  4. Test Adapter alpha-ess v4.1.0
302 Beiträge 37 Kommentatoren 106.8k Aufrufe 35 Beobachtet
  • JohreiJ Offline
    JohreiJ Offline
    Johrei
    schrieb am zuletzt editiert von Johrei
    #158
    2024-01-02 23:52:11.254 - info: host.johannes-MINI-S stopInstance system.adapter.alpha-ess.0 (force=false, process=true)
    2024-01-02 23:52:11.257 - info: alpha-ess.0 (551183) Got terminate signal TERMINATE_YOURSELF
    2024-01-02 23:52:11.336 - info: host.johannes-MINI-S stopInstance system.adapter.alpha-ess.0 send kill signal
    2024-01-02 23:52:11.434 - info: alpha-ess.0 (551183) terminating
    2024-01-02 23:52:11.434 - info: alpha-ess.0 (551183) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-02 23:52:11.758 - info: alpha-ess.0 (551183) terminating
    2024-01-02 23:52:12.001 - info: host.johannes-MINI-S instance system.adapter.alpha-ess.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-01-02 23:52:14.388 - info: host.johannes-MINI-S instance system.adapter.alpha-ess.0 started with pid 552101
    2024-01-02 23:52:14.984 - info: alpha-ess.0 (552101) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.alpha-ess, node: v18.19.0, js-controller: 5.0.17
    2024-01-02 23:52:15.819 - info: alpha-ess.0 (552101) Initialized states for : Realtime
    2024-01-02 23:52:16.981 - info: alpha-ess.0 (552101) Initialized states for : Energy
    2024-01-02 23:52:17.536 - info: alpha-ess.0 (552101) Initialized states for : Settings_Charge
    2024-01-02 23:52:18.059 - error: alpha-ess.0 (552101) Alpha ESS Api returns an error! Group: Settings_Discharge
    2024-01-02 23:52:18.060 - info: alpha-ess.0 (552101) Error code: 6053 - The request was too fast, please try again later (#1)
    2024-01-02 23:52:18.882 - info: alpha-ess.0 (552101) Initialized states for : Summary
    2024-01-02 23:52:18.904 - info: alpha-ess.0 (552101) Wallbox data disabled! Adapter won't fetch Wallbox data. According states deleted.
    Hoffe du meintest so
    danke Update hat super funktioniert leider ohne Erfolg
    • JohreiJ Johrei
      #159
      @johrei sagte in Test Adapter alpha-ess v2.0.0:
      leider ohne Erfolg
      Ja doch. Deine Basis ist jetzt wieder auf Stand und wird aus dem richtigen Repo gespeist.
      CodeTags verbergen sich übrigens hinter dem </> Icon.
      Text dann zwischen die Anführungszeichen kopieren.
      Oder Text markieren und dann auf das Icon klicken.
      • JohreiJ Offline
        JohreiJ Offline
        Johrei
        #160
        Bekomme aber dennoch keine Datenpunkte im Verzeichnis Realtime angezeigt.
        GaspodeG 1 Antwort Letzte Antwort
        • JohreiJ Johrei
          GaspodeG Offline
          GaspodeG Offline
          Gaspode
          #161
          @johrei said in Test Adapter alpha-ess v2.0.0:
          Das ist seltsam. Das Log sieht bis auf den bekannten Fehler auf Alpha-ESS Seite (Settings_Discharge) gut aus.
          Schalte mal die Log Stufe auf Debug und poste nochmal.
