  4. ioBroker friert ein: "Request actual repository...".....
81 Beiträge 10 Kommentatoren 13.5k Aufrufe 9 Beobachtet
    @lollo_c
    Gibt mal von allen Kisten die Langfassung von
    iob diag
    bekannt.
    Lollo_C
    @thomas-braun Hier zunächst vom Master:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: RasPi4
           Icon name: computer
              Kernel: Linux 6.1.0-rpi8-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     21:15:15 up  1:01,  2 users,  load average: 0.99, 0.63, 0.50
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2024-03-27 21:15:15 CET
               Universal time: Wed 2024-03-27 20:15:15 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        2.4G        333M        1.2M        1.2G        1.6G
    Swap:           104M          0B        104M
    Total:          4.1G        2.4G        438M
             3792 M total memory
             2250 M used memory
             2836 M active memory
              500 M inactive memory
              317 M free memory
               93 M buffer memory
             1058 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/sda2      ext4      110G  9.7G   96G  10% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Wed Mar 27 20:13:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A6:44:D3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a45a8ca6-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Mar 27 20:13:58 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Mar 27 20:13:59 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.0G    /var/
    4.0G    /var/log/journal/e4b3faf7370f4262b1b9aded77288404
    4.0G    /var/log
    539M    /var/cache
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    75M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    641M    /opt/iobroker/iobroker-data/
    519M    /opt/iobroker/iobroker-data/files
    164M    /opt/iobroker/iobroker-data/files/vis-2
    92M     /opt/iobroker/iobroker-data/backup-objects
    81M     /opt/iobroker/iobroker-data/files/vis-2/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.20.0-1nodesource1
      Version table:
         18.20.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
     *** 18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : RasPi4                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : RasPi4                                   -  enabled
      system.adapter.cloud.0                  : cloud                 : RasPi4                                   - disabled
      system.adapter.devices.0                : devices               : RasPi4                                   - disabled
    + system.adapter.discovery.0              : discovery             : RasPi4                                   -  enabled
      system.adapter.dwd.0                    : dwd                   : RasPi3                                   -  enabled
      system.adapter.flot.0                   : flot                  : RasPi4                                   - disabled
    + system.adapter.hm-rega.1                : hm-rega               : RasPi4                                   -  enabled
    + system.adapter.hm-rpc.2                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
    + system.adapter.hmip.0                   : hmip                  : RasPi4                                   -  enabled
      system.adapter.ical.0                   : ical                  : RasPi3                                   -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : RasPi4                                   - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RasPi4                                   - disabled
    + system.adapter.influxdb.0               : influxdb              : RasPi4                                   -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : RasPi4                                   -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : RasPi4                                   -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : RasPi4                                   -  enabled
      system.adapter.luftdaten.0              : luftdaten             : RasPi3                                   -  enabled
      system.adapter.luftdaten.1              : luftdaten             : RasPi3                                   -  enabled
      system.adapter.luftdaten.2              : luftdaten             : RasPi3                                   -  enabled
      system.adapter.mobile.0                 : mobile                : RasPi4                                   - disabled
    + system.adapter.modbus.0                 : modbus                : RasPi4                                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : RasPi4                                   -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : RasPi4                                   -  enabled
      system.adapter.openweathermap.0         : openweathermap        : RasPi3                                   -  enabled
    + system.adapter.owfs.0                   : owfs                  : RasPi3                                   -  enabled, port: 4304
    + system.adapter.ping.0                   : ping                  : RasPi4                                   -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : RasPi3                                   -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : RasPi4                                   -  enabled
    + system.adapter.rpi2.1                   : rpi2                  : RasPi3                                   -  enabled
    + system.adapter.scenes.0                 : scenes                : RasPi4                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : RasPi4                                   -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : RasPi4                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : RasPi3                                   -  enabled
    + system.adapter.socketio.0               : socketio              : RasPi4                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonos.0                  : sonos                 : RasPi4                                   -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : RasPi3                                   -  enabled
    + system.adapter.telegram.0               : telegram              : RasPi4                                   -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : RasPi4                                   -  enabled
      system.adapter.vis-2.0                  : vis-2                 : RasPi4                                   - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : RasPi4                                   - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : RasPi4                                   -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RasPi4                                   - disabled
      system.adapter.vis-material.0           : vis-material          : RasPi4                                   - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi4                                   - disabled
      system.adapter.vis-metro.0              : vis-metro             : RasPi4                                   -  enabled
      system.adapter.vis-players.0            : vis-players           : RasPi4                                   - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : RasPi4                                   - disabled
      system.adapter.vis-weather.0            : vis-weather           : RasPi4                                   - disabled
      system.adapter.vis.0                    : vis                   : RasPi4                                   -  enabled
    + system.adapter.web.0                    : web                   : RasPi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.ws.0                     : ws                    : RasPi4                                   - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : RasPi4                                   -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
    + instance is alive
    ioBroker-Repositories
    stable        : http://repo.iobroker.live/sources-dist.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.4.0    , installed 4.2.0  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "hmip"         : 1.22.0   , installed 1.22.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "shelly"       : 6.8.0    , installed 6.6.1  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        11601
    States:         9592
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 https://repos.influxdata.com/debian stable InRelease
    Hit:3 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 7
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      106        16717      704/redis-server 0.
