  4. Vis2 ab 09.01.2024 im stable
422 Beiträge 79 Kommentatoren 167.5k Aufrufe 85 Beobachtet
  • SantosS Santos
    pi@raspberrypi:~ $ iob diag
    iobroker [command]
    Commands:
     iobroker setup                                               Setup ioBroker
     iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
     iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
     iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
     iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
     iobroker info                                                Shows the host info
     iobroker logs [<adapter>]                                    Monitor log
     iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
     iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
     iobroker rebuild [<module>]                                  Rebuild all native modules or path
     iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
     iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
     iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
     iobroker update [<repositoryUrl>]                            Update repository and list adapters
     iobroker upgrade                                             Upgrade management
     iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
     iobroker object                                              Object management  [aliases: o]
     iobroker state                                               State management  [aliases: s]
     iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
     iobroker list <type> [<filter>]                              List all entries, like objects
     iobroker chmod <mode> <file>                                 Change file rights
     iobroker chown <user> <group> <file>                         Change file ownership
     iobroker touch <file>                                        Touch file
     iobroker rm <file>                                           Remove file
     iobroker file                                                File management
     iobroker user                                                User commands
     iobroker group                                               group management
     iobroker host <hostname>                                     Set host to given hostname
     iobroker set <adapter>.<instance>                            Change settings of adapter config
     iobroker license <license.file or license.text>              Update license by given file
     iobroker cert                                                Certificate management
     iobroker clean <yes>                                         Clears all objects and states
     iobroker backup                                              Create backup
     iobroker restore <backup name or path>                       Restore a specified backup
     iobroker validate <backup name or path>                      Validate a specified backup
     iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
     iobroker repo [<name>]                                       Show repo information
     iobroker uuid                                                Show uuid of the installation  [aliases: id]
     iobroker unsetup                                             Reset license, installation secret and language
     iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
     iobroker multihost                                           Multihost management
     iobroker compact                                             compact group management
     iobroker plugin                                              Plugin management
     iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
     --help  Show help  [boolean]
    #167
    @santos
    Dann fangen wir ganz unten an...
    iob stop
    iob fix
    iob start
    Und dann nochmal
    iob diag
    • SantosS Santos
      iobroker [command]
      Commands:
      Options:
      HomoranH Offline
      HomoranH Offline
      #168
      @santos ja, so alt, dass es die Befehle nicht kennt.
      Das gibt jetzt Arbeit
      • SantosS Offline
        SantosS Offline
        Santos
        #169
        Ich sehe, wie alt die ganze Kiste ist...
                               v.2023-10-10
          Static hostname: raspberrypi
                Icon name: computer
         Operating System: Raspbian GNU/Linux 10 (buster)
                   Kernel: Linux 5.10.103-v7l+
             Architecture: arm
        Kernel:                 armv7l
        Userland:               armhf
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            multi-user.target
        Pending OS-Updates:
        Pending iob updates:    5
        Nodejs-Installation:    /usr/bin/nodejs         v17.6.0
                               /usr/bin/node           v17.6.0
                               /usr/bin/npm            8.5.1
                               /usr/bin/npx            8.5.1
                               /usr/bin/corepack       0.10.0
        Recommended versions are nodejs  and npm
        MEMORY:
        Mem:           7.9G        1.2G        4.7G        395M        2.1G        6.3G
        Swap:           99M          0B         99M
        Total:         8.0G        1.2G        4.8G
        Active iob-Instances:   19
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.18
                               admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                7577
        States:                 9682
        Size of iob-Database:
