  4. Alpha Test js-controller Kiera (v6.0)
alphajs-controllerkieratest
234 Beiträge 20 Kommentatoren 72.9k Aufrufe 25 Beobachtet
  • T TT-Tom
    auf meinem Testsystem läuft jetzt auch der neue Controller. Im Testsystem laufen alle Adapter mit dem Beta-Repro und sind auf dem letzten Stand.
    Der Fahrplan Adapter 1.2.3 startet nicht und bringt folgende Meldungen. läuft jetzt nach npm update
    host.iobtest
    2024-05-24 11:16:00.146	info	instance system.adapter.fahrplan.0 started with pid 218788
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: ^
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module zipFiles.js
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/controllerTools.js:128:15)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
    host.iobtest
    2024-05-24 11:16:01.254	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/index.js:19:27)
    host.iobtest
    2024-05-24 11:16:01.254	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.iobtest
    2024-05-24 11:16:01.254	error	Caught by controller[0]: Node.js v18.20.2
    host.iobtest
    2024-05-24 11:16:01.254	error	instance system.adapter.fahrplan.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobtest
    2024-05-24 11:16:01.254	info	Restart adapter system.adapter.fahrplan.0 because enabled
    Bei dem Javascript Adapter 8.3.1 ist mir folgendes aufgefallen, dass die Module nicht mehr einzeln in der Config stehen.
    habe sie jetzt neu eingetragen, sie werden aber laut Log-Ausgabe nicht geladen / installiert, was mir diese Fehlermeldung bestätigt.
    javascript.0
    2024-05-24 11:37:12.904	info	Compiling TypeScript source script.js.common.NSPanel4400
    javascript.0
    2024-05-24 11:37:15.383	info	script.js.common.NSPanel4400: source code did not change, using cached compilation result...
    javascript.0
    2024-05-24 11:37:15.728	warn	script.js.common.NSPanel4400: error at function init_dayjs: dayjs_1.locale is not a function
    javascript.0
    2024-05-24 11:37:15.747	info	script.js.common.NSPanel4400: setObjects enabled - create Alias Channels possible
    javascript.0
    2024-05-24 11:37:15.772	info	script.js.common.NSPanel4400: weather alias for accuweather.0. already exists
    javascript.0
    2024-05-24 11:37:15.897	info	script.js.common.NSPanel4400: registered 33 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0
    2024-05-24 11:37:16.379	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:16.381	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:16.824	info	script.js.common.NSPanel4400: Debug mode disabled
    javascript.0
    2024-05-24 11:37:17.243	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:17.244	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:17.799	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:17.800	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:17.910	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:17.911	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:29.303	warn	script.js.common.NSPanel4400: error at function HandleScreensaverUpdate: parseFormat is not a function
    javascript.0
    2024-05-24 11:37:53.476	info	Stopping script script.js.common.NSPanel4400
    der netamo-crawler Adapter 0.8.1 läuft auch nicht mehr , selbst im Debug modus der Instanz kommen nicht mehr Daten. Läuft jetzt nach npm update
    host.iobtest
    2024-05-24 11:46:00.632	info	instance scheduled system.adapter.netatmo-crawler.0 */5 * * * *
    host.iobtest
    2024-05-24 11:46:00.644	info	instance system.adapter.netatmo-crawler.0 started with pid 219300
    host.iobtest
    2024-05-24 11:46:01.782	error	instance system.adapter.netatmo-crawler.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    das waren die ersten Sachen die ich gefunden habe bei mir.
    mcm1957M
    mcm1957M
    mcm1957
    #102
    @tt-tom said in Alpha Test js-controller Kiera (v6.0):
    zipFiles.js
    Dazu gabs weiter oben schon einen Beitrag. Ich glaub ein npm upgrade oder so hat das was gefixed. Ist - wenn ichs richtig im Kopf hab - ein offenes Problem. Schau mal frühere Beoiträge durch.
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    • sigi234S sigi234
      @mcm1957 sagte in Alpha Test js-controller Kiera (v6.0):
      Und genau diese 3 Adapter haben beim Start ab 11:37 einen already running error gemeldet.
