  4. SONOFF NSPanel Lovelance UI Rückgängig machen
35 Beiträge 6 Kommentatoren 4.1k Aufrufe 2 Beobachtet
  • T TT-Tom
    @armilar
    ich habe auch den Verdacht dass die npm-Module nicht eingetragen sind.
    Karlson 0
    @TT-Tom
    @Armilar
    Die npm-Module führen mich leider zu meinem nächsten Problem, sobald ich sie eintrage startet mein JS Adapter nicht mehr und ich bekomme folgende Meldung:
    2024-08-09 21:17:39.475 - info: javascript.0 (675) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.7.0, js-controller: 6.0.9
    2024-08-09 21:17:39.575 - error: javascript.0 (675) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-08-09 21:17:39.576 - error: javascript.0 (675) unhandled promise rejection: URL.canParse is not a function
    2024-08-09 21:17:39.576 - error: javascript.0 (675) TypeError: URL.canParse is not a function
    at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1868:17)
    2024-08-09 21:17:39.576 - error: javascript.0 (675) URL.canParse is not a function
    2024-08-09 21:17:39.604 - info: javascript.0 (675) terminating
    2024-08-09 21:17:39.605 - warn: javascript.0 (675) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-08-09 21:17:40.103 - info: javascript.0 (675) terminating
    2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[1]: TypeError: URL.canParse is not a function
    2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[1]: at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1868:17)
    2024-08-09 21:17:40.151 - error: host.ioBroker instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-08-09 21:17:40.151 - info: host.ioBroker Restart adapter system.adapter.javascript.0 because enabled
    2024-08-09 21:17:40.151 - warn: host.ioBroker Do not restart adapter system.adapter.javascript.0 because restart loop detected
    ArmilarA T 2 Antworten Letzte Antwort
    • K Karlson 0
      @TT-Tom
      @Armilar
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      @karlson-0
      Führe mal ein
      iob fix
      durch
      Dann mal
      sudo apt update
      sudo apt dist-upgrade
      sudo reboot
      danach nochmal versuchen
      • K Karlson 0
        @TT-Tom
        @Armilar
        TT-Tom
        @karlson-0
        Zeig mal was du da eingetragen hast.
        Gruß Tom
        Public Transport
        NSPanel Adapter Wiki
        • ArmilarA Armilar
          @karlson-0
          Führe mal ein
          iob fix
          durch
          Dann mal
          sudo apt update
          sudo reboot
          TT-Tom
          @armilar
          @Karlson-0
          Und gleich die nodejs Version anpassen auf 20.
          iob nodejs-update 20
          Gruß Tom
          Public Transport
          • T TT-Tom
            @armilar
            @Karlson-0
            Karlson 0
            @tt-tom
            @Armilar
            Nach
            iob fix
            sudo apt update
            sudo reboot
            Hat es leider nicht funktioniert
            Jetzt das nächste Problem, und ich hoffe ihr habt starke nerven:
            Node V 20 bekomme ich bei mir irgendwie nicht drauf, war schon ein wunder dass ich 18 drauf bekommen habe.
            Muss dazu sagen, dass iobroker bei mir auf einem LXC Container über Proxmox läuft.
            Ich bekomme bei der Installation folgende Meldung:
            root@ioBroker:~# sudo -E bash nodesource_setup.sh
            2024-08-09 21:50:33 - Installing pre-requisites
            Ign:1 http://archive.ubuntu.com/ubuntu kinetic InRelease
            Ign:2 http://archive.ubuntu.com/ubuntu kinetic-updates InRelease
            Ign:3 http://archive.ubuntu.com/ubuntu kinetic-security InRelease
            Err:4 http://archive.ubuntu.com/ubuntu kinetic Release
              404  Not Found [IP: 91.189.91.83 80]
            Err:5 http://archive.ubuntu.com/ubuntu kinetic-updates Release
            Err:6 http://archive.ubuntu.com/ubuntu kinetic-security Release
            Reading package lists... Done
            E: The repository 'http://archive.ubuntu.com/ubuntu kinetic Release' no longer has a Release file.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-updates Release' no longer has a Release file.
            E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-security Release' no longer has a Release file.
            2024-08-09 21:50:34 - Error: Failed to run 'apt-get update' (Exit Code: 0)
            HomoranH T 2 Antworten Letzte Antwort
            • K Karlson 0
              @tt-tom
              @Armilar
              Nach
              iob fix
              sudo apt update
              sudo reboot
              @karlson-0 sagte in SONOFF NSPanel Lovelance UI Rückgängig machen:
              ubuntu kinetic
              Ubuntu 22.10 Kinetic Kudu ist eine "Short Term Support" Version, die nur bis Juli 2023 mit Updates versorgt wird
              • K Karlson 0
                @tt-tom
                @Armilar
                Nach
                iob fix
                sudo apt update
                sudo reboot
                TT-Tom
                @karlson-0
                Warum arbeitest du als Root????
                Du musst immer als normal User im System unterwegs sein.
                Lege die ein neuen Container an, als Vorlage würde ich dir Debian 12 empfehlen.
                Dann baust du dir iobroker komplett neu auf und spielst das Backup deiner aktuellen Version ein.
                Wenn ich zu Hause bin kann ich dir eine kleine Schritt für Schritt Anleitung noch posten.
                Gruß Tom
                Public Transport
                • T TT-Tom
                  @karlson-0
                  Karlson 0
                  @tt-tom
                  So weit meine Kenntnis reicht, gibt es in diesen LXC Containern nur den Root User, In einigen Foren wird noch der User Ubuntu beschrieben, mit pw ubuntu, funktioniert bei mir aber nicht.
                  Thomas BraunT K 2 Antworten Letzte Antwort
                  • K Karlson 0
                    @tt-tom
                    Man legt sich immer einen user an.
                    Ist die erste (und einzige) Aktion als root in einem frischen LXC.
                    Undd dein kinetisches Kudo ist ausgestorben. Deswegen frisst das auch kein nodejs20 mehr.
