  4. Test Adapter zigbee2mqtt
    6.3k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 203.9k Aufrufe 45 Beobachtet
    biker1602
    schrieb am zuletzt editiert von biker1602
    #448
    @asgothian
    Ich habe probiert und versucht. Jetzt habe ich ihn im ioBroker drin kann ihn auch aufrufen.
    Im Protokoll sind aber Fehlermeldungen
    2024-07-11 16:16:04.346 - warn: zigbee2mqtt.0 (89552) Start try again in 1 seconds...
    2024-07-11 16:16:09.744 - error: zigbee2mqtt.0 (89588) ===================================================
    2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) ===================================================
    2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) Legacy api is activated, so the adapter can not work correctly!!!
    2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) Please add the following lines to your Zigbee2MQTT configuration.yaml:
    2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) advanced:
    2024-07-11 16:16:09.747 - error: zigbee2mqtt.0 (89588) legacy_api: false
    2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588)
    2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) Legacy Availability Payload is activated, thus the adapter cannot represent the availability of the devices!!!
    2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) Please add the following lines to your Zigbee2MQTT configuration.yaml:
    2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) advanced:
    2024-07-11 16:16:09.748 - error: zigbee2mqtt.0 (89588) legacy_availability_payload: false
    2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) Device Legacy Payload is activated, therefore the adapter may process the states of the devices correctly!!!
    2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) Please add the following lines to your Zigbee2MQTT configuration.yaml:
    2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) device_options:
    2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) legacy: false
    2024-07-11 16:16:09.749 - error: zigbee2mqtt.0 (89588) ===================================================
    und der Adapter wird nicht grün
    AsgothianA crunchipC 2 Antworten Letzte Antwort
    • B biker1602
      @asgothian
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #449
      @biker1602 Hast du den getan wozu dich das Log auffordert ?
      • B biker1602
        @asgothian
        crunchipC Abwesend
        crunchipC Abwesend
        #450
        @biker1602 sagte in Test Adapter zigbee2mqtt:
        configuration.yaml
        Wie sieht die denn im Ganzen aus?
        B 2 Antworten Letzte Antwort
        • AsgothianA Asgothian
          biker1602
          #451
          @asgothian said in Test Adapter zigbee2mqtt:
          Soll ich das in der Configuration eintragen?
          legacy_api: false
            configuration.yaml
            biker1602
            #452
            @crunchip said in Test Adapter zigbee2mqtt:
            configuration.yaml
            Das ist Protokoll im iobroker da ist nicht mehr.
              configuration.yaml
              biker1602
              #453
              configuration.yaml
              Das ist die Config
              # Home Assistant integration (MQTT discovery)
              homeassistant: false
              # Enable the frontend, runs on port 8080 by default
              frontend: true
              # allow new device to join
              # permit_join: true
              # MQTT settings
              mqtt:
                # MQTT base topic for zigbee2mqtt MQTT messages
                base_topic: zigbee2mqtt
                # MQTT server URL
                server: 'mqtt://localhost'
                # MQTT server authentication, uncomment if required:
                 user: biker1602
                 password: Ulli1602
              # Serial settings
                # Achtung: Wenn Sie das Z2M-Add-on für HA verwenden, ist es besser, die Yaml-Konfigurationsdatei direkt zu bearbeiten
              serial:
              # Location of SLZB-06
                port: tcp://192.168.57.90:6638
                baudrate: 115200
                adapter: zstack
              # Grüne LED deaktivieren?
                disable_led: false
              # Ausgangsleistung auf max. 20 einstellen
              advanced:
                transmit_power: 20
              # Advanced settings
                network_key: GENERATE
                pan_id: GENERATE
                ext_pan_id: GENERATE
              crunchipC D 2 Antworten Letzte Antwort
              • B biker1602
                configuration.yaml
                Das ist die Config
                frontend: true
                # permit_join: true
                # MQTT settings
                mqtt:
                  # MQTT server URL
                   user: biker1602
                   password: Ulli1602
                # Serial settings
                serial:
                  baudrate: 115200
                  adapter: zstack
                  disable_led: false
                advanced:
                  transmit_power: 20
                # Advanced settings
                  pan_id: GENERATE
                crunchipC Abwesend
                crunchipC Abwesend
                #454
                @biker1602 da fehlt bisserl was, im ersten Beitrag steht was zwingend eingetragen werden muss und in der Adapterbeschreibung steht es etwas ausführlicher
                  biker1602
                  #455
                  Ich mache einen anderen Tag weiter oder lasse es ganz. Ich sehe den Wald vor lauter Bäumen nicht mehr.
                  Kann mir jemand sagen wie ich das ganze in putty deinstallieren kann das auch alles verschwindet und nicht irgendwo noch versteckte Dateien sind dich nicht gelöscht werden?
