System mit Master/Slave neu aufsetzen
@marc-berg
Zeile auskommentiert, neu gestartet und keine Veränderung.@lollo_c sagte in System mit Master/Slave neu aufsetzen:
Dann zeig jetzt nochmal das iob diag. Wenn sich da nichts geändert hat, wird die redis.conf nicht verwendet.
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: RasPi4 Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-rpi8-rpi-v8 Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : arm64 Systemuptime and Load: 11:05:30 up 7 min, 2 users, load average: 0.61, 1.15, 0.69 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Sat 2024-03-02 11:05:30 CET Universal time: Sat 2024-03-02 10:05:30 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 4.0G 2.1G 882M 1.2M 1.0G 1.8G Swap: 104M 0B 104M Total: 4.1G 2.1G 987M 3792 M total memory 2029 M used memory 2558 M active memory 256 M inactive memory 842 M free memory 71 M buffer memory 924 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 380M 1.2M 379M 1% /run /dev/sda2 ext4 29G 5.4G 22G 20% / tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/sda1 vfat 510M 61M 450M 12% /boot/firmware tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sat Mar 2 10:58:12 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:A6:44:D3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=a45a8ca6-02 rootfstype=ext4 fsck.repair=yes rootwait [Sat Mar 2 10:58:14 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Sat Mar 2 10:58:15 2024] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1.1G /var/ 538M /var/cache 524M /var/cache/apt 410M /var/cache/apt/archives 262M /var/log Archived and active journals take up 260.8M in the file system. /opt/iobroker/backups: 75M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 370M /opt/iobroker/iobroker-data/ 303M /opt/iobroker/iobroker-data/files 57M /opt/iobroker/iobroker-data/files/javascript.admin 45M /opt/iobroker/iobroker-data/files/devices.admin/static 45M /opt/iobroker/iobroker-data/files/devices.admin The five largest files in iobroker-data are: 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 22M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map 22M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map 20M /opt/iobroker/iobroker-data/objects.jsonl 8.9M /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.1 /usr/bin/node v18.19.1 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.1-1nodesource1 Candidate: 18.19.1-1nodesource1 Version table: *** 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: redis Core adapters versions js-controller: 5.0.19 admin: 6.13.16 javascript: 7.8.0 Adapters from github: 1 Adapter State + system.adapter.admin.0 : admin : RasPi4 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : RasPi4 - enabled system.adapter.broadlink2.0 : broadlink2 : RasPi4 - disabled system.adapter.cloud.0 : cloud : RasPi4 - disabled system.adapter.devices.0 : devices : RasPi4 - disabled + system.adapter.discovery.0 : discovery : RasPi4 - enabled system.adapter.dwd.0 : dwd : RasPi3 - enabled system.adapter.flot.0 : flot : RasPi4 - disabled + system.adapter.hm-rega.1 : hm-rega : RasPi4 - enabled + system.adapter.hm-rpc.2 : hm-rpc : RasPi4 - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : RasPi4 - enabled, port: 0 + system.adapter.hmip.0 : hmip : RasPi4 - enabled system.adapter.ical.0 : ical : RasPi3 - enabled system.adapter.icons-material-png.0 : icons-material-png : RasPi4 - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : RasPi4 - disabled + system.adapter.influxdb.0 : influxdb : RasPi4 - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : RasPi4 - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : RasPi4 - enabled, port: 8086 + system.adapter.javascript.0 : javascript : RasPi4 - enabled system.adapter.luftdaten.0 : luftdaten : RasPi3 - enabled system.adapter.luftdaten.1 : luftdaten : RasPi3 - enabled system.adapter.luftdaten.2 : luftdaten : RasPi3 - enabled system.adapter.mobile.0 : mobile : RasPi4 - disabled + system.adapter.modbus.0 : modbus : RasPi4 - enabled + system.adapter.mqtt.0 : mqtt : RasPi4 - enabled, port: 1882, bind: 127.0.0.1 + system.adapter.nut.0 : nut : RasPi4 - enabled system.adapter.openweathermap.0 : openweathermap : RasPi3 - enabled system.adapter.owfs.0 : owfs : RasPi3 - enabled, port: 4304 + system.adapter.ping.0 : ping : RasPi4 - enabled system.adapter.pvforecast.0 : pvforecast : RasPi3 - enabled + system.adapter.rpi2.0 : rpi2 : RasPi4 - enabled system.adapter.rpi2.1 : rpi2 : RasPi3 - enabled + system.adapter.scenes.0 : scenes : RasPi4 - enabled + system.adapter.shelly.0 : shelly : RasPi4 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : RasPi4 - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.smartmeter.0 : smartmeter : RasPi3 - enabled + system.adapter.socketio.0 : socketio : RasPi4 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonos.0 : sonos : RasPi4 - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : RasPi4 - enabled + system.adapter.telegram.0 : telegram : RasPi4 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : RasPi4 - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : RasPi4 - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : RasPi4 - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : RasPi4 - disabled system.adapter.vis-material-webfont.0 : vis-material-webfont : RasPi4 - disabled system.adapter.vis-material.0 : vis-material : RasPi4 - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : RasPi4 - disabled system.adapter.vis-metro.0 : vis-metro : RasPi4 - disabled system.adapter.vis-players.0 : vis-players : RasPi4 - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : RasPi4 - disabled system.adapter.vis-weather.0 : vis-weather : RasPi4 - disabled system.adapter.vis.0 : vis : RasPi4 - enabled + system.adapter.web.0 : web : RasPi4 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.ws.0 : ws : RasPi4 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : RasPi4 - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : RasPi4 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.2 : hm-rpc : RasPi4 - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : RasPi4 - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : RasPi4 - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : RasPi4 - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : RasPi4 - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : RasPi4 - enabled, port: 1882, bind: 127.0.0.1 system.adapter.owfs.0 : owfs : RasPi3 - enabled, port: 4304 + system.adapter.shelly.0 : shelly : RasPi4 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : RasPi4 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.socketio.0 : socketio : RasPi4 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : RasPi4 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : RasPi4 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.ws.0 : ws : RasPi4 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : RasPi4 - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "backitup" : 2.10.11 , installed 2.10.11 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "hm-rega" : 4.0.0 , installed 4.0.0 Adapter "hm-rpc" : 1.16.0 , installed 1.16.0 Adapter "hmip" : 1.21.0 , installed 1.22.0 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 7.8.0 , installed 7.8.0 Controller "js-controller": 5.0.19 , installed 5.0.19 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "modbus" : 6.1.0 , installed 6.1.0 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 3.0.1 , installed 3.0.1 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-material" : 0.1.3 , installed 0.1.3 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "web" : 6.2.3 , installed 6.2.3 Adapter "ws" : 2.5.10 , installed 2.5.10 Adapter "zigbee" : 1.10.1 , installed 1.10.1 Objects and States Please stand by - This may take a while Objects: 11484 States: 9871 *** OS-Repositories and Updates *** Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 https://repos.influxdata.com/debian stable InRelease Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease Hit:5 https://apt.grafana.com stable InRelease Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:7 http://deb.debian.org/debian bookworm-updates InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 14726 780/influxd tcp 0 0 127.0.0.1:1882 0.0.0.0:* LISTEN 1001 15228 1154/io.mqtt.0 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 107 13291 721/mosquitto tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 22667 1216/io.shelly.0 tcp 0 0 192.168.2.210:42001 0.0.0.0:* LISTEN 1001 18287 1106/io.hm-rpc.3 tcp 0 0 192.168.2.210:42010 0.0.0.0:* LISTEN 1001 17120 1091/io.hm-rpc.2 tcp 0 0 0.0.0.0:6379 0.0.0.0:* LISTEN 106 13311 699/redis-server *: tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13302 725/sshd: /usr/sbin tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 16472 852/iobroker.js-con tcp6 0 0 :::3500 :::* LISTEN 1001 22722 1267/io.sonos.0 tcp6 0 0 :::8086 :::* LISTEN 999 13908 780/influxd tcp6 0 0 :::8087 :::* LISTEN 1001 25883 1405/io.simple-api. tcp6 0 0 :::8084 :::* LISTEN 1001 23776 1323/io.socketio.0 tcp6 0 0 :::8082 :::* LISTEN 1001 24397 1390/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 14777 896/io.admin.0 tcp6 0 0 :::1882 :::* LISTEN 107 13292 721/mosquitto tcp6 0 0 :::6379 :::* LISTEN 106 13312 699/redis-server *: tcp6 0 0 :::22 :::* LISTEN 0 13304 725/sshd: /usr/sbin tcp6 0 0 :::3000 :::* LISTEN 108 13926 851/grafana udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 13072 541/avahi-daemon: r udp 0 0 0.0.0.0:44362 0.0.0.0:* 104 13074 541/avahi-daemon: r udp6 0 0 :::5353 :::* 104 13073 541/avahi-daemon: r udp6 0 0 fe80::5635:5d6e:3e1:546 :::* 0 17493 653/NetworkManager udp6 0 0 :::37488 :::* 104 13075 541/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-03-02 11:06:22.563 - warn: shelly.0 (1216) [authEnabled] 192.168.2.32 (shellyplug-s / shellyplug-s-4022D881C8A0 / SHPLG-S#4022D881C8A0#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:22.883 - info: javascript.0 (984) script.js.EIGENE_SCRIPTE.Geraete.Kuehlgeraete.Gefrierschrank_Status_v1: Status 2 | Gefrierschrank LÄUFT 2024-03-02 11:06:23.695 - warn: shelly.0 (1216) [authEnabled] 192.168.2.37 (shellyplug-s / shellyplug-s-4022D881C855 / SHPLG-S#4022D881C855#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:23.746 - warn: shelly.0 (1216) [authEnabled] 192.168.2.33 (shellyplug-s / shellyplug-s-7A34A5 / SHPLG-S#7A34A5#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:23.752 - warn: shelly.0 (1216) [authEnabled] 192.168.2.34 (shellyplug-s / shellyplug-s-041B6E / SHPLG-S#041B6E#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:26.761 - warn: host.RasPi4 "system.host.RasPi3" is offline 2024-03-02 11:06:26.913 - warn: host.RasPi4 "system.host.RasPi3" is offline 2024-03-02 11:06:27.028 - warn: host.RasPi4 "system.host.RasPi3" is offline 2024-03-02 11:06:32.598 - warn: shelly.0 (1216) [authEnabled] 192.168.2.31 (shellyplug-s / shellyplug-s-04119D / SHPLG-S#04119D#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:32.622 - warn: shelly.0 (1216) [authEnabled] 192.168.2.35 (shellyplug-s / shellyplug-s-F1AEC2 / SHPLG-S#F1AEC2#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:32.654 - warn: shelly.0 (1216) [authEnabled] 192.168.2.48 (shellyplug-s / shellyplug-s-9DCC68 / SHPLG-S#9DCC68#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:32.939 - warn: shelly.0 (1216) [authEnabled] 192.168.2.32 (shellyplug-s / shellyplug-s-4022D881C8A0 / SHPLG-S#4022D881C8A0#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:33.743 - warn: sonos.0 (1267) State "sonos.0.root.192_168_2_44.current_track_number" has no existing object, this might lead to an error in future versions 2024-03-02 11:06:33.818 - warn: sonos.0 (1267) State "sonos.0.root.192_168_2_44.current_track_number" has no existing object, this might lead to an error in future versions 2024-03-02 11:06:33.968 - warn: shelly.0 (1216) [authEnabled] 192.168.2.37 (shellyplug-s / shellyplug-s-4022D881C855 / SHPLG-S#4022D881C855#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:34.035 - warn: shelly.0 (1216) [authEnabled] 192.168.2.33 (shellyplug-s / shellyplug-s-7A34A5 / SHPLG-S#7A34A5#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:34.043 - warn: shelly.0 (1216) [authEnabled] 192.168.2.34 (shellyplug-s / shellyplug-s-041B6E / SHPLG-S#041B6E#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:42.709 - warn: shelly.0 (1216) [authEnabled] 192.168.2.31 (shellyplug-s / shellyplug-s-04119D / SHPLG-S#04119D#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:42.763 - warn: shelly.0 (1216) [authEnabled] 192.168.2.35 (shellyplug-s / shellyplug-s-F1AEC2 / SHPLG-S#F1AEC2#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:42.827 - warn: shelly.0 (1216) [authEnabled] 192.168.2.48 (shellyplug-s / shellyplug-s-9DCC68 / SHPLG-S#9DCC68#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:43.084 - warn: shelly.0 (1216) [authEnabled] 192.168.2.32 (shellyplug-s / shellyplug-s-4022D881C8A0 / SHPLG-S#4022D881C8A0#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:44.137 - warn: shelly.0 (1216) [authEnabled] 192.168.2.37 (shellyplug-s / shellyplug-s-4022D881C855 / SHPLG-S#4022D881C855#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:44.231 - warn: shelly.0 (1216) [authEnabled] 192.168.2.34 (shellyplug-s / shellyplug-s-041B6E / SHPLG-S#041B6E#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:44.236 - warn: shelly.0 (1216) [authEnabled] 192.168.2.33 (shellyplug-s / shellyplug-s-7A34A5 / SHPLG-S#7A34A5#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-02 11:06:47.696 - info: javascript.0 (984) script.js.EIGENE_SCRIPTE.Geraete.Kuehlgeraete.Gefrierschrank_Status_v1: Status 2 | Gefrierschrank LÄUFT -
tcp 0 0 0.0.0.0:6379 0.0.0.0:* LISTEN 106 13311 699/redis-server *:Das sieht jetzt eigentlich gut aus. Habe erstmal keine Idee, was da noch schief sein könnte. Die IP auf dem Slave passt ganz sicher?
