  4. Aufhängen RPi: Keine SSH, IOBrokerAPI ('lebt' (ping))
39 Beiträge 6 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • Kanzler1959K Kanzler1959
    @thomas-braun : Ok. Das geht aber nur, wenn der RPi (SSH) lebt. Hab ich jetzt mal gemacht. Das ist aber eine Menge Zeugs ...
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: myIOBroker
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     13:48:54 up 25 min,  5 users,  load average: 0.09, 0.12, 0.21
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2024-01-18 13:48:54 CET
               Universal time: Thu 2024-01-18 12:48:54 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    dieter
    /home/dieter
    dieter adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            1.9G        1.5G        113M         15M        398M        426M
    Swap:           104M        6.0M         98M
    Total:          2.0G        1.5G        212M
             1848 M total memory
             1441 M used memory
             1288 M active memory
              306 M inactive memory
              108 M free memory
                9 M buffer memory
              370 M swap cache
               99 M total swap
                5 M used swap
               94 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
    * NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  658M     0  658M   0% /dev
    tmpfs          tmpfs     185M  1.3M  184M   1% /run
    /dev/mmcblk0p2 ext4       29G  6.7G   21G  25% /
    tmpfs          tmpfs     925M  148K  924M   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
    tmpfs          tmpfs     185M   36K  185M   1% /run/user/1000
    [Thu Jan 18 13:23:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:87:BF:19 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=2d278e7b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Thu Jan 18 13:23:50 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Jan 18 13:23:53 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    651M    /var/
    191M    /var/lib
    186M    /var/cache
    173M    /var/log
    173M    /var/cache/apt
    Archived and active journals take up 171.8M in the file system.
    /opt/iobroker/backups:
    55M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    386M    /opt/iobroker/iobroker-data/
    338M    /opt/iobroker/iobroker-data/files
    90M     /opt/iobroker/iobroker-data/files/echarts.admin
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    58M     /opt/iobroker/iobroker-data/files/echarts
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DQ00LLBD-if00-port0
    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D30IF43L-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0+dfsg-6~deb12u1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : myIOBroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : myIOBroker                               -  enabled
    + system.adapter.chromecast.0             : chromecast            : myIOBroker                               -  enabled
    + system.adapter.cloud.0                  : cloud                 : myIOBroker                               -  enabled
    + system.adapter.discovery.0              : discovery             : myIOBroker                               -  enabled
    + system.adapter.echarts.0                : echarts               : myIOBroker                               -  enabled
    + system.adapter.email.0                  : email                 : myIOBroker                               -  enabled
      system.adapter.fritzdect.0              : fritzdect             : myIOBroker                               - disabled
    + system.adapter.hm-rega.0                : hm-rega               : myIOBroker                               -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : myIOBroker                               -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : myIOBroker                               -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : myIOBroker                               -  enabled, port: 12010
    + system.adapter.influxdb.0               : influxdb              : myIOBroker                               -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : myIOBroker                               -  enabled
      system.adapter.net-tools.0              : net-tools             : myIOBroker                               - disabled
    + system.adapter.nuki-extended.0          : nuki-extended         : myIOBroker                               -  enabled
      system.adapter.ping.0                   : ping                  : myIOBroker                               - disabled
    + system.adapter.smartmeter.0             : smartmeter            : myIOBroker                               -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : myIOBroker                               -  enabled
    + system.adapter.synology.0               : synology              : myIOBroker                               -  enabled, port: 5000
    + system.adapter.tr-064.0                 : tr-064                : myIOBroker                               -  enabled
    + system.adapter.tr-064.1                 : tr-064                : myIOBroker                               -  enabled
    + system.adapter.tr-064.2                 : tr-064                : myIOBroker                               -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : myIOBroker                               -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : myIOBroker                               -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : myIOBroker                               -  enabled