        12M     /opt/iobroker/iobroker-data/objects.jsonl
        8.5M    /opt/iobroker/iobroker-data/objects.json.migrated
        8.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        3.4M    /opt/iobroker/iobroker-data/states.jsonl
        2.1M    /opt/iobroker/iobroker-data/states.json.migrated
        2.1M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        • SantosS Santos
                                 v.2023-10-10
                  Icon name: computer
               Architecture: arm
          Kernel:                 armv7l
          Userland:               armhf
          User-ID:                1000
          X-Server:               false
          Pending OS-Updates:
                                 /usr/bin/npm            8.5.1
                                 /usr/bin/npx            8.5.1
          MEMORY:
          Swap:           99M          0B         99M
                                 admin                   6.12.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                7577
          States:                 9682
          HomoranH Offline
          HomoranH Offline
          #170
          @santos bitte die Langfassung
          SantosS 1 Antwort Letzte Antwort
            SantosS Offline
            SantosS Offline
            Santos
            #171
            @homoran sagte in Vis2 ab morgen im stable:
            Es läuft. Vermutlich schickt ihr mich gleich die nodejs, npm und js-controller zu updaten 😲
            SantosS Thomas BraunT HomoranH 3 Antworten Letzte Antwort
            • SantosS Santos
                                     v.2023-10-10
                      Icon name: computer
                   Architecture: arm
              Kernel:                 armv7l
              Userland:               armhf
              User-ID:                1000
              X-Server:               false
              Pending OS-Updates:
                                     /usr/bin/npm            8.5.1
                                     /usr/bin/npx            8.5.1
              MEMORY:
              Swap:           99M          0B         99M
                                     admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                7577
              States:                 9682
              #172
              @santos sagte in Vis2 ab morgen im stable:
              Ist tot.
              Installier da NEU! ein Raspberry OS 12 in der 64Bit-Lite-Version.
              iob nodejs-update
              bringt die Basis auf Stand.
              Dann die 5 iob-Adapter aktualisieren, als letztes den js-controller:
              iob update
              iob upgrade all
              iob stop
              iob upgrade self
              iob start
              Und dann sollte auch vis-2 installierbar sein.
              Davon dann ein Backup erstellen und zeitnah auf ein frisches System umziehen.
              • SantosS Santos
                SantosS Offline
                SantosS Offline
                Santos
                #173
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Model           : Raspberry Pi 4 Model B Rev 1.4
                Docker          : false
                Virtualization  : none
                Kernel          : armv7l
                Userland        : armhf
                Systemuptime and Load:
                 21:35:31 up 46 days, 59 min,  2 users,  load average: 0.96, 1.29, 1.37
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Fri 2024-02-02 21:35:31 CET
                           Universal time: Fri 2024-02-02 20:35:31 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           7.9G        1.2G        4.6G        395M        2.1G        6.3G
                Swap:           99M          0B         99M
                Total:         8.0G        1.2G        4.7G
                         7898 M total memory
                         1207 M used memory
                          869 M active memory
                         2182 M inactive memory
                         4617 M free memory
                          233 M buffer memory
                         1839 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                0 loaded units listed. Pass --all to see loaded but inactive units, too.
                To show all installed unit files use 'systemctl list-unit-files'.
                *** FILESYSTEM ***
                /dev/root      ext4       59G  8.1G   48G  15% /
                devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs          tmpfs     3.9G  396M  3.5G  11% /run
                tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                [Mon Dec 18 20:35:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:E2:25:2C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=848b4126-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                [Mon Dec 18 20:35:50 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                [Mon Dec 18 20:35:50 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Mon Dec 18 20:35:52 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                TARGET        SOURCE         FSTYPE OPTIONS
                /             /dev/mmcblk0p2 ext4   rw,noatime
                |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                515M    /var/
                193M    /var/cache
                181M    /var/cache/apt
                125M    /var/lib
                122M    /var/cache/apt/archives
                Archived and active journals take up 394.7M in the file system.
