  4. SONOFF NSPanel Lovelance UI Rückgängig machen
35 Beiträge 6 Kommentatoren 4.1k Aufrufe 2 Beobachtet
  • K Karlson 0
    @tt-tom danke, nicht die Antwort, die ich erhofft habe, aber ich muss wohl damit leben, und das ding jetzt zum Laufen bringen.
    Wenn ich das Script Starte bekomme ich folgende Fehlermeldungen:
    javascript.0
    2024-08-07 19:57:01.650 info script.js.common.NSPanelTs_ts: No Updates for NSPanel available
    javascript.0
    2024-08-07 19:57:01.823 error script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:620:25) at RedirectableRequest.emit (node:events:513:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:481:9) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at Axios.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { hostname: 'undefined', syscall: 'getaddrinfo', code: 'ENOTFOUND', errno: -3008, config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, /', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://undefined/cm?cmnd=Status0', data: undefined }, request: <ref *1> Writable { _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: false, decodeStrings: true, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: true, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: true, autoDestroy: true, errored: null, closed: false, closeEmitted: false, [Symbol(kOnFinished)]: [] }, _events: [Object: null prototype] { response: [Function: handleResponse], error: [Function: handleRequestError], socket: [Function: handleRequestSocket] }, _eventsCount: 3, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Status0', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: 'undefined', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Status0' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, /\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 7f690517773d4ceea50d74be57dfd8af-b818672b904075d2\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=7f690517773d4ceea50d74be57dfd8af\r\n' + 'Host: undefined\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, path: '/cm?cmnd=Status0', _ended: false, res: null, aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: 'undefined', protocol: 'http:', _redirectable: [Circular *1], [Symbol(kCapture)]: false, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://undefined/cm?cmnd=Status0', [Symbol(kCapture)]: false }, cause: Error: getaddrinfo ENOTFOUND undefined at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:111:26) { errno: -3008, code: 'ENOTFOUND', syscall: 'getaddrinfo', hostname: 'undefined' }}
    javascript.0
    2024-08-07 19:57:01.969 error script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:620:25) at RedirectableRequest.emit (node:events:513:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:481:9) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at Axios.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { hostname: 'undefined', syscall: 'getaddrinfo', code: 'ENOTFOUND', errno: -3008, config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, /', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://undefined/cm?cmnd=Status0', data: undefined }, request: <ref *1> Writable { _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: false, decodeStrings: true, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: true, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: true, autoDestroy: true, errored: null, closed: false, closeEmitted: false, [Symbol(kOnFinished)]: [] }, _events: [Object: null prototype] { response: [Function: handleResponse], error: [Function: handleRequestError], socket: [Function: handleRequestSocket] }, _eventsCount: 3, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Status0', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: 'undefined', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Status0' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, /\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 7f690517773d4ceea50d74be57dfd8af-af3c1705d05ef682\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=7f690517773d4ceea50d74be57dfd8af\r\n' + 'Host: undefined\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, path: '/cm?cmnd=Status0', _ended: false, res: null, aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: 'undefined', protocol: 'http:', _redirectable: [Circular *1], [Symbol(kCapture)]: false, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://undefined/cm?cmnd=Status0', [Symbol(kCapture)]: false }, cause: Error: getaddrinfo ENOTFOUND undefined at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:111:26) { errno: -3008, code: 'ENOTFOUND', syscall: 'getaddrinfo', hostname: 'undefined' }}
    javascript.0
    2024-08-07 19:57:02.389 info script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
    javascript.0
    2024-08-07 19:57:02.511 info script.js.common.NSPanelTs_ts: Debug mode disabled
    javascript.0
    2024-08-07 19:57:02.753 warn getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
    javascript.0
    2024-08-07 19:57:02.756 warn at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
    javascript.0
    2024-08-07 19:57:02.756 warn at script.js.common.NSPanelTs_ts:3341:99
    javascript.0
    2024-08-07 19:57:02.756 warn at step (script.js.common.NSPanelTs_ts:33:23)
    javascript.0
    2024-08-07 19:57:02.757 warn at Object.next (script.js.common.NSPanelTs_ts:14:53)
    javascript.0
    2024-08-07 19:57:02.757 warn at fulfilled (script.js.common.NSPanelTs_ts:5:58)
    javascript.0
    2024-08-07 19:57:02.757 warn at runNextTicks (node:internal/process/task_queues:60:5)
    javascript.0
    2024-08-07 19:57:02.757 warn at processImmediate (node:internal/timers:442:9)
    javascript.0
    2024-08-07 19:57:02.757 warn script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
    javascript.0
    2024-08-07 19:57:02.778 warn getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
    javascript.0
    2024-08-07 19:57:02.779 warn at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
    javascript.0
    2024-08-07 19:57:02.779 warn at script.js.common.NSPanelTs_ts:3341:99
    javascript.0
    2024-08-07 19:57:02.779 warn at step (script.js.common.NSPanelTs_ts:33:23)
    javascript.0
    2024-08-07 19:57:02.779 warn at Object.next (script.js.common.NSPanelTs_ts:14:53)
    javascript.0
    2024-08-07 19:57:02.779 warn at fulfilled (script.js.common.NSPanelTs_ts:5:58)
    javascript.0
    2024-08-07 19:57:02.779 warn at runNextTicks (node:internal/process/task_queues:60:5)
    javascript.0
    2024-08-07 19:57:02.779 warn at processImmediate (node:internal/timers:442:9)
    javascript.0
    2024-08-07 19:57:02.779 warn script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
    javascript.0
    2024-08-07 19:57:02.780 warn Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
    javascript.0
    2024-08-07 19:57:02.781 info State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
    javascript.0
    2024-08-07 19:57:02.790 warn Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
    javascript.0
    2024-08-07 19:57:02.791 info State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
    javascript.0
    2024-08-07 19:57:02.870 warn getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
    javascript.0
    2024-08-07 19:57:02.871 warn at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
    javascript.0
    2024-08-07 19:57:02.871 warn at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
    javascript.0
    2024-08-07 19:57:02.871 warn at script.js.common.NSPanelTs_ts:3352:21
    javascript.0
    2024-08-07 19:57:02.871 warn at step (script.js.common.NSPanelTs_ts:33:23)
    javascript.0
    2024-08-07 19:57:02.871 warn at Object.next (script.js.common.NSPanelTs_ts:14:53)
    javascript.0
    2024-08-07 19:57:02.871 warn at fulfilled (script.js.common.NSPanelTs_ts:5:58)
    javascript.0
    2024-08-07 19:57:02.871 warn script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
    javascript.0
