  4. [gelöst] Nach Neuinstallation Fehler im Zigbee Adapter
zigbee cc2531
41 Beiträge 7 Kommentatoren 5.7k Aufrufe 6 Beobachtet
  • KlarieK Klarie
    @thomas-braun sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
    Nein. Aber ich habe just gerade genau dazu im iob diag neuen Code drin.
    Du kannst ja mal die Beta-Version von hier laufen lassen:
    https://forum.iobroker.net/topic/59549/iob-diag-skript
    Ausgabe des Logs:
    Skript v.2024-04-07
    *** BASE SYSTEM ***
     Static hostname: raspi4iobroker
           Icon name: computer
              Kernel: Linux 6.6.20+rpt-rpi-v8
        Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     20:18:08 up  5:25,  1 user,  load average: 0.46, 0.26, 0.15
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-04-07 20:18:08 CEST
               Universal time: Sun 2024-04-07 18:18:08 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    klaus
    HOME=/home/klaus
    GROUPS=klaus adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
    *** Display-Server-Setup ***
    pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
    Try `pgrep -f' option to match against the complete command line.
    Display-Server: false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            4.0G        553M        3.1G        1.2M        356M        3.4G
    Swap:           104M          0B        104M
    Total:          4.1G        553M        3.2G
    Active iob-Instances: 	5
             3791 M total memory
              526 M used memory
              588 M active memory
              124 M inactive memory
             2991 M free memory
               57 M buffer memory
              283 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 20:18:11 up  5:25,  1 user,  load average: 0.46, 0.26, 0.15
    Tasks: 162 total,   1 running, 161 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3791.1 total,   2989.9 free,    528.0 used,    340.6 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3263.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  378M   1% /run
    /dev/sda2      ext4      117G  2.9G  109G   3% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   63M  448M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sun Apr  7 14:52:21 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5B:67:30 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=2fd6c37d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Apr  7 14:52:27 2024] EXT4-fs (sda2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
    [Sun Apr  7 14:52:28 2024] EXT4-fs (sda2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET                                                  SOURCE      FSTYPE      OPTIONS
    /                                                       /dev/sda2   ext4        rw,noatime
    |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
    |-/proc                                                 proc        proc        rw,relatime
    | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=352
    |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
    |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1671028k,nr_inodes=417757,mode=755
    | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
    | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
    |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=388204k,mode=755
    | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=388204k,nr_inodes=97051,mode=700,uid=1000,gid=1000
    `-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    521M	/var/
    203M	/var/cache
    197M	/var/cache/apt
    161M	/var/lib
    133M	/var/lib/apt/lists
    Archived and active journals take up 56.0M in the file system.
    /opt/iobroker/backups:
    2.9M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    69M	/opt/iobroker/iobroker-data/
    30M	/opt/iobroker/iobroker-data/backup-objects
    22M	/opt/iobroker/iobroker-data/files
    13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    14M	/opt/iobroker/iobroker-data/objects.jsonl
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.3M	/opt/iobroker/iobroker-data/states.jsonl
    2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    No Devices found 'by-id'
    HINT:
    COM-Port in your ZigBee-Instance ist not set to the 'by-id'-Link. Please check that!
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.20.1
    /usr/bin/node 		v18.20.1
    /usr/bin/npm 		10.5.0
    /usr/bin/npx 		10.5.0
    /usr/bin/corepack 	0.25.2
    nodejs:
      Installed: 18.20.1-1nodesource1
      Candidate: 18.20.1-1nodesource1
      Version table:
     *** 18.20.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.19
    admin: 		6.13.16
    javascript: 	"javascript" not found
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi4iobroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspi4iobroker                           -  enabled
    + system.adapter.discovery.0              : discovery             : raspi4iobroker                           -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspi4iobroker                           -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects: 	172
    States: 	127
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       930        674/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       923        674/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2829       697/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7187       734/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2831       697/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2592       537/avahi-daemon: r
    udp        0      0 0.0.0.0:40558           0.0.0.0:*                           104        2594       537/avahi-daemon: r
    udp6       0      0 :::52192                :::*                                104        2595       537/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        2593       537/avahi-daemon: r
    udp6       0      0 fe80::a2e3:3846:8ea:546 :::*                                0          5830       630/NetworkManager
    2024-04-07 19:36:09.155  - info: admin.0 (734) ==> Connected system.user.admin from ::ffff:192.168.178.24
    2024-04-07 19:49:23.095  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-04-07 19:49:23.107  - info: zigbee.0 (824) Got terminate signal TERMINATE_YOURSELF
    2024-04-07 19:49:23.153  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 send kill signal
    2024-04-07 19:49:23.111  - info: zigbee.0 (824) cleaned everything up...
