  4. Alpha Test js-controller Kiera (v6.0)
alphajs-controllerkieratest
234 Beiträge 20 Kommentatoren 72.9k Aufrufe 25 Beobachtet
  • T TT-Tom
    auf meinem Testsystem läuft jetzt auch der neue Controller. Im Testsystem laufen alle Adapter mit dem Beta-Repro und sind auf dem letzten Stand.
    Der Fahrplan Adapter 1.2.3 startet nicht und bringt folgende Meldungen. läuft jetzt nach npm update
    host.iobtest
    2024-05-24 11:16:00.146	info	instance system.adapter.fahrplan.0 started with pid 218788
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: ^
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module zipFiles.js
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/controllerTools.js:128:15)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
    host.iobtest
    2024-05-24 11:16:01.254	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/index.js:19:27)
    host.iobtest
    2024-05-24 11:16:01.254	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.iobtest
    2024-05-24 11:16:01.254	error	Caught by controller[0]: Node.js v18.20.2
    host.iobtest
    2024-05-24 11:16:01.254	error	instance system.adapter.fahrplan.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobtest
    2024-05-24 11:16:01.254	info	Restart adapter system.adapter.fahrplan.0 because enabled
    Bei dem Javascript Adapter 8.3.1 ist mir folgendes aufgefallen, dass die Module nicht mehr einzeln in der Config stehen.
    habe sie jetzt neu eingetragen, sie werden aber laut Log-Ausgabe nicht geladen / installiert, was mir diese Fehlermeldung bestätigt.
    javascript.0
    2024-05-24 11:37:12.904	info	Compiling TypeScript source script.js.common.NSPanel4400
    javascript.0
    2024-05-24 11:37:15.383	info	script.js.common.NSPanel4400: source code did not change, using cached compilation result...
    javascript.0
    2024-05-24 11:37:15.728	warn	script.js.common.NSPanel4400: error at function init_dayjs: dayjs_1.locale is not a function
    javascript.0
    2024-05-24 11:37:15.747	info	script.js.common.NSPanel4400: setObjects enabled - create Alias Channels possible
    javascript.0
    2024-05-24 11:37:15.772	info	script.js.common.NSPanel4400: weather alias for accuweather.0. already exists
    javascript.0
    2024-05-24 11:37:15.897	info	script.js.common.NSPanel4400: registered 33 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0
    2024-05-24 11:37:16.379	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:16.381	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:16.824	info	script.js.common.NSPanel4400: Debug mode disabled
    javascript.0
    2024-05-24 11:37:17.243	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:17.244	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:17.799	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:17.800	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:17.910	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:17.911	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:29.303	warn	script.js.common.NSPanel4400: error at function HandleScreensaverUpdate: parseFormat is not a function
    javascript.0
    2024-05-24 11:37:53.476	info	Stopping script script.js.common.NSPanel4400
    der netamo-crawler Adapter 0.8.1 läuft auch nicht mehr , selbst im Debug modus der Instanz kommen nicht mehr Daten. Läuft jetzt nach npm update
    host.iobtest
    2024-05-24 11:46:00.632	info	instance scheduled system.adapter.netatmo-crawler.0 */5 * * * *
    host.iobtest
    2024-05-24 11:46:00.644	info	instance system.adapter.netatmo-crawler.0 started with pid 219300
    host.iobtest
    2024-05-24 11:46:01.782	error	instance system.adapter.netatmo-crawler.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    das waren die ersten Sachen die ich gefunden habe bei mir.
    haus-automatisierungH
    #106
    @tt-tom sagte in Alpha Test js-controller Kiera (v6.0):
    Von welcher Version bist Du denn vorher gekommen? Denke mal das hängt mit dem Wechsel auf jsonConfig zusammen und dass der alte Wert ggf. nicht richtig migriert wird.
    📚 Meine Dokumentation
      FeuersturmF
      FeuersturmF
      Feuersturm
      #107
      @haus-automatisierung Das Verhalten sehe ich bei mir auch.
      In der Javascript Instanz v8.0.3 auf meinem Produktivsystem werden die npm Module korrekt einzeln dargestellt.
