  4. [gelöst] Nach Neuinstallation Fehler im Zigbee Adapter
zigbee cc2531
41 Beiträge 7 Kommentatoren 5.7k Aufrufe 6 Beobachtet
  • KlarieK Offline
    KlarieK Offline
    Klarie
    @thomas-braun sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
    @klarie sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
    Keine Leerzeichen.
    Richtig. Aber da ist 'kein Gerät' unter dieser Adresse wohnhaft.
    Steck das Ding nochmal richtig rein... :-)
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0
    Your ZigBee COM-Ports are matching 'by-id'. Very good!
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi4iobroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspi4iobroker                           -  enabled
    + system.adapter.discovery.0              : discovery             : raspi4iobroker                           -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspi4iobroker                           -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0
    + instance is alive
    Trozdem:
    2024-04-07 21:33:59.829  - info: admin.0 (934) <== Disconnect system.user.admin from ::ffff:192.168.178.24 admin
    2024-04-07 21:34:00.179  - info: admin.0 (934) ==> Connected system.user.admin from ::ffff:192.168.178.24
    2024-04-07 21:34:05.736  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-04-07 21:34:05.752  - info: zigbee.0 (871) Got terminate signal TERMINATE_YOURSELF
    2024-04-07 21:34:05.757  - info: zigbee.0 (871) cleaned everything up...
    2024-04-07 21:34:05.764  - info: zigbee.0 (871) Zigbee: disabling joining new devices.
    2024-04-07 21:34:05.793  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 send kill signal
    2024-04-07 21:34:06.259  - info: zigbee.0 (871) terminating
    2024-04-07 21:34:06.261  - info: zigbee.0 (871) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-04-07 21:34:06.798  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 killing pid 871
    2024-04-07 21:34:06.818  - info: host.raspi4iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-04-07 21:34:08.826  - info: host.raspi4iobroker instance system.adapter.zigbee.0 started with pid 991
    2024-04-07 21:34:13.466  - info: zigbee.0 (991) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
    2024-04-07 21:34:13.576  - info: zigbee.0 (991) delete old Backup files. keep only last 10
    2024-04-07 21:34:13.578  - info: zigbee.0 (991) Starting Zigbee  npm ...
    2024-04-07 21:34:13.904  - info: zigbee.0 (991) Installed Version: iobroker.zigbee@1.10.1
    2024-04-07 21:35:19.130  - error: zigbee.0 (991) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
    2024-04-07 21:35:19.132  - error: zigbee.0 (991) Failed to start Zigbee
    2024-04-07 21:35:19.133  - error: zigbee.0 (991) Error herdsman start
    2024-04-07 21:35:29.137  - info: zigbee.0 (991) Try to reconnect. 1 attempts left
    2024-04-07 21:35:29.139  - info: zigbee.0 (991) Starting Zigbee  npm ...
    2024-04-07 21:35:29.156  - info: zigbee.0 (991) Installed Version: iobroker.zigbee@1.10.1
    2024-04-07 21:35:29.394  - error: zigbee.0 (991) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2024-04-07 21:35:29.396  - error: zigbee.0 (991) Failed to start Zigbee
    2024-04-07 21:35:29.397  - error: zigbee.0 (991) Error herdsman start
    • KlarieK Klarie
      Keine Leerzeichen.
      USB-Devices by-id:
      Adapter State
      + instance is alive
      Trozdem:
      Trozdem:
      Jetzt sind aber die Meldungen andere...
      Zeig mal die Einstellungen im Adapter in Gänze.
      KlarieK 1 Antwort Letzte Antwort
        Trozdem:
        KlarieK Offline
        KlarieK Offline
        Klarie
        • KlarieK Klarie
          @klarie
          Setz die Erw. PAN-Id auf was anderes als den default.
            @klarie
            KlarieK Offline
            KlarieK Offline
            Klarie
            Dann muss ich aber alle Geräte neu anlernen - Richtig?
            Soll ich nicht lieber nochmal versuchen, den Raspi neu zu starten, wenn alle Router stromlos sind?