          • JohreiJ Offline
            JohreiJ Offline
            Johrei
            #162
            2024-01-03 10:05:18.088 - info: host.johannes-MINI-S instance system.adapter.alpha-ess.0 started with pid 694018
            2024-01-03 10:05:18.451 - debug: alpha-ess.0 (694018) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2024-01-03 10:05:18.473 - debug: alpha-ess.0 (694018) Objects client ready ... initialize now
            2024-01-03 10:05:18.473 - debug: alpha-ess.0 (694018) Objects create System PubSub Client
            2024-01-03 10:05:18.474 - debug: alpha-ess.0 (694018) Objects create User PubSub Client
            2024-01-03 10:05:18.522 - debug: alpha-ess.0 (694018) Objects client initialize lua scripts
            2024-01-03 10:05:18.524 - debug: alpha-ess.0 (694018) Objects connected to redis: 127.0.0.1:9001
            2024-01-03 10:05:18.550 - debug: alpha-ess.0 (694018) Redis States: Use Redis connection: 127.0.0.1:9000
            2024-01-03 10:05:18.563 - debug: alpha-ess.0 (694018) States create System PubSub Client
            2024-01-03 10:05:18.563 - debug: alpha-ess.0 (694018) States create User PubSub Client
            2024-01-03 10:05:18.630 - debug: alpha-ess.0 (694018) States connected to redis: 127.0.0.1:9000
            2024-01-03 10:05:18.681 - info: alpha-ess.0 (694018) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.alpha-ess, node: v18.19.0, js-controller: 5.0.17
            2024-01-03 10:05:18.747 - debug: alpha-ess.0 (694018) Used API: Open API
            2024-01-03 10:05:18.747 - debug: alpha-ess.0 (694018) config appID: alphaf45842ae84000000
            2024-01-03 10:05:18.747 - debug: alpha-ess.0 (694018) config systemId: AL200101000000
            2024-01-03 10:05:18.747 - debug: alpha-ess.0 (694018) config oAIntervalRealtime: 30
            2024-01-03 10:05:18.748 - debug: alpha-ess.0 (694018) config oAIntervalEnergyMins: 5
            2024-01-03 10:05:18.748 - debug: alpha-ess.0 (694018) config oAIntervalSettingsChargeMins 5
            2024-01-03 10:05:18.748 - debug: alpha-ess.0 (694018) config oAIntervalSettingsDischargeMins 5
            2024-01-03 10:05:18.748 - debug: alpha-ess.0 (694018) config oAIntervalSummaryMins: 5
            2024-01-03 10:05:18.748 - debug: alpha-ess.0 (694018) config oAIntervalWallboxMins: 5
            2024-01-03 10:05:18.748 - debug: alpha-ess.0 (694018) config oAEnableRealtime: true
            2024-01-03 10:05:18.748 - debug: alpha-ess.0 (694018) config oAEnableEnergy: true
            2024-01-03 10:05:18.748 - debug: alpha-ess.0 (694018) config oAEnableSettingsCharge: true
            2024-01-03 10:05:18.748 - debug: alpha-ess.0 (694018) config oAEnableSettingsDischarge: true
            2024-01-03 10:05:18.749 - debug: alpha-ess.0 (694018) config oAEnableSummary: true
            2024-01-03 10:05:18.749 - debug: alpha-ess.0 (694018) config oAEnableWallbox: false
            2024-01-03 10:05:18.749 - debug: alpha-ess.0 (694018) config updateUnchangedStates: true
            2024-01-03 10:05:18.797 - debug: alpha-ess.0 (694018) oAIntervalRealtime: 30
            2024-01-03 10:05:18.804 - debug: alpha-ess.0 (694018) Fetching Realtime data...
            2024-01-03 10:05:19.538 - info: alpha-ess.0 (694018) Initialized states for : Realtime
            2024-01-03 10:05:19.538 - debug: alpha-ess.0 (694018) Timeout with interval 30000 ms started for group Realtime
            2024-01-03 10:05:19.538 - debug: alpha-ess.0 (694018) oAIntervalEnergyMins: 300
            2024-01-03 10:05:19.581 - debug: alpha-ess.0 (694018) Set state Energy.Battery_charge_today to val: 0; q: 2; ack: true
            2024-01-03 10:05:19.584 - debug: alpha-ess.0 (694018) Set state Energy.Battery_discharge_today to val: 0; q: 2; ack: true
            2024-01-03 10:05:19.586 - debug: alpha-ess.0 (694018) Set state Energy.Charging_pile to val: 0; q: 2; ack: true
            2024-01-03 10:05:19.588 - debug: alpha-ess.0 (694018) Set state Energy.Grid_charge to val: 0; q: 2; ack: true
            2024-01-03 10:05:19.590 - debug: alpha-ess.0 (694018) Set state Energy.Grid_consumption_today to val: 3.58; q: 2; ack: true
            2024-01-03 10:05:19.592 - debug: alpha-ess.0 (694018) Set state Energy.Grid_feed_in_today to val: 0.73; q: 2; ack: true
            2024-01-03 10:05:19.594 - debug: alpha-ess.0 (694018) Set state Energy.Generation_today to val: 1.1; q: 2; ack: true
            2024-01-03 10:05:19.596 - debug: alpha-ess.0 (694018) Fetching Energy data...