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16706      718/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16835      775/influxd
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16909      851/iobroker.js-con
    tcp        0      0 192.168.2.210:42010     0.0.0.0:*               LISTEN      1001       16262      1067/io.hm-rpc.2
    tcp        0      0 192.168.2.210:42001     0.0.0.0:*               LISTEN      1001       19700      1082/io.hm-rpc.3
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       20925      1231/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        13640      723/mosquitto
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16708      718/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      108        13753      850/grafana
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       20286      1272/io.sonos.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        13722      775/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23008      1363/io.simple-api.
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21380      1303/io.socketio.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22965      1352/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13780      889/io.admin.0
    tcp6       0      0 :::1883                 :::*                    LISTEN      107        13641      723/mosquitto
    udp        0      0 0.0.0.0:54748           0.0.0.0:*                           104        13537      549/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13535      549/avahi-daemon: r
    udp6       0      0 fe80::5635:5d6e:3e1:546 :::*                                0          13245      661/NetworkManager
    udp6       0      0 :::60556                :::*                                104        13538      549/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        13536      549/avahi-daemon: r
    2024-03-27 20:47:56.672  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state with {"val":"play","ack":false,"ts":1711568876576,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711568876576}
    2024-03-27 20:47:56.773  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":true,"ack":false,"ts":1711568876676,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711568876676}
    2024-03-27 20:51:37.377  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_27","ack":false,"ts":1711569097373,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569097373}
    2024-03-27 20:51:38.377  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state with {"val":"stop","ack":false,"ts":1711569098373,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569098373}
    2024-03-27 20:51:38.380  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":false,"ack":false,"ts":1711569098373,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569098373}
    2024-03-27 21:05:22.330  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_45","ack":false,"ts":1711569922324,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569922324}
    2024-03-27 21:05:22.372  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state with {"val":"play","ack":false,"ts":1711569922324,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569922324}
    2024-03-27 21:05:22.428  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":true,"ack":false,"ts":1711569922425,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711569922425}
    2024-03-27 21:05:28.709  - info: zigbee.0 (1261) Device '0x842e14fffea79363' announced itself
    2024-03-27 21:06:47.202  - info: zigbee.0 (1261) State value to set for "zigbee.0.14b457fffe3358c5.brightness" has to be type "number" but received type "boolean"
    2024-03-27 21:06:47.522  - info: zigbee.0 (1261) Device '0x00158d00045845e9' announced itself
    2024-03-27 21:06:47.664  - info: zigbee.0 (1261) Device '0x00158d00045850c7' announced itself
    2024-03-27 21:06:47.683  - info: zigbee.0 (1261) Device '0x00158d00045832aa' announced itself
    2024-03-27 21:06:53.254  - error: zigbee.0 (1261) Send command to 0x7cb03eaa0a0c57e5 failed with no error code (Timeout - 40202 - 3 - 120 - 6 - 11 after 10000ms)
    2024-03-27 21:06:53.537  - info: zigbee.0 (1261) Device '0x842e14fffea79363' announced itself
    2024-03-27 21:08:56.112  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.coordinator with {"val":"192_168_2_45","ack":false,"ts":1711570136107,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711564306935}
    2024-03-27 21:08:57.133  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.state with {"val":"stop","ack":false,"ts":1711570137109,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570137109}
    2024-03-27 21:08:57.137  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.state_simple with {"val":false,"ack":false,"ts":1711570137109,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570137109}
    2024-03-27 21:10:03.205  - warn: zigbee.0 (1261) unread state change for group members ["0x00158d00045845e9","0x00158d00045850c7"]
    2024-03-27 21:10:26.257  - warn: zigbee.0 (1261) unread brightness change for group members ["0x00158d00045832aa","0x00158d00045845e9","0x00158d00045850c7"]
    2024-03-27 21:10:49.329  - warn: zigbee.0 (1261) unread colortemp change for group members ["0x00158d00045832aa","0x00158d00045845e9","0x00158d00045850c7"]
    2024-03-27 21:12:28.657  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.coordinator with {"val":"192_168_2_27","ack":false,"ts":1711570348654,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570348654}
    2024-03-27 21:12:28.699  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.state with {"val":"play","ack":false,"ts":1711570348654,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570348654}
    2024-03-27 21:12:28.702  - info: sonos.0 (1272) try to control id sonos.0.root.192_168_2_45.state_simple with {"val":true,"ack":false,"ts":1711570348654,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1711570348654}
