  4. Start aus Backup *gelöst*
51 Beiträge 5 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • G gluecksmann
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     16:40:22 up  1:46,  1 user,  load average: 2.58, 1.95, 1.55
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-01-14 16:40:25 CET
               Universal time: Sun 2024-01-14 15:40:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:           7.9G        353M        6.7G        8.0M        812M        7.3G
    Swap:           99M          0B         99M
    Total:         8.0G        353M        6.8G
             7898 M total memory
              352 M used memory
              517 M active memory
              445 M inactive memory
             6732 M free memory
              239 M buffer memory
              573 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   14G   14G  50% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Sun Jan 14 14:53:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Jan 14 14:53:46 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Jan 14 14:53:46 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Jan 14 14:53:48 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    404M    /var/
    118M    /var/lib
    102M    /var/cache
    90M     /var/cache/apt
    82M     /var/log
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    68M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    595M    /opt/iobroker/iobroker-data/
    313M    /opt/iobroker/iobroker-data/files
    144M    /opt/iobroker/iobroker-data/backup-objects
    94M     /opt/iobroker/iobroker-data/sonosCache
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @iobroker/socket-classes@1.4.6 /opt/iobroker/node_modules/@iobroker/socket-classes
    npm ERR! extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
    npm ERR! extraneous: @iobroker/ws-server@2.1.2 /opt/iobroker/node_modules/@iobroker/ws-server
    npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
    npm ERR! extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
    npm ERR! extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
    npm ERR! extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
    npm ERR! extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
    npm ERR! extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
    npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
    npm ERR! extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
    npm ERR! extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
    npm ERR! extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
    npm ERR! extraneous: @types/long@4.0.2 /opt/iobroker/node_modules/@types/long
    npm ERR! extraneous: ajv@8.12.0 /opt/iobroker/node_modules/ajv
    npm ERR! extraneous: archiver-utils@4.0.1 /opt/iobroker/node_modules/archiver-utils
    npm ERR! extraneous: archiver@6.0.1 /opt/iobroker/node_modules/archiver
    npm ERR! extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
    npm ERR! extraneous: compress-commons@5.0.1 /opt/iobroker/node_modules/compress-commons
    npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
    npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
    npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
    npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser
    npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie
    npm ERR! extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
    npm ERR! extraneous: crc32-stream@5.0.0 /opt/iobroker/node_modules/crc32-stream
    npm ERR! extraneous: express-fileupload@1.4.3 /opt/iobroker/node_modules/express-fileupload
    npm ERR! extraneous: express-session@1.17.3 /opt/iobroker/node_modules/express-session
    npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
    npm ERR! extraneous: iobroker.sonoff@3.0.3 /opt/iobroker/node_modules/iobroker.sonoff
    npm ERR! extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
    npm ERR! extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
    npm ERR! extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
    npm ERR! extraneous: long@4.0.0 /opt/iobroker/node_modules/long
    npm ERR! extraneous: mime@3.0.0 /opt/iobroker/node_modules/mime
    npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
    npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
    npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
    npm ERR! extraneous: passport@0.6.0 /opt/iobroker/node_modules/passport
    npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause
    npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
    npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
    npm ERR! extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
    npm ERR! extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
    npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
    npm ERR! extraneous: zip-stream@5.0.1 /opt/iobroker/node_modules/zip-stream
    npm ERR! extraneous: bytes@3.0.0 /opt/iobroker/node_modules/compression/node_modules/bytes
    npm ERR! extraneous: cookie@0.4.2 /opt/iobroker/node_modules/express-session/node_modules/cookie
    npm ERR! extraneous: safe-buffer@5.2.1 /opt/iobroker/node_modules/express-session/node_modules/safe-buffer
    npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/iobroker.admin/node_modules/semver
    npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/lazystream/node_modules/readable-stream
    npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/lazystream/node_modules/string_decoder
    npm ERR! invalid: string_decoder@1.3.0 /opt/iobroker/node_modules/string_decoder
    npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
    npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms
    npm ERR! invalid: protobufjs@ /opt/iobroker/node_modules/protobufjs
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-14T15_40_34_077Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          "admin" not found
    javascript:     7.1.6
