  4. jarvis v3.2.x - just another remarkable vis
    apollon77A
969 Beiträge 48 Kommentatoren 397.1k Aufrufe 45 Beobachtet
  • T tritanium
    @mcu okay, jetzt rc5, leider keine Besserung, gleiches Verhalten:
    dann geht der Pro Honweis weg, und das wars... hmm, zurück zu 3.1.19 alpha ??
    M
    M
    MCU
    #326
    @tritanium Nein. Der CSS muss umgesetzt werden
    Schick mal den inhalt hier in </> Code-Tags
    • M MCU
      T
      T
      tritanium
      #327
      @mcu ```
      .jarvis-page-container {
      background-image: url('https://images.hdqwalls.com/download/the-avengers-metal-logo-4k-id-1920x1080.jpg');
      .body--dark .jarvis-header {
      background-color: rgba(0,0,0,0.3) !important;
      .jarvis-tabs-container,
      .jarvis-widget-container {
      background-color: transparent !important;
      .body--dark .jarvis-widget {
      background: rgba(0,0,0,0.6);
      .body--light .jarvis-widget {
      background: rgba(255,255,255,1);
      @keyframes up_down {
      0% {
      background-position: 50% 0%;
      50% {
      	background-position: 50% 100%;
      100% {
      .impuls {
      animation: rechteck-puls 1s infinite;
      @keyframes rechteck-puls {
      0% {
      box-shadow: 0 0 0 0px rgba(255, 255, 0, 0.9);
      100% {
      	box-shadow: 0 0 0 10px rgba(255, 255, 0, 0);
      .Calendar {
      width: 100%;
      • T tritanium
        @mcu ```
        0% {
        50% {
        100% {
        .impuls {
        0% {
        100% {
        .Calendar {
        width: 100%;
        M
        M
        MCU
        #328
        @tritanium Dann bitte dies in den css-DP Inhalt setzen
          "version": 3.2,
          "signature": 1234,
          "styles": ".jarvis-page-container {\nbackground-image: url(\\\"https://images.hdqwalls.com/download/the-avengers-metal-logo-4k-id-1920x1080.jpg\\\");\n}\n\n.body--dark .jarvis-header {\nbackground-color: rgba(0,0,0,0.3) !important;\n}\n\n.jarvis-tabs-container,\n.jarvis-widget-container {\nbackground-color: transparent !important;\n}\n\n.body--dark .jarvis-widget {\nbackground: rgba(0,0,0,0.6);\n}\n\n.body--light .jarvis-widget {\nbackground: rgba(255,255,255,1);\n}\n\n@keyframes up_down {\n0% {\nbackground-position: 50% 0%;\n}\n\n50% {\n\tbackground-position: 50% 100%;\n}\n\n100% {\n\tbackground-position: 50% 0%;\n}\n}\n\n.impuls {\nanimation: rechteck-puls 1s infinite;\n}\n\n@keyframes rechteck-puls {\n0% {\nbox-shadow: 0 0 0 0px rgba(255, 255, 0, 0.9);\n}\n\n100% {\n\tbox-shadow: 0 0 0 10px rgba(255, 255, 0, 0);\n}\n}\n\n.Calendar {\nwidth: 100%;\n}\n"
        • M MCU
            "version": 3.2,
            "signature": 1234,
          T
          T
          tritanium
          #329
          @mcu
          :-) Okay, ich sehe wieder was, aber das ist alles voll "unförmig":
          • Hintergrundbild ist weg
          • durchsichtigkeit der Widgets ist weg...
          und einige sehen so aus, obwohl bis unten an den Rand noch viel platz ist....
          • T tritanium
            @mcu
            M
            M
            MCU
            #330
            @tritanium Zeig mal bitte die CSS / Styles was er daraus gemacht hat in jarvis, nicht den DP-Inhalt
            • M MCU
              T
              T
              tritanium
              #331
              @mcu
              das sieht dann so aus:
              	background-image: url(\"https://images.hdqwalls.com/download/the-avengers-metal-logo-4k-id-1920x1080.jpg\");
              	0% {
              	50% {
              	100% {
              .impuls {
              	0% {
              	100% {
              .Calendar {
              	width: 100%;
              • T tritanium
                @mcu
                	0% {
                	50% {
                	100% {
                .impuls {
                	0% {
                	100% {
                .Calendar {
                	width: 100%;
                M
                M
                MCU
                #332
                @tritanium Nimm in jarvis in Styles die \ vor " raus und dann speichern, dann müsste das Bild wieder da sein.
                • M MCU
                  T
                  T
                  tritanium
                  #333
                  @mcu
                  seufz ...leider nein.... aber egal... daran werde ich erst einmal nicht sterben :-)
                  Noch Ideen ?
                  • T tritanium
                    @mcu
                    Noch Ideen ?
