  4. SONOFF NSPanel Lovelance UI Rückgängig machen
35 Beiträge 6 Kommentatoren 4.1k Aufrufe 2 Beobachtet
  • K Karlson 0
    @TT-Tom
    @Armilar
    Die npm-Module führen mich leider zu meinem nächsten Problem, sobald ich sie eintrage startet mein JS Adapter nicht mehr und ich bekomme folgende Meldung:
    2024-08-09 21:17:39.475 - info: javascript.0 (675) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.7.0, js-controller: 6.0.9
    2024-08-09 21:17:39.575 - error: javascript.0 (675) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-08-09 21:17:39.576 - error: javascript.0 (675) unhandled promise rejection: URL.canParse is not a function
    2024-08-09 21:17:39.576 - error: javascript.0 (675) TypeError: URL.canParse is not a function
    at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1868:17)
    2024-08-09 21:17:39.576 - error: javascript.0 (675) URL.canParse is not a function
    2024-08-09 21:17:39.604 - info: javascript.0 (675) terminating
    2024-08-09 21:17:39.605 - warn: javascript.0 (675) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-08-09 21:17:40.103 - info: javascript.0 (675) terminating
    2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[1]: TypeError: URL.canParse is not a function
    2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[1]: at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1868:17)
    2024-08-09 21:17:40.151 - error: host.ioBroker instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-08-09 21:17:40.151 - info: host.ioBroker Restart adapter system.adapter.javascript.0 because enabled
    2024-08-09 21:17:40.151 - warn: host.ioBroker Do not restart adapter system.adapter.javascript.0 because restart loop detected
    TT-Tom
    @karlson-0
    Zeig mal was du da eingetragen hast.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • ArmilarA Armilar
      @karlson-0
      Führe mal ein
      iob fix
      durch
      Dann mal
      sudo apt update
      sudo apt dist-upgrade
      sudo reboot
      danach nochmal versuchen
      TT-Tom
      @armilar
      @Karlson-0
      Und gleich die nodejs Version anpassen auf 20.
      iob nodejs-update 20
      Gruß Tom
      Public Transport
      • T TT-Tom
        @armilar
        @Karlson-0
        Karlson 0
        @tt-tom
        @Armilar
        Nach
        iob fix
        sudo apt update
        sudo reboot
        Hat es leider nicht funktioniert
        Jetzt das nächste Problem, und ich hoffe ihr habt starke nerven:
        Node V 20 bekomme ich bei mir irgendwie nicht drauf, war schon ein wunder dass ich 18 drauf bekommen habe.
        Muss dazu sagen, dass iobroker bei mir auf einem LXC Container über Proxmox läuft.
        Ich bekomme bei der Installation folgende Meldung:
        root@ioBroker:~# sudo -E bash nodesource_setup.sh
        2024-08-09 21:50:33 - Installing pre-requisites
        Ign:1 http://archive.ubuntu.com/ubuntu kinetic InRelease
        Ign:2 http://archive.ubuntu.com/ubuntu kinetic-updates InRelease
        Ign:3 http://archive.ubuntu.com/ubuntu kinetic-security InRelease
        Err:4 http://archive.ubuntu.com/ubuntu kinetic Release
          404  Not Found [IP: 91.189.91.83 80]
        Err:5 http://archive.ubuntu.com/ubuntu kinetic-updates Release
        Err:6 http://archive.ubuntu.com/ubuntu kinetic-security Release
        Reading package lists... Done
        E: The repository 'http://archive.ubuntu.com/ubuntu kinetic Release' no longer has a Release file.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-updates Release' no longer has a Release file.
        E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-security Release' no longer has a Release file.
        2024-08-09 21:50:34 - Error: Failed to run 'apt-get update' (Exit Code: 0)
        HomoranH T 2 Antworten Letzte Antwort
        • K Karlson 0
          @tt-tom
          @Armilar
          Nach
          iob fix
          sudo apt update
          sudo reboot
          @karlson-0 sagte in SONOFF NSPanel Lovelance UI Rückgängig machen:
          ubuntu kinetic
          Ubuntu 22.10 Kinetic Kudu ist eine "Short Term Support" Version, die nur bis Juli 2023 mit Updates versorgt wird
          • K Karlson 0
            @tt-tom
            @Armilar
            Nach
            iob fix
            sudo apt update
            sudo reboot
            TT-Tom
            @karlson-0
            Warum arbeitest du als Root????
            Du musst immer als normal User im System unterwegs sein.
            Lege die ein neuen Container an, als Vorlage würde ich dir Debian 12 empfehlen.
            Dann baust du dir iobroker komplett neu auf und spielst das Backup deiner aktuellen Version ein.
            Wenn ich zu Hause bin kann ich dir eine kleine Schritt für Schritt Anleitung noch posten.
            Gruß Tom
            Public Transport
            • T TT-Tom
              @karlson-0
              Karlson 0
              @tt-tom
              So weit meine Kenntnis reicht, gibt es in diesen LXC Containern nur den Root User, In einigen Foren wird noch der User Ubuntu beschrieben, mit pw ubuntu, funktioniert bei mir aber nicht.
              Thomas BraunT K 2 Antworten Letzte Antwort
              • K Karlson 0
                @tt-tom
                Man legt sich immer einen user an.
                Ist die erste (und einzige) Aktion als root in einem frischen LXC.
                Undd dein kinetisches Kudo ist ausgestorben. Deswegen frisst das auch kein nodejs20 mehr.
                Zimmer dir einen frischen Debian12-LXC hin.
                • K Karlson 0
                  @tt-tom
                  Karlson 0
                  schrieb am zuletzt editiert von Karlson 0
                  Ich habe gerade das ioBroker Backup gemacht, werde morgen einen neuen Debian 12 Container für Iobroker erstellen, und danach sofort berichten
                  • K Karlson 0
                    TT-Tom
                    @karlson-0
                    hier wie versprochen meine kurze Schritt für Schritt Anleitung. Wenn der Container läuft sind die ersten Schritte bis zum Reboot als Root. Danach wird root nicht mehr angefasst, IMMER als Standard-User anmelden und ggf. mit sudo arbeiten.
                    apt update && apt full-upgrade -y
                    apt install -y curl sudo mc
                    dpkg-reconfigure tzdata
                    dpkg-reconfigure locales
                    //Standarduser erstellen
                    adduser "name"
                    usermod -aG sudo "name"
                    reboot
                    // login als Standarduser
                    // install ioBroker
                    curl -sLf https://iobroker.net/install.sh | bash -
                    Gruß Tom
                    Public Transport
                    • T TT-Tom
                      @karlson-0
                      adduser "name"
                      reboot
                      // install ioBroker
                      Karlson 0
                      Leider weiterhin nicht erfolgreich.