    2024-04-07 19:49:23.115  - info: zigbee.0 (824) Zigbee: disabling joining new devices.
    2024-04-07 19:49:23.332  - warn: zigbee.0 (824) Failed to stop zigbee during startup
    2024-04-07 19:49:23.333  - info: zigbee.0 (824) terminating
    2024-04-07 19:49:23.334  - info: zigbee.0 (824) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-04-07 19:49:23.612  - info: zigbee.0 (824) terminating
    2024-04-07 19:49:23.917  - info: host.raspi4iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-04-07 19:49:26.191  - info: host.raspi4iobroker instance system.adapter.zigbee.0 started with pid 1140
    2024-04-07 19:49:30.773  - info: zigbee.0 (1140) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
    2024-04-07 19:49:30.881  - info: zigbee.0 (1140) delete old Backup files. keep only last 10
    2024-04-07 19:49:30.883  - info: zigbee.0 (1140) Starting Zigbee  npm ...
    2024-04-07 19:49:31.222  - error: zigbee.0 (1140) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0'"
    2024-04-07 19:49:31.222  - error: zigbee.0 (1140) Failed to start Zigbee
    2024-04-07 19:49:31.223  - error: zigbee.0 (1140) Error herdsman start
    2024-04-07 19:49:31.239  - info: zigbee.0 (1140) Installed Version: iobroker.zigbee@1.10.1
    2024-04-07 19:49:41.227  - info: zigbee.0 (1140) Try to reconnect. 1 attempts left
    2024-04-07 19:49:41.229  - info: zigbee.0 (1140) Starting Zigbee  npm ...
    2024-04-07 19:49:41.257  - error: zigbee.0 (1140) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0'"
    2024-04-07 19:49:41.259  - error: zigbee.0 (1140) Failed to start Zigbee
    2024-04-07 19:49:41.261  - error: zigbee.0 (1140) Error herdsman start
    2024-04-07 19:49:41.279  - info: zigbee.0 (1140) Installed Version: iobroker.zigbee@1.10.1
    ...und der Summary:
    			v.2024-04-07
           Icon name: computer
        Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		64 bit
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation:
    /usr/bin/npm 		10.5.0
    /usr/bin/npx 		10.5.0
    Recommended versions are nodejs 18.20.1 and npm 10.5.0
    MEMORY:
    Mem:            4.0G        614M        2.8G        1.2M        590M        3.4G
    Swap:           104M          0B        104M
    Total:          4.1G        614M        3.0G
    ioBroker Core: 		js-controller 		5.0.19
    			admin 			6.13.16
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		172
    States: 		127
    Size of iob-Database:
    18M	/opt/iobroker/iobroker-data/objects.jsonl
    3.4M	/opt/iobroker/iobroker-data/states.jsonl
    @klarie sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
    find: '/dev/serial/by-id/': No such file or directory No Devices found 'by-id'
    Da ist kein Gerät.
    KlarieK 1 Antwort Letzte Antwort
      @klarie
      Auch keine Zahlendreher drin?
      KlarieK Offline
      KlarieK Offline
      Klarie
      @klarie
      Beim "Copy&Paste" gehe ich nicht davon aus. 😌
      @wildbill sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
      @klarie Beim Kopieren vielleicht versehentlich vorne order hinten ein Leerzeichen angehängt?
      Einfach mal vorne das erste Zeichen löschen und nochmal neu manuell eingeben. Hinten das Gleiche.
      Sag mal, kennst Du mich? 😊
      Habe ich geprüft. Keine Leerzeichen. 😧
      Thomas BraunT W 2 Antworten Letzte Antwort
      • KlarieK Klarie
        @klarie
        Keine Leerzeichen.
        Richtig. Aber da ist 'kein Gerät' unter dieser Adresse wohnhaft.
        Steck das Ding nochmal richtig rein... :-)
          Da ist kein Gerät.
