  4. js-controller 6.0.x jetzt für alle User im STABLE!
    1.0k
    6.1k
controllerjs-controllerkierastable
257 Beiträge 47 Kommentatoren 88.2k Aufrufe 45 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @foxriver76
    Bleiben wir ruhig bei dem genannten Beispiel.
    Alias:
      "common": {
        "alias": {
          "id": {
            "read": "mqtt-client.0.stat.tasmota_A36501.POWER2",
            "write": "mqtt-client.0.cmnd.tasmota_A36501.POWER2"
          "read": "val == \"ON\" ? true : false",
          "write": "val == true ? 1 : 0"
        "name": "Strahler 2",
        "role": "switch",
        "type": "boolean",
        "unit": "",
        "min": null,
        "max": null,
        "read": true,
        "write": true,
        "smartName": {
          "de": "Strahler 2",
          "smartType": "SWITCH"
      "native": {},
      "type": "state",
      "_id": "alias.0.Haus.Erdgeschoss.Schlafzimmer.Strahler2.switch_on",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "user": "system.user.admin",
      "ts": 1680780507033
    Datenpunkt lesend:
      "type": "state",
      "role": "text",
      "common": {
        "name": "POWER2",
        "type": "mixed",
        "read": true,
        "write": true,
        "desc": "created from topic",
        "custom": {
          "mqtt-client.0": {
            "enabled": true,
            "topic": "stat/tasmota_A36501/POWER2",
            "publish": false,
            "pubChangesOnly": false,
            "pubAsObject": false,
            "qos": 0,
            "retain": false,
            "subscribe": true,
            "subChangesOnly": false,
            "subAsObject": false,
            "subQos": 0,
            "setAck": true
      "native": {
      "from": "system.adapter.mqtt-client.0",
      "ts": 1680698849842,
      "_id": "mqtt-client.0.stat.tasmota_A36501.POWER2",
      "acl": {
        "object": 1636,
        "state": 1636,
      "binary": true
    Datenpunkt schreibend:
      "type": "state",
      "role": "text",
      "common": {
        "name": "POWER2",
        "type": "mixed",
        "read": true,
        "write": true,
        "custom": {
          "mqtt-client.0": {
            "enabled": true,
            "topic": "cmnd/tasmota_A36501/POWER2",
            "publish": true,
            "qos": 0,
            "retain": false,
            "subscribe": true,
            "subQos": 0,
            "setAck": true
      "native": {
      "_id": "mqtt-client.0.cmnd.tasmota_A36501.POWER2",
      "acl": {
        "object": 1636,
        "state": 1636,
      "ts": 1680700517346,
      "binary": true
    Edit:
    Ich schätze, die Meldung kommt jeweils vom Javascript-Adapter und vom Influxdb-Adapter für jeden Alias, der eine Konvertierungsfunktion (lesend) aktiviert hat.
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    @ofbeqnpolkkl6mby5e13 Hm schaut eigentlich ok aus, muss ich probieren nachzustellen.
    Videotutorials & mehr
    • CodierknechtC Codierknecht
      @fellpower sagte in Nach Update des JS Controllers einige Fehler:
      Ja, wenn man ein Linux Profi ist, macht man das natürlich anders - bin ich aber nicht!
      Ich mit Sicherheit auch nicht ;-)
      fellpower
      schrieb am zuletzt editiert von fellpower
      @codierknecht
      Also fassen wir zusammen:
      Ich habe den js-controller geupdatet, das hat wohl funktioniert.
      Aufgrund der Docker "Problematik" kann ich mein node.js irgendwie nicht updaten.
      Wenn ich es mit den bekannten Befehlen versuche (Wie hier beschrieben: https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18), dann funktioniert das irgendwie nicht. node.js bleibt auf 18.20.4.
      Also muss ich warten, bis buanet was neues bringt - oder selbst n Container bauen, wäre noch ne Möglichkeit.
      Was ist mit den Node-Red Fehlern auf dem Bild? Woher kommen die - und wie löse ich das?
      • F fellpower
        @codierknecht
        crunchipC Offline
        crunchipC Offline
        Also muss ich warten, bis buanet was neues bringt?
        https://github.com/buanet/ioBroker.docker/releases/tag/v10.0.0-beta.1
        F 1 Antwort Letzte Antwort
          fellpower
          @crunchip
          Hab ich schon gesehen. Wollte aber warten, bis nicht mehr Beta. ;)
          Aber ich denke, dann ist ja eigentlich alles richtig gelaufen, nur node.js kann noch nicht geupdatet werden, bis ich das Image neu ausrolle.
          Was sind das für Fehler mit Node-Red? Weiß das jemand? Node-Red an sich funktioniert noch.
          • crunchipC Offline
            crunchipC Offline
            stimmt wohl die Verlinkung nicht
              @foxriver76 muss ich testen, bisher nur einmal versucht
              @foxriver76 habe es soeben nochmal probiert, lief allerdings auf den gleichen Fehler hinaus
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              @crunchip Docker oder klassische Linux Installation?
              • foxriver76F foxriver76
                crunchipC Offline
                crunchipC Offline
                @foxriver76
                @crunchip sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                buanet-docker Installation image - v9.1.2
                  @foxriver76
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  @crunchip Hm okay.. vor den Fehlern im Screenshot sieht man da noch andere Fehler? Im Endeffekt kann er bei setup first entweder nicht zur DB verbinden oder es kommt vorher zu einem Fehler den man auf dem Screenshot nicht sieht.