                      Mein iobroker läuft jetzt auf einem Debian 12 Container, node 20 ist drauf, npm Module sind jetzt auch eingetragen, und die Instanz javascript wird grün.
                      Bekomme beim Start von NSPanelTS.ts folgende Meldungen:
                      2024-08-12 21:45:15.043 - info: admin.0 (407) ==> Connected system.user.admin from ::ffff:192.168.178.240
                      2024-08-12 21:45:19.220 - info: javascript.0 (458) Compiling TypeScript source script.js.common.NSPanelTs_ts
                      2024-08-12 21:45:24.438 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: TypeScript compilation successful
                      2024-08-12 21:45:24.545 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.545 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.546 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.546 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                      2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                      2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.546 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.548 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.548 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.548 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.549 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.549 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                      2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                      2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.549 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.551 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.551 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.552 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.552 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                      2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                      2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.553 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.554 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.554 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.554 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.554 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.555 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                      2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                      2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.555 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.561 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.561 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.561 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.561 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.561 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                      2024-08-12 21:45:24.561 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                      2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.562 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.562 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.564 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.564 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.564 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.564 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.564 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                      2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                      2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.565 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.567 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.568 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.568 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                      2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                      2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.569 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.569 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.569 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.569 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.570 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                      2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                      2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.570 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.575 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.575 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.575 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.575 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.575 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                      2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                      2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.576 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.578 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.578 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.578 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.579 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.579 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                      2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                      2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.579 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.581 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.581 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.581 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.581 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.581 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                      2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                      2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.582 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.584 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.585 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.585 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                      2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                      2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.586 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.586 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.586 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.587 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.587 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                      2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                      2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.587 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.588 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.588 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.588 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.589 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.589 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                      2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                      2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.589 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.590 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.590 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.591 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.591 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                      2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                      2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.591 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.594 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.594 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.594 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.595 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.595 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                      2024-08-12 21:45:24.595 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                      2024-08-12 21:45:24.595 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.598 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.598 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.598 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.599 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.599 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.599 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.599 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.599 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                      2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                      2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.600 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.602 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.602 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.602 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.602 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                      2024-08-12 21:45:24.602 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                      2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.603 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.603 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.603 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.606 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.606 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.606 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.606 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.607 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                      2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                      2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.607 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.609 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.609 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.609 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.609 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                      2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                      2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.610 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.612 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.612 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.613 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.613 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                      2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                      2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.613 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.615 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                      2024-08-12 21:45:24.615 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                      2024-08-12 21:45:24.615 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                      2024-08-12 21:45:24.616 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                      2024-08-12 21:45:24.616 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                      2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                      2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                      2024-08-12 21:45:24.616 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                      2024-08-12 21:45:24.623 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: nodeJS must be at least v18.X.X. Currently: v14.5.0! Please Update your System! --> iob nodejs-update 18