            • KlarieK Klarie
              @klarie
              Die eindeutige Bezeichnung deines ZigBee-Netzwerkes hättest du ja auch sofort machen sollen. Deswegen steht der entsprechende Text auch daneben.
                @klarie
                KlarieK Offline
                KlarieK Offline
                Klarie
                Nachher ist man immer schlauer...
                Ich ziehe in einem guten halben Jahr um, und werde dann vermutlich eh alles neu aufsetzen. Dann auch mit neuer PAN-ID.
                Ich versuche es heute Abend erst einmal mit einem Neustart "ohne" Router.
                Ich werde im Anschluss spätestens morgen berichten. ;o)
                Jetzt schon mal besten Dank, dass Du dich so sehr mit meinem Problem beschäftigst. 👍
                • KlarieK Klarie
                  Udate
                  Der Tipp von @arteck hat leider nicht funktioniert.
                  Trotz einer "halben Rolle" Alufolie entdeckte der Coordinator immer noch die gleiche PanID in der Nähe.
                  Ich habe vermutlich zu viele und "starke!" Router im Netz... 🤡
                  Also habe ich im ganzen Haus den Strom abgestellt und den Raspi über eine leistungsstarke Powerbank gestartet.
                  Der Zigbee-Adapter bleibt weiterhin gelb (kann nicht mit Gerät oder Dienst verbinden).
                  Logfile des Startvorganges
                  2024-04-07 14:21:52.062  - info: backitup.0 (860) cleaned everything up...
                  2024-04-07 14:21:52.066  - info: zigbee.0 (884) cleaned everything up...
                  2024-04-07 14:21:52.066  - info: host.raspi4iobroker received SIGTERM
                  2024-04-07 14:21:52.067  - info: admin.0 (763) terminating http server on port 8081
                  2024-04-07 14:21:52.080  - info: host.raspi4iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                  2024-04-07 14:21:52.081  - info: host.raspi4iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                  2024-04-07 14:21:52.082  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2024-04-07 14:21:52.083  - info: host.raspi4iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                  2024-04-07 14:21:52.133  - info: discovery.0 (895) Got terminate signal TERMINATE_YOURSELF
                  2024-04-07 14:21:52.129  - info: admin.0 (763) Got terminate signal TERMINATE_YOURSELF
                  2024-04-07 14:21:52.139  - info: host.raspi4iobroker stopInstance system.adapter.admin.0 send kill signal
                  2024-04-07 14:21:52.135  - info: discovery.0 (895) terminating
                  2024-04-07 14:21:52.139  - info: discovery.0 (895) Terminated (NO_ERROR): Without reason
                  2024-04-07 14:21:52.141  - info: host.raspi4iobroker stopInstance system.adapter.backitup.0 send kill signal
                  2024-04-07 14:21:52.142  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 send kill signal
                  2024-04-07 14:21:52.142  - info: host.raspi4iobroker stopInstance system.adapter.discovery.0 send kill signal
                  2024-04-07 14:21:52.130  - info: backitup.0 (860) Got terminate signal TERMINATE_YOURSELF
                  2024-04-07 14:21:52.145  - info: backitup.0 (860) terminating
                  2024-04-07 14:21:52.148  - info: admin.0 (763) terminating
                  2024-04-07 14:21:52.147  - info: backitup.0 (860) Terminated (NO_ERROR): Without reason
                  2024-04-07 14:21:52.154  - info: admin.0 (763) Terminated (NO_ERROR): Without reason
                  2024-04-07 14:21:52.087  - info: zigbee.0 (884) Zigbee: disabling joining new devices.