                /opt/iobroker/backups:
                17M     /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                1.1G    /opt/iobroker/iobroker-data/
                540M    /opt/iobroker/iobroker-data/files
                385M    /opt/iobroker/iobroker-data/history
                138M    /opt/iobroker/iobroker-data/files/vis-2
                124M    /opt/iobroker/iobroker-data/backup-objects
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e642d05b.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                *** NodeJS-Installation ***
                /usr/bin/npm            8.5.1
                /usr/bin/npx            8.5.1
                nodejs:
                  Installed: 17.6.0-deb-1nodesource1
                  Candidate: 17.6.0-deb-1nodesource1
                  Version table:
                 *** 17.6.0-deb-1nodesource1 100
                     14.21.3-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                     10.24.0~dfsg-1~deb10u3 500
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  4.0.18
                admin:          6.12.0
                javascript:     7.1.6
                Adapters from github:   0
                Adapter State
                  system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
                  system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                + system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 192.168.1.32
                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
                + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                  system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              - disabled
                + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
                + instance is alive
                ioBroker-Repositories
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.13.15  , installed 6.12.0 [Updatable]
                Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
                Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                Adapter    "fullybrowser" : 3.0.9    , installed 2.1.2  [Updatable]
                Adapter    "ical"         : 1.13.3   , installed 1.13.3
                Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                Adapter    "info"         : 2.0.0    , installed 2.0.0
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Controller "js-controller": 5.0.17   , installed 4.0.18 [Updatable]
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                Adapter    "reolink"      : 1.0.3    , installed 1.0.3
                Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
                Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                Adapter    "vis"          : 1.5.4    , installed 1.5.4
                Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
                Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                Adapter    "web"          : 6.2.3    , installed 6.2.3
                Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                Adapter    "worx"         : 2.3.4    , installed 2.3.4
                Adapter    "ws"           : 2.5.10   , installed 2.5.10
                Adapter    "zigbee"       : 1.10.1   , installed 1.8.24 [Updatable]
                Objects and States
                Objects:        7577
                States:         9681
                Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                Get:3 https://deb.nodesource.com/node_14.x buster InRelease [4584 B]
                Get:4 https://pkgs.tailscale.com/stable/raspbian buster InRelease
                Fetched 11.1 kB in 6s (1945 B/s)
                Reading package lists...
                E: Broken packages
                Pending Updates:
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       54870218   6832/io.jarvis.0
                tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          16284      522/dnsmasq
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16312      537/sshd
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          53797492   9084/cupsd
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       54865841   6654/io.sonoff.0
                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       54868268   6606/io.mqtt.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       54863717   6217/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       54863710   6217/iobroker.js-co
                tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          16961      510/vncserver-x11-c
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54862302   6237/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       54866932   6824/io.web.0
                tcp6       0      0 :::53                   :::*                    LISTEN      0          16286      522/dnsmasq
                tcp6       0      0 :::22                   :::*                    LISTEN      0          16314      537/sshd
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          53797491   9084/cupsd
                tcp6       0      0 :::5900                 :::*                    LISTEN      0          16960      510/vncserver-x11-c
                udp        0      0 0.0.0.0:59828           0.0.0.0:*                           108        15850      403/avahi-daemon: r
                udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          16283      522/dnsmasq
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18815      457/dhcpcd
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          53796127   9086/cups-browsed
                udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          30663282   639/tailscaled
                udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       54867124   6527/io.mihome.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15848      403/avahi-daemon: r
                udp6       0      0 :::40928                :::*                                108        15851      403/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          21396      457/dhcpcd
                udp6       0      0 :::53                   :::*                                0          16285      522/dnsmasq
                udp6       0      0 :::41641                :::*                                0          30663281   639/tailscaled
                udp6       0      0 :::5353                 :::*                                108        15849      403/avahi-daemon: r
                2024-02-02 21:29:02.192  - info: sonoff.0 (6654) Client [Sonoff-Rollo-K1] connected with secret 1706905742191_7543
                2024-02-02 21:29:02.202  - info: sonoff.0 (6654) Client [Sonoff-Rollo-K2] connected with secret 1706905742201_9385
                2024-02-02 21:29:02.468  - info: sonoff.0 (6654) Client [Sonoff-Gastherme] connected with secret 1706905742467_1880
                2024-02-02 21:29:02.708  - info: sonoff.0 (6654) Client [Sonoff-Touch-Lara] connected with secret 1706905742707_7343
                2024-02-02 21:29:02.716  - info: sonoff.0 (6654) Client [Sonoff-Heizung-PV] connected with secret 1706905742710_9766
                2024-02-02 21:29:43.287  - info: alexa2.0 (6404) Unknown Device, but enabling commands, Try it and report back if commands work.