    2024-08-07 19:57:02.897 warn script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:620:25) at RedirectableRequest.emit (node:events:513:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:481:9) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at Axios.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { hostname: 'undefined', syscall: 'getaddrinfo', code: 'ENOTFOUND', errno: -3008, config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, /', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://undefined/cm?cmnd=GetDriverVersion', data: undefined }, request: <ref *1> Writable { _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: false, decodeStrings: true, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: true, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: true, autoDestroy: true, errored: null, closed: false, closeEmitted: false, [Symbol(kOnFinished)]: [] }, _events: [Object: null prototype] { response: [Function: handleResponse], error: [Function: handleRequestError], socket: [Function: handleRequestSocket] }, _eventsCount: 3, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=GetDriverVersion', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: 'undefined', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=GetDriverVersion' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=GetDriverVersion HTTP/1.1\r\n' + 'Accept: application/json, text/plain, /\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 7f690517773d4ceea50d74be57dfd8af-b0197d35366d4aa6\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=7f690517773d4ceea50d74be57dfd8af\r\n' + 'Host: undefined\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, path: '/cm?cmnd=GetDriverVersion', _ended: false, res: null, aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: 'undefined', protocol: 'http:', _redirectable: [Circular *1], [Symbol(kCapture)]: false, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://undefined/cm?cmnd=GetDriverVersion', [Symbol(kCapture)]: false }, cause: Error: getaddrinfo ENOTFOUND undefined at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:111:26) { errno: -3008, code: 'ENOTFOUND', syscall: 'getaddrinfo', hostname: 'undefined' }}
    javascript.0
    2024-08-07 19:57:02.909 warn getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
    javascript.0
    2024-08-07 19:57:02.909 warn at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
    javascript.0
    2024-08-07 19:57:02.909 warn at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
    javascript.0
    2024-08-07 19:57:02.909 warn at script.js.common.NSPanelTs_ts:3352:21
    javascript.0
    2024-08-07 19:57:02.909 warn at step (script.js.common.NSPanelTs_ts:33:23)
    javascript.0
    2024-08-07 19:57:02.909 warn at Object.next (script.js.common.NSPanelTs_ts:14:53)
    javascript.0
    2024-08-07 19:57:02.910 warn at fulfilled (script.js.common.NSPanelTs_ts:5:58)
    javascript.0
    2024-08-07 19:57:02.910 warn script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
    javascript.0
    2024-08-07 19:57:02.946 warn script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:620:25) at RedirectableRequest.emit (node:events:513:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:481:9) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at Axios.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { hostname: 'undefined', syscall: 'getaddrinfo', code: 'ENOTFOUND', errno: -3008, config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, /', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://undefined/cm?cmnd=GetDriverVersion', data: undefined }, request: <ref *1> Writable { _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: false, decodeStrings: true, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: true, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: true, autoDestroy: true, errored: null, closed: false, closeEmitted: false, [Symbol(kOnFinished)]: [] }, _events: [Object: null prototype] { response: [Function: handleResponse], error: [Function: handleRequestError], socket: [Function: handleRequestSocket] }, _eventsCount: 3, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=GetDriverVersion', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: 'undefined', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=GetDriverVersion' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=GetDriverVersion HTTP/1.1\r\n' + 'Accept: application/json, text/plain, /\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 7f690517773d4ceea50d74be57dfd8af-84367abd971d3763\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=7f690517773d4ceea50d74be57dfd8af\r\n' + 'Host: undefined\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, path: '/cm?cmnd=GetDriverVersion', _ended: false, res: null, aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: 'undefined', protocol: 'http:', _redirectable: [Circular *1], [Symbol(kCapture)]: false, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://undefined/cm?cmnd=GetDriverVersion', [Symbol(kCapture)]: false }, cause: Error: getaddrinfo ENOTFOUND undefined at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:111:26) { errno: -3008, code: 'ENOTFOUND', syscall: 'getaddrinfo', hostname: 'undefined' }}
    admin.0
    2024-08-07 19:57:05.692 info <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
    admin.0
    2024-08-07 21:57:05.692 info <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
    javascript.0
    2024-08-07 21:57:05.768 info script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
    javascript.0
    2024-08-07 21:57:05.769 info script.js.common.NSPanelTs_ts: -- admin.0 - 8081
    javascript.0
    2024-08-07 21:57:05.769 info script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
    javascript.0
    2024-08-07 21:57:05.769 info script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
    javascript.0
    2024-08-07 21:57:05.769 info script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
    javascript.0
    2024-08-07 21:57:05.769 info script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
    javascript.0
    2024-08-07 21:57:05.769 info script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
    javascript.0
    2024-08-07 21:57:05.769 info script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------
    Kannst du diese Meldungen für mich in To Do´s übersetzten ?
    Samson71S Offline
    Samson71S Offline
    Samson71
    @karlson-0
    Das kann so keiner anständig lesen. Pack das mal in Code-Tags </>. Das zu editieren ist am Handy Mist.
    Markus
    Bitte beachten:
    • K Karlson 0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      admin.0
      admin.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      TT-Tom
      @karlson-0
      Muss Samson71 recht geben, so kann ich dir nicht helfen.
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      • T TT-Tom
        @karlson-0
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        Most Active Forum Testing
        @tt-tom
        @Samson71
        Gebe euch Recht... Vernünftig Formatieren würde helfen...
        Das Problem liegt in den MQTT-Verbindungsparametern ;)
        Die IP kann nicht gefunden werden, weil Status0 bzw. Info2 nicht gelesen werden kann... Der Rest ist Folgefehler...
        scheint im Script nicht gefunden zu werden...
        @Karlson-0
        Bitte mal die Verbindungsparameter für "RESULT" und "CustomSend" im TS-Script posten und einen Screenshot aus den Objekten des mqtt.0. machen.
        Ebenfalls wäre ein Screenshot aus den Tasmota-MQTT-Einstellungen hilfreich...
        • ArmilarA Armilar
          @tt-tom
          @Samson71
          @Karlson-0
          Karlson 0
          @armilar
          Sorry, ist so hoffentlich besser.
          2024-08-09 18:15:39.512 - info: admin.0 (178) <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
          2024-08-09 18:15:48.401 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
          2024-08-09 18:15:48.401 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
          2024-08-09 18:15:48.401 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
          2024-08-09 18:15:48.401 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
          2024-08-09 18:15:48.401 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
          2024-08-09 18:15:48.401 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
          2024-08-09 18:15:48.402 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
          2024-08-09 18:15:48.402 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------
          2024-08-09 18:18:19.858 - info: admin.0 (178) ==> Connected system.user.admin from ::ffff:192.168.178.240
          2024-08-09 18:18:23.672 - info: javascript.0 (185) Stopping script script.js.common.NSPanelTs_ts
          2024-08-09 18:18:26.986 - info: admin.0 (178) <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
          2024-08-09 18:19:03.370 - info: admin.0 (178) ==> Connected system.user.admin from ::ffff:192.168.178.240
          2024-08-09 18:19:11.186 - info: javascript.0 (185) Compiling TypeScript source script.js.common.NSPanelTs_ts
          2024-08-09 18:19:12.462 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: source code did not change, using cached compilation result...