      Bei mir sind es einige mehr. War aber immer schon so. Beruhigt sich nach einiger Zeit wieder. Bis zum Neustart eben.
      host.SmartHome
      2024-05-24 11:58:49.508	error	instance system.adapter.upnp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:58:41.067	error	instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:58:37.231	error	instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:58:25.628	error	instance system.adapter.ecovacs-deebot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:58:22.100	error	instance system.adapter.vis-2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:58:16.992	error	instance system.adapter.parser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:58:13.106	error	instance system.adapter.tapo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:58:09.359	error	instance system.adapter.pollenflug.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:58:05.571	error	instance system.adapter.musiccast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:58:01.679	error	instance system.adapter.web.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:57.194	error	instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:53.440	error	instance system.adapter.jarvis.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:49.746	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:45.893	error	instance system.adapter.weather-warnings.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:42.774	error	instance system.adapter.alarm.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:32.892	error	instance system.adapter.socketio.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:29.354	error	instance system.adapter.ws.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:24.995	error	instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:17.208	error	instance system.adapter.snmp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:12.895	error	instance system.adapter.lgtv.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:57:05.988	error	instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:57.522	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:50.507	error	instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:45.626	error	instance system.adapter.yamaha.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:42.406	error	instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:37.747	error	instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:32.874	error	instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:28.974	error	instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:24.950	error	instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:20.873	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:16.888	error	instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:13.251	error	instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:09.200	error	instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:56:05.239	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.SmartHome
      2024-05-24 11:55:52.252	error	instance system.adapter.vis-inventwo.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:52.143	error	instance system.adapter.sayit.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:52.042	error	instance system.adapter.ecovacs-deebot.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:51.928	error	instance system.adapter.vis-2.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:51.827	error	instance system.adapter.parser.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:51.724	error	instance system.adapter.tapo.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:51.540	error	instance system.adapter.pollenflug.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:51.400	error	instance system.adapter.musiccast.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:51.300	error	instance system.adapter.web.1 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:51.182	error	instance system.adapter.iot.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:51.081	error	instance system.adapter.jarvis.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.961	error	instance system.adapter.fb-checkpresence.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.853	error	instance system.adapter.weather-warnings.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.752	error	instance system.adapter.alarm.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.652	error	instance system.adapter.socketio.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.553	error	instance system.adapter.ws.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.447	error	instance system.adapter.web.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.347	error	instance system.adapter.snmp.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.250	error	instance system.adapter.lgtv.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.149	error	instance system.adapter.meross.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:50.050	error	instance system.adapter.cloud.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:49.944	error	instance system.adapter.alexa2.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:49.825	error	instance system.adapter.yamaha.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:49.697	error	instance system.adapter.tr-064.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:49.576	error	instance system.adapter.hm-rpc.1 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:49.471	error	instance system.adapter.hm-rega.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:49.363	error	instance system.adapter.hm-rpc.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:49.226	error	instance system.adapter.hue.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:49.091	error	instance system.adapter.backitup.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:48.983	error	instance system.adapter.email.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:48.883	error	instance system.adapter.javascript.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:48.747	error	instance system.adapter.history.0 terminated with code 4294967295 ()
      host.SmartHome
      2024-05-24 11:55:48.583	error	instance system.adapter.admin.0 terminated with code 4294967295 ()
      mcm1957M
      mcm1957M
      mcm1957
      #103
      @sigi234
      OK, aber auch diese haben einen "ungewöhnlichen" Existstatus beim Beenden.
      • mcm1957M mcm1957
        zipFiles.js
        T
        T
        TT-Tom
        #104
        @mcm1957 danke für die Info, läuft jetzt soweit bis auf die Sache mit dem Javascript Adapter.
        Gruß Tom
        Public Transport
        NSPanel Adapter Dokumentation
        https://ticaki.github.io/ioBroker.nspanel-lovelace-ui/
        • T TT-Tom
          mcm1957M
          mcm1957M
          mcm1957
          #105
          @haus-automatisierung
          Soweit ich weiß hat sich mit js-controller 6 und / oder (?) Javascript 8.x.x was mit der Installation der zusätzlichen npm Module geändert. Wahrscheinlich kann da haus-automatisierung am besten helfen um festzustellen ob da ein Problem vorliegt oder "nur" eine Anpassung durch dich notwendig ist.