@marc-berg sagte in System mit Master/Slave neu aufsetzen:
Im Standard hört die redis DB dann auf alle verfügbaren Interfaces.
sicher?
ich meine 0.0.0.0 muss explizit freigegeben werden -
@marc-berg
Am Slave habe ich ja nichts geändert. Ich kann mit Putty auf ihn zugreifen. Die iob diag vom Slave sieht wie folgt aus:Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: RasPi3 Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7+ Architecture: arm Model : Raspberry Pi 3 Model B Plus Rev 1.3 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 11:22:26 up 16:07, 1 user, load average: 0.32, 0.25, 0.21 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: ~ Under-voltage has occurred *** Time and Time Zones *** Local time: Sat 2024-03-02 11:22:26 CET Universal time: Sat 2024-03-02 10:22:26 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 923M 211M 262M 15M 449M 733M Swap: 99M 3.0M 96M Total: 1.0G 214M 359M 923 M total memory 211 M used memory 283 M active memory 312 M inactive memory 262 M free memory 79 M buffer memory 369 M swap cache 99 M total swap 3 M used swap 96 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** 0 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 15G 5.5G 8.2G 40% / devtmpfs devtmpfs 430M 0 430M 0% /dev tmpfs tmpfs 462M 0 462M 0% /dev/shm tmpfs tmpfs 462M 18M 444M 4% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 462M 0 462M 0% /sys/fs/cgroup /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 93M 0 93M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Mar 1 19:15:07 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [Fri Mar 1 19:15:10 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Fri Mar 1 19:15:10 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Fri Mar 1 19:15:13 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 |-/run/owfs OWFS fuse.OWFS rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.6G /var/ 2.3G /var/cache/apt/archives 2.3G /var/cache/apt 2.3G /var/cache 147M /var/lib Archived and active journals take up 17.3M in the file system. /opt/iobroker/backups: 169M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 42M /opt/iobroker/iobroker-data/ 22M /opt/iobroker/iobroker-data/files 15M /opt/iobroker/iobroker-data/backup-objects 8.0M /opt/iobroker/iobroker-data/files/vis 7.9M /opt/iobroker/iobroker-data/files/web The five largest files in iobroker-data are: 2.0M /opt/iobroker/iobroker-data/objects.json.migrated 2.0M /opt/iobroker/iobroker-data/objects.json.bak.migrated 636K /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-20_objects.json.gz 632K /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-28_objects.json.gz 632K /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-25_objects.json.gz USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DK0EJEOL-if00-port0 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.1 /usr/bin/node v18.19.1 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.1-1nodesource1 Candidate: 18.19.1-1nodesource1 Version table: *** 18.19.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.19.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.2-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status No connection to states 192.168.2.210:6379[redis] Core adapters versions js-controller: 5.0.19 admin: 6.3.5 javascript: "javascript" not found Adapters from github: 0 Adapter State No connection to states 192.168.2.210:6379[redis] Enabled adapters with bindings ioBroker-Repositories No connection to states 192.168.2.210:6379[redis] Installed ioBroker-Instances No connection to states 192.168.2.210:6379[redis] Objects and States Please stand by - This may take a while Objects: 1 States: 1 *** OS-Repositories and Updates *** W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead. Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 http://phoscon.de/apt/deconz buster InRelease Get:4 https://repos.influxdata.com/debian buster InRelease [7047 B] Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease Err:4 https://repos.influxdata.com/debian buster InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E Fetched 7047 B in 2s (4327 B/s) Reading package lists... W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead. Pending Updates: 2 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:2120 0.0.0.0:* LISTEN 109 15414 327/owftpd tcp 0 0 0.0.0.0:2121 0.0.0.0:* LISTEN 109 16506 456/owhttpd tcp 0 0 0.0.0.0:5005 0.0.0.0:* LISTEN 0 15896 637/node tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15836 642/sshd tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 16526 409/influxd tcp6 0 0 :::3500 :::* LISTEN 0 15898 637/node tcp6 0 0 :::4304 :::* LISTEN 0 13594 1/init tcp6 0 0 :::8086 :::* LISTEN 999 16006 409/influxd tcp6 0 0 :::22 :::* LISTEN 0 15846 642/sshd udp 0 0 0.0.0.0:68 0.0.0.0:* 0 14849 635/dhcpcd udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14734 346/avahi-daemon: r udp 0 0 0.0.0.0:42936 0.0.0.0:* 108 14736 346/avahi-daemon: r udp6 0 0 :::45220 :::* 108 14737 346/avahi-daemon: r udp6 0 0 :::5353 :::* 108 14735 346/avahi-daemon: r udp6 0 0 :::546 :::* 0 14993 635/dhcpcd *** Log File - Last 25 Lines *** 2024-03-02 11:22:20.955 - info: host.RasPi3 iobroker _restart 2024-03-02 11:22:29.592 - info: host.RasPi3 iobroker.js-controller version 5.0.19 js-controller starting 2024-03-02 11:22:29.605 - info: host.RasPi3 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2024-03-02 11:22:29.607 - info: host.RasPi3 hostname: RasPi3, node: v18.19.1 2024-03-02 11:22:29.609 - info: host.RasPi3 ip addresses: 192.168.2.30 2003:e0:9712:9a00:bee:e5c2:b6b8:6aad fe80::df32:ad2b:5f7d:3ca 2024-03-02 11:22:59.685 - error: host.RasPi3 No connection to databases possible, restart 2024-03-02 11:22:59.699 - info: host.RasPi3 iobroker _restart 2024-03-02 11:23:07.999 - info: host.RasPi3 iobroker.js-controller version 5.0.19 js-controller starting 2024-03-02 11:23:08.011 - info: host.RasPi3 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2024-03-02 11:23:08.013 - info: host.RasPi3 hostname: RasPi3, node: v18.19.1 2024-03-02 11:23:08.016 - info: host.RasPi3 ip addresses: 192.168.2.30 2003:e0:9712:9a00:bee:e5c2:b6b8:6aad fe80::df32:ad2b:5f7d:3ca 2024-03-02 11:23:38.096 - error: host.RasPi3 No connection to databases possible, restart 2024-03-02 11:23:38.123 - info: host.RasPi3 iobroker _restart 2024-03-02 11:23:46.193 - info: host.RasPi3 iobroker.js-controller version 5.0.19 js-controller starting 2024-03-02 11:23:46.207 - info: host.RasPi3 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2024-03-02 11:23:46.210 - info: host.RasPi3 hostname: RasPi3, node: v18.19.1 2024-03-02 11:23:46.212 - info: host.RasPi3 ip addresses: 192.168.2.30 2003:e0:9712:9a00:bee:e5c2:b6b8:6aad fe80::df32:ad2b:5f7d:3ca 2024-03-02 11:24:16.265 - error: host.RasPi3 No connection to databases possible, restart 2024-03-02 11:24:16.280 - info: host.RasPi3 iobroker _restart 2024-03-02 11:24:24.292 - info: host.RasPi3 iobroker.js-controller version 5.0.19 js-controller starting 2024-03-02 11:24:24.302 - info: host.RasPi3 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2024-03-02 11:24:24.304 - info: host.RasPi3 hostname: RasPi3, node: v18.19.1 2024-03-02 11:24:24.305 - info: host.RasPi3 ip addresses: 192.168.2.30 2003:e0:9712:9a00:bee:e5c2:b6b8:6aad fe80::df32:ad2b:5f7d:3ca 2024-03-02 11:24:54.355 - error: host.RasPi3 No connection to databases possible, restart 2024-03-02 11:24:54.369 - info: host.RasPi3 iobroker _restart -
@marc-berg
mach da mal
iob setup customund prüfe/korrigiere die Parameterlaut Konfiguration im ersten Post hast du jsonl eingestellt
EDIT
SORRY, war Blödsinn@homoran
Bevor ich das mache: wären das die richtigen Parameter, oder muss ich bei Host auf states die des Master angeben?Type of objects DB [file, couch, redis], default [jsonl]: ENTER Host of objects DB(file), default[127.0.0.1]: <0.0.0.0> Port of objects DB(file), default[9001]: ENTER Type of states DB [file, redis], default [redis]: ENTER Host of states DB (file), default[0.0.0.0]: ENTER Port of states DB (file), default[6379]: ENTER Host name of this machine [RasPi3]: ENTER -
@lollo_c Dein slave soll doch auf die Redis des Masters zugreifen
(wieso überhaupt redis?)dann muss hier (beim Slave) auch die IP des Masters rein.
