  4. Test Adapter jablotron v.0.1.x
    apollon77A
jablotron alarm system test
39 Beiträge 7 Kommentatoren 5.8k Aufrufe 7 Beobachtet
  • CodierknechtC
    CodierknechtC
    Codierknecht
    Wäre schön, wenn die Tester hier nochmal ihr Fazit posten könnten.
    Dann könnte der Adapter ins Stable-Repo wandern.
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    T Hant0rH 2 Antworten Letzte Antwort
    • CodierknechtC Codierknecht
      T
      T
      tritor
      schrieb am zuletzt editiert von tritor
      @codierknecht
      bei mir steht der Adpater fast täglich, brauch dann manuellen Restart.
      hier das log bevor der Adapter sich verabschiedet hat:
      2024-01-15 05:57:32.713 - debug: jablotron.0 (1764400) thermoDevicesGet: {"data":{"service-states":{"last-event-time":"2024-01-15T04:41:42+0100","service-name":"xxxxxxx"},"states":[]},"http-code":200}
      2024-01-15 05:58:14.580 - debug: jablotron.0 (1764400) Fetch data from jablonet.net
      2024-01-15 05:58:14.586 - error: jablotron.0 (1764400) getServices: Error: getaddrinfo EAI_AGAIN api.jablonet.net
      2024-01-15 05:58:14.586 - error: jablotron.0 (1764400) getExtendedData: Error: getaddrinfo EAI_AGAIN api.jablonet.net
      2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) unhandled promise rejection: getaddrinfo EAI_AGAIN api.jablonet.net
      2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) Error: getaddrinfo EAI_AGAIN api.jablonet.net
      at AxiosError.from (/opt/iobroker/node_modules/iobroker.jablotron/node_modules/axios/dist/node/axios.cjs:837:14)
      at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.jablotron/node_modules/axios/dist/node/axios.cjs:3083:25)
      2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) Exception-Code: EAI_AGAIN: getaddrinfo EAI_AGAIN api.jablonet.net
      2024-01-15 05:58:14.591 - info: jablotron.0 (1764400) terminating
      2024-01-15 05:58:14.591 - warn: jablotron.0 (1764400) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-01-15 05:58:15.090 - info: jablotron.0 (1764400) terminating
      2024-01-15 05:58:15.144 - error: host.ioBroker-prox instance system.adapter.jablotron.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-01-15 05:58:15.145 - info: host.ioBroker-prox Restart adapter system.adapter.jablotron.0 because enabled
      2024-01-15 05:58:45.202 - info: host.ioBroker-prox instance system.adapter.jablotron.0 started with pid 1813150
      2024-01-15 05:58:45.561 - info: jablotron.0 (1813150) setState not processed because States database not connected
      2024-01-15 05:58:45.646 - debug: jablotron.0 (1813150) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-01-15 05:58:45.659 - debug: jablotron.0 (1813150) Objects client ready ... initialize now
      2024-01-15 05:58:45.661 - debug: jablotron.0 (1813150) Objects create System PubSub Client
      2024-01-15 05:58:45.661 - debug: jablotron.0 (1813150) Objects create User PubSub Client
      2024-01-15 05:58:45.679 - debug: jablotron.0 (1813150) Objects client initialize lua scripts
      2024-01-15 05:58:45.682 - debug: jablotron.0 (1813150) Objects connected to redis: 127.0.0.1:9001
      2024-01-15 05:58:45.704 - debug: jablotron.0 (1813150) Redis States: Use Redis connection: 127.0.0.1:6379
      2024-01-15 05:58:45.706 - debug: jablotron.0 (1813150) States create System PubSub Client
      2024-01-15 05:58:45.707 - debug: jablotron.0 (1813150) States create User PubSub Client
      2024-01-15 05:58:45.714 - debug: jablotron.0 (1813150) States connected to redis: 127.0.0.1:6379
      2024-01-15 05:58:45.764 - info: jablotron.0 (1813150) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.jablotron, node: v18.19.0, js-controller: 5.0.17
      2024-01-15 05:58:45.772 - debug: jablotron.0 (1813150) Fetching new session id
      2024-01-15 05:58:45.833 - error: jablotron.0 (1813150) Error: getaddrinfo EAI_AGAIN api.jablonet.net
      2024-01-15 05:58:45.834 - error: jablotron.0 (1813150) Error in onReady: Error: Not connect to jablonet.net
      Gernot
      Host: i9 server Proxmox , Debian 13.4 for ioBroker
      ioBroker: 8.0.23, Node.js: 24.21.0, NPM: 10.9.8,
      Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.6
      Grafana 13.1.1 / InfluxDB 2.9.1
        Hant0rH
        Hant0rH
        Hant0r
        @codierknecht
        Sorry, bei mir ist es so, dass der Adapter irgendwann auf gelb steht und nicht mehr funktioniert.