            2024-01-03 10:05:20.125 - debug: alpha-ess.0 (694018) Skipped object Energy.sysSn
            2024-01-03 10:05:20.125 - debug: alpha-ess.0 (694018) Skipped object Energy.theDate
            2024-01-03 10:05:20.126 - debug: alpha-ess.0 (694018) Created object Energy.eCharge
            2024-01-03 10:05:20.127 - debug: alpha-ess.0 (694018) Created object Energy.epv
            2024-01-03 10:05:20.127 - debug: alpha-ess.0 (694018) Created object Energy.eOutput
            2024-01-03 10:05:20.128 - debug: alpha-ess.0 (694018) Created object Energy.eInput
            2024-01-03 10:05:20.128 - debug: alpha-ess.0 (694018) Created object Energy.eGridCharge
            2024-01-03 10:05:20.129 - debug: alpha-ess.0 (694018) Created object Energy.eDischarge
            2024-01-03 10:05:20.129 - debug: alpha-ess.0 (694018) Created object Energy.eChargingPile
            2024-01-03 10:05:20.130 - info: alpha-ess.0 (694018) Initialized states for : Energy
            2024-01-03 10:05:20.174 - debug: alpha-ess.0 (694018) Received object Energy.eCharge with value 0
            2024-01-03 10:05:20.178 - debug: alpha-ess.0 (694018) Received object Energy.epv with value 1.1
            2024-01-03 10:05:20.180 - debug: alpha-ess.0 (694018) Received object Energy.eOutput with value 0.73
            2024-01-03 10:05:20.183 - debug: alpha-ess.0 (694018) Received object Energy.eInput with value 3.58
            2024-01-03 10:05:20.185 - debug: alpha-ess.0 (694018) Received object Energy.eGridCharge with value 0
            2024-01-03 10:05:20.187 - debug: alpha-ess.0 (694018) Received object Energy.eDischarge with value 0
            2024-01-03 10:05:20.189 - debug: alpha-ess.0 (694018) Received object Energy.eChargingPile with value 0
            2024-01-03 10:05:20.189 - debug: alpha-ess.0 (694018) Timeout with interval 300000 ms started for group Energy
            2024-01-03 10:05:20.189 - debug: alpha-ess.0 (694018) oAIntervalSettingsChargeMins: 300
            2024-01-03 10:05:20.233 - debug: alpha-ess.0 (694018) Set state Settings_Charge.Battery_Charging_enabled to val: false; q: 2; ack: true
            2024-01-03 10:05:20.236 - debug: alpha-ess.0 (694018) Set state Settings_Charge.Charging_period_1_start to val: 00:00; q: 2; ack: true
            2024-01-03 10:05:20.238 - debug: alpha-ess.0 (694018) Set state Settings_Charge.Charging_period 1_end to val: 00:00; q: 2; ack: true
            2024-01-03 10:05:20.240 - debug: alpha-ess.0 (694018) Set state Settings_Charge.Charging_period_2_start to val: 00:00; q: 2; ack: true
            2024-01-03 10:05:20.242 - debug: alpha-ess.0 (694018) Set state Settings_Charge.Charging_period_2_end to val: 00:00; q: 2; ack: true
            2024-01-03 10:05:20.245 - debug: alpha-ess.0 (694018) Set state Settings_Charge.Charging_stopps_at_SOC to val: 100; q: 2; ack: true
            2024-01-03 10:05:20.247 - debug: alpha-ess.0 (694018) Fetching Settings_Charge data...