                  2024-04-07 14:21:52.180  - warn: zigbee.0 (884) Failed to stop zigbee during startup
                  2024-04-07 14:21:52.203  - info: zigbee.0 (884) Got terminate signal TERMINATE_YOURSELF
                  2024-04-07 14:21:52.248  - info: zigbee.0 (884) terminating
                  2024-04-07 14:21:52.250  - info: zigbee.0 (884) Terminated (NO_ERROR): Without reason
                  2024-04-07 14:21:52.565  - info: discovery.0 (895) terminating
                  2024-04-07 14:21:52.570  - info: backitup.0 (860) terminating
                  2024-04-07 14:21:52.578  - info: zigbee.0 (884) terminating
                  2024-04-07 14:21:52.599  - info: admin.0 (763) terminating
                  2024-04-07 14:21:52.756  - info: host.raspi4iobroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                  2024-04-07 14:21:52.756  - info: host.raspi4iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2024-04-07 14:21:52.801  - info: host.raspi4iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                  2024-04-07 14:21:52.817  - info: host.raspi4iobroker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                  2024-04-07 14:21:52.818  - info: host.raspi4iobroker All instances are stopped.
                  2024-04-07 14:21:52.950  - info: host.raspi4iobroker terminated
                  2024-04-07 14:22:02.703  - info: host.raspi4iobroker iobroker.js-controller version 5.0.19 js-controller starting
                  2024-04-07 14:22:02.710  - info: host.raspi4iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                  2024-04-07 14:22:02.711  - info: host.raspi4iobroker hostname: raspi4iobroker, node: v18.20.1
                  2024-04-07 14:22:02.712  - info: host.raspi4iobroker ip addresses:
                  2024-04-07 14:22:04.614  - info: host.raspi4iobroker connected to Objects and States
                  2024-04-07 14:22:04.683  - info: host.raspi4iobroker added notifications configuration of host
                  2024-04-07 14:22:05.836  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.nodeCurrent"
                  2024-04-07 14:22:05.841  - info: host.raspi4iobroker 4 instances found
                  2024-04-07 14:22:05.877  - info: host.raspi4iobroker starting 4 instances
                  2024-04-07 14:22:05.978  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.nodeNewest"
                  2024-04-07 14:22:06.008  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.nodeNewestNext"
                  2024-04-07 14:22:06.034  - info: host.raspi4iobroker instance system.adapter.admin.0 started with pid 800
                  2024-04-07 14:22:06.052  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.npmCurrent"
                  2024-04-07 14:22:06.112  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.npmNewest"
                  2024-04-07 14:22:06.127  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.npmNewestNext"
                  2024-04-07 14:22:06.141  - info: host.raspi4iobroker Some obsolete host states deleted.
                  2024-04-07 14:22:09.937  - info: host.raspi4iobroker instance system.adapter.backitup.0 started with pid 810
                  2024-04-07 14:22:12.188  - info: admin.0 (800) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.1, js-controller: 5.0.19
                  2024-04-07 14:22:12.293  - info: admin.0 (800) requesting all objects
                  2024-04-07 14:22:13.183  - warn: admin.0 (800) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org
                  2024-04-07 14:22:14.038  - info: host.raspi4iobroker instance system.adapter.zigbee.0 started with pid 829
                  2024-04-07 14:22:14.463  - info: admin.0 (800) received all objects
                  2024-04-07 14:22:15.278  - warn: admin.0 (800) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
                  2024-04-07 14:22:15.291  - info: admin.0 (800) Request actual repository...
                  2024-04-07 14:22:15.369  - info: admin.0 (800) socket.io server listening on port 8081
                  2024-04-07 14:22:15.381  - info: admin.0 (800) http server listening on port 8081
                  2024-04-07 14:22:15.384  - info: admin.0 (800) Use link "http://127.0.0.1:8081" to configure.
                  2024-04-07 14:22:16.527  - warn: admin.0 (800) Cannot update rating: getaddrinfo EAI_AGAIN rating.iobroker.net
                  2024-04-07 14:22:17.248  - info: host.raspi4iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2024-04-07 14:22:17.633  - error: host.raspi4iobroker Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": getaddrinfo EAI_AGAIN download.iobroker.net
                  2024-04-07 14:22:19.141  - info: host.raspi4iobroker instance system.adapter.discovery.0 started with pid 836
                  2024-04-07 14:22:19.533  - info: admin.0 (800) Repository received successfully.