    2024-03-27 21:12:50.821  - info: admin.0 (889) ==> Connected system.user.admin from ::ffff:192.168.2.74
    und hier der Slave:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
      Static hostname: RasPi3
            Icon name: computer
     Operating System: Raspbian GNU/Linux 10 (buster)
               Kernel: Linux 5.10.103-v7+
         Architecture: arm
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Docker          : false
    Kernel          : armv7l
    Userland        : armhf
    21:18:30 up 12:22,  1 user,  load average: 0.54, 0.46, 0.45
    CPU threads: 4
    Current issues:
    ~ Under-voltage has occurred
                  Local time: Wed 2024-03-27 21:18:30 CET
              Universal time: Wed 2024-03-27 20:18:30 UTC
                    RTC time: n/a
                 NTP service: active
             RTC in local TZ: no
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           923M        501M        152M        6.0M        269M        450M
    Swap:           99M          0B         99M
    Total:         1.0G        501M        252M
             923 M total memory
             501 M used memory
             160 M active memory
             555 M inactive memory
             152 M free memory
              62 M buffer memory
             206 M swap cache
              99 M total swap
               0 M used swap
              99 M free swap
    Raspberry only:
    oom events: 0
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       15G  5.5G  8.2G  41% /
    devtmpfs       devtmpfs  430M     0  430M   0% /dev
    tmpfs          tmpfs     462M     0  462M   0% /dev/shm
    tmpfs          tmpfs     462M  6.3M  456M   2% /run
    tmpfs          tmpfs     462M     0  462M   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    [Wed Mar 27 08:56:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Wed Mar 27 08:56:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Wed Mar 27 08:56:26 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Mar 27 08:56:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    /             /dev/mmcblk0p2 ext4      rw,noatime
    |-/sys/fs/bpf none           bpf       rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/owfs   OWFS           fuse.OWFS rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/boot       /dev/mmcblk0p1 vfat      rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.6G    /var/
    2.3G    /var/cache/apt/archives
    2.3G    /var/cache/apt
    2.3G    /var/cache
    137M    /var/lib
    Archived and active journals take up 5.7M in the file system.
    169M    /opt/iobroker/backups/
    42M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/backup-objects
    8.0M    /opt/iobroker/iobroker-data/files/vis
    7.9M    /opt/iobroker/iobroker-data/files/web
    2.0M    /opt/iobroker/iobroker-data/objects.json.migrated
    2.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    636K    /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-20_objects.json.gz
    632K    /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-28_objects.json.gz
    632K    /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-25_objects.json.gz
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DK0EJEOL-if00-port0
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    nodejs:
     Candidate: 18.19.1-1nodesource1
     Version table:
    *** 18.19.1-1nodesource1 600
           500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
        18.19.0-1nodesource1 600
        18.18.2-1nodesource1 600
        18.18.1-1nodesource1 600
        18.18.0-1nodesource1 600
        18.17.1-1nodesource1 600
        18.17.0-1nodesource1 600
        18.16.1-1nodesource1 600
        18.16.0-1nodesource1 600
        18.15.0-1nodesource1 600
        18.14.2-1nodesource1 600
        18.14.1-1nodesource1 600
        18.14.0-1nodesource1 600
        18.13.0-1nodesource1 600
        18.12.0-1nodesource1 600
        18.11.0-1nodesource1 600
        18.10.0-1nodesource1 600
        18.9.1-1nodesource1 600
        18.9.0-1nodesource1 600
        18.8.0-1nodesource1 600
        18.7.0-1nodesource1 600
        18.6.0-1nodesource1 600
        18.5.0-1nodesource1 600
        18.4.0-1nodesource1 600
        18.3.0-1nodesource1 600
        18.2.0-1nodesource1 600
        18.1.0-1nodesource1 600
        18.0.0-1nodesource1 600
        10.24.0~dfsg-1~deb10u3 500
    Errors in npm tree:
    ioBroker Status
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: redis
    admin:          6.13.16
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + instance is alive
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Objects and States
    Objects:        11601
    States:         9592
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://phoscon.de/apt/deconz buster InRelease
    Get:4 https://repos.influxdata.com/debian buster InRelease [12.8 kB]
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Err:4 https://repos.influxdata.com/debian buster InRelease
    Fetched 12.8 kB in 7s (1740 B/s)
    Pending Updates: 12
    tcp        0      0 0.0.0.0:2120            0.0.0.0:*               LISTEN      109        14864      328/owftpd
    tcp        0      0 0.0.0.0:2121            0.0.0.0:*               LISTEN      109        15672      464/owhttpd
    tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          16981      636/node
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16900      641/sshd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16742      389/influxd
    tcp6       0      0 :::3500                 :::*                    LISTEN      0          18468      636/node
    tcp6       0      0 :::4304                 :::*                    LISTEN      0          10977      1/init
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        18566      389/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16902      641/sshd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14047      634/dhcpcd