            2024-01-03 10:05:20.780 - debug: alpha-ess.0 (694018) Created object Settings_Charge.gridCharge
            2024-01-03 10:05:20.781 - debug: alpha-ess.0 (694018) Subscribed State: Settings_Charge.Battery_Charging_enabled
            2024-01-03 10:05:20.783 - debug: alpha-ess.0 (694018) Created object Settings_Charge.timeChaf1
            2024-01-03 10:05:20.783 - debug: alpha-ess.0 (694018) Subscribed State: Settings_Charge.Charging_period_1_start
            2024-01-03 10:05:20.784 - debug: alpha-ess.0 (694018) Created object Settings_Charge.timeChae1
            2024-01-03 10:05:20.785 - debug: alpha-ess.0 (694018) Subscribed State: Settings_Charge.Charging_period 1_end
            2024-01-03 10:05:20.785 - debug: alpha-ess.0 (694018) Created object Settings_Charge.timeChaf2
            2024-01-03 10:05:20.786 - debug: alpha-ess.0 (694018) Subscribed State: Settings_Charge.Charging_period_2_start
            2024-01-03 10:05:20.787 - debug: alpha-ess.0 (694018) Created object Settings_Charge.timeChae2
            2024-01-03 10:05:20.787 - debug: alpha-ess.0 (694018) Subscribed State: Settings_Charge.Charging_period_2_end
            2024-01-03 10:05:20.788 - debug: alpha-ess.0 (694018) Created object Settings_Charge.batHighCap
            2024-01-03 10:05:20.789 - debug: alpha-ess.0 (694018) Subscribed State: Settings_Charge.Charging_stopps_at_SOC
            2024-01-03 10:05:20.789 - info: alpha-ess.0 (694018) Initialized states for : Settings_Charge
            2024-01-03 10:05:20.839 - debug: alpha-ess.0 (694018) Received object Settings_Charge.gridCharge with value 0
            2024-01-03 10:05:20.843 - debug: alpha-ess.0 (694018) Received object Settings_Charge.timeChaf1 with value 00:00
            2024-01-03 10:05:20.847 - debug: alpha-ess.0 (694018) Received object Settings_Charge.timeChae1 with value 00:00
            2024-01-03 10:05:20.851 - debug: alpha-ess.0 (694018) Received object Settings_Charge.timeChaf2 with value 00:00
            2024-01-03 10:05:20.854 - debug: alpha-ess.0 (694018) Received object Settings_Charge.timeChae2 with value 00:00
            2024-01-03 10:05:20.856 - debug: alpha-ess.0 (694018) Received object Settings_Charge.batHighCap with value 100
            2024-01-03 10:05:20.857 - debug: alpha-ess.0 (694018) Timeout with interval 300000 ms started for group Settings_Charge
            2024-01-03 10:05:20.857 - debug: alpha-ess.0 (694018) oAIntervalSettingsDischargeMins: 300
            2024-01-03 10:05:20.904 - debug: alpha-ess.0 (694018) Fetching Settings_Discharge data...
            2024-01-03 10:05:21.448 - error: alpha-ess.0 (694018) Alpha ESS Api returns an error! Group: Settings_Discharge
            2024-01-03 10:05:21.448 - info: alpha-ess.0 (694018) Error code: 6053 - The request was too fast, please try again later (#1)
            2024-01-03 10:05:21.496 - debug: alpha-ess.0 (694018) Timeout with interval 300000 ms started for group Settings_Discharge
            2024-01-03 10:05:21.496 - debug: alpha-ess.0 (694018) oAIntervalSummaryMins: 300
            2024-01-03 10:05:21.541 - debug: alpha-ess.0 (694018) Set state Summary.Generation_today to val: 1.1; q: 2; ack: true
            2024-01-03 10:05:21.545 - debug: alpha-ess.0 (694018) Set state Summary.Generation_total to val: 34506.2; q: 2; ack: true
            2024-01-03 10:05:21.548 - debug: alpha-ess.0 (694018) Set state Summary.Income_today to val: 0.18; q: 2; ack: true
            2024-01-03 10:05:21.551 - debug: alpha-ess.0 (694018) Set state Summary.Income_total to val: 5543.9; q: 2; ack: true
            2024-01-03 10:05:21.553 - debug: alpha-ess.0 (694018) Set state Summary.Self_consumption_total to val: 31.2; q: 2; ack: true
            2024-01-03 10:05:21.555 - debug: alpha-ess.0 (694018) Set state Summary.Self_sufficiency_total to val: 32.4; q: 2; ack: true
            2024-01-03 10:05:21.558 - debug: alpha-ess.0 (694018) Set state Summary.Trees_plantet_total to val: 5907.9; q: 2; ack: true
            2024-01-03 10:05:21.560 - debug: alpha-ess.0 (694018) Set state Summary.CO2_reduction_total to val: 29675.3; q: 2; ack: true
            2024-01-03 10:05:21.562 - debug: alpha-ess.0 (694018) Set state Summary.Currency to val: Euro; q: 2; ack: true
            2024-01-03 10:05:21.564 - debug: alpha-ess.0 (694018) Set state Summary.Consumption_today to val: 3.95; q: 2; ack: true
            2024-01-03 10:05:21.567 - debug: alpha-ess.0 (694018) Set state Summary.Grid_feed_in_today to val: 0.73; q: 2; ack: true
            2024-01-03 10:05:21.569 - debug: alpha-ess.0 (694018) Set state Summary.Grid_consumption_today to val: 3.58; q: 2; ack: true
            2024-01-03 10:05:21.571 - debug: alpha-ess.0 (694018) Set state Summary.Battery_charge_today to val: 0; q: 2; ack: true
            2024-01-03 10:05:21.573 - debug: alpha-ess.0 (694018) Set state Summary.Battery_discharge_today to val: 0; q: 2; ack: true
            2024-01-03 10:05:21.575 - debug: alpha-ess.0 (694018) Fetching Summary data...
