  4. Test Adapter jablotron v.0.1.x
jablotron alarm system test
39 Beiträge 7 Kommentatoren 5.7k Aufrufe 7 Beobachtet
  • CodierknechtC Codierknecht
    @tritor sagte in Test Adapter jablotron v.0.1.x:
    was sollte da auf jeden Fall anonymisiert werden?
    Die ID's zu Deinen Elementen. Sieht z.B. bei den PG's so aus: PG-1234567890
    Ich weiß nicht, ob man damit Unfug anstellen könnte.
    Sollte reichen, wenn da ein paar Ziffern ge-X't werden.
    T
    T
    tritor
    schrieb am zuletzt editiert von tritor
    @codierknecht
    hier das log:
    jablotron.0 2023-12-16 17:43:37.897	debug	thermoDevicesGet: {"data":{"service-states":{"last-event-time":"2023-12-16T17:19:01+0100","service-name":"XXXX"},"states":[]},"http-code":200}
    jablotron.0 2023-12-16 17:43:37.140	debug	programmableGatesGet: {"data":{"service-states":{"last-event-time":"2023-12-16T17:19:01+0100","service-name":"XXXX"},"states":[{"cloud-component-id":"PG-XXXX","state":"OFF"}],"programmableGates":[{"cloud-component-id":"PG-XXXX","name":"Alarmausgang","can-control":true,"need-authorization":true}]},"http-code":200}
    jablotron.0 2023-12-16 17:43:36.386	debug	sectionsGet: {"data":{"service-states":{"last-event-time":"2023-12-16T17:19:01+0100","service-name":"XXXX"},"states":[{"cloud-component-id":"SEC-XXXX","state":"DISARM"}],"sections":[{"cloud-component-id":"SEC-XXXX","name":"Sicherung","can-control":true,"need-authorization":true,"partial-arm-enabled":true}]},"http-code":200}
    jablotron.0 2023-12-16 17:43:35.713	debug	serviceListGet: {"data":{"services":[{"service-id":XXXX,"cloud-entity-id":"SERVICE_JA100F:XXXX","name":"XXXX","service-type":"JA100F","icon":"JA100F","index":1000000,"level":"FULL","status":"ENABLED","visible":true,"message":"OK","event-last-time":"2023-11-29T15:10:32+0100","share-status":"OWNER","service-blocked":"NONE","extended-states":[{"type":"ARM","value":"0"},{"type":"DISARM","value":"1"}],"notifications":0}],"meta":{"checksum":"XXXX"}},"http-code":200}
    jablotron.0 2023-12-16 17:43:35.234	debug	Fetch data from jablonet.net
    jablotron.0 2023-12-16 17:43:05.232	debug	Setting up recurring refresh
    jablotron.0 2023-12-16 17:43:05.232	debug	thermoDevicesGet: {"data":{"service-states":{"last-event-time":"2023-12-16T17:19:01+0100","service-name":"XXXX"},"states":[]},"http-code":200}
    jablotron.0 2023-12-16 17:43:03.877	debug	programmableGatesGet: {"data":{"service-states":{"last-event-time":"2023-12-16T17:19:01+0100","service-name":"XXXX"},"states":[{"cloud-component-id":"PG-XXXX","state":"OFF"}],"programmableGates":[{"cloud-component-id":"PG-XXXX","name":"Alarmausgang","can-control":true,"need-authorization":true}]},"http-code":200}
    jablotron.0 2023-12-16 17:43:03.104	debug	sectionsGet: {"data":{"service-states":{"last-event-time":"2023-12-16T17:19:01+0100","service-name":"XXXX"},"states":[{"cloud-component-id":"SEC-XXXX","state":"DISARM"}],"sections":[{"cloud-component-id":"SEC-XXXX","name":"Sicherung","can-control":true,"need-authorization":true,"partial-arm-enabled":true}]},"http-code":200}