    udp        0      0 0.0.0.0:37004           0.0.0.0:*                           108        14888      334/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14886      334/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14887      334/avahi-daemon: r
    udp6       0      0 :::35598                :::*                                108        14889      334/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14081      634/dhcpcd
    2024-03-27 21:15:20.223  - info: host.RasPi3 instance system.adapter.openweathermap.0 started with pid 10740
    2024-03-27 21:15:25.157  - info: host.RasPi3 instance system.adapter.luftdaten.2 terminated with code 0 (NO_ERROR)
    2024-03-27 21:15:26.618  - info: openweathermap.0 (10740) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.1, js-controller: 5.0.19
    2024-03-27 21:15:36.480  - info: openweathermap.0 (10740) Terminated (NO_ERROR): Without reason
    2024-03-27 21:15:37.049  - info: host.RasPi3 instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2024-03-27 21:16:00.049  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 10962
    2024-03-27 21:16:16.929  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-03-27 21:17:00.051  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 11131
    2024-03-27 21:17:16.438  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-03-27 21:18:00.047  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 11339
    2024-03-27 21:18:09.117  - info: smartmeter.0 (895) Received 66 values, 2 updated
    2024-03-27 21:18:18.027  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-03-27 21:19:00.028  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 11728
    2024-03-27 21:19:18.695  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-03-27 21:20:00.112  - info: host.RasPi3 instance system.adapter.ical.0 started with pid 11998
    2024-03-27 21:20:04.129  - info: host.RasPi3 instance system.adapter.luftdaten.2 started with pid 12009
    2024-03-27 21:20:08.178  - info: host.RasPi3 instance system.adapter.luftdaten.1 started with pid 12196
    2024-03-27 21:20:12.194  - info: host.RasPi3 instance system.adapter.luftdaten.0 started with pid 12267
    2024-03-27 21:20:12.528  - info: host.RasPi3 instance system.adapter.luftdaten.2 terminated with code 0 (NO_ERROR)
    2024-03-27 21:20:16.212  - info: host.RasPi3 instance system.adapter.dwd.0 started with pid 12282
    2024-03-27 21:20:17.632  - info: host.RasPi3 instance system.adapter.luftdaten.1 terminated with code 0 (NO_ERROR)
    2024-03-27 21:20:22.010  - info: dwd.0 (12282) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.1, js-controller: 5.0.19
    2024-03-27 21:20:22.217  - info: host.RasPi3 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-03-27 21:20:22.516  - info: host.RasPi3 instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2024-03-27 21:20:24.749  - info: host.RasPi3 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    Mit freundlichen Grüßen und Glückauf
    Wilfried
    • L Lollo_C
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               3792 M total memory
               2250 M used memory
                317 M free memory
                 93 M buffer memory
               1058 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      5.0G    /var/
      4.0G    /var/log
      539M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        11601
      States:         9592
      Pending Updates: 7
      und hier der Slave:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
              Icon name: computer
           Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                      RTC time: n/a
                   NTP service: active
               RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               923 M total memory
               501 M used memory
               160 M active memory
               152 M free memory
                62 M buffer memory
               206 M swap cache
                99 M total swap
                 0 M used swap
                99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      2.6G    /var/
      2.3G    /var/cache/apt
      2.3G    /var/cache
      137M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
       Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      admin:          6.13.16
      Adapter State
      + instance is alive
      Objects and States
      Objects:        11601
      States:         9592
      Pending Updates: 12
      @lollo_c
      Der Master muss mal aktualisiert werden. Inkl. anschließendem Reboot, weil Kernel-Update.
      Und
      wozu braucht man drei Instanzen influxdb, die aber auf die gleiche Datenbank zugreifen?
      Der Slave muss komplett in die Gegenwart geholt werden, Raspbian 10 'Buster' ist abgekündigt. Neuinstallation von Raspberry OS 12 'Bookworm'.
      L 1 Antwort Letzte Antwort
        @lollo_c
        Und
        Lollo_C
        @thomas-braun Mit "Master aktualisieren" meinst Du sudo apt-get update und sudo apt full-upgrade, oder?
        Die 3 Instanzen influxDB_v1.8 habe ich, weil ich unterschiedliche Vorhaltezeiten habe.
        Zum Slave: Ich war bis gerade der Meinung, Bookworm gibt es nur als 64 bit Variante. Da muss ich mich jetzt mal näher mit beschäftigen, wie ich den hochgezogen bekomme. Ist es nicht dann viel besser, für den Slave auch einen 64 bit Raspi zu nehmen?
        Ich hatte damals (vor 5 Jahren) mit dem Raspi3 gestartet. Der hat noch ein Homematik Funkmodul drin. Gibt es irgendwo einen "Fahrplan", wie ich ein Master-Slave System komplett neu aufsetzen kann?
        Wilfried
        • L Lollo_C
          @lollo_c
          Der Rpi3 kann auch mit 64bit umghehen. Die letzen Versionen definitiv.
          • L Lollo_C
            @lollo_c sagte in ioBroker friert ein: "Request actual repository...".....:
            Ich denke, ich lass es erst mal so laufen und warte ab, was passiert. Er hat ja vorher auch schon mal 2 Tage am Stück gelaufen.