      system.adapter.vis-metro.0              : vis-metro             : myIOBroker                               -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : myIOBroker                               -  enabled
      system.adapter.vis.0                    : vis                   : myIOBroker                               -  enabled
    + system.adapter.web.0                    : web                   : myIOBroker                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.5.4  [Updatable]
    Adapter    "email"        : 1.2.1    , installed 1.2.1
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "smartmeter"   : 3.4.0    , installed 3.3.4  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "tuya"         : 3.15.0   , installed 3.14.2 [Updatable]
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.0.0  [Updatable]
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        2822
    States:         2298
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 37
    *** Listening Ports ***
    tcp        0      0 192.168.178.152:18701   0.0.0.0:*               LISTEN      1001       20358      2275/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17673      822/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17022      809/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18314      809/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17681      808/cupsd
    tcp        0      0 192.168.178.152:12010   0.0.0.0:*               LISTEN      1001       20376      2290/io.hm-rpc.2
    tcp        0      0 192.168.178.152:12001   0.0.0.0:*               LISTEN      1001       21977      2268/io.hm-rpc.1
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17675      822/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       24596      2459/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20160      2016/io.admin.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17680      808/cupsd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          19407      2009/cups-browsed
    udp        0      0 0.0.0.0:38887           0.0.0.0:*                           104        16459      613/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22778      2384/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16457      613/avahi-daemon: r
    udp6       0      0 :::46066                :::*                                104        16460      613/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        16458      613/avahi-daemon: r
    udp6       0      0 fe80::17b2:afcf:15c:546 :::*                                0          13250      749/NetworkManager
    2024-01-18 13:49:35.682  - info: smartmeter.0 (2395) Received 13 values, 8 updated
    2024-01-18 13:49:37.366  - info: smartmeter.1 (2410) Received 13 values, 8 updated
    2024-01-18 13:49:41.720  - info: smartmeter.0 (2395) Received 13 values, 9 updated
    2024-01-18 13:49:43.373  - info: smartmeter.1 (2410) Received 13 values, 9 updated
    2024-01-18 13:49:47.699  - info: smartmeter.0 (2395) Received 13 values, 9 updated
    2024-01-18 13:49:49.361  - info: smartmeter.1 (2410) Received 13 values, 9 updated
    2024-01-18 13:49:53.688  - info: smartmeter.0 (2395) Received 13 values, 9 updated
    2024-01-18 13:49:55.415  - info: smartmeter.1 (2410) Received 13 values, 9 updated
    2024-01-18 13:49:59.676  - info: smartmeter.0 (2395) Received 13 values, 9 updated
    2024-01-18 13:50:01.407  - info: smartmeter.1 (2410) Received 13 values, 9 updated
    2024-01-18 13:50:05.679  - info: smartmeter.0 (2395) Received 13 values, 8 updated
    2024-01-18 13:50:07.382  - info: smartmeter.1 (2410) Received 13 values, 8 updated
    2024-01-18 13:50:11.702  - info: smartmeter.0 (2395) Received 13 values, 8 updated
    2024-01-18 13:50:13.374  - info: smartmeter.1 (2410) Received 13 values, 8 updated
    2024-01-18 13:50:17.705  - info: smartmeter.0 (2395) Received 13 values, 8 updated
    2024-01-18 13:50:19.368  - info: smartmeter.1 (2410) Received 13 values, 8 updated
    2024-01-18 13:50:25.005  - info: smartmeter.0 (2395) Received 13 values, 9 updated
    2024-01-18 13:50:25.378  - info: smartmeter.1 (2410) Received 13 values, 9 updated
    2024-01-18 13:50:29.715  - info: smartmeter.0 (2395) Received 13 values, 9 updated
    2024-01-18 13:50:31.379  - info: smartmeter.1 (2410) Received 13 values, 8 updated
    2024-01-18 13:50:35.677  - info: smartmeter.0 (2395) Received 13 values, 9 updated
    2024-01-18 13:50:37.357  - info: smartmeter.1 (2410) Received 13 values, 7 updated
    2024-01-18 13:50:41.736  - info: smartmeter.0 (2395) Received 13 values, 9 updated
    2024-01-18 13:50:43.361  - info: smartmeter.1 (2410) Received 13 values, 8 updated
    2024-01-18 13:50:47.702  - info: smartmeter.0 (2395) Received 13 values, 9 updated
    Mir fällt auf:
    CodierknechtC Offline
    Codierknecht
    @kanzler1959
    Mit ihren knapp 30 Instanzen dürfte die Kiste so ziemlich am Rand der Leistungsfähigkeit kratzen.
    Insbesondere wenn da noch zusätzliche Dinge wie InfluxDb installiert sind oder backitup startet.
    Discovery kannst Du eigentlich rauswerfen. Das braucht man nicht wirklich, wenn die Kiste einmal eingerichtet ist.
    Wozu 3x tr-064?
    Wozu 3x hm-rpc?
    Wozu 2x smartmeter?
