  4. Backitup Probleme mit mount NAS
51 Beiträge 6 Kommentatoren 2.5k Aufrufe 4 Beobachtet
    Snopy_16
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     17:08:52 up  1:55,  3 users,  load average: 0.89, 0.98, 1.10
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-02-17 17:08:52 CET
               Universal time: Sat 2024-02-17 16:08:52 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        3.1G        2.3G         34M        2.3G        4.5G
    Swap:            99M          0B         99M
    Total:          7.9G        3.1G        2.4G
             7811 M total memory
             3146 M used memory
             4170 M active memory
              962 M inactive memory
             2330 M free memory
              156 M buffer memory
             2178 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                          Type      Size  Used Avail Use% Mounted on
    /dev/root                           ext4      110G   14G   90G  14% /
    devtmpfs                            devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs                               tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                               tmpfs     1.6G  9.3M  1.6G   1% /run
    tmpfs                               tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1                           vfat      253M   31M  222M  13% /boot
    tmpfs                               tmpfs     782M   20K  782M   1% /run/user/1000
    //192.168.178.10/Sicherung/iobroker cifs      1.9T  509G  1.4T  28% /opt/iobroker/backups
    [Sat Feb 17 15:13:07 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:59:9B:B3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=96bb02d6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Feb 17 15:13:09 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Feb 17 15:13:09 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Feb 17 15:13:11 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET                  SOURCE                              FSTYPE OPTIONS
    /                       /dev/sda2                           ext4   rw,noatime,stripe=8191
    |-/boot                 /dev/sda1                           vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/opt/iobroker/backups //192.168.178.10/Sicherung/iobroker cifs   rw,relatime,vers=2.1,cache=strict,username=admin,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.10,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
    /var:
    2.8G    /var/
    1.5G    /var/lib
    987M    /var/cache
    975M    /var/cache/apt
    873M    /var/cache/apt/archives
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    402M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.0G    /opt/iobroker/iobroker-data/
    1.5G    /opt/iobroker/iobroker-data/history
    406M    /opt/iobroker/iobroker-data/files
    100M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    21M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.605c1bc5.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   2
    Adapter State
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
    + system.adapter.eventlist.0              : eventlist             : raspberrypi                              -  enabled
    + system.adapter.eventlist.1              : eventlist             : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
    + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
    + system.adapter.pushsafer.0              : pushsafer             : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
    + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 9090, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
    + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.9.6   , installed 2.9.6
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
    Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.2  [Updatable]
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "snmp"         : 3.1.0    , installed 3.1.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        10824
    States:         9011
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://giteduberger.fr rpimonitor/ InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:8 https://repos.influxdata.com/debian bullseye InRelease
    Hit:9 https://packages.grafana.com/oss/deb stable InRelease
    Hit:10 https://dl.ui.com/unifi/debian unifi-7.4 InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15011      565/cupsd
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15723      700/vncserver-x11-c
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        15498      611/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       101899     19950/io.sonoff.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       101382     19641/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       101389     19641/iobroker.js-c
    tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      118        22670      2799/bin/mongod
    tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      117        15111      584/mongod
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          16779      1252/perl
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13052      705/sshd: /usr/sbin
    tcp6       0      0 :::8086                 :::*                    LISTEN      119        15991      591/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       99627      19665/io.admin.0
    tcp6       0      0 :::8080                 :::*                    LISTEN      118        19310      676/java
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       104961     21178/io.web.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      120        16282      1410/grafana
    tcp6       0      0 :::6789                 :::*                    LISTEN      118        22157      676/java
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15010      565/cupsd
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          15722      700/vncserver-x11-c
    tcp6       0      0 :::1883                 :::*                    LISTEN      116        15499      611/mosquitto
    tcp6       0      0 :::9090                 :::*                    LISTEN      1001       100345     20566/io.socketio.0
    tcp6       0      0 :::8843                 :::*                    LISTEN      118        21228      676/java
    tcp6       0      0 :::8880                 :::*                    LISTEN      118        19311      676/java
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13054      705/sshd: /usr/sbin
    tcp6       0      0 :::8443                 :::*                    LISTEN      118        20002      676/java
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       99103      19977/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       99104      19977/io.tuya.0
    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          14808      -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16403      521/dhcpcd
    udp        0      0 0.0.0.0:53424           0.0.0.0:*                           1001       104855     21114/io.upnp.0
    udp        0      0 0.0.0.0:37188           0.0.0.0:*                           1001       104854     21114/io.upnp.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15080      1004/cups-browsed
    udp        0      0 0.0.0.0:41761           0.0.0.0:*                           108        11245      409/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11243      409/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       99938      19930/io.shelly.0
    udp        0      0 0.0.0.0:55061           0.0.0.0:*                           1001       104611     20543/io.snmp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       105001     21114/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       105000     21114/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       104999     21114/io.upnp.0
    udp        0      0 0.0.0.0:38900           0.0.0.0:*                           1001       104612     20543/io.snmp.0
    udp        0      0 0.0.0.0:55616           0.0.0.0:*                           1001       104856     21114/io.upnp.0
    udp6       0      0 :::51820                :::*                                0          14809      -
    udp6       0      0 :::51853                :::*                                108        11246      409/avahi-daemon: r
    udp6       0      0 10.110.114.1:56456      :::*                                118        22225      676/java
    udp6       0      0 192.168.178.11:56694    :::*                                118        22233      676/java
    udp6       0      0 192.168.178.211:60810   :::*                                118        22232      676/java
    udp6       0      0 :::3478                 :::*                                118        23068      676/java
    udp6       0      0 :::546                  :::*                                0          13152      521/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        11244      409/avahi-daemon: r
    udp6       0      0 :::5514                 :::*                                118        22221      676/java
    udp6       0      0 :::10001                :::*                                118        22234      676/java
    2024-02-17 17:02:00.276  - info: javascript.0 (19740) script.js.Mein_Ordner.Fronius0: Solarweb Token erstellt
    2024-02-17 17:09:53.317  - info: admin.0 (19665) ==> Connected system.user.admin from ::ffff:192.168.178.33
    2024-02-17 17:09:53.422  - info: admin.0 (19665) ==> Connected system.user.admin from ::ffff:192.168.178.33
    Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
    LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
    iobroker auf Proxmox VM
    Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
    FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
    • Thomas BraunT Online
      @snopy_16
      könnte da etwas im Argen liegen?
