  4. Test Adapter zigbee2mqtt
    6.3k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 203.8k Aufrufe 45 Beobachtet
  • B biker1602
    @asgothian
    biker1602@iobroker:~$ /opt/zigbee2mqtt.io
    -bash: /opt/zigbee2mqtt.io: No such file or directory
    biker1602@iobroker:~$ npm audit
    # npm audit report
    axios  1.0.0 - 1.5.1
    Severity: moderate
    Axios Cross-Site Request Forgery Vulnerability - https://github.com/advisories/GHSA-wf5p-g6vw-rhxx
    fix available via `npm audit fix`
    node_modules/axios
    braces  <3.0.3
    Severity: high
    Uncontrolled resource consumption in braces - https://github.com/advisories/GHSA-grv7-fg5c-xmjg
    node_modules/braces
    follow-redirects  <=1.15.5
    Severity: moderate
    Follow Redirects improperly handles URLs in the url.parse() function - https://github.com/advisories/GHSA-jchw-25xp-jwwc
    follow-redirects' Proxy-Authorization header kept across hosts - https://github.com/advisories/GHSA-cxjh-pqwp-8mfp
    node_modules/follow-redirects
    ip  *
    Severity: high
    ip SSRF improper categorization in isPublic - https://github.com/advisories/GHSA-2p57-rm9w-gvfp
    NPM IP package incorrectly identifies some private IP addresses as public - https://github.com/advisories/GHSA-78xj-cgh5-2h22
    fix available via `npm audit fix --force`
    Will install iobroker.ring@1.2.8, which is a breaking change
    node_modules/ip
      werift  *
      Depends on vulnerable versions of ip
      node_modules/werift
        ring-client-api  >=11.0.1
        Depends on vulnerable versions of werift
        node_modules/ring-client-api
          iobroker.ring  >=2.0.0-beta.0
          Depends on vulnerable versions of ring-client-api
          node_modules/iobroker.ring
    semver  6.0.0 - 6.3.0
    Severity: moderate
    semver vulnerable to Regular Expression Denial of Service - https://github.com/advisories/GHSA-c2qf-rxjj-qqgw
    node_modules/semver
    tar  <6.2.1
    Severity: moderate
    Denial of service while parsing a tar file due to lack of folders count validation - https://github.com/advisories/GHSA-f5x3-32g6-xq36
    node_modules/tar
    ws  7.0.0 - 7.5.9 || 8.0.0 - 8.17.0
    Severity: high
    ws affected by a DoS when handling a request with many HTTP headers - https://github.com/advisories/GHSA-3h5v-q93c-6h6q
    node_modules/engine.io-client/node_modules/ws
    node_modules/ws
      engine.io-client  0.7.0 || 0.7.8 - 0.7.9 || 3.5.0 - 3.5.3 || 4.0.0-alpha.0 - 5.2.0
      Depends on vulnerable versions of ws
    11 vulnerabilities (4 moderate, 7 high)
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues (including breaking changes), run:
    -bash: /opt/zigbee2mqtt: Is a directory
    # npm audit report
    axios  1.0.0 - 1.5.1
    Severity: moderate
    node_modules/axios
    braces  <3.0.3
    Severity: high
    node_modules/braces
    Severity: moderate
    ip  *
    Severity: high
    node_modules/ip
      werift  *
      node_modules/werift
    Severity: moderate
    node_modules/semver
    tar  <6.2.1
    Severity: moderate
    node_modules/tar
    Severity: high
    node_modules/ws
      npm audit fix
    iker1602@iobroker:~$ cd /opt/zigbee2mqtt
    biker1602@iobroker:/opt/zigbee2mqtt$ npm audit
    found 0 vulnerabilities
    Irgendwie findet er da nichts oder?
    MartinPM Offline
    MartinPM Offline
    MartinP
    #444
    @biker1602 Okay, also arbeitest Du mit einer dem zigbee2mqtt Adapter vorgeschalteten zigbee2MQTT Server - Instanz...
    • MartinPM MartinP
      @biker1602 Du solltest erstmal genauer beschreiben, wie Du den bisherigen USB-Koordinator mit ioBroker verbunden hast.
      Der Einsatz des zigbee2mqtt Adapters legt ja nahe, dass der USB-Koordinator über einen zigbee2MQTT Server eingebunden ist...