                2024-02-02 21:29:43.288  - info: alexa2.0 (6404) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                2024-02-02 21:29:43.288  - info: alexa2.0 (6404)     Device-type:A1CFVS523BQYZ7 - Oleg's Mi Watch (Mi Watch) (SLEEP,SUPPORTS_LOCALE_SWITCH,TIMERS_AND_ALARMS,DEEZER,VOLUME_SETTING,KINDLE_BOOKS,SET_LOCALE,AMAZON_MUSIC,SIRIUSXM,REMINDERS,DEREGISTER_DEVICE,CHANGE_NAME,AUDIBLE,I_HEART_RADIO,SUPPORTS_LOCALE,ADAPTIVE_LISTENING,TIDAL,ASCENDING_ALARM_VOLUME,DIALOG_INTERFACE_VERSION,PERSISTENT_CONNECTION,MICROPHONE,SPEECH_RECOGNIZER_USS,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,CUSTOM_ALARM_TONE,TOUCH_INITIATED,DREAM_TRAINING,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,TUNE_IN,MUSIC_SKILL,MULTI_WAKEWORDS_SUPPORTED,GOLDFISH,SET_TIME_ZONE,APPLE_MUSIC,EARCONS,AUDIO_PLAYER)
                2024-02-02 21:29:57.566  - info: alexa2.0 (6404) Using cached smart home devices list from Fri Feb 02 2024 21:12:52 GMT+0100 (Mitteleuropäische Normalzeit)
                2024-02-02 21:29:59.018  - info: alexa2.0 (6404) No smart home devices to query
                2024-02-02 21:29:59.918  - info: alexa2.0 (6404) Subscribing to states...
                2024-02-02 21:29:59.931  - info: alexa2.0 (6404) Deleting the following states: ["Smart-Home-Devices.54d4a433-7a90-481c-b72b-57b2afa41876","Smart-Home-Devices.54d4a433-7a90-481c-b72b-57b2afa41876.#enabled","Smart-Home-Devices.54d4a433-7a90-481c-b72b-57b2afa41876.#delete"]
                2024-02-02 21:30:00.188  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 8110
                2024-02-02 21:30:02.476  - info: alexa2.0 (6404) Alexa-Push-Connection (macDms = true) established. Disable Polling
                2024-02-02 21:30:02.641  - info: daswetter.0 (8110) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                2024-02-02 21:30:02.853  - info: daswetter.0 (8110) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v17.6.0, js-controller: 4.0.18
                2024-02-02 21:30:11.044  - info: daswetter.0 (8110) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2024-02-02 21:30:11.565  - info: daswetter.0 (8110) cleaned everything up...
                2024-02-02 21:30:11.597  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-02-02 21:30:18.813  - info: alexa2.0 (6404) Initialization Done ...
                2024-02-02 21:32:48.987  - info: admin.0 (6237) <== Disconnect system.user.admin from ::ffff:192.168.1.64
                2024-02-02 21:34:46.737  - info: admin.0 (6237) <== Disconnect system.user.admin from ::ffff:192.168.1.64 admin
                2024-02-02 21:34:48.077  - info: jarvis.0 (6832) Client with IP 192.168.1.64 connected.
                2024-02-02 21:34:51.027  - info: jarvis.0 (6832) Client with IP 192.168.1.64 disconnected.
                2024-02-02 21:34:54.795  - info: admin.0 (6237) ==> Connected system.user.admin from ::ffff:192.168.1.64
                • SantosS Santos
                  #174
                  Selbstverständlich.