                    M
                    M
                    MCU
                    #334
                    @tritanium Muss man sich im Detail anschauen, schick mal die DPs als txt oder eine Sicherung, dann schau ich mal morgen.
                    Sicherung nur kurz rein setzen und nach meine OK sofort wieder rausnehmen.
                    Keiner zurzeit nicht helfen System defekt bis auf Weiteres.
                    • T
                      T
                      Titanflex
                      #335
                      nachdem ich ein Update bei Jarvis auf v3.2.0-rc.5 gemacht habe, geht gar nix mehr :)
                      Was muss gemacht werden? Ab wann fängt die Fehlerbehandlung hier im Beitrag an ?
                      hotspot_2H 1 Antwort Letzte Antwort
                      • T Titanflex
                        hotspot_2H
                        hotspot_2H
                        hotspot_2
                        #336
                        @titanflex Hi! Bei mir funktioniert auch mit rc5 alles Bestens. Wenn ich den lila Screen sehe lösche ich immer den Cache (alles) und dann klappt es meistens wieder wenn man jarvis neu aufruft. Nur so als Tipp.
                        • T
                          T
                          Titanflex
                          #337
                          @hotspot_2
                          Nun kommt der Startbildschirm und fertig :)
                          MeinzIsAsM 1 Antwort Letzte Antwort
                          • T Titanflex
                            @hotspot_2
                            MeinzIsAsM
                            MeinzIsAsM
                            MeinzIsAs
                            #338
                            @titanflex Versuch mal folgendes:
                            Im Datenpunkt css trägst Du das hier ein:
                              "version": 3.2,
                              "signature": 1234,
                              "styles": ""
                            Im Datenpunkt scripts das hier:
                              "version": 3.2,
                              "signature": 1234,
                              "scripts": {}
                            Danach Adapter neu starten. Im Browser dann nur über die IP und den Port aufrufen.
                            ip-adresse:Port
                            Bei mir hat das so funktioniert. Zur Zeit läuft er wieder.
                            • MeinzIsAsM MeinzIsAs
                                "version": 3.2,
                                "signature": 1234,
                                "styles": ""
                                "version": 3.2,
                                "signature": 1234,
                                "scripts": {}
                              ip-adresse:Port
                              T
                              T
                              Titanflex
                              #339
                              @meinzisas sagte in jarvis v3.2.x - just another remarkable vis:
                                "version": 3.2,
                                "signature": 1234,
                                "styles": ""
                                "version": 3.2,
                                "signature": 1234,
                                "scripts": {}
                              ip-adresse:Port
                              Perfekt, vielen Dank. Daran hat es gelegen. Wie kommt das. dass hier die Datenpunkte fehlen ?
                              • T Titanflex
                                  "version": 3.2,
                                  "signature": 1234,
                                  "styles": ""
                                  "version": 3.2,
                                  "signature": 1234,
                                  "scripts": {}
                                ip-adresse:Port
                                MeinzIsAsM
                                MeinzIsAsM
                                MeinzIsAs
                                #340
                                @titanflex Lag wohl am Update auf 3.2 und der Migration der Datenpunkte. Kann ja mal passieren. 😊
                                • ZefauZ Zefau
                                  ich suche eine paar Wenige, die die jarvis v3.2.x im alpha testen könnten.
                                  Ab v3.2.x sollten ältere Geräte unterstützt werden, die unter jarvis v3.1 (bzw. auch vis) nicht (mehr) funktionieren. Bei mir persönlich betrifft es das iPad Air 1 mit iOS 12.5, was nun mit v3.2 funktioniert.
                                  Hat jemand solche ältere Geräte und könnte testen, ob v3.2 läuft und ob ggf. etwas vom Design zerschossen ist?
                                  Installation der alpha wie gewohnt via Github, siehe https://github.com/Zefau/ioBroker.jarvis bzw. https://github.com/Zefau/ioBroker.jarvis/issues/866
                                  sigi234S
                                  sigi234S
                                  #341
                                  @zefau
                                  Version v3.2.0-rc.5 läuft einwandfrei. DANKE!
                                  • sigi234S sigi234
                                    @zefau
                                    ZefauZ
                                    ZefauZ
                                    Zefau
                                    #342
                                    @sigi234 bist du von v3.1 direkt auf rc-5 oder erst auf eine frühere Version?
                                    • ZefauZ Zefau
                                      sigi234S
                                      sigi234S
                                      #343
                                      @zefau sagte in jarvis v3.2.x - just another remarkable vis:
                                      Von alpha auf rc1 und dann auf rc 2,3,5
                                      • sigi234S sigi234
                                        M
                                        M
                                        MCU
                                        #344
                                        @sigi234 Dubhast aber damals die DPs anpassen müssen?
                                        • M MCU
                                          sigi234S
                                          sigi234S
                                          #345
                                          @mcu sagte in jarvis v3.2.x - just another remarkable vis:
                                          Nein
                                          84.1k