          Ref zu deinem ersten Fehlerbericht https://forum.iobroker.net/topic/74822/alpha-test-js-controller-kiera-v6-0/106
          • T TT-Tom
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            host.iobtest
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            host.iobtest
            host.iobtest
            host.iobtest
            haus-automatisierungH
            #106
            @tt-tom sagte in Alpha Test js-controller Kiera (v6.0):
            Von welcher Version bist Du denn vorher gekommen? Denke mal das hängt mit dem Wechsel auf jsonConfig zusammen und dass der alte Wert ggf. nicht richtig migriert wird.
            📚 Meine Dokumentation
              FeuersturmF
              FeuersturmF
              Feuersturm
              #107
              @haus-automatisierung Das Verhalten sehe ich bei mir auch.
              In der Javascript Instanz v8.0.3 auf meinem Produktivsystem werden die npm Module korrekt einzeln dargestellt.
              Auf meinem Testsystem ist Javascript auf 8.3.1 und dort sieht es jetzt auch so aus, das alles in einem item steht
              • FeuersturmF Feuersturm
                #108
                @feuersturm sagte in Alpha Test js-controller Kiera (v6.0):
                Dann zeig mal bitte das Native-Objekt aus dem Instanz-Objekt.
                  FeuersturmF
                  FeuersturmF
                  Feuersturm
                  #109
                  @haus-automatisierung Meinst du das hier?
                    #110
                    @feuersturm Genau, danke. Ist also mit Leerzeichen getrennt und kein Array. Muss ich fixen.
                    "libraries": "xml2js moment moment-timezone moment-duration-format mathjs",
                    Thomas BraunT T 2 Antworten Letzte Antwort
                      Thomas BraunT
                      Thomas BraunT
                      Most Active Developer
                      #111
                      @foxriver76
                      Gerade gecheckt: Die Anzeige von anstehenden Updates meines Debian-Systems funktioniert im Admin.
                        @foxriver76
                        FeuersturmF
                        FeuersturmF
                        Feuersturm
                        #112
                        @thomas-braun sagte in Alpha Test js-controller Kiera (v6.0):
                        @foxriver76
                        Bei mir werden auch mögliche Updates angezeigt
                        Wenn ich dann versuche die Pakete zu aktualisieren werden diese aber nicht aktualisiert, sondern zurückgehalten.
                        proxmox@ioBrokerTestsystem:~$ sudo apt update
                        [sudo] password for proxmox:
                        Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                        Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
                        Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                        Get:5 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [1683 k        B]
                        Get:6 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [10        75 kB]
                        Fetched 2987 kB in 3s (892 kB/s)
                        Reading package lists... Done
                        2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                        proxmox@ioBrokerTestsystem:~$ sudo apt list --upgradable
                        Listing... Done
                        python3-update-manager/jammy-updates 1:22.04.20 all [upgradable from: 1:22.04.19]
                        update-manager-core/jammy-updates 1:22.04.20 all [upgradable from: 1:22.04.19]
                        proxmox@ioBrokerTestsystem:~$ sudo apt full-upgrade -y
                        Calculating upgrade... Done
                        The following packages have been kept back:
                          python3-update-manager update-manager-core
                        0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                        Kannst du mir sagen, was hier der Hintergrund ist? Für den Enduser ist die Meldung aus meiner Sicht verwirrend, wenn hier Updates angezeigt werden, welche aber nicht installiert werden können.
                          @foxriver76
                          Listing... Done
                          Thomas BraunT
                          Thomas BraunT
                          #113
                          Das hat mit dem ioBroker nix zu tun sondern ist eine der vielen Schnubbibuntu-Sonderlocken. (Weswegen ich diese Distribution auch nicht mag und auch nicht empfehlen würde).
                          Nennt sich 'Phased Updates' und sorgt dafür, dass eigentlich anstehende Updates in Wellen scharf geschaltet werden.