          KlarieK Offline
          KlarieK Offline
          Klarie
          schrieb am zuletzt editiert von Klarie
          Da ist kein Gerät.
          Wo müsste es denn stehen?
          Dann probiere ich gleich mal verschiedene Optionen (USB-Anschlüsse/Kabel) durch.
          [Edit] Erledigt. Habe den Eintrag gefunden.
          • KlarieK Klarie
            Da ist kein Gerät.
            Der Link wird vom Kernel bzw von udev angelegt, wenn das Gerät in den Tiefen des KernelRingPuffers auftaucht.
            Was haste denn da genau als Coordinator am Start?
              KlarieK Offline
              KlarieK Offline
              Klarie
              "SONOFF Zigbee 3.0 USB Plus" (CC2652P )
              • KlarieK Klarie
                @klarie
                W Online
                W Online
                Wildbill
                Die Erfahrung mit einem Leerzeichen an unpassender Stelle habe ich (und vermutlich viele andere auch) schon machen müssen. 😊
                Gruss, Jürgen
                • KlarieK Offline
                  KlarieK Offline
                  Klarie
                  Keine Leerzeichen.
                  USB-Devices by-id:
                  Your ZigBee COM-Ports are matching 'by-id'. Very good!
                  Adapter State
                  + instance is alive
                  Trozdem:
                  2024-04-07 21:33:59.829  - info: admin.0 (934) <== Disconnect system.user.admin from ::ffff:192.168.178.24 admin
                  2024-04-07 21:34:00.179  - info: admin.0 (934) ==> Connected system.user.admin from ::ffff:192.168.178.24
                  2024-04-07 21:34:05.736  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2024-04-07 21:34:05.752  - info: zigbee.0 (871) Got terminate signal TERMINATE_YOURSELF
                  2024-04-07 21:34:05.757  - info: zigbee.0 (871) cleaned everything up...
                  2024-04-07 21:34:05.764  - info: zigbee.0 (871) Zigbee: disabling joining new devices.
                  2024-04-07 21:34:05.793  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 send kill signal
                  2024-04-07 21:34:06.259  - info: zigbee.0 (871) terminating
                  2024-04-07 21:34:06.261  - info: zigbee.0 (871) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-04-07 21:34:06.798  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 killing pid 871
                  2024-04-07 21:34:06.818  - info: host.raspi4iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-04-07 21:34:08.826  - info: host.raspi4iobroker instance system.adapter.zigbee.0 started with pid 991
                  2024-04-07 21:34:13.466  - info: zigbee.0 (991) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
                  2024-04-07 21:34:13.576  - info: zigbee.0 (991) delete old Backup files. keep only last 10
                  2024-04-07 21:34:13.578  - info: zigbee.0 (991) Starting Zigbee  npm ...
                  2024-04-07 21:34:13.904  - info: zigbee.0 (991) Installed Version: iobroker.zigbee@1.10.1
                  2024-04-07 21:35:19.130  - error: zigbee.0 (991) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                  2024-04-07 21:35:19.132  - error: zigbee.0 (991) Failed to start Zigbee
                  2024-04-07 21:35:19.133  - error: zigbee.0 (991) Error herdsman start
                  2024-04-07 21:35:29.137  - info: zigbee.0 (991) Try to reconnect. 1 attempts left
                  2024-04-07 21:35:29.139  - info: zigbee.0 (991) Starting Zigbee  npm ...
                  2024-04-07 21:35:29.156  - info: zigbee.0 (991) Installed Version: iobroker.zigbee@1.10.1
                  2024-04-07 21:35:29.394  - error: zigbee.0 (991) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                  2024-04-07 21:35:29.396  - error: zigbee.0 (991) Failed to start Zigbee
                  2024-04-07 21:35:29.397  - error: zigbee.0 (991) Error herdsman start
                  • KlarieK Klarie
                    Keine Leerzeichen.
                    USB-Devices by-id:
                    Adapter State
                    + instance is alive
                    Trozdem:
                    Trozdem:
                    Jetzt sind aber die Meldungen andere...
                    Zeig mal die Einstellungen im Adapter in Gänze.
                      Trozdem:
                      KlarieK Offline
                      KlarieK Offline
                      Klarie
                      • KlarieK Klarie
                        @klarie
                        Setz die Erw. PAN-Id auf was anderes als den default.