                  • SantosS Santos
                    HomoranH Offline
                    HomoranH Offline
                    #175
                    Alleine schon deswegen, weil ungerade nodejs Versionen nur Entwicklerversionen sind, npm immer nur mit nodejs zusammen installiert werden soll und der Controller v5 Bedingung für vis2 ist
                    • SantosS Santos
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : armhf
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           99M          0B         99M
                               7898 M total memory
                               1207 M used memory
                                869 M active memory
                               4617 M free memory
                                233 M buffer memory
                               1839 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      515M    /var/
                      193M    /var/cache
                      181M    /var/cache/apt
                      125M    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            8.5.1
                      /usr/bin/npx            8.5.1
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        7577
                      States:         9681
                      E: Broken packages
                      Pending Updates:
                      #176
                      E: Broken packages
                      Deine Paketdatenbank ist inkonsistent.
                      sudo apt update
                      sudo apt full-upgrade
                      zeigen.
                      • SantosS Offline
                        SantosS Offline
                        Santos
                        #177
                        So, jetzt fertig.
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                Icon name: computer
                             Architecture: arm
                        Docker          : false
                        Kernel          : armv7l
                        Userland        : armhf
                        22:11:07 up 46 days,  1:35,  2 users,  load average: 1.61, 3.09, 2.87
                        CPU threads: 4
                        Current issues:
                        This system needs to be REBOOTED!
                                      Local time: Fri 2024-02-02 22:11:07 CET
                                  Universal time: Fri 2024-02-02 21:11:07 UTC
                                        RTC time: n/a
                                     NTP service: active
                                 RTC in local TZ: no
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:           7.9G        1.2G        3.2G        395M        3.5G        6.3G
                        Swap:           99M          0B         99M
                        Total:         8.0G        1.2G        3.3G
                                7898 M total memory
                                1200 M used memory
                                1004 M active memory
                                3455 M inactive memory
                                3189 M free memory
                                 262 M buffer memory
                                3246 M swap cache
                                  99 M total swap
                                   0 M used swap
                                  99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4       59G  8.3G   48G  15% /
                        [Mon Dec 18 20:35:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC        :A6:32:E2:25:2C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=t        tyS0,115200 console=tty1 root=PARTUUID=848b4126-02 rootfstype=ext4 elevator=dead        line fsck.repair=yes rootwait
                        [Mon Dec 18 20:35:50 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
                        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=4        37,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        516M    /var/
                        193M    /var/cache
                        182M    /var/cache/apt
                        125M    /var/lib
                        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
                        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.m        ap
                        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
                        19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc        3820.js.map
                        USB-Devices by-id:
                        /usr/bin/nodejs         v18.19.0
                        /usr/bin/node           v18.19.0
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        /usr/bin/corepack       0.22.0
                        nodejs:
                         Installed: 18.19.0-1nodesource1
                         Candidate: 18.19.0-1nodesource1
                         Version table:
                        *** 18.19.0-1nodesource1 1001
                               500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                            18.18.2-1nodesource1 1001
                            18.18.1-1nodesource1 1001
                            18.18.0-1nodesource1 1001
                            18.17.1-1nodesource1 1001
                            18.17.0-1nodesource1 1001
                            18.16.1-1nodesource1 1001
                            18.16.0-1nodesource1 1001
                            18.15.0-1nodesource1 1001
                            18.14.2-1nodesource1 1001
                            18.14.1-1nodesource1 1001
                            18.14.0-1nodesource1 1001
                            18.13.0-1nodesource1 1001
                            18.12.0-1nodesource1 1001
                            18.11.0-1nodesource1 1001