            So, ich war jetzt eine Woche im Urlaub und der Raspi ist 2x eingefroren. Die letzte Einträge in der Protokolldatei waren wieder:
            2024-03-22 19:10:21.310 - info: admin.0 (895) Adapter rating updated
            2024-03-22 19:11:11.508 - info: admin.0 (895) Request actual repository...
            2024-03-22 19:11:14.967 - info: host.RasPi4 Updating repository "stable" under "http://repo.iobroker.live/sources-dist.json"
            Für den Raspi2 (Slave) konnte ich zuletzt folgende Meldungen auslesen:
            2024-03-22 19:13:58.231 - warn: ical.0 (4164) slow connection to objects DB. Still waiting ...
            2024-03-22 19:13:58.262 - warn: ical.0 (4165) slow connection to objects DB. Still waiting ...
            2024-03-22 19:14:00.010 - warn: host.RasPi3 instance system.adapter.ical.0 already running with pid 4165
            2024-03-22 19:15:00.013 - warn: host.RasPi3 instance system.adapter.ical.0 already running with pid 4165
            2024-03-22 19:16:07.391 - info: host.RasPi3 instance system.adapter.dwd.0 started with pid 4586
            2024-03-22 19:16:20.701 - warn: dwd.0 (4586) slow connection to objects DB. Still waiting ...
            2024-03-22 19:20:09.933 - info: dwd.0 (4586) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-03-22 19:23:15.846 - info: host.RasPi3 instance system.adapter.luftdaten.0 started with pid 5703
            Im Verlauf der Nacht habe ich auf dem Slave noch folgende Meldungen gefunden:
            2024-03-23 04:03:49.170  - error: rpi2.1 (6010) Objects database error: read EHOSTUNREACH
            2024-03-23 04:03:55.010  - error: rpi2.1 (6010) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:01.250  - error: rpi2.1 (6010) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:07.490  - error: rpi2.1 (6010) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:09.651  - error: smartmeter.0 (6086) Objects database error: read EHOSTUNREACH
            2024-03-23 04:04:13.730  - error: rpi2.1 (6010) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:16.851  - error: smartmeter.0 (6086) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:19.969  - error: rpi2.1 (6010) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:23.091  - error: smartmeter.0 (6086) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:26.210  - error: rpi2.1 (6010) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:29.330  - error: smartmeter.0 (6086) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:32.450  - error: rpi2.1 (6010) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:35.570  - error: smartmeter.0 (6086) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            2024-03-23 04:04:38.690  - error: rpi2.1 (6010) Objects database error: connect EHOSTUNREACH 192.168.2.210:9001
            Da ich beim Neuaufsetzen des ioBroker Probleme mit der REDIS Datenbank-Verbindung zum Slave hatte vermute ich mal, dass sich beim Prüfen der aktuellen Repositorys die REDIS Datenbank aufhängt. Kann das sein? ...und wie kann ich das überprüfen?
            Ich habe im Admin-Adapter den Zeitraum für die Überprüfung der Updates erst einmal von "täglich" auf "alle 2 Wochen" gestellt.
            @lollo_c
            Wenn Dein iobroker neu startet, wirft das Log unter anderem diesen Fehler aus.
            2024-03-14 17:31:31.746 - error: host.RasPi4 iobroker npm-install: host.RasPi4 Unknown packetName vis-material-webfont. Please install packages from outside the repository using npm!
            Wenn dieser Adapter schräg rumhängt, kann ich mir vorstellen, dass er just immer dann einfriert, wenn er Adapter raten und das Repo abgleichen will.
            Kannst Du den nicht "irgendwie" bereinigen und löschen?
              @lollo_c
              Lollo_C
              @rscsb Die Meldung kam bis zum 14.03.24 Danach habe ich die Instanz und den Adapter gelöscht. Seitdem kam die Meldung nicht mehr.
              Wilfried
              • L Lollo_C
                Lollo_C
                Hallo Zusammen,
                was soll ich sagen: 14 Tage sind rum, der ioBroker wollte mal wieder nach Hause telefonieren....
                2024-04-10 22:16:16.995 - info: admin.0 (94686) Request actual repository...
                2024-04-10 22:16:20.263 - info: host.RasPi4 Updating repository "stable" under "http://repo.iobroker.live/sources-dist.json"
                ...und prompt ist der RasPi wieder eingefroren. Für mich besteht da ein Zusammenhang.
                Wie dem auch sei: Ich bin gerade dabei mit aktueller Hardware ein neues System aufzubauen. Dann habe ich hoffentlich Ruhe.
                Wilfried
                • L Lollo_C
                  Hallo Zusammen,
                  @lollo_c
                  Hattest du die Langfassung von
                  iob diag
                  gepostet?
                    @lollo_c
                    iob diag
                    gepostet?
                    Lollo_C
                    @thomas-braun Ja, hatte ich in dem Beitrag https://forum.iobroker.net/post/1144851 gepostet.