      Jedenfalls ist DAS der Verwendungszweck des zigbee2mqtt Adapters.
      biker1602
      #445
      @martinp said in Test Adapter zigbee2mqtt:
      Der USB Koordinator wird durgeschliffen bei Proxmox und wird nur für den normalen Zigbee Adapter genutzt.
      • MartinPM MartinP
        biker1602
        schrieb am zuletzt editiert von biker1602
        #446
        Ich weiß schon garnichts mehr. Den SLZB-06 habe ich erst kurz. Mein Plan war Zigbee2mqtt zu nutzen und den anderen (sonoff) und den Zigbee Adapter zu deaktivieren.
        Ich bekommen zigbee2mqtt aber nicht deinstalliert um alles nochmal neu zu machen.
        Wenn ich den Status abfrage kommt folgende Meldung
        biker1602@iobroker:~$ systemctl status zigbee2mqtt.service
        ● zigbee2mqtt.service - zigbee2mqtt
             Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
             Active: activating (auto-restart) (Result: exit-code) since Thu 2024-07-11 11:00:35 CEST; 2s ago
            Process: 72010 ExecStart=/usr/bin/node index.js (code=exited, status=1/FAILURE)
           Main PID: 72010 (code=exited, status=1/FAILURE)
                CPU: 562ms
        AsgothianA 1Topf1 2 Antworten Letzte Antwort
        • B biker1602
                  CPU: 562ms
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #447
          @biker1602 Ich denke damit kommt das hier zum Tragen:
          @asgothian sagte in Test Adapter zigbee2mqtt:
          Beim Zigbee2mqtt.io Projekt nachschauen - die haben eigentlich gute Doku zu solchen Fällen.
          Nachtrag: wenn Du dir den Text der Fehlermeldung genau anschaust, dann beschwert er sich darüber das im YAML das Schlüsselwort "serial:" doppelt vorkommt. Das kommt von Deiner Anpassung als du den TCP Port eingetragen hast. berichtige das mal, dann sollte der laufen.
          A.
            biker1602
            #448
            @asgothian
            Ich habe probiert und versucht. Jetzt habe ich ihn im ioBroker drin kann ihn auch aufrufen.
            Im Protokoll sind aber Fehlermeldungen
            2024-07-11 16:16:04.346 - warn: zigbee2mqtt.0 (89552) Start try again in 1 seconds...
            2024-07-11 16:16:09.744 - error: zigbee2mqtt.0 (89588) ===================================================
            2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) ===================================================
            2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) Legacy api is activated, so the adapter can not work correctly!!!
            2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) Please add the following lines to your Zigbee2MQTT configuration.yaml:
            2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) advanced:
            2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) legacy_api: false
            2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588)
            2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) Legacy Availability Payload is activated, thus the adapter cannot represent the availability of the devices!!!
            2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) Please add the following lines to your Zigbee2MQTT configuration.yaml:
            2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) advanced:
            2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) legacy_availability_payload: false
            2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) Device Legacy Payload is activated, therefore the adapter may process the states of the devices correctly!!!
            2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) Please add the following lines to your Zigbee2MQTT configuration.yaml:
            2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) device_options:
            2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) legacy: false
            2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) ===================================================
            und der Adapter wird nicht grün
            AsgothianA crunchipC 2 Antworten Letzte Antwort
            • B biker1602
              @asgothian
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #449
              @biker1602 Hast du den getan wozu dich das Log auffordert ?
              • B biker1602
                @asgothian
                crunchipC Offline
                crunchipC Offline
                #450
                @biker1602 sagte in Test Adapter zigbee2mqtt:
                configuration.yaml
                Wie sieht die denn im Ganzen aus?