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
      @homoran : Mein Fehler - ist ein RPi4
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @kanzler1959
      Sollte vll auch noch beachtet werden dass bei einem RPI mit 2GB da definitiv zu viele Adapter drauf laufen.
      Daraus wird mMn auch der "Absturz" um 2:07 Uhr führen weil Du (wahrscheinlich) Dein Backup um 2:05 Uhr laufen lässt.
      Lehrling seit 1975 !!!
      Kanzler1959K 1 Antwort Letzte Antwort
        @kanzler1959
        sudo systemctl set-default multi-user.target
        echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Wenn die Kiste wieder online ist:
        iobroker update
        iobroker upgrade all
        Kanzler1959K Offline
        Kanzler1959
        @thomas-braun : Hallo - auch an die anderen
        Ich werde jetzt brav alles abarbeiten ... und noch mal brav posten,
        Hätte nicht gedacht, das eine 'Standard-Installation' (ich habe ja den IOBroker beim ersten Start suchen lassen) schon zu einer Überlastung führt. Da werde ich dann wohl was rauswerfen müssen.
        Raspberry Pi 4 Model B Rev 1.5 (IOBroker, SSD 128G)
        Huawei Sun2000 WR & LUNA Speicher
        HomeMatic CCU3 (mit allerlei ...)
        Diverses (Sockets, Dallas via ESP, Shellys ...)
        Visualisierrung via Grafana
        Synology NAS
        und einige Fritzboxen für die Abdeckung
        • DJMarc75D DJMarc75
          @kanzler1959
          Kanzler1959
          @djmarc75 : Der Absturz war nach exakt einem Tag und zwei Minuten (02m07s). Das Backup läuft um 02:40 in der frühen Nacht. Ziel: FTP (NAS). Ich werde - auch weil das alle schreiben - die Adapter mal ausmisten. Sind halt alle 'automatisch' hinzugekommen.
          Synology NAS
            @kanzler1959 sagte in Aufhängen RPi: Keine SSH, IOBrokerAPI ('lebt' (ping)):
            Das hängt halt davon ab, welche Hardware die mit deiner 'Standard-Installation' zurecht kommen muss.
            • Kanzler1959K Offline
              Kanzler1959
              @codierknecht :
              Ok - Nochmal ... ich habe 'einfach' alles suchen lassen, was es bei mir im Hause so gibt.
              • BackItUp ist drauf und startet um 02:40 in Richtung NAS.
              • Ich habe halt drei FB (als Accesspoints verteilt). Da man von den Dingern aber sowieso nix vernüftiges bekommt fliegen Die nun raus. Danke soweit.
              • Die drei hm-rpc wurden so initial erstellt, und beinhalten auch verschiedene Geräte - hat mich auch gewundert, warumn nicht alles in einer Instanz ist. Muss mal sehen ob ich alles brauche.
              • zwei Smartmeter - ich habe halt zwei Zähler und damit zwei (USB) Adapter. Habe eine Wärmepumpe mit speziellen Tarif. Da ich nun auch noch 'Strom vom Dach' habe auch noch eine spezielle Verschaltung (Kaskadenschaltung (quasi beider Zähler hintereinander)).
              --> bin schon mal auf 1.1G RAM runter
              Synology NAS
                Hätte nicht gedacht, das eine 'Standard-Installation' ... schon zu einer Überlastung führt.
                naja
                @homoran sagte in Aufhängen RPi: Keine SSH, IOBrokerAPI ('lebt' (ping)):
                22 aktive Adapter bei 2 GB RAM ist auch schon sportlich.
                und nicht Standard.
                Und wahrscheinlich
                @codierknecht sagte in Aufhängen RPi: Keine SSH, IOBrokerAPI ('lebt' (ping)):
                Wozu 3x tr-064?
                Wozu 3x hm-rpc?
                Wozu 2x smartmeter?
                ohne Not mehrfach installiert ohne zu hinterfragen
                was allein für die Kompression massiv RAM benötigt
                Wenn dann noch scheduled Adapters dazukommen, insbesondere Backitup, dann knallt's im MEM
                  weiss ich 😁
                  Mir fällt auf:
                  und mir
                  Pending Updates: 37
                  im Betriebssystem und 5 Adapter
                  22 aktive Adapter bei 2 GB RAM ist auch sch8n sportlich.
