  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • Andre 6A Andre 6
    @elektrofix-ol kannst Du mal einen Screenshot machen?
    Bei mir funktioniert das nicht, ich muss sogar immer größer werden.
    Elektrofix-OLE Offline
    Elektrofix-OL
    schrieb am zuletzt editiert von Elektrofix-OL
    #2224
    @andre-6 Hier die Shots:
    05ea17f2-e2ee-4bc7-a6db-8d1474c07f9b-image.png a1246d80-c25c-4e16-ad2e-89027196ead0-image.png 546375c3-2405-4d32-aa3f-c6baa99983bd-image.png e06802b8-f217-4cb8-a570-db2736cd989f-image.png
    Das SVG-Fenster als Code
    <path d="M8.5,38.9c-2.2,0-3.9,1.8-3.9,3.9c0,2.2,1.8,3.9,3.9,3.9c2.2,0,3.9-1.8,3.9-3.9  C12.4,40.7,10.6,38.9,8.5,38.9z M8.5,45.1c-1.3,0-2.3-1-2.3-2.3c0-1.3,1-2.3,2.3-2.3s2.3,1,2.3,2.3C10.8,44.1,9.8,45.1,8.5,45.1z   M55.7,38.9c-2.2,0-3.9,1.8-3.9,3.9c0,2.2,1.8,3.9,3.9,3.9c2.2,0,3.9-1.8,3.9-3.9C59.7,40.7,57.9,38.9,55.7,38.9z M55.7,45.1  c-1.3,0-2.3-1-2.3-2.3c0-1.3,1-2.3,2.3-2.3c1.3,0,2.3,1,2.3,2.3C58.1,44.1,57,45.1,55.7,45.1z M60.3,31.2c-0.1-2.5-1.3-5.5-7.9-5.9  L51,25.3c-0.5-0.5-12.6-11.5-20.1-12.1c-1.8-0.1-3.4-0.2-5.1-0.2v0c-0.1,0-0.1,0-0.2,0c-0.9,0-1.9,0-3,0.1  c-3.8,0.2-9.4,0.5-14.7,1.1l-0.1,0c-0.3,0-0.6,0.3-0.7,0.6c0,0-2.4,11-3.5,15.6C-0.8,33.9-0.4,41.7,0.7,45l0,0  c1,3.4,4.1,5.8,7.7,5.8c3.4,0,6.4-2.2,7.5-5.2h32.2c1.2,3,4.1,5.2,7.5,5.2c4.4,0,8-3.6,8.1-8C64.8,34.4,61.7,31.9,60.3,31.2z   M23.2,15.1v8.7l-6.4-0.3c0.6-1.7,1.6-3.7,3.1-5.8C20.5,16.9,21.5,15.7,23.2,15.1z M8.6,15.8c0.5-0.1,1.1-0.1,1.6-0.2L8.5,23  c0,0.1-0.4,1.6-1.6,1.6H6.6C7.4,20.9,8.3,17.1,8.6,15.8z M8.5,49.3c-3.6,0-6.5-2.9-6.5-6.5s2.9-6.5,6.5-6.5s6.5,2.9,6.5,6.5  S12,49.3,8.5,49.3z M16.4,44.1c0.1-0.4,0.1-0.8,0.1-1.3c0-4.4-3.6-8.1-8.1-8.1c-2.9,0-5.4,1.6-6.9,3.9c0.2-2.8,1.1-5.6,3.3-7.1  c0,0,0-0.1,0.1-0.1c0.6,0.3,1.4,0.7,2.3,1.4c0.4,0,0.8-0.1,1.2-0.1c0.3,0,0.6,0,0.9,0c0.1,0,0.2,0,0.2,0c0,0-0.1-0.1-0.2-0.2  c-1.5-1.5-3-2.3-4-2.7c0.2-1.1,0.5-2.4,0.8-3.7h0.7c2,0,2.9-1.8,3.2-2.8l1.7-7.9c3.1-0.3,6.1-0.5,8.6-0.6c-0.9,0.7-1.5,1.4-1.8,1.9  c-3.3,4.8-4.6,8.9-3.7,12c0.5,1.6,5,9.6,9.4,12.4c0.5,0.3,1.5,0.8,2.8,0.9c6.5,0.3,18.1,0.5,20.5,0.6c0,0.1,0,0.2,0,0.2  c0,0.4,0,0.9,0.1,1.3H16.4z M55.7,49.3c-3.6,0-6.5-2.9-6.5-6.5s2.9-6.5,6.5-6.5c3.6,0,6.5,2.9,6.5,6.5S59.3,49.3,55.7,49.3z   M55.7,34.8c-3.8,0-7,2.7-7.8,6.2c-2,0-14-0.2-20.6-0.6c-1-0.1-1.7-0.4-2.1-0.6c-4-2.5-8.4-10.1-8.8-11.5c-0.3-0.9-0.3-2,0-3.2  l24.2,1.3l-0.1,1.3l1.6,0.1l0.3-5.4l-1.6-0.1l-0.2,2.4l-15.9-0.8v-9.2c0.2,0,0.5,0,0.7-0.1c1.8,0,3.4,0,5.3,0.2  c5.5,0.4,14.1,7.4,17.6,10.3l-4-0.2l-0.1,1.6l8,0.4c5.6,0.3,6.3,2.5,6.4,4.9c0,0.4,0.3,0.7,0.6,0.8c0,0,2.5,0.8,3,5.6  C60.8,36.1,58.5,34.8,55.7,34.8z" fill="#0000FF"></path>
    Andre 6A 1 Antwort Letzte Antwort
    • Andre 6A Andre 6
      @skb Moin,
      leider ist das mit dem SVG noch nicht komplett gefixt.
      Die Änderung der Farbe wird nicht übernommen, gleiches Verhalten. Werte werden im Log nach dem speichern richtig angezeigt aber nach einem reload der Seite ist der Standard Wert wieder drin. Gleiches bei der Größe, hier bleiben zwar die Werte im Log aber die Anzeige passt nicht.