          2024-08-09 18:19:12.568 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs'
          2024-08-09 18:19:12.568 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.568 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.568 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.568 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:979:13
          2024-08-09 18:19:12.568 - error: javascript.0 (185) at Script.runInContext (node:vm:141:12)
          2024-08-09 18:19:12.569 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/moment-parseformat'
          2024-08-09 18:19:12.569 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.569 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.569 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.569 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:981:19
          2024-08-09 18:19:12.569 - error: javascript.0 (185) at Script.runInContext (node:vm:141:12)
          2024-08-09 18:19:12.571 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs'
          2024-08-09 18:19:12.571 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.571 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.571 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.571 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:992:27
          2024-08-09 18:19:12.571 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.571 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.571 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.571 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.572 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/en'
          2024-08-09 18:19:12.572 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.572 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.572 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.572 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.572 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.572 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.572 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.572 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.573 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/de'
          2024-08-09 18:19:12.573 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.573 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.573 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.573 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.573 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.573 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.573 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.573 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.573 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/nl'
          2024-08-09 18:19:12.574 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.574 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.574 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.574 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.574 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.574 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.574 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.574 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.574 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/da'
          2024-08-09 18:19:12.575 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.575 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.575 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.575 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.575 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.575 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.575 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/es'
          2024-08-09 18:19:12.575 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.575 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.576 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.576 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.576 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.576 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.576 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/fr'
          2024-08-09 18:19:12.576 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.576 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.577 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.577 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.577 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.577 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.580 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.580 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.581 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/it'
          2024-08-09 18:19:12.581 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.581 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.581 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.581 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.581 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.581 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.581 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.581 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.582 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/ru'
          2024-08-09 18:19:12.582 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.582 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.582 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.582 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.582 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.582 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.582 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.582 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.583 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/nb'
          2024-08-09 18:19:12.583 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.583 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.583 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.583 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.583 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.583 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.586 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.586 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.586 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/nn'
          2024-08-09 18:19:12.586 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.586 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.587 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.587 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.587 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.587 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.587 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.587 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.589 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/pl'
          2024-08-09 18:19:12.589 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.589 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.589 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.589 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.589 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.589 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.589 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.589 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.590 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/pt'
          2024-08-09 18:19:12.590 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.590 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.590 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.590 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.590 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.590 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.590 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.590 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.591 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/af'
          2024-08-09 18:19:12.591 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.591 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.591 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.591 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.591 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.591 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.591 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.591 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.592 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/ar'
          2024-08-09 18:19:12.592 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.592 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.592 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.592 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.592 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.592 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.592 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.592 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.593 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/bg'
          2024-08-09 18:19:12.593 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.593 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.593 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.593 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.593 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.593 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.593 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.593 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.594 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/ca'
          2024-08-09 18:19:12.594 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.594 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.594 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.594 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.594 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.594 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.594 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.594 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.595 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/cs'
          2024-08-09 18:19:12.595 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.595 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.595 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.595 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.595 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.595 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.595 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.595 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.595 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/el'
          2024-08-09 18:19:12.596 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.596 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.596 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.596 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.596 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.596 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.596 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.596 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.596 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/et'
          2024-08-09 18:19:12.597 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.597 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.597 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.597 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.597 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.597 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.597 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.597 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/fa'
          2024-08-09 18:19:12.597 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.598 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.598 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.598 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.598 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.598 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/fi'
          2024-08-09 18:19:12.601 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.601 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.601 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.601 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.601 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.601 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.601 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.601 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.601 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/he'
          2024-08-09 18:19:12.602 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.602 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.602 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.602 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.602 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.602 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.602 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.602 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.602 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/hr'