    jablotron.0 2023-12-16 17:43:01.824	debug	serviceListGet: {"data":{"services":[{"service-id":XXXX,"cloud-entity-id":"SERVICE_JA100F:XXXX","name":"XXXX","service-type":"JA100F","icon":"JA100F","index":1000000,"level":"FULL","status":"ENABLED","visible":true,"message":"OK","event-last-time":"2023-11-29T15:10:32+0100","share-status":"OWNER","service-blocked":"NONE","extended-states":[{"type":"ARM","value":"0"},{"type":"DISARM","value":"1"}],"notifications":0}],"meta":{"checksum":"XXXX"}},"http-code":200}
    jablotron.0 2023-12-16 17:43:01.294	debug	Fetching initial data from jablonet.net
    jablotron.0 2023-12-16 17:43:01.294	debug	Session-ID: PHPSESSID=XXXX
    jablotron.0 2023-12-16 17:43:01.294	info	Logged in to jablonet api
    jablotron.0 2023-12-16 17:43:00.336	debug	Fetching new session id
    jablotron.0 2023-12-16 17:43:00.330	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.jablotron, node: v18.19.0, js-controller: 5.0.17
    jablotron.0 2023-12-16 17:42:57.204	info	terminating
    jablotron.0 2023-12-16 17:42:56.705	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    jablotron.0 2023-12-16 17:42:56.705	info	terminating
    jablotron.0 2023-12-16 17:42:56.702	info	Got terminate signal TERMINATE_YOURSELF
    btw: das update Intervall von 10 sec. ist das nicht zu klein, was wäre einzuwenden dies auf 60s zu erhöhen?
    Gernot
    Host: i9 server Proxmox , Debian 13.4 for ioBroker
    ioBroker: 8.0.11, Node.js: 22.23.2, NPM: 10.9.8,
    Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.6
    Grafana 13.1.1 / InfluxDB 2.9.1
    CodierknechtC Hant0rH 2 Antworten Letzte Antwort
    • T tritor
      @codierknecht
      hier das log:
      CodierknechtC
      CodierknechtC
      Codierknecht
      Das kann jeder nach Belieben auch gerne höher setzen.
      Je höher das ist, desto weniger läuft man Gefahr dass der Hersteller aufmerksam wird und möglicherweise neue Hindernisse einbaut ;-)
      Danke für's Log.
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • T tritor
        @codierknecht
        hier das log:
        Hant0rH
        Hant0rH
        Hant0r
        Ist die Frage was machen machen möchte.
        Um z. B. auf ein geöffnetes Fenster/Tür zu reagieren, um die Rolladen hoch zu fahren, wären 10 Sekunden schon sehr lang.
        Um Alarm zu schalten, wenn sich ein Feuermelder meldet, auch ;)
        • Hant0rH Hant0r
          CodierknechtC
          CodierknechtC
          Codierknecht
          @hant0r
          Sollte auch keinesfalls eine Art Vorwurf sein.
          Intervall so klein wie nötig, so groß wie möglich. Jeder so wie er/sie es gerade braucht.
          Hant0rH 1 Antwort Letzte Antwort
            @hant0r
            Hant0rH
            Hant0rH
            Hant0r
            @codierknecht
            Hatte ich auch nicht so verstanden 🙈
            • CodierknechtC
              CodierknechtC
              Codierknecht
              Wäre schön, wenn die Tester hier nochmal ihr Fazit posten könnten.
              Dann könnte der Adapter ins Stable-Repo wandern.