                    @foxriver76
                    Alias:
                      "common": {
                        "alias": {
                          "id": {
                        "role": "switch",
                        "type": "boolean",
                        "unit": "",
                        "min": null,
                        "max": null,
                        "read": true,
                        "write": true,
                        "smartName": {
                          "de": "Strahler 2",
                      "native": {},
                      "type": "state",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                      "ts": 1680780507033
                    Datenpunkt lesend:
                      "type": "state",
                      "role": "text",
                      "common": {
                        "name": "POWER2",
                        "type": "mixed",
                        "read": true,
                        "write": true,
                        "custom": {
                          "mqtt-client.0": {
                            "enabled": true,
                            "publish": false,
                            "qos": 0,
                            "retain": false,
                            "subscribe": true,
                            "subQos": 0,
                            "setAck": true
                      "native": {
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                      "binary": true
                      "type": "state",
                      "role": "text",
                      "common": {
                        "name": "POWER2",
                        "type": "mixed",
                        "read": true,
                        "write": true,
                        "custom": {
                          "mqtt-client.0": {
                            "enabled": true,
                            "publish": true,
                            "qos": 0,
                            "retain": false,
                            "subscribe": true,
                            "subQos": 0,
                            "setAck": true
                      "native": {
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                      "binary": true
                    Edit:
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    @ofbeqnpolkkl6mby5e13 Und beim Neustart von javascript treten die Fehler erneut auf oder in welchem Interval, weil du meintest es hat aufgehört?
                    O 1 Antwort Letzte Antwort
                      crunchipC Offline
                      crunchipC Offline
                      @foxriver76 ich kann da nicht scrollen, da das Bild dann eingefroren ist, oben im ersten Beitrag ist das log eingefügt
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        @crunchip Okay, kannst du mal inventwo vorher stoppen und dann nochmal probieren, iwie überlebt der den terminate Prozess ist auch etwas was mit dem nächsten Controller nochmal optimiert wurde aber mit 5.0.19 eben noch nicht.
                          O Abwesend
                          O Abwesend
                          @foxriver76
                          Meine Einschätzung ist, dass für jeden Alias mit Konvertierungsfunktion die Meldung einmal vom Javascript-Adapter kommt und einmal vom Influxdb-Adapter, wenn derselbe Alias zusätzlich auch protokolliert wird. Da ich sehr viele Alias mit Konvertierungsfunktion habe, sah es aus, als wenn da wiederholt "Millionen" Meldungen durchlaufen. Es waren auch sehr viele, aber wie bereits erwähnt, nur einmal bzw. zweimal pro Alias. Ein Neustart des Javascript-Adapters bringt die Meldungen nicht erneut hervor.
                          MartinPM foxriver76F 2 Antworten Letzte Antwort
                            @foxriver76
                            MartinPM Online
                            MartinPM Online
                            MartinP
                            Was sagt mir die Meldung
                            "... Body has already been consumed?"
                            Bei mir läuft gerade das Update aus der GUI
                            • MartinPM MartinP
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              schrieb am zuletzt editiert von foxriver76
                              @martinp Mit welcher Admin Version? Grundsätzlich ein Fehler im Admin aber sollte mit aktueller stable (7.0.22) eigentlich nicht mehr auftreten.
                                @foxriver76
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                @ofbeqnpolkkl6mby5e13 Hm okay, falls es bei controller neustart wieder auftritt gib bitte Bescheid, ansonsten weiß ich gerade nicht wie ich es nachgestellt bekomme.
                                O isi07I 2 Antworten Letzte Antwort
                                  O Abwesend
                                  O Abwesend
                                  @foxriver76
                                  Okay.
                                    MartinPM Online
                                    MartinPM Online
                                    MartinP
                                    @foxriver76 Aktuell ist die Kiste noch mitten im Update Prozess, kann ich nicht beantworten. Ist aber eigentlich auf dem aktuellen Stable-Stand (Keine Hinweise auf Updates)
                                    • MartinPM MartinP
                                      foxriver76F Offline
                                      foxriver76F Offline
                                      foxriver76
                                      @martinp ist auch erst seit heute morgen oder gestern Abend stable also könnte sein, dass es ohne manuelles aktualisieren nocht niocht aufgepoppt ist.
                                        crunchipC Offline
                                        crunchipC Offline
                                        @foxriver76 sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                                        hab ich vorher gestoppt, trotzdem bei upgrade, irgendwie seltsam
                                        2024-08-02 09:22:49.895  - info: admin.0 (150) ==> Connected system.user.admin from ::ffff:10.1.1.129
                                        2024-08-02 09:23:23.143  - info: host.IoBroker "system.adapter.vis-inventwo.0" disabled
                                        2024-08-02 09:23:23.143  - info: host.IoBroker stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
                                        2024-08-02 09:25:05.288  - info: host.IoBroker [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                                        2024-08-02 09:25:05.290  - info: host.IoBroker [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
                                        2024-08-02 09:25:14.298  - info: host.IoBroker force terminating
                                        2024-08-02 09:25:14.299  - info: host.IoBroker Adapter vis-inventwo still running
                                        2024-08-02 09:25:19.287  - error: vis-inventwo.0 (1494) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2024-08-02 09:25:19.301  - error: vis-inventwo.0 (1494) States database error: connect ECONNREFUSED 127.0.0.1:9000
                                        2024-08-02 09:25:24.290  - error: vis-inventwo.0 (1494) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2024-08-02 09:25:24.301  - error: vis-inventwo.0 (1494) States database error: connect ECONNREFUSED 127.0.0.1:9000
                                        2024-08-02 09:25:29.292  - error: vis-inventwo.0 (1494) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2024-08-02 09:25:29.303  - error: vis-inventwo.0 (1494) States database error: connect ECONNREFUSED 127.0.0.1:9000
                                          MartinPM Online
                                          MartinPM Online
                                          MartinP
                                          @foxriver76 Jetzt ist der Update einigermaßen durch. Admin war vorher noch auf 6.xxx, wird gerade auf die 7er Version aktualisiert