                  Kanzler1959
                  und mir
                  Pending Updates: 37
                  Ok. Ich habe ausgemistet. Bei manchen Adaptern bin ich mit aber nicht sicher, ob Ich Sie 'einfach' rauswerfen sollte. Nehmen Adapter ohne Instanz auch RAM weg? Kann man sehen, wieviel RAM ein Adapter / Instanz hat?
                  Synology NAS
                    und mir
                    Pending Updates: 37
                    @kanzler1959
                    Die obigen Maßnahmen durchgeacker?
                    Wie schaut
                    iob diag
                    nun aus?
                      naja
                      und nicht Standard.
                      Und wahrscheinlich
                      Wozu 3x tr-064?
                      Wozu 3x hm-rpc?
                      Wozu 2x smartmeter?
                      Kanzler1959
                      und nicht Standard.
                      ==> Ich habe halt nur nach "Anleitung" gearbeitet. Dort (von verschiedenen Seiten) wurde halt gesagt "lass den IOBroker mal suchen" ... mag falsch sein. Habe aber nichts kompaktes 'für Dummies' gefunden.
                      Wozu 3x tr-064?
                      Wozu 3x hm-rpc?
                      Wozu 2x smartmeter?
                      ==> Nicht wirklich.
                      Nochmal: 3x tr-064 und 3x hm-rpc sind beim initialen Lauf entstanden
                      Und die zwei Instanzen des Smartmeters brauche ich ja, da es zwei Meter/Geber sind.
                      Oder geht das anders?
                      ==> Aber eine sinnvolle Sache ist?!
                      Bin jetzt auf gut 1G RAM runter:
                      Mit macht aber der SWAP Bereich noch Sorgen.
                      Synology NAS
                        und nicht Standard.
                        Wozu 3x tr-064?
                        Wozu 3x hm-rpc?
                        Wozu 2x smartmeter?
                        ==> Nicht wirklich.
                        @kanzler1959
                        Bitte keine Screenshots von Text. Dafür gibt es die CodeTags...
                        Und besser
                        free -ht --mega
                        verwenden. Ist besser verständlich.
                          @kanzler1959
                          Wie schaut
                          iob diag
                          nun aus?
                          Kanzler1959
                          @thomas-braun said in Aufhängen RPi: Keine SSH, IOBrokerAPI ('lebt' (ping)):
                          @kanzler1959
                          Wie schaut
                          iob diag
                          nun aus?
                          Immer langsam: Schritt für Schritt; Schön dokumentieren was man gemacht hat ...
                          Nun noch die Updates und dann werden wir sehen (in einem Monat im besten Falle ;-)
                          Synology NAS
                            @kanzler1959
                            Und besser
                            free -ht --mega
                            Kanzler1959
                            @kanzler1959
                            Und besser
                            free -ht --mega
                            dieter@myIOBroker:~ $ free -ht --mega
                            Mem:            1.9G        1.3G        356M         15M        391M        661M
                            Swap:           104M        104M        729K
                            Total:          2.0G        1.4G        357M
                            Synology NAS
                              @kanzler1959
                              sudo apt update
                              sudo reboot
                              iobroker update
                              Kanzler1959
                              Was macht
                              sudo systemctl set-default multi-user.target"
                              echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref"
                              genau (damit ich was lerne)?
                              Und ich habe auch gesehen, das ich dann doch ein wenig mehr als jungfräulich war/bin. Insbesondere in der Visualisierung habe ich schon Experimente gemacht. Ich will ja am Ende auch sehen, was meine Verbräuche sind.
                              Und am Ende sind es doch wieder 1.3G - nachdem ich vor dem IOBroker Upgrade 0.9G hatte.
                              Wir werden sehen ...
                              Synology NAS
                                Was macht
                                Zeile 1 setzt das System auf das boot-Target 'multi-user', d.h. ohne Desktop-Mumpitz.
                                Zeile 2 setzt die Installations-Priorität der 'nodesource'-Quelle auf 'nimm das immer von dort, egal wie hoch die Versionsnummern aus anderen Quellen ist'.
                                  @kanzler1959
                                  Wie schaut
                                  iob diag
                                  nun aus?
                                  Kanzler1959
                                  @kanzler1959 said in Aufhängen RPi: Keine SSH, IOBrokerAPI ('lebt' (ping)):
                                  @kanzler1959
                                  Wie schaut
                                  iob diag
                                  nun aus?