                      2024-08-12 21:45:24.624 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: setObjects enabled - create Alias Channels possible
                      2024-08-12 21:45:24.630 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: weather alias for accuweather.0. already exists
                      2024-08-12 21:45:24.689 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                      2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                      2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                      2024-08-12 21:45:24.694 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2994:1
                      2024-08-12 21:45:24.694 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                      2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                      2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                      2024-08-12 21:45:24.726 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                      2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                      2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                      2024-08-12 21:45:24.726 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2986:5
                      2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Object._schedule (script.js.common.NSPanelTs_ts:11224:9)
                      2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3212:34)
                      2024-08-12 21:45:24.726 - warn: javascript.0 (458) at listOnTimeout (node:internal/timers:581:17)
                      2024-08-12 21:45:24.726 - warn: javascript.0 (458) at processTimers (node:internal/timers:519:7)
                      2024-08-12 21:45:24.726 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                      2024-08-12 21:45:24.727 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                      2024-08-12 21:45:24.877 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                      at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14)
                      at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:620:25)
                      at RedirectableRequest.emit (node:events:519:28)
                      at RedirectableRequest.emit (node:domain:488:12)
                      at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)
                      at ClientRequest.emit (node:events:531:35)
                      at ClientRequest.emit (node:domain:488:12)
                      at Socket.socketErrorListener (node:_http_client:500:9)
                      at Socket.emit (node:events:519:28)
                      at Socket.emit (node:domain:488:12)
                      at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)
                      at processTicksAndRejections (node:internal/process/task_queues:95:5) {
                      hostname: 'undefined',
                      syscall: 'getaddrinfo',
                      code: 'ENOTFOUND',
                      errno: -3008,
                      config: {
                      transitional: {
                      silentJSONParsing: true,
                      forcedJSONParsing: true,
                      clarifyTimeoutError: false
                      adapter: [ 'xhr', 'http', 'fetch' ],
                      transformRequest: [ [Function: transformRequest] ],
                      transformResponse: [ [Function: transformResponse] ],
                      timeout: 0,
                      xsrfCookieName: 'XSRF-TOKEN',
                      xsrfHeaderName: 'X-XSRF-TOKEN',
                      maxContentLength: -1,
                      maxBodyLength: -1,
                      env: { FormData: [Function], Blob: [class Blob] },
                      validateStatus: [Function: validateStatus],
                      headers: Object [AxiosHeaders] {
                      Accept: 'application/json, text/plain, */*',
                      'Content-Type': undefined,
                      'User-Agent': 'ioBroker',
                      'Accept-Encoding': 'gzip, compress, deflate, br'
                      method: 'get',
                      url: 'http://undefined/cm?cmnd=Status0',
                      data: undefined
                      request: Writable {
                      _events: {
                      close: undefined,
                      error: [Function: handleRequestError],
                      prefinish: undefined,
                      finish: undefined,
                      drain: undefined,
                      response: [Function: handleResponse],
                      socket: [Function: handleRequestSocket]
                      _writableState: WritableState {
                      highWaterMark: 16384,
                      length: 0,
                      corked: 0,
                      onwrite: [Function: bound onwrite],
                      writelen: 0,
                      bufferedIndex: 0,
                      pendingcb: 0,
                      [Symbol(kState)]: 17580812,
                      [Symbol(kBufferedValue)]: null
                      _maxListeners: 100,
                      _options: {
                      maxRedirects: 21,
                      maxBodyLength: Infinity,
                      protocol: 'http:',
                      path: '/cm?cmnd=Status0',
                      method: 'GET',
                      headers: [Object: null prototype],
                      agents: [Object],
                      auth: undefined,
                      family: undefined,
                      beforeRedirect: [Function: dispatchBeforeRedirect],
                      beforeRedirects: [Object],
                      port: '',
                      agent: undefined,
                      nativeProtocols: [Object],
                      pathname: '/cm',
                      search: '?cmnd=Status0'
                      _ended: true,
                      _ending: true,
                      _redirectCount: 0,
                      _redirects: [],
                      _requestBodyLength: 0,
                      _requestBodyBuffers: [],
                      _eventsCount: 3,
                      _onNativeResponse: [Function (anonymous)],
                      _currentRequest: ClientRequest {
                      _events: [Object: null prototype],
                      _eventsCount: 7,
                      _maxListeners: 100,
                      outputData: [],
                      outputSize: 0,
                      writable: true,
                      destroyed: false,
                      _last: true,
                      chunkedEncoding: false,
                      shouldKeepAlive: true,
                      maxRequestsOnConnectionReached: false,
                      _defaultKeepAlive: true,
                      useChunkedEncodingByDefault: false,
                      sendDate: false,
                      _removedConnection: false,
                      _removedContLen: false,
                      _removedTE: false,
                      strictContentLength: false,
                      _contentLength: 0,
                      _hasBody: true,
                      _trailer: '',
                      finished: true,
                      _headerSent: true,
                      _closed: false,
                      socket: [Socket],
                      _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' +
                      'Accept: application/json, text/plain, */*\r\n' +
                      'User-Agent: ioBroker\r\n' +
                      'Accept-Encoding: gzip, compress, deflate, br\r\n' +
                      'sentry-trace: 49d0d7813b8c428eab3645c24d1a50f8-98b170a0ea551350\r\n' +
                      'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=49d0d7813b8c428eab3645c24d1a50f8\r\n' +
                      'Host: undefined\r\n' +
                      'Connection: keep-alive\r\n' +
                      '\r\n',
                      _keepAliveTimeout: 0,
                      _onPendingData: [Function: nop],
                      agent: [Agent],
                      socketPath: undefined,
                      method: 'GET',
                      maxHeaderSize: undefined,
                      insecureHTTPParser: undefined,
                      joinDuplicateHeaders: undefined,
                      _ended: false,
                      res: null,
                      aborted: false,
                      timeoutCb: [Function: emitRequestTimeout],
                      upgradeOrConnect: false,
                      parser: null,
                      maxHeadersCount: null,
                      reusedSocket: false,
                      host: 'undefined',
                      protocol: 'http:',
                      _redirectable: [Circular *1],
                      [Symbol(shapeMode)]: false,
                      [Symbol(kCapture)]: false,
                      [Symbol(kBytesWritten)]: 0,
                      [Symbol(kNeedDrain)]: false,
                      [Symbol(corked)]: 0,
                      [Symbol(kOutHeaders)]: [Object: null prototype],
                      [Symbol(errored)]: null,
                      [Symbol(kHighWaterMark)]: 16384,
                      [Symbol(kRejectNonStandardBodyWrites)]: false,
                      [Symbol(kUniqueHeaders)]: null
                      _currentUrl: 'http://undefined/cm?cmnd=Status0',
                      [Symbol(shapeMode)]: true,
                      cause: Error: getaddrinfo ENOTFOUND undefined
                      at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
                      errno: -3008,
                      code: 'ENOTFOUND',
                      2024-08-12 21:45:24.879 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                      code: 'ENOTFOUND',
                      errno: -3008,
                      config: {
                      transitional: {
                      timeout: 0,
                      maxBodyLength: -1,
                      method: 'get',
                      data: undefined
                      request: Writable {
                      _events: {
                      close: undefined,
                      finish: undefined,
                      drain: undefined,
                      length: 0,
                      corked: 0,
                      writelen: 0,
                      bufferedIndex: 0,
                      pendingcb: 0,
                      _maxListeners: 100,
                      _options: {
                      maxRedirects: 21,
                      protocol: 'http:',
                      method: 'GET',
                      agents: [Object],
                      auth: undefined,
                      family: undefined,
                      port: '',
                      agent: undefined,
                      pathname: '/cm',
                      _ended: true,
                      _ending: true,
                      _redirectCount: 0,
                      _redirects: [],
                      _eventsCount: 3,
                      _eventsCount: 7,
                      _maxListeners: 100,
                      outputData: [],
                      outputSize: 0,
                      writable: true,
                      destroyed: false,
                      _last: true,
                      sendDate: false,
                      _removedTE: false,
                      _contentLength: 0,
                      _hasBody: true,