        Schätzungsweise einmal pro Tag. Habe ihn aber als "Info" laufen und im Log steht nichts.
        Wenn es hilft, lasse ich ihn mal die ganze Zeit mit "debug" laufen, spammt dann nur sehr das Log zu. :)
        • T tritor
          @codierknecht
          CodierknechtC
          CodierknechtC
          Codierknecht
          @tritor sagte in Test Adapter jablotron v.0.1.x:
          EAI_AGAIN
          Das sieht nach einem DNS-Problem aus.
          Da muss ich mal die Kollegen fragen, wie man sowas am besten umgeht.
          Es wird dann vermutlich in Kürze eine neue Version geben.
          • Hant0rH Hant0r
            @codierknecht
            CodierknechtC
            CodierknechtC
            Codierknecht
            @hant0r sagte in Test Adapter jablotron v.0.1.x:
            Ich lasse den mal bei mir 'ne Weile laufen.
            Wenn's nur ein kurzer Stolperer beim DNS-Lookup ist, sollte das zu verschmerzen sein.
            Sollte ich dann vielleicht hochzählen und bei mehr als X aufeinanderfolgenden DNS-Fehlern aussteigen.
            • CodierknechtC
              CodierknechtC
              Codierknecht
              Das Portal des Herstellers scheint recht empfindlich zu sein.
              Auf GitHub findet ihr eine Version mit "Selbstheilungskräften". Die aktualisiert auch zur Sicherheit mal jede Stunde ihre Session-ID.
                CodierknechtC
                CodierknechtC
                Codierknecht
                Wartet noch mit der neuen Version - da stimmt noch etwas nicht so ganz :-(
                • CodierknechtC
                  CodierknechtC
                  Codierknecht
                  Das stündliche Aktualisieren der Session-ID - also quasi im "vorauseilenden Gehorsam" - funktioniert nicht so wie gewünscht.
                  Das habe ich jetzt wieder rausgenommen. Die ID wird nur noch nach einem HTTP 401 (not authorized) neu geholt.
                  Ich werde das noch eine Weile beobachten und dann die Version einchecken.
                  Ich gebe Bescheid, wenn es etwas zu testen gibt.
                    CodierknechtC
                    CodierknechtC
                    Codierknecht
                    Aktuell sieht's recht vielversprechend aus ...
                    Ich gebe Bescheid, wenn's etwas zu installieren gibt.
                    • CodierknechtC
                      CodierknechtC
                      Codierknecht
                      Heute läuft er seit > 10 Std. durch.
                      Das Portal des Herstellers zickt aber zwischendurch immer mal wieder rum.
                      • CodierknechtC
                        CodierknechtC
                        Codierknecht
                        So - auf GitHub wurde gerade Version 0.1.3 veröffentlicht.
                        Die sollte in Kürze auch im Beta-Repository erscheinen.
                        Diese Version läuft jetzt seit einigen Tagen stabil durch.
                        Bitte bei Gelegenheit testen und hier Feedback geben, damit der Adapter dann auch ins Stable-Repo gehen kann.