            2024-01-03 10:05:22.768 - debug: alpha-ess.0 (694018) Created object Summary.epvtoday
            2024-01-03 10:05:22.769 - debug: alpha-ess.0 (694018) Created object Summary.epvtotal
            2024-01-03 10:05:22.770 - debug: alpha-ess.0 (694018) Created object Summary.eload
            2024-01-03 10:05:22.770 - debug: alpha-ess.0 (694018) Created object Summary.eoutput
            2024-01-03 10:05:22.770 - debug: alpha-ess.0 (694018) Created object Summary.einput
            2024-01-03 10:05:22.771 - debug: alpha-ess.0 (694018) Created object Summary.echarge
            2024-01-03 10:05:22.772 - debug: alpha-ess.0 (694018) Created object Summary.edischarge
            2024-01-03 10:05:22.772 - debug: alpha-ess.0 (694018) Created object Summary.todayIncome
            2024-01-03 10:05:22.773 - debug: alpha-ess.0 (694018) Created object Summary.totalIncome
            2024-01-03 10:05:22.774 - debug: alpha-ess.0 (694018) Created object Summary.eselfConsumption
            2024-01-03 10:05:22.775 - debug: alpha-ess.0 (694018) Created object Summary.eselfSufficiency
            2024-01-03 10:05:22.776 - debug: alpha-ess.0 (694018) Created object Summary.treeNum
            2024-01-03 10:05:22.778 - debug: alpha-ess.0 (694018) Created object Summary.carbonNum
            2024-01-03 10:05:22.779 - debug: alpha-ess.0 (694018) Created object Summary.moneyType
            2024-01-03 10:05:22.780 - info: alpha-ess.0 (694018) Initialized states for : Summary
            2024-01-03 10:05:22.830 - debug: alpha-ess.0 (694018) Received object Summary.epvtoday with value 1.1
            2024-01-03 10:05:22.833 - debug: alpha-ess.0 (694018) Received object Summary.epvtotal with value 34506.2
            2024-01-03 10:05:22.835 - debug: alpha-ess.0 (694018) Received object Summary.eload with value 3.95
            2024-01-03 10:05:22.837 - debug: alpha-ess.0 (694018) Received object Summary.eoutput with value 0.73
            2024-01-03 10:05:22.839 - debug: alpha-ess.0 (694018) Received object Summary.einput with value 3.58
            2024-01-03 10:05:22.841 - debug: alpha-ess.0 (694018) Received object Summary.echarge with value 0
            2024-01-03 10:05:22.843 - debug: alpha-ess.0 (694018) Received object Summary.edischarge with value 0
            2024-01-03 10:05:22.845 - debug: alpha-ess.0 (694018) Received object Summary.todayIncome with value 0.18
            2024-01-03 10:05:22.847 - debug: alpha-ess.0 (694018) Received object Summary.totalIncome with value 5543.9
            2024-01-03 10:05:22.851 - debug: alpha-ess.0 (694018) Received object Summary.eselfConsumption with value 0.31193
            2024-01-03 10:05:22.853 - debug: alpha-ess.0 (694018) Received object Summary.eselfSufficiency with value 0.32433
            2024-01-03 10:05:22.855 - debug: alpha-ess.0 (694018) Received object Summary.treeNum with value 5907.8901
            2024-01-03 10:05:22.857 - debug: alpha-ess.0 (694018) Received object Summary.carbonNum with value 29675.332
            2024-01-03 10:05:22.859 - debug: alpha-ess.0 (694018) Received object Summary.moneyType with value Euro
            2024-01-03 10:05:22.859 - debug: alpha-ess.0 (694018) Timeout with interval 300000 ms started for group Summary
            2024-01-03 10:05:22.859 - debug: alpha-ess.0 (694018) oAIntervalWallboxMins: 300
            2024-01-03 10:05:22.859 - info: alpha-ess.0 (694018) Wallbox data disabled! Adapter won't fetch Wallbox data. According states deleted.