      Ja, da ist irgendwas bei der Rechteverwaltung krumm. Der User 'iobroker' kann nicht mehr via sudo Dinge ausführen. Keine Ahnung wo es genau klemmt.
      Oder hat etwa das update node.js von v18.19.0 auf v18.19.1 damit etwas zu tun?
      Nein.
        @snopy_16
        Nein.
        Snopy_16
        @thomas-braun sagte in Backitup Probleme mit mount NAS:
        😧 Das ist schlimm, da ich jetzt absolut nicht mehr weiter weiss.
        Kann man dem iobroker nicht mehr die Rechte geben?
        Gibt es eine Möglichkeit, das wieder zurecht zurücken? (OHNE Neuinstallation)
        • S Snopy_16
          @snopy_16
          ls -lah /home/pi/temp_sudo_file
          getfacl /home/pi/temp_sudo_file
          sagt?
            Snopy_16
            pi@raspberrypi:~ $ ls -lah /home/pi/temp_sudo_file
            ls: Zugriff auf '/home/pi/temp_sudo_file' nicht möglich: Datei oder Verzeichnis nicht gefunden
            pi@raspberrypi:~ $ getfacl /home/pi/temp_sudo_file
            getfacl: /home/pi/temp_sudo_file: Datei oder Verzeichnis nicht gefunden
            Die Datei gibts nicht
            • S Snopy_16
              Snopy_16
              @Thomas-Braun @Homoran
              Noch wer eine Idee?
              • S Snopy_16
                Noch wer eine Idee?
                @snopy_16
                Installier da neu ein RaspberryOS 12.
                Dist-upgrade von 11 auf 12 funktioniert eh nicht.
                  @snopy_16
                  Snopy_16
                  Das will ich vermeiden. (Hab ja einiges drauf auf dem derzeitigen Raspberry 4)
                  Zumindest bis ich vielleicht mal umsteige auf einen Raspi 5.
                  Bookworm erscheint mir noch etwas suspect (Einrichten einer statischen IP,...)
                  Weiss auch nicht, ob dann alles in Ordnung ist, wenn ich ein Backup von iobroker einspiele.
                  • S Snopy_16
                    @snopy_16 sagte in Backitup Probleme mit mount NAS:
                    Kannst du eh nicht vermeiden.
                    Was soll da sein? Wird halt jetzt ggfls. anders gemacht, das ist aber auch schon alles.
                      Snopy_16
                      Nun, ich bin der Sache etwas näher gekommen.
                      Ich habe eine 1:1 Kopie der SSD-Platte vom 12.2.24.
                      Mit der habe ich das system gestartet und gleich mal ein Backup mit dem Backitup Adapter gemacht. Funktionierte wie gewohnt.
                      Anschließend machte ich ein
                      iob fix
                      was war die Folge?
                          Checking ioBroker user and directory permissions (2/5)
                      main: Zeile 702: /home/pi/temp_sudo_file: Keine Berechtigung
                      This system does not support setting default permissions.
                      Do not use npm to manually install adapters unless you know what you are doing!
                      Dann machte ich nochmal ein Backup machen und sofort kam die ursprüngliche Meldung wie auf Post #1 beschrieben und das NAS wurde nicht gemountet.
                      Also liegt das ganze an IOB FIX.
                      Mit dem sollte eigentlich was repariert werden und nicht ein Problem erzeugt.
                      Was steht da im Code auf Seite 702?
                      Ein IOB FIX kann ich wohl nicht mehr rückgängig machen.