                B 2 Antworten Letzte Antwort
                • AsgothianA Asgothian
                  biker1602
                  #451
                  @asgothian said in Test Adapter zigbee2mqtt:
                  Soll ich das in der Configuration eintragen?
                  legacy_api: false
                    configuration.yaml
                    biker1602
                    #452
                    @crunchip said in Test Adapter zigbee2mqtt:
                    configuration.yaml
                    Das ist Protokoll im iobroker da ist nicht mehr.
                      configuration.yaml
                      biker1602
                      #453
                      configuration.yaml
                      Das ist die Config
                      # Home Assistant integration (MQTT discovery)
                      homeassistant: false
                      # Enable the frontend, runs on port 8080 by default
                      frontend: true
                      # allow new device to join
                      # permit_join: true
                      # MQTT settings
                      mqtt:
                        # MQTT base topic for zigbee2mqtt MQTT messages
                        base_topic: zigbee2mqtt
                        # MQTT server URL
                        server: 'mqtt://localhost'
                        # MQTT server authentication, uncomment if required:
                         user: biker1602
                         password: Ulli1602
                      # Serial settings
                        # Achtung: Wenn Sie das Z2M-Add-on für HA verwenden, ist es besser, die Yaml-Konfigurationsdatei direkt zu bearbeiten
                      serial:
                      # Location of SLZB-06
                        port: tcp://192.168.57.90:6638
                        baudrate: 115200
                        adapter: zstack
                      # Grüne LED deaktivieren?
                        disable_led: false
                      # Ausgangsleistung auf max. 20 einstellen
                      advanced:
                        transmit_power: 20
                      # Advanced settings
                        network_key: GENERATE
                        pan_id: GENERATE
                        ext_pan_id: GENERATE
                      crunchipC D 2 Antworten Letzte Antwort
                      • B biker1602
                        configuration.yaml
                        Das ist die Config
                        frontend: true
                        # permit_join: true
                        # MQTT settings
                        mqtt:
                          # MQTT server URL
                           user: biker1602
                           password: Ulli1602
                        # Serial settings
                        serial:
                          baudrate: 115200
                          adapter: zstack
                          disable_led: false
                        advanced:
                          transmit_power: 20
                        # Advanced settings
                          pan_id: GENERATE
                        crunchipC Offline
                        crunchipC Offline
                        #454
                        @biker1602 da fehlt bisserl was, im ersten Beitrag steht was zwingend eingetragen werden muss und in der Adapterbeschreibung steht es etwas ausführlicher
                          biker1602
                          #455
                          Ich mache einen anderen Tag weiter oder lasse es ganz. Ich sehe den Wald vor lauter Bäumen nicht mehr.
                          Kann mir jemand sagen wie ich das ganze in putty deinstallieren kann das auch alles verschwindet und nicht irgendwo noch versteckte Dateien sind dich nicht gelöscht werden?
                          • B biker1602
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #456
                            @biker1602 es gibt keine versteckten Datei .. bist ja nicht unter Windows
                            und wenn du die config richtig machst dann geht das auch..man muss sich halt einlesen.. es ist nicht reinstöpseln ..fettisch
                            es ist alles gut Dokumentiert (wozu schreiben wir den quatsch)
                              biker1602
                              #457
                              @arteck said in Test Adapter zigbee2mqtt:
                              Entschuldigung Vielleicht war ich ja gestern auch genervt weil es nicht funktioniert hat. Ich hatte es dann gestern doch noch hinbekommen und war auch glücklich das ich Geräte anlernen konnte. Heute Morgen denke ich mal sehen was bei HA passiert und da war der Adapter auch zu sehen. Ich in meinem Übermut wollte ihne konfigurieren und habe plötzlich Panik bekommen und abgebrochen. seitdem kann ich keine Geräte mehr anlernen und es kommt ein Roter Warnhinweis unter Protokolle.
                              zh:zstack:znp: Error while parsing to ZpiObject 'TypeError: Cannot read properties of undefined (reading 'name') at Function.readParameters (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:88:63) at Function.fromUnpiFrame (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:73:30) at Znp.onUnpiParsed (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:93:38) at Parser.emit (node:events:519:28) at Parser.parseNext (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/unpi/parser.ts:45:26) at Parser._transform (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/unpi/parser.ts:19:14) at Parser.Transform._write (node:internal/streams/transform:171:8) at writeOrBuffer (node:internal/streams/writable:564:12) at _write (node:internal/streams/writable:493:10) at Parser.Writable.write (node:internal/streams/writable:502:10)'
                              Das kann doch nur mit dem HA zusamenhängen oder? Ich hatte in der Configurationstatei nachgesehen da war eine Zeile mit HA dazu gekommen. Die habe ich gelöscht aber das hat das Problem nicht behoben. Hast du eine Ahnung was ich da noch machen kann?