                    Zimmer dir einen frischen Debian12-LXC hin.
                    • K Karlson 0
                      @tt-tom
                      Karlson 0
                      schrieb am zuletzt editiert von Karlson 0
                      Ich habe gerade das ioBroker Backup gemacht, werde morgen einen neuen Debian 12 Container für Iobroker erstellen, und danach sofort berichten
                      • K Karlson 0
                        TT-Tom
                        @karlson-0
                        hier wie versprochen meine kurze Schritt für Schritt Anleitung. Wenn der Container läuft sind die ersten Schritte bis zum Reboot als Root. Danach wird root nicht mehr angefasst, IMMER als Standard-User anmelden und ggf. mit sudo arbeiten.
                        apt update && apt full-upgrade -y
                        apt install -y curl sudo mc
                        dpkg-reconfigure tzdata
                        dpkg-reconfigure locales
                        //Standarduser erstellen
                        adduser "name"
                        usermod -aG sudo "name"
                        reboot
                        // login als Standarduser
                        // install ioBroker
                        curl -sLf https://iobroker.net/install.sh | bash -
                        Gruß Tom
                        Public Transport
                        • T TT-Tom
                          @karlson-0
                          adduser "name"
                          reboot
                          // install ioBroker
                          Karlson 0
                          Leider weiterhin nicht erfolgreich.
                          Mein iobroker läuft jetzt auf einem Debian 12 Container, node 20 ist drauf, npm Module sind jetzt auch eingetragen, und die Instanz javascript wird grün.
                          Bekomme beim Start von NSPanelTS.ts folgende Meldungen:
                          2024-08-12 21:45:15.043 - info: admin.0 (407) ==> Connected system.user.admin from ::ffff:192.168.178.240
                          2024-08-12 21:45:19.220 - info: javascript.0 (458) Compiling TypeScript source script.js.common.NSPanelTs_ts
                          2024-08-12 21:45:24.438 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: TypeScript compilation successful
                          2024-08-12 21:45:24.545 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.545 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.546 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.546 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                          2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                          2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.546 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.548 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.548 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.548 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.549 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.549 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                          2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                          2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.549 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.551 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.551 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.552 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.552 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                          2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                          2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.553 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.554 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.554 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.554 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.554 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.555 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                          2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                          2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.555 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.561 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.561 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.561 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.561 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.561 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                          2024-08-12 21:45:24.561 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                          2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.562 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.562 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.564 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.564 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.564 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.564 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.564 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                          2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                          2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.565 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.567 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.568 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.568 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                          2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                          2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.569 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.569 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.569 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.569 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.570 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                          2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                          2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.570 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.575 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.575 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.575 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.575 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.575 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                          2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                          2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.576 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.578 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.578 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.578 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.579 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.579 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                          2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                          2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.579 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.581 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.581 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.581 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.581 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.581 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                          2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                          2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.582 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.584 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.585 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.585 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                          2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                          2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.586 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.586 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.586 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.587 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.587 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                          2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                          2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.587 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.588 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.588 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.588 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.589 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.589 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                          2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                          2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.589 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.590 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.590 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.591 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.591 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                          2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                          2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.591 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.594 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.594 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.594 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.595 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.595 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                          2024-08-12 21:45:24.595 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                          2024-08-12 21:45:24.595 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.598 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.598 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.598 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.599 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.599 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.599 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.599 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.599 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                          2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                          2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.600 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.602 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.602 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.602 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.602 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                          2024-08-12 21:45:24.602 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                          2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.603 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.603 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.603 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.606 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.606 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.606 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.606 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.607 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                          2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                          2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.607 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.609 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.609 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.609 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.609 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                          2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                          2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.610 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.612 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.612 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.613 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.613 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                          2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                          2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.613 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.615 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                          2024-08-12 21:45:24.615 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-12 21:45:24.615 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-12 21:45:24.616 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                          2024-08-12 21:45:24.616 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                          2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                          2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-12 21:45:24.616 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-12 21:45:24.623 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: nodeJS must be at least v18.X.X. Currently: v14.5.0! Please Update your System! --> iob nodejs-update 18