                    Wilfried
                    C 1 Antwort Letzte Antwort
                    • L Lollo_C
                      Clyde
                      @lollo_c Bist du schon schlauer geworden? Habe seit Februar genau die gleichen sporadischen Abstüzte mit genau den gleichen letzten Meldungen und völlig ratlos
                      Thomas BraunT L 2 Antworten Letzte Antwort
                      • C Clyde
                        @clyde
                        Und hast du auch die Langfassung von
                        iob diag
                        gepostet?
                          @clyde
                          iob diag
                          gepostet?
                          Clyde
                          #66
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                             Static hostname: raspberrypi
                                   Icon name: computer
                            Operating System: Raspbian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 6.1.64-v8+
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                           15:57:44 up 1 day, 21:51,  2 users,  load average: 0.93, 1.07, 1.00
                          CPU threads: 4
                          Current issues:
                                         Local time: Mon 2024-04-22 15:57:44 CEST
                                     Universal time: Mon 2024-04-22 13:57:44 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            1.8G        1.1G        263M        0.0K        477M        673M
                          Swap:            99M         23M         76M
                          Total:          1.9G        1.1G        340M
                                   1847 M total memory
                                   1106 M used memory
                                    966 M active memory
                                    453 M inactive memory
                                    263 M free memory
                                     46 M buffer memory
                                    431 M swap cache
                                     99 M total swap
                                     23 M used swap
                                     76 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4       59G   36G   21G  64% /
                          devtmpfs       devtmpfs  666M     0  666M   0% /dev
                          tmpfs          tmpfs     924M     0  924M   0% /dev/shm
                          tmpfs          tmpfs     370M  1.1M  369M   1% /run
                          /dev/sda1      vfat      253M   60M  193M  24% /boot
                          tmpfs          tmpfs     185M  4.0K  185M   1% /run/user/1000
                          [Sat Apr 20 18:06:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enab                   le_hdmi=0  smsc95xx.macaddr=E4:5F:01:A3:D6:28 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=811c5af8-02 rootfstype=ext4 fsck.repai                   r=yes rootwait
                          [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                          [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): write access will be enabled during recovery
                          [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
                          [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): 1 orphan inode deleted
                          [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): recovery complete
                          [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat Apr 20 18:06:24 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                          [Sat Apr 20 18:06:26 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                          /var:
                          802M    /var/
                          543M    /var/cache
                          538M    /var/cache/apt
                          473M    /var/cache/apt/archives
                          101M    /var/lib
                          Archived and active journals take up 55.0M in the file system.
                          84M     /opt/iobroker/backups/
                          31G     /opt/iobroker/iobroker-data/history
                          324M    /opt/iobroker/iobroker-data/files
                          99M     /opt/iobroker/iobroker-data/history/20230624
                          98M     /opt/iobroker/iobroker-data/history/20230702
                          31M     /opt/iobroker/iobroker-data/objects.jsonl
                          27M     /opt/iobroker/iobroker-data/states.jsonl
                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                          19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                          USB-Devices by-id:
                          find: '/dev/serial/by-id/': No such file or directory
                          /usr/bin/nodejs         v18.20.2
                          /usr/bin/node           v18.20.2
                          /usr/bin/npm            10.5.0
                          /usr/bin/npx            10.5.0
                          /usr/bin/corepack       0.25.2
                          nodejs:
                            Installed: 18.20.2-1nodesource1
                            Candidate: 18.20.2-1nodesource1
                            Version table:
                           *** 18.20.2-1nodesource1 500
                               18.20.1-1nodesource1 500
                               18.20.0-1nodesource1 500
                               18.19.1-1nodesource1 500
                               18.19.0-1nodesource1 500
                               18.18.2-1nodesource1 500
                               18.18.1-1nodesource1 500
                               18.18.0-1nodesource1 500
                               18.17.1-1nodesource1 500
                               18.17.0-1nodesource1 500
                               18.16.1-1nodesource1 500
                               18.16.0-1nodesource1 500
                               18.15.0-1nodesource1 500
                               18.14.2-1nodesource1 500
                               18.14.1-1nodesource1 500
                               18.14.0-1nodesource1 500
                               18.13.0-1nodesource1 500
                               18.12.0-1nodesource1 500
                               18.11.0-1nodesource1 500
                               18.10.0-1nodesource1 500
                               18.9.1-1nodesource1 500
                               18.9.0-1nodesource1 500
                               18.8.0-1nodesource1 500
                               18.7.0-1nodesource1 500
                               18.6.0-1nodesource1 500
                               18.5.0-1nodesource1 500
                               18.4.0-1nodesource1 500
                               18.3.0-1nodesource1 500
                               18.2.0-1nodesource1 500
                               18.1.0-1nodesource1 500
                               18.0.0-1nodesource1 500
                               12.22.12~dfsg-1~deb11u4 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.13.16
                          javascript:     7.8.0
                          Adapters from github:   2
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.1.204, run as: admin
                            system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                          + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
                          + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
                          + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                          + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                          + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
                          + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
                          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                          + system.adapter.viessmann.0              : viessmann             : raspberrypi                              -  enabled, port: 3002