                          @klarie
                          KlarieK Offline
                          KlarieK Offline
                          Klarie
                          Dann muss ich aber alle Geräte neu anlernen - Richtig?
                          Soll ich nicht lieber nochmal versuchen, den Raspi neu zu starten, wenn alle Router stromlos sind?
                          • KlarieK Klarie
                            @klarie
                            Die eindeutige Bezeichnung deines ZigBee-Netzwerkes hättest du ja auch sofort machen sollen. Deswegen steht der entsprechende Text auch daneben.
                              @klarie
                              KlarieK Offline
                              KlarieK Offline
                              Klarie
                              Nachher ist man immer schlauer...
                              Ich ziehe in einem guten halben Jahr um, und werde dann vermutlich eh alles neu aufsetzen. Dann auch mit neuer PAN-ID.
                              Ich versuche es heute Abend erst einmal mit einem Neustart "ohne" Router.
                              Ich werde im Anschluss spätestens morgen berichten. ;o)
                              Jetzt schon mal besten Dank, dass Du dich so sehr mit meinem Problem beschäftigst. 👍
                              • KlarieK Klarie
                                Udate
                                Der Tipp von @arteck hat leider nicht funktioniert.
                                Trotz einer "halben Rolle" Alufolie entdeckte der Coordinator immer noch die gleiche PanID in der Nähe.
                                Ich habe vermutlich zu viele und "starke!" Router im Netz... 🤡
                                Also habe ich im ganzen Haus den Strom abgestellt und den Raspi über eine leistungsstarke Powerbank gestartet.
                                Der Zigbee-Adapter bleibt weiterhin gelb (kann nicht mit Gerät oder Dienst verbinden).
                                Logfile des Startvorganges
                                2024-04-07 14:21:52.062  - info: backitup.0 (860) cleaned everything up...
                                2024-04-07 14:21:52.066  - info: zigbee.0 (884) cleaned everything up...
                                2024-04-07 14:21:52.066  - info: host.raspi4iobroker received SIGTERM
                                2024-04-07 14:21:52.067  - info: admin.0 (763) terminating http server on port 8081
                                2024-04-07 14:21:52.080  - info: host.raspi4iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                                2024-04-07 14:21:52.081  - info: host.raspi4iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2024-04-07 14:21:52.082  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                2024-04-07 14:21:52.083  - info: host.raspi4iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                                2024-04-07 14:21:52.133  - info: discovery.0 (895) Got terminate signal TERMINATE_YOURSELF
                                2024-04-07 14:21:52.129  - info: admin.0 (763) Got terminate signal TERMINATE_YOURSELF
                                2024-04-07 14:21:52.139  - info: host.raspi4iobroker stopInstance system.adapter.admin.0 send kill signal
                                2024-04-07 14:21:52.135  - info: discovery.0 (895) terminating
                                2024-04-07 14:21:52.139  - info: discovery.0 (895) Terminated (NO_ERROR): Without reason
                                2024-04-07 14:21:52.141  - info: host.raspi4iobroker stopInstance system.adapter.backitup.0 send kill signal
                                2024-04-07 14:21:52.142  - info: host.raspi4iobroker stopInstance system.adapter.zigbee.0 send kill signal
                                2024-04-07 14:21:52.142  - info: host.raspi4iobroker stopInstance system.adapter.discovery.0 send kill signal
                                2024-04-07 14:21:52.130  - info: backitup.0 (860) Got terminate signal TERMINATE_YOURSELF
                                2024-04-07 14:21:52.145  - info: backitup.0 (860) terminating
                                2024-04-07 14:21:52.148  - info: admin.0 (763) terminating
                                2024-04-07 14:21:52.147  - info: backitup.0 (860) Terminated (NO_ERROR): Without reason
                                2024-04-07 14:21:52.154  - info: admin.0 (763) Terminated (NO_ERROR): Without reason
                                2024-04-07 14:21:52.087  - info: zigbee.0 (884) Zigbee: disabling joining new devices.
