  4. ZigBee neue Version 1.9.x
1.9converterzhczigbee
120 Beiträge 28 Kommentatoren 33.0k Aufrufe 28 Beobachtet
  • coyoteC coyote
    Adapter nochmal neu gestartet, sieht dann so im Log aus:
    zigbee.0
    2024-01-11 18:43:36.872	warn	Send command to 0x0017880100e3af59 failed with: Code 205 (No network route)
    admin.0
    2024-01-11 18:43:23.750	info	<== Disconnect system.user.admin from ::ffff:192.168.66.80
    admin.0
    zigbee.0
    2024-01-11 18:42:40.576	warn	DeviceAvailability:Failed to ping 0xa4c13882d1086da6 TS011F
    zigbee.0
    2024-01-11 18:42:40.362	warn	DeviceAvailability:Failed to ping 0xa4c138c56e482534 TS011F
    zigbee.0
    2024-01-11 18:42:40.190	warn	DeviceAvailability:Failed to ping 0xa4c1385a00722ee7 TS011F
    zigbee.0
    2024-01-11 18:42:40.075	warn	DeviceAvailability:Failed to ping 0xec1bbdfffea57729 TS011F
    zigbee.0
    2024-01-11 18:42:39.968	warn	DeviceAvailability:Failed to ping 0x0017880104c994d1 LWB010
    zigbee.0
    2024-01-11 18:42:39.867	warn	DeviceAvailability:Failed to ping 0x00158d000327a0bb ZBT-ColorTemperature
    zigbee.0
    2024-01-11 18:42:39.861	warn	DeviceAvailability:Failed to ping 0x0017880100f5b6ef LCT001
    zigbee.0
    2024-01-11 18:42:39.784	warn	DeviceAvailability:Failed to ping 0x0017880102624546 LCT012
    zigbee.0
    2024-01-11 18:42:39.766	warn	DeviceAvailability:Failed to ping 0xbc33acfffe51626c TS011F
    zigbee.0
    2024-01-11 18:42:39.681	warn	DeviceAvailability:Failed to ping 0x00178801025f05a9 LCT003
    zigbee.0
    2024-01-11 18:42:39.422	warn	DeviceAvailability:Failed to ping 0xa4c13884528fe4cd TS011F
    zigbee.0
    2024-01-11 18:42:39.418	warn	DeviceAvailability:Failed to ping 0x0017880100e86284 LCT003
    zigbee.0
    2024-01-11 18:42:39.264	warn	DeviceAvailability:Failed to ping 0x0017880100e3af59 LCT001
    coyoteC Offline
    coyoteC Offline
    coyote
    @arteck mit dem inkonsistenten Start habe ich jetzt auch probiert, aber bleibt leider so. Log ist gleich mit meinem letzten Post. Noch ne Idee?
    • coyoteC coyote
      arteckA Offline
      arteckA Offline
      arteck
      @coyote
      aber die ganzen Lampen sind nicht verbunden.
      ja weil du das Netz mal geändert hast.und jetzt sind die Router (Lampen) weg.. wenn du glück hast kommen die wieder ..das dauert aber.. ansonsten neu pairen
      und lass die Finger von den Einstellungen ..wenn du es nicht brauchst
      coyoteC 1 Antwort Letzte Antwort
      • arteckA arteck
        @coyote
        coyoteC Offline
        coyoteC Offline
        coyote
        @arteck ja, ich will ja auch gar nicht in den Einstellungen rumfummeln. Leider war mir bis heute Mittag nicht ganz bewusst, dass sich was ändert, wenn ich in HA den Gateway anspreche.
        Egal, habe jetzt alle 38 Geräte neu gepairt, da die Sensoren zwar als verbunden angezeigt wurden, aber bei Änderung hat sich in Iob nichts getan.
        Also wie gesagt, Kopplungsmodus aktivieren und alles einmal kurz koppeln, momentan sieht es gut aus, nur bei der Netzkarte werden keine Verbindungen angezeigt.
        Ich lasse jetzt das Netz sich erst mal beruhigen, morgen schau ich dann ob alles passt.
        • coyoteC coyote
          arteckA Offline
          arteckA Offline
          arteck
          @coyote sagte in ZigBee neue Version 1.9.x:
          Netzkarte
          vergiss die Karte... schau ob die sensoren IMMEr die link_quality übermittlent..