                      Ich weiss leider nicht, wer in dieser Sache den nötigen Einblick hat, aber es muss doch einen Grund dafür geben.
                      • S Snopy_16
                        iob fix
                        was war die Folge?
                        wieso???
                        wenn du
                        dabei einen vorhandenen Fehler klonst, an dem iob fix sich die Zähne ausbeisst, weil du z.b. vorher mit der Verwendung von root Rechte so verbogen hattest, dass selbst der Fixer das nicht mehr richten kann, dann ist der Fixer nicht der Täter sonden das Opfer!
                        Deswegen klont man keine ganzen Platten sondern installiert neu.
                        • S Snopy_16
                          iob fix
                          was war die Folge?
                          Nix. Das fix-Skript hat nur 480 Zeilen.
                          https://github.com/ioBroker/ioBroker/blob/master/fix_installation.sh
                          Ich hab jetzt gerade mal spaßeshalber 2x hintereinander den iob fix auf meinem System durchgeführt. Kein Fehler bei mir.
                            wieso???
                            wenn du
                            Snopy_16
                            Also doch sehr komplex, ich versteh einfach nicht:
                            Wieso sucht der Fixer in Zeile 702 nach "/home/pi/temp_sudo_file", das nicht vorhanden ist und schreibt dann "keine Berechtigung".
                            Kann man diese file nicht nachinstallieren?
                            Thomas BraunT HomoranH 4 Antworten Letzte Antwort
                            • S Snopy_16
                              Nein, das ist nur ein temporäres File, das wird vom fixer wieder gelöscht.
                              • S Snopy_16
                                @snopy_16
                                groups
                                als der user, der auch den fixer aufruft sagt? Wohl der 'pi' bei dir.
                                • S Snopy_16
                                  mal halblang. Diese Meldung ist nicht normal!
                                  und der Rest anscheinend fehlinterpretiert. ich bin kein Entwickler und Programmierer, aber wie kommst fu darauf, dass
                                  da steht
                                  Keine Berechtigung
                                  heisst: selbst der Fixer hat nicht das Recht, die verbogenen Rechte wieder herzustellen!
                                  irgendwas an dem Grundsystem wurde so verstellt, dass
                                  • S Snopy_16
                                    @snopy_16
                                    sudo cat /etc/sudoers.d/iobroker
                                    S 2 Antworten Letzte Antwort
                                      @snopy_16
                                      Snopy_16
                                      Ich meinte das nicht so, ist einfach für MICH zu komplex.
                                      Wusste auch nicht das die Datei nur temporär angelegt wird und wieder gelöscht wird, darum hab ich sie auch nicht gefunden.
                                      Ich will halt alles verstehen und mache mir dazu Gedanken, wenn auch oftmals falsche.
                                      bin aber sehr froh, dass ich bei Euch Hilfe finde.
                                        @snopy_16
                                        Snopy_16
                                        schrieb am zuletzt editiert von Snopy_16
                                        pi@raspberrypi:~ $ sudo cat /etc/sudoers.d/iobroker
                                        cat: /etc/sudoers.d/iobroker: Datei oder Verzeichnis nicht gefunden
                                        Habe dann auf meinem Ersatzsystem ein
                                        sudo iob fix
                                        gemacht, dabei wurde dann die datei angelegt
                                        Seitdem funktioniert auch wieder das Backup auf das NAS 👍
                                        auch nach einem reboot.
                                        Hier nun die Ausgabe vom angelegtem
                                        iobroker ALL=(ALL) ALL
                                        iobroker ALL=(ALL) NOPASSWD: /usr/sbin/shutdown
                                        iobroker ALL=(ALL) NOPASSWD: /usr/sbin/halt
                                        iobroker ALL=(ALL) NOPASSWD: /usr/sbin/poweroff
                                        iobroker ALL=(ALL) NOPASSWD: /usr/sbin/reboot
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/systemctl start
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/systemctl stop
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/mount
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/umount
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/systemd-run
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/apt-get
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/dpkg
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/make
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/ping
                                        iobroker ALL=(ALL) NOPASSWD: /usr/sbin/setcap
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/vcgencmd
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/cat
                                        iobroker ALL=(ALL) NOPASSWD: /usr/bin/df
                                        iobroker ALL=(ALL) NOPASSWD: /usr/sbin/ldconfig
                                        ALL ALL=NOPASSWD: /usr/bin/systemctl start iobroker
                                        ALL ALL=NOPASSWD: /usr/bin/systemctl stop iobroker
                                        ALL ALL=NOPASSWD: /usr/bin/systemctl restart iobroker
                                        ALL ALL=(iobroker) NOPASSWD: /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js *
                                        Ich weiss zwar nicht ob das jetzt in Ordnung ist, aber es funktioniert
                                        Mit einem erneutem IOB-FIX ohne sudo kamen wieder die selben Probleme.
                                          sudo iob fix
                                          gemacht,
                                          niemals nie nicht iobroker Befehle mit sudo einleiten!!!
                                          das führt zu genau so etwas