          2024-08-09 18:19:12.603 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.603 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.603 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.603 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.603 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.603 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.603 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/hu'
          2024-08-09 18:19:12.603 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.603 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.604 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.604 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.604 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.604 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.604 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/hy-am'
          2024-08-09 18:19:12.604 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.604 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.604 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.604 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.605 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.605 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.605 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/id'
          2024-08-09 18:19:12.605 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.605 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.605 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.605 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.605 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.605 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.606 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.606 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.606 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/is'
          2024-08-09 18:19:12.606 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.606 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.606 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.606 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.606 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.606 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.607 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/lb'
          2024-08-09 18:19:12.607 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.607 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.607 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.607 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.607 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.607 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.607 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.607 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.608 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/lt'
          2024-08-09 18:19:12.608 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.608 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.608 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.608 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.608 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.608 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.608 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.608 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.609 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/ro'
          2024-08-09 18:19:12.609 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.609 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.609 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.609 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.609 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.609 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.609 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.609 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.610 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/sk'
          2024-08-09 18:19:12.610 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.610 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.610 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.610 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.610 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.610 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.610 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.610 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.611 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/sl'
          2024-08-09 18:19:12.611 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.611 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.611 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.611 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.611 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.611 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.611 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.611 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.612 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/sv'
          2024-08-09 18:19:12.612 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.612 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.612 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.612 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.612 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.612 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.612 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.612 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.613 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/th'
          2024-08-09 18:19:12.613 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.613 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.613 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.613 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.613 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.613 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.613 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.613 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.614 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/tr'
          2024-08-09 18:19:12.614 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.614 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.614 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.614 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.614 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.614 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.614 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.614 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.615 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/uk'
          2024-08-09 18:19:12.615 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.615 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.615 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.615 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.615 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.615 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.615 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.615 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.616 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/vi'
          2024-08-09 18:19:12.616 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.616 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.616 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.616 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.616 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.632 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.632 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.632 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.632 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/zh-cn'
          2024-08-09 18:19:12.633 - error: javascript.0 (185) at Module.require (node:internal/modules/cjs/loader:1022:19)
          2024-08-09 18:19:12.633 - error: javascript.0 (185) at require (node:internal/modules/cjs/helpers:102:18)
          2024-08-09 18:19:12.633 - error: javascript.0 (185) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          2024-08-09 18:19:12.633 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.633 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.633 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.633 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.633 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.633 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: Error: Cannot find module '@iobroker-javascript.0/dayjs/locale/zh-tw'
          2024-08-09 18:19:12.634 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:998:21
          2024-08-09 18:19:12.634 - error: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:12.634 - error: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:12.634 - error: javascript.0 (185) at script.js.common.NSPanelTs_ts:8:71
          2024-08-09 18:19:12.634 - error: javascript.0 (185) at new Promise ()
          2024-08-09 18:19:12.634 - warn: javascript.0 (185) script.js.common.NSPanelTs_ts: error at function init_dayjs: Cannot read properties of undefined (reading 'locale')
          2024-08-09 18:19:12.641 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: nodeJS must be at least v18.X.X. Currently: v14.5.0! Please Update your System! --> iob nodejs-update 18
          2024-08-09 18:19:12.642 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: setObjects enabled - create Alias Channels possible
          2024-08-09 18:19:12.654 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: weather alias for accuweather.0. already exists
          2024-08-09 18:19:12.673 - warn: javascript.0 (185) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
          2024-08-09 18:19:12.677 - warn: javascript.0 (185) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
          2024-08-09 18:19:12.677 - warn: javascript.0 (185) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
          2024-08-09 18:19:12.677 - warn: javascript.0 (185) at script.js.common.NSPanelTs_ts:2994:1
          2024-08-09 18:19:12.677 - warn: javascript.0 (185) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
          2024-08-09 18:19:12.680 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
          2024-08-09 18:19:12.680 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          2024-08-09 18:19:12.691 - warn: javascript.0 (185) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
          2024-08-09 18:19:12.692 - warn: javascript.0 (185) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
          2024-08-09 18:19:12.692 - warn: javascript.0 (185) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
          2024-08-09 18:19:12.692 - warn: javascript.0 (185) at script.js.common.NSPanelTs_ts:2986:5
          2024-08-09 18:19:12.692 - warn: javascript.0 (185) at Object._schedule (script.js.common.NSPanelTs_ts:11224:9)
          2024-08-09 18:19:12.692 - warn: javascript.0 (185) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3212:34)
          2024-08-09 18:19:12.692 - warn: javascript.0 (185) at listOnTimeout (node:internal/timers:564:17)
          2024-08-09 18:19:12.692 - warn: javascript.0 (185) at processTimers (node:internal/timers:507:7)
          2024-08-09 18:19:12.692 - warn: javascript.0 (185) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
          2024-08-09 18:19:12.694 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
          2024-08-09 18:19:12.699 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
          at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)
          code: 'ENOTFOUND',
          errno: -3008,
          config: {
          transitional: {
          timeout: 0,
          maxBodyLength: -1,
          Accept: 'application/json, text/plain, */*',
          method: 'get',
          url: 'http://undefined/cm?cmnd=Status0',
          data: undefined
          request: Writable {
          objectMode: false,
          finalCalled: false,
          needDrain: false,
          ending: false,
          ended: false,
          finished: false,
          destroyed: false,
          length: 0,
          writing: false,
          corked: 0,
          sync: true,
          writecb: null,
          writelen: 0,
          buffered: [],
          bufferedIndex: 0,
          allBuffers: true,
          allNoop: true,
          pendingcb: 0,
          constructed: true,
          prefinished: false,
          emitClose: true,
          autoDestroy: true,
          errored: null,
          closed: false,
          _eventsCount: 3,
          _maxListeners: 100,
          _options: {
          maxRedirects: 21,
          protocol: 'http:',
          path: '/cm?cmnd=Status0',
          method: 'GET',
          agents: [Object],
          auth: undefined,
          family: undefined,
          port: '',
          agent: undefined,
          pathname: '/cm',
          search: '?cmnd=Status0'
          _ended: true,
          _ending: true,
          _redirectCount: 0,
          _redirects: [],
          _eventsCount: 7,
          _maxListeners: 100,
          outputData: [],
          outputSize: 0,
          writable: true,
          destroyed: false,
          _last: true,
          sendDate: false,
          _removedTE: false,
          _contentLength: 0,
          _hasBody: true,
          _trailer: '',
          finished: true,
          _headerSent: true,
          _closed: false,
          socket: [Socket],
          _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' +
          'Accept: application/json, text/plain, */*\r\n' +