                                  Bitteschön:
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                   16:02:36 up 21 min,  4 users,  load average: 0.12, 0.35, 0.60
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Thu 2024-01-18 16:02:36 CET
                                             Universal time: Thu 2024-01-18 15:02:36 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  dieter
                                  /home/dieter
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  Boot Target:    multi-user.target
                                  *** MEMORY ***
                                  Mem:            1.9G        1.2G        515M        1.3M        296M        738M
                                  Swap:           104M          0B        104M
                                  Total:          2.0G        1.2G        620M
                                           1848 M total memory
                                           1143 M used memory
                                           1213 M active memory
                                             13 M inactive memory
                                            491 M free memory
                                             11 M buffer memory
                                            271 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  0 loaded units listed.
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs     185M  1.2M  184M   1% /run
                                  /dev/mmcblk0p2 ext4       29G  6.7G   20G  26% /
                                  tmpfs          tmpfs     925M  8.0K  925M   1% /dev/shm
                                  tmpfs          tmpfs     185M   32K  185M   1% /run/user/1000
                                  [Thu Jan 18 15:41:19 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:87:BF:19 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=2d278e7b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                                  [Thu Jan 18 15:41:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Thu Jan 18 15:41:25 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  /var:
                                  670M    /var/
                                  192M    /var/log/journal/801820c1aba041bb835071924f157206
                                  192M    /var/log
                                  191M    /var/lib
                                  Archived and active journals take up 191.2M in the file system.
                                  393M    /opt/iobroker/iobroker-data/
                                  334M    /opt/iobroker/iobroker-data/files
                                  89M     /opt/iobroker/iobroker-data/files/echarts.admin
                                  57M     /opt/iobroker/iobroker-data/files/echarts
                                  24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                  23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Candidate: 18.19.0-1nodesource1
                                    Version table:
                                   *** 18.19.0-1nodesource1 1001
                                       18.18.2-1nodesource1 1001
                                       18.18.1-1nodesource1 1001
                                       18.18.0-1nodesource1 1001
                                       18.17.1-1nodesource1 1001
                                       18.17.0-1nodesource1 1001
                                       18.16.1-1nodesource1 1001
                                       18.16.0-1nodesource1 1001
                                       18.15.0-1nodesource1 1001
                                       18.14.2-1nodesource1 1001
                                       18.14.1-1nodesource1 1001
                                       18.14.0-1nodesource1 1001
                                       18.13.0+dfsg1-1 500
                                       18.13.0-1nodesource1 1001
                                       18.12.0-1nodesource1 1001
                                       18.11.0-1nodesource1 1001
                                       18.10.0-1nodesource1 1001
                                       18.9.1-1nodesource1 1001
                                       18.9.0-1nodesource1 1001
                                       18.8.0-1nodesource1 1001
                                       18.7.0-1nodesource1 1001
                                       18.6.0-1nodesource1 1001
                                       18.5.0-1nodesource1 1001
                                       18.4.0-1nodesource1 1001
                                       18.3.0-1nodesource1 1001
                                       18.2.0-1nodesource1 1001
                                       18.1.0-1nodesource1 1001
                                       18.0.0-1nodesource1 1001
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.12.0
                                  javascript:     7.1.6
                                  Adapter State
                                  + instance is alive
                                  Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                  Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                  Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                  Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                                  Objects and States
                                  Objects:        2702
                                  States:         2207
                                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16761      799/sshd: /usr/sbin
                                  tcp        0      0 192.168.178.152:18701   0.0.0.0:*               LISTEN      1001       18488      995/io.hm-rpc.0
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3867       790/cupsd
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16822      791/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3924       791/iobroker.js-con
                                  tcp        0      0 192.168.178.152:12001   0.0.0.0:*               LISTEN      1001       17807      1076/io.hm-rpc.1
                                  tcp        0      0 192.168.178.152:12010   0.0.0.0:*               LISTEN      1001       17147      1091/io.hm-rpc.2
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          16763      799/sshd: /usr/sbin
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17244      1181/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16847      878/io.admin.0
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3866       790/cupsd