                            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                            system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                            system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
                            system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
                            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                          + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
                          + instance is alive
                          Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
                          Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
                          Adapter    "fronius"      : 2.0.2    , installed 1.1.6  [Updatable]
                          Adapter    "go-e"         : 1.0.29   , installed 1.0.29
                          Adapter    "hm-rpc"       : 1.17.0   , installed 1.16.0 [Updatable]
                          Adapter    "hue"          : 3.10.2   , installed 3.10.2
                          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                          Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                          Adapter    "telegram"     : 3.2.1    , installed 3.1.0  [Updatable]
                          Adapter    "text2command" : 3.0.3    , installed 3.0.3
                          Adapter    "viessmann"    : 1.4.7    , installed 1.4.7
                          Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
                          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
                          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
                          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                          Adapter    "web"          : 6.2.5    , installed 6.2.5
                          Adapter    "ws"           : 2.5.11   , installed 2.5.11
                          Objects and States
                          Objects:        12641
                          States:         14186
                          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 0
                          tcp        0      0 192.168.1.204:18701     0.0.0.0:*               LISTEN      1001       3132060    32457/io.hm-rpc.0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3131143    32322/iobroker.js-c
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3128867    32322/iobroker.js-c
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       3129144    32517/io.shelly.0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       3132545    32547/io.sonoff.0
                          tcp        0      0 0.0.0.0:3002            0.0.0.0:*               LISTEN      0          3693       542/vcontrold
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15542      533/sshd: /usr/sbin
                          tcp        0      0 192.168.1.204:8081      0.0.0.0:*               LISTEN      1001       3128918    32343/io.admin.0
                          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        15578      506/redis-server 12
                          tcp        0      0 192.168.1.204:12010     0.0.0.0:*               LISTEN      1001       3132463    32487/io.hm-rpc.2
                          tcp        0      0 192.168.1.204:12001     0.0.0.0:*               LISTEN      1001       3132423    32472/io.hm-rpc.1
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3138863    1257/io.web.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          15552      533/sshd: /usr/sbin
                          tcp6       0      0 ::1:6379                :::*                    LISTEN      109        15579      506/redis-server 12
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14644      711/dhcpcd
                          udp        0      0 0.0.0.0:53397           0.0.0.0:*                           108        12267      392/avahi-daemon: r
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12265      392/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        12266      392/avahi-daemon: r
                          udp6       0      0 :::41461                :::*                                108        12268      392/avahi-daemon: r
                          2024-04-22 15:46:57.720  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 adapter for vis-material-advanced
                          2024-04-22 15:46:58.251  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 states (system.adapter.vis-material-advanced.*) from states
                          2024-04-22 15:47:03.233  - info: host.raspberrypi iobroker host.raspberrypi file vis/widgets/vis-material-advanced deleted
                          2024-04-22 15:47:03.316  - info: host.raspberrypi iobroker host.raspberrypi file vis/widgets/vis-material-advanced.html deleted
                          2024-04-22 15:47:03.415  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
                          2024-04-22 15:47:03.486  - info: host.raspberrypi iobroker host.raspberrypi file vis-material-advanced.admin deleted
                          2024-04-22 15:47:03.514  - info: host.raspberrypi iobroker host.raspberrypi object vis-material-advanced deleted
                          2024-04-22 15:47:03.576  - info: host.raspberrypi iobroker host.raspberrypi object vis-material-advanced.admin deletedhost.raspberrypi Deleting 3 object(s).
                          2024-04-22 15:47:03.726  - info: host.raspberrypi object deleted system.adapter.vis-material-advanced.0
                          2024-04-22 15:47:03.731  - info: host.raspberrypi iobroker host.raspberrypi Deleting 1 state(s).
                          2024-04-22 15:47:08.787  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 flot
                          2024-04-22 15:47:08.824  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 vis.0
                          2024-04-22 15:47:08.827  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 flot
                          2024-04-22 15:47:11.243  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
                          2024-04-22 15:47:12.265  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
                          2024-04-22 15:47:19.819  - info: vis.0 (1239) Uploaded. 0
                          2024-04-22 15:47:20.142  - info: host.raspberrypi iobroker removed 1 package in 15s266 packages are looking for funding  run `npm fund` for details
                          2024-04-22 15:47:20.273  - info: host.raspberrypi "system.adapter.vis.0" disabled
                          2024-04-22 15:47:20.274  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
                          2024-04-22 15:47:20.302  - info: host.raspberrypi "system.adapter.vis.0" enabled
                          2024-04-22 15:47:20.302  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
                          2024-04-22 15:47:20.307  - info: host.raspberrypi iobroker Adapter "system.adapter.vis.0" restarted.
                          2024-04-22 15:47:20.335  - info: vis.0 (1239) Terminated (NO_ERROR): Without reason
                          2024-04-22 15:47:20.983  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                          2024-04-22 15:47:21.349  - info: host.raspberrypi iobroker exit 0
                          ============ Mark until here for C&P =============```
                          • C Clyde
                            Lollo_C
                            schrieb am zuletzt editiert von Lollo_C
                            #67
                            @clyde sagte in ioBroker friert ein: "Request actual repository...".....:
                            Wie ich weiter oben angekündigt hatte, habe ich den Fehler genutzt und meine Hardware umgestellt. Der Master läuft nun auf einem Raspberry Pi 5 mit 8 GB und der Slave auf einem Raspberry Pi 4 mit 4 GB.