                          2024-08-12 21:45:24.624 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: setObjects enabled - create Alias Channels possible
                          2024-08-12 21:45:24.630 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: weather alias for accuweather.0. already exists
                          2024-08-12 21:45:24.689 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                          2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                          2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                          2024-08-12 21:45:24.694 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2994:1
                          2024-08-12 21:45:24.694 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                          2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                          2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2024-08-12 21:45:24.726 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                          2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                          2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                          2024-08-12 21:45:24.726 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2986:5
                          2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Object._schedule (script.js.common.NSPanelTs_ts:11224:9)
                          2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3212:34)
                          2024-08-12 21:45:24.726 - warn: javascript.0 (458) at listOnTimeout (node:internal/timers:581:17)
                          2024-08-12 21:45:24.726 - warn: javascript.0 (458) at processTimers (node:internal/timers:519:7)
                          2024-08-12 21:45:24.726 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                          2024-08-12 21:45:24.727 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                          2024-08-12 21:45:24.877 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                          at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14)
                          at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:620:25)
                          at RedirectableRequest.emit (node:events:519:28)
                          at RedirectableRequest.emit (node:domain:488:12)
                          at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)
                          at ClientRequest.emit (node:events:531:35)
                          at ClientRequest.emit (node:domain:488:12)
                          at Socket.socketErrorListener (node:_http_client:500:9)
                          at Socket.emit (node:events:519:28)
                          at Socket.emit (node:domain:488:12)
                          at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)
                          at processTicksAndRejections (node:internal/process/task_queues:95:5) {
                          hostname: 'undefined',
                          syscall: 'getaddrinfo',
                          code: 'ENOTFOUND',
                          errno: -3008,
                          config: {
                          transitional: {
                          silentJSONParsing: true,
                          forcedJSONParsing: true,
                          clarifyTimeoutError: false
                          adapter: [ 'xhr', 'http', 'fetch' ],
                          transformRequest: [ [Function: transformRequest] ],
                          transformResponse: [ [Function: transformResponse] ],
                          timeout: 0,
                          xsrfCookieName: 'XSRF-TOKEN',
                          xsrfHeaderName: 'X-XSRF-TOKEN',
                          maxContentLength: -1,
                          maxBodyLength: -1,
                          env: { FormData: [Function], Blob: [class Blob] },
                          validateStatus: [Function: validateStatus],
                          headers: Object [AxiosHeaders] {
                          Accept: 'application/json, text/plain, */*',
                          'Content-Type': undefined,
                          'User-Agent': 'ioBroker',
                          'Accept-Encoding': 'gzip, compress, deflate, br'
                          method: 'get',
                          url: 'http://undefined/cm?cmnd=Status0',
                          data: undefined
                          request: Writable {
                          _events: {
                          close: undefined,
                          error: [Function: handleRequestError],
                          prefinish: undefined,
                          finish: undefined,
                          drain: undefined,
                          response: [Function: handleResponse],
                          socket: [Function: handleRequestSocket]
                          _writableState: WritableState {
                          highWaterMark: 16384,
                          length: 0,
                          corked: 0,
                          onwrite: [Function: bound onwrite],
                          writelen: 0,
                          bufferedIndex: 0,
                          pendingcb: 0,
                          [Symbol(kState)]: 17580812,
                          [Symbol(kBufferedValue)]: null
                          _maxListeners: 100,
                          _options: {
                          maxRedirects: 21,
                          maxBodyLength: Infinity,
                          protocol: 'http:',
                          path: '/cm?cmnd=Status0',
                          method: 'GET',
                          headers: [Object: null prototype],
                          agents: [Object],
                          auth: undefined,
                          family: undefined,
                          beforeRedirect: [Function: dispatchBeforeRedirect],
                          beforeRedirects: [Object],
                          port: '',
                          agent: undefined,
                          nativeProtocols: [Object],
                          pathname: '/cm',
                          search: '?cmnd=Status0'
                          _ended: true,
                          _ending: true,
                          _redirectCount: 0,
                          _redirects: [],
                          _requestBodyLength: 0,
                          _requestBodyBuffers: [],
                          _eventsCount: 3,
                          _onNativeResponse: [Function (anonymous)],
                          _currentRequest: ClientRequest {
                          _events: [Object: null prototype],
                          _eventsCount: 7,
                          _maxListeners: 100,
                          outputData: [],
                          outputSize: 0,
                          writable: true,
                          destroyed: false,
                          _last: true,
                          chunkedEncoding: false,
                          shouldKeepAlive: true,
                          maxRequestsOnConnectionReached: false,
                          _defaultKeepAlive: true,
                          useChunkedEncodingByDefault: false,
                          sendDate: false,
                          _removedConnection: false,
                          _removedContLen: false,
                          _removedTE: false,
                          strictContentLength: false,
                          _contentLength: 0,
                          _hasBody: true,
                          _trailer: '',
                          finished: true,
                          _headerSent: true,
                          _closed: false,
                          socket: [Socket],
                          _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' +
                          'Accept: application/json, text/plain, */*\r\n' +
                          'User-Agent: ioBroker\r\n' +
                          'Accept-Encoding: gzip, compress, deflate, br\r\n' +
                          'sentry-trace: 49d0d7813b8c428eab3645c24d1a50f8-98b170a0ea551350\r\n' +
                          'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=49d0d7813b8c428eab3645c24d1a50f8\r\n' +
                          'Host: undefined\r\n' +
                          'Connection: keep-alive\r\n' +
                          '\r\n',
                          _keepAliveTimeout: 0,
                          _onPendingData: [Function: nop],
                          agent: [Agent],
                          socketPath: undefined,
                          method: 'GET',
                          maxHeaderSize: undefined,
                          insecureHTTPParser: undefined,
                          joinDuplicateHeaders: undefined,
                          _ended: false,
                          res: null,
                          aborted: false,
                          timeoutCb: [Function: emitRequestTimeout],
                          upgradeOrConnect: false,
                          parser: null,
                          maxHeadersCount: null,
                          reusedSocket: false,
                          host: 'undefined',
                          protocol: 'http:',
                          _redirectable: [Circular *1],
                          [Symbol(shapeMode)]: false,
                          [Symbol(kCapture)]: false,
                          [Symbol(kBytesWritten)]: 0,
                          [Symbol(kNeedDrain)]: false,
                          [Symbol(corked)]: 0,
                          [Symbol(kOutHeaders)]: [Object: null prototype],
                          [Symbol(errored)]: null,
                          [Symbol(kHighWaterMark)]: 16384,
                          [Symbol(kRejectNonStandardBodyWrites)]: false,
                          [Symbol(kUniqueHeaders)]: null
                          _currentUrl: 'http://undefined/cm?cmnd=Status0',
                          [Symbol(shapeMode)]: true,
                          cause: Error: getaddrinfo ENOTFOUND undefined
                          at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
                          errno: -3008,
                          code: 'ENOTFOUND',
                          2024-08-12 21:45:24.879 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                          code: 'ENOTFOUND',
                          errno: -3008,
                          config: {
                          transitional: {
                          timeout: 0,
                          maxBodyLength: -1,
                          method: 'get',
                          data: undefined
                          request: Writable {
                          _events: {
                          close: undefined,
                          finish: undefined,
                          drain: undefined,
                          length: 0,
                          corked: 0,
                          writelen: 0,
                          bufferedIndex: 0,
                          pendingcb: 0,
                          _maxListeners: 100,
                          _options: {
                          maxRedirects: 21,
                          protocol: 'http:',
                          method: 'GET',
                          agents: [Object],
                          auth: undefined,
                          family: undefined,
                          port: '',
                          agent: undefined,
                          pathname: '/cm',
                          _ended: true,
                          _ending: true,
                          _redirectCount: 0,
                          _redirects: [],
                          _eventsCount: 3,
                          _eventsCount: 7,