          • arteckA arteck
            Netzkarte
            coyoteC Offline
            coyoteC Offline
            coyote
            @arteck ok. Wird link quality zyklisch übermittelt, auch von Sensoren?
            Sehe ich es jetzt richtig, dass ich keinen Parallelbetrieb mit HA machen kann. Also 2, ich nenn es mal Adapter, die auf das Zigbee Lan GW zugreifen.
            Konfiguriert ist ja alles in iobroker und in HA wollte ich mit zigbee2mqtt das GW ansprechen und so kam es zu der Inkonsistenz der IDs
            • coyoteC coyote
              arteckA Offline
              arteckA Offline
              arteck
              @coyote das geht nicht..
              du kannst aber zigbee2mqtt mit mosquitto aufsetzten
              und den zigbee2mqtt adapter nehmen.. das geht.somit greift nur zigbee2mqtt auf den coordinator
              • arteckA arteck
                coyoteC Offline
                coyoteC Offline
                coyote
                @arteck ok danke. Also wenn ich das mit beiden System nutzen möchte, auf beiden zigbee2mqtt aufsetzen und auf den coordinator zugreifen. Danke für die Info 👍
                • L Offline
                  locito09
                  schrieb am zuletzt editiert von locito09
                  So hab jetzt mal einen neuen Zigbee Cordinator gekauft von Texas Intrument LAUNCHXL-CC26X2R1 weil ich immer wieder diese Fehlermeldung hatte ( auch nach abziehen des Cordinators und erneut einstecken tipp von @arteck )
                  Send command to 0x04cf8cdf3c8e4d5c failed with no error code (SREQ '--> ZDO - extRouteDisc - {"dstAddr":47258,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)
                  Send command to 0x54ef44100088d6f5 failed with no error code (SREQ '--> ZDO - extRouteDisc - {"dstAddr":33166,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)
                  zigbee.0
                  2024-01-12 10:48:50.441	error	Send command to 0x54ef44100088d8c5 failed with no error code (SREQ '--> ZDO - extRouteDisc - {"dstAddr":42116,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)
                  zigbee.0
                  2024-01-12 10:48:50.426	error	Send command to 0x54ef44100088d9bd failed with no error code (SREQ '--> ZDO - extRouteDisc - {"dstAddr":24876,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)
                  zigbee.0
                  2024-01-12 10:48:50.412	error	Send command to 0x04cf8cdf3c8e4d5c failed with no error code (SREQ '--> ZDO - extRouteDisc - {"dstAddr":47258,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)
                  Send command to 0x00158d000286b630 failed with no error code (Timeout - 47769 - 1 - 11 - 6 - 11 after 10000ms)
                  Paar Tage hat es wieder funktioniert, doch jetzt erneut diese Fehlermeldungen
                  Firmware ist die neuste auf den cc26X2R1 und Zigbee die neuste vom Github
                  Geräte Total 96
                  Immer wieder bekomme ich auch diese Fehlermeldung auch nach mehrmals abziehen der Batterie:
                  State value to set for "zigbee.0.00158d0004aacb15.humidity" has value "654.36" greater than max "100"
                  B D 2 Antworten Letzte Antwort
                  • L locito09
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    Geräte Total 96
                    BigMike71
                    @locito09 said in ZigBee neue Version 1.9.x:
                    NWK_TABLE_FULL
                    das liegt an einem problem der Firmware, Koenkk versucht schon seit Monaten das Problem zu lösen, siehe https://github.com/Koenkk/Z-Stack-firmware/discussions/478
                    so wie ich das mitlese ist der Ti Support mit involviert und dieses Jahr mit einer Lösung zu rechnen...🤞
                    • L locito09
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      Geräte Total 96
                      dimaiv
                      @locito09
                      Firmware ?
                      Coordinator vorher?
                      ioBroker- NUC8i3 / Proxmox / VM
                      Node.js v22.21.0
                      NPM v10.9.4
                      JS controller 7.1.0
                      Admin 7.7.20
                      ZigBee Adapter 3.3.1alpha.0
                      Zigbee LAN Gateway CC2652P
                      Zigbee Firmware 20250321
                      L R 2 Antworten Letzte Antwort
                      • D dimaiv
                        @locito09
                        Firmware ?