      Bei der Farbe kann man tricksen indem man die Farbe beim SVG direkt angibt.
      In meinem Fall "black"
      Mit der Größe (width="40" height="40" viewBox="0 0 40 40") funktioniert das leider nicht.
      MfG
      André
      SKBS Offline
      SKBS Offline
      SKB
      #2225
      @andre-6 Schaue ich mir Morgen nochmal an.
      Elektrofix-OLE Andre 6A 2 Antworten Letzte Antwort
      • U66U U66
        @skb
        Ich sehe aber gerade das ich kein Element ( in meinem Falle der Batteriefüllstand ) über ein Bild legen läßt.
        SKBS Offline
        SKBS Offline
        SKB
        #2226
        @u66 Reihenfolge der Elemente angepasst?
        U66U 1 Antwort Letzte Antwort
        • SKBS SKB
          Elektrofix-OL
          #2227
          @skb Wenn ich es auf die Größe auf 30 27 einstelle siehst es in der Übersicht vollständig und kleiner aus aber in Live so: 12a22e42-13f1-46dd-ba97-efb7c641c04a-image.png
          • SKBS SKB
            Andre 6A Offline
            Andre 6A Offline
            Andre 6
            #2228
            @skb danke
            It's not a bug it's a feature.
            • Elektrofix-OLE Elektrofix-OL
              Andre 6A Offline
              Andre 6A Offline
              Andre 6
              #2229
              @elektrofix-ol dann scheint 65 und 56 aber auch die Originalgröße zu sein
              • SKBS SKB
                U66U Offline
                U66U Offline
                U66
                #2230
                @skb
                Ja
                hatte da ja nichts geändert.
                Aber lass Dir Zeit
                SKBS 1 Antwort Letzte Antwort
                • L Offline
                  lesiflo
                  #2231
                  Moin, ich möchte eine 2. Instanz für eine weitere Darstellung anlegen. Wie bekommen ich die Daten aus der 1. Instanz in die 2.?
                  • L lesiflo
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #2232
                    @lesiflo kopier den inhal von den 2 datenpunkten
                    L 1 Antwort Letzte Antwort
                    • arteckA arteck
                      lesiflo
                      #2233
                      @arteck Top, danke hat geklappt.
                        @andre-6 Mit den Größen haben ich keine Probleme, habe es in der ViewBox (0 0 65 56) und Größe (65 und 56) eingestellt und dann lief es. Die Farbe kann ich nur in SVG-Inhalt ändern.
                        EDIT: Ich wollte es nicht kleiner haben, aber wenn ich das machen, sieht es nicht gut aus (weiter unten)
                        @andre-6 Du schreibst oben, das Du ein Strommast als SVG je nach Richtung in Rot oder Grün anzeigen lässt, wie hast Du das hinbekommen? als Symbol schaffe ich das auch, aber als SVG hat es die Einstellmöglichkeiten nicht.