              T Hant0rH 2 Antworten Letzte Antwort
                T
                T
                tritor
                @codierknecht
                bei mir steht der Adpater fast täglich, brauch dann manuellen Restart.
                hier das log bevor der Adapter sich verabschiedet hat:
                2024-01-15 05:57:32.713 - debug: jablotron.0 (1764400) thermoDevicesGet: {"data":{"service-states":{"last-event-time":"2024-01-15T04:41:42+0100","service-name":"xxxxxxx"},"states":[]},"http-code":200}
                2024-01-15 05:58:14.580 - debug: jablotron.0 (1764400) Fetch data from jablonet.net
                2024-01-15 05:58:14.586 - error: jablotron.0 (1764400) getServices: Error: getaddrinfo EAI_AGAIN api.jablonet.net
                2024-01-15 05:58:14.586 - error: jablotron.0 (1764400) getExtendedData: Error: getaddrinfo EAI_AGAIN api.jablonet.net
                2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) unhandled promise rejection: getaddrinfo EAI_AGAIN api.jablonet.net
                2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) Error: getaddrinfo EAI_AGAIN api.jablonet.net
                at AxiosError.from (/opt/iobroker/node_modules/iobroker.jablotron/node_modules/axios/dist/node/axios.cjs:837:14)
                at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.jablotron/node_modules/axios/dist/node/axios.cjs:3083:25)
                2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) Exception-Code: EAI_AGAIN: getaddrinfo EAI_AGAIN api.jablonet.net
                2024-01-15 05:58:14.591 - info: jablotron.0 (1764400) terminating
                2024-01-15 05:58:14.591 - warn: jablotron.0 (1764400) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-01-15 05:58:15.090 - info: jablotron.0 (1764400) terminating
                2024-01-15 05:58:15.144 - error: host.ioBroker-prox instance system.adapter.jablotron.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2024-01-15 05:58:15.145 - info: host.ioBroker-prox Restart adapter system.adapter.jablotron.0 because enabled
                2024-01-15 05:58:45.202 - info: host.ioBroker-prox instance system.adapter.jablotron.0 started with pid 1813150
                2024-01-15 05:58:45.561 - info: jablotron.0 (1813150) setState not processed because States database not connected
                2024-01-15 05:58:45.646 - debug: jablotron.0 (1813150) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2024-01-15 05:58:45.659 - debug: jablotron.0 (1813150) Objects client ready ... initialize now
                2024-01-15 05:58:45.661 - debug: jablotron.0 (1813150) Objects create System PubSub Client
                2024-01-15 05:58:45.661 - debug: jablotron.0 (1813150) Objects create User PubSub Client
                2024-01-15 05:58:45.679 - debug: jablotron.0 (1813150) Objects client initialize lua scripts
                2024-01-15 05:58:45.682 - debug: jablotron.0 (1813150) Objects connected to redis: 127.0.0.1:9001
                2024-01-15 05:58:45.704 - debug: jablotron.0 (1813150) Redis States: Use Redis connection: 127.0.0.1:6379
                2024-01-15 05:58:45.706 - debug: jablotron.0 (1813150) States create System PubSub Client
                2024-01-15 05:58:45.707 - debug: jablotron.0 (1813150) States create User PubSub Client
                2024-01-15 05:58:45.714 - debug: jablotron.0 (1813150) States connected to redis: 127.0.0.1:6379
                2024-01-15 05:58:45.764 - info: jablotron.0 (1813150) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.jablotron, node: v18.19.0, js-controller: 5.0.17
                2024-01-15 05:58:45.772 - debug: jablotron.0 (1813150) Fetching new session id
                2024-01-15 05:58:45.833 - error: jablotron.0 (1813150) Error: getaddrinfo EAI_AGAIN api.jablonet.net
                2024-01-15 05:58:45.834 - error: jablotron.0 (1813150) Error in onReady: Error: Not connect to jablonet.net
                Gernot
                  Hant0rH
                  Hant0rH
                  Hant0r
                  @codierknecht
                  Sorry, bei mir ist es so, dass der Adapter irgendwann auf gelb steht und nicht mehr funktioniert.
                  Schätzungsweise einmal pro Tag. Habe ihn aber als "Info" laufen und im Log steht nichts.