      Auf meinem Testsystem ist Javascript auf 8.3.1 und dort sieht es jetzt auch so aus, das alles in einem item steht
      • FeuersturmF Feuersturm
        #108
        @feuersturm sagte in Alpha Test js-controller Kiera (v6.0):
        Dann zeig mal bitte das Native-Objekt aus dem Instanz-Objekt.
          FeuersturmF
          FeuersturmF
          Feuersturm
          #109
          @haus-automatisierung Meinst du das hier?
            #110
            @feuersturm Genau, danke. Ist also mit Leerzeichen getrennt und kein Array. Muss ich fixen.
            "libraries": "xml2js moment moment-timezone moment-duration-format mathjs",
            Thomas BraunT T 2 Antworten Letzte Antwort
              Thomas BraunT
              Thomas BraunT
              Most Active Developer
              #111
              @foxriver76
              Gerade gecheckt: Die Anzeige von anstehenden Updates meines Debian-Systems funktioniert im Admin.
                @foxriver76
                FeuersturmF
                FeuersturmF
                Feuersturm
                #112
                @thomas-braun sagte in Alpha Test js-controller Kiera (v6.0):
                @foxriver76
                Bei mir werden auch mögliche Updates angezeigt
                Wenn ich dann versuche die Pakete zu aktualisieren werden diese aber nicht aktualisiert, sondern zurückgehalten.
                proxmox@ioBrokerTestsystem:~$ sudo apt update
                [sudo] password for proxmox:
                Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
                Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                Get:5 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [1683 k        B]
                Get:6 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [10        75 kB]
                Fetched 2987 kB in 3s (892 kB/s)
                Reading package lists... Done
                2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                proxmox@ioBrokerTestsystem:~$ sudo apt list --upgradable
                Listing... Done
                python3-update-manager/jammy-updates 1:22.04.20 all [upgradable from: 1:22.04.19]
                update-manager-core/jammy-updates 1:22.04.20 all [upgradable from: 1:22.04.19]
                proxmox@ioBrokerTestsystem:~$ sudo apt full-upgrade -y
                Calculating upgrade... Done
                The following packages have been kept back:
                  python3-update-manager update-manager-core
                0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                Kannst du mir sagen, was hier der Hintergrund ist? Für den Enduser ist die Meldung aus meiner Sicht verwirrend, wenn hier Updates angezeigt werden, welche aber nicht installiert werden können.
                  @foxriver76
                  Listing... Done
                  Thomas BraunT
                  Thomas BraunT
                  #113
                  Das hat mit dem ioBroker nix zu tun sondern ist eine der vielen Schnubbibuntu-Sonderlocken. (Weswegen ich diese Distribution auch nicht mag und auch nicht empfehlen würde).
                  Nennt sich 'Phased Updates' und sorgt dafür, dass eigentlich anstehende Updates in Wellen scharf geschaltet werden.
                    FeuersturmF
                    FeuersturmF
                    Feuersturm
                    #114
                    @thomas-braun Danke für die Erklärung, das heißt ich warte einfach und bis dahin muss ich mit der Meldung leben.
                    • foxriver76F
                      foxriver76F
                      foxriver76
                      #115
                      @thomas-braun https://forum.iobroker.net/topic/74822/alpha-test-js-controller-kiera-v6-0/100 hast du gesehen?
                      Videotutorials & mehr
                        T
                        T
                        TT-Tom
                        #116
                        Danke, warte jetzt auf dein Fix. Wollen wir damit in dein Test Thread wechseln??
                        Gruß Tom
                        Public Transport
                        NSPanel Adapter Dokumentation
                        https://ticaki.github.io/ioBroker.nspanel-lovelace-ui/
                        • T TT-Tom
                          #117
                          Bitte als Issue auf GitHub öffnen. Sonst laufen da zig Themen durcheinander.
                          • foxriver76F foxriver76
                            Thomas BraunT
                            Thomas BraunT
                            #118
                            @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
                            Ja, aber noch nicht testen können. Kein gescheites Terminal zur Hand, nur eine Android-App und mit der will ich nix aufwändigeres per SSH machen.