          'sentry-trace: 7f690517773d4ceea50d74be57dfd8af-97fe931e98c3f49b\r\n' +
          '\r\n',
          agent: [Agent],
          method: 'GET',
          _ended: false,
          res: null,
          aborted: false,
          timeoutCb: null,
          parser: null,
          host: 'undefined',
          protocol: 'http:',
          _currentUrl: 'http://undefined/cm?cmnd=Status0',
          errno: -3008,
          code: 'ENOTFOUND',
          2024-08-09 18:19:12.806 - error: javascript.0 (185) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
          code: 'ENOTFOUND',
          errno: -3008,
          config: {
          transitional: {
          timeout: 0,
          maxBodyLength: -1,
          method: 'get',
          data: undefined
          request: Writable {
          objectMode: false,
          finalCalled: false,
          needDrain: false,
          ending: false,
          ended: false,
          finished: false,
          destroyed: false,
          length: 0,
          writing: false,
          corked: 0,
          sync: true,
          writecb: null,
          writelen: 0,
          buffered: [],
          bufferedIndex: 0,
          allBuffers: true,
          allNoop: true,
          pendingcb: 0,
          constructed: true,
          prefinished: false,
          emitClose: true,
          autoDestroy: true,
          errored: null,
          closed: false,
          _eventsCount: 3,
          _maxListeners: 100,
          _options: {
          maxRedirects: 21,
          protocol: 'http:',
          method: 'GET',
          agents: [Object],
          auth: undefined,
          family: undefined,
          port: '',
          agent: undefined,
          pathname: '/cm',
          _ended: true,
          _ending: true,
          _redirectCount: 0,
          _redirects: [],
          _eventsCount: 7,
          _maxListeners: 100,
          outputData: [],
          outputSize: 0,
          writable: true,
          destroyed: false,
          _last: true,
          sendDate: false,
          _removedTE: false,
          _contentLength: 0,
          _hasBody: true,
          _trailer: '',
          finished: true,
          _headerSent: true,
          _closed: false,
          socket: [Socket],
          'sentry-trace: 7f690517773d4ceea50d74be57dfd8af-b086e7549e0ba860\r\n' +
          '\r\n',
          agent: [Agent],
          method: 'GET',
          _ended: false,
          res: null,
          aborted: false,
          timeoutCb: null,
          parser: null,
          host: 'undefined',
          protocol: 'http:',
          errno: -3008,
          code: 'ENOTFOUND',
          2024-08-09 18:19:13.200 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
          2024-08-09 18:19:13.334 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: Debug mode disabled
          2024-08-09 18:19:13.493 - warn: javascript.0 (185) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
          2024-08-09 18:19:13.494 - warn: javascript.0 (185) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
          2024-08-09 18:19:13.494 - warn: javascript.0 (185) at script.js.common.NSPanelTs_ts:3341:99
          2024-08-09 18:19:13.494 - warn: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:13.494 - warn: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:13.494 - warn: javascript.0 (185) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
          2024-08-09 18:19:13.494 - warn: javascript.0 (185) at runNextTicks (node:internal/process/task_queues:60:5)
          2024-08-09 18:19:13.494 - warn: javascript.0 (185) at processImmediate (node:internal/timers:442:9)
          2024-08-09 18:19:13.494 - warn: javascript.0 (185) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
          2024-08-09 18:19:13.511 - warn: javascript.0 (185) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
          2024-08-09 18:19:13.512 - warn: javascript.0 (185) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
          2024-08-09 18:19:13.512 - warn: javascript.0 (185) at script.js.common.NSPanelTs_ts:3341:99
          2024-08-09 18:19:13.512 - warn: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:13.512 - warn: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:13.512 - warn: javascript.0 (185) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
          2024-08-09 18:19:13.512 - warn: javascript.0 (185) at runNextTicks (node:internal/process/task_queues:60:5)
          2024-08-09 18:19:13.512 - warn: javascript.0 (185) at processImmediate (node:internal/timers:442:9)
          2024-08-09 18:19:13.512 - warn: javascript.0 (185) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
          2024-08-09 18:19:13.513 - warn: javascript.0 (185) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
          2024-08-09 18:19:13.513 - info: javascript.0 (185) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
          2024-08-09 18:19:13.529 - warn: javascript.0 (185) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
          2024-08-09 18:19:13.529 - info: javascript.0 (185) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
          2024-08-09 18:19:13.577 - warn: javascript.0 (185) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
          2024-08-09 18:19:13.578 - warn: javascript.0 (185) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
          2024-08-09 18:19:13.578 - warn: javascript.0 (185) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
          2024-08-09 18:19:13.578 - warn: javascript.0 (185) at script.js.common.NSPanelTs_ts:3352:21
          2024-08-09 18:19:13.578 - warn: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:13.578 - warn: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:13.578 - warn: javascript.0 (185) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
          2024-08-09 18:19:13.578 - warn: javascript.0 (185) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
          2024-08-09 18:19:13.608 - warn: javascript.0 (185) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
          code: 'ENOTFOUND',
          errno: -3008,
          config: {
          transitional: {
          timeout: 0,
          maxBodyLength: -1,
          method: 'get',
          data: undefined
          request: Writable {
          objectMode: false,
          finalCalled: false,
          needDrain: false,
          ending: false,
          ended: false,
          finished: false,
          destroyed: false,
          length: 0,
          writing: false,
          corked: 0,
          sync: true,
          writecb: null,
          writelen: 0,
          buffered: [],
          bufferedIndex: 0,
          allBuffers: true,
          allNoop: true,
          pendingcb: 0,
          constructed: true,
          prefinished: false,
          emitClose: true,
          autoDestroy: true,
          errored: null,
          closed: false,
          _eventsCount: 3,
          _maxListeners: 100,
          _options: {
          maxRedirects: 21,
          protocol: 'http:',
          method: 'GET',
          agents: [Object],
          auth: undefined,
          family: undefined,
          port: '',
          agent: undefined,
          pathname: '/cm',
          _ended: true,
          _ending: true,
          _redirectCount: 0,
          _redirects: [],
          _eventsCount: 7,
          _maxListeners: 100,
          outputData: [],
          outputSize: 0,
          writable: true,
          destroyed: false,
          _last: true,
          sendDate: false,
          _removedTE: false,
          _contentLength: 0,
          _hasBody: true,
          _trailer: '',
          finished: true,
          _headerSent: true,
          _closed: false,
          socket: [Socket],
          'sentry-trace: 7f690517773d4ceea50d74be57dfd8af-8848c63d58a2ede6\r\n' +
          '\r\n',
          agent: [Agent],
          method: 'GET',
          _ended: false,
          res: null,
          aborted: false,
          timeoutCb: null,
          parser: null,
          host: 'undefined',
          protocol: 'http:',
          errno: -3008,
          code: 'ENOTFOUND',
          2024-08-09 18:19:13.628 - warn: javascript.0 (185) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
          2024-08-09 18:19:13.629 - warn: javascript.0 (185) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
          2024-08-09 18:19:13.629 - warn: javascript.0 (185) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
          2024-08-09 18:19:13.629 - warn: javascript.0 (185) at script.js.common.NSPanelTs_ts:3352:21
          2024-08-09 18:19:13.629 - warn: javascript.0 (185) at step (script.js.common.NSPanelTs_ts:33:23)
          2024-08-09 18:19:13.629 - warn: javascript.0 (185) at Object.next (script.js.common.NSPanelTs_ts:14:53)
          2024-08-09 18:19:13.629 - warn: javascript.0 (185) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
          2024-08-09 18:19:13.629 - warn: javascript.0 (185) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
          2024-08-09 18:19:13.663 - warn: javascript.0 (185) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
          code: 'ENOTFOUND',
          errno: -3008,
          config: {
          transitional: {
          timeout: 0,
          maxBodyLength: -1,
          method: 'get',
          data: undefined
          request: Writable {
          objectMode: false,
          finalCalled: false,
          needDrain: false,
          ending: false,
          ended: false,
          finished: false,
          destroyed: false,
          length: 0,
          writing: false,
          corked: 0,
          sync: true,
          writecb: null,
          writelen: 0,
          buffered: [],
          bufferedIndex: 0,
          allBuffers: true,
          allNoop: true,
          pendingcb: 0,
          constructed: true,
          prefinished: false,
          emitClose: true,
          autoDestroy: true,
          errored: null,
          closed: false,
          _eventsCount: 3,
          _maxListeners: 100,
          _options: {
          maxRedirects: 21,
          protocol: 'http:',
          method: 'GET',
          agents: [Object],
          auth: undefined,
          family: undefined,
          port: '',
          agent: undefined,
          pathname: '/cm',
          _ended: true,
          _ending: true,
          _redirectCount: 0,
          _redirects: [],
          _eventsCount: 7,
          _maxListeners: 100,
          outputData: [],
          outputSize: 0,
          writable: true,
          destroyed: false,
          _last: true,
          sendDate: false,
          _removedTE: false,
          _contentLength: 0,
          _hasBody: true,
          _trailer: '',
          finished: true,
          _headerSent: true,
          _closed: false,
          socket: [Socket],
          'sentry-trace: 7f690517773d4ceea50d74be57dfd8af-bcf24ffe2c8fdf6c\r\n' +
          '\r\n',
          agent: [Agent],
          method: 'GET',
          _ended: false,
          res: null,
          aborted: false,
          timeoutCb: null,
          parser: null,
          host: 'undefined',
          protocol: 'http:',
          errno: -3008,
          code: 'ENOTFOUND',
          2024-08-09 18:19:16.329 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
          2024-08-09 18:19:16.329 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
          2024-08-09 18:19:16.329 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
          2024-08-09 18:19:16.329 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
          2024-08-09 18:19:16.329 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
          2024-08-09 18:19:16.329 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
          2024-08-09 18:19:16.330 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
          2024-08-09 18:19:16.330 - info: javascript.0 (185) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------
          2024-08-09 18:19:18.167 - info: admin.0 (178) <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
          So sieht die Ordnerstruktur aus:
          Und hier ein Ausschnitt aus dem Script:
          /***** 1. Tasmota-Config *****/
              // DE: Anpassen an die Verzeichnisse der MQTT-Adapter-Instanz
              // EN: Adapt to the MQTT adapter instance directories
              const NSPanelReceiveTopic: string = 'mqtt.0.SmartHome.NSPanel_1.stat.RESULT';
              const NSPanelSendTopic: string = 'mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend';
              // DE: nur ändern, falls der User im Tasmota vor dem Kompilieren umbenannt wurde (Standard Tasmota: admin)
              // EN: only change if the user was renamed in Tasmota before compiling (default Tasmota: admin)
              const tasmota_web_admin_user: string = 'admin';
              // DE: setzten, falls "Web Admin Password" in Tasmota vergeben
              // EN set if "Web Admin Password" is assigned in Tasmota
              const tasmota_web_admin_password: string = '';
              // DE: Setzen der bevorzugten Tasmota32-Version (für Updates)
              // EN: Set preferred Tasmota32 version (for updates)
              const tasmotaOtaVersion: string = 'tasmota32-DE.bin';
                  // DE: Es können ebenfalls andere Versionen verwendet werden wie zum Beispiel:
                  // EN: Other versions can also be used, such as:
                  // 'tasmota32-nspanel.bin' or 'tasmota32.bin' or 'tasmota32-DE.bin' or etc.