                      _trailer: '',
                      finished: true,
                      _headerSent: true,
                      _closed: false,
                      socket: [Socket],
                      '\r\n',
                      agent: [Agent],
                      method: 'GET',
                      _ended: false,
                      res: null,
                      aborted: false,
                      parser: null,
                      host: 'undefined',
                      protocol: 'http:',
                      errno: -3008,
                      code: 'ENOTFOUND',
                      2024-08-12 21:45:25.215 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
                      2024-08-12 21:45:25.265 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Debug mode disabled
                      2024-08-12 21:45:25.294 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                      2024-08-12 21:45:25.294 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                      2024-08-12 21:45:25.294 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                      2024-08-12 21:45:25.295 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                      2024-08-12 21:45:25.295 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                      2024-08-12 21:45:25.295 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                      2024-08-12 21:45:25.295 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                      2024-08-12 21:45:25.304 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                      2024-08-12 21:45:25.305 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                      2024-08-12 21:45:25.307 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                      2024-08-12 21:45:25.308 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                      2024-08-12 21:45:25.308 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                      2024-08-12 21:45:25.308 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                      2024-08-12 21:45:25.308 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                      2024-08-12 21:45:25.308 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                      2024-08-12 21:45:25.308 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                      2024-08-12 21:45:25.309 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                      2024-08-12 21:45:25.309 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                      2024-08-12 21:45:25.321 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                      2024-08-12 21:45:25.321 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                      2024-08-12 21:45:25.355 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                      2024-08-12 21:45:25.356 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                      2024-08-12 21:45:25.357 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                      2024-08-12 21:45:25.357 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                      2024-08-12 21:45:25.357 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                      2024-08-12 21:45:25.357 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                      2024-08-12 21:45:25.357 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                      2024-08-12 21:45:25.357 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                      2024-08-12 21:45:25.369 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                      2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                      2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                      2024-08-12 21:45:25.370 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                      2024-08-12 21:45:25.370 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                      2024-08-12 21:45:25.370 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                      2024-08-12 21:45:25.370 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                      2024-08-12 21:45:25.370 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                      2024-08-12 21:45:25.370 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                      2024-08-12 21:45:25.370 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                      2024-08-12 21:45:25.379 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                      code: 'ENOTFOUND',
                      errno: -3008,
                      config: {
                      transitional: {
                      timeout: 0,
                      maxBodyLength: -1,
                      method: 'get',
                      url: 'http://undefined/cm?cmnd=GetDriverVersion',
                      data: undefined
                      request: Writable {
                      _events: {
                      close: undefined,
                      finish: undefined,
                      drain: undefined,
                      length: 0,
                      corked: 0,
                      writelen: 0,
                      bufferedIndex: 0,
                      pendingcb: 0,
                      _maxListeners: 100,
                      _options: {
                      maxRedirects: 21,
                      protocol: 'http:',
                      path: '/cm?cmnd=GetDriverVersion',
                      method: 'GET',
                      agents: [Object],
                      auth: undefined,
                      family: undefined,
                      port: '',
                      agent: undefined,
                      pathname: '/cm',
                      search: '?cmnd=GetDriverVersion'
                      _ended: true,
                      _ending: true,
                      _redirectCount: 0,
                      _redirects: [],
                      _eventsCount: 3,
                      _eventsCount: 7,
                      _maxListeners: 100,
                      outputData: [],
                      outputSize: 0,
                      writable: true,
                      destroyed: false,
                      _last: true,
                      sendDate: false,
                      _removedTE: false,
                      _contentLength: 0,
                      _hasBody: true,
                      _trailer: '',
                      finished: true,
                      _headerSent: true,
                      _closed: false,
                      socket: [Socket],
                      _header: 'GET /cm?cmnd=GetDriverVersion HTTP/1.1\r\n' +
                      '\r\n',
                      agent: [Agent],
                      method: 'GET',
                      _ended: false,
                      res: null,
                      aborted: false,
                      parser: null,
                      host: 'undefined',
                      protocol: 'http:',
                      _currentUrl: 'http://undefined/cm?cmnd=GetDriverVersion',
                      errno: -3008,
                      code: 'ENOTFOUND',
                      2024-08-12 21:45:25.413 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                      code: 'ENOTFOUND',
                      errno: -3008,
                      config: {
                      transitional: {
                      timeout: 0,
                      maxBodyLength: -1,
                      method: 'get',
                      data: undefined
                      request: Writable {
                      _events: {
                      close: undefined,
                      finish: undefined,
                      drain: undefined,
                      length: 0,
                      corked: 0,
                      writelen: 0,
                      bufferedIndex: 0,
                      pendingcb: 0,
                      _maxListeners: 100,
                      _options: {
                      maxRedirects: 21,
                      protocol: 'http:',
                      method: 'GET',
                      agents: [Object],
                      auth: undefined,
                      family: undefined,
                      port: '',
                      agent: undefined,
                      pathname: '/cm',
                      _ended: true,
                      _ending: true,
                      _redirectCount: 0,
                      _redirects: [],
                      _eventsCount: 3,
                      _eventsCount: 7,
                      _maxListeners: 100,
                      outputData: [],
                      outputSize: 0,
                      writable: true,
                      destroyed: false,
                      _last: true,
                      sendDate: false,
                      _removedTE: false,
                      _contentLength: 0,
                      _hasBody: true,
                      _trailer: '',
                      finished: true,
                      _headerSent: true,
                      _closed: false,
                      socket: [Socket],
                      '\r\n',
                      agent: [Agent],
                      method: 'GET',
                      _ended: false,
                      res: null,
                      aborted: false,
                      parser: null,
                      host: 'undefined',
                      protocol: 'http:',
                      errno: -3008,
                      code: 'ENOTFOUND',
                      2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
                      2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
                      2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
                      2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
                      2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
                      2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
                      2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
                      2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------
                      2024-08-12 21:45:32.571 - info: admin.0 (407) <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
                      2024-08-12 21:45:36.977 - info: mqtt.0 (509) Client [NSPanel_1] connected with secret 1723491936974_7775
                      2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd\..*/
                      2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_1\.cmnd\..*/
                      2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd\..*/
                      2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd\..*/
                      2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^cmnd\.NSPanel_1_fb\..*/
                      2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^mqtt\.0\.cmnd\.NSPanel_1_fb\..*/
                      2024-08-12 21:45:37.285 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                      2024-08-12 21:45:37.286 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                      2024-08-12 21:45:37.287 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                      • K Karlson 0
                        Leider weiterhin nicht erfolgreich.
                        Mein iobroker läuft jetzt auf einem Debian 12 Container, node 20 ist drauf, npm Module sind jetzt auch eingetragen, und die Instanz javascript wird grün.