                            18.10.0-1nodesource1 1001
                            18.9.1-1nodesource1 1001
                            18.9.0-1nodesource1 1001
                            18.8.0-1nodesource1 1001
                            18.7.0-1nodesource1 1001
                            18.6.0-1nodesource1 1001
                            18.5.0-1nodesource1 1001
                            18.4.0-1nodesource1 1001
                            18.3.0-1nodesource1 1001
                            18.2.0-1nodesource1 1001
                            18.1.0-1nodesource1 1001
                            18.0.0-1nodesource1 1001
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        js-controller:  5.0.17
                        admin:          6.13.15
                        javascript:     7.1.6
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                        + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                        + instance is alive
                        Adapter    "admin"        : 6.13.15  , installed 6.13.15
                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                        Controller "js-controller": 5.0.17   , installed 5.0.17
                        Objects and States
                        Objects:        7581
                        States:         9658
                        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Fetched 6564 B in 3s (2131 B/s)
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       54931202   14511/io.jarvis.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          54988018   27703/sshd
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          54986327   27773/cupsd
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       54928185   14328/io.sonoff.0
                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       54928156   14270/io.mqtt.0
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       54927526   13964/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       54923960   13964/iobroker.js-c
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54926940   13982/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       54931003   14478/io.web.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          54988020   27703/sshd
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          54986326   27773/cupsd
                        udp        0      0 0.0.0.0:46015           0.0.0.0:*                           108        54987139   27929/avahi-daemon:
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          54989164   27832/cups-browsed
                        udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          54983888   27133/tailscaled
                        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       54929576   14216/io.mihome.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        54987137   27929/avahi-daemon:
                        udp6       0      0 :::55206                :::*                                108        54987140   27929/avahi-daemon:
                        udp6       0      0 :::41641                :::*                                0          54983879   27133/tailscaled
                        udp6       0      0 :::5353                 :::*                                108        54987138   27929/avahi-daemon:
                        2024-02-02 21:53:50.068  - info: info.0 (14419) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                        2024-02-02 21:53:50.789  - info: discovery.0 (14593) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2024-02-02 21:53:51.458  - info: discovery.0 (14593) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v17.6.0, js-controller: 5.0.17
                        2024-02-02 21:53:51.556  - info: info.0 (14419) cpu Temp res = {"main":62.809,"cores":[],"max":62.809,"socket":[],"chipset":null}
                        2024-02-02 21:53:54.555  - info: fronius.0 (14661) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.fronius, node: v17.6.0, js-controller: 5.0.17
                        2024-02-02 21:54:14.769  - info: daswetter.0 (14563) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                        2024-02-02 21:54:15.297  - info: daswetter.0 (14563) cleaned everything up...
                        2024-02-02 21:54:15.410  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-02-02 21:54:30.220  - info: alexa2.0 (14146) Unknown Device, but enabling commands, Try it and report back if commands work.
                        2024-02-02 21:54:30.222  - info: alexa2.0 (14146) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                        2024-02-02 21:54:30.223  - info: alexa2.0 (14146)     Device-type:A1CFVS523BQYZ7 - Oleg's Mi Watch (Mi Watch) (SLEEP,SUPPORTS_LOCALE_SWITCH,TIMERS_AND_ALARMS,DEEZER,VOLUME_SETTING,KINDLE_BOOKS,SET_LOCALE,AMAZON_MUSIC,SIRIUSXM,REMINDERS,DEREGISTER_DEVICE,CHANGE_NAME,AUDIBLE,I_HEART_RADIO,SUPPORTS_LOCALE,ADAPTIVE_LISTENING,TIDAL,ASCENDING_ALARM_VOLUME,DIALOG_INTERFACE_VERSION,PERSISTENT_CONNECTION,MICROPHONE,SPEECH_RECOGNIZER_USS,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,CUSTOM_ALARM_TONE,TOUCH_INITIATED,DREAM_TRAINING,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,TUNE_IN,MUSIC_SKILL,MULTI_WAKEWORDS_SUPPORTED,GOLDFISH,SET_TIME_ZONE,APPLE_MUSIC,EARCONS,AUDIO_PLAYER)
                        2024-02-02 21:54:37.499  - info: alexa2.0 (14146) Using cached smart home devices list from Fri Feb 02 2024 21:47:06 GMT+0100 (Mitteleuropäische Normalzeit)
                        2024-02-02 21:54:38.446  - info: alexa2.0 (14146) No smart home devices to query
                        2024-02-02 21:54:39.378  - info: alexa2.0 (14146) Subscribing to states...