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16676      605/avahi-daemon: r
                                  udp        0      0 0.0.0.0:55669           0.0.0.0:*                           104        16678      605/avahi-daemon: r
                                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17616      958/cups-browsed
                                  udp6       0      0 :::5353                 :::*                                104        16677      605/avahi-daemon: r
                                  udp6       0      0 fe80::17b2:afcf:15c:546 :::*                                0          3922       736/NetworkManager
                                  udp6       0      0 :::35376                :::*                                104        16679      605/avahi-daemon: r
                                  2024-01-18 16:02:44.509  - info: smartmeter.0 (1436) Received 13 values, 8 updated
                                  2024-01-18 16:02:50.266  - info: smartmeter.1 (1443) Received 13 values, 9 updated
                                  2024-01-18 16:02:50.510  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  2024-01-18 16:02:56.278  - info: smartmeter.1 (1443) Received 13 values, 8 updated
                                  2024-01-18 16:02:56.541  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  2024-01-18 16:03:02.271  - info: smartmeter.1 (1443) Received 13 values, 9 updated
                                  2024-01-18 16:03:02.532  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  2024-01-18 16:03:08.299  - info: smartmeter.1 (1443) Received 13 values, 9 updated
                                  2024-01-18 16:03:08.531  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  2024-01-18 16:03:14.264  - info: smartmeter.1 (1443) Received 13 values, 8 updated
                                  2024-01-18 16:03:14.531  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  2024-01-18 16:03:20.262  - info: smartmeter.1 (1443) Received 13 values, 8 updated
                                  2024-01-18 16:03:20.529  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  2024-01-18 16:03:26.258  - info: smartmeter.1 (1443) Received 13 values, 9 updated
                                  2024-01-18 16:03:26.539  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  2024-01-18 16:03:32.259  - info: smartmeter.1 (1443) Received 13 values, 9 updated
                                  2024-01-18 16:03:32.512  - info: smartmeter.0 (1436) Received 13 values, 8 updated
                                  2024-01-18 16:03:38.268  - info: smartmeter.1 (1443) Received 13 values, 9 updated
                                  2024-01-18 16:03:38.525  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  2024-01-18 16:03:44.273  - info: smartmeter.1 (1443) Received 13 values, 9 updated
                                  2024-01-18 16:03:44.527  - info: smartmeter.0 (1436) Received 13 values, 8 updated
                                  2024-01-18 16:03:50.292  - info: smartmeter.1 (1443) Received 13 values, 8 updated
                                  2024-01-18 16:03:50.524  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  2024-01-18 16:03:56.269  - info: smartmeter.1 (1443) Received 13 values, 9 updated
                                  2024-01-18 16:03:56.620  - info: smartmeter.0 (1436) Received 13 values, 9 updated
                                  Synology NAS
                                    @kanzler1959
                                    Wie schaut
                                    iob diag
                                    nun aus?
                                    Bitteschön:
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    dieter
                                    /home/dieter
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           104M          0B        104M
                                             1848 M total memory
                                             1143 M used memory
                                              491 M free memory
                                               11 M buffer memory
                                              271 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    670M    /var/
                                    192M    /var/log
                                    191M    /var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    javascript:     7.1.6
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        2702
                                    States:         2207
                                    Pending Updates: 0
                                    Die beiden
                                    smartmeter-Instanzen würde ich im LogLevel herabsetzen.
                                    Und auch prüfen, ob die beide im Sekundentakt laufen müssen.
                                      Die beiden
                                      Kanzler1959
                                      @thomas-braun :
                                      Ok. Bringt die Last runter.
                                      Letzte Frage:
                                      Wie ist das mit dem Speicher? Brauchen Adapter ohne Instanz RAM?
                                      Synology NAS
                                        @thomas-braun :
                                        Letzte Frage:
                                        Meister MopperM Online
                                        Meister Mopper
                                        What you see is what you consume (wysiwyc).
                                        Proxmox und HA ...
                                          Kanzler1959
                                          @meister-mopper said in Aufhängen RPi: Keine SSH, IOBrokerAPI ('lebt' (ping)):
                                          Was die Frage nicht (oder mit NEIN) beantwortet: Brauchen Adapter ohne Instanz RAM.
                                          Im Bild sehe ich RAM per Instanz - das ist ja klar.
                                          In C++ zum Beispiel benötigt die Klasse auch kein RAM (solange es Execute In Place ist). Erst durch die Instanziierung (-->Objekt) wird dann RAM benötigt. Da es hier aber ein Linux ist, das vermutlich im komplett ins RAM geladen wird, ist es sicher anders? Dahin geht die Frage. Ich hatte den Eindruck - beim Ausmisten - das es nichts bringt, die Adapter zu löschen?!
                                          Synology NAS
                                          Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