                        Bekomme beim Start von NSPanelTS.ts folgende Meldungen:
                        2024-08-12 21:45:15.043 - info: admin.0 (407) ==> Connected system.user.admin from ::ffff:192.168.178.240
                        2024-08-12 21:45:19.220 - info: javascript.0 (458) Compiling TypeScript source script.js.common.NSPanelTs_ts
                        2024-08-12 21:45:24.438 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: TypeScript compilation successful
                        2024-08-12 21:45:24.545 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.545 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.546 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.546 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                        2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                        2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.546 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.548 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.548 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.548 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.549 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.549 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                        2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                        2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.549 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.551 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.551 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.552 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.552 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                        2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                        2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.553 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.554 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.554 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.554 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.554 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.555 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                        2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                        2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.555 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.561 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.561 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.561 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.561 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.561 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                        2024-08-12 21:45:24.561 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                        2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.562 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.562 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.564 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.564 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.564 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.564 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.564 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                        2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                        2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.565 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.567 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.568 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.568 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                        2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                        2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.569 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.569 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.569 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.569 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.570 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                        2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                        2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.570 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.575 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.575 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.575 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.575 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.575 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                        2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                        2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.576 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.578 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.578 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.578 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.579 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.579 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                        2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                        2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.579 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.581 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.581 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.581 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.581 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.581 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                        2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                        2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.582 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.584 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.585 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.585 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                        2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                        2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.586 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.586 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.586 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.587 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.587 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                        2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                        2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.587 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.588 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.588 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.588 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.589 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.589 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                        2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                        2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.589 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.590 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.590 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.591 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.591 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                        2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                        2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.591 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.594 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.594 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.594 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.595 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.595 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                        2024-08-12 21:45:24.595 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                        2024-08-12 21:45:24.595 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.598 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.598 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.598 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.599 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.599 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.599 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.599 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.599 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                        2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                        2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.600 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.602 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.602 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.602 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.602 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                        2024-08-12 21:45:24.602 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                        2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.603 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.603 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.603 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.606 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.606 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.606 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.606 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.607 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                        2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                        2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.607 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.609 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.609 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.609 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.609 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                        2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                        2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.610 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.612 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.612 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.613 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.613 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                        2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                        2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.613 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.615 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                        2024-08-12 21:45:24.615 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                        2024-08-12 21:45:24.615 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                        2024-08-12 21:45:24.616 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                        2024-08-12 21:45:24.616 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                        2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                        2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                        2024-08-12 21:45:24.616 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                        2024-08-12 21:45:24.623 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: nodeJS must be at least v18.X.X. Currently: v14.5.0! Please Update your System! --> iob nodejs-update 18
                        2024-08-12 21:45:24.624 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: setObjects enabled - create Alias Channels possible
                        2024-08-12 21:45:24.630 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: weather alias for accuweather.0. already exists
                        2024-08-12 21:45:24.689 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                        2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                        2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                        2024-08-12 21:45:24.694 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2994:1
                        2024-08-12 21:45:24.694 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                        2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                        2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2024-08-12 21:45:24.726 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                        2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                        2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                        2024-08-12 21:45:24.726 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2986:5
                        2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Object._schedule (script.js.common.NSPanelTs_ts:11224:9)
                        2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3212:34)
                        2024-08-12 21:45:24.726 - warn: javascript.0 (458) at listOnTimeout (node:internal/timers:581:17)
                        2024-08-12 21:45:24.726 - warn: javascript.0 (458) at processTimers (node:internal/timers:519:7)
                        2024-08-12 21:45:24.726 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                        2024-08-12 21:45:24.727 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                        2024-08-12 21:45:24.877 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                        at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14)