                                2024-04-07 14:21:52.180  - warn: zigbee.0 (884) Failed to stop zigbee during startup
                                2024-04-07 14:21:52.203  - info: zigbee.0 (884) Got terminate signal TERMINATE_YOURSELF
                                2024-04-07 14:21:52.248  - info: zigbee.0 (884) terminating
                                2024-04-07 14:21:52.250  - info: zigbee.0 (884) Terminated (NO_ERROR): Without reason
                                2024-04-07 14:21:52.565  - info: discovery.0 (895) terminating
                                2024-04-07 14:21:52.570  - info: backitup.0 (860) terminating
                                2024-04-07 14:21:52.578  - info: zigbee.0 (884) terminating
                                2024-04-07 14:21:52.599  - info: admin.0 (763) terminating
                                2024-04-07 14:21:52.756  - info: host.raspi4iobroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                                2024-04-07 14:21:52.756  - info: host.raspi4iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                                2024-04-07 14:21:52.801  - info: host.raspi4iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                2024-04-07 14:21:52.817  - info: host.raspi4iobroker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                                2024-04-07 14:21:52.818  - info: host.raspi4iobroker All instances are stopped.
                                2024-04-07 14:21:52.950  - info: host.raspi4iobroker terminated
                                2024-04-07 14:22:02.703  - info: host.raspi4iobroker iobroker.js-controller version 5.0.19 js-controller starting
                                2024-04-07 14:22:02.710  - info: host.raspi4iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                2024-04-07 14:22:02.711  - info: host.raspi4iobroker hostname: raspi4iobroker, node: v18.20.1
                                2024-04-07 14:22:02.712  - info: host.raspi4iobroker ip addresses:
                                2024-04-07 14:22:04.614  - info: host.raspi4iobroker connected to Objects and States
                                2024-04-07 14:22:04.683  - info: host.raspi4iobroker added notifications configuration of host
                                2024-04-07 14:22:05.836  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.nodeCurrent"
                                2024-04-07 14:22:05.841  - info: host.raspi4iobroker 4 instances found
                                2024-04-07 14:22:05.877  - info: host.raspi4iobroker starting 4 instances
                                2024-04-07 14:22:05.978  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.nodeNewest"
                                2024-04-07 14:22:06.008  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.nodeNewestNext"
                                2024-04-07 14:22:06.034  - info: host.raspi4iobroker instance system.adapter.admin.0 started with pid 800
                                2024-04-07 14:22:06.052  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.npmCurrent"
                                2024-04-07 14:22:06.112  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.npmNewest"
                                2024-04-07 14:22:06.127  - info: host.raspi4iobroker Delete state "system.host.raspi4iobroker.versions.npmNewestNext"
                                2024-04-07 14:22:06.141  - info: host.raspi4iobroker Some obsolete host states deleted.
                                2024-04-07 14:22:09.937  - info: host.raspi4iobroker instance system.adapter.backitup.0 started with pid 810
                                2024-04-07 14:22:12.188  - info: admin.0 (800) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.1, js-controller: 5.0.19
                                2024-04-07 14:22:12.293  - info: admin.0 (800) requesting all objects
                                2024-04-07 14:22:13.183  - warn: admin.0 (800) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org
                                2024-04-07 14:22:14.038  - info: host.raspi4iobroker instance system.adapter.zigbee.0 started with pid 829
                                2024-04-07 14:22:14.463  - info: admin.0 (800) received all objects
                                2024-04-07 14:22:15.278  - warn: admin.0 (800) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
                                2024-04-07 14:22:15.291  - info: admin.0 (800) Request actual repository...
                                2024-04-07 14:22:15.369  - info: admin.0 (800) socket.io server listening on port 8081
                                2024-04-07 14:22:15.381  - info: admin.0 (800) http server listening on port 8081
                                2024-04-07 14:22:15.384  - info: admin.0 (800) Use link "http://127.0.0.1:8081" to configure.
                                2024-04-07 14:22:16.527  - warn: admin.0 (800) Cannot update rating: getaddrinfo EAI_AGAIN rating.iobroker.net
                                2024-04-07 14:22:17.248  - info: host.raspi4iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                2024-04-07 14:22:17.633  - error: host.raspi4iobroker Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": getaddrinfo EAI_AGAIN download.iobroker.net
                                2024-04-07 14:22:19.141  - info: host.raspi4iobroker instance system.adapter.discovery.0 started with pid 836
                                2024-04-07 14:22:19.533  - info: admin.0 (800) Repository received successfully.