                              2024-07-12 00:00:00.009 - info: hekr.0 (65528) Scheduled restart.
                              2024-07-12 00:00:00.032 - info: hekr.0 (65528) terminating
                              2024-07-12 00:00:00.032 - info: hekr.0 (65528) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2024-07-12 00:00:00.523 - info: hekr.0 (65528) terminating
                              2024-07-12 00:00:01.000 - debug: javascript.0 (64883) [sunTimeSchedules] Times: {"solarNoon":"2024-07-12T11:24:45.080Z","nadir":"2024-07-12T23:24:45.080Z","sunrise":"2024-07-12T03:12:14.591Z","sunset":"2024-07-12T19:37:15.569Z","sunriseEnd":"2024-07-12T03:16:42.195Z","sunsetStart":"2024-07-12T19:32:47.965Z","dawn":"2024-07-12T02:25:23.002Z","dusk":"2024-07-12T20:24:07.158Z","nauticalDawn":"2024-07-12T01:14:32.792Z","nauticalDusk":"2024-07-12T21:34:57.368Z","nightEnd":null,"night":null,"goldenHourEnd":"2024-07-12T04:06:04.637Z","goldenHour":"2024-07-12T18:43:25.523Z"}
                              2024-07-12 00:00:01.023 - debug: javascript.0 (64883) [sunTimeSchedules] Next: 2024-07-12T22:00:01.000Z
                              2024-07-12 00:00:02.476 - info: hekr.0 (98780) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.hekr, node: v20.15.1, js-controller: 5.0.19
                              2024-07-12 00:00:03.511 - info: hekr.0 (98780) Login successful
                              2024-07-12 00:00:04.163 - info: hekr.0 (98780) 1 devices found.
                              2024-07-12 00:00:04.479 - info: hekr.0 (98780) 1 template found.
                              2024-07-12 00:00:08.690 - info: feiertage.0 (98901) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v20.15.1, js-controller: 5.0.19
                              2024-07-12 00:00:08.824 - info: feiertage.0 (98901) Next holiday: Tag der deutschen Einheit is in 83 days on 03.10.2024
                              2024-07-12 00:00:08.831 - info: feiertage.0 (98901) all objects written
                              2024-07-12 00:00:08.875 - info: feiertage.0 (98901) Terminated (NO_ERROR): Without reason
                              2024-07-12 02:01:17.300 - warn: fb-checkpresence.0 (66044) checkDevices: getDeviceList: AxiosError maxContentLength size of -1 exceeded
                              2024-07-12 03:00:11.924 - warn: broadlink2.0 (99046) device RM:RMMINI-1a-02-40 not found, please rescan later again or delete it! It was: 192.168.57.109,80,10039,Broadlink Mini,0,[object Object],78:0f:77:1a:02:40,RM,RM:RMMINI-1a-02-40,0x2737,RM Mini,RMMINI-1a-02-40,RM:RMMINI-1a-02-40,50
                              2024-07-12 04:46:32.180 - warn: fb-checkpresence.0 (66044) checkDevices: getDeviceList: AxiosError maxContentLength size of -1 exceeded
                              2024-07-12 05:04:03.167 - info: javascript.0 (64883) script.js.Meine_Schalter.Büro.Test_Telegram_Menü:
                              2024-07-12 06:00:00.009 - info: hekr.0 (98780) Scheduled restart.
                              2024-07-12 06:00:00.015 - info: hekr.0 (98780) terminating
                              2024-07-12 06:00:00.015 - info: hekr.0 (98780) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2024-07-12 06:00:00.515 - info: hekr.0 (98780) terminating
                              2024-07-12 06:00:02.482 - info: hekr.0 (99264) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.hekr, node: v20.15.1, js-controller: 5.0.19
                              2024-07-12 06:00:03.257 - info: hekr.0 (99264) Login successful
                              2024-07-12 06:00:03.876 - info: hekr.0 (99264) 1 devices found.
                              2024-07-12 06:00:04.723 - info: hekr.0 (99264) 1 template found.