                        at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:620:25)
                        at RedirectableRequest.emit (node:events:519:28)
                        at RedirectableRequest.emit (node:domain:488:12)
                        at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)
                        at ClientRequest.emit (node:events:531:35)
                        at ClientRequest.emit (node:domain:488:12)
                        at Socket.socketErrorListener (node:_http_client:500:9)
                        at Socket.emit (node:events:519:28)
                        at Socket.emit (node:domain:488:12)
                        at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)
                        at processTicksAndRejections (node:internal/process/task_queues:95:5) {
                        hostname: 'undefined',
                        syscall: 'getaddrinfo',
                        code: 'ENOTFOUND',
                        errno: -3008,
                        config: {
                        transitional: {
                        silentJSONParsing: true,
                        forcedJSONParsing: true,
                        clarifyTimeoutError: false
                        adapter: [ 'xhr', 'http', 'fetch' ],
                        transformRequest: [ [Function: transformRequest] ],
                        transformResponse: [ [Function: transformResponse] ],
                        timeout: 0,
                        xsrfCookieName: 'XSRF-TOKEN',
                        xsrfHeaderName: 'X-XSRF-TOKEN',
                        maxContentLength: -1,
                        maxBodyLength: -1,
                        env: { FormData: [Function], Blob: [class Blob] },
                        validateStatus: [Function: validateStatus],
                        headers: Object [AxiosHeaders] {
                        Accept: 'application/json, text/plain, */*',
                        'Content-Type': undefined,
                        'User-Agent': 'ioBroker',
                        'Accept-Encoding': 'gzip, compress, deflate, br'
                        method: 'get',
                        url: 'http://undefined/cm?cmnd=Status0',
                        data: undefined
                        request: Writable {
                        _events: {
                        close: undefined,
                        error: [Function: handleRequestError],
                        prefinish: undefined,
                        finish: undefined,
                        drain: undefined,
                        response: [Function: handleResponse],
                        socket: [Function: handleRequestSocket]
                        _writableState: WritableState {
                        highWaterMark: 16384,
                        length: 0,
                        corked: 0,
                        onwrite: [Function: bound onwrite],
                        writelen: 0,
                        bufferedIndex: 0,
                        pendingcb: 0,
                        [Symbol(kState)]: 17580812,
                        [Symbol(kBufferedValue)]: null
                        _maxListeners: 100,
                        _options: {
                        maxRedirects: 21,
                        maxBodyLength: Infinity,
                        protocol: 'http:',
                        path: '/cm?cmnd=Status0',
                        method: 'GET',
                        headers: [Object: null prototype],
                        agents: [Object],
                        auth: undefined,
                        family: undefined,
                        beforeRedirect: [Function: dispatchBeforeRedirect],
                        beforeRedirects: [Object],
                        port: '',
                        agent: undefined,
                        nativeProtocols: [Object],
                        pathname: '/cm',
                        search: '?cmnd=Status0'
                        _ended: true,
                        _ending: true,
                        _redirectCount: 0,
                        _redirects: [],
                        _requestBodyLength: 0,
                        _requestBodyBuffers: [],
                        _eventsCount: 3,
                        _onNativeResponse: [Function (anonymous)],
                        _currentRequest: ClientRequest {
                        _events: [Object: null prototype],
                        _eventsCount: 7,
                        _maxListeners: 100,
                        outputData: [],
                        outputSize: 0,
                        writable: true,
                        destroyed: false,
                        _last: true,
                        chunkedEncoding: false,
                        shouldKeepAlive: true,
                        maxRequestsOnConnectionReached: false,
                        _defaultKeepAlive: true,
                        useChunkedEncodingByDefault: false,
                        sendDate: false,
                        _removedConnection: false,
                        _removedContLen: false,
                        _removedTE: false,
                        strictContentLength: false,
                        _contentLength: 0,
                        _hasBody: true,
                        _trailer: '',
                        finished: true,
                        _headerSent: true,
                        _closed: false,
                        socket: [Socket],
                        _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' +
                        'Accept: application/json, text/plain, */*\r\n' +
                        'User-Agent: ioBroker\r\n' +
                        'Accept-Encoding: gzip, compress, deflate, br\r\n' +
                        'sentry-trace: 49d0d7813b8c428eab3645c24d1a50f8-98b170a0ea551350\r\n' +
                        'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=49d0d7813b8c428eab3645c24d1a50f8\r\n' +
                        'Host: undefined\r\n' +
                        'Connection: keep-alive\r\n' +
                        '\r\n',
                        _keepAliveTimeout: 0,
                        _onPendingData: [Function: nop],
                        agent: [Agent],
                        socketPath: undefined,
                        method: 'GET',
                        maxHeaderSize: undefined,
                        insecureHTTPParser: undefined,
                        joinDuplicateHeaders: undefined,
                        _ended: false,
                        res: null,
                        aborted: false,
                        timeoutCb: [Function: emitRequestTimeout],
                        upgradeOrConnect: false,
                        parser: null,
                        maxHeadersCount: null,
                        reusedSocket: false,
                        host: 'undefined',
                        protocol: 'http:',
                        _redirectable: [Circular *1],
                        [Symbol(shapeMode)]: false,
                        [Symbol(kCapture)]: false,
                        [Symbol(kBytesWritten)]: 0,
                        [Symbol(kNeedDrain)]: false,
                        [Symbol(corked)]: 0,
                        [Symbol(kOutHeaders)]: [Object: null prototype],
                        [Symbol(errored)]: null,
                        [Symbol(kHighWaterMark)]: 16384,
                        [Symbol(kRejectNonStandardBodyWrites)]: false,
                        [Symbol(kUniqueHeaders)]: null
                        _currentUrl: 'http://undefined/cm?cmnd=Status0',
                        [Symbol(shapeMode)]: true,
                        cause: Error: getaddrinfo ENOTFOUND undefined
                        at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
                        errno: -3008,
                        code: 'ENOTFOUND',
                        2024-08-12 21:45:24.879 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                        code: 'ENOTFOUND',
                        errno: -3008,
                        config: {
                        transitional: {
                        timeout: 0,
                        maxBodyLength: -1,
                        method: 'get',
                        data: undefined
                        request: Writable {
                        _events: {
                        close: undefined,
                        finish: undefined,
                        drain: undefined,
                        length: 0,
                        corked: 0,
                        writelen: 0,
                        bufferedIndex: 0,
                        pendingcb: 0,
                        _maxListeners: 100,
                        _options: {
                        maxRedirects: 21,
                        protocol: 'http:',
                        method: 'GET',
                        agents: [Object],
                        auth: undefined,
                        family: undefined,
                        port: '',
                        agent: undefined,
                        pathname: '/cm',
                        _ended: true,
                        _ending: true,
                        _redirectCount: 0,
                        _redirects: [],
                        _eventsCount: 3,
                        _eventsCount: 7,
                        _maxListeners: 100,
                        outputData: [],
                        outputSize: 0,
                        writable: true,
                        destroyed: false,
                        _last: true,
                        sendDate: false,
                        _removedTE: false,
                        _contentLength: 0,
                        _hasBody: true,
                        _trailer: '',
                        finished: true,
                        _headerSent: true,
                        _closed: false,
                        socket: [Socket],
                        '\r\n',
                        agent: [Agent],
                        method: 'GET',
                        _ended: false,
                        res: null,
                        aborted: false,
                        parser: null,
                        host: 'undefined',
                        protocol: 'http:',
                        errno: -3008,
                        code: 'ENOTFOUND',
                        2024-08-12 21:45:25.215 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
                        2024-08-12 21:45:25.265 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Debug mode disabled
                        2024-08-12 21:45:25.294 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                        2024-08-12 21:45:25.294 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                        2024-08-12 21:45:25.294 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                        2024-08-12 21:45:25.295 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                        2024-08-12 21:45:25.295 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                        2024-08-12 21:45:25.295 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                        2024-08-12 21:45:25.295 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                        2024-08-12 21:45:25.304 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                        2024-08-12 21:45:25.305 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                        2024-08-12 21:45:25.307 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                        2024-08-12 21:45:25.308 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                        2024-08-12 21:45:25.308 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                        2024-08-12 21:45:25.308 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                        2024-08-12 21:45:25.308 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                        2024-08-12 21:45:25.308 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                        2024-08-12 21:45:25.308 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                        2024-08-12 21:45:25.309 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                        2024-08-12 21:45:25.309 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                        2024-08-12 21:45:25.321 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                        2024-08-12 21:45:25.321 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                        2024-08-12 21:45:25.355 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                        2024-08-12 21:45:25.356 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                        2024-08-12 21:45:25.357 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                        2024-08-12 21:45:25.357 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                        2024-08-12 21:45:25.357 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                        2024-08-12 21:45:25.357 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                        2024-08-12 21:45:25.357 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                        2024-08-12 21:45:25.357 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                        2024-08-12 21:45:25.369 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                        2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                        2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                        2024-08-12 21:45:25.370 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                        2024-08-12 21:45:25.370 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                        2024-08-12 21:45:25.370 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                        2024-08-12 21:45:25.370 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                        2024-08-12 21:45:25.370 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                        2024-08-12 21:45:25.370 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                        2024-08-12 21:45:25.370 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                        2024-08-12 21:45:25.379 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                        code: 'ENOTFOUND',