                        Coordinator vorher?
                        locito09
                        @dimaiv
                        Firmware war die gleiche wie vorher und cordinator auch, wurde nur durch einen neuen ersetzt
                        • D dimaiv
                          @locito09
                          Firmware ?
                          Coordinator vorher?
                          rewenode
                          @arteck Habe leider zu spät gesehen, dass die v 1.9 nodejs V18 braucht.
                          Das bekomme ich in meiner Docker-Installation nicht auf die Schnelle geregelt.
                          Wie komme ich schnell auf die 1.8.24 zurück?
                          Auf der Kachel gehts nur bis 1.9.0 zurück.
                          ...immer wenns schnell gehen soll..
                          Schon mal Danke für die Hilfe
                          Reiner
                          • L locito09
                            @dimaiv
                            dimaiv
                            @locito09
                            Dann, viel Glück.
                            Node.js v22.21.0
                            NPM v10.9.4
                            JS controller 7.1.0
                            Admin 7.7.20
                            • R rewenode
                              Reiner
                              @rewenode sagte in ZigBee neue Version 1.9.x:
                              Neuen Docker ausrollen, fertig. Geht doch immer total easy mit den Dockern.
                              R 1 Antwort Letzte Antwort
                                rewenode
                                @thomas-braun Ja, hast absolut recht. Habe ich auch gerade getan. Hat keine 10min gedauert und alles ok.
                                Problem bei mir, weshalb ich gezögert habe ist der Rock64 auf dem das alles läuft. Da brauche ich ein Image was arm64v7 unterstützt. Ist bei buanet:latest zum Glück der Fall. Leider gilt das nicht mehr für alle meine Container (z.B. Grafana)
                                Da geht die Sucherei dann los.
                                • arteckA arteck
                                  es gibt mal eine neue Version mit zahlreichen Korrekturen und neun Geräten
                                  ich verweise auch mal wieder auf die Überarbeitete Doku (danke Stefan)
                                  leider sind auch paar Fehler resultierend aus der Converter Überabreitung wo ich kein Einfluss habe
                                  bekannte Probleme :
                                  • IKEA Lampen : bei einschalten kommt ein Fehler (hab keine hier, kann den fehler nicht nachstellen)
                                  LatziL Online
                                  LatziL Online
                                  Latzi
                                  @arteck
                                  ich verwende diesen Schalter mit Leistungsmessung (https://www.zigbee2mqtt.io/devices/SSM-U01.html), läuft soweit, jedoch kommen keine Leistungsdaten. Mit Ausschliessen tritt keine Veränderung ein.
                                  Hier die Daten zu dem guten Teil:
                                  DP's im Objektbaum:
                                  Hast du eine Rat für mich?
                                  • LatziL Latzi
                                    @arteck
                                    DP's im Objektbaum:
                                    dimaiv
                                    @latzi
                                    Hi. Erst mal Zigbee Adapter aktualisieren auf 1.10.2, dann weiter forschen, wenn noch nötig .
                                    Node.js v22.21.0
                                    NPM v10.9.4
                                    JS controller 7.1.0
                                    Admin 7.7.20
                                    LatziL 1 Antwort Letzte Antwort
                                    • D dimaiv
                                      @latzi
                                      LatziL Online
                                      LatziL Online
                                      Latzi
                                      @dimaiv sagte in ZigBee neue Version 1.9.x:
                                      ich war schon auf 1.10.2 ;-)
                                      • LatziL Latzi
                                        dimaiv
                                        @latzi
                                        Heute wurden die Converter im Zigbee Adapter auf Github aktualisiert, damit wurden viele Converter-Fehler behoben.
                                        Probier mal dein Zigbee Adapter über die Katze/Github jetzt noch mal aktualisieren.
                                        Node.js v22.21.0
                                        NPM v10.9.4
                                        JS controller 7.1.0
                                        Admin 7.7.20
                                        • D dimaiv
                                          @latzi
                                          LatziL Online
                                          LatziL Online
                                          Latzi
                                          schrieb am zuletzt editiert von Latzi
                                          @dimaiv
                                          Vielen Dank für die Info!
                                          Leider hat es zu keiner Änderung geführt, die DP's sind immer noch (null)