                              2024-07-12 06:31:34.430 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Kaffemaschine: Bitteschön, Dein Kaffeeautomat einschalten und spülen ist fertig
                              2024-07-12 06:39:06.821 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Kaffemaschine: Bitteschön, Dein Caffè Crema ist fertig
                              2024-07-12 06:44:13.448 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Kaffemaschine: Bitteschön, Dein Caffè Crema ist fertig
                              2024-07-12 06:45:48.277 - warn: zigbee2mqtt.0 (98069) z2m: Device '0x00158d000487408c' left the network
                              2024-07-12 06:58:14.862 - info: javascript.0 (64883) Stopping script script.js.Meine_Schalter.Schlafzimmer.Ventilator
                              2024-07-12 06:58:14.907 - info: javascript.0 (64883) Start JavaScript script.js.Meine_Schalter.Schlafzimmer.Ventilator (Blockly)
                              2024-07-12 06:58:14.925 - info: javascript.0 (64883) script.js.Meine_Schalter.Schlafzimmer.Ventilator: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                              2024-07-12 07:25:00.649 - info: javascript.0 (64883) Stopping script script.js.Meine_Schalter.Küche.Musik_Küche_Bewegungsmelder
                              2024-07-12 07:25:00.696 - info: javascript.0 (64883) Start JavaScript script.js.Meine_Schalter.Küche.Musik_Küche_Bewegungsmelder (Blockly)
                              2024-07-12 07:25:00.711 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Musik_Küche_Bewegungsmelder: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2024-07-12 07:38:11.826 - error: zigbee2mqtt.0 (98069) zh:zstack:znp: Error while parsing to ZpiObject 'TypeError: Cannot read properties of undefined (reading 'name')
                              2024-07-12 07:44:33.170 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/2, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":211,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,87,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                              2024-07-12 07:44:36.178 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 2/2, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":212,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,88,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                              2024-07-12 07:54:37.189 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":213,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,89,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                              2024-07-12 07:56:06.936 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 07:56:16.769 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 07:56:23.430 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 07:56:30.058 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 07:56:41.258 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 07:57:31.211 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 07:58:51.162 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:00:12.992 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:00:19.085 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:00:45.364 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:02:50.022 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:04:38.197 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":214,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,90,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                              2024-07-12 08:07:40.767 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:11:40.196 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:11:50.666 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:14:39.206 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":215,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,91,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                              2024-07-12 08:18:41.767 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:18:50.614 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                              2024-07-12 08:24:40.215 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":216,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,92,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                              • B biker1602
                                        CPU: 562ms
                                1Topf1 Offline
                                1Topf1 Offline
                                1Topf
                                #458
                                Nur falls es dich noch interessiert, wie man es löscht:
                                sudo rm -rf /opt/zigbee2mqtt
                                • 1Topf1 1Topf
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #459
                                  @1topf sagte in Test Adapter zigbee2mqtt:
                                  /opt/zigbee2mqtt
                                  wenns da installiert wurde....
                                  das ist jetzt nicht dein erst oder.. währe da dein Haus explodiert oder hättest du das Internet damit gelöscht oder wie...
                                  kein plan was du da anstellst .. vor allem im HA bareich..
                                  prüfe nochmal alles angefangen von zigbee2mqtt (läuft es ohne fehler) dann den adapter verbindet sich dieser mit zigbee2mqtt ohne fehler..
                                    biker1602
                                    #460
                                    Ich habe jetzt erst bei HA ein Backup eingespielt den den SLZB neu gestartet und ich kann jetzt wieder Geräte anlernen und obwohl ich availability: true hinterlegt habe, zeigt er mir unter Objekte die Geräte mit Gelb und als nicht verbunden an.
                                    Die Geräte reagieren aber so z.B Bewegungsmelder oder so. Das macht mich stutzig.
                                    • B biker1602
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #461
                                      @biker1602 hast du alle gesetzt
                                      advanced:
                                           legacy_api: false
                                           output: json
                                      device_options:
                                           legacy: false
                                      availability: true
                                      • arteckA arteck
                                        advanced:
                                             legacy_api: false
                                             output: json
                                        device_options:
                                             legacy: false
                                        availability: true
                                        biker1602
                                        #462
                                        @arteck
                                        device options: stand nicht drin alles andere ja und jetzt sind sie auch Grün.👍 👍
                                        Eine Frage habe ich noch. Wieso werden auf dem Dashbord nicht alle Geräte angezeigt?
                                        Unter Geräte sind sie alle da.
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #463
                                          auf dem Dashbord
                                          auf welchen Dashboard ?