            2024-01-03 10:05:22.875 - debug: alpha-ess.0 (694018) Watchdog interval started!
            Hier das Log als Debug
            die letzten Ziffern bei App ID und System ID habe ich abgeändert.
            Evtl. werden ja auch keine Realtime Daten von meiner Anlage angeboten ist ein 8 Jahre alter Storion Eco ES5
            Auf der Weboberfläche steht bei Echtzeit auch das die Daten nur alle 5 Minuten geholt werden
            • JohreiJ Johrei
              GaspodeG Offline
              GaspodeG Offline
              Gaspode
              #163
              Ja, das ist dann leider so. Im Log sieht man, dass die API keine Werte liefert. Wollte gerade fragen, welche Anlage du hast.
              Evtl. hilft ein Feature Request hier: https://github.com/alphaess-developer/alphacloud_open_api/issues
              Sorry, da sind mir leider die Hände gebunden :(
              • GaspodeG Offline
                GaspodeG Offline
                Gaspode
                #164
                ​Gute Nachrichten:
                ElevenFan hat den nervigen Bug beim Lesen der Discharge Settings Daten korrigiert. Außerdem dürfen die Werte jetzt alle 10 Minuten geschrieben werden, nicht nur alle 24 Stunden.
                Da leider der Lese-Timeout etwas erhöht wurde (auf 10 Sekunden), wird es demnächst eine neu Version 2.0.1 (zunächst im Beta Repository) geben, die sicher stellen soll, dass es beim Rücklesen nach dem Schreiben von Werten keine Fehlermeldung gibt. In dieser Version wird vor dem Rücklesen mindestens 11 Sekunden gewartet.
                • GaspodeG Offline
                  GaspodeG Offline
                  Gaspode
                  #165
                  Leider gibt es schon das nächste Problem:
                  https://github.com/alphaess-developer/alphacloud_open_api/issues/59
                  • GaspodeG Gaspode
                    Aktuelle Version v4.1.0
                    Veröffentlichungsdatum 14.02.2026
                    Github Link Verfügbar im ioBroker Beta Repository
                    dieser Adapter ist wahrscheinlich nur für einen sehr kleinen Anwenderkreis interessant.
                    Die Firma Alpha ESS vertreibt Photovoltaikanlagen mit Batteriespeicher (auf Wunsch mit USV). Die neueren Modelle haben ein Modbus Interface, mit dem sich die meisten Daten auslesen lassen.
                    Will man eine Alpha-ESS Wallbox steuern oder hat man ein älteres Modell, steht dieser Weg leider nicht zur Verfügung. Alpha ESS bietet zusätzlich noch eine Cloud API, die (derzeit) leider nicht offiziell dokumentiert ist, mit der sich insbesondere die Konfigurationsdaten der Anlage auslesen und teilweise auch modifizieren lassen.
                    Der vorliegende Adapter kann sowohl Echtzeitdaten als auch Konfigurationsdaten zyklisch auslesen und auch zu schreiben.
                    Seit Version V2.0.0 wird jetzt ausschließlich die offizielle Alpha-ESS API "OpenAPI" unterstützt. Wer sie nutzen will, muss sich und seine Anlage unter https://open.alphaess.com registrieren. Die inoffizielle "Closed API" wurde von Alpha-ESS am 2.12.2023 (wieder einmal) geändert und daher funktionierte diese Zugangsart nicht mehr. Da Alpha-ESS das bereits angekündigt hatte und dazu aufgerufen hatte, auf die "Open API" umzusteigen, habe ich die "Closed API" jetzt aus dem Adapter entfernt.
                    Das State Attribut Quality wird entsprechend des aktuellen Status gesetzt:
                    Quality meaning
                    0x00 OK and up to date
                    0x01 value not updated due to unknown reason, see debug log
                    0x02 problem with online connection for this data point
                    0x12 adapter disconnected or stopped
                    0x44 API returned error or internal error, see debug log
                    Mehr Info findet ihr in der README des Adapters
                    Viel Spaß
                    Gaspode
                    Armin 2
                    schrieb am zuletzt editiert von Armin 2
                    #166
                    @gaspode
                    Ich benutze den alpha-Ess V2.0.2
                    mit IO-Broker auf Raspery 5
                    Ich möchte besonders die Werte:
                    alpha-ess.0.Settings_Charge.Battery_Charging_enabled
                    alpha-ess.0.Settings_Charge.Charging_stopps_at_SOC
                    alpha-ess.0.Settings_Discharge.Discharging_Cutoff_SOC
                    schreiben.