                          _maxListeners: 100,
                          outputData: [],
                          outputSize: 0,
                          writable: true,
                          destroyed: false,
                          _last: true,
                          sendDate: false,
                          _removedTE: false,
                          _contentLength: 0,
                          _hasBody: true,
                          _trailer: '',
                          finished: true,
                          _headerSent: true,
                          _closed: false,
                          socket: [Socket],
                          '\r\n',
                          agent: [Agent],
                          method: 'GET',
                          _ended: false,
                          res: null,
                          aborted: false,
                          parser: null,
                          host: 'undefined',
                          protocol: 'http:',
                          errno: -3008,
                          code: 'ENOTFOUND',
                          2024-08-12 21:45:25.215 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
                          2024-08-12 21:45:25.265 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Debug mode disabled
                          2024-08-12 21:45:25.294 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                          2024-08-12 21:45:25.294 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                          2024-08-12 21:45:25.294 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                          2024-08-12 21:45:25.295 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                          2024-08-12 21:45:25.295 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                          2024-08-12 21:45:25.295 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                          2024-08-12 21:45:25.295 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                          2024-08-12 21:45:25.304 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                          2024-08-12 21:45:25.305 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                          2024-08-12 21:45:25.307 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                          2024-08-12 21:45:25.308 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                          2024-08-12 21:45:25.308 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                          2024-08-12 21:45:25.308 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                          2024-08-12 21:45:25.308 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                          2024-08-12 21:45:25.308 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                          2024-08-12 21:45:25.308 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                          2024-08-12 21:45:25.309 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                          2024-08-12 21:45:25.309 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                          2024-08-12 21:45:25.321 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                          2024-08-12 21:45:25.321 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                          2024-08-12 21:45:25.355 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                          2024-08-12 21:45:25.356 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                          2024-08-12 21:45:25.357 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                          2024-08-12 21:45:25.357 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                          2024-08-12 21:45:25.357 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                          2024-08-12 21:45:25.357 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                          2024-08-12 21:45:25.357 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                          2024-08-12 21:45:25.357 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                          2024-08-12 21:45:25.369 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                          2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                          2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                          2024-08-12 21:45:25.370 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                          2024-08-12 21:45:25.370 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                          2024-08-12 21:45:25.370 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                          2024-08-12 21:45:25.370 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                          2024-08-12 21:45:25.370 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                          2024-08-12 21:45:25.370 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                          2024-08-12 21:45:25.370 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                          2024-08-12 21:45:25.379 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                          code: 'ENOTFOUND',
                          errno: -3008,
                          config: {
                          transitional: {
                          timeout: 0,
                          maxBodyLength: -1,
                          method: 'get',
                          url: 'http://undefined/cm?cmnd=GetDriverVersion',
                          data: undefined
                          request: Writable {
                          _events: {
                          close: undefined,
                          finish: undefined,
                          drain: undefined,
                          length: 0,
                          corked: 0,
                          writelen: 0,
                          bufferedIndex: 0,
                          pendingcb: 0,
                          _maxListeners: 100,
                          _options: {
                          maxRedirects: 21,
                          protocol: 'http:',
                          path: '/cm?cmnd=GetDriverVersion',
                          method: 'GET',
                          agents: [Object],
                          auth: undefined,
                          family: undefined,
                          port: '',
                          agent: undefined,
                          pathname: '/cm',
                          search: '?cmnd=GetDriverVersion'
                          _ended: true,
                          _ending: true,
                          _redirectCount: 0,
                          _redirects: [],
                          _eventsCount: 3,
                          _eventsCount: 7,
                          _maxListeners: 100,
                          outputData: [],
                          outputSize: 0,
                          writable: true,
                          destroyed: false,
                          _last: true,
                          sendDate: false,
                          _removedTE: false,
                          _contentLength: 0,
                          _hasBody: true,
                          _trailer: '',
                          finished: true,
                          _headerSent: true,
                          _closed: false,
                          socket: [Socket],
                          _header: 'GET /cm?cmnd=GetDriverVersion HTTP/1.1\r\n' +
                          '\r\n',
                          agent: [Agent],
                          method: 'GET',
                          _ended: false,
                          res: null,
                          aborted: false,
                          parser: null,
                          host: 'undefined',
                          protocol: 'http:',
                          _currentUrl: 'http://undefined/cm?cmnd=GetDriverVersion',
                          errno: -3008,
                          code: 'ENOTFOUND',
                          2024-08-12 21:45:25.413 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                          code: 'ENOTFOUND',
                          errno: -3008,
                          config: {
                          transitional: {
                          timeout: 0,
                          maxBodyLength: -1,
                          method: 'get',
                          data: undefined
                          request: Writable {
                          _events: {
                          close: undefined,
                          finish: undefined,
                          drain: undefined,
                          length: 0,
                          corked: 0,
                          writelen: 0,
                          bufferedIndex: 0,
                          pendingcb: 0,
                          _maxListeners: 100,
                          _options: {
                          maxRedirects: 21,
                          protocol: 'http:',
                          method: 'GET',
                          agents: [Object],
                          auth: undefined,
                          family: undefined,
                          port: '',
                          agent: undefined,
                          pathname: '/cm',
                          _ended: true,
                          _ending: true,
                          _redirectCount: 0,
                          _redirects: [],
                          _eventsCount: 3,
                          _eventsCount: 7,
                          _maxListeners: 100,
                          outputData: [],
                          outputSize: 0,
                          writable: true,
                          destroyed: false,
                          _last: true,
                          sendDate: false,
                          _removedTE: false,
                          _contentLength: 0,
                          _hasBody: true,
                          _trailer: '',
                          finished: true,
                          _headerSent: true,
                          _closed: false,
                          socket: [Socket],
                          '\r\n',
                          agent: [Agent],
                          method: 'GET',
                          _ended: false,
                          res: null,
                          aborted: false,
                          parser: null,
                          host: 'undefined',
                          protocol: 'http:',
                          errno: -3008,
                          code: 'ENOTFOUND',
                          2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
                          2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
                          2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
                          2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
                          2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
                          2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
                          2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
                          2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------
                          2024-08-12 21:45:32.571 - info: admin.0 (407) <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
                          2024-08-12 21:45:36.977 - info: mqtt.0 (509) Client [NSPanel_1] connected with secret 1723491936974_7775
                          2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd\..*/
                          2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_1\.cmnd\..*/
                          2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd\..*/
                          2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd\..*/
                          2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^cmnd\.NSPanel_1_fb\..*/
                          2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^mqtt\.0\.cmnd\.NSPanel_1_fb\..*/
                          2024-08-12 21:45:37.285 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                          2024-08-12 21:45:37.286 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                          2024-08-12 21:45:37.287 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                          • K Karlson 0
                            Leider weiterhin nicht erfolgreich.