          /***** 2. Directories in 0_userdata.0... *****/
              // DE: Anpassen an das jeweilige NSPanel
              // EN: Adapt to the respective NSPanel
              const NSPanel_Path = '0_userdata.0.NSPanel.1.';
              // DE: Pfad für gemeinsame Nutzung durch mehrere Panels (bei Nutzung der cardAlarm/cardUnlock)
              // EN: Path for sharing between multiple panels (when using cardAlarm/cardUnlock)
              const NSPanel_Alarm_Path = '0_userdata.0.NSPanel.';
          • K Karlson 0
            @armilar
            at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14)
            at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:620:25)
            at RedirectableRequest.emit (node:events:513:28)
            at RedirectableRequest.emit (node:domain:489:12)
            at ClientRequest.emit (node:events:525:35)
            at ClientRequest.emit (node:domain:489:12)
            at Socket.socketErrorListener (node:_http_client:481:9)
            at Socket.emit (node:events:513:28)
            at Socket.emit (node:domain:489:12)
            at Axios.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/Axios.js:45:41)
            at processTicksAndRejections (node:internal/process/task_queues:95:5) {
            hostname: 'undefined',
            code: 'ENOTFOUND',
            errno: -3008,
            config: {
            transitional: {
            silentJSONParsing: true,
            forcedJSONParsing: true,
            clarifyTimeoutError: false
            adapter: [ 'xhr', 'http', 'fetch' ],
            transformRequest: [ [Function: transformRequest] ],
            transformResponse: [ [Function: transformResponse] ],
            timeout: 0,
            xsrfCookieName: 'XSRF-TOKEN',
            xsrfHeaderName: 'X-XSRF-TOKEN',
            maxContentLength: -1,
            maxBodyLength: -1,
            env: { FormData: [Function], Blob: [class Blob] },
            validateStatus: [Function: validateStatus],
            headers: Object [AxiosHeaders] {
            'Content-Type': undefined,
            'User-Agent': 'ioBroker',
            'Accept-Encoding': 'gzip, compress, deflate, br'
            method: 'get',
            data: undefined
            request: Writable {
            _writableState: WritableState {
            objectMode: false,
            highWaterMark: 16384,
            finalCalled: false,
            needDrain: false,
            ending: false,
            ended: false,
            finished: false,
            destroyed: false,
            decodeStrings: true,
            defaultEncoding: 'utf8',
            length: 0,
            writing: false,
            corked: 0,
            sync: true,
            bufferProcessing: false,
            onwrite: [Function: bound onwrite],
            writecb: null,
            writelen: 0,
            afterWriteTickInfo: null,
            buffered: [],
            bufferedIndex: 0,
            allBuffers: true,
            allNoop: true,
            pendingcb: 0,
            constructed: true,
            prefinished: false,
            errorEmitted: false,
            emitClose: true,
            autoDestroy: true,
            errored: null,
            closed: false,
            closeEmitted: false,
            [Symbol(kOnFinished)]: []
            _events: [Object: null prototype] {
            response: [Function: handleResponse],
            error: [Function: handleRequestError],
            socket: [Function: handleRequestSocket]
            _eventsCount: 3,
            _maxListeners: 100,
            _options: {
            maxRedirects: 21,
            maxBodyLength: Infinity,
            protocol: 'http:',
            method: 'GET',
            headers: [Object: null prototype],
            agents: [Object],
            auth: undefined,
            family: undefined,
            beforeRedirect: [Function: dispatchBeforeRedirect],
            beforeRedirects: [Object],
            port: '',
            agent: undefined,
            nativeProtocols: [Object],
            pathname: '/cm',
            _ended: true,
            _ending: true,
            _redirectCount: 0,
            _redirects: [],
            _requestBodyLength: 0,
            _requestBodyBuffers: [],
            _onNativeResponse: [Function (anonymous)],
            _currentRequest: ClientRequest {
            _events: [Object: null prototype],
            _eventsCount: 7,
            _maxListeners: 100,
            outputData: [],
            outputSize: 0,
            writable: true,
            destroyed: false,
            _last: true,
            chunkedEncoding: false,
            shouldKeepAlive: false,
            maxRequestsOnConnectionReached: false,
            _defaultKeepAlive: true,
            useChunkedEncodingByDefault: false,
            sendDate: false,
            _removedConnection: false,
            _removedContLen: false,
            _removedTE: false,
            _contentLength: 0,
            _hasBody: true,
            _trailer: '',
            finished: true,
            _headerSent: true,
            _closed: false,
            socket: [Socket],
            'User-Agent: ioBroker\r\n' +
            'Accept-Encoding: gzip, compress, deflate, br\r\n' +
            'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=7f690517773d4ceea50d74be57dfd8af\r\n' +
            'Host: undefined\r\n' +
            'Connection: close\r\n' +
            '\r\n',
            _keepAliveTimeout: 0,
            _onPendingData: [Function: nop],
            agent: [Agent],
            socketPath: undefined,
            method: 'GET',
            maxHeaderSize: undefined,
            insecureHTTPParser: undefined,
            _ended: false,
            res: null,
            aborted: false,
            timeoutCb: null,
            upgradeOrConnect: false,
            parser: null,
            maxHeadersCount: null,
            reusedSocket: false,
            host: 'undefined',
            protocol: 'http:',
            _redirectable: [Circular *1],
            [Symbol(kCapture)]: false,
            [Symbol(kNeedDrain)]: false,
            [Symbol(corked)]: 0,
            [Symbol(kOutHeaders)]: [Object: null prototype],
            [Symbol(kUniqueHeaders)]: null
            cause: Error: getaddrinfo ENOTFOUND undefined
            at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:111:26) {
            errno: -3008,
            code: 'ENOTFOUND',
            syscall: 'getaddrinfo',
            code: 'ENOTFOUND',
            errno: -3008,
            config: {
            transitional: {
            timeout: 0,
            maxBodyLength: -1,
            method: 'get',
            data: undefined
            request: Writable {
            objectMode: false,
            finalCalled: false,
            needDrain: false,
            ending: false,
            ended: false,
            finished: false,
            destroyed: false,
            length: 0,
            writing: false,
            corked: 0,
            sync: true,
            writecb: null,
            writelen: 0,
            buffered: [],
            bufferedIndex: 0,
            allBuffers: true,
            allNoop: true,
            pendingcb: 0,
            constructed: true,
            prefinished: false,
            emitClose: true,
            autoDestroy: true,
            errored: null,
            closed: false,
            _eventsCount: 3,