                        T mike2507M 2 Antworten Letzte Antwort
                        • mike2507M
                          mike2507M
                          mike2507
                          @codierknecht
                          Danke für diesen Adapter.
                          Habe schon lange darauf gewartet.
                          Bis jetzt habe ich es über ham Adapter gelöst.
                          Werde den Adapter mal Testen und berichten.
                            T
                            T
                            tritor
                            @codierknecht
                            läuft seit gestern stabil. vielen Dank!
                            3.Feb.: immer noch alles paletti!
                            Gernot
                              mike2507M
                              mike2507M
                              mike2507
                              @codierknecht
                              bei mir läuft auch alles stabil.
                              • CodierknechtC
                                CodierknechtC
                                Codierknecht
                                Version 0.1.3 sollte in Kürze im Stable-Repository auftauchen :-)
                                Allen Testern an dieser Stelle schon mal einen großen Dank!
                                • Hant0rH
                                  Hant0rH
                                  Hant0r
                                  schrieb am zuletzt editiert von Hant0r
                                  Moin,
                                  Im Log kommt leider nur noch folgendes:
                                  jablotron.0 2024-03-04 09:46:19.655	warn	Communication error 400 (ERR_BAD_REQUEST).
                                  jablotron.0 2024-03-04 09:46:09.652	warn	Communication error 400 (ERR_BAD_REQUEST).
                                  jablotron.0 2024-03-04 09:45:59.646	warn	Communication error 400 (ERR_BAD_REQUEST).
                                  jablotron.0 2024-03-04 09:45:49.644	warn	Communication error 400 (ERR_BAD_REQUEST).
                                  Status vom Adapter ist grün.
                                  Nach einem Adapter-Neustart kommt nur noch das:
                                  jablotron.0 2024-03-04 09:46:27.153	error	Error in onReady: Error: Not connect to jablonet.net
                                  jablotron.0 2024-03-04 09:46:27.150	error	AxiosError: Request failed with status code 405
                                  jablotron.0 2024-03-04 09:46:26.827	info	starting. Version 0.1.3 (non-npm: DEV2DEV-DE/ioBroker.jablotron) in /opt/iobroker/node_modules/iobroker.jablotron, node: v18.19.1, js-controller: 5.0.19
                                  jablotron.0 2024-03-04 09:46:21.105	info	terminating
                                  jablotron.0 2024-03-04 09:46:20.767	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  jablotron.0 2024-03-04 09:46:20.766	info	terminating
                                  jablotron.0 2024-03-04 09:46:20.602	info	Got terminate signal TERMINATE_YOURSELF
                                  • Hant0rH Hant0r
                                    Moin,
                                    CodierknechtC
                                    CodierknechtC
                                    Codierknecht
                                    @hant0r
                                    Status 405 bedeutet "Method not allowed".
                                    Vermutlich hat Jablotron das API geändert.
                                    Mal sehen, ob ich herausbekomme was die da gemacht haben.
                                    Gab es vor kurzem mal ein Update der App?
                                    Hant0rH 1 Antwort Letzte Antwort
                                    • CodierknechtC
                                      CodierknechtC
                                      Codierknecht
                                      Scheinbar funktioniert der Adapter wieder.
                                      Möglicherweise nur Wartungsarbeiten bei Jablotron?
                                      Man weiß es nicht ;-(
                                        @hant0r
                                        Hant0rH
                                        Hant0rH
                                        Hant0r
                                        @codierknecht sagte in Test Adapter jablotron v.0.1.x:
                                        Letzte Aktualisierung war der 02.02.24
                                        Finde dazu leider nichts
                                        • O
                                          O
                                          observer
                                          Der Vollständigkeit halber sei angemerkt, dass der Adapter nicht zur älteren Produktlinie OASIS-80 (auch bekannt als INDEXA System 8000) kompatibel ist.
                                          Ich habe es gerade eben getestet. Offenbar nutzt der Hersteller unterschiedliche Cloud-Implementationen.
                                          83.9k
