338
                              @titanflex Versuch mal folgendes:
                              Im Datenpunkt css trägst Du das hier ein:
                                "version": 3.2,
                                "signature": 1234,
                                "styles": ""
                              Im Datenpunkt scripts das hier:
                                "version": 3.2,
                                "signature": 1234,
                                "scripts": {}
                              Danach Adapter neu starten. Im Browser dann nur über die IP und den Port aufrufen.
                              ip-adresse:Port
                              Bei mir hat das so funktioniert. Zur Zeit läuft er wieder.
                              • MeinzIsAsM MeinzIsAs
                                  "version": 3.2,
                                  "signature": 1234,
                                  "styles": ""
                                  "version": 3.2,
                                  "signature": 1234,
                                  "scripts": {}
                                ip-adresse:Port
                                Titanflex
                                #339
                                @meinzisas sagte in jarvis v3.2.x - just another remarkable vis:
                                  "version": 3.2,
                                  "signature": 1234,
                                  "styles": ""
                                  "version": 3.2,
                                  "signature": 1234,
                                  "scripts": {}
                                ip-adresse:Port
                                Perfekt, vielen Dank. Daran hat es gelegen. Wie kommt das. dass hier die Datenpunkte fehlen ?
                                • T Titanflex
                                    "version": 3.2,
                                    "signature": 1234,
                                    "styles": ""
                                    "version": 3.2,
                                    "signature": 1234,
                                    "scripts": {}
                                  ip-adresse:Port
                                  MeinzIsAsM Offline
                                  MeinzIsAsM Offline
                                  MeinzIsAs
                                  #340
                                  @titanflex Lag wohl am Update auf 3.2 und der Migration der Datenpunkte. Kann ja mal passieren. 😊
                                  • ZefauZ Zefau
                                    ich suche eine paar Wenige, die die jarvis v3.2.x im alpha testen könnten.
                                    Ab v3.2.x sollten ältere Geräte unterstützt werden, die unter jarvis v3.1 (bzw. auch vis) nicht (mehr) funktionieren. Bei mir persönlich betrifft es das iPad Air 1 mit iOS 12.5, was nun mit v3.2 funktioniert.
                                    Hat jemand solche ältere Geräte und könnte testen, ob v3.2 läuft und ob ggf. etwas vom Design zerschossen ist?
                                    Installation der alpha wie gewohnt via Github, siehe https://github.com/Zefau/ioBroker.jarvis bzw. https://github.com/Zefau/ioBroker.jarvis/issues/866
                                    sigi234S Online
                                    sigi234S Online
                                    #341
                                    @zefau
                                    Version v3.2.0-rc.5 läuft einwandfrei. DANKE!
                                    • sigi234S sigi234
                                      @zefau
                                      ZefauZ Offline
                                      ZefauZ Offline
                                      Zefau
                                      #342
                                      @sigi234 bist du von v3.1 direkt auf rc-5 oder erst auf eine frühere Version?
                                      • ZefauZ Zefau
                                        sigi234S Online
                                        sigi234S Online
                                        #343
                                        @zefau sagte in jarvis v3.2.x - just another remarkable vis:
                                        Von alpha auf rc1 und dann auf rc 2,3,5
                                        • sigi234S sigi234
                                          MCU
                                          #344
                                          @sigi234 Dubhast aber damals die DPs anpassen müssen?