                            Mein iobroker läuft jetzt auf einem Debian 12 Container, node 20 ist drauf, npm Module sind jetzt auch eingetragen, und die Instanz javascript wird grün.
                            Bekomme beim Start von NSPanelTS.ts folgende Meldungen:
                            2024-08-12 21:45:15.043 - info: admin.0 (407) ==> Connected system.user.admin from ::ffff:192.168.178.240
                            2024-08-12 21:45:19.220 - info: javascript.0 (458) Compiling TypeScript source script.js.common.NSPanelTs_ts
                            2024-08-12 21:45:24.438 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: TypeScript compilation successful
                            2024-08-12 21:45:24.545 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.545 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.546 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.546 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                            2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                            2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.546 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.548 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.548 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.548 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.549 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.549 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                            2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                            2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.549 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.551 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.551 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.552 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.552 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                            2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                            2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.553 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.554 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.554 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.554 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.554 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.555 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                            2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                            2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.555 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.561 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.561 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.561 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.561 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.561 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                            2024-08-12 21:45:24.561 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                            2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.562 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.562 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.564 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.564 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.564 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.564 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.564 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                            2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                            2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.565 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.567 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.568 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.568 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                            2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                            2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.569 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.569 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.569 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.569 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.570 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                            2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                            2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.570 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.575 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.575 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.575 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.575 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.575 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                            2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                            2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.576 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.578 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.578 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.578 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.579 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.579 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                            2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                            2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.579 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.581 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.581 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.581 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.581 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.581 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                            2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                            2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.582 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.584 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.585 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.585 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                            2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                            2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.586 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.586 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.586 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.587 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.587 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                            2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                            2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.587 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.588 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.588 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.588 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.589 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.589 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                            2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                            2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.589 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.590 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.590 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.591 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.591 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                            2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                            2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.591 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.594 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.594 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.594 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.595 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.595 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                            2024-08-12 21:45:24.595 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                            2024-08-12 21:45:24.595 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.598 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.598 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.598 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.599 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.599 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.599 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.599 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.599 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                            2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                            2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.600 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.602 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.602 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.602 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.602 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                            2024-08-12 21:45:24.602 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                            2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.603 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.603 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.603 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.606 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.606 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.606 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.606 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.607 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                            2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                            2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.607 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.609 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.609 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.609 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.609 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                            2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                            2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.610 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.612 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.612 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.613 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.613 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                            2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                            2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.613 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.615 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                            2024-08-12 21:45:24.615 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                            2024-08-12 21:45:24.615 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                            2024-08-12 21:45:24.616 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                            2024-08-12 21:45:24.616 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                            2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                            2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                            2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                            2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            2024-08-12 21:45:24.616 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                            2024-08-12 21:45:24.623 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: nodeJS must be at least v18.X.X. Currently: v14.5.0! Please Update your System! --> iob nodejs-update 18
                            2024-08-12 21:45:24.624 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: setObjects enabled - create Alias Channels possible
                            2024-08-12 21:45:24.630 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: weather alias for accuweather.0. already exists