                        errno: -3008,
                        config: {
                        transitional: {
                        timeout: 0,
                        maxBodyLength: -1,
                        method: 'get',
                        url: 'http://undefined/cm?cmnd=GetDriverVersion',
                        data: undefined
                        request: Writable {
                        _events: {
                        close: undefined,
                        finish: undefined,
                        drain: undefined,
                        length: 0,
                        corked: 0,
                        writelen: 0,
                        bufferedIndex: 0,
                        pendingcb: 0,
                        _maxListeners: 100,
                        _options: {
                        maxRedirects: 21,
                        protocol: 'http:',
                        path: '/cm?cmnd=GetDriverVersion',
                        method: 'GET',
                        agents: [Object],
                        auth: undefined,
                        family: undefined,
                        port: '',
                        agent: undefined,
                        pathname: '/cm',
                        search: '?cmnd=GetDriverVersion'
                        _ended: true,
                        _ending: true,
                        _redirectCount: 0,
                        _redirects: [],
                        _eventsCount: 3,
                        _eventsCount: 7,
                        _maxListeners: 100,
                        outputData: [],
                        outputSize: 0,
                        writable: true,
                        destroyed: false,
                        _last: true,
                        sendDate: false,
                        _removedTE: false,
                        _contentLength: 0,
                        _hasBody: true,
                        _trailer: '',
                        finished: true,
                        _headerSent: true,
                        _closed: false,
                        socket: [Socket],
                        _header: 'GET /cm?cmnd=GetDriverVersion HTTP/1.1\r\n' +
                        '\r\n',
                        agent: [Agent],
                        method: 'GET',
                        _ended: false,
                        res: null,
                        aborted: false,
                        parser: null,
                        host: 'undefined',
                        protocol: 'http:',
                        _currentUrl: 'http://undefined/cm?cmnd=GetDriverVersion',
                        errno: -3008,
                        code: 'ENOTFOUND',
                        2024-08-12 21:45:25.413 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                        code: 'ENOTFOUND',
                        errno: -3008,
                        config: {
                        transitional: {
                        timeout: 0,
                        maxBodyLength: -1,
                        method: 'get',
                        data: undefined
                        request: Writable {
                        _events: {
                        close: undefined,
                        finish: undefined,
                        drain: undefined,
                        length: 0,
                        corked: 0,
                        writelen: 0,
                        bufferedIndex: 0,
                        pendingcb: 0,
                        _maxListeners: 100,
                        _options: {
                        maxRedirects: 21,
                        protocol: 'http:',
                        method: 'GET',
                        agents: [Object],
                        auth: undefined,
                        family: undefined,
                        port: '',
                        agent: undefined,
                        pathname: '/cm',
                        _ended: true,
                        _ending: true,
                        _redirectCount: 0,
                        _redirects: [],
                        _eventsCount: 3,
                        _eventsCount: 7,
                        _maxListeners: 100,
                        outputData: [],
                        outputSize: 0,
                        writable: true,
                        destroyed: false,
                        _last: true,
                        sendDate: false,
                        _removedTE: false,
                        _contentLength: 0,
                        _hasBody: true,
                        _trailer: '',
                        finished: true,
                        _headerSent: true,
                        _closed: false,
                        socket: [Socket],
                        '\r\n',
                        agent: [Agent],
                        method: 'GET',
                        _ended: false,
                        res: null,
                        aborted: false,
                        parser: null,
                        host: 'undefined',
                        protocol: 'http:',
                        errno: -3008,
                        code: 'ENOTFOUND',
                        2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
                        2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
                        2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
                        2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
                        2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
                        2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
                        2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
                        2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------
                        2024-08-12 21:45:32.571 - info: admin.0 (407) <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
                        2024-08-12 21:45:36.977 - info: mqtt.0 (509) Client [NSPanel_1] connected with secret 1723491936974_7775
                        2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd\..*/
                        2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_1\.cmnd\..*/
                        2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd\..*/
                        2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd\..*/
                        2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^cmnd\.NSPanel_1_fb\..*/
                        2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^mqtt\.0\.cmnd\.NSPanel_1_fb\..*/
                        2024-08-12 21:45:37.285 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                        2024-08-12 21:45:37.286 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                        2024-08-12 21:45:37.287 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        Most Active Forum Testing
                        @karlson-0 sagte in SONOFF NSPanel Lovelance UI Rückgängig machen:
                        Das Problem liegt immer noch im falschen Script Parameter:
                        Im Result Connection String für MQTT (im NSPanelTs.ts Script) sollte:
                        mqtt.0.SmartHome.NSPanel_1.tele.RESULT
                        stehen...
                        Bitte erneut die:
                        • Einstellungen im Tasmota (MQTT)
                        • Objekte unter mqtt.0.SmartHome.NSPanel_1
                        • Einstellungen der mqtt.0. Instanz
                        senden.
                        Dein Problem liegt nach wie vor in der MQTT-Kommunikation...
                        • ArmilarA Armilar
                          stehen...
                          Bitte erneut die:
                          senden.
                          Karlson 0
                          @armilar
                          Bitteschön:
                          • K Karlson 0
                            @armilar
                            Bitteschön:
                            Karlson 0
                            @karlson-0
                            Hier das Ergebnis mit der Änderung tele.result:
                            2024-08-12 22:12:45.360 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: TypeScript compilation successful
                            2024-08-12 22:12:45.462 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.463 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.464 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                            2024-08-12 22:12:45.465 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                            2024-08-12 22:12:45.466 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.467 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.468 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.469 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.469 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.469 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.469 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.469 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                            2024-08-12 22:12:45.469 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                            2024-08-12 22:12:45.469 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.469 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.469 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.470 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.471 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.472 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.473 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.474 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.475 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.476 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.477 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.478 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.479 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.480 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.481 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.482 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.483 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.484 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.485 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.486 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.487 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.488 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.489 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.490 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.491 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.492 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.493 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.494 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.495 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                            2024-08-12 22:12:45.496 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                            2024-08-12 22:12:45.497 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.497 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.497 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.497 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.497 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.497 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.498 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.498 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.498 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                            2024-08-12 22:12:45.498 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                            2024-08-12 22:12:45.498 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.498 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.498 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.498 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.498 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 22:12:45.499 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Config-Parameter: << config.panelRecvTopic - mqtt.0.SmartHome.NSPanel_1.tele.RESULT >> is not reachable. Please Check Parameters!