                        2024-02-02 21:54:39.387  - info: alexa2.0 (14146) Deleting the following states: ["Smart-Home-Devices.54d4a433-7a90-481c-b72b-57b2afa41876","Smart-Home-Devices.54d4a433-7a90-481c-b72b-57b2afa41876.#enabled","Smart-Home-Devices.54d4a433-7a90-481c-b72b-57b2afa41876.#delete"]
                        2024-02-02 21:54:41.421  - info: alexa2.0 (14146) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2024-02-02 21:54:54.670  - info: alexa2.0 (14146) Initialization Done ...
                        2024-02-02 22:00:00.256  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 19160
                        2024-02-02 22:00:02.752  - info: daswetter.0 (19160) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2024-02-02 22:00:02.879  - info: daswetter.0 (19160) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v17.6.0, js-controller: 5.0.17
                        2024-02-02 22:00:10.894  - info: daswetter.0 (19160) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                        2024-02-02 22:00:11.408  - info: daswetter.0 (19160) cleaned everything up...
                        2024-02-02 22:00:11.427  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-02-02 22:06:39.130  - info: sonoff.0 (14328) Client [Sonoff-Touch1-Tim] connection closed: closed
                        2024-02-02 22:06:39.528  - info: sonoff.0 (14328) Client [Sonoff-Touch1-Tim] connected with secret 1706907999526_2818
                        • SantosS Santos
                          So, jetzt fertig.
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                  Icon name: computer
                               Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : armhf
                          CPU threads: 4
                          Current issues:
                                          RTC time: n/a
                                       NTP service: active
                                   RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           99M          0B         99M
                                  7898 M total memory
                                  1200 M used memory
                                  3189 M free memory
                                   262 M buffer memory
                                  3246 M swap cache
                                    99 M total swap
                                     0 M used swap
                                    99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          516M    /var/
                          193M    /var/cache
                          182M    /var/cache/apt
                          125M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                           Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.13.15
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        7581
                          States:         9658
                          Pending Updates: 0
                          #178
                          vncserver-x11-c
                          Was macht der da?
                          Schalt den (vermutlich in raspi-config) aus.
                          Den fully und zigbee auch noch updaten.
                            vncserver-x11-c
                            Was macht der da?
                            SantosS Offline
                            SantosS Offline
                            Santos
                            #179
                            @thomas-braun sagte in Vis2 ab morgen im stable:
                            vncserver-x11-c
                            Was macht der da?
                            Den vncserver habe ich am Anfang noch genutzt, war einfach zu bedienen.
                            Jetzt funzt alles wieder und die VIS-2 wurde installiert. Die nächsten Tage schnuppere ich mich dann rein.
                            Vielen Dank für die schnelle, vor allem professionelle Hilfe!
                              MasterXY
                              #180
                              Ich bin gerade mit der Responsive Funktion der Vis 2 am experimentieren.
                              Leider gibt es wenig Infos darüber.
                              Hat einer von euch einen Link mit Infos oder ein Beispielprojekt wie man die Responsive Funktionen der Vis 2 richtig verwendet?
                              Ich vermute mal die Slider in den Seiteneigenschaften repräsentieren die Breite in Pixel. Ich möchte gerne dieses Raster unterteilen bzw. zwei Spalten für manche Widgets verwenden. Damit dieses gelingt habe ich neue Seiten mit immer kleiner werdenden Spaltenbreiten angelegt und bei dem größeren Raster das View in Widget verwendet. Am Ende sind das aber sehr viele Seiten was denke ich mal so nicht gedacht ist.