                        Andre 6A Offline
                        Andre 6A Offline
                        Andre 6
                        schrieb am zuletzt editiert von Andre 6
                        #2234
                        @elektrofix-ol da war ja noch eine Frage..🫣
                        Die Idee mit den Strommasten stammt von homoran und ist auch über die Symbole umgesetzt.
                        Den Strommast ohne Pfeil habe ich dann als SVG dazugedichtet weil es das als Symbol nicht gibt.
                        Der SVG Code für den Strommast ohne Pfeil ist:
                        d="m5.18 5.45l-1.78-.9L4.66 2h8.47l1.27 2.55l-1.78.89L11.9 4h-6zM15.5 8H11l-.8-3H7.6l-.79 3H2.28L1 10.55l1.79.89L3.5 10h10.78l.72 1.45l1.79-.89zm-.83 14H12.6l-.24-.9l-3.46-5.2l-3.47 5.2l-.23.9H3.13L6 11h2.09l-.36 1.35L8.9 14.1l1.16-1.75L9.71 11h2.07zM8.3 15l-.9-1.35l-1.18 4.48zm3.28 3.12l-1.18-4.48L9.5 15zM23"
                        Das Grid Symbol habe ich voll transparent eingestellt und das SVG an der gleichen Stelle plaziert.
                        • Andre 6A Andre 6
                          @skb Moin,
                          MfG
                          André
                          SKBS Offline
                          SKBS Offline
                          SKB
                          #2235
                          @andre-6 Kannst Du nochmal die Version von Git drüber installieren und testen?
                          Weiss nicht, was ich gestern auf den Augen hatte - aber irgendwie hatte ich da einen Feld-Dreher drin :D
                          • U66U U66
                            @skb
                            Ja
                            Aber lass Dir Zeit
                            SKBS Offline
                            SKBS Offline
                            SKB
                            #2236
                            @u66 Also wenn dies beides Bilder sind, kannst Du entscheiden, welches Bild im Vorder- oder Hintergrund sein soll.
                            Hier als Beispiel:
                            2024-01-26 10_33_02-Energiefluss - erweitert Configuration – Mozilla Firefox.png
                            • SKBS SKB
                              Hier als Beispiel:
                              U66U Offline
                              U66U Offline
                              U66
                              #2237
                              @skb
                              probier mal Quadrat über BILD
                              • U66U U66
                                @skb
                                SKBS Offline
                                SKBS Offline
                                SKB
                                #2238
                                @u66 Bei Rechtecke über Bilder hat das Rechteck Priorität.
                                • SKBS SKB
                                  U66U Offline
                                  U66U Offline
                                  U66
                                  #2239
                                  @skb
                                  Bin noch auf Arbeit
                                  Gestern hab ich das nicht hinbekommen
                                  Auch mit anordnen nicht sie Bild oben.
                                  • U66U U66
                                    @skb
                                    Bin noch auf Arbeit
                                    SKBS Offline
                                    SKBS Offline
                                    SKB
                                    #2240
                                    @u66 Ist aber so auch dokumentiert.
                                    Jede Gruppe ist für sich - heisst, Rechtecke und Kreise, Texte, Icons und Bilder.
                                    In den jeweiligen Gruppen können die Elemente anders angeordnet werden - eine globale Anordnung gibt es nicht.
                                    Somit kann kein Bild vor einem Icon oder Rechteck/Kreis sein.
                                    • SKBS SKB
                                      Andre 6A Offline
                                      Andre 6A Offline
                                      Andre 6
                                      #2241
                                      @skb 👍 super jetzt ist es schick, danke.
                                      • SKBS SKB
                                        U66U Offline
                                        U66U Offline
                                        U66
                                        #2242
                                        @skb
                                        Bild auf Blld ok
                                        Schrift auf Bild auch ok
                                        Den Rest siehst Du.
                                        Keine Ahnung wie was …….
                                        War mir nach dem ich das Update gemacht hatte gleich aufgefallen das das Rechteck (Batterie Ladung ) verschwunden war.
                                        • U66U U66
                                          @skb
                                          Bild auf Blld ok
                                          Den Rest siehst Du.
                                          SKBS Offline
                                          SKBS Offline
                                          SKB
                                          #2243
                                          @u66 genauso habe ich es ja oben beschrieben.