                            2024-08-12 21:45:24.689 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                            2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                            2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                            2024-08-12 21:45:24.694 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2994:1
                            2024-08-12 21:45:24.694 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                            2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                            2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            2024-08-12 21:45:24.726 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                            2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                            2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                            2024-08-12 21:45:24.726 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2986:5
                            2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Object._schedule (script.js.common.NSPanelTs_ts:11224:9)
                            2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3212:34)
                            2024-08-12 21:45:24.726 - warn: javascript.0 (458) at listOnTimeout (node:internal/timers:581:17)
                            2024-08-12 21:45:24.726 - warn: javascript.0 (458) at processTimers (node:internal/timers:519:7)
                            2024-08-12 21:45:24.726 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                            2024-08-12 21:45:24.727 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                            2024-08-12 21:45:24.877 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                            at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14)
                            at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:620:25)
                            at RedirectableRequest.emit (node:events:519:28)
                            at RedirectableRequest.emit (node:domain:488:12)
                            at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)
                            at ClientRequest.emit (node:events:531:35)
                            at ClientRequest.emit (node:domain:488:12)
                            at Socket.socketErrorListener (node:_http_client:500:9)
                            at Socket.emit (node:events:519:28)
                            at Socket.emit (node:domain:488:12)
                            at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)
                            at processTicksAndRejections (node:internal/process/task_queues:95:5) {
                            hostname: 'undefined',
                            syscall: 'getaddrinfo',
                            code: 'ENOTFOUND',
                            errno: -3008,
                            config: {
                            transitional: {
                            silentJSONParsing: true,
                            forcedJSONParsing: true,
                            clarifyTimeoutError: false
                            adapter: [ 'xhr', 'http', 'fetch' ],
                            transformRequest: [ [Function: transformRequest] ],
                            transformResponse: [ [Function: transformResponse] ],
                            timeout: 0,
                            xsrfCookieName: 'XSRF-TOKEN',
                            xsrfHeaderName: 'X-XSRF-TOKEN',
                            maxContentLength: -1,
                            maxBodyLength: -1,
                            env: { FormData: [Function], Blob: [class Blob] },
                            validateStatus: [Function: validateStatus],
                            headers: Object [AxiosHeaders] {
                            Accept: 'application/json, text/plain, */*',
                            'Content-Type': undefined,
                            'User-Agent': 'ioBroker',
                            'Accept-Encoding': 'gzip, compress, deflate, br'
                            method: 'get',
                            url: 'http://undefined/cm?cmnd=Status0',
                            data: undefined
                            request: Writable {
                            _events: {
                            close: undefined,
                            error: [Function: handleRequestError],
                            prefinish: undefined,
                            finish: undefined,
                            drain: undefined,
                            response: [Function: handleResponse],
                            socket: [Function: handleRequestSocket]
                            _writableState: WritableState {
                            highWaterMark: 16384,
                            length: 0,
                            corked: 0,
                            onwrite: [Function: bound onwrite],
                            writelen: 0,
                            bufferedIndex: 0,
                            pendingcb: 0,
                            [Symbol(kState)]: 17580812,
                            [Symbol(kBufferedValue)]: null
                            _maxListeners: 100,
                            _options: {
                            maxRedirects: 21,
                            maxBodyLength: Infinity,
                            protocol: 'http:',
                            path: '/cm?cmnd=Status0',
                            method: 'GET',
                            headers: [Object: null prototype],
                            agents: [Object],
                            auth: undefined,
                            family: undefined,
                            beforeRedirect: [Function: dispatchBeforeRedirect],
                            beforeRedirects: [Object],
                            port: '',
                            agent: undefined,
                            nativeProtocols: [Object],
                            pathname: '/cm',
                            search: '?cmnd=Status0'
                            _ended: true,
                            _ending: true,
                            _redirectCount: 0,
                            _redirects: [],
                            _requestBodyLength: 0,
                            _requestBodyBuffers: [],
                            _eventsCount: 3,
                            _onNativeResponse: [Function (anonymous)],
                            _currentRequest: ClientRequest {
                            _events: [Object: null prototype],
                            _eventsCount: 7,
                            _maxListeners: 100,
                            outputData: [],
                            outputSize: 0,
                            writable: true,
                            destroyed: false,
                            _last: true,
                            chunkedEncoding: false,
                            shouldKeepAlive: true,
                            maxRequestsOnConnectionReached: false,
                            _defaultKeepAlive: true,
                            useChunkedEncodingByDefault: false,
                            sendDate: false,
                            _removedConnection: false,
                            _removedContLen: false,
                            _removedTE: false,
                            strictContentLength: false,
                            _contentLength: 0,
                            _hasBody: true,
                            _trailer: '',
                            finished: true,
                            _headerSent: true,
                            _closed: false,
                            socket: [Socket],
                            _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' +
                            'Accept: application/json, text/plain, */*\r\n' +
                            'User-Agent: ioBroker\r\n' +
                            'Accept-Encoding: gzip, compress, deflate, br\r\n' +
                            'sentry-trace: 49d0d7813b8c428eab3645c24d1a50f8-98b170a0ea551350\r\n' +
                            'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=49d0d7813b8c428eab3645c24d1a50f8\r\n' +
                            'Host: undefined\r\n' +
                            'Connection: keep-alive\r\n' +
                            '\r\n',
                            _keepAliveTimeout: 0,
                            _onPendingData: [Function: nop],
                            agent: [Agent],
                            socketPath: undefined,
                            method: 'GET',
                            maxHeaderSize: undefined,
                            insecureHTTPParser: undefined,
                            joinDuplicateHeaders: undefined,
                            _ended: false,
                            res: null,
                            aborted: false,
                            timeoutCb: [Function: emitRequestTimeout],
                            upgradeOrConnect: false,
                            parser: null,
                            maxHeadersCount: null,
                            reusedSocket: false,
                            host: 'undefined',
                            protocol: 'http:',
                            _redirectable: [Circular *1],
                            [Symbol(shapeMode)]: false,
                            [Symbol(kCapture)]: false,
                            [Symbol(kBytesWritten)]: 0,
                            [Symbol(kNeedDrain)]: false,
                            [Symbol(corked)]: 0,
                            [Symbol(kOutHeaders)]: [Object: null prototype],
                            [Symbol(errored)]: null,
                            [Symbol(kHighWaterMark)]: 16384,
                            [Symbol(kRejectNonStandardBodyWrites)]: false,
                            [Symbol(kUniqueHeaders)]: null
                            _currentUrl: 'http://undefined/cm?cmnd=Status0',
                            [Symbol(shapeMode)]: true,
                            cause: Error: getaddrinfo ENOTFOUND undefined
                            at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
                            errno: -3008,
                            code: 'ENOTFOUND',
                            2024-08-12 21:45:24.879 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                            code: 'ENOTFOUND',
                            errno: -3008,
                            config: {
                            transitional: {
                            timeout: 0,
                            maxBodyLength: -1,
                            method: 'get',
                            data: undefined
                            request: Writable {
                            _events: {
                            close: undefined,
                            finish: undefined,
                            drain: undefined,
                            length: 0,
                            corked: 0,
                            writelen: 0,
                            bufferedIndex: 0,
                            pendingcb: 0,
                            _maxListeners: 100,
                            _options: {
                            maxRedirects: 21,
                            protocol: 'http:',
                            method: 'GET',
                            agents: [Object],
                            auth: undefined,
                            family: undefined,
                            port: '',
                            agent: undefined,
                            pathname: '/cm',
                            _ended: true,
                            _ending: true,
                            _redirectCount: 0,
                            _redirects: [],
                            _eventsCount: 3,
                            _eventsCount: 7,
                            _maxListeners: 100,
                            outputData: [],
                            outputSize: 0,
                            writable: true,
                            destroyed: false,
                            _last: true,
                            sendDate: false,
                            _removedTE: false,
                            _contentLength: 0,
                            _hasBody: true,
                            _trailer: '',
                            finished: true,
                            _headerSent: true,
                            _closed: false,
                            socket: [Socket],
                            '\r\n',
                            agent: [Agent],
                            method: 'GET',