                            • foxriver76F
                              foxriver76F
                              foxriver76
                              #119
                              An alle: bitte nochmal updaten
                              A F T 3 Antworten Letzte Antwort
                                A
                                A
                                ag
                                #120
                                @foxriver76
                                js-controller 6.01 auf dem testsystem läuft alles wieder.
                                Beim Start der Instamcen nach reboot oder iobroker start.
                                2024-05-24 18:16:06.510 - info: host.RPI5Test instance system.adapter.daikin.0 started with pid 1646
                                2024-05-24 18:16:07.191 - error: daikin.0 (1646) daikin.0 invalid instance object: {"_id":"","type":"device","common":{},"native":{}}
                                2024-05-24 18:16:07.232 - info: daikin.0 (1646) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.daikin, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240524-14a872375
                                2024-05-24 18:16:08.169 - info: daikin.0 (1646) Daikin Device initialized successfully
                                2024-05-24 18:16:08.170 - info: daikin.0 (1646) Set polling Intervall to 300s
                                Adapter funktiniert aber danach
                                Operating System: Debian GNU/Linux 12 architecture: arm64 Pi5 8GB
                                /usr/bin/nodejs v20.18.0 /usr/bin/node 20.18.1 /usr/bin/npm 10.8.2
                                js-controller 7.0.6 admin 7.4.10
                                  F
                                  F
                                  Fortune95
                                  #121
                                  @foxriver76
                                  Aktuelle Version läuft.
                                  Nur der Adapter Heatingcontrol läuft nicht an:
                                  2024-05-24 18:21:38.650  - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-co        re/build/controllerTools.js:83
                                  2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                                  2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]:     ^
                                  2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                                  2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_m        odules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                                  2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_m        odules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                                  2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                                  2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                                  2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_m        odules/@iobroker/adapter-core/build/index.js:19:27)
                                  2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]: Node.js v20.13.1
                                  2024-05-24 18:21:38.652  - error: host.iobroker instance system.adapter.heatingcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  Adapter Instanzen:
                                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                  + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled
                                    system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                                  + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                                    system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                    system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                  + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
                                    system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 - disabled
                                    system.adapter.esphome.0                : esphome               : iobroker                                 - disabled
                                    system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                    system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                                  + system.adapter.gruenbeck.0              : gruenbeck             : iobroker                                 -  enabled
                                    system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 - disabled
                                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                  + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                                    system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 - disabled
                                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                  + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                  + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                  + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  + system.adapter.jeelink.0                : jeelink               : iobroker                                 -  enabled
                                  + system.adapter.klf200.0                 : klf200                : iobroker                                 -  enabled
                                  + system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled
                                    system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
                                  + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.12.219
                                    system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
                                  + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
                                  + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                  + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                  + system.adapter.selverf.0                : selverf               : iobroker                                 -  enabled
                                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1895, bind: 192.168.12.219
                                  + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                                  + system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
                                  + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
                                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                  + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                  + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                                    system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                                  + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                                  + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
                                  + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.12.212:6638
                                  • F Fortune95
                                    @foxriver76
                                    Adapter Instanzen:
                                    T
                                    T
                                    TT-Tom
                                    #122
                                    @fortune95
                                    Da hilft npm update unter /opt/iobroker hatte den Fehler auch
                                    https://forum.iobroker.net/post/1162312
                                    https://forum.iobroker.net/post/1161997
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @fortune95
                                      foxriver76F
                                      foxriver76F
                                      foxriver76
                                      #123
                                      @tt-tom hm sollte jetzt eigentlich automatisch ausgeführt werden bei install der neusten Version 6.0.1-alpha.0-20240524-14a872375
                                        T
                                        T
                                        TT-Tom
                                        #124
                                        @foxriver76
                                        Kann es persönlich erst heute Nacht noch einmal testen.
                                        Gruß Tom
                                        Public Transport
                                        • foxriver76F
                                          foxriver76F
                                          foxriver76
                                          #125
                                          Ansonsten bitte nochmal updaten und log von update zeigen
                                          F Thomas BraunT FeuersturmF 3 Antworten Letzte Antwort
                                          84.2k
