  4. [Gelöst] Keine Netzwerkverbindung zum iobroker mehr möglich
120 Beiträge 8 Kommentatoren 18.7k Aufrufe 6 Beobachtet
  • A Airframe75
    @wendy2702 @hormoran
    Hier der etrakt aus dem curl Befehl
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     21:11:36 up  1:35,  1 user,  load average: 0.00, 0.00, 0.00
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-02-25 21:11:36 CET
               Universal time: Sun 2024-02-25 20:11:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G         85M        3.5G        1.0M        188M        3.6G
    Swap:            99M          0B         99M
    Total:          3.9G         85M        3.6G
             3794 M total memory
               85 M used memory
              160 M active memory
               32 M inactive memory
             3520 M free memory
               15 M buffer memory
              172 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  6.4G   22G  23% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [sudo] password for iobroker:
    [Sun Feb 25 19:36:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FB:C3:CA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8f761cd6-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Feb 25 19:36:27 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Feb 25 19:36:27 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Feb 25 19:36:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.9G    /var/
    2.4G    /var/log
    801M    /var/log/journal/54548f5b193440069d487fa9f59dd13a
    288M    /var/cache
    Archived and active journals take up 800.4M in the file system.
    /opt/iobroker/backups:
    239M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    353M    /opt/iobroker/iobroker-data/
    237M    /opt/iobroker/iobroker-data/files
    75M     /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    43M     /opt/iobroker/iobroker-data/files/iot.admin
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/states.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** NodeJS-Installation ***
    diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Core adapters versions
    js-controller:
    admin:
    javascript:
    Adapters from github:   1
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:6 https://repos.influxdata.com/debian bullseye InRelease
    Reading package lists... Done
    Pending Updates: 39
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12181      536/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12192      536/sshd: /usr/sbin
    udp        0      0 0.0.0.0:60921           0.0.0.0:*                           108        14732      391/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14809      789/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14730      391/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          1692       789/dhcpcd
    udp6       0      0 :::46147                :::*                                108        14733      391/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14731      391/avahi-daemon: r
    Airframe75
    #74
    @hormoran
    Copy text starting here:
                            v.2023-10-10
             Icon name: computer
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     39
    Pending iob updates:    0
    diag.sh: line 486: nodejs: command not found
    Nodejs-Installation:
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs  and npm
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            3.8G         82M        3.2G        1.0M        467M        3.6G
    Swap:            99M          0B         99M
    Total:          3.9G         82M        3.3G
    Active iob-Instances:   0
    ioBroker Core:          js-controller
                            admin
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    === Mark text until here for copying ===
      @airframe75
      systemctl status iobroker
      sagt?
      Airframe75
      #75
      iobroker@iobroker:~ $ systemctl status iobroker
      ● iobroker.service
           Loaded: masked (Reason: Unit iobroker.service is masked.)
           Active: inactive (dead)
      • A Airframe75
        @hormoran
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm64
        Kernel:                 aarch64
        Userland:               arm64
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        Please check
        MEMORY:
        Swap:            99M          0B         99M
                                admin
        ioBroker Status:
        Objects:                0
        States:                 0
        wendy2702W Offline
        wendy2702W Offline
        #76
        @airframe75 im Summary steht drin was zu tun ist.
        • A Airframe75
          ● iobroker.service
          #77
          @airframe75
          sudo systemctl unmask iobroker.service
          iob nodejs-update
          sudo reboot
            @airframe75
            iob nodejs-update
            sudo reboot
            Airframe75
            #78
            Die erste Zeile ging, bei update ging es nicht mehr
            ● iobroker.service
            iobroker@iobroker:~ $ systemctl unmask iobroker.service
            ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
            Authentication is required to manage system service or unit files.
            Authenticating as: ,,, (iobroker)
            Password:
            ==== AUTHENTICATION COMPLETE ===
            ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
            Authentication is required to reload the systemd state.
            Password:
            • A Airframe75
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              iobroker
              /home/iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       3794 M total memory
                         85 M used memory
                        160 M active memory
                       3520 M free memory
                         15 M buffer memory
                        172 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              2.9G    /var/
              2.4G    /var/log
              288M    /var/cache
              USB-Devices by-id:
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              js-controller:
              admin:
              javascript:
              Adapter State
              Objects and States
              Objects:        0
              States:         0
              Pending Updates: 39
              HomoranH Offline
              HomoranH Offline
              #79
              @airframe75 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
              läuft da nix?
              ioBroker Status
              ist iobroker überhaupt installiert?
              wie hast du das gemacht?
              was hat daran 2 Wochen gedauert?
              A 2 Antworten Letzte Antwort
                läuft da nix?
                ioBroker Status
                Airframe75
                #80
                Bis vor zwei Monaten lief alles super.
                • A Airframe75
                  #81
                  @airframe75
                  iob nodejs-update
                  sudo reboot
                    läuft da nix?
                    ioBroker Status
                    Airframe75
                    #82
                    @homoran said in Keine Netzwerkverbindung zum iobroker mehr möglich:
                    Ja natürlich habe ich den dort installiert :-)
                    • A Airframe75
                      HomoranH Offline
                      HomoranH Offline
                      #83
                      wie hast du iobroker installiert?
                      was hastcdu vor Wochen geändert?
                      • A Airframe75
                        ● iobroker.service
                        Password:
                        Password:
                        wendy2702W Offline
                        wendy2702W Offline
                        #84
                        Zeigen!
                          Airframe75
                          #85
                          Ich habe gar nichts gemacht.
                          • A Airframe75
                            HomoranH Offline
                            HomoranH Offline
                            #86
                            @airframe75 bleibt die Frage
                            @homoran sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                            • wendy2702W wendy2702
                              Zeigen!
                              Airframe75
                              #87
                              @wendy2702
                              ● iobroker.service
                              Password:
                              Password:
                              iobroker@iobroker:~ $ iob nodejs-update
                              iobroker@iobroker:~ $ sudo reboot```
                              code_text
                              • A Airframe75
                                @wendy2702
                                ● iobroker.service
                                Password:
                                Password:
                                code_text
                                HomoranH Offline
                                HomoranH Offline
                                #88
                                freedesktop
                                was ist denn das?
                                  Airframe75
                                  #89
                                  Ich habe den ioBroker masterkurs von Matthias Kleine besucht, mir die Videos angeschaut und das nachgemacht.
                                  • A Airframe75
                                    @wendy2702
                                    ● iobroker.service
                                    Password:
                                    Password:
                                    code_text
                                    #90
                                    ist falsch, da gehört ein SUDO davor. Hab ich aber glaube ich jetzt 2x geschrieben...
                                    Also ein drittes mal...
                                      freedesktop
                                      was ist denn das?
                                      Airframe75
                                      #91
                                      was ist denn das?
                                      Wo steht das denn (freedesktop)
                                        Airframe75
                                        #92
                                        Jetzt habe ich es. Sorry für die Blindheit
                                        iobroker@iobroker:~ $ sudo systemctl unmask iobroker.service
                                        Connection to iobroker closed by remote host.
                                        Connection to iobroker closed.
                                        PS C:\Users\user>
                                        • A Airframe75
                                          was ist denn das?
                                          CodierknechtC Offline
                                          Codierknecht
                                          #93
                                          In Deiner Ausgabe
                                          HmIP|ZigBee|Tasmota|Unifi
                                          Zabbix Certified Specialist