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-14T15_40_54_148Z-debug-0.log
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
      system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
      system.adapter.govee.0                  : govee                 : raspberrypi                              - disabled
      system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
      system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.info.0                   : info                  : raspberrypi                              - disabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
      system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              - disabled
      system.adapter.musiccast.0              : musiccast             : raspberrypi                              - disabled
      system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
      system.adapter.netatmo.0                : netatmo               : raspberrypi                              - disabled
      system.adapter.philips-air.0            : philips-air           : raspberrypi                              - disabled
      system.adapter.philips-air.1            : philips-air           : raspberrypi                              - disabled
      system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
      system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
      system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
      system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
      system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
      system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.admin/io-package.json: /opt/iobroker/node_modules/iobroker.admin/io-package.json: Unexpected end of JSON input
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
    Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "meross"       : 1.17.0   , installed 1.16.1 [Updatable]
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.0.0  [Updatable]
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "zigbee"       : 1.9.7    , installed 1.8.24 [Updatable]
    Objects and States
    Objects:        11186
    States:         8901
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16886      641/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14852      365/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       45899      9623/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       45892      9623/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16888      641/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14851      365/cupsd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17522      631/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16544      484/cups-browsed
    udp        0      0 0.0.0.0:42683           0.0.0.0:*                           108        16161      372/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16159      372/avahi-daemon: r
    udp6       0      0 :::41952                :::*                                108        16162      372/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16570      631/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        16160      372/avahi-daemon: r
    2024-01-14 16:40:45.597  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:122:24)
    2024-01-14 16:40:45.597  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run_main_module:28:49 {
    2024-01-14 16:40:45.598  - error: host.raspberrypi Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.admin/package.json'
    2024-01-14 16:40:45.598  - error: host.raspberrypi Caught by controller[0]: }
    2024-01-14 16:40:45.599  - error: host.raspberrypi Caught by controller[1]: Node.js v18.19.0
    2024-01-14 16:40:45.599  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-14 16:40:45.600  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2024-01-14 16:41:15.734  - error: host.raspberrypi startInstance admin.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.admin/package.json"
    2024-01-14 16:41:15.749  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 10027
    2024-01-14 16:41:16.203  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/package_json_reader:92
    2024-01-14 16:41:16.204  - error: host.raspberrypi Caught by controller[0]:         throw error;
    2024-01-14 16:41:16.205  - error: host.raspberrypi Caught by controller[0]:         ^
    2024-01-14 16:41:16.205  - error: host.raspberrypi Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.admin/package.json: Unexpected end of JSON input
    2024-01-14 16:41:16.205  - error: host.raspberrypi Caught by controller[0]:     at parse (<anonymous>)
    2024-01-14 16:41:16.206  - error: host.raspberrypi Caught by controller[0]:     at read (node:internal/modules/package_json_reader:79:16)
    2024-01-14 16:41:16.206  - error: host.raspberrypi Caught by controller[0]:     at readPackage (node:internal/modules/package_json_reader:140:10)
    2024-01-14 16:41:16.206  - error: host.raspberrypi Caught by controller[0]:     at readPackageScope (node:internal/modules/package_json_reader:157:19)
    2024-01-14 16:41:16.207  - error: host.raspberrypi Caught by controller[0]:     at shouldUseESMLoader (node:internal/modules/run_main:77:15)
    2024-01-14 16:41:16.207  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:122:24)
    2024-01-14 16:41:16.208  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run_main_module:28:49 {
    2024-01-14 16:41:16.208  - error: host.raspberrypi Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.admin/package.json'
    2024-01-14 16:41:16.208  - error: host.raspberrypi Caught by controller[0]: }
    2024-01-14 16:41:16.209  - error: host.raspberrypi Caught by controller[0]: Node.js v18.19.0
    2024-01-14 16:41:16.209  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-14 16:41:16.209  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    @gluecksmann
    Buster ist tot. Muss ersetzt werden.
    Installier da NEU ein 64Bit Bookworm.