                  Wenn es hilft, lasse ich ihn mal die ganze Zeit mit "debug" laufen, spammt dann nur sehr das Log zu. :)
                  • T tritor
                    @codierknecht
                    CodierknechtC
                    CodierknechtC
                    Codierknecht
                    EAI_AGAIN
                    Das sieht nach einem DNS-Problem aus.
                    Da muss ich mal die Kollegen fragen, wie man sowas am besten umgeht.
                    Es wird dann vermutlich in Kürze eine neue Version geben.
                    • Hant0rH Hant0r
                      @codierknecht
                      CodierknechtC
                      CodierknechtC
                      Codierknecht
                      @hant0r sagte in Test Adapter jablotron v.0.1.x:
                      Ich lasse den mal bei mir 'ne Weile laufen.
                      Wenn's nur ein kurzer Stolperer beim DNS-Lookup ist, sollte das zu verschmerzen sein.
                      Sollte ich dann vielleicht hochzählen und bei mehr als X aufeinanderfolgenden DNS-Fehlern aussteigen.
                      • CodierknechtC
                        CodierknechtC
                        Codierknecht
                        Das Portal des Herstellers scheint recht empfindlich zu sein.
                        Auf GitHub findet ihr eine Version mit "Selbstheilungskräften". Die aktualisiert auch zur Sicherheit mal jede Stunde ihre Session-ID.
                          CodierknechtC
                          CodierknechtC
                          Codierknecht
                          Wartet noch mit der neuen Version - da stimmt noch etwas nicht so ganz :-(
                          • CodierknechtC
                            CodierknechtC
                            Codierknecht
                            Das stündliche Aktualisieren der Session-ID - also quasi im "vorauseilenden Gehorsam" - funktioniert nicht so wie gewünscht.
                            Das habe ich jetzt wieder rausgenommen. Die ID wird nur noch nach einem HTTP 401 (not authorized) neu geholt.
                            Ich werde das noch eine Weile beobachten und dann die Version einchecken.
                            Ich gebe Bescheid, wenn es etwas zu testen gibt.
                              CodierknechtC
                              CodierknechtC
                              Codierknecht
                              Aktuell sieht's recht vielversprechend aus ...
                              Ich gebe Bescheid, wenn's etwas zu installieren gibt.
                              • CodierknechtC
                                CodierknechtC
                                Codierknecht
                                Heute läuft er seit > 10 Std. durch.
                                Das Portal des Herstellers zickt aber zwischendurch immer mal wieder rum.
                                • CodierknechtC
                                  CodierknechtC
                                  Codierknecht
                                  So - auf GitHub wurde gerade Version 0.1.3 veröffentlicht.
                                  Die sollte in Kürze auch im Beta-Repository erscheinen.
                                  Diese Version läuft jetzt seit einigen Tagen stabil durch.
                                  Bitte bei Gelegenheit testen und hier Feedback geben, damit der Adapter dann auch ins Stable-Repo gehen kann.
                                  T mike2507M 2 Antworten Letzte Antwort
                                  • mike2507M
                                    mike2507M
                                    mike2507
                                    @codierknecht
                                    Danke für diesen Adapter.
                                    Habe schon lange darauf gewartet.
                                    Bis jetzt habe ich es über ham Adapter gelöst.
                                    Werde den Adapter mal Testen und berichten.
                                      T
                                      T
                                      tritor
                                      @codierknecht
                                      läuft seit gestern stabil. vielen Dank!
                                      3.Feb.: immer noch alles paletti!
                                      Gernot
                                        mike2507M
                                        mike2507M
                                        mike2507
                                        @codierknecht
                                        bei mir läuft auch alles stabil.
                                        • CodierknechtC
                                          CodierknechtC
                                          Codierknecht
                                          Version 0.1.3 sollte in Kürze im Stable-Repository auftauchen :-)
                                          Allen Testern an dieser Stelle schon mal einen großen Dank!
                                          83.8k