                    Wenn ich den Wert im IO-Broker oder über Nodered setze
                    werden die Werte immer wieder ?? von Alpha?? überschrieben.
                    Was mache ich falsch.
                    An eine Schreibbegenzung alle 10 Minuten habe ich mich gehalten.
                    • A Armin 2
                      @gaspode
                      schreiben.
                      GaspodeG Offline
                      GaspodeG Offline
                      Gaspode
                      #167
                      @armin-2
                      Hmm, kann ich dir gerade nicht sagen. Ich hab gerade testweise Settings_Charge.Charging_stopps_at_SOC gesetzt und das hat funktioniert und der neue Wert war auch im Alpha-ESS Portal zu sehen.
                      Wie schreibst du denn die Werte genau?
                      • GaspodeG Gaspode
                        @armin-2
                        Armin 2
                        #168
                        @gaspode Im iobroker
                        Fenster Wert Schreiben:
                        Wert 30
                        WERT SETZEN
                        Im Protokoll
                        alpha-ess.0
                        2024-01-22 17:22:07.729 info Written values fror group Settings_Charge
                        Wert bleibt gesetzt.
                        Auch im Alpha Portal
                        Nächster Versuch:
                        17:44 Wert aus Node-Red 33
                        Wert ist im iobroker auch 33
                        Im Alpha Portal wird der Wert nicht gesetzt.
                        Es wird im Portokol kein INFO "Written values fror group Settings_Charge" gesetzt.
                        Wert wird nach ca. 5 Minuten wieder auf den alten Wert gesetzt.
                        • GaspodeG Offline
                          GaspodeG Offline
                          Gaspode
                          #169
                          @armin-2
                          Also direkt im Admin geht es?
                          Bin jetzt nicht so der NodeRed Fachmann, das Problem scheint dann ja eher dort zu liegen. Klingt so, als würdest du beim Schreiben per Node-Red das Attribut "Bestätigt" bzw. "Acknowledged" auf True setzen. Das würde erklären, warum der Adapter erst gar nicht versucht, zu schreiben.
                          Details dazu findest du hier: https://forum.iobroker.net/topic/61876
                            Armin 2
                            #170
                            @gaspode
                            das Achnowledged Signal war das Problem.
                            Richtig gemacht und schon gehts.
                            Danke für die Unterstützung.
                            Armin
                            • A Armin 2
                              @gaspode
                              Armin
                              GaspodeG Offline
                              GaspodeG Offline
                              Gaspode
                              #171
                              @armin-2 said in Test Adapter alpha-ess v2.0.1:
                              Alles klar, Danke für die Rückmeldung :)
                              • H Offline
                                Hehabela
                                #172
                                kann mir jemand eine Info geben, was die beiden Zeichen (Lampenschirm) bei Charging_Start und Stop bedeuten?
                                • GaspodeG Offline
                                  GaspodeG Offline
                                  Gaspode
                                  schrieb am zuletzt editiert von Gaspode
                                  #173
                                  @hehabela
                                  Das sind States mit der Rolle "Button", d.h. zu Deutsch "Knöpfe" bzw. "Taster".
                                  States mit dieser Rolle zeigen keinen Zustand an, sie sind dafür da, dass man "draufdrücken" kann und dadurch eine Aktion auslöst. Das "Ergebnis" spiegelt sich im State "Status" wider, der wechselt z.B. von 1 auf einen anderen Wert, wenn das Starten geklappt hat.
                                  • GaspodeG Gaspode
                                    Quality meaning
                                    Viel Spaß
                                    Gaspode
                                    Andreas.S
                                    #174
                                    @gaspode
                                    vielen Dank für diesen Super-Adapter für einen kleinen Kreis von Nutzern.
                                    Das Einrichten hat mit deiner Anleitung sofort Funktioniert 👍
                                    Einzig scheinen mir Datenpunkte zu fehlen, die bei anderen Nutzern (vgl. Kommentare) offenbar da sind.
                                    Insbesondere diese fehlen mir in der Version 2.0.2 ...