    G 1 Antwort Letzte Antwort
      @gluecksmann
      gluecksmann
      Mhhhh... werde das dann wohl mal machen müssen...wobei es ja vorher lief...
      • G gluecksmann
        @gluecksmann sagte in Start aus Backup:
        das heisst nichts.
        jetzt ist jetzt.
        nachdem ich heute Vomittag ein Backup über den Backitup Adapter eingespielt habe
        wie alt?
        welche Grundkonfiguration in dem Backup?
        welche jetzt?
        • G gluecksmann
          @gluecksmann
          Es läuft immer vorher, bis es eben nicht mehr läuft.
          Ich vermute du hast den Back-up-Prozess unterbrochen. Das kann geraume Zeit dauern.
            @gluecksmann
            gluecksmann
            na da hoffe ich das das Backup nachts "gut" ist.... Suche jetzt mal eine neue Speicherkarte...
            • G gluecksmann
              gluecksmann
              @gluecksmann
              Hat jetzt scheinbar geklappt...bin aber das Problem mit Zigbee nicht losgeworden...
              2024-01-14 20:12:42.572  - error: zigbee.0 (14059) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              was denn nun schon wieder? Ist doch alles neu und frisch...
              • G gluecksmann
                @gluecksmann
                Vielleicht gerade deswegen.
                wie ist die Konfiguration von der Instanz?
                  gluecksmann
                  wenn ich in die Instanz gehe, begrüßt mich diese Fehlermeldung...
                  • G gluecksmann
                    @gluecksmann
                    Schau in das LogFile rein und guck was der Adapter da zu melden hat.
                    Ein CC2531 ist allerdings auch mittlerweile veraltet. Würde ich eh austauschen.
                    G 2 Antworten Letzte Antwort
                      @gluecksmann
                      gluecksmann
                      • G gluecksmann
                        @gluecksmann
                        Keine Screenshots.
                        Schau in die Datei.
                        iob logs --watch
                        Beobachte da einen Neustart.
                          @gluecksmann
                          gluecksmann
                          was austauschen? Geht es um den Zigbee Stick? Da hatte ich nach Empfehlungen gefragt..bekam aber keine für mich als DAU User verwertbaren Antworten..
                          • G gluecksmann
                            @gluecksmann dein /dev/by-id in der Konfiguration scheint bei der list of ports nicht dabei zu sein.
                            Du solltest aber doch inzwischen wissen dass logs als Text in code-tags gepostet werden
                            • G gluecksmann
                              Ja.
                              Nimm einen aus dieser Liste:
                              https://www.zigbee2mqtt.io/guide/adapters/#recommended
                                @gluecksmann
                                Keine Screenshots.
                                Schau in die Datei.
                                iob logs --watch
                                gluecksmann
                                @thomas-braun sagte in Start aus Backup:
                                iob logs --watch
                                2024-01-14 20:21:59.992  - error: zigbee.0 (14059) getGroups: caught error: Type        Error: Cannot read properties of undefined (reading 'getGroups')
                                • G gluecksmann
                                  iob logs --watch
                                  @gluecksmann
                                  Den ganzen Neustart des Adapters anschauen. Da steht deutlich mehr drin.
                                  • crunchipC Offline
                                    crunchipC Offline
                                    Einstellungen sind
                                    irgendwelche bindings/Gruppen angelegt?
                                      Einstellungen sind
                                      gluecksmann
                                      schrieb am zuletzt editiert von gluecksmann
                                      @crunchip
                                      Komisch...jetzt funktioniert es... gehe ich Recht in der Annahme, das ich bei einem neuem Zigbee Stick alles neu anlernen muß?
                                        Ja.
                                        gluecksmann
                                        Gibt es da Quellen die man nicht nutzen sollte? Wenn ich mit den Sonoff Stock anschauen kostet der bei Amazon das doppelte wie bei Ali ...
                                        • G gluecksmann
                                          @gluecksmann
                                          Die Vor- und Nachteile eines Kaufs bei den verschiedenen Shops kann ich dir nicht auseinander rupfen. Musst du selber entscheiden.