                  • B biker1602
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #456
                    @biker1602 es gibt keine versteckten Datei .. bist ja nicht unter Windows
                    und wenn du die config richtig machst dann geht das auch..man muss sich halt einlesen.. es ist nicht reinstöpseln ..fettisch
                    es ist alles gut Dokumentiert (wozu schreiben wir den quatsch)
                      biker1602
                      #457
                      @arteck said in Test Adapter zigbee2mqtt:
                      Entschuldigung Vielleicht war ich ja gestern auch genervt weil es nicht funktioniert hat. Ich hatte es dann gestern doch noch hinbekommen und war auch glücklich das ich Geräte anlernen konnte. Heute Morgen denke ich mal sehen was bei HA passiert und da war der Adapter auch zu sehen. Ich in meinem Übermut wollte ihne konfigurieren und habe plötzlich Panik bekommen und abgebrochen. seitdem kann ich keine Geräte mehr anlernen und es kommt ein Roter Warnhinweis unter Protokolle.
                      zh:zstack:znp: Error while parsing to ZpiObject 'TypeError: Cannot read properties of undefined (reading 'name') at Function.readParameters (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:88:63) at Function.fromUnpiFrame (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:73:30) at Znp.onUnpiParsed (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:93:38) at Parser.emit (node:events:519:28) at Parser.parseNext (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/unpi/parser.ts:45:26) at Parser._transform (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/unpi/parser.ts:19:14) at Parser.Transform._write (node:internal/streams/transform:171:8) at writeOrBuffer (node:internal/streams/writable:564:12) at _write (node:internal/streams/writable:493:10) at Parser.Writable.write (node:internal/streams/writable:502:10)'
                      Das kann doch nur mit dem HA zusamenhängen oder? Ich hatte in der Configurationstatei nachgesehen da war eine Zeile mit HA dazu gekommen. Die habe ich gelöscht aber das hat das Problem nicht behoben. Hast du eine Ahnung was ich da noch machen kann?
                      2024-07-12 00:00:00.009 - info: hekr.0 (65528) Scheduled restart.
                      2024-07-12 00:00:00.032 - info: hekr.0 (65528) terminating
                      2024-07-12 00:00:00.032 - info: hekr.0 (65528) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2024-07-12 00:00:00.523 - info: hekr.0 (65528) terminating
                      2024-07-12 00:00:01.000 - debug: javascript.0 (64883) [sunTimeSchedules] Times: {"solarNoon":"2024-07-12T11:24:45.080Z","nadir":"2024-07-12T23:24:45.080Z","sunrise":"2024-07-12T03:12:14.591Z","sunset":"2024-07-12T19:37:15.569Z","sunriseEnd":"2024-07-12T03:16:42.195Z","sunsetStart":"2024-07-12T19:32:47.965Z","dawn":"2024-07-12T02:25:23.002Z","dusk":"2024-07-12T20:24:07.158Z","nauticalDawn":"2024-07-12T01:14:32.792Z","nauticalDusk":"2024-07-12T21:34:57.368Z","nightEnd":null,"night":null,"goldenHourEnd":"2024-07-12T04:06:04.637Z","goldenHour":"2024-07-12T18:43:25.523Z"}
                      2024-07-12 00:00:01.023 - debug: javascript.0 (64883) [sunTimeSchedules] Next: 2024-07-12T22:00:01.000Z
                      2024-07-12 00:00:02.476 - info: hekr.0 (98780) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.hekr, node: v20.15.1, js-controller: 5.0.19
                      2024-07-12 00:00:03.511 - info: hekr.0 (98780) Login successful
                      2024-07-12 00:00:04.163 - info: hekr.0 (98780) 1 devices found.
                      2024-07-12 00:00:04.479 - info: hekr.0 (98780) 1 template found.
                      2024-07-12 00:00:08.690 - info: feiertage.0 (98901) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v20.15.1, js-controller: 5.0.19
                      2024-07-12 00:00:08.824 - info: feiertage.0 (98901) Next holiday: Tag der deutschen Einheit is in 83 days on 03.10.2024
                      2024-07-12 00:00:08.831 - info: feiertage.0 (98901) all objects written
                      2024-07-12 00:00:08.875 - info: feiertage.0 (98901) Terminated (NO_ERROR): Without reason
                      2024-07-12 02:01:17.300 - warn: fb-checkpresence.0 (66044) checkDevices: getDeviceList: AxiosError maxContentLength size of -1 exceeded
                      2024-07-12 03:00:11.924 - warn: broadlink2.0 (99046) device RM:RMMINI-1a-02-40 not found, please rescan later again or delete it! It was: 192.168.57.109,80,10039,Broadlink Mini,0,[object Object],78:0f:77:1a:02:40,RM,RM:RMMINI-1a-02-40,0x2737,RM Mini,RMMINI-1a-02-40,RM:RMMINI-1a-02-40,50
                      2024-07-12 04:46:32.180 - warn: fb-checkpresence.0 (66044) checkDevices: getDeviceList: AxiosError maxContentLength size of -1 exceeded
                      2024-07-12 05:04:03.167 - info: javascript.0 (64883) script.js.Meine_Schalter.Büro.Test_Telegram_Menü:
                      2024-07-12 06:00:00.009 - info: hekr.0 (98780) Scheduled restart.