            _maxListeners: 100,
            _options: {
            maxRedirects: 21,
            protocol: 'http:',
            method: 'GET',
            agents: [Object],
            auth: undefined,
            family: undefined,
            port: '',
            agent: undefined,
            pathname: '/cm',
            _ended: true,
            _ending: true,
            _redirectCount: 0,
            _redirects: [],
            _eventsCount: 7,
            _maxListeners: 100,
            outputData: [],
            outputSize: 0,
            writable: true,
            destroyed: false,
            _last: true,
            sendDate: false,
            _removedTE: false,
            _contentLength: 0,
            _hasBody: true,
            _trailer: '',
            finished: true,
            _headerSent: true,
            _closed: false,
            socket: [Socket],
            '\r\n',
            agent: [Agent],
            method: 'GET',
            _ended: false,
            res: null,
            aborted: false,
            timeoutCb: null,
            parser: null,
            host: 'undefined',
            protocol: 'http:',
            errno: -3008,
            code: 'ENOTFOUND',
            code: 'ENOTFOUND',
            errno: -3008,
            config: {
            transitional: {
            timeout: 0,
            maxBodyLength: -1,
            method: 'get',
            url: 'http://undefined/cm?cmnd=GetDriverVersion',
            data: undefined
            request: Writable {
            objectMode: false,
            finalCalled: false,
            needDrain: false,
            ending: false,
            ended: false,
            finished: false,
            destroyed: false,
            length: 0,
            writing: false,
            corked: 0,
            sync: true,
            writecb: null,
            writelen: 0,
            buffered: [],
            bufferedIndex: 0,
            allBuffers: true,
            allNoop: true,
            pendingcb: 0,
            constructed: true,
            prefinished: false,
            emitClose: true,
            autoDestroy: true,
            errored: null,
            closed: false,
            _eventsCount: 3,
            _maxListeners: 100,
            _options: {
            maxRedirects: 21,
            protocol: 'http:',
            path: '/cm?cmnd=GetDriverVersion',
            method: 'GET',
            agents: [Object],
            auth: undefined,
            family: undefined,
            port: '',
            agent: undefined,
            pathname: '/cm',
            search: '?cmnd=GetDriverVersion'
            _ended: true,
            _ending: true,
            _redirectCount: 0,
            _redirects: [],
            _eventsCount: 7,
            _maxListeners: 100,
            outputData: [],
            outputSize: 0,
            writable: true,
            destroyed: false,
            _last: true,
            sendDate: false,
            _removedTE: false,
            _contentLength: 0,
            _hasBody: true,
            _trailer: '',
            finished: true,
            _headerSent: true,
            _closed: false,
            socket: [Socket],
            _header: 'GET /cm?cmnd=GetDriverVersion HTTP/1.1\r\n' +
            '\r\n',
            agent: [Agent],
            method: 'GET',
            _ended: false,
            res: null,
            aborted: false,
            timeoutCb: null,
            parser: null,
            host: 'undefined',
            protocol: 'http:',
            _currentUrl: 'http://undefined/cm?cmnd=GetDriverVersion',
            errno: -3008,
            code: 'ENOTFOUND',
            code: 'ENOTFOUND',
            errno: -3008,
            config: {
            transitional: {
            timeout: 0,
            maxBodyLength: -1,
            method: 'get',
            data: undefined
            request: Writable {
            objectMode: false,
            finalCalled: false,
            needDrain: false,
            ending: false,
            ended: false,
            finished: false,
            destroyed: false,
            length: 0,
            writing: false,
            corked: 0,
            sync: true,
            writecb: null,
            writelen: 0,
            buffered: [],
            bufferedIndex: 0,
            allBuffers: true,
            allNoop: true,
            pendingcb: 0,
            constructed: true,
            prefinished: false,
            emitClose: true,
            autoDestroy: true,
            errored: null,
            closed: false,
            _eventsCount: 3,
            _maxListeners: 100,
            _options: {
            maxRedirects: 21,
            protocol: 'http:',
            method: 'GET',
            agents: [Object],
            auth: undefined,
            family: undefined,
            port: '',
            agent: undefined,
            pathname: '/cm',
            _ended: true,
            _ending: true,
            _redirectCount: 0,
            _redirects: [],
            _eventsCount: 7,
            _maxListeners: 100,
            outputData: [],
            outputSize: 0,
            writable: true,
            destroyed: false,
            _last: true,
            sendDate: false,
            _removedTE: false,
            _contentLength: 0,
            _hasBody: true,
            _trailer: '',
            finished: true,
            _headerSent: true,
            _closed: false,
            socket: [Socket],
            '\r\n',
            agent: [Agent],
            method: 'GET',
            _ended: false,
            res: null,
            aborted: false,
            timeoutCb: null,
            parser: null,
            host: 'undefined',
            protocol: 'http:',
            errno: -3008,
            code: 'ENOTFOUND',
            TT-Tom
            @karlson-0
            Bitte noch ein Screenshot von den Einstellungen der JavaScript Instanz, wo die npm Module eingetragen sind.
            Sowie von Tasmota die mqtt Einstellungen und die Log Einstellungen in Tasmota.
            Gruß Tom
            Public Transport
            NSPanel Adapter Wiki
            • T TT-Tom
              @karlson-0
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              Most Active Forum Testing
              @tt-tom
              @Karlson-0
              Der ist falsch
              wir fragen auf tele ab:
              mqtt.0.SmartHome.NSPanel_1.tele.RESULT
              Da der CustomSend ja schon die Daten bekommt, denke ich springt die Mühle danach an...
              Falls irgendwelche Fehler, kurz posten...
              • ArmilarA Armilar
                @tt-tom
                @Karlson-0
                Der ist falsch
                TT-Tom
                @armilar
                Tele.Result ist in seinen Objekten nicht enthalten.
                Edit: da er auf Stat steht kann er auch nicht Info finden.
                Gruß Tom
                Public Transport
                • T TT-Tom
                  @armilar
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  @tt-tom
                  Ups... stimmt... Dann doch mal kurz die Einstellungen wie bei i TT-Tom beschrieben
                  • ArmilarA Armilar
                    @tt-tom
                    TT-Tom
                    @armilar
                    ich habe auch den Verdacht dass die npm-Module nicht eingetragen sind.