                                2024-04-07 14:22:19.699  - info: backitup.0 (810) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.1, js-controller: 5.0.19
                                2024-04-07 14:22:19.923  - info: backitup.0 (810) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                2024-04-07 14:22:23.509  - info: discovery.0 (836) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.20.1, js-controller: 5.0.19
                                2024-04-07 14:22:24.766  - info: zigbee.0 (829) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
                                2024-04-07 14:22:24.996  - info: zigbee.0 (829) delete old Backup files. keep only last 10
                                2024-04-07 14:22:25.001  - info: zigbee.0 (829) Starting Zigbee  npm ...
                                2024-04-07 14:22:25.824  - error: zigbee.0 (829) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0'"
                                2024-04-07 14:22:25.826  - error: zigbee.0 (829) Failed to start Zigbee
                                2024-04-07 14:22:25.827  - error: zigbee.0 (829) Error herdsman start
                                2024-04-07 14:22:25.835  - info: zigbee.0 (829) Installed Version: iobroker.zigbee@1.10.1
                                2024-04-07 14:22:35.835  - info: zigbee.0 (829) Try to reconnect. 1 attempts left
                                2024-04-07 14:22:35.837  - info: zigbee.0 (829) Starting Zigbee  npm ...
                                2024-04-07 14:22:35.862  - error: zigbee.0 (829) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f8e52e2daaa4ed11aa9081582981d5c7-if00-port0'"
                                2024-04-07 14:22:35.864  - error: zigbee.0 (829) Failed to start Zigbee
                                2024-04-07 14:22:35.866  - error: zigbee.0 (829) Error herdsman start
                                2024-04-07 14:22:35.893  - info: zigbee.0 (829) Installed Version: iobroker.zigbee@1.10.1
                                2024-04-07 14:26:05.943  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                                2024-04-07 14:26:05.945  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                                2024-04-07 14:26:05.946  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                                2024-04-07 14:26:05.947  - info: host.raspi4iobroker No IPv4 address found after 5 minutes.
                                2024-04-07 14:35:28.526  - info: admin.0 (800) failed connection to socket.io from ::ffff:192.168.178.24: Passport was not initialized
                                2024-04-07 14:35:40.236  - info: admin.0 (800) ==> Connected system.user.admin from ::ffff:192.168.178.24
                                arteckA Offline
                                arteckA Offline
                                arteck
                                doch das geht..musst du nur richtig machen.. steckt der Coordinator direkt im USB oder mit Verlängerung .. da ist es einacheres abzuschirmen..es darf kein Signal rauskommen
                                und NEIN auch wenn @Thomas-Braun der Meinung ist es muss eine neue PANID ..muss nicht sein.. ausser du hast in der Nachbarschaft auch noch ein zigbee Netzwerk ..
                                und ja dann musst du ALLES neu anlernen
                                • arteckA arteck
                                  @arteck sagte in Nach Neuinstallation Fehler im Zigbee Adapter:
                                  Muss nicht. Aber sinnvoll wäre es.
                                    KlarieK Offline
                                    KlarieK Offline
                                    Klarie
                                    Ihr hilfsbereiten Menschen,
                                    heute hat es geklappt, den Zigbee-Stick endlich einzubinden und der Adapter läuft stabil.
                                    Über Backitup konnte ich auch alle Sensoren und Aktoren wieder einbinden, ohne sie neu anzulernen.
                                    Danke Jungs! 🤝
                                    Dieses mal hat es auch mit den Tipps von @Asgothian und @arteck geklappt, den Antennenanschluss mit Alufolie abzuschirmen. So konnte ich mir auch sparen, den Strom im ganzen Haus abzustellen. 😁
                                    @Thomas-Braun, Danke, dass Du dich in meine ganzen Logs eingelesen hast. Das neue Script von Dir läuft einwandfrei!
                                    Zu den PANIDs habe ich aber noch eine Frage. Wenn die ganzen Router im Zigbee-Netz lustig weiter funken, hätte ich doch das gleiche Problem gehabt, wenn ich bei der Einrichtung die IDs geändert hätte - oder?
                                    Trotzdem werde ich nach dem Umzug die IDs individualisieren.
                                    Jetzt habe ich noch ein paar Problemchen mit anderen Adaptern, aber da fuchse ich mich erst einmal selber rein. 😜
                                    Tema gelöst!
                                    Viele Grüße
                                    Klaus