bei den objects mit JSONL bin ich mir da nicht sicher
Warum redis: weil irgendwann mal gesagt wurde, dann läuft der iobroker schneller. (Sorry, aber ich habe mein Wissen meist von YT). Egal: ich habe beim Slave kontrolliert:Current configuration: - Objects database: - Type: jsonl - Host/Unix Socket: 192.168.2.210 - Port: 9001 - States database: - Type: redis - Host/Unix Socket: 192.168.2.210 - Port: 6379 - Data Directory: ../../iobroker-data/ Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: Host / Unix Socket of objects DB(jsonl), default[192.168.2.210]: Port of objects DB(jsonl), default[9001]: Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [jsonl]: r Host / Unix Socket of states DB (redis), default[192.168.2.210]: Port of states DB (redis), default[6379]: Host name of this machine [RasPi3]: updating conf/iobroker.jsonSieht für mich erst einmal i.O. aus, oder?
ja, bei Raspberry v1/2 und ähnlichen.
und läuft's jetzt?
@homoran sagte in System mit Master/Slave neu aufsetzen:
und läuft's jetzt?
nein, leider nicht.
dann bitte nochmal auf dem Master in der redis.conf explizit die 0.0.0.0 freigeben (über bind)
wenn das auch nicht hilft, Master und slave neu starten (ggf. 2x im Wechsel) -
und läuft's jetzt?
nein, leider nicht.
wenn das auch nicht hilft, Master und slave neu starten (ggf. 2x im Wechsel)@homoran
Ich glaube, jetzt habe ich was falsch eingegeben. In der redis.config:bind 127.0.0.1 0.0.0.0Beim "sudo service redis-server restart" kommt Fehlermeldung
Job for redis-server.service failed because the control process exited with error code. See "systemctl status redis-server.service" and "journalctl -xeu redis-server.service" for details. -
Job for redis-server.service failed because the control process exited with error code. See "systemctl status redis-server.service" and "journalctl -xeu redis-server.service" for details.@lollo_c sagte in System mit Master/Slave neu aufsetzen:
Das geht so nicht. Wenn, dann musst du
bind 0.0.0.0eingeben. Aber wie oben bereits erwähnt, ist es das gleiche, als wenn du gar nichts konfigurierst. Und man hat ja schon gesehen, dass es funktionierte:
tcp 0 0 0.0.0.0:6379 0.0.0.0:* LISTEN 106 13311 699/redis-server *: -
Hast du
protected-mode noin der redis.conf eingestellt?
Hast du
Nein, steht auf YES
Hast du
DAS WAR ES! Vielen Dank, jetzt ist der Slave da.
Hast du
@lollo_c
Ich benötige doch noch einmal Hilfe. Master und Slave laufen nun. Im #tab-instances sind alle (bis auf die ws.0) Instanzen grün. Es werden auch Daten in die Objekte geschrieben. Wenn ich die Einstellungen der Instanzen auf dem Slave öffnen möchte, dann bleibt die Seite weiß und es erscheint eine Meldung[JsonConfig] Cannot read file: Not existsBei den Protokollen werden jede Menge Warnungen zu Instanzen vom Slave angezeigt.
Hast du
ist das neu(er)?
und deswegen jetzt 0.0.0.0 als default? -
@marc-berg
Ich hatte die redis.config gerade durchgeschaut und nur die o.g. Zeile gefunden.