                                    ppv1, ppv2: [W]
                                    Summe der PV Leistung
                                    pbat: [W]
                                    Ladeleistung (-) bzw. Entladeleistung (+) der Batterie
                                    soc: [%]
                                    Batteriestand
                                    • A Andreas.S
                                      @gaspode
                                      ppv1, ppv2: [W]
                                      pbat: [W]
                                      soc: [%]
                                      Batteriestand
                                      GaspodeG Offline
                                      GaspodeG Offline
                                      Gaspode
                                      #175
                                      @andreas-s
                                      So sollten die Echtzeitwerte aussehen:
                                      Sind die anderen alle da uns passen? Welches Alpha-ESS Gerät hast du denn? Ist das Gerät korrekt in der Alpha-Cloud registriert?
                                      Ansonsten kannst du gerne mal ein Log vom Adapterstart und einen Screenshot deiner Adapterkonfiguartion posten.
                                      • GaspodeG Gaspode
                                        @andreas-s
                                        Andreas.S
                                        #176
                                        @gaspode
                                        also obwohl die Instanz gut aussieht, scheint im Protokoll einiges doch nicht sauber zu gehen.
                                        Laut Monitoring Seite heißt mein Modell SMILE-S6-HV-INV sollte aber die gleichen Werte haben.
                                        alpha-ess.0
                                        2024-04-16 19:34:35.943	info	Got terminate signal TERMINATE_YOURSELF
                                        alpha-ess.0
                                        2024-04-16 19:34:36.245	info	terminating
                                        alpha-ess.0
                                        2024-04-16 19:34:36.246	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        alpha-ess.0
                                        2024-04-16 19:34:36.448	info	terminating
                                        host.iob2022
                                        2024-04-16 19:34:36.853	info	instance system.adapter.alpha-ess.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        host.iob2022
                                        2024-04-16 19:34:57.266	info	"system.adapter.alpha-ess.0" enabled
                                        host.iob2022
                                        2024-04-16 19:34:57.528	info	instance system.adapter.alpha-ess.0 started with pid 1155099
                                        alpha-ess.0
                                        2024-04-16 19:34:59.496	info	starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.alpha-ess, node: v18.19.0, js-controller: 5.0.19
                                        alpha-ess.0
                                        2024-04-16 19:35:00.452	error	Alpha ESS Api returns an error! Group: Realtime
                                        alpha-ess.0
                                        2024-04-16 19:35:00.452	info	Error code: 6005 - This appId is not bound to the SN (#1)
                                        alpha-ess.0
                                        2024-04-16 19:35:00.453	error	Adapter won't try again to fetch any data.
                                        alpha-ess.0
                                        2024-04-16 19:35:01.041	error	Alpha ESS Api returns an error! Group: Energy
                                        alpha-ess.0
                                        2024-04-16 19:35:01.042	info	Error code: 6005 - This appId is not bound to the SN (#2)
                                        alpha-ess.0
                                        2024-04-16 19:35:01.042	error	Adapter won't try again to fetch any data.
                                        alpha-ess.0
                                        2024-04-16 19:35:01.606	error	Alpha ESS Api returns an error! Group: Settings_Charge
                                        alpha-ess.0
                                        2024-04-16 19:35:01.607	info	Error code: 6005 - This appId is not bound to the SN (#3)
                                        alpha-ess.0
                                        2024-04-16 19:35:01.609	error	Adapter won't try again to fetch any data.
                                        alpha-ess.0
                                        2024-04-16 19:35:02.194	error	Alpha ESS Api returns an error! Group: Settings_Discharge
                                        alpha-ess.0
                                        2024-04-16 19:35:02.197	info	Error code: 6005 - This appId is not bound to the SN (#4)
                                        alpha-ess.0
                                        2024-04-16 19:35:02.198	error	Adapter won't try again to fetch any data.
                                        alpha-ess.0
                                        2024-04-16 19:35:03.552	info	Initialized states for : Summary
                                        alpha-ess.0
                                        2024-04-16 19:35:03.623	info	Wallbox data disabled! Adapter won't fetch Wallbox data. According states deleted.
                                        Das sind die Datenpunkte in den Objekten
                                        • A Andreas.S
                                          @gaspode
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          host.iob2022
                                          host.iob2022
                                          host.iob2022
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          alpha-ess.0
                                          GaspodeG Offline
                                          GaspodeG Offline
                                          Gaspode
                                          #177
                                          @andreas-s said in Test Adapter alpha-ess v2.0.1:
                                          Du musst den Smile auch korrekt registrieren und an den Account binden:
                                          https://forum.iobroker.net/post/1095868