                      2024-07-12 06:00:00.015 - info: hekr.0 (98780) terminating
                      2024-07-12 06:00:00.015 - info: hekr.0 (98780) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2024-07-12 06:00:00.515 - info: hekr.0 (98780) terminating
                      2024-07-12 06:00:02.482 - info: hekr.0 (99264) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.hekr, node: v20.15.1, js-controller: 5.0.19
                      2024-07-12 06:00:03.257 - info: hekr.0 (99264) Login successful
                      2024-07-12 06:00:03.876 - info: hekr.0 (99264) 1 devices found.
                      2024-07-12 06:00:04.723 - info: hekr.0 (99264) 1 template found.
                      2024-07-12 06:31:34.430 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Kaffemaschine: Bitteschön, Dein Kaffeeautomat einschalten und spülen ist fertig
                      2024-07-12 06:39:06.821 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Kaffemaschine: Bitteschön, Dein Caffè Crema ist fertig
                      2024-07-12 06:44:13.448 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Kaffemaschine: Bitteschön, Dein Caffè Crema ist fertig
                      2024-07-12 06:45:48.277 - warn: zigbee2mqtt.0 (98069) z2m: Device '0x00158d000487408c' left the network
                      2024-07-12 06:58:14.862 - info: javascript.0 (64883) Stopping script script.js.Meine_Schalter.Schlafzimmer.Ventilator
                      2024-07-12 06:58:14.907 - info: javascript.0 (64883) Start JavaScript script.js.Meine_Schalter.Schlafzimmer.Ventilator (Blockly)
                      2024-07-12 06:58:14.925 - info: javascript.0 (64883) script.js.Meine_Schalter.Schlafzimmer.Ventilator: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                      2024-07-12 07:25:00.649 - info: javascript.0 (64883) Stopping script script.js.Meine_Schalter.Küche.Musik_Küche_Bewegungsmelder
                      2024-07-12 07:25:00.696 - info: javascript.0 (64883) Start JavaScript script.js.Meine_Schalter.Küche.Musik_Küche_Bewegungsmelder (Blockly)
                      2024-07-12 07:25:00.711 - info: javascript.0 (64883) script.js.Meine_Schalter.Küche.Musik_Küche_Bewegungsmelder: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                      2024-07-12 07:38:11.826 - error: zigbee2mqtt.0 (98069) zh:zstack:znp: Error while parsing to ZpiObject 'TypeError: Cannot read properties of undefined (reading 'name')
                      2024-07-12 07:44:33.170 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/2, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":211,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,87,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                      2024-07-12 07:44:36.178 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 2/2, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":212,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,88,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                      2024-07-12 07:54:37.189 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":213,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,89,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                      2024-07-12 07:56:06.936 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 07:56:16.769 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 07:56:23.430 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 07:56:30.058 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 07:56:41.258 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 07:57:31.211 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 07:58:51.162 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:00:12.992 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:00:19.085 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:00:45.364 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:02:50.022 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:04:38.197 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":214,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,90,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                      2024-07-12 08:07:40.767 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:11:40.196 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:11:50.666 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:14:39.206 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":215,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,91,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                      2024-07-12 08:18:41.767 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:18:50.614 - error: zigbee2mqtt.0 (98069) z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
                      2024-07-12 08:24:40.215 - warn: zigbee2mqtt.0 (98069) z2m: Failed to ping 'Osram Steckdose Küche' (attempt 1/1, ZCL command 0x7cb03eaa0a094194/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> AF - dataRequest - {"dstaddr":33593,"destendpoint":3,"srcendpoint":1,"clusterid":0,"transid":216,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[16,92,0,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')))
                      • B biker1602
                        @martinp said in Test Adapter zigbee2mqtt:
                        @biker1602 Okay, also arbeitest Du mit einer dem zigbee2mqtt Adapter vorgeschalteten zigbee2MQTT Server - Instanz...
                        Ich weiß schon garnichts mehr. Den SLZB-06 habe ich erst kurz. Mein Plan war Zigbee2mqtt zu nutzen und den anderen (sonoff) und den Zigbee Adapter zu deaktivieren.
                        Ich bekommen zigbee2mqtt aber nicht deinstalliert um alles nochmal neu zu machen.