                            FeuersturmF
                            FeuersturmF
                            Feuersturm
                            #114
                            @thomas-braun Danke für die Erklärung, das heißt ich warte einfach und bis dahin muss ich mit der Meldung leben.
                            • foxriver76F
                              foxriver76F
                              foxriver76
                              #115
                              @thomas-braun https://forum.iobroker.net/topic/74822/alpha-test-js-controller-kiera-v6-0/100 hast du gesehen?
                              Videotutorials & mehr
                                T
                                T
                                TT-Tom
                                #116
                                Danke, warte jetzt auf dein Fix. Wollen wir damit in dein Test Thread wechseln??
                                Gruß Tom
                                Public Transport
                                • T TT-Tom
                                  #117
                                  Bitte als Issue auf GitHub öffnen. Sonst laufen da zig Themen durcheinander.
                                  • foxriver76F foxriver76
                                    Thomas BraunT
                                    Thomas BraunT
                                    #118
                                    @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
                                    Ja, aber noch nicht testen können. Kein gescheites Terminal zur Hand, nur eine Android-App und mit der will ich nix aufwändigeres per SSH machen.
                                    • foxriver76F
                                      foxriver76F
                                      foxriver76
                                      #119
                                      An alle: bitte nochmal updaten
                                      A F T 3 Antworten Letzte Antwort
                                        A
                                        A
                                        ag
                                        #120
                                        @foxriver76
                                        js-controller 6.01 auf dem testsystem läuft alles wieder.
                                        Beim Start der Instamcen nach reboot oder iobroker start.
                                        2024-05-24 18:16:06.510 - info: host.RPI5Test instance system.adapter.daikin.0 started with pid 1646
                                        2024-05-24 18:16:07.191 - error: daikin.0 (1646) daikin.0 invalid instance object: {"_id":"","type":"device","common":{},"native":{}}
                                        2024-05-24 18:16:07.232 - info: daikin.0 (1646) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.daikin, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240524-14a872375
                                        2024-05-24 18:16:08.169 - info: daikin.0 (1646) Daikin Device initialized successfully
                                        2024-05-24 18:16:08.170 - info: daikin.0 (1646) Set polling Intervall to 300s
                                        Adapter funktiniert aber danach
                                        Operating System: Debian GNU/Linux 12 architecture: arm64 Pi5 8GB
                                        /usr/bin/nodejs v20.18.0 /usr/bin/node 20.18.1 /usr/bin/npm 10.8.2
                                        js-controller 7.0.6 admin 7.4.10
                                          F
                                          F
                                          Fortune95
                                          #121
                                          @foxriver76
                                          Aktuelle Version läuft.
                                          Nur der Adapter Heatingcontrol läuft nicht an:
                                          2024-05-24 18:21:38.650  - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-co        re/build/controllerTools.js:83
                                          2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                                          2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]:     ^
                                          2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                                          2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_m        odules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                                          2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_m        odules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                                          2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                                          2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_m        odules/@iobroker/adapter-core/build/index.js:19:27)
                                          2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]: Node.js v20.13.1
                                          2024-05-24 18:21:38.652  - error: host.iobroker instance system.adapter.heatingcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          Adapter Instanzen:
                                            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                          + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled
                                            system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                                          + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                                            system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                          + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
                                            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 - disabled
                                            system.adapter.esphome.0                : esphome               : iobroker                                 - disabled
                                            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                            system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                                          + system.adapter.gruenbeck.0              : gruenbeck             : iobroker                                 -  enabled
                                            system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 - disabled
                                          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                          + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                                            system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 - disabled
                                            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                          + system.adapter.jeelink.0                : jeelink               : iobroker                                 -  enabled
                                          + system.adapter.klf200.0                 : klf200                : iobroker                                 -  enabled
                                          + system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled
                                            system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
                                          + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.12.219
                                            system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
                                          + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
                                          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                          + system.adapter.selverf.0                : selverf               : iobroker                                 -  enabled
                                          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1895, bind: 192.168.12.219
                                          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                                          + system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
                                          + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
                                          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                          + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                                            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                                          + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                                          + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
                                          + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.12.212:6638
                                          84.2k