                    Gruß Tom
                    Public Transport
                    • T TT-Tom
                      @armilar
                      Karlson 0
                      @TT-Tom
                      @Armilar
                      Die npm-Module führen mich leider zu meinem nächsten Problem, sobald ich sie eintrage startet mein JS Adapter nicht mehr und ich bekomme folgende Meldung:
                      2024-08-09 21:17:39.475 - info: javascript.0 (675) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.7.0, js-controller: 6.0.9
                      2024-08-09 21:17:39.575 - error: javascript.0 (675) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2024-08-09 21:17:39.576 - error: javascript.0 (675) unhandled promise rejection: URL.canParse is not a function
                      2024-08-09 21:17:39.576 - error: javascript.0 (675) TypeError: URL.canParse is not a function
                      at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1868:17)
                      2024-08-09 21:17:39.576 - error: javascript.0 (675) URL.canParse is not a function
                      2024-08-09 21:17:39.604 - info: javascript.0 (675) terminating
                      2024-08-09 21:17:39.605 - warn: javascript.0 (675) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2024-08-09 21:17:40.103 - info: javascript.0 (675) terminating
                      2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                      2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[1]: TypeError: URL.canParse is not a function
                      2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[1]: at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1868:17)
                      2024-08-09 21:17:40.151 - error: host.ioBroker instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2024-08-09 21:17:40.151 - info: host.ioBroker Restart adapter system.adapter.javascript.0 because enabled
                      2024-08-09 21:17:40.151 - warn: host.ioBroker Do not restart adapter system.adapter.javascript.0 because restart loop detected
                      ArmilarA T 2 Antworten Letzte Antwort
                      • K Karlson 0
                        @TT-Tom
                        @Armilar
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        @karlson-0
                        Führe mal ein
                        iob fix
                        durch
                        Dann mal
                        sudo apt update
                        sudo apt dist-upgrade
                        sudo reboot
                        danach nochmal versuchen
                        • K Karlson 0
                          @TT-Tom
                          @Armilar
                          TT-Tom
                          @karlson-0
                          Zeig mal was du da eingetragen hast.
                          Gruß Tom
                          Public Transport
                          • ArmilarA Armilar
                            @karlson-0
                            Führe mal ein
                            iob fix
                            durch
                            Dann mal
                            sudo apt update
                            sudo reboot
                            TT-Tom
                            @armilar
                            @Karlson-0
                            Und gleich die nodejs Version anpassen auf 20.
                            iob nodejs-update 20
                            Gruß Tom
                            Public Transport
                            • T TT-Tom
                              @armilar
                              @Karlson-0
                              Karlson 0
                              @tt-tom
                              @Armilar
                              Nach
                              iob fix
                              sudo apt update
                              sudo reboot
                              Hat es leider nicht funktioniert
                              Jetzt das nächste Problem, und ich hoffe ihr habt starke nerven:
                              Node V 20 bekomme ich bei mir irgendwie nicht drauf, war schon ein wunder dass ich 18 drauf bekommen habe.
                              Muss dazu sagen, dass iobroker bei mir auf einem LXC Container über Proxmox läuft.
                              Ich bekomme bei der Installation folgende Meldung:
                              root@ioBroker:~# sudo -E bash nodesource_setup.sh
                              2024-08-09 21:50:33 - Installing pre-requisites
                              Ign:1 http://archive.ubuntu.com/ubuntu kinetic InRelease
                              Ign:2 http://archive.ubuntu.com/ubuntu kinetic-updates InRelease
                              Ign:3 http://archive.ubuntu.com/ubuntu kinetic-security InRelease
                              Err:4 http://archive.ubuntu.com/ubuntu kinetic Release
                                404  Not Found [IP: 91.189.91.83 80]
                              Err:5 http://archive.ubuntu.com/ubuntu kinetic-updates Release
                              Err:6 http://archive.ubuntu.com/ubuntu kinetic-security Release
                              Reading package lists... Done
                              E: The repository 'http://archive.ubuntu.com/ubuntu kinetic Release' no longer has a Release file.
                              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                              N: See apt-secure(8) manpage for repository creation and user configuration details.
                              E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-updates Release' no longer has a Release file.
                              E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-security Release' no longer has a Release file.
                              2024-08-09 21:50:34 - Error: Failed to run 'apt-get update' (Exit Code: 0)
                              HomoranH T 2 Antworten Letzte Antwort
                              • K Karlson 0
                                @tt-tom
                                @Armilar
                                Nach
                                iob fix
                                sudo apt update
                                sudo reboot
                                @karlson-0 sagte in SONOFF NSPanel Lovelance UI Rückgängig machen:
                                ubuntu kinetic
                                Ubuntu 22.10 Kinetic Kudu ist eine "Short Term Support" Version, die nur bis Juli 2023 mit Updates versorgt wird
                                • K Karlson 0
                                  @tt-tom
                                  @Armilar
                                  Nach
                                  iob fix
                                  sudo apt update
                                  sudo reboot
                                  TT-Tom
                                  @karlson-0
                                  Warum arbeitest du als Root????
                                  Du musst immer als normal User im System unterwegs sein.
                                  Lege die ein neuen Container an, als Vorlage würde ich dir Debian 12 empfehlen.
                                  Dann baust du dir iobroker komplett neu auf und spielst das Backup deiner aktuellen Version ein.
                                  Wenn ich zu Hause bin kann ich dir eine kleine Schritt für Schritt Anleitung noch posten.
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @karlson-0
                                    Karlson 0
                                    @tt-tom
                                    So weit meine Kenntnis reicht, gibt es in diesen LXC Containern nur den Root User, In einigen Foren wird noch der User Ubuntu beschrieben, mit pw ubuntu, funktioniert bei mir aber nicht.
                                    Thomas BraunT K 2 Antworten Letzte Antwort
                                    • K Karlson 0
                                      @tt-tom
                                      Man legt sich immer einen user an.
                                      Ist die erste (und einzige) Aktion als root in einem frischen LXC.
                                      Undd dein kinetisches Kudo ist ausgestorben. Deswegen frisst das auch kein nodejs20 mehr.
                                      Zimmer dir einen frischen Debian12-LXC hin.
                                      • K Karlson 0
                                        @tt-tom
                                        Karlson 0
                                        schrieb am zuletzt editiert von Karlson 0
                                        Ich habe gerade das ioBroker Backup gemacht, werde morgen einen neuen Debian 12 Container für Iobroker erstellen, und danach sofort berichten
                                        • K Karlson 0
                                          TT-Tom
                                          @karlson-0
                                          hier wie versprochen meine kurze Schritt für Schritt Anleitung. Wenn der Container läuft sind die ersten Schritte bis zum Reboot als Root. Danach wird root nicht mehr angefasst, IMMER als Standard-User anmelden und ggf. mit sudo arbeiten.
                                          apt update && apt full-upgrade -y
                                          apt install -y curl sudo mc
                                          dpkg-reconfigure tzdata
                                          dpkg-reconfigure locales
                                          //Standarduser erstellen
                                          adduser "name"
                                          usermod -aG sudo "name"
                                          reboot
                                          // login als Standarduser
                                          // install ioBroker
                                          curl -sLf https://iobroker.net/install.sh | bash -
                                          Gruß Tom
                                          Public Transport