                            _ended: false,
                            res: null,
                            aborted: false,
                            parser: null,
                            host: 'undefined',
                            protocol: 'http:',
                            errno: -3008,
                            code: 'ENOTFOUND',
                            2024-08-12 21:45:25.215 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
                            2024-08-12 21:45:25.265 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Debug mode disabled
                            2024-08-12 21:45:25.294 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                            2024-08-12 21:45:25.294 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                            2024-08-12 21:45:25.294 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                            2024-08-12 21:45:25.295 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                            2024-08-12 21:45:25.295 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                            2024-08-12 21:45:25.295 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                            2024-08-12 21:45:25.295 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                            2024-08-12 21:45:25.304 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                            2024-08-12 21:45:25.305 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                            2024-08-12 21:45:25.307 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                            2024-08-12 21:45:25.308 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                            2024-08-12 21:45:25.308 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                            2024-08-12 21:45:25.308 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                            2024-08-12 21:45:25.308 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                            2024-08-12 21:45:25.308 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                            2024-08-12 21:45:25.308 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                            2024-08-12 21:45:25.309 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                            2024-08-12 21:45:25.309 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                            2024-08-12 21:45:25.321 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                            2024-08-12 21:45:25.321 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                            2024-08-12 21:45:25.355 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                            2024-08-12 21:45:25.356 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                            2024-08-12 21:45:25.357 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                            2024-08-12 21:45:25.357 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                            2024-08-12 21:45:25.357 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                            2024-08-12 21:45:25.357 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                            2024-08-12 21:45:25.357 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                            2024-08-12 21:45:25.357 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                            2024-08-12 21:45:25.369 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                            2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                            2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                            2024-08-12 21:45:25.370 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                            2024-08-12 21:45:25.370 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                            2024-08-12 21:45:25.370 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                            2024-08-12 21:45:25.370 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                            2024-08-12 21:45:25.370 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                            2024-08-12 21:45:25.370 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                            2024-08-12 21:45:25.370 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                            2024-08-12 21:45:25.379 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                            code: 'ENOTFOUND',
                            errno: -3008,
                            config: {
                            transitional: {
                            timeout: 0,
                            maxBodyLength: -1,
                            method: 'get',
                            url: 'http://undefined/cm?cmnd=GetDriverVersion',
                            data: undefined
                            request: Writable {
                            _events: {
                            close: undefined,
                            finish: undefined,
                            drain: undefined,
                            length: 0,
                            corked: 0,
                            writelen: 0,
                            bufferedIndex: 0,
                            pendingcb: 0,
                            _maxListeners: 100,
                            _options: {
                            maxRedirects: 21,
                            protocol: 'http:',
                            path: '/cm?cmnd=GetDriverVersion',
                            method: 'GET',
                            agents: [Object],
                            auth: undefined,
                            family: undefined,
                            port: '',
                            agent: undefined,
                            pathname: '/cm',
                            search: '?cmnd=GetDriverVersion'
                            _ended: true,
                            _ending: true,
                            _redirectCount: 0,
                            _redirects: [],
                            _eventsCount: 3,
                            _eventsCount: 7,
                            _maxListeners: 100,
                            outputData: [],
                            outputSize: 0,
                            writable: true,
                            destroyed: false,
                            _last: true,
                            sendDate: false,
                            _removedTE: false,
                            _contentLength: 0,
                            _hasBody: true,
                            _trailer: '',
                            finished: true,
                            _headerSent: true,
                            _closed: false,
                            socket: [Socket],
                            _header: 'GET /cm?cmnd=GetDriverVersion HTTP/1.1\r\n' +
                            '\r\n',
                            agent: [Agent],
                            method: 'GET',
                            _ended: false,
                            res: null,
                            aborted: false,
                            parser: null,
                            host: 'undefined',
                            protocol: 'http:',
                            _currentUrl: 'http://undefined/cm?cmnd=GetDriverVersion',
                            errno: -3008,
                            code: 'ENOTFOUND',
                            2024-08-12 21:45:25.413 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                            code: 'ENOTFOUND',
                            errno: -3008,
                            config: {
                            transitional: {
                            timeout: 0,
                            maxBodyLength: -1,
                            method: 'get',
                            data: undefined
                            request: Writable {
                            _events: {
                            close: undefined,
                            finish: undefined,
                            drain: undefined,
                            length: 0,
                            corked: 0,
                            writelen: 0,
                            bufferedIndex: 0,
                            pendingcb: 0,
                            _maxListeners: 100,
                            _options: {
                            maxRedirects: 21,
                            protocol: 'http:',
                            method: 'GET',
                            agents: [Object],
                            auth: undefined,
                            family: undefined,
                            port: '',
                            agent: undefined,
                            pathname: '/cm',
                            _ended: true,
                            _ending: true,
                            _redirectCount: 0,
                            _redirects: [],
                            _eventsCount: 3,
                            _eventsCount: 7,
                            _maxListeners: 100,
                            outputData: [],
                            outputSize: 0,
                            writable: true,
                            destroyed: false,
                            _last: true,
                            sendDate: false,
                            _removedTE: false,
                            _contentLength: 0,
                            _hasBody: true,
                            _trailer: '',
                            finished: true,
                            _headerSent: true,
                            _closed: false,
                            socket: [Socket],
                            '\r\n',
                            agent: [Agent],
                            method: 'GET',
                            _ended: false,
                            res: null,
                            aborted: false,
                            parser: null,
                            host: 'undefined',
                            protocol: 'http:',
                            errno: -3008,
                            code: 'ENOTFOUND',
                            2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
                            2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
                            2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
                            2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
                            2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
                            2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
                            2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
                            2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------
                            2024-08-12 21:45:32.571 - info: admin.0 (407) <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
                            2024-08-12 21:45:36.977 - info: mqtt.0 (509) Client [NSPanel_1] connected with secret 1723491936974_7775
                            2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd\..*/
                            2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_1\.cmnd\..*/
                            2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd\..*/
                            2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd\..*/
                            2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^cmnd\.NSPanel_1_fb\..*/
                            2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^mqtt\.0\.cmnd\.NSPanel_1_fb\..*/
                            2024-08-12 21:45:37.285 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                            2024-08-12 21:45:37.286 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                            2024-08-12 21:45:37.287 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            Most Active Forum Testing
                            @karlson-0 sagte in SONOFF NSPanel Lovelance UI Rückgängig machen:
                            Das Problem liegt immer noch im falschen Script Parameter:
                            Im Result Connection String für MQTT (im NSPanelTs.ts Script) sollte:
                            mqtt.0.SmartHome.NSPanel_1.tele.RESULT
                            stehen...