                              Der Sinn hinter diesem a5afb011-fe0e-4eae-8f03-6a9dbb89d3cc-image.png Button verstehe ich auch nicht so richtig. Der begrenzt nur die Breite auf 50% und der restliche Spaltenplatz ist dann einfach leer. Ich hätte erwartet, dass man dann wenigstens ein zweites halbes Widget daneben setzen kann.
                              • AgrippinenserA Offline
                                Agrippinenser
                                schrieb am zuletzt editiert von Agrippinenser
                                #181
                                ich vermisse seit heute das Widget "tplEnergy2Consumption".
                                Unter "Energie-Widgets" sind nur noch die beiden "Verteilung" und "Intervallwähler" zu sehen.
                                Korrektur: zu früh gepostet. Issue #195
                                Grüße vom Rhein @Colonia Claudia Ara Agrippinensium
                                • AgrippinenserA Agrippinenser
                                  Micha 3
                                  schrieb am zuletzt editiert von Micha 3
                                  #182
                                  @agrippinenser schon mal probiert iob u vis-2
                                  zumindest sind bei mir dann die Widget Anzeigefehler weg. Issues #318
                                  Keine Ahnung warum ich das nach jedem Update machen muss. Achso, die CSS Daten sind dann leider auch weg. Also vorher sichern falls vorhanden.
                                  AgrippinenserA 1 Antwort Letzte Antwort
                                    kafibo
                                    #183
                                    bei mir werden keine Signalbilder mehr angezeigt. Ich meine das ist seit Version 2.9.25 oder 2.9.26 der Fall. Bin mir aber nicht genau sicher. Hat noch jemand das Problem ?
                                    JS-Controller 5.0.19
                                    nodejs 18.19.0
                                    npm 10.2.3
                                    Admin 6.13.16
                                    Web 6.2.3
                                    • K kafibo
                                      nodejs 18.19.0
                                      npm 10.2.3
                                      Admin 6.13.16
                                      Web 6.2.3
                                      FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      #184
                                      @kafibo Hi, führ doch bitte Mal ein downgrade auf eine frühere vis-2 Version durch und schaue wo es noch geht. Dann am besten ein issue einstellen, damit foxriver es sich anschauen kann.
                                      Es gab in den letzten Wochen Änderungen, wenn man in den geschlossenen issues nach Signalbild sucht.
                                      • FeuersturmF Feuersturm
                                        kafibo
                                        #185
                                        @feuersturm
                                        So ich habe jetzt mal ein bischen getestet. Bin bis 2.9.24 zurück und da war das Problem auch noch, noch weiter wollte ich nicht zurück da gab es das Problem das alles (vor allem die Navigation) ganz langsam war.
                                        Ich habe dann mehrere Standard-Widgets ausprobiert und festgestellt, dass die Signalbilder nicht mehr bei allen Widgets funktioniert. Darunter auch das normale HTML-Widget !!!
                                        Dieses habe ich z.B. bei den Homematicgeräten die bei Batterie nur true und false kennen und nicht die Batteriespannung wie die HMIP-Geräte anzeigen. Dort verwende ich das HTML-Widget und lasse mir für true und false halt Signalbilder anzeigen, welche nicht mehr angezeigt werden. In früheren Verdsionen konnte man bei allen Standard - Widgets Signalbilder anzeigen lassen. Warum geht das jetzt nicht mehr.
                                        Bin jetzt wieder auf 2.9.28 und dort funktionieren halt die Signalbilder nicht bei allen Widgets !
                                        • M Micha 3
                                          Agrippinenser
                                          #186
                                          @micha-3 sagte in Vis2 ab morgen im stable:
                                          iob u vis-2
                                          bis Dato klappte das ohne Zusatz einwandfrei. Ich habe aber iob u vis-2gerade mal ausprobiert, leider erfolglos ;-)