                            2024-08-12 22:12:45.512 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: nodeJS must be at least v18.X.X. Currently: v14.5.0! Please Update your System! --> iob nodejs-update 18
                            2024-08-12 22:12:45.513 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: setObjects enabled - create Alias Channels possible
                            2024-08-12 22:12:45.517 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: weather alias for accuweather.0. already exists
                            2024-08-12 22:12:45.524 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                            2024-08-12 22:12:45.525 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            2024-08-12 22:12:45.528 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                            2024-08-12 22:12:45.835 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
                            2024-08-12 22:12:45.891 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Debug mode disabled
                            2024-08-12 22:12:46.199 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has been written without ack-flag with value "[object Object]"
                            2024-08-12 22:12:46.199 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has to be type "string" but received type "object"
                            2024-08-12 22:12:46.240 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has been written without ack-flag with value "[object Object]"
                            2024-08-12 22:12:46.240 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has to be type "string" but received type "object"
                            2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
                            2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
                            2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
                            2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
                            2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
                            2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
                            2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
                            2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------```
                            • K Karlson 0
                              @karlson-0
                              ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              @karlson-0
                              Okay... schon besser:
                              Die oberen dayjs-Meldungen sind erstmal irrelevant. Haben andere auch, kommen aktuell nur zum Start und hindert den Start des NSPanels auch nicht. Kommt nicht bei allen Usern - ist aber ein Thema außerhalb des Scriptes zwischen JS-Adapter/JS-Controller... also erstmal ignorieren...
                              "mqtt.0.SmartHome.NSPanel_1.tele.INFO2" ist vorhanden - dennoch kommt diese Nachricht:
                              Kannst du mal den dritten Reiter aus der MQTT-Instanz posten
                              EDIT:
                              Wir müssen also nur noch dieses Problem lösen:
                              Danach läuft das Panel...
                              EDIT2: Auch hier würde @TT-Tom wieder anmerken, dass da der Datenpunkt "tele.RESULT" im MQTT bei dir nicht vorhanden ist.
                              Sieht so aus, als würde der Berry-Driver im Tasmota nicht existieren...
                              • ArmilarA Armilar
                                @karlson-0
                                EDIT:
                                Karlson 0
                                @armilar
                                Bitteschön:
                                • K Karlson 0
                                  @armilar
                                  Bitteschön:
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  @karlson-0
                                  Siehe Vorherige Nachricht... Bitte den Berry-Driver nochmal installieren...
                                  Danach auf jeden Fall Tasmota neu starten
                                  • ArmilarA Armilar
                                    @karlson-0
                                    Karlson 0
                                    @armilar
                                    @Homoran
                                    @Samson71
                                    @Thomas-Braun
                                    @TT-Tom
                                    Es läuft endlich, vielen lieben Dank an euch.
                                    • K Karlson 0
                                      @armilar
                                      @Homoran
                                      @Samson71
                                      @Thomas-Braun
                                      @TT-Tom
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      @karlson-0
                                      Bingo 😊
                                      Die Anleitung mit vielen Beispielen ist hier
                                      Und hier bekommst du bei Fragen und Problemchen schnell Hilfe:
                                      https://forum.iobroker.net/topic/58170/sonoff-nspanel-mit-lovelace-ui?page=1
                                      Einfach zum letzten Beitrag, auf Antworten klicken und lostippen ;-)
                                      Hier sind auch noch interessante Sachen:
                                      https://forum.iobroker.net/topic/69942/sonoff-nspanel-mit-lovelace-ui-zeigt-her-eure-cards?_=1723495308865
                                      • ArmilarA Armilar
                                        @karlson-0
                                        Bingo 😊
                                        Karlson 0
                                        Hallo Zusammen,
                                        ich habe mal wieder mein NS Panel geschrottet, könnt ihr mir bitte sagen, was ich zuerst überprüfen soll ?
                                        Mein NS Panel hat wieder den Tollen "Waiting for content" Bildschirm
                                        javascript.0
                                        2025-09-11 21:04:23.156	error	script.js.common.NSPanelTs_ts: TypeScript compilation failed: SendToPanel({ payload: 'dimmode~' + getState(NSPanel_Path + 'ScreensaverInfo.activeDimmodeBrightness').val + '~' + getState(NSPanel_Path + 'ScreensaverInfo.activeBrightness').val ?? 80 + '~' + rgb_dec565(config.defaultBackgroundColor) + '~' + rgb_dec565(globalTextColor) + '~' + Sliders2 }); ^ERROR: Right operand of ?? is unreachable because the left operand is never nullish. SendToPanel({ payload: 'dimmode~' + timeDimMode.brightnessDay + '~' + getState(NSPanel_Path + 'ScreensaverInfo.activeBrightness').val ?? 80 + '~' + rgb_dec565(config.defaultBackgroundColor) + '~' + rgb_dec565(globalTextColor) + '~' + Sliders2 }); ^ERROR: Right operand of ?? is unreachable because the left operand is never nullish. SendToPanel({ payload: 'dimmode~' + timeDimMode.brightnessNight + '~' + getState(NSPanel_Path + 'ScreensaverInfo.activeBrightness').val ?? 80 + '~' + rgb_dec565(config.defaultBackgroundColor) + '~' + rgb_dec565(globalTextColor) + '~' + Sliders2 }); ^ERROR: Right operand of ?? is unreachable because the left operand is never nullish.
                                        Danke schonmal vorab
                                        • K Karlson 0
                                          Hallo Zusammen,
                                          javascript.0
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          2025-09-11 21:04:23.156 error script.js.common.NSPanelTs_ts: TypeScript compilation failed: SendToPanel({ payload: 'dimmode~' + getState(NSPanel_Path + 'ScreensaverInfo.activeDimmodeBrightness').val + '~' + getState(NSPanel_Path + 'ScreensaverInfo.activeBrightne...
                                          Hmm... Das sieht mir nach einem alten Script aus, dass ggfs. Probleme mit neuem JS-Adapter, etc. haben könnte...
                                          Ich bräuchte die Scriptversion vom NSPanelTS.ts und die Version des JS-Adapters...
                                          Da wir wahrscheinlich nicht nachvollziehen können mit welchen deiner Änderungen am ioBroker das passiert ist, würde ich vorschlagen, dass du den unteren Teil des Skriptes in die NSPanel-Version 5.0.0.1 bringst...
                                          EDIT: Ach ja... Das NSPanel wartet nur auf Content und ist noch Top okay... könnte danach wahrscheinlich auch ein FlashNextion zur neuen Version 5.0.0 gebrauchen... Auch der Berry ist jetzt in der Version 10... Aber mit dem physischen NSPanel hat das hier nichts zu tun... Typescript ist nur restriktiver geworden und mag den alten Code nicht mehr...