                            Bitte erneut die:
                            • Einstellungen im Tasmota (MQTT)
                            • Objekte unter mqtt.0.SmartHome.NSPanel_1
                            • Einstellungen der mqtt.0. Instanz
                            senden.
                            Dein Problem liegt nach wie vor in der MQTT-Kommunikation...
                            • ArmilarA Armilar
                              stehen...
                              Bitte erneut die:
                              senden.
                              Karlson 0
                              @armilar
                              Bitteschön:
                              • K Karlson 0
                                @armilar
                                Bitteschön:
                                Karlson 0
                                @karlson-0
                                Hier das Ergebnis mit der Änderung tele.result:
                                2024-08-12 22:12:45.360 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: TypeScript compilation successful
                                2024-08-12 22:12:45.462 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.463 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.464 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                                2024-08-12 22:12:45.465 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                                2024-08-12 22:12:45.466 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.467 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.468 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.469 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.469 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.469 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.469 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.469 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                                2024-08-12 22:12:45.469 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                                2024-08-12 22:12:45.469 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.469 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.469 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.470 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.471 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.472 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.473 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.474 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.475 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.476 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.477 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.478 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.479 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.480 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.481 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.482 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.483 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.484 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.485 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.486 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.487 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.488 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.489 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.490 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.491 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.492 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.493 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.494 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.495 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                                2024-08-12 22:12:45.496 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                                2024-08-12 22:12:45.497 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.497 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.497 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.497 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.497 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.497 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.498 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.498 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.498 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                                2024-08-12 22:12:45.498 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                                2024-08-12 22:12:45.498 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.498 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.498 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.498 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.498 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                2024-08-12 22:12:45.499 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Config-Parameter: << config.panelRecvTopic - mqtt.0.SmartHome.NSPanel_1.tele.RESULT >> is not reachable. Please Check Parameters!
                                2024-08-12 22:12:45.512 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: nodeJS must be at least v18.X.X. Currently: v14.5.0! Please Update your System! --> iob nodejs-update 18
                                2024-08-12 22:12:45.513 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: setObjects enabled - create Alias Channels possible
                                2024-08-12 22:12:45.517 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: weather alias for accuweather.0. already exists
                                2024-08-12 22:12:45.524 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                                2024-08-12 22:12:45.525 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                2024-08-12 22:12:45.528 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                                2024-08-12 22:12:45.835 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
                                2024-08-12 22:12:45.891 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Debug mode disabled
                                2024-08-12 22:12:46.199 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has been written without ack-flag with value "[object Object]"
                                2024-08-12 22:12:46.199 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has to be type "string" but received type "object"
                                2024-08-12 22:12:46.240 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has been written without ack-flag with value "[object Object]"
                                2024-08-12 22:12:46.240 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has to be type "string" but received type "object"
                                2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
                                2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
                                2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
                                2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
                                2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
                                2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
                                2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
                                2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------```
                                • K Karlson 0
                                  @karlson-0
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  @karlson-0
                                  Okay... schon besser:
                                  Die oberen dayjs-Meldungen sind erstmal irrelevant. Haben andere auch, kommen aktuell nur zum Start und hindert den Start des NSPanels auch nicht. Kommt nicht bei allen Usern - ist aber ein Thema außerhalb des Scriptes zwischen JS-Adapter/JS-Controller... also erstmal ignorieren...
                                  "mqtt.0.SmartHome.NSPanel_1.tele.INFO2" ist vorhanden - dennoch kommt diese Nachricht:
                                  Kannst du mal den dritten Reiter aus der MQTT-Instanz posten
                                  EDIT:
                                  Wir müssen also nur noch dieses Problem lösen:
                                  Danach läuft das Panel...
                                  EDIT2: Auch hier würde @TT-Tom wieder anmerken, dass da der Datenpunkt "tele.RESULT" im MQTT bei dir nicht vorhanden ist.
                                  Sieht so aus, als würde der Berry-Driver im Tasmota nicht existieren...
                                  • ArmilarA Armilar
                                    @karlson-0
                                    EDIT:
                                    Karlson 0
                                    @armilar
                                    Bitteschön:
                                    • K Karlson 0
                                      @armilar
                                      Bitteschön:
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      @karlson-0
                                      Siehe Vorherige Nachricht... Bitte den Berry-Driver nochmal installieren...
                                      Danach auf jeden Fall Tasmota neu starten
                                      • ArmilarA Armilar
                                        @karlson-0
                                        Karlson 0
                                        @armilar
                                        @Homoran
                                        @Samson71
                                        @Thomas-Braun
                                        @TT-Tom
                                        Es läuft endlich, vielen lieben Dank an euch.
                                        • K Karlson 0
                                          @armilar
                                          @Homoran
                                          @Samson71
                                          @Thomas-Braun
                                          @TT-Tom
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          @karlson-0
                                          Bingo 😊
                                          Die Anleitung mit vielen Beispielen ist hier
                                          Und hier bekommst du bei Fragen und Problemchen schnell Hilfe:
                                          https://forum.iobroker.net/topic/58170/sonoff-nspanel-mit-lovelace-ui?page=1
                                          Einfach zum letzten Beitrag, auf Antworten klicken und lostippen ;-)
                                          Hier sind auch noch interessante Sachen:
                                          https://forum.iobroker.net/topic/69942/sonoff-nspanel-mit-lovelace-ui-zeigt-her-eure-cards?_=1723495308865