                            Das System läuft nun seit über einer Woche ohne Probleme, obwohl jeden Tag auf Updates überprüft wird.
                            Das "alte" System läuft noch leer nebenher und ich denke mal, dass er in 2 Tagen wieder einfrieren wird. Dann sind die 14 Tage um und er wird wieder nach Updates suchen wollen.
                            Wilfried
                            • C Clyde
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M         23M         76M
                                       1847 M total memory
                                       1106 M used memory
                                        966 M active memory
                                        263 M free memory
                                         46 M buffer memory
                                        431 M swap cache
                                         99 M total swap
                                         23 M used swap
                                         76 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              802M    /var/
                              543M    /var/cache
                              538M    /var/cache/apt
                              101M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.13.16
                              javascript:     7.8.0
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        12641
                              States:         14186
                              Pending Updates: 0
                              #68
                              @clyde
                              Stell es auf ein reines 64Bit 'Bookworm' um.
                              Und 2GB RAM sind für einen 'normalen' Betrieb unterdimensioniert.
                              Dann hast du Einschläge auf dem Dateisystem:
                              Bei den ioBroker-Adaptern herrscht Update-Stau.
                                @clyde
                                Clyde
                                schrieb am zuletzt editiert von Clyde
                                #69
                                @thomas-braun lief über Jahre mit den 2 GB.
                                Wie stelle ich auf Bookworm um?
                                Vor zwei Wochen alles geupdadet, aber ja, müsste ich mal wieder machen.
                                Was bedeutet das mit den Einschlägen? 18:06 am 20. April war übrigens direkt zum Reboot nach dem letzten Hänger. Also beim Hochfahren nach dem Fehler und dementsprechend eher nicht ursächlich.
                                • C Clyde
                                  #70
                                  Das ist immer so. Irgendwann läuft es eben nicht mehr.
                                  Komplette Neuinstallation, weil du da im Userland auf 32Bit hängst.
                                  Dann machst du es deutlich zu selten. Die 8 Updates sind doch nicht alle aus den letzten zwei Wochen? Nicht im Stable-Repo...
                                  Das bedeutet, dass nach deiner Exekution durch Stromentzug das System einige Dateien nicht wieder reanimieren konnte und die beerdigt/gelöscht hat.
                                  Nö, vielleicht nicht, aber da hat es die nächsten Rumms im Dateisystem gegeben, trägt alles nicht zu einem stabilen System bei. Im Gegenteil.
                                    Clyde
                                    #71
                                    Alle zwei Wochen ist zu selten? Dachte eigentlich, dass iobroker für mich arbeitet und nicht umgekehrt. Bis auf den Fronius-Adapter war vor zwei Wochen alles aktuell. Bei dem gibt es wohl ein größere Update mit Objektänderungen, was ich mal irgendwann mache, wenn ich mehr Zeit habe.
                                    Vermutlich dann im Zuge der 64-Bit-Umstellung.
                                    Der "Einschlag" war wie gesagt nach dem harten Reset; vermutlich einfach dem geschuldet. Was bleibt: "wir haben keine Ahnung, also Neuinstallation." Ärgerlich aber nach ein paar Jahren ohne Probleme wohl mal verschmerzbar.
                                    Thomas BraunT HomoranH CodierknechtC 3 Antworten Letzte Antwort
                                    • C Clyde
                                      #72
                                      Ich habe genug Ahnung und ich sage dir, das eine Umstellung des Userlands von 32Bit auf 64Bit nicht per Upgrade sondern nur per kompletter Neuinstallation geht.
                                      Und meine Ahnung lässt mich auch wissen, das gelöschte Inodes halt gelöscht sind und nicht wiederhergestellt werden konnten. Auch das bekommst du nur durch eine Neuinstallation und Einspielen eines hoffentlich vorhandenen Backups geheilt.
                                      • C Clyde
                                        #73
                                        dann ist gut,
                                        @thomas-braun sagte in ioBroker friert ein: "Request actual repository...".....:
                                        ich habe im stable keine 8 updates in den letzten 2 Wochen gehabt, höchstens 3.
                                        nicht ernst gemeint, oder doch?
                                        • C Clyde
                                          CodierknechtC Offline
                                          Codierknecht
                                          #74
                                          Was - wenn auch mit einem gewissen Risiko verbunden - auch noch gehen würde, wäre ein automatisches Update per Script.
                                          Wenn man eh nur alles durchwinken würde, kommt das aufs Gleiche raus.
                                          Damit lassen sich sowohl die Adapter als auch das OS immer aktuell halten.
                                          HmIP|ZigBee|Tasmota|Unifi
                                          Zabbix Certified Specialist