                  2024-04-07 14:22:19.699  - info: backitup.0 (810) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.1, js-controller: 5.0.19
                  2024-04-07 14:22:19.923  - info: backitup.0 (810) [iobroker] backup will be activated at 02:48 every 1 day(s)
                  2024-04-07 14:22:23.509  - info: discovery.0 (836) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.20.1, js-controller: 5.0.19
                  2024-04-07 14:22:24.766  - info: zigbee.0 (829) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
                  2024-04-07 14:22:24.996  - info: zigbee.0 (829) delete old Backup files. keep only last 10
                  2024-04-07 14:22:25.001  - info: zigbee.0 (829) Starting Zigbee  npm ...
                  2024-04-07 14:22:25.824  - error: zigbee.0 (829) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0'"
                  2024-04-07 14:22:25.826  - error: zigbee.0 (829) Failed to start Zigbee
                  2024-04-07 14:22:25.827  - error: zigbee.0 (829) Error herdsman start
                  2024-04-07 14:22:25.835  - info: zigbee.0 (829) Installed Version: iobroker.zigbee@1.10.1
                  2024-04-07 14:22:35.835  - info: zigbee.0 (829) Try to reconnect. 1 attempts left
                  2024-04-07 14:22:35.837  - info: zigbee.0 (829) Starting Zigbee  npm ...
                  2024-04-07 14:22:35.862  - error: zigbee.0 (829) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0'"
                  2024-04-07 14:22:35.864  - error: zigbee.0 (829) Failed to start Zigbee
                  2024-04-07 14:22:35.866  - error: zigbee.0 (829) Error herdsman start
                  2024-04-07 14:22:35.893  - info: zigbee.0 (829) Installed Version: iobroker.zigbee@1.10.1
                  2024-04-07 14:26:05.943  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                  2024-04-07 14:26:05.945  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                  2024-04-07 14:26:05.946  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                  2024-04-07 14:26:05.947  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                  2024-04-07 14:35:28.526  - info: admin.0 (800) failed connection to socket.io from ::ffff:192.168.178.24: Passport was not initialized
                  2024-04-07 14:35:40.236  - info: admin.0 (800) ==> Connected system.user.admin from ::ffff:192.168.178.24
                  arteckA Offline
                  arteckA Offline
                  arteck
                  doch das geht..musst du nur richtig machen.. steckt der Coordinator direkt im USB oder mit Verlängerung .. da ist es einacheres abzuschirmen..es darf kein Signal rauskommen
                  und NEIN auch wenn @Thomas-Braun der Meinung ist es muss eine neue PANID ..muss nicht sein.. ausser du hast in der Nachbarschaft auch noch ein zigbee Netzwerk ..
                  und ja dann musst du ALLES neu anlernen
                  • arteckA arteck
                    @arteck sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
                    Muss nicht. Aber sinnvoll wäre es.
                      KlarieK Offline
                      KlarieK Offline
                      Klarie
                      Ihr hilfsbereiten Menschen,
                      heute hat es geklappt, den Zigbee-Stick endlich einzubinden und der Adapter läuft stabil.
                      Über Backitup konnte ich auch alle Sensoren und Aktoren wieder einbinden, ohne sie neu anzulernen.
                      Danke Jungs! 🤝
                      Dieses mal hat es auch mit den Tipps von @Asgothian und @arteck geklappt, den Antennenanschluss mit Alufolie abzuschirmen. So konnte ich mir auch sparen, den Strom im ganzen Haus abzustellen. 😁
                      @Thomas-Braun, Danke, dass Du dich in meine ganzen Logs eingelesen hast. Das neue Script von Dir läuft einwandfrei!
                      Zu den PANIDs habe ich aber noch eine Frage. Wenn die ganzen Router im Zigbee-Netz lustig weiter funken, hätte ich doch das gleiche Problem gehabt, wenn ich bei der Einrichtung die IDs geändert hätte - oder?
                      Trotzdem werde ich nach dem Umzug die IDs individualisieren.
                      Jetzt habe ich noch ein paar Problemchen mit anderen Adaptern, aber da fuchse ich mich erst einmal selber rein. 😜
                      Tema gelöst!
                      Viele Grüße
                      Klaus
