  4. [Gelöst] Keine Netzwerkverbindung zum iobroker mehr möglich
120 Beiträge 8 Kommentatoren 18.7k Aufrufe 6 Beobachtet
  • A Airframe75
    iobroker@iobroker:~ $ systemctl status iobroker
    ● iobroker.service
         Loaded: masked (Reason: Unit iobroker.service is masked.)
         Active: inactive (dead)
    #77
    @airframe75
    sudo systemctl unmask iobroker.service
    iob nodejs-update
    sudo reboot
      @airframe75
      iob nodejs-update
      sudo reboot
      Airframe75
      #78
      Die erste Zeile ging, bei update ging es nicht mehr
      ● iobroker.service
      iobroker@iobroker:~ $ systemctl unmask iobroker.service
      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
      Authentication is required to manage system service or unit files.
      Authenticating as: ,,, (iobroker)
      Password:
      ==== AUTHENTICATION COMPLETE ===
      ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
      Authentication is required to reload the systemd state.
      Password:
      • A Airframe75
        @wendy2702 @hormoran
        Hier der etrakt aus dem curl Befehl
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         21:11:36 up  1:35,  1 user,  load average: 0.00, 0.00, 0.00
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2024-02-25 21:11:36 CET
                   Universal time: Sun 2024-02-25 20:11:36 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        iobroker
        /home/iobroker
        iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            3.8G         85M        3.5G        1.0M        188M        3.6G
        Swap:            99M          0B         99M
        Total:          3.9G         85M        3.6G
                 3794 M total memory
                   85 M used memory
                  160 M active memory
                   32 M inactive memory
                 3520 M free memory
                   15 M buffer memory
                  172 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
        * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
        1 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  6.4G   22G  23% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [sudo] password for iobroker:
        [Sun Feb 25 19:36:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FB:C3:CA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8f761cd6-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sun Feb 25 19:36:27 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Feb 25 19:36:27 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Feb 25 19:36:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.9G    /var/
        2.4G    /var/log
        801M    /var/log/journal/54548f5b193440069d487fa9f59dd13a
        288M    /var/cache
        Archived and active journals take up 800.4M in the file system.
        /opt/iobroker/backups:
        239M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        353M    /opt/iobroker/iobroker-data/
        237M    /opt/iobroker/iobroker-data/files
        75M     /opt/iobroker/iobroker-data/backup-objects
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        43M     /opt/iobroker/iobroker-data/files/iot.admin
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M     /opt/iobroker/iobroker-data/states.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        18M     /opt/iobroker/iobroker-data/objects.jsonl
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
        *** NodeJS-Installation ***
        diag.sh: line 277: nodejs: command not found
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        diag.sh: line 288: nodejs: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Core adapters versions
        js-controller:
        admin:
        javascript:
        Adapters from github:   1
        Adapter State
        ioBroker-Repositories
        Installed ioBroker-Instances
        Objects and States
        Objects:        0
        States:         0
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:6 https://repos.influxdata.com/debian bullseye InRelease
        Reading package lists... Done
        Pending Updates: 39
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12181      536/sshd: /usr/sbin
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12192      536/sshd: /usr/sbin
        udp        0      0 0.0.0.0:60921           0.0.0.0:*                           108        14732      391/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14809      789/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14730      391/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          1692       789/dhcpcd
        udp6       0      0 :::46147                :::*                                108        14733      391/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        14731      391/avahi-daemon: r
        HomoranH Offline
        HomoranH Offline
        #79
        @airframe75 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
        läuft da nix?
        ioBroker Status
        ist iobroker überhaupt installiert?
        wie hast du das gemacht?
        was hat daran 2 Wochen gedauert?
        A 2 Antworten Letzte Antwort
          läuft da nix?
          ioBroker Status
          Airframe75
          #80
          Bis vor zwei Monaten lief alles super.
          • A Airframe75
            #81
            @airframe75
            iob nodejs-update
            sudo reboot
              läuft da nix?
              ioBroker Status
              Airframe75
              #82
              @homoran said in Keine Netzwerkverbindung zum iobroker mehr möglich:
              Ja natürlich habe ich den dort installiert :-)
              • A Airframe75
                HomoranH Offline
                HomoranH Offline
                #83
                wie hast du iobroker installiert?
                was hastcdu vor Wochen geändert?
                • A Airframe75
                  ● iobroker.service
                  Password:
                  Password:
                  wendy2702W Offline
                  wendy2702W Offline
                  #84
                  Zeigen!
                    Airframe75
                    #85
                    Ich habe gar nichts gemacht.
                    • A Airframe75
                      HomoranH Offline
                      HomoranH Offline
                      #86
                      @airframe75 bleibt die Frage
                      @homoran sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                      • wendy2702W wendy2702
                        Zeigen!
                        Airframe75
                        #87
                        @wendy2702
                        ● iobroker.service
                        Password:
                        Password:
                        iobroker@iobroker:~ $ iob nodejs-update
                        iobroker@iobroker:~ $ sudo reboot```
                        code_text
                        • A Airframe75
                          @wendy2702
                          ● iobroker.service
                          Password:
                          Password:
                          code_text
                          HomoranH Offline
                          HomoranH Offline
                          #88
                          freedesktop
                          was ist denn das?
                            Airframe75
                            #89
                            Ich habe den ioBroker masterkurs von Matthias Kleine besucht, mir die Videos angeschaut und das nachgemacht.
                            • A Airframe75
                              @wendy2702
                              ● iobroker.service
                              Password:
                              Password:
                              code_text
                              #90
                              ist falsch, da gehört ein SUDO davor. Hab ich aber glaube ich jetzt 2x geschrieben...
                              Also ein drittes mal...
                                freedesktop
                                was ist denn das?
                                Airframe75
                                #91
                                was ist denn das?
                                Wo steht das denn (freedesktop)
                                  Airframe75
                                  #92
                                  Jetzt habe ich es. Sorry für die Blindheit
                                  iobroker@iobroker:~ $ sudo systemctl unmask iobroker.service
                                  Connection to iobroker closed by remote host.
                                  Connection to iobroker closed.
                                  PS C:\Users\user>
                                  • A Airframe75
                                    was ist denn das?
                                    CodierknechtC Offline
                                    Codierknecht
                                    #93
                                    In Deiner Ausgabe
                                    HmIP|ZigBee|Tasmota|Unifi
                                    Zabbix Certified Specialist
                                    • CodierknechtC Codierknecht
                                      In Deiner Ausgabe
                                      Airframe75
                                      #94
                                      @codierknecht
                                      Ich habe nur den Curl link von @hormoran benutzt
                                      • HomoranH Offline
                                        HomoranH Offline
                                        #95
                                        @Airframe75
                                        Bitte beantworte die Frage wie du iobroker installiert hast!
                                        wenn du iob dermaßen tiefergelegt hast, dass wir mit unserem Wagenheber nicht mehr drunterkommen, müssen wir wenigstens wissen, wo wir angreifen könnten!
                                          @Airframe75
                                          Airframe75
                                          schrieb am zuletzt editiert von Airframe75
                                          #96
                                          Ich habe mir die Videoanleitung angeschaut und dann das nachgemacht. Aber was für genaue Befehle das waren habe ich mir nicht aufgeschrieben
                                          Anfangs den Resberry PI über den Installer installieren.
                                          Auf jedenfall waren diese Befehle dabei:
                                          sudo apt update
                                          sudo apt full-upgrade
                                          sudo apt install curl
                                          curl -sLf https://iobroker.net/install.sh | bash -
                                          Beantwortet das ungefähr deine Frage?