                        Wenn ich den Status abfrage kommt folgende Meldung
                        biker1602@iobroker:~$ systemctl status zigbee2mqtt.service
                        ● zigbee2mqtt.service - zigbee2mqtt
                             Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
                             Active: activating (auto-restart) (Result: exit-code) since Thu 2024-07-11 11:00:35 CEST; 2s ago
                            Process: 72010 ExecStart=/usr/bin/node index.js (code=exited, status=1/FAILURE)
                           Main PID: 72010 (code=exited, status=1/FAILURE)
                                CPU: 562ms
                        1Topf1 Offline
                        1Topf1 Offline
                        1Topf
                        #458
                        Nur falls es dich noch interessiert, wie man es löscht:
                        sudo rm -rf /opt/zigbee2mqtt
                        • 1Topf1 1Topf
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #459
                          @1topf sagte in Test Adapter zigbee2mqtt:
                          /opt/zigbee2mqtt
                          wenns da installiert wurde....
                          das ist jetzt nicht dein erst oder.. währe da dein Haus explodiert oder hättest du das Internet damit gelöscht oder wie...
                          kein plan was du da anstellst .. vor allem im HA bareich..
                          prüfe nochmal alles angefangen von zigbee2mqtt (läuft es ohne fehler) dann den adapter verbindet sich dieser mit zigbee2mqtt ohne fehler..
                            biker1602
                            #460
                            Ich habe jetzt erst bei HA ein Backup eingespielt den den SLZB neu gestartet und ich kann jetzt wieder Geräte anlernen und obwohl ich availability: true hinterlegt habe, zeigt er mir unter Objekte die Geräte mit Gelb und als nicht verbunden an.
                            Die Geräte reagieren aber so z.B Bewegungsmelder oder so. Das macht mich stutzig.
                            • B biker1602
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #461
                              @biker1602 hast du alle gesetzt
                              advanced:
                                   legacy_api: false
                                   output: json
                              device_options:
                                   legacy: false
                              availability: true
                              • arteckA arteck
                                advanced:
                                     legacy_api: false
                                     output: json
                                device_options:
                                     legacy: false
                                availability: true
                                biker1602
                                #462
                                @arteck
                                device options: stand nicht drin alles andere ja und jetzt sind sie auch Grün.👍 👍
                                Eine Frage habe ich noch. Wieso werden auf dem Dashbord nicht alle Geräte angezeigt?
                                Unter Geräte sind sie alle da.
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #463
                                  auf dem Dashbord
                                  auf welchen Dashboard ?
                                    tritor
                                    #464
                                    hab den Adapter nun erfolgreich am Laufen.
                                    Einzig, im log scheint folgendes auf:
                                    zigbee2mqtt.0 2024-07-14 11:47:16.010	warn	No image for device model: ICPSHC24-10EU-IL-1/ICPSHC24-10EU-IL-2 found!
                                    zigbee2mqtt.0 2024-07-14 11:47:16.007	warn	AxiosError: Request failed with status code 404
                                    Meldung ist ja eindeutig, daß eben das Bild fehlt.
                                    Im Adapter ist der Haken im Setup gesetzt:
                                    und im z2m server ist das Bild auch ersichtlich:
                                    Frage: wie kriege ich das Bild im ioB rein und die Fehlermeldung weg?
                                    Gernot
                                    Host: i9 server Proxmox , Debian 13.4 for ioBroker
                                    ioBroker: 7.9.2, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.2.1
                                    Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
                                    Grafana 13.0.1 / InfluxDB 2.8.0
                                    DolomitiD arteckA 2 Antworten Letzte Antwort
                                    • T tritor
                                      DolomitiD Offline
                                      DolomitiD Offline
                                      Dolomiti
                                      #465
                                      @tritor
                                      Da war mal was mit einer falschen Dateiendung der Icons. Ich hatte das Problem zwar mit dem Zigbee-Adapter, aber der holt sich die Icons auch von Z2M. Evtl. ist hier das gleiche Problem.
                                      https://forum.iobroker.net/post/1160809
                                      Intel N100 (32GB,256GB SSD), Proxmox -> Debian 13 in VM (Master) + Debian 13 in CT (Test) + Debmatic, HM-Aktoren, Wago 750-880, Shelly, Zigbee
                                      • T tritor
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #466
                                        @tritor muss ich mal schauen..
                                        da ist weider mal eas zusammengesetztes was der adater nicht finden kann
                                        • arteckA arteck
                                          auf dem Dashbord
                                          biker1602
                                          #467
                                          @arteck
                                          Wieso werden keine Symbole unter Objekte angezeigt so wie unter dem normalen Zigbee Adpter? ist das eine Einstellungssache?
                                          arteckA T 2 Antworten Letzte Antwort
